[mapguide-commits] r6194 - in trunk/Installer: . Custom/apache_actions Custom/iis_actions FdoRegUtil Installers/MapGuide Libraries/CS Map Libraries/MapGuide Server Libraries/MapGuide Web Extensions Support/Web/x64 Support/Web/x64/Apache2/conf Support/Web/x64/FDO Support/Web/x86/configs Support/Web/x86/configs/Apache2/conf Support/Web/x86/configs/FDO
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Nov 1 02:00:35 EDT 2011
Author: jng
Date: 2011-10-31 23:00:35 -0700 (Mon, 31 Oct 2011)
New Revision: 6194
Added:
   trunk/Installer/Custom/apache_actions/resource.h
   trunk/Installer/Custom/apache_actions/resources.aps
   trunk/Installer/Custom/apache_actions/resources.rc
   trunk/Installer/Custom/iis_actions/resource.h
   trunk/Installer/Custom/iis_actions/resources.aps
   trunk/Installer/Custom/iis_actions/resources.rc
   trunk/Installer/Support/Web/x64/FDO/
   trunk/Installer/Support/Web/x64/FDO/providers.xml
   trunk/Installer/Support/Web/x86/configs/FDO/
   trunk/Installer/Support/Web/x86/configs/FDO/providers.xml
   trunk/Installer/Custom/apache_actions/apache_actions.cpp
   trunk/Installer/Custom/apache_actions/apache_actions.vcproj
   trunk/Installer/Custom/iis_actions/iis_actions.vcproj
   trunk/Installer/FdoRegUtil/FdoRegUtil.cpp
   trunk/Installer/FdoRegUtil/stdafx.h
   trunk/Installer/Installers/MapGuide/MapGuide.wixproj
   trunk/Installer/Installers/MapGuide/MapGuide.wxs
   trunk/Installer/Libraries/CS Map/CS Map.wixproj
   trunk/Installer/Libraries/CS Map/CSMap.wxs
   trunk/Installer/Libraries/MapGuide Server/FDO.wxs
   trunk/Installer/Libraries/MapGuide Server/InstallService.wxs
   trunk/Installer/Libraries/MapGuide Server/MapGuide Server.wixproj
   trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs
   trunk/Installer/Libraries/MapGuide Web Extensions/IIS.wxs
   trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs
   trunk/Installer/Libraries/MapGuide Web Extensions/MapGuide Web Extensions.wixproj
   trunk/Installer/Libraries/MapGuide Web Extensions/Shortcuts.wxs
   trunk/Installer/Support/Web/x64/Apache2/conf/httpd.conf
   trunk/Installer/Support/Web/x86/configs/Apache2/conf/httpd.conf
   trunk/Installer/build.bat
   trunk/Installer/build64.bat
#1805: Installer changes:
 - Update to use WiX 3.5
 - Update FdoRegUtil.exe to use registration by library path (made possible with new APIs in FDO 3.6)
 - Add version resources to custom action projects (required by WiX 3.5)
 - Update CS-Map installer component to write the dictionary path to serverconfig.ini and webconfig.ini instead of the MENTOR_DICTIONARY_PATH environment variable
 - Update file offsets and version numbers
Modified: trunk/Installer/Custom/apache_actions/apache_actions.cpp
--- trunk/Installer/Custom/apache_actions/apache_actions.cpp	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/Custom/apache_actions/apache_actions.cpp	2011-11-01 06:00:35 UTC (rev 6194)
@@ -340,6 +340,9 @@
 			fout.close();
+        //Even if the java option is not the active API, perform these substitutions
+        //anyway on these files should they get installed.
 		szFileName = szApacheDir + "\\conf\\tomcat.conf";
 		const char* szTomcatConf = szFileName.c_str();
@@ -365,6 +368,31 @@
 			fout << buffer;
 			fout.close();
+        szFileName = szWebExtDir + "\\Tomcat\\conf\\Catalina\\localhost\\mapguide.xml";
+        const char* szMapGuideXml = szFileName.c_str();
+        if (FileExists(szMapGuideXml))
+            std::ifstream fin(szTomcatConf);
+			std::string buffer;
+			std::string line;
+			while(!fin.eof())
+				std::getline(fin, line);
+				//Process this line
+				FindAndReplace(line, "%MG_WEB_ROOT%", szWebRootDir);
+				buffer += line + "\n";
+			fin.close();
+			std::ofstream fout(szMapGuideXml);
+			fout << buffer;
+			fout.close();
 	return ERROR_SUCCESS;
Modified: trunk/Installer/Custom/apache_actions/apache_actions.vcproj
--- trunk/Installer/Custom/apache_actions/apache_actions.vcproj	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/Custom/apache_actions/apache_actions.vcproj	2011-11-01 06:00:35 UTC (rev 6194)
@@ -239,6 +239,10 @@
 			</File>
 			<File
+				RelativePath=".\resources.rc"
+			</File>
+			<File
 				RelativePath="StdAfx.cpp"
 				<FileConfiguration
@@ -269,6 +273,10 @@
 			</File>
 			<File
+				RelativePath=".\resource.h"
+			</File>
+			<File
 				RelativePath="StdAfx.h"
 			</File>
Added: trunk/Installer/Custom/apache_actions/resource.h
--- trunk/Installer/Custom/apache_actions/resource.h	                        (rev 0)
+++ trunk/Installer/Custom/apache_actions/resource.h	2011-11-01 06:00:35 UTC (rev 6194)
@@ -0,0 +1,15 @@
+//{{NO_DEPENDENCIES}}
+// Microsoft Visual C++ generated include file.
+// Used by resources.rc
+// Next default values for new objects
+#ifdef APSTUDIO_INVOKED
+#ifndef APSTUDIO_READONLY_SYMBOLS
+#define _APS_NEXT_RESOURCE_VALUE        103
+#define _APS_NEXT_COMMAND_VALUE         40001
+#define _APS_NEXT_CONTROL_VALUE         1001
+#define _APS_NEXT_SYMED_VALUE           101
+#endif
+#endif
Added: trunk/Installer/Custom/apache_actions/resources.aps
(Binary files differ)
Property changes on: trunk/Installer/Custom/apache_actions/resources.aps
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/Installer/Custom/apache_actions/resources.rc
--- trunk/Installer/Custom/apache_actions/resources.rc	                        (rev 0)
+++ trunk/Installer/Custom/apache_actions/resources.rc	2011-11-01 06:00:35 UTC (rev 6194)
@@ -0,0 +1,102 @@
+// Microsoft Visual C++ generated resource script.
+#include "resource.h"
+#define APSTUDIO_READONLY_SYMBOLS
+// Generated from the TEXTINCLUDE 2 resource.
