[mapguide-commits] r5648 - in trunk/Tools/Maestro: Maestro.Editors/MapDefinition OSGeo.MapGuide.MaestroAPI/ObjectModels
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Mar 21 08:40:41 EDT 2011
Author: jng
Date: 2011-03-21 05:40:40 -0700 (Mon, 21 Mar 2011)
New Revision: 5648
   trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinitionInterfaces.cs
#1631: Fix Drag/drop reordering of layers in a base layer group does nothing
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs	2011-03-21 11:58:26 UTC (rev 5647)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs	2011-03-21 12:40:40 UTC (rev 5648)
@@ -907,10 +907,11 @@
         private void trvBaseLayers_DragDrop(object sender, DragEventArgs e)
-            int added = 0;
             var rids = e.Data.GetData(typeof(ResourceIdentifier[])) as ResourceIdentifier[];
+            var data = e.Data.GetData(typeof(TreeNodeAdv[])) as TreeNodeAdv[];
             if (rids != null && rids.Length > 0)
+                int added = 0;
                 var node = trvBaseLayers.GetNodeAt(trvBaseLayers.PointToClient(new Point(e.X, e.Y)));
                 IBaseMapGroup group = null;
@@ -934,11 +935,59 @@
                         added++;
+                if (added > 0)
+                    _tiledLayerModel.Invalidate();
+            else if (data != null && data.Length == 1)
+                var li = data[0].Tag as BaseLayerItem;
+                if (li != null)
+                    IBaseMapLayer sourceLayer = li.Tag;
+                    IBaseMapLayer targetLayer = null;
+                    IBaseMapGroup targetGroup = null;
+                    var node = trvBaseLayers.GetNodeAt(trvBaseLayers.PointToClient(new Point(e.X, e.Y)));
+                    if (node != null)
+                        var tli = node.Tag as BaseLayerItem;
+                        var tlg = node.Tag as BaseLayerGroupItem;
+                        if (tli != null)
+                            targetLayer = tli.Tag;
+                        else if (tlg != null)
+                            targetGroup = tlg.Tag;
-            if (added > 0)
-                _tiledLayerModel.Invalidate();
+                    if (sourceLayer != null && targetLayer != null && sourceLayer != targetLayer)
+                        var srcGroup = _map.BaseMap.GetGroupForLayer(sourceLayer);
+                        var dstGroup = _map.BaseMap.GetGroupForLayer(targetLayer);
+                        if (srcGroup != null)
+                            if (srcGroup == dstGroup)
+                                int idx = srcGroup.GetIndex(targetLayer);
+                                if (idx >= 0)
+                                    srcGroup.RemoveBaseMapLayer(sourceLayer);
+                                    srcGroup.InsertLayer(idx, sourceLayer);
+                            else
+                                dstGroup.InsertLayer(0, targetLayer);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs	2011-03-21 11:58:26 UTC (rev 5647)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs	2011-03-21 12:40:40 UTC (rev 5648)
@@ -639,6 +639,25 @@
+        public int GetIndex(IBaseMapLayer layer)
+            var bl = layer as BaseMapLayerType;
+            if (bl != null)
+                return this.BaseMapLayer.IndexOf(bl);
+            return -1;
+        public void InsertLayer(int index, IBaseMapLayer layer)
+            if (bl != null)
+                this.BaseMapLayer.Insert(index, bl);
         public IBaseMapLayer AddLayer(string layerName, string resourceId)
             BaseMapLayerType layer = new BaseMapLayerType()
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinitionInterfaces.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinitionInterfaces.cs	2011-03-21 11:58:26 UTC (rev 5647)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinitionInterfaces.cs	2011-03-21 12:40:40 UTC (rev 5648)
@@ -250,6 +250,26 @@
         /// <summary>
+        /// Gets the parent group for the specified layer
+        /// </summary>
+        /// <param name="map"></param>
+        /// <param name="layer"></param>
+        /// <returns></returns>
+        public static IBaseMapGroup GetGroupForLayer(this IBaseMapDefinition map, IBaseMapLayer layer)
+            Check.NotNull(map, "map");
+            foreach (var group in map.BaseMapLayerGroup)
+                foreach (var tl in group.BaseMapLayer)
+                    if (tl == layer)
+                        return group;
+            return null;
+        /// <summary>
         /// Gets whether this base map group has tiled layers
         /// </summary>
         /// <param name="grp"></param>
@@ -640,6 +660,20 @@
         void RemoveBaseMapLayer(IBaseMapLayer layer);
         /// <summary>
+        /// Insert the base map layer at the specified index
+        /// </summary>
+        /// <param name="index"></param>
+        void InsertLayer(int index, IBaseMapLayer layer);
+        /// <summary>
+        /// Gets the index of the specified layer
+        /// </summary>
+        int GetIndex(IBaseMapLayer layer);
+        /// <summary>
         /// Moves the specified layer up.
         /// </summary>
         /// <param name="layer">The layer.</param>
More information about the mapguide-commits mailing list
