[mapguide-commits] r6204 - in trunk/Tools/Maestro: Maestro.Base
Maestro.Base/Commands Maestro.Base/Properties
Maestro.Base/Resources Maestro.Editors Maestro.Editors/Common
Maestro.Editors/Packaging Maestro.Editors/Properties
Maestro.Editors/Resources Maestro.Packaging
Maestro.Packaging/Properties Maestro.Shared.UI
svn_mapguide at osgeo.org
Tue Nov 8 08:43:56 EST 2011
Author: jng
Date: 2011-11-08 05:43:56 -0800 (Tue, 08 Nov 2011)
New Revision: 6204
Added:
trunk/Tools/Maestro/Maestro.Base/Commands/EditPackageCommand.cs
trunk/Tools/Maestro/Maestro.Base/Resources/box--pencil.png
trunk/Tools/Maestro/Maestro.Editors/Packaging/
trunk/Tools/Maestro/Maestro.Editors/Packaging/AddResourceEntryDialog.cs
trunk/Tools/Maestro/Maestro.Editors/Packaging/AddResourceEntryDialog.designer.cs
trunk/Tools/Maestro/Maestro.Editors/Packaging/AddResourceEntryDialog.resx
trunk/Tools/Maestro/Maestro.Editors/Packaging/EditResourceDataEntryDialog.cs
trunk/Tools/Maestro/Maestro.Editors/Packaging/EditResourceDataEntryDialog.designer.cs
trunk/Tools/Maestro/Maestro.Editors/Packaging/EditResourceDataEntryDialog.resx
trunk/Tools/Maestro/Maestro.Editors/Packaging/PackageEditorDialog.cs
trunk/Tools/Maestro/Maestro.Editors/Packaging/PackageEditorDialog.designer.cs
trunk/Tools/Maestro/Maestro.Editors/Packaging/PackageEditorDialog.resx
trunk/Tools/Maestro/Maestro.Editors/RepositoryIcons.cs
trunk/Tools/Maestro/Maestro.Editors/Resources/application-browser.png
trunk/Tools/Maestro/Maestro.Editors/Resources/applications-stack.png
trunk/Tools/Maestro/Maestro.Editors/Resources/blueprints.png
trunk/Tools/Maestro/Maestro.Editors/Resources/database-share.png
trunk/Tools/Maestro/Maestro.Editors/Resources/disk.png
trunk/Tools/Maestro/Maestro.Editors/Resources/images-stack.png
trunk/Tools/Maestro/Maestro.Editors/Resources/map.png
trunk/Tools/Maestro/Maestro.Editors/Resources/printer.png
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.cs
trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.resx
trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
trunk/Tools/Maestro/Maestro.Packaging/PackageBuilder.cs
trunk/Tools/Maestro/Maestro.Packaging/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Packaging/Properties/Resources.resx
trunk/Tools/Maestro/Maestro.Packaging/ResourceItem.cs
trunk/Tools/Maestro/Maestro.Shared.UI/CollapsiblePanel.cs
#1810: Re-instate the package editor which went MIA since Maestro 2.1. Other changes include adding a RepositoryIcons helper class to build consistent image lists. Package Editor and Resource Picker have been modified to use this shared helper class.