+#include "afxres.h"
+#undef APSTUDIO_READONLY_SYMBOLS
+// English (Australia) resources
+#if !defined(AFX_RESOURCE_DLL) || defined(AFX_TARG_ENA)
+#ifdef _WIN32
+LANGUAGE LANG_ENGLISH, SUBLANG_ENGLISH_AUS
+#pragma code_page(1252)
+#endif //_WIN32
+// TEXTINCLUDE
+1 TEXTINCLUDE
+BEGIN
+    "resource.h\0"
+END
+2 TEXTINCLUDE
+BEGIN
+    "#include ""afxres.h""\r\n"
+    "\0"
+END
+3 TEXTINCLUDE
+BEGIN
+    "\r\n"
+    "\0"
+END
+#endif    // APSTUDIO_INVOKED
+// Version
+VS_VERSION_INFO VERSIONINFO
+ FILEVERSION 1,0,0,1
+ PRODUCTVERSION 1,0,0,1
+ FILEFLAGSMASK 0x17L
+#ifdef _DEBUG
+ FILEFLAGS 0x1L
+#else
+ FILEFLAGS 0x0L
+#endif
+ FILEOS 0x4L
+ FILETYPE 0x2L
+ FILESUBTYPE 0x0L
+BEGIN
+    BLOCK "StringFileInfo"
+    BEGIN
+        BLOCK "0c0904b0"
+        BEGIN
+            VALUE "CompanyName", "OSGeo"
+            VALUE "FileDescription", "MapGuide Open Source Installer Custom Action Library"
+            VALUE "FileVersion", "1, 0, 0, 1"
+            VALUE "InternalName", "apache_actions"
+            VALUE "LegalCopyright", "Copyright (C) 2011"
+            VALUE "OriginalFilename", "apache_actions.dll"
+            VALUE "ProductName", "MapGuide Open Source Installer Custom Action Library"
+            VALUE "ProductVersion", "1, 0, 0, 1"
+        END
+    END
+    BLOCK "VarFileInfo"
+    BEGIN
+        VALUE "Translation", 0xc09, 1200
+    END
+END
+#endif    // English (Australia) resources
+#ifndef APSTUDIO_INVOKED
+// Generated from the TEXTINCLUDE 3 resource.
+#endif    // not APSTUDIO_INVOKED
Modified: trunk/Installer/Custom/iis_actions/iis_actions.vcproj
--- trunk/Installer/Custom/iis_actions/iis_actions.vcproj	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/Custom/iis_actions/iis_actions.vcproj	2011-11-01 06:00:35 UTC (rev 6194)
@@ -61,7 +61,7 @@
 			<Tool
 				Name="VCLinkerTool"
-				AdditionalDependencies="msi.lib dutil.lib wcautil.lib"
+				AdditionalDependencies="version.lib msi.lib dutil_2008.lib wcautil_2008.lib"
 				LinkIncremental="2"
 				AdditionalLibraryDirectories="$(WIX)sdk\lib"
 				ModuleDefinitionFile="CustomAction.def"
@@ -137,7 +137,7 @@
 			<Tool
 				Name="VCLinkerTool"
 				LinkIncremental="1"
@@ -213,6 +213,10 @@
 			UniqueIdentifier="{93995380-89BD-4b04-88EB-625FBE52EBFB}"
 			<File
+			</File>
+			<File
 				RelativePath=".\stdafx.h"
 			</File>
@@ -226,6 +230,10 @@
 			Filter="rc;ico;cur;bmp;dlg;rc2;rct;bin;rgs;gif;jpg;jpeg;jpe;resx;tiff;tif;png;wav"
 			UniqueIdentifier="{67DA6AB6-F800-4c08-8B7A-83BB121AAD01}"
+			<File
+			</File>
 		</Filter>
 	</Files>
 	<Globals>
Added: trunk/Installer/Custom/iis_actions/resource.h
--- trunk/Installer/Custom/iis_actions/resource.h	                        (rev 0)
+++ trunk/Installer/Custom/iis_actions/resource.h	2011-11-01 06:00:35 UTC (rev 6194)
@@ -0,0 +1,14 @@
+#define _APS_NEXT_RESOURCE_VALUE        101
+#endif
+#endif
Added: trunk/Installer/Custom/iis_actions/resources.aps
Property changes on: trunk/Installer/Custom/iis_actions/resources.aps
Added: trunk/Installer/Custom/iis_actions/resources.rc
--- trunk/Installer/Custom/iis_actions/resources.rc	                        (rev 0)
+++ trunk/Installer/Custom/iis_actions/resources.rc	2011-11-01 06:00:35 UTC (rev 6194)
@@ -0,0 +1,101 @@
+#ifdef _WIN32
+#endif //_WIN32
+// TEXTINCLUDE
+1 TEXTINCLUDE
+BEGIN
+    "resource.h\0"
+END
+2 TEXTINCLUDE
+BEGIN
+    "\0"
+END
+3 TEXTINCLUDE
+BEGIN
+    "\r\n"
+    "\0"
+END
+// Version
+#ifdef _DEBUG
+ FILEFLAGS 0x1L
+#else
+ FILEFLAGS 0x0L
+#endif
+ FILEOS 0x4L
+ FILETYPE 0x2L
+ FILESUBTYPE 0x0L
+BEGIN
+    BEGIN
+        BLOCK "0c0904b0"
+        BEGIN
+            VALUE "InternalName", "iis_actions"
+            VALUE "OriginalFilename", "iis_actions.dll"
+        END
+    END
+    BEGIN
+    END
+END
Modified: trunk/Installer/FdoRegUtil/FdoRegUtil.cpp
--- trunk/Installer/FdoRegUtil/FdoRegUtil.cpp	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/FdoRegUtil/FdoRegUtil.cpp	2011-11-01 06:00:35 UTC (rev 6194)
@@ -3,47 +3,50 @@
 #include "stdafx.h"
-// usage: FdoRegUtil.exe [/r|/u] <provider name> <display name> <provider description> <version> <fdo version> <provider dll path>
+// usage: FdoRegUtil.exe [-r] <provider dll>
+//        FdoRegUtil.exe [-u] <provider name>
 int _tmain(int argc, _TCHAR* argv[])
 	int ret = 0;
 	if (argc == 3)
-		if(wcscmp(argv[1], L"-u") != 0)
-			goto usage;
-		ret = Unregister(argv[2]);
-		goto exit;
+		if(wcscmp(argv[1], L"-u") == 0)
+			ret = Unregister(argv[2]);
+        else if(wcscmp(argv[1], L"-r") == 0)
+			ret = Register(argv[2]);
+        else
+            Usage();
-	else if (argc == 8)
-		if(wcscmp(argv[1], L"-r") != 0)
-			goto usage;
-		ret = Register(argv[2], argv[3], argv[4], argv[5], argv[6], argv[7]);
-		goto exit;
-usage:
-	Usage();
-exit:
 	return ret;
 void Usage()
 	printf("usage\n");
-	printf("registering: FdoRegUtil.exe -r <provider name> <display name> <provider description> <version> <fdo version> <provider dll path>\n");
+	printf("registering: FdoRegUtil.exe -r <provider dll path>\n");
 	printf("unregistering: FdoRegUtil.exe -u <provider name>\n");
-int Register(_TCHAR* name, _TCHAR* displayName, _TCHAR* description, _TCHAR* version, _TCHAR* fdoVersion, _TCHAR* path)
+int Register(_TCHAR* path)
 	int ret = 0;
-	FdoPtr<IProviderRegistry> prvReg = FdoFeatureAccessManager::GetProviderRegistry();
+	FdoPtr<IProviderRegistry> provReg = FdoFeatureAccessManager::GetProviderRegistry();
+    FdoPtr<IConnectionManager> connMgr = FdoFeatureAccessManager::GetConnectionManager();
 	try
-		prvReg->RegisterProvider(name, displayName, description, version, fdoVersion, path, false);
+        //As of FDO 3.6 this supports FDO dll paths
+        FdoPtr<FdoIConnection> conn = connMgr->CreateConnection(path);
+        FdoPtr<FdoIConnectionInfo> connInfo = conn->GetConnectionInfo();
+        //FDO connections already have this information!
