[mapguide-commits] r5645 - in trunk/Tools/Maestro: Maestro.Base/Editor Maestro.Base/Properties Maestro.Editors/MapDefinition OSGeo.MapGuide.MaestroAPI/Properties OSGeo.MapGuide.MaestroAPI/Resource/Validation
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Mar 21 07:07:41 EDT 2011
Author: jng
Date: 2011-03-21 04:07:41 -0700 (Mon, 21 Mar 2011)
New Revision: 5645
   trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.cs
   trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
   trunk/Tools/Maestro/Maestro.Editors/MapDefinition/ManualScaleEditor.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/MapDefinition/ManualScaleEditor.resx
   trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
   trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapTreeModels.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/MapDefinitionValidator.cs
#1631: Fix the following defects in the Map Definition editor:
 - Deleting layers does not clear the layer editor
 - Deleting folders does not clear the folder editor
 - Dropping a Layer Definition into a Base Layer Group will not add it to the group, but rather creates a new base layer group instead.
 - It is possible for System.NullReferenceException? to occur when adding the first layer to a Map Definition due to the fact that it naively assumes that obtaining the extents for the layer will always succeed.
 - Manual Scale List editor textbox does not allow the return keypress
 - Add a new validation rule: A map definition with 1 or more base layer groups, must have 1 or more finite scale ranges defined.
 - Editing the legend label incorrectly updates the layer display. This should be happening to the name component instead.
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.cs	2011-03-21 10:08:22 UTC (rev 5644)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.cs	2011-03-21 11:07:41 UTC (rev 5645)
@@ -50,13 +50,27 @@
         protected override void OnBeforeSave(object sender, CancelEventArgs e)
+            var mdf = (IMapDefinition)_edsvc.GetEditedResource();
+            //Unfortunately we can't hook in the standard validation as the act of
+            //committing the xml content back, will trigger the invalid XML content error
+            //before the standard validation is performed. So check this one particular
+            //validation rule here before we go ahead
+            if (mdf.BaseMap != null && mdf.BaseMap.HasLayers())
+                if (mdf.BaseMap.ScaleCount == 0)
+                    MessageService.ShowMessage(Properties.Resources.NoFiniteDisplayScalesSpecified);
+                    e.Cancel = true;
+                    return;
             if (_edsvc.IsNew)
                 base.OnBeforeSave(sender, e);
                 return;
-            var mdf = (IMapDefinition)_edsvc.GetEditedResource();
             if (mdf.BaseMap != null)
                 if (mdf.BaseMap.HasLayers())
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs	2011-03-21 10:08:22 UTC (rev 5644)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs	2011-03-21 11:07:41 UTC (rev 5645)
@@ -1158,6 +1158,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to This Map Definition has tiled layers but has no finite display scales defined. Define some display scales..
+        /// </summary>
+        internal static string NoFiniteDisplayScalesSpecified {
+            get {
+                return ResourceManager.GetString("NoFiniteDisplayScalesSpecified", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to The following resources were not copied or moved because they would be overwriting resources currently open: {0}The following resources were not moved because they are currently open: {1}.
         /// </summary>
         internal static string NotCopiedOrMovedDueToOpenEditors {
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx	2011-03-21 10:08:22 UTC (rev 5644)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx	2011-03-21 11:07:41 UTC (rev 5645)
@@ -874,4 +874,7 @@
   <data name="ItemsNotMovedDueToBeingOpen" xml:space="preserve">
     <value>The following items were not moved due to being already open in an editor: {0}</value>
   </data>
+  <data name="NoFiniteDisplayScalesSpecified" xml:space="preserve">
+    <value>This Map Definition has tiled layers but has no finite display scales defined. Define some display scales.</value>
+  </data>
 </root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/ManualScaleEditor.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/ManualScaleEditor.Designer.cs	2011-03-21 10:08:22 UTC (rev 5644)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/ManualScaleEditor.Designer.cs	2011-03-21 11:07:41 UTC (rev 5645)
@@ -36,6 +36,7 @@
             // txtScales
+            this.txtScales.AcceptsReturn = true;
             resources.ApplyResources(this.txtScales, "txtScales");
             this.txtScales.Name = "txtScales";
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/ManualScaleEditor.resx
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/ManualScaleEditor.resx	2011-03-21 10:08:22 UTC (rev 5644)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/ManualScaleEditor.resx	2011-03-21 11:07:41 UTC (rev 5645)
@@ -129,6 +129,9 @@
   <data name="txtScales.Multiline" type="System.Boolean, mscorlib">
