[mapguide-commits] r5662 - trunk/Tools/Maestro/Maestro.Base/UI
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Mar 28 06:41:30 EDT 2011
Author: jng
Date: 2011-03-28 03:41:30 -0700 (Mon, 28 Mar 2011)
New Revision: 5662
   trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.cs
#1642: Default with all categories selected and only start retaining previous selection when a template has been selected (ie. not cancelled)
Modified: trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.cs	2011-03-28 10:29:00 UTC (rev 5661)
+++ trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.cs	2011-03-28 10:41:30 UTC (rev 5662)
@@ -33,6 +33,7 @@
     public partial class NewResourceDialog : Form
+        private static bool _subsequentRun = false;
         private static List<string> _lastSelectedCategoies = new List<string>();
         private NewResourceDialog()
@@ -56,10 +57,25 @@
             lstCategories.DataSource = _nits.GetCategories();
-            if (_lastSelectedCategoies.Count > 0)
+            if (_subsequentRun)
-                foreach (var cat in _lastSelectedCategoies)
+                if (_lastSelectedCategoies.Count > 0)
+                    foreach (var cat in _lastSelectedCategoies)
+                        var idx = lstCategories.Items.IndexOf(cat);
+                        if (idx >= 0)
+                            lstCategories.SetSelected(idx, true);
+            else
+                //First run, select all categories
+                foreach (var cat in _nits.GetCategories())
                     if (idx >= 0)
@@ -207,6 +223,9 @@
                 _lastSelectedCategoies.Add(item.ToString());
+            if (!_subsequentRun)
+                _subsequentRun = true;
         private void lstTemplates_MouseDoubleClick(object sender, MouseEventArgs e)
More information about the mapguide-commits mailing list