+        provReg->RegisterProvider(connInfo->GetProviderName(),
+                                  connInfo->GetProviderDisplayName(),
+                                  connInfo->GetProviderDescription(),
+                                  connInfo->GetProviderVersion(),
+                                  connInfo->GetFeatureDataObjectsVersion(),
+                                  path,
+                                  false);
 	catch(FdoException* ex)
Modified: trunk/Installer/FdoRegUtil/stdafx.h
--- trunk/Installer/FdoRegUtil/stdafx.h	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/FdoRegUtil/stdafx.h	2011-11-01 06:00:35 UTC (rev 6194)
@@ -10,7 +10,7 @@
 #include <stdio.h>
 #include <tchar.h>
-int Register(_TCHAR* name, _TCHAR* displayName, _TCHAR* description, _TCHAR* version, _TCHAR* fdoVersion, _TCHAR* path);
+int Register(_TCHAR* path);
 int Unregister(_TCHAR* name);
 void Usage();
Modified: trunk/Installer/Installers/MapGuide/MapGuide.wixproj
--- trunk/Installer/Installers/MapGuide/MapGuide.wixproj	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/Installers/MapGuide/MapGuide.wixproj	2011-11-01 06:00:35 UTC (rev 6194)
@@ -7,7 +7,7 @@
     <SchemaVersion>2.0</SchemaVersion>
     <OutputName Condition=" '$(OutputName)' == '' ">MapGuideOpenSource</OutputName>
     <OutputType>Package</OutputType>
-    <WixTargetsPath Condition=" '$(WixTargetsPath)' == '' ">$(MSBuildExtensionsPath)\Microsoft\WiX\v3.0\Wix.targets</WixTargetsPath>
+    <WixTargetsPath Condition=" '$(WixTargetsPath)' == '' ">$(MSBuildExtensionsPath)\Microsoft\WiX\v3.x\Wix.targets</WixTargetsPath>
     <Name>MapGuide</Name>
     <MgCulture Condition=" '$(MgCulture)'=='' ">en-US</MgCulture>
     <MgTitle Condition=" '$(MgTitle)'=='' ">MapGuide Open Source 2.1.0 Ux</MgTitle>
@@ -35,20 +35,6 @@
     <Compile Include="MapGuide.wxs" />
   </ItemGroup>
   <ItemGroup>
-    <WixExtension Include="WixIIsExtension">
-      <HintPath>$(WixExtDir)\WixIIsExtension.dll</HintPath>
-    </WixExtension>
-    <WixExtension Include="WixNetFxExtension">
-      <HintPath>$(WixExtDir)\WixNetFxExtension.dll</HintPath>
-    </WixExtension>
-    <WixExtension Include="WixUtilExtension">
-      <HintPath>$(WixExtDir)\WixUtilExtension.dll</HintPath>
-    </WixExtension>
-    <WixExtension Include="WixUIExtension">
-      <HintPath>$(WixExtDir)\WixUIExtension.dll</HintPath>
-    </WixExtension>
-  </ItemGroup>
-  <ItemGroup>
     <Content Include="Resources\InstallerLarge.bmp" />
     <Content Include="Resources\InstallerSmall.bmp" />
     <Content Include="Resources\LGPL21.rtf" />
@@ -78,6 +64,24 @@
     <EmbeddedResource Include="Lang\MapGuide_en-US.wxl" />
     <EmbeddedResource Include="Lang\MapGuide_es-ES.wxl" />
   </ItemGroup>
+  <ItemGroup>
+    <WixExtension Include="WixUtilExtension">
+      <HintPath>$(WixExtDir)\WixUtilExtension.dll</HintPath>
+      <Name>WixUtilExtension</Name>
+    </WixExtension>
+    <WixExtension Include="WixUIExtension">
+      <HintPath>$(WixExtDir)\WixUIExtension.dll</HintPath>
+      <Name>WixUIExtension</Name>
+    </WixExtension>
+    <WixExtension Include="WixNetFxExtension">
+      <HintPath>$(WixExtDir)\WixNetFxExtension.dll</HintPath>
+      <Name>WixNetFxExtension</Name>
+    </WixExtension>
+    <WixExtension Include="WixIIsExtension">
+      <HintPath>$(WixExtDir)\WixIIsExtension.dll</HintPath>
+      <Name>WixIIsExtension</Name>
+    </WixExtension>
+  </ItemGroup>
   <Import Project="$(WixTargetsPath)" />
 	To modify your build process, add your task inside one of the targets below and uncomment it.