     <value>True</value>
   </data>
+  <data name="txtScales.ScrollBars" type="System.Windows.Forms.ScrollBars, System.Windows.Forms">
+    <value>Vertical</value>
+  </data>
   <data name="txtScales.Size" type="System.Drawing.Size, System.Drawing">
     <value>267, 219</value>
   </data>
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs	2011-03-21 10:08:22 UTC (rev 5644)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs	2011-03-21 11:07:41 UTC (rev 5645)
@@ -159,6 +159,7 @@
             var group = GetSelectedLayerGroupItem() as GroupItem;
             _map.RemoveGroup(group.Tag);
+            propertiesPanel.Controls.Clear();
             _grpLayerModel.Invalidate();
@@ -183,6 +184,7 @@
             if (layer != null)
                 _map.RemoveLayer(layer.Tag);
                 this.RefreshModels();
@@ -217,6 +219,7 @@
             if (layer != null)
@@ -377,6 +380,7 @@
             if (group != null)
                 _map.BaseMap.RemoveBaseLayerGroup(group.Tag);
                 _tiledLayerModel.Invalidate();
@@ -476,6 +480,7 @@
                 var grp = layer.Parent;
                 grp.RemoveBaseMapLayer(layer.Tag);
@@ -770,7 +775,7 @@
             var rids = e.Data.GetData(typeof(ResourceIdentifier[])) as ResourceIdentifier[];
             if (rids != null && rids.Length > 0)
-                var node = trvLayersGroup.GetNodeAt(trvLayersGroup.PointToClient(new Point(e.X, e.Y)));
+                var node = trvBaseLayers.GetNodeAt(trvBaseLayers.PointToClient(new Point(e.X, e.Y)));
                 IBaseMapGroup group = null;
                 if (node != null && node.Tag is BaseLayerGroupItem)
@@ -783,14 +788,14 @@
                     _map.InitBaseMap();
                     group = _map.BaseMap.AddBaseLayerGroup(GenerateBaseGroupName(_map));
-                    foreach (var rid in rids)
+                foreach (var rid in rids)
+                    if (rid.ResourceType == ResourceTypes.LayerDefinition)
-                        if (rid.ResourceType == ResourceTypes.LayerDefinition)
-                            group.AddLayer(GenerateBaseLayerName(rid.ToString(), _map.BaseMap), rid.ToString());
-                            added++;
+                        group.AddLayer(GenerateBaseLayerName(rid.ToString(), _map.BaseMap), rid.ToString());
+                        added++;
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapTreeModels.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapTreeModels.cs	2011-03-21 10:08:22 UTC (rev 5644)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapTreeModels.cs	2011-03-21 11:07:41 UTC (rev 5645)
@@ -61,9 +61,9 @@
         void OnPropertyChanged(object sender, PropertyChangedEventArgs e)
-            if (e.PropertyName == "LegendLabel")
+            if (e.PropertyName == "Name")
-                this.Text = this.Tag.LegendLabel;
+                this.Text = this.Tag.Name;
@@ -78,9 +78,9 @@
@@ -102,9 +102,9 @@
@@ -119,9 +119,9 @@
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs	2011-03-21 10:08:22 UTC (rev 5644)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs	2011-03-21 11:07:41 UTC (rev 5645)
@@ -809,6 +809,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to The Map Definition contains tiled layers but has no finite display scales defined.
+        /// </summary>
+        internal static string MDF_NoFiniteDisplayScalesSpecified {
+            get {
+                return ResourceManager.GetString("MDF_NoFiniteDisplayScalesSpecified", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to {0} is a raster layer, and in another coordinate system than the map. No data will be displayed by the layer.
         /// </summary>
         internal static string MDF_RasterReprojectionError {
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx	2011-03-21 10:08:22 UTC (rev 5644)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx	2011-03-21 11:07:41 UTC (rev 5645)
@@ -485,4 +485,7 @@
   <data name="UnknownSymbolDefVersion" xml:space="preserve">
     <value>Unknown Symbol Definition version: </value>
   </data>
+  <data name="MDF_NoFiniteDisplayScalesSpecified" xml:space="preserve">
+    <value>The Map Definition contains tiled layers but has no finite display scales defined</value>
+  </data>
 </root>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/MapDefinitionValidator.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/MapDefinitionValidator.cs	2011-03-21 10:08:22 UTC (rev 5644)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/MapDefinitionValidator.cs	2011-03-21 11:07:41 UTC (rev 5645)
@@ -69,10 +69,16 @@
                 layers.Add(l);
             if (mdef.BaseMap != null && mdef.BaseMap.HasGroups())
+                if (mdef.BaseMap.ScaleCount == 0)
+                    issues.Add(new ValidationIssue(mdef, ValidationStatus.Error, Properties.Resources.MDF_NoFiniteDisplayScalesSpecified));
                 foreach (IBaseMapGroup g in mdef.BaseMap.BaseMapLayerGroup)
                     foreach (IBaseMapLayer l in g.BaseMapLayer)
                         layers.Add(l);
             Dictionary<string, IBaseMapLayer> nameCounter = new Dictionary<string, IBaseMapLayer>();
             foreach (IBaseMapLayer l in layers)
More information about the mapguide-commits mailing list