Added: trunk/Tools/Maestro/Maestro.Base/Commands/EditPackageCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/EditPackageCommand.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/EditPackageCommand.cs 2011-11-08 13:43:56 UTC (rev 6204)
@@ -0,0 +1,50 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using ICSharpCode.Core;
+using Maestro.Shared.UI;
+using Maestro.Base.Services;
+using Maestro.Editors.Packaging;
+namespace Maestro.Base.Commands
+ internal class EditPackageCommand : AbstractMenuCommand
+ public override void Run()
+ var wb = Workbench.Instance;
+ var exp = wb.ActiveSiteExplorer;
+ var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+ var conn = connMgr.GetConnection(exp.ConnectionName);
+ using (var open = DialogFactory.OpenFile())
+ open.Filter = Properties.Resources.Filter_Mgp_Files;
+ if (open.ShowDialog(wb) == System.Windows.Forms.DialogResult.OK)
+ var dlg = new PackageEditorDialog(open.FileName, conn);
+ dlg.ShowDialog(wb);
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2011-11-07 16:31:53 UTC (rev 6203)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2011-11-08 13:43:56 UTC (rev 6204)
@@ -237,6 +237,10 @@
icon="box__arrow"
label="${res:Menu_Package_LoadPackage}"
class="Maestro.Base.Commands.LoadPackageCommand" />
+ <MenuItem id="EditPackage"
+ label="${res:EditPackage}"
+ icon="box__pencil"
+ class="Maestro.Base.Commands.EditPackageCommand"/>
</MenuItem>
<MenuItem id="Menu_Help"
type="Menu"
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2011-11-07 16:31:53 UTC (rev 6203)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2011-11-08 13:43:56 UTC (rev 6204)
@@ -69,6 +69,7 @@
<Compile Include="Commands\CreatePackageCommand.cs" />
<Compile Include="Commands\CutCommand.cs" />
<Compile Include="Commands\EditAsXmlCommand.cs" />
+ <Compile Include="Commands\EditPackageCommand.cs" />
<Compile Include="Commands\LoadPackageCommand.cs" />
<Compile Include="Commands\LocalFeatureSourcePreviewCommand.cs" />
<Compile Include="Commands\LoginCommand.cs" />
@@ -385,6 +386,7 @@
</ItemGroup>
<ItemGroup>
<Content Include="Maestro.Base.addin" />
+ <None Include="Resources\box--pencil.png" />
<None Include="Resources\Contributors.txt" />
<None Include="Resources\edit.png" />
<None Include="Resources\marker.png" />
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-11-07 16:31:53 UTC (rev 6203)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-11-08 13:43:56 UTC (rev 6204)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:2.0.50727.4959
+// Runtime Version:2.0.50727.5448
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
@@ -241,6 +241,13 @@
+ internal static System.Drawing.Bitmap box__pencil {
+ get {
+ object obj = ResourceManager.GetObject("box__pencil", resourceCulture);