Modified: trunk/Installer/Installers/MapGuide/MapGuide.wxs
--- trunk/Installer/Installers/MapGuide/MapGuide.wxs	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/Installers/MapGuide/MapGuide.wxs	2011-11-01 06:00:35 UTC (rev 6194)
@@ -47,16 +47,16 @@
         <Property Id="APP_POOL_NAME" Secure="yes" Value="MapGuideAppPool" />
         <Property Id="MGSERVER_IP" Secure="yes" Value="127.0.0.1" />
         <Property Id="APACHE_PORT" Secure="yes" Value="8008" />
-        <Property Id="APACHE_VERSION" Secure="yes" Value="2.2.11" />
-        <Property Id="PHP_VERSION" Secure="yes" Value="5.3.2" />
-        <Property Id="MG_VERSION_MAJOR_MINOR" Secure="yes" Value="2.3" />
+        <Property Id="APACHE_VERSION" Secure="yes" Value="2.2.21" />
+        <Property Id="PHP_VERSION" Secure="yes" Value="5.3.8" />
+        <Property Id="MG_VERSION_MAJOR_MINOR" Secure="yes" Value="2.4" />
         <!-- Server Port Settings  -->
         <Property Id="MG_ADMIN_PORT" Secure="yes" Value="2810" />
         <Property Id="MG_CLIENT_PORT" Secure="yes" Value="2811" />
         <Property Id="MG_SITE_PORT" Secure="yes" Value="2812" />
         <!-- Used by FdoRegUtil.exe -->
-        <Property Id="FDO_VERSION" Secure="yes" Value="3.6.0.0" />
-        <Property Id="FDO_VERSION_SMALL" Secure="yes" Value="3.6" />
+        <Property Id="FDO_VERSION" Secure="yes" Value="3.7.0.0" />
+        <Property Id="FDO_VERSION_SMALL" Secure="yes" Value="3.7" />
         These are currently static, though there is opportunity in the future for these
@@ -573,7 +573,8 @@
         <InstallExecuteSequence>
           <!-- IIS7 Base properties for deferred actions -->
-            <Custom Action="MapGuideIIS7_I_AppCmd_Cmd" After="CostFinalize">MGWEB_CONFIG=&quot;IIS&quot; AND IISVERSIONMAJOR=&quot;#7&quot; AND &amp;WebExtensionsFeature&gt;2</Custom>
+            <Custom Action="MapGuideIIS7_I_CreateFastCgi_Cmd" After="CostFinalize">MGWEB_CONFIG=&quot;IIS&quot; AND IISVERSIONMAJOR=&quot;#7&quot; AND &amp;WebExtensionsFeature&gt;2</Custom>
+            <Custom Action="MapGuideIIS7_I_AppCmd_Cmd" After="MapGuideIIS7_I_CreateFastCgi_Cmd">MGWEB_CONFIG=&quot;IIS&quot; AND IISVERSIONMAJOR=&quot;#7&quot; AND &amp;WebExtensionsFeature&gt;2</Custom>
             <Custom Action="MapGuideIIS7_I_CreateAppPool_Cmd" After="MapGuideIIS7_I_AppCmd_Cmd">MGWEB_CONFIG=&quot;IIS&quot; AND IISVERSIONMAJOR=&quot;#7&quot; AND &amp;WebExtensionsFeature&gt;2</Custom>
             <Custom Action="MapGuideIIS7_I_SetAppPoolProp_Cmd" After="MapGuideIIS7_I_CreateAppPool_Cmd">MGWEB_CONFIG=&quot;IIS&quot; AND IISVERSIONMAJOR=&quot;#7&quot; AND &amp;WebExtensionsFeature&gt;2</Custom>
             <Custom Action="MapGuideIIS7_I_UnlockSrvHandlers_Cmd" After="MapGuideIIS7_I_SetAppPoolProp_Cmd">MGWEB_CONFIG=&quot;IIS&quot; AND IISVERSIONMAJOR=&quot;#7&quot; AND &amp;WebExtensionsFeature&gt;2</Custom>
Modified: trunk/Installer/Libraries/CS Map/CS Map.wixproj
--- trunk/Installer/Libraries/CS Map/CS Map.wixproj	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/Libraries/CS Map/CS Map.wixproj	2011-11-01 06:00:35 UTC (rev 6194)
@@ -1,4 +1,4 @@
-<Project DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+<Project DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
   <PropertyGroup>
     <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
     <Platform Condition=" '$(Platform)' == '' ">x86</Platform>
@@ -7,7 +7,7 @@
     <OutputName>CS Map</OutputName>
     <OutputType>Library</OutputType>
     <MgRegKey Condition=" '$(MgRegKey)' == '' ">SOFTWARE\OSGeo\MapGuide</MgRegKey>
     <MgSource Condition="('$(MgSource)'=='')">$(MSBuildProjectDirectory)\..\..\..\MgDev\$(Configuration)</MgSource>
   </PropertyGroup>
Modified: trunk/Installer/Libraries/CS Map/CSMap.wxs
--- trunk/Installer/Libraries/CS Map/CSMap.wxs	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/Libraries/CS Map/CSMap.wxs	2011-11-01 06:00:35 UTC (rev 6194)
@@ -12,13 +12,20 @@
       <Directory Id="CSMAPLOCATION" Name="CS-Map">
         <Component Id="CsMapComponent" Win64="$(var.Win64)" Guid="552EAF5E-2420-4C2A-A52C-62B456EE1F64">
           <CreateFolder />
-          <Environment Id="CsMapEnvVar"
-             Action="set"
-             Part="all"
-             Name="MENTOR_DICTIONARY_PATH"
-             Permanent="no"
-             System="yes"
-             Value="[dir_Dictionaries_0]" />
+          <IniFile Id="INISETSERVERDICTPATH"
+                   Action="addLine"
+                   Directory="SERVERBINLOCATION"
+                   Key="MentorDictionaryPath"
+                   Name="serverconfig.ini"
+                   Section="GeneralProperties"
+                   Value="[dir_Dictionaries_0]"/>
+          <IniFile Id="INISETWEBDICTPATH"
+                   Action="addLine"
+                   Directory="WEBROOTLOCATION"
+                   Name="webconfig.ini"
         </Component>
       </Directory>
     </DirectoryRef>
Modified: trunk/Installer/Libraries/MapGuide Server/FDO.wxs
--- trunk/Installer/Libraries/MapGuide Server/FDO.wxs	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/Libraries/MapGuide Server/FDO.wxs	2011-11-01 06:00:35 UTC (rev 6194)
@@ -10,19 +10,19 @@
   <Fragment>
       <CustomAction Id="FdoRegCmd" Property="FdoReg" Execute="immediate" Value="&quot;[FDOLOCATION]FdoRegUtil.exe&quot;" />
-      <CustomAction Execute="immediate" Id="FdoRegArcSdeCmd" Property="FdoRegArcSde" Value="[FdoReg] -r &quot;OSGeo.ArcSDE.[FDO_VERSION_SMALL]&quot; &quot;!(loc.ArcSdeProvider)&quot; &quot;!(loc.ArcSdeProviderDesc)&quot; &quot;[FDO_VERSION]&quot; &quot;[FDO_VERSION]&quot; &quot;.\ArcSDEProvider.dll&quot;" />
-      <CustomAction Execute="immediate" Id="FdoRegSdfCmd" Property="FdoRegSdf" Value="[FdoReg] -r &quot;OSGeo.SDF.[FDO_VERSION_SMALL]&quot; &quot;!(loc.SdfProvider)&quot; &quot;!(loc.SdfProviderDesc)&quot; &quot;[FDO_VERSION]&quot; &quot;[FDO_VERSION]&quot; &quot;.\SDFProvider.dll&quot;" />
