[mapguide-commits] r5639 - in trunk/Tools/Maestro/MaestroAPITests: . UserTestData
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Mar 18 19:52:52 EDT 2011
Author: jng
Date: 2011-03-18 16:52:52 -0700 (Fri, 18 Mar 2011)
New Revision: 5639
Added:
   trunk/Tools/Maestro/MaestroAPITests/UserTestData/NASA_WMS_config_doc.xml
   trunk/Tools/Maestro/MaestroAPITests/ConfigurationTests.cs
   trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj
Add WMS configuration unit test
Modified: trunk/Tools/Maestro/MaestroAPITests/ConfigurationTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/ConfigurationTests.cs	2011-03-18 23:38:17 UTC (rev 5638)
+++ trunk/Tools/Maestro/MaestroAPITests/ConfigurationTests.cs	2011-03-18 23:52:52 UTC (rev 5639)
@@ -25,6 +25,7 @@
 using OSGeo.MapGuide.MaestroAPI.SchemaOverrides;
 using OSGeo.MapGuide.ObjectModels.Common;
 using System.IO;
+using System.Drawing;
 namespace MaestroAPITests
@@ -136,11 +137,71 @@
+        [Test]
+        public void TestWmsLoad()
+            var conf = ConfigurationDocument.LoadXml(File.ReadAllText("UserTestData\\NASA_WMS_config_doc.xml")) as WmsConfigurationDocument;
+            Assert.NotNull(conf);
         [Test]
         public void TestWmsSaveLoad()
+            var conf = new WmsConfigurationDocument();
+            var schema = new FeatureSchema("WMS", "");
+            var cls = new ClassDefinition("NASAWMSGlobalPan", "");
+            cls.AddProperty(new DataPropertyDefinition("Id", "")
+                DataType = DataPropertyType.String,
+                Length = 256,
+                IsNullable = false
+            }, true);
+            cls.AddProperty(new RasterPropertyDefinition("Image", "")
+                DefaultImageXSize = 800,
+                DefaultImageYSize = 800
+            schema.AddClass(cls);
+            conf.AddSchema(schema);
+            var item = new RasterWmsItem(cls.Name, "Image");
+            item.ImageFormat = RasterWmsItem.WmsImageFormat.PNG;
+            item.IsTransparent = true;
+            item.BackgroundColor = ColorTranslator.FromHtml("#FFFFFF");
+            item.Time = "current";
+            item.ElevationDimension = "0";
+            item.SpatialContextName = "EPSG:4326";
+            for (int i = 0; i < 5; i++)
+                item.AddLayer(new WmsLayerDefinition("Layer" + i));
+            conf.AddRasterItem(item);
+            string path = "WmsConfigTest.xml";
+            File.WriteAllText(path, conf.ToXml());
+            conf = null;
+            string xml = File.ReadAllText(path);
+            conf = ConfigurationDocument.LoadXml(xml) as WmsConfigurationDocument;
+            Assert.AreEqual(1, conf.RasterOverrides.Length);
+            var ritem = conf.RasterOverrides[0];
+            Assert.AreEqual(item.ImageFormat, ritem.ImageFormat);
+            Assert.AreEqual(item.IsTransparent, ritem.IsTransparent);
+            Assert.AreEqual(item.BackgroundColor, ritem.BackgroundColor);
+            Assert.AreEqual(item.Time, ritem.Time);
+            Assert.AreEqual(item.ElevationDimension, ritem.ElevationDimension);
+            Assert.AreEqual(item.SpatialContextName, ritem.SpatialContextName);
+            Assert.AreEqual(5, item.Layers.Length);
Modified: trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj
--- trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj	2011-03-18 23:38:17 UTC (rev 5638)
+++ trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj	2011-03-18 23:52:52 UTC (rev 5639)
@@ -585,6 +585,9 @@
     <Content Include="TestData\Wms\Sheboygan_CityLimits_Layer_Header.xml">
       <CopyToOutputDirectory>Always</CopyToOutputDirectory>
     </Content>
+    <Content Include="UserTestData\NASA_WMS_config_doc.xml">
+      <CopyToOutputDirectory>Always</CopyToOutputDirectory>
+    </Content>
     <Content Include="UserTestData\odbc_example_config.xml">
     </Content>
Added: trunk/Tools/Maestro/MaestroAPITests/UserTestData/NASA_WMS_config_doc.xml
--- trunk/Tools/Maestro/MaestroAPITests/UserTestData/NASA_WMS_config_doc.xml	                        (rev 0)
+++ trunk/Tools/Maestro/MaestroAPITests/UserTestData/NASA_WMS_config_doc.xml	2011-03-18 23:52:52 UTC (rev 5639)
@@ -0,0 +1,49 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!-- This configuration document is from the Fdo WMS notes (http://trac.osgeo.org/fdo/wiki/FdoWmsNotes) -->
+<fdo:DataStore xmlns:fdo="http://fdo.osgeo.org/schemas" xmlns:gml="http://www.opengis.net/gml" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns="http://fdo.osgeo.org/schemas" xsi:schemaLocation="http://fdo.osgeo.org/schemas FdoDocument.xsd">
+  <xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" targetNamespace="http://fdo.osgeo.org/schemas/feature/WMS" xmlns:fdo="http://fdo.osgeo.org/schemas" xmlns:WMS="http://fdo.osgeo.org/schemas/feature/WMS" elementFormDefault="qualified" attributeFormDefault="unqualified">
+    <xs:element name="NASAWMSGlobalPan" type="WMS:NASAWMSGlobalPanType" abstract="false" substitutionGroup="gml:_Feature">
+      <xs:key name="NASAWMSGlobalPanKey">
+        <xs:selector xpath=".//NASAWMSGlobalPan"/>
+        <xs:field xpath="Id"/>
+      </xs:key>
+    </xs:element>
+    <xs:complexType name="NASAWMSGlobalPanType" abstract="false">
+      <xs:complexContent>
+        <xs:extension base="gml:AbstractFeatureType">
+          <xs:sequence>
+            <xs:element name="Id">
+              <xs:simpleType>
+                <xs:restriction base="xs:string">
+                  <xs:maxLength value="256"/>
+                </xs:restriction>
+              </xs:simpleType>
+            </xs:element>
+            <xs:element name="Image" type="fdo:RasterPropertyType" fdo:defaultImageXSize="800" fdo:defaultImageYSize="600">
+              <xs:annotation>
+                <xs:appinfo source="http://fdo.osgeo.org/schemas">
+                  <fdo:DefaultDataModel organization="Row" bitsPerPixel="32" tileSizeX="100" tileSizeY="100"/>
+                </xs:appinfo>
+              </xs:annotation>
+            </xs:element>
+          </xs:sequence>
+        </xs:extension>
+      </xs:complexContent>
+    </xs:complexType>
+  </xs:schema>
+  <SchemaMapping provider="OSGeo.WMS.3.1" name="WMS" xmlns="http://fdowms.osgeo.org/schemas">
+    <complexType name="NASAWMSGlobalPanType">
+      <RasterDefinition name="Image">
+        <Format>PNG</Format>
+        <Transparent>true</Transparent>
+        <BackgroundColor>0xFFFFFF</BackgroundColor>
+        <Time>current</Time>
+        <Elevation>0</Elevation>
+        <SpatialContext>EPSG:4326</SpatialContext>
+        <Layer name="global_mosaic">
+          <Style/>
+        </Layer>
+      </RasterDefinition>
+    </complexType>
+  </SchemaMapping>
+</fdo:DataStore>
More information about the mapguide-commits mailing list