+ return ((System.Drawing.Bitmap)(obj));
internal static System.Drawing.Bitmap box__plus {
get {
object obj = ResourceManager.GetObject("box__plus", resourceCulture);
@@ -681,6 +688,15 @@
/// <summary>
+ /// Looks up a localized string similar to Package Editor.
+ /// </summary>
+ internal static string EditPackage {
+ get {
+ return ResourceManager.GetString("EditPackage", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Singleton view content cannot be closed by users. The AllowUserClose property must return false.
/// </summary>
internal static string Error_Closeable_Singleton_Content {
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-11-07 16:31:53 UTC (rev 6203)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-11-08 13:43:56 UTC (rev 6204)
@@ -1070,4 +1070,10 @@
<data name="PromptOverwriteOnTargetConnection" xml:space="preserve">
<value>There are {0} already existing resources that have the same name. Do you want to overwrite these resources?</value>
</data>
+ <data name="EditPackage" xml:space="preserve">
+ <value>Package Editor</value>
+ </data>
+ <data name="box__pencil" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\box--pencil.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Base/Resources/box--pencil.png
(Binary files differ)
Property changes on: trunk/Tools/Maestro/Maestro.Base/Resources/box--pencil.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.Designer.cs 2011-11-07 16:31:53 UTC (rev 6203)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.Designer.cs 2011-11-08 13:43:56 UTC (rev 6204)
@@ -84,19 +84,9 @@
// resImageList
- this.resImageList.ImageStream = ((System.Windows.Forms.ImageListStreamer)(resources.GetObject("resImageList.ImageStream")));
+ this.resImageList.ColorDepth = System.Windows.Forms.ColorDepth.Depth8Bit;
+ resources.ApplyResources(this.resImageList, "resImageList");
this.resImageList.TransparentColor = System.Drawing.Color.Transparent;
- this.resImageList.Images.SetKeyName(0, "document.png");
- this.resImageList.Images.SetKeyName(1, "database-share.png");
- this.resImageList.Images.SetKeyName(2, "layer.png");
- this.resImageList.Images.SetKeyName(3, "map.png");
- this.resImageList.Images.SetKeyName(4, "application-browser.png");
- this.resImageList.Images.SetKeyName(5, "images-stack.png");
- this.resImageList.Images.SetKeyName(6, "printer.png");
- this.resImageList.Images.SetKeyName(7, "blueprints.png");
- this.resImageList.Images.SetKeyName(8, "applications-stack.png");
- this.resImageList.Images.SetKeyName(9, "marker.png");
- this.resImageList.Images.SetKeyName(10, "edit.png");
// btnOK
@@ -170,10 +160,9 @@
// folderImageList
- this.folderImageList.ImageStream = ((System.Windows.Forms.ImageListStreamer)(resources.GetObject("folderImageList.ImageStream")));