-      <CustomAction Execute="immediate" Id="FdoRegShpCmd" Property="FdoRegShp" Value="[FdoReg] -r &quot;OSGeo.SHP.[FDO_VERSION_SMALL]&quot; &quot;!(loc.ShpProvider)&quot; &quot;!(loc.ShpProviderDesc)&quot; &quot;[FDO_VERSION]&quot; &quot;[FDO_VERSION]&quot; &quot;.\SHPProvider.dll&quot;" />
-      <CustomAction Execute="immediate" Id="FdoRegWfsCmd" Property="FdoRegWfs" Value="[FdoReg] -r &quot;OSGeo.WFS.[FDO_VERSION_SMALL]&quot; &quot;!(loc.WfsProvider)&quot; &quot;!(loc.WfsProviderDesc)&quot; &quot;[FDO_VERSION]&quot; &quot;[FDO_VERSION]&quot; &quot;.\WFSProvider.dll&quot;" />
-      <CustomAction Execute="immediate" Id="FdoRegWmsCmd" Property="FdoRegWms" Value="[FdoReg] -r &quot;OSGeo.WMS.[FDO_VERSION_SMALL]&quot; &quot;!(loc.WmsProvider)&quot; &quot;!(loc.WmsProviderDesc)&quot; &quot;[FDO_VERSION]&quot; &quot;[FDO_VERSION]&quot; &quot;.\WMSProvider.dll&quot;" />
-      <CustomAction Execute="immediate" Id="FdoRegOdbcCmd" Property="FdoRegOdbc" Value="[FdoReg] -r &quot;OSGeo.ODBC.[FDO_VERSION_SMALL]&quot; &quot;!(loc.OdbcProvider)&quot; &quot;!(loc.OdbcProviderDesc)&quot; &quot;[FDO_VERSION]&quot; &quot;[FDO_VERSION]&quot; &quot;.\ODBCProvider.dll&quot;" />
-      <CustomAction Execute="immediate" Id="FdoRegMySqlCmd" Property="FdoRegMySql" Value="[FdoReg] -r &quot;OSGeo.MySQL.[FDO_VERSION_SMALL]&quot; &quot;!(loc.MySqlProvider)&quot; &quot;!(loc.MySqlProviderDesc)&quot; &quot;[FDO_VERSION]&quot; &quot;[FDO_VERSION]&quot; &quot;.\MySQLProvider.dll&quot;" />
-      <CustomAction Execute="immediate" Id="FdoRegGdalCmd" Property="FdoRegGdal" Value="[FdoReg] -r &quot;OSGeo.Gdal.[FDO_VERSION_SMALL]&quot; &quot;!(loc.GdalProvider)&quot; &quot;!(loc.GdalProviderDesc)&quot; &quot;[FDO_VERSION]&quot; &quot;[FDO_VERSION]&quot; &quot;.\GRFPProvider.dll&quot;" />
-      <CustomAction Execute="immediate" Id="FdoRegOgrCmd" Property="FdoRegOgr" Value="[FdoReg] -r &quot;OSGeo.OGR.[FDO_VERSION_SMALL]&quot; &quot;!(loc.OgrProvider)&quot; &quot;!(loc.OgrProviderDesc)&quot; &quot;[FDO_VERSION]&quot; &quot;[FDO_VERSION]&quot; &quot;.\OGRProvider.dll&quot;" />
-      <CustomAction Execute="immediate" Id="FdoRegPostgreSqlCmd" Property="FdoRegPostgreSql" Value="[FdoReg] -r &quot;OSGeo.PostgreSQL.[FDO_VERSION_SMALL]&quot; &quot;!(loc.PostgreSqlProvider)&quot; &quot;!(loc.PostgreSqlProviderDesc)&quot; &quot;[FDO_VERSION]&quot; &quot;[FDO_VERSION]&quot; &quot;.\PostgreSQLProvider.dll&quot;" />
-      <CustomAction Execute="immediate" Id="FdoRegOracleCmd" Property="FdoRegOracle" Value="[FdoReg] -r &quot;King.Oracle.[FDO_VERSION_SMALL]&quot; &quot;!(loc.KingOracleProvider)&quot; &quot;!(loc.KingOracleProviderDesc)&quot; &quot;[FDO_VERSION]&quot; &quot;[FDO_VERSION]&quot; &quot;.\KingOracleProvider.dll&quot;" />
-      <CustomAction Execute="immediate" Id="FdoRegSqlServerCmd" Property="FdoRegSqlServer" Value="[FdoReg] -r &quot;OSGeo.SQLServerSpatial.[FDO_VERSION_SMALL]&quot; &quot;!(loc.SqlServerProvider)&quot; &quot;!(loc.SqlServerProviderDesc)&quot; &quot;[FDO_VERSION]&quot; &quot;[FDO_VERSION]&quot; &quot;.\SQLServerSpatialProvider.dll&quot;" />
-      <CustomAction Execute="immediate" Id="FdoRegSltCmd" Property="FdoRegSlt" Value="[FdoReg] -r &quot;OSGeo.SQLite.[FDO_VERSION_SMALL]&quot; &quot;!(loc.SltProvider)&quot; &quot;!(loc.SltProviderDesc)&quot; &quot;[FDO_VERSION]&quot; &quot;[FDO_VERSION]&quot; &quot;.\SQLiteProvider.dll&quot;" />
+      <CustomAction Execute="immediate" Id="FdoRegArcSdeCmd" Property="FdoRegArcSde" Value="[FdoReg] -r &quot;.\ArcSDEProvider.dll&quot;" />
+      <CustomAction Execute="immediate" Id="FdoRegSdfCmd" Property="FdoRegSdf" Value="[FdoReg] -r &quot;.\SDFProvider.dll&quot;" />
+      <CustomAction Execute="immediate" Id="FdoRegShpCmd" Property="FdoRegShp" Value="[FdoReg] -r &quot;.\SHPProvider.dll&quot;" />
+      <CustomAction Execute="immediate" Id="FdoRegWfsCmd" Property="FdoRegWfs" Value="[FdoReg] -r &quot;.\WFSProvider.dll&quot;" />
+      <CustomAction Execute="immediate" Id="FdoRegWmsCmd" Property="FdoRegWms" Value="[FdoReg] -r &quot;.\WMSProvider.dll&quot;" />
+      <CustomAction Execute="immediate" Id="FdoRegOdbcCmd" Property="FdoRegOdbc" Value="[FdoReg] -r &quot;.\ODBCProvider.dll&quot;" />
+      <CustomAction Execute="immediate" Id="FdoRegMySqlCmd" Property="FdoRegMySql" Value="[FdoReg] -r &quot;.\MySQLProvider.dll&quot;" />
+      <CustomAction Execute="immediate" Id="FdoRegGdalCmd" Property="FdoRegGdal" Value="[FdoReg] -r &quot;.\GRFPProvider.dll&quot;" />
+      <CustomAction Execute="immediate" Id="FdoRegOgrCmd" Property="FdoRegOgr" Value="[FdoReg] -r &quot;.\OGRProvider.dll&quot;" />
+      <CustomAction Execute="immediate" Id="FdoRegPostgreSqlCmd" Property="FdoRegPostgreSql" Value="[FdoReg] -r &quot;.\PostgreSQLProvider.dll&quot;" />
+      <CustomAction Execute="immediate" Id="FdoRegOracleCmd" Property="FdoRegOracle" Value="[FdoReg] -r &quot;.\KingOracleProvider.dll&quot;" />
+      <CustomAction Execute="immediate" Id="FdoRegSqlServerCmd" Property="FdoRegSqlServer" Value="[FdoReg] -r &quot;.\SQLServerSpatialProvider.dll&quot;" />
+      <CustomAction Execute="immediate" Id="FdoRegSltCmd" Property="FdoRegSlt" Value="[FdoReg] -r &quot;.\SQLiteProvider.dll&quot;" />
       <CustomAction Id="FdoRegArcSde" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
       <CustomAction Id="FdoRegSdf" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
@@ -98,6 +98,7 @@
               <File Id="FdoSpatial" Checksum="yes" Source="$(var.MgSource)\Server\FDO\FDOSpatial.dll" />
               <File Id="FdoOWS" Checksum="yes" Source="$(var.MgSource)\Server\FDO\OWS.dll" />
               <File Id="GdalLib" Checksum="yes" Source="$(var.MgSource)\Server\FDO\gdal17.dll" />
+              <File Id="ProvidersXml" Checksum="yes" Source="$(var.MgSource)\Server\FDO\providers.xml" />
