[mapguide-commits] r5668 - trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Gdal
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Mar 29 09:34:27 EDT 2011
Author: jng
Date: 2011-03-29 06:34:26 -0700 (Tue, 29 Mar 2011)
New Revision: 5668
   trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Gdal/CompositeFileCtrl.cs
#1067: Instead of doing what is described in the ticket, let's attack the underlying problem. The GDAL configuration document being built used a logical raster property named "Image" instead of the GDAL default of "Raster". The document generation code now uses the same logical raster property name as what GDAL spits out by default. This way no affected layers will be broken when a GDAL configuration document is rebuilt. Also along the way, I found a UI defect when rebuilding the config doc (the existing UI file items weren't being removed). This has also been fixed with this submission
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Gdal/CompositeFileCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Gdal/CompositeFileCtrl.cs	2011-03-29 13:08:57 UTC (rev 5667)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Gdal/CompositeFileCtrl.cs	2011-03-29 13:34:26 UTC (rev 5668)
@@ -102,7 +102,7 @@
         // This should really come from GetSchemaMapping, but it's broken:  minX, minY, maxX, maxY
         private const string TEMPLATE_CFG = "<?xml version=\"1.0\" encoding=\"UTF-8\"?><fdo:DataStore xmlns:xs=\"http://www.w3.org/2001/XMLSchema\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xmlns:xlink=\"http://www.w3.org/1999/xlink\" xmlns:gml=\"http://www.opengis.net/gml\" xmlns:fdo=\"http://fdo.osgeo.org/schemas\" xmlns:fds=\"http://fdo.osgeo.org/schemas/fds\"><gml:DerivedCRS gml:id=\"Default\"><gml:metaDataProperty><gml:GenericMetaData><fdo:SCExtentType>dynamic</fdo:SCExtentType><fdo:XYTolerance>0.001000</fdo:XYTolerance><fdo:ZTolerance>0.001000</fdo:ZTolerance></gml:GenericMetaData></gml:metaDataProperty><gml:remarks>System generated default FDO Spatial Context</gml:remarks><gml:srsName>Default</gml:srsName><gml:validArea><gml:boundingBox><gml:pos>{0} {1}</gml:pos><gml:pos>{2} {3}</gml:pos></gml:boundingBox></gml:validArea><gml:baseCRS>" +
             "<fdo:WKTCRS gml:id=\"Default\"><gml:srsName>Default</gml:srsName><fdo:WKT>LOCAL_CS[\"*XY-MT*\",LOCAL_DATUM[\"*X-Y*\",10000],UNIT[\"Meter\", 1],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH]]</fdo:WKT></fdo:WKTCRS></gml:baseCRS><gml:definedByConversion xlink:href=\"http://fdo.osgeo.org/coord_conversions#identity\"/><gml:derivedCRSType codeSpace=\"http://fdo.osgeo.org/crs_types\">geographic</gml:derivedCRSType><gml:usesCS xlink:href=\"http://fdo.osgeo.org/cs#default_cartesian\"/></gml:DerivedCRS><xs:schema xmlns:xs=\"http://www.w3.org/2001/XMLSchema\" xmlns:fdo=\"http://fdo.osgeo.org/schemas\" xmlns:gml=\"http://www.opengis.net/gml\" xmlns:default=\"http://fdo.osgeo.org/schemas/feature/default\" targetNamespace=\"http://fdo.osgeo.org/schemas/feature/default\" elementFormDefault=\"qualified\" attributeFormDefault=\"unqualified\"><xs:annotation><xs:appinfo source=\"http://fdo.osgeo.org/schemas\"/></xs:annotation><xs:element name=\"default\" type=\"default:defaultType\" abstract
 =\"false\" substitutionGroup=\"gml:_Feature\"><xs:key name=\"defaultKey\"><xs:selector xpath=\".//default\"/>" +