+ this.folderImageList.ColorDepth = System.Windows.Forms.ColorDepth.Depth32Bit;
+ resources.ApplyResources(this.folderImageList, "folderImageList");
this.folderImageList.TransparentColor = System.Drawing.Color.Transparent;
- this.folderImageList.Images.SetKeyName(0, "server.png");
- this.folderImageList.Images.SetKeyName(1, "folder-horizontal.png");
// label2
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.cs 2011-11-07 16:31:53 UTC (rev 6203)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.cs 2011-11-08 13:43:56 UTC (rev 6204)
@@ -38,18 +38,6 @@
/// </summary>
public partial class ResourcePicker : Form
- const int RES_UNKNOWN = 0;
- const int RES_FEATURESOURCE = 1;
- const int RES_LAYERDEFINITION = 2;
- const int RES_MAPDEFINITION = 3;
- const int RES_WEBLAYOUT = 4;
- const int RES_SYMBOLLIBRARY = 5;
- const int RES_PRINTLAYOUT = 6;
- const int RES_DRAWINGSOURCE = 7;
- const int RES_APPLICATIONDEFINITION = 8;
- const int RES_SYMBOLDEFINITION = 9;
- const int RES_WATERMARK = 10;
private ResourceTypes[] _resTypes;
private ResourcePicker()
@@ -71,6 +59,8 @@
ResourceTypes.WatermarkDefinition
cmbResourceFilter.DataSource = _resTypes;
+ RepositoryIcons.PopulateImageList(resImageList);
+ RepositoryIcons.PopulateImageList(folderImageList);
private IResourceService _resSvc;
@@ -347,46 +337,11 @@
try
var rt = ResourceIdentifier.GetResourceType(doc.ResourceId);
- switch (rt)
- case ResourceTypes.ApplicationDefinition:
- li.ImageIndex = RES_APPLICATIONDEFINITION;
- break;
- case ResourceTypes.DrawingSource:
- li.ImageIndex = RES_DRAWINGSOURCE;
- break;
- case ResourceTypes.FeatureSource:
- li.ImageIndex = RES_FEATURESOURCE;
- break;
- case ResourceTypes.LayerDefinition:
- li.ImageIndex = RES_LAYERDEFINITION;
- break;
- case ResourceTypes.MapDefinition:
- li.ImageIndex = RES_MAPDEFINITION;
- break;
- case ResourceTypes.PrintLayout:
- li.ImageIndex = RES_PRINTLAYOUT;
- break;
- case ResourceTypes.SymbolLibrary:
- li.ImageIndex = RES_SYMBOLLIBRARY;
- break;
- case ResourceTypes.WebLayout:
- li.ImageIndex = RES_WEBLAYOUT;
- break;
- case ResourceTypes.SymbolDefinition:
- li.ImageIndex = RES_SYMBOLDEFINITION;
- break;
- case ResourceTypes.WatermarkDefinition:
- li.ImageIndex = RES_WATERMARK;
- break;
- default:
- li.ImageIndex = RES_UNKNOWN;
- break;
+ li.ImageIndex = RepositoryIcons.GetImageIndexForResourceType(rt);
catch
+ li.ImageIndex = RepositoryIcons.RES_UNKNOWN;
lstResources.Items.Add(li);
@@ -581,16 +536,13 @@
- const int IDX_SERVER = 0;
- const int IDX_FOLDER = 1;
private static TreeNode CreateNode(RepositoryFolder folder)
var node = new TreeNode();
node.Name = folder.Name;
node.Text = folder.Name;
node.Tag = folder;
- node.ImageIndex = node.SelectedImageIndex = folder.IsRoot ? IDX_SERVER : IDX_FOLDER;