               <File Id="XalanLib" Checksum="yes" Source="$(var.MgSource)\Server\FDO\Xalan-C_1_11.dll" />
               <File Id="XalanMessagesLib" Checksum="yes" Source="$(var.MgSource)\Server\FDO\XalanMessages_1_11.dll" />
               <File Id="XercesLib" Checksum="yes" Source="$(var.MgSource)\Server\FDO\xerces-c_3_1.dll" />
Modified: trunk/Installer/Libraries/MapGuide Server/InstallService.wxs
--- trunk/Installer/Libraries/MapGuide Server/InstallService.wxs	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/Libraries/MapGuide Server/InstallService.wxs	2011-11-01 06:00:35 UTC (rev 6194)
@@ -1,19 +1,21 @@
 <?xml version="1.0" encoding="utf-8"?>
 <Wix   xmlns="http://schemas.microsoft.com/wix/2006/wi">
+  <!-- mgserver.exe -->
+  <?define MGSERVER_MAP = "file_SRVBINFILES_26" ?>
   <Fragment>
     <CustomAction
       Execute="deferred"
       Return="ignore"
       Id="MgServerInstallCA"
-      FileKey="file_SRVBINFILES_26"
+      FileKey="$(var.MGSERVER_MAP)"
       ExeCommand="install &quot;MapGuide Server [MG_VERSION_MAJOR_MINOR]&quot;" />
     <CustomAction
       Execute="immediate"
       Return="ignore"
       Id="MgServerUninstallCA"
       ExeCommand="uninstall" />
   </Fragment>
Modified: trunk/Installer/Libraries/MapGuide Server/MapGuide Server.wixproj
--- trunk/Installer/Libraries/MapGuide Server/MapGuide Server.wixproj	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/Libraries/MapGuide Server/MapGuide Server.wixproj	2011-11-01 06:00:35 UTC (rev 6194)
@@ -7,7 +7,7 @@
     <OutputName>MapGuideServer</OutputName>
     <Name>MapGuide Server</Name>
@@ -45,6 +45,7 @@
   <ItemGroup>
     </WixExtension>
   </ItemGroup>
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs
--- trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs	2011-11-01 06:00:35 UTC (rev 6194)
@@ -1,13 +1,15 @@
+    <!-- httpd.exe -->
+    <?define HTTP_MAP = "file_APACHEFILES_20" ?>
 	<Fragment>
         <Binary Id="ApacheActions" SourceFile="..\..\Custom\bin\apache_actions.dll" />
         <CustomAction Id="UpdateApacheConfig.SetValues" Property="UpdateApacheConfig" Value="[WEBEXTENSIONSLOCATION];[APACHE_API_TYPE];[APACHE_PORT];[APACHELOCATION];[PHPLOCATION];[WEBROOTLOCATION];[VIRTUALDIR]" />
         <CustomAction Id="UpdateApacheConfig" Return="check" BinaryKey="ApacheActions" Execute="deferred"  DllEntry="UpdateApacheConfig" />
         <CustomAction Id="UpdatePhpIni.SetValues" Property="UpdatePhpIni" Value='[PHPLOCATION];2;[WEBTEMPLOCATION]' />
         <CustomAction Id="UpdatePhpIni" Return="check" BinaryKey="ApacheActions" Execute="deferred" DllEntry="UpdatePhpIni" />
-        <CustomAction Id="RemoveApacheServiceCA" Execute="immediate" Return="ignore" FileKey="file_APACHEFILES_18" ExeCommand="-k uninstall -n &quot;ApacheMapGuide[MG_VERSION_MAJOR_MINOR]&quot;" />
-        <CustomAction Id="InstallApacheServiceCA" Execute="deferred" Return="ignore" FileKey="file_APACHEFILES_18" ExeCommand="-k install -n &quot;ApacheMapGuide[MG_VERSION_MAJOR_MINOR]&quot;" />
-        <CustomAction Id="StartApacheServiceCA" Execute="deferred" Return="ignore" FileKey="file_APACHEFILES_18" ExeCommand="-k start -n &quot;ApacheMapGuide[MG_VERSION_MAJOR_MINOR]&quot;" />
+        <CustomAction Id="RemoveApacheServiceCA" Execute="immediate" Return="ignore" FileKey="$(var.HTTP_MAP)" ExeCommand="-k uninstall -n &quot;ApacheMapGuide[MG_VERSION_MAJOR_MINOR]&quot;" />
+        <CustomAction Id="InstallApacheServiceCA" Execute="deferred" Return="ignore" FileKey="$(var.HTTP_MAP)" ExeCommand="-k install -n &quot;ApacheMapGuide[MG_VERSION_MAJOR_MINOR]&quot;" />
+        <CustomAction Id="StartApacheServiceCA" Execute="deferred" Return="ignore" FileKey="$(var.HTTP_MAP)" ExeCommand="-k start -n &quot;ApacheMapGuide[MG_VERSION_MAJOR_MINOR]&quot;" />
 	</Fragment>
 </Wix>
\ No newline at end of file
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/IIS.wxs
--- trunk/Installer/Libraries/MapGuide Web Extensions/IIS.wxs	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/IIS.wxs	2011-11-01 06:00:35 UTC (rev 6194)
@@ -12,7 +12,7 @@
 	<!-- isapi_MapAgent.dll -->
     <?define FCGI_MAP = "[!file_MAPAGENTFILES_100]" ?>
 	<!-- php5isapi.dll -->
-    <?define PHP_MAP = "[!file_PHPFILES_43]" ?>
+    <?define PHP_MAP = "[WindowsFolder]\system32\inetsrv\fcgiext.dll" ?>
     <Fragment>
         <Property Id="FRAMEWORKDIR">
             <RegistrySearch
@@ -67,12 +67,15 @@
                     </iis:WebApplication>
                     <iis:WebVirtualDir Id="IIS5MapAgentVDir" Alias="mapagent" Directory="dir_mapagent_0" >
                         <iis:WebDirProperties Id="IIS5MapAgentProperties" DefaultDocuments="index.html" AnonymousAccess="yes" BasicAuthentication="no" WindowsAuthentication="no"/>
+                        <!-- Moving to WiX 3.5 broke this. So we'll disable for now -->
                         <iis:WebError ErrorCode="401" SubCode="0" />
                         <iis:WebError ErrorCode="401" SubCode="1" />
                         <iis:WebError ErrorCode="401" SubCode="2" />
                         <iis:WebError ErrorCode="401" SubCode="3" />
                         <iis:WebError ErrorCode="401" SubCode="4" />
                         <iis:WebError ErrorCode="401" SubCode="5" />
                         <iis:WebApplication Id="IIS5MapAgentWebApp" Name="mapagent" >
                             <iis:WebApplicationExtension Extension="fcgi" Script="yes" Verbs="GET,POST" CheckPath="no" Executable="$(var.FCGI_MAP)" />
                             <iis:WebApplicationExtension Extension="php" Script="yes" Verbs="GET,POST" CheckPath="no" Executable="$(var.PHP_MAP)" />
@@ -129,12 +132,15 @@
                     <iis:WebVirtualDir Id="IIS6MapAgentVDir" Alias="mapagent" Directory="dir_mapagent_0" >