-            "<xs:field xpath=\"FeatId\"/></xs:key></xs:element><xs:complexType name=\"defaultType\" abstract=\"false\" fdo:hasGeometry=\"false\"><xs:annotation><xs:appinfo source=\"http://fdo.osgeo.org/schemas\"/></xs:annotation><xs:complexContent><xs:extension base=\"gml:AbstractFeatureType\"><xs:sequence><xs:element name=\"FeatId\"><xs:annotation><xs:appinfo source=\"http://fdo.osgeo.org/schemas\"/></xs:annotation><xs:simpleType><xs:restriction base=\"xs:string\"><xs:maxLength value=\"256\"/></xs:restriction></xs:simpleType></xs:element><xs:element name=\"Image\" type=\"fdo:RasterPropertyType\" fdo:defaultImageXSize=\"1024\" fdo:defaultImageYSize=\"1024\" fdo:srsName=\"Default\"><xs:annotation>" +
+            "<xs:field xpath=\"FeatId\"/></xs:key></xs:element><xs:complexType name=\"defaultType\" abstract=\"false\" fdo:hasGeometry=\"false\"><xs:annotation><xs:appinfo source=\"http://fdo.osgeo.org/schemas\"/></xs:annotation><xs:complexContent><xs:extension base=\"gml:AbstractFeatureType\"><xs:sequence><xs:element name=\"FeatId\"><xs:annotation><xs:appinfo source=\"http://fdo.osgeo.org/schemas\"/></xs:annotation><xs:simpleType><xs:restriction base=\"xs:string\"><xs:maxLength value=\"256\"/></xs:restriction></xs:simpleType></xs:element><xs:element name=\"Raster\" type=\"fdo:RasterPropertyType\" fdo:defaultImageXSize=\"1024\" fdo:defaultImageYSize=\"1024\" fdo:srsName=\"Default\"><xs:annotation>" +
             "<xs:appinfo source=\"http://fdo.osgeo.org/schemas\"><fdo:DefaultDataModel dataModelType=\"Bitonal\" dataType=\"Unknown\" organization=\"Pixel\" bitsPerPixel=\"1\" tileSizeX=\"256\" tileSizeY=\"256\"/></xs:appinfo></xs:annotation></xs:element></xs:sequence></xs:extension></xs:complexContent></xs:complexType></xs:schema><SchemaMapping xmlns=\"http://fdogrfp.osgeo.org/schemas\" provider=\"OSGeo.Gdal.3.2\" name=\"default\"></SchemaMapping></fdo:DataStore>";
@@ -141,6 +141,7 @@
                 files.Add(item.Text);
+            lstView.Clear(); //Clear now. It will be repopulated after rebuild
             DoUpdateConfiguration(files.ToArray(), new string[0]);
@@ -216,6 +217,23 @@
             var result = new UpdateConfigResult() { Added = new List<string>(), Removed = new List<string>() };
+            //Remove first
+            foreach (var remove in toRemove)
+                var dir = Path.GetDirectoryName(remove);
+                var loc = FindLocation(conf, dir);
+                if (null != loc)
+                    loc.RemoveItem(Path.GetFileName(remove));
+                    result.Removed.Add(remove);
+                    if (loc.Items.Length == 0)
+                        conf.RemoveLocation(loc);
+                progress += unit;
+                worker.ReportProgress(progress, string.Format(Properties.Resources.ProcessedItem, remove));
+            //Then add
             foreach (var add in toAdd)
                 var dir = Path.GetDirectoryName(add);
@@ -260,21 +278,6 @@
                 worker.ReportProgress(progress, string.Format(Properties.Resources.ProcessedItem, add));
-            foreach (var remove in toRemove)
-                var dir = Path.GetDirectoryName(remove);
-                var loc = FindLocation(conf, dir);
-                if (null != loc)
-                    loc.RemoveItem(Path.GetFileName(remove));
-                    result.Removed.Add(remove);
-                    if (loc.Items.Length == 0)
-                        conf.RemoveLocation(loc);
-                progress += unit;
-                worker.ReportProgress(progress, string.Format(Properties.Resources.ProcessedItem, remove));
             return result;
More information about the mapguide-commits mailing list