+ node.ImageIndex = node.SelectedImageIndex = folder.IsRoot ? RepositoryIcons.RES_ROOT : RepositoryIcons.RES_FOLDER;
node.Nodes.Add(new DummyNode());
return node;
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.resx
--- trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.resx 2011-11-07 16:31:53 UTC (rev 6203)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.resx 2011-11-08 13:43:56 UTC (rev 6204)
@@ -124,99 +124,10 @@
<metadata name="resImageList.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>17, 17</value>
</metadata>
- <data name="resImageList.ImageStream" mimetype="application/x-microsoft.net.object.binary.base64">
- <value>
- AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
- LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
- ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAADk
- EwAAAk1TRnQBSQFMAgEBCwEAAegBAAHoAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
- AwABQAMAATADAAEBAQABCAYAAQwYAAGAAgABgAMAAoABAAGAAwABgAEAAYABAAKAAgADwAEAAcAB3AHA
- AQAB8AHKAaYBAAEzBQABMwEAATMBAAEzAQACMwIAAxYBAAMcAQADIgEAAykBAANVAQADTQEAA0IBAAM5
- AQABgAF8Af8BAAJQAf8BAAGTAQAB1gEAAf8B7AHMAQABxgHWAe8BAAHWAucBAAGQAakBrQIAAf8BMwMA
- AWYDAAGZAwABzAIAATMDAAIzAgABMwFmAgABMwGZAgABMwHMAgABMwH/AgABZgMAAWYBMwIAAmYCAAFm
- AZkCAAFmAcwCAAFmAf8CAAGZAwABmQEzAgABmQFmAgACmQIAAZkBzAIAAZkB/wIAAcwDAAHMATMCAAHM
- AWYCAAHMAZkCAALMAgABzAH/AgAB/wFmAgAB/wGZAgAB/wHMAQABMwH/AgAB/wEAATMBAAEzAQABZgEA
- ATMBAAGZAQABMwEAAcwBAAEzAQAB/wEAAf8BMwIAAzMBAAIzAWYBAAIzAZkBAAIzAcwBAAIzAf8BAAEz
- AWYCAAEzAWYBMwEAATMCZgEAATMBZgGZAQABMwFmAcwBAAEzAWYB/wEAATMBmQIAATMBmQEzAQABMwGZ
- AWYBAAEzApkBAAEzAZkBzAEAATMBmQH/AQABMwHMAgABMwHMATMBAAEzAcwBZgEAATMBzAGZAQABMwLM
- AQABMwHMAf8BAAEzAf8BMwEAATMB/wFmAQABMwH/AZkBAAEzAf8BzAEAATMC/wEAAWYDAAFmAQABMwEA
- AWYBAAFmAQABZgEAAZkBAAFmAQABzAEAAWYBAAH/AQABZgEzAgABZgIzAQABZgEzAWYBAAFmATMBmQEA
- AWYBMwHMAQABZgEzAf8BAAJmAgACZgEzAQADZgEAAmYBmQEAAmYBzAEAAWYBmQIAAWYBmQEzAQABZgGZ
- AWYBAAFmApkBAAFmAZkBzAEAAWYBmQH/AQABZgHMAgABZgHMATMBAAFmAcwBmQEAAWYCzAEAAWYBzAH/
- AQABZgH/AgABZgH/ATMBAAFmAf8BmQEAAWYB/wHMAQABzAEAAf8BAAH/AQABzAEAApkCAAGZATMBmQEA
- AZkBAAGZAQABmQEAAcwBAAGZAwABmQIzAQABmQEAAWYBAAGZATMBzAEAAZkBAAH/AQABmQFmAgABmQFm
- ATMBAAGZATMBZgEAAZkBZgGZAQABmQFmAcwBAAGZATMB/wEAApkBMwEAApkBZgEAA5kBAAKZAcwBAAKZ
- Af8BAAGZAcwCAAGZAcwBMwEAAWYBzAFmAQABmQHMAZkBAAGZAswBAAGZAcwB/wEAAZkB/wIAAZkB/wEz
- AQABmQHMAWYBAAGZAf8BmQEAAZkB/wHMAQABmQL/AQABzAMAAZkBAAEzAQABzAEAAWYBAAHMAQABmQEA
- AcwBAAHMAQABmQEzAgABzAIzAQABzAEzAWYBAAHMATMBmQEAAcwBMwHMAQABzAEzAf8BAAHMAWYCAAHM
- AWYBMwEAAZkCZgEAAcwBZgGZAQABzAFmAcwBAAGZAWYB/wEAAcwBmQIAAcwBmQEzAQABzAGZAWYBAAHM
- ApkBAAHMAZkBzAEAAcwBmQH/AQACzAIAAswBMwEAAswBZgEAAswBmQEAA8wBAALMAf8BAAHMAf8CAAHM
- Af8BMwEAAZkB/wFmAQABzAH/AZkBAAHMAf8BzAEAAcwC/wEAAcwBAAEzAQAB/wEAAWYBAAH/AQABmQEA
- AcwBMwIAAf8CMwEAAf8BMwFmAQAB/wEzAZkBAAH/ATMBzAEAAf8BMwH/AQAB/wFmAgAB/wFmATMBAAHM