                         <iis:WebDirProperties Id="IIS6MapAgentProperties" DefaultDocuments="index.html" AnonymousAccess="yes" BasicAuthentication="no" WindowsAuthentication="no" />
                         <iis:WebError ErrorCode="401" SubCode="0"/>
                         <iis:WebApplication Id="IIS6MapAgentWebApp" Name="mapagent" WebAppPool="IIS6MapGuideAppPool">
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs
--- trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs	2011-11-01 06:00:35 UTC (rev 6194)
@@ -15,6 +15,11 @@
         Value="[AppCmd] add apppool /name:&quot;[APP_POOL_NAME]&quot;" />
     <CustomAction Id="MapGuideIIS7_I_CreateAppPool" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
+    <!-- Set up FastCGI -->
+    <CustomAction Id="MapGuideIIS7_I_CreateFastCgi_Cmd" Property="MapGuideIIS7_I_CreateFastCgi" Execute="immediate"
+            Value="[AppCmd] add apppool set config /section:system.webServer/fastCGI /+[\[]fullPath=&quot;[WEBEXTENSIONSLOCATION]Php\php-cgi.exe&quot;[\]]" />
+    <CustomAction Id="MapGuideIIS7_I_CreateFastCgi" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
     <!-- Set the application pool's properties -->
     <CustomAction Id="MapGuideIIS7_I_SetAppPoolProp_Cmd" Property="MapGuideIIS7_I_SetAppPoolProp" Execute="immediate"
         Value="[AppCmd] set config /section:applicationPools /[\[]name='[APP_POOL_NAME]'[\]].processModel.idleTimeout:00:00:00  /[\[]name='[APP_POOL_NAME]'[\]].recycling.disallowOverlappingRotation:True" />
@@ -35,9 +40,9 @@
         Value="[AppCmd] add app /site.name:&quot;[MG_WEBSITE]&quot; /path:&quot;/[VIRTUALDIR]&quot; /physicalPath:&quot;[WEBEXTENSIONSLOCATION]www&quot;" />
     <CustomAction Id="MapGuideIIS7_I_CreateMapGuideApp" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
-    <!-- Set up the PHP script mapping -->
+    <!-- Set up the PHP script mapping to FastCGI -->
     <CustomAction Id="MapGuideIIS7_I_CreatePhpScriptMapping_Cmd" Property="MapGuideIIS7_I_CreatePhpScriptMapping" Execute="immediate"
-        Value="[AppCmd] set config &quot;[MG_WEBSITE]/[VIRTUALDIR]&quot; /section:handlers /+[\[]name='&quot;PHP ISAPI handler&quot;',path='*.php',verb='*',scriptProcessor='&quot;[WEBEXTENSIONSLOCATION]Php\php5isapi.dll&quot;',modules='IsapiModule',resourceType='Unspecified'[\]]" />
+        Value="[AppCmd] set config &quot;[MG_WEBSITE]/[VIRTUALDIR]&quot; /section:handlers /+[\[]name='&quot;PHP_via_FastCGI&quot;',path='*.php',verb='*',scriptProcessor='&quot;[WEBEXTENSIONSLOCATION]Php\php-cgi.exe&quot;',modules='FastCgiModule',resourceType='Unspecified'[\]]" />
     <CustomAction Id="MapGuideIIS7_I_CreatePhpScriptMapping" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
     <!-- Allow access to the PHP ISAPI -->
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/MapGuide Web Extensions.wixproj
--- trunk/Installer/Libraries/MapGuide Web Extensions/MapGuide Web Extensions.wixproj	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/MapGuide Web Extensions.wixproj	2011-11-01 06:00:35 UTC (rev 6194)
@@ -7,7 +7,7 @@
     <OutputName>MapGuide Web Extensions</OutputName>
   </PropertyGroup>
@@ -50,20 +50,23 @@
     <Folder Include="Lang" />
   </ItemGroup>
   <ItemGroup>
+    <EmbeddedResource Include="Lang\MapGuideWebExtensions_en-US.wxl" />
+    <EmbeddedResource Include="Lang\MapGuideWebExtensions_es-ES.wxl" />
+  </ItemGroup>
+  <ItemGroup>
+    </WixExtension>
     </WixExtension>
     </WixExtension>
-    </WixExtension>
   </ItemGroup>
-  <ItemGroup>
-    <EmbeddedResource Include="Lang\MapGuideWebExtensions_en-US.wxl" />
-    <EmbeddedResource Include="Lang\MapGuideWebExtensions_es-ES.wxl" />
-  </ItemGroup>
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/Shortcuts.wxs
--- trunk/Installer/Libraries/MapGuide Web Extensions/Shortcuts.wxs	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/Shortcuts.wxs	2011-11-01 06:00:35 UTC (rev 6194)
@@ -11,7 +11,7 @@
   <Fragment>
     <DirectoryRef Id="ProgramMenuFolder">
       <!-- HACK: For some reason the MG_VERSION_MAJOR_MINOR property doesn't evaluate, so hardcode it for now -->
-      <Directory Id="MapGuideOpenSourceMenuLocation" Name="MapGuide Open Source 2.2">
+      <Directory Id="MapGuideOpenSourceMenuLocation" Name="MapGuide Open Source 2.4">
         <Component Id="GenericShortcutComponent" Win64="$(var.Win64)" Guid="243CE0F3-D6BC-476B-910E-6F34DA54A2E2">
           <CreateFolder />
           <RegistryKey Root="HKCU" Key="$(var.MgRegKey)\GenericShortcut">
Modified: trunk/Installer/Support/Web/x64/Apache2/conf/httpd.conf
--- trunk/Installer/Support/Web/x64/Apache2/conf/httpd.conf	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/Support/Web/x64/Apache2/conf/httpd.conf	2011-11-01 06:00:35 UTC (rev 6194)
@@ -982,11 +982,11 @@
 # MapViewer to MapViewerPhp aliases. Comment out Alias and AliasMatch for Java API.
-ScriptAlias /%MG_VIRTUAL_DIR%/mapagent/mapagent.fcgi "%MG_WEB_ROOT%mapagent/mapagent.fcgi"
-%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerajax/([^\?])(.*)$ "%MG_WEB_ROOT%mapviewerphp/$1$2"
-%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerajax/(.*)$ "%MG_WEB_ROOT%mapviewerphp/ajaxviewer.php$1"
-%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerdwf/([^\?])(.*)$ "%MG_WEB_ROOT%mapviewerphp/$1$2"
-%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerdwf/(.*)$ "%MG_WEB_ROOT%mapviewerphp/dwfviewer.php$1"
+ScriptAlias /%MG_VIRTUAL_DIR%/mapagent/mapagent.fcgi "%MG_WEB_ROOT%/mapagent/mapagent.fcgi"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerajax/([^\?])(.*)$ "%MG_WEB_ROOT%/mapviewerphp/$1$2"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerajax/(.*)$ "%MG_WEB_ROOT%/mapviewerphp/ajaxviewer.php$1"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerdwf/([^\?])(.*)$ "%MG_WEB_ROOT%/mapviewerphp/$1$2"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerdwf/(.*)$ "%MG_WEB_ROOT%/mapviewerphp/dwfviewer.php$1"
 # MapViewer to MapViewerJava Redirect. Uncomment Redirect for Java API.
 %MG_JAVA_API%Redirect /%MG_VIRTUAL_DIR%/mapviewerajax/ http://localhost:%MG_WEB_PORT%/%MG_VIRTUAL_DIR%/mapviewerjava/ajaxviewer.jsp
Added: trunk/Installer/Support/Web/x64/FDO/providers.xml
--- trunk/Installer/Support/Web/x64/FDO/providers.xml	                        (rev 0)
+++ trunk/Installer/Support/Web/x64/FDO/providers.xml	2011-11-01 06:00:35 UTC (rev 6194)
@@ -0,0 +1,3 @@
+<?xml version="1.0" encoding="utf-8"?>
+<FeatureProviderRegistry>
+</FeatureProviderRegistry>
Modified: trunk/Installer/Support/Web/x86/configs/Apache2/conf/httpd.conf
--- trunk/Installer/Support/Web/x86/configs/Apache2/conf/httpd.conf	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/Support/Web/x86/configs/Apache2/conf/httpd.conf	2011-11-01 06:00:35 UTC (rev 6194)
@@ -192,7 +192,7 @@
 #LoadModule usertrack_module modules/mod_usertrack.so
 #LoadModule vhost_alias_module modules/mod_vhost_alias.so
 #LoadModule ssl_module modules/mod_ssl.so
-LoadModule php5_module modules/php5apache2_2.dll
+LoadModule php5_module "%MG_WEB_PHP%/php5apache2_2.dll"
 LoadModule mgmapagent_module modules/mod_mgmapagent.so
Added: trunk/Installer/Support/Web/x86/configs/FDO/providers.xml
--- trunk/Installer/Support/Web/x86/configs/FDO/providers.xml	                        (rev 0)
+++ trunk/Installer/Support/Web/x86/configs/FDO/providers.xml	2011-11-01 06:00:35 UTC (rev 6194)
@@ -0,0 +1,3 @@
Modified: trunk/Installer/build.bat
--- trunk/Installer/build.bat	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/build.bat	2011-11-01 06:00:35 UTC (rev 6194)
@@ -44,10 +44,11 @@
 SET CPUTYPE=x86
 SET TYPEBUILD=Release
 SET CULTURE=en-US
-SET INSTALLER_VERSION_MAJOR_MINOR_REV=2.3.0
+SET INSTALLER_VERSION_MAJOR_MINOR=2.4
+SET INSTALLER_VERSION_MAJOR_MINOR_REV=%INSTALLER_VERSION_MAJOR_MINOR%.0
 SET INSTALLER_NAME=MapGuideOpenSource-%INSTALLER_VERSION_MAJOR_MINOR_REV%-Trunk-%CULTURE%-%TYPEBUILD%-%CPUTYPE%
 SET INSTALLER_VERSION=%INSTALLER_VERSION_MAJOR_MINOR_REV%.0
-SET INSTALLER_TITLE="MapGuide Open Source 2.3 Trunk (%TYPEBUILD%)"
+SET INSTALLER_TITLE="MapGuide Open Source %INSTALLER_VERSION_MAJOR_MINOR% Trunk (%TYPEBUILD%)"
 SET MG_REG_KEY=Software\OSGeo\MapGuide\%INSTALLER_VERSION_MAJOR_MINOR_REV%
 SET MG_SOURCE=%CD%\..\MgDev\%TYPEBUILD%
 SET MG_SOURCE_INC=
@@ -212,6 +213,15 @@
 %XCOPY% "%INSTALLER_DEV%\Support\Web\%CPUTYPE%\Php" "%MG_SOURCE%\Web\Php" /EXCLUDE:svn_excludes.txt
 echo [prepare] Apache2
 %XCOPY% "%INSTALLER_DEV%\Support\Web\%CPUTYPE%\Apache2" "%MG_SOURCE%\Web\Apache2" /EXCLUDE:svn_excludes.txt
+rem copy template configs on top
+echo [prepare] Tomcat config
+%XCOPY% "%INSTALLER_DEV%\Support\Web\%CPUTYPE%\configs\Tomcat" "%MG_SOURCE%\Web\Tomcat" /EXCLUDE:svn_excludes.txt
+echo [prepare] Php config
+%XCOPY% "%INSTALLER_DEV%\Support\Web\%CPUTYPE%\configs\Php" "%MG_SOURCE%\Web\Php" /EXCLUDE:svn_excludes.txt
+echo [prepare] Apache2 config
+%XCOPY% "%INSTALLER_DEV%\Support\Web\%CPUTYPE%\configs\Apache2" "%MG_SOURCE%\Web\Apache2" /EXCLUDE:svn_excludes.txt
+echo [prepare] FDO providers.xml
+copy /Y "%INSTALLER_DEV%\Support\Web\%CPUTYPE%\configs\FDO\providers.xml" "%MG_SOURCE%\Server\FDO\"
 goto quit
Modified: trunk/Installer/build64.bat
--- trunk/Installer/build64.bat	2011-10-29 14:06:17 UTC (rev 6193)
+++ trunk/Installer/build64.bat	2011-11-01 06:00:35 UTC (rev 6194)
@@ -45,10 +45,11 @@
 SET CONFIGURATION=Release
 SET PLATFORM=x64
 SET CULTURE=en-US
 SET INSTALLER_NAME=MapGuideOpenSource-%INSTALLER_VERSION_MAJOR_MINOR_REV%-Trunk-%CULTURE%-%TYPEBUILD%-%PLATFORM%
 SET MG_SOURCE_INC=
@@ -250,6 +251,15 @@
 %XCOPY% "%INSTALLER_DEV%\Support\Web\%PLATFORM%\Php" "%MG_SOURCE%\Web\Php" /EXCLUDE:svn_excludes.txt
 %XCOPY% "%INSTALLER_DEV%\Support\Web\%PLATFORM%\Apache2" "%MG_SOURCE%\Web\Apache2" /EXCLUDE:svn_excludes.txt
+%XCOPY% "%INSTALLER_DEV%\Support\Web\%PLATFORM%\configs\Tomcat" "%MG_SOURCE%\Web\Tomcat" /EXCLUDE:svn_excludes.txt
+%XCOPY% "%INSTALLER_DEV%\Support\Web\%PLATFORM%\configs\Php" "%MG_SOURCE%\Web\Php" /EXCLUDE:svn_excludes.txt
+%XCOPY% "%INSTALLER_DEV%\Support\Web\%PLATFORM%\configs\Apache2" "%MG_SOURCE%\Web\Apache2" /EXCLUDE:svn_excludes.txt
+copy /Y "%INSTALLER_DEV%\Support\Web\%PLATFORM%\configs\FDO\providers.xml" "%MG_SOURCE%\Server\FDO\"
 goto quit
More information about the mapguide-commits mailing list