- AmYBAAH/AWYBmQEAAf8BZgHMAQABzAFmAf8BAAH/AZkCAAH/AZkBMwEAAf8BmQFmAQAB/wKZAQAB/wGZ
- AcwBAAH/AZkB/wEAAf8BzAIAAf8BzAEzAQAB/wHMAWYBAAH/AcwBmQEAAf8CzAEAAf8BzAH/AQAC/wEz
- AQABzAH/AWYBAAL/AZkBAAL/AcwBAAJmAf8BAAFmAf8BZgEAAWYC/wEAAf8CZgEAAf8BZgH/AQAC/wFm
- AQABIQEAAaUBAANfAQADdwEAA4YBAAOWAQADywEAA7IBAAPXAQAD3QEAA+MBAAPqAQAD8QEAA/gBAAHw
- AfsB/wEAAaQCoAEAA4ADAAH/AgAB/wMAAv8BAAH/AwAB/wEAAf8BAAL/AgAD/wEAAfAIBwG8Af8IAAL/
- AfQBBwFvAQcB8wL/BgAM/xIAAbwI8wG8Af8IAAP/AW8BFwFvA/8GAAL/AW0GEAFtAfQB/xIAAfAB9Abz
- AfQB8AwAAW8B4wFvCwABEQPqAhIB6gERFAAB8AH/BvQB/wG8A/8JAAFvAeMBbwsAAewBQwEUAhIBFAFD
- AewUAAHxCP8BkgIHAfAIAAH/AW8B4wFvAf8LAAHzARQCEgEUAfMVAAHwAgcD7wL3AZIB7ALzAbwIAAEa
- AW8B4wFvARoMAAETAhIBExYAAfEB8AHxAfABvAEHA7wB7wHzAfQB8AcAAf8CbwHjAm8B/wsABBIWAAH0
- AfIB8QXvAQcB8gH0Af8BvAP/BAABGgFvA+MBbwEaCwAB6gITAeoZAAHxCP8BkgIHAfADAAH/AW8BFgPj
- ARYBbwH/CgABbQITAW0ZAAHwAgcD7wL3AZIB7ALzAbwDAAEaAhYD4wIWARoKAAFtAhIBbRkAAfEB8AHx
- AfABvAEHA7wB7wHzAfQB8AMAAZMBFgHjAW4BFAFuAeMBFgGTBQAB7wHrAfECAAHrAuoB6wIAAfEB6wHv
- FAAB9AHyAfEF7wEHAfIB9AH/AfADAAEWAZQBFgMTARYBlAEWBQAB6wHsAesCAAHrAm0B6wIAAesBbQHr
- FwAB8Qj/AfEDAAKUARYBbgESAW4BFgKUBQAC7AFtA+wC6wPsARIBbQHsFwAB8AIHA+8C9wGSAbwDAAEa
- BxYBGgUACewE6wHsFwAB8QHwAfEB8AG8AQcDvAHxAwAB/wGUARYDlAEWAZQB/wUAAe8M7AHvFwAB9AHy
- BvEB8gH0BAAB/wEaAZQBFgGUARoB/zUADP8HAAG8CAcBvAMAAfQBtQi0AbUB9AQAEP8BvAoHAbwEAAP/
- AQcI/wEHBP8BtAHcARkE2wEJAdwBtAH/BAABvALvDK4BtQG8Af8I9AH/AQcC/wIAAQcD7wHyAbMBCQG7
- AmwBiwHyA+8BBwEAAbQCGQEJARkCCQEZAQkBtAX/AQcB8wHyAYsJswHVAa0BkQG8AfQEKgEwATcBMAEq
- AfQB7AEHAbwCAAMHCuoDBwEAAbQB2wIJAdsBCQHbAQkB2wGtA7QBtQH0AbwB8wHyAYsB2wazAbQC2wGz
- AbQBvAH0BTEBWAE3ATEB9AH3Af8BBwL/AbwBBwHvAW0C7QbsAesCBwG8AQABtAHbAQkB2wHcAdsCCQHb
- AbMB2wEJAdwBtAEAAbwB8wHyArQDswK0AboBtAGzAdwB2wG0AbwB/wERARUBSwFRAXkBoAHlAVgB/wG0
- AfQB7AEHAbwB8AEHAfcBEAgSARABkgHvAfABAAG0AdsBGQLbAdwB2wEJAdsBswEJARkBCQG0AQABvAH0
- AfMBCQGzAbQBugEJAbsBugEJARkBugEJAeEBtAHwAf8BRAFLAlgBWQHlAVkBWAH/AbQB9AH3Af8BvAHx
- AfABBwFDARIHFAFDAeQBBwHxAQABtAHbAgkD2wEJAdsBswHbAQkB2wG0AQAB8AH0AvMBtAG6AbsCGQIJ
- BBkBtAHwAf8BUgdYAf8B7wH/AUoB9AG8AfMCvAEUAW0CFAQVAhQB7wEHAfMBAAG6AdsBGQHbAdwC2wEJ
- AdsBswIJAdsBtAEAAfAD9AHyAbQBuwEJARkCCQEZAuIB3AG7AfAB/wgxAf8BBwH/AVEB9AG8AfQBvAHx
- AeoB6wFtAeoBEgEUARUBQwETAeoCBwH0AQABugHbAgkB2wHcAdsBCQHbAbMB2wEJAdsBtAEAAfAE/wHz
- AroDCQIZAdsBugLwCv8BuwH/AVEB/wG8Af8B8AHzAW0I7AFtAfIB8AH/AQABugHbAQkB2wEJAdsDswGt
- AdsBCQHbAbQBAAHwBv8BGQLbAdQC2wEZAf8B8AHzAfEB7wG8ArMBtAGzA7QBuwH/AVEB/wHwAf8B8gHx
- AfcI6wH3AfEB8gH/AQABugEJARkDCQG0Af8CtAHbAQkB2wG6AQAB8Q7/AfECAAHwCv8BUQH/AfADAAHw
- Af8C9ALzAvEB9AHwBAAC2wEJA9sDtAHcAdsBCQHbAboBAAHwAwcG7wP3ApIBvAIAAfMB8QHvAbwIUQH/
- AfADAAHwAf8B9ALzAfED9wG8BAABCQPbAtQB1QG0AQkB2wOzAbQBAAHxAfAC8QLwArwCBwW8AfEEAAHw
- Cv8B8AMAAfAB/wLzAvEB7wH/AfAB/wgAAboBCQEZAwkBtAH/AfAB9AEAAfQB8gzxAfIB9AQAAfMK8QHz
- AwAB8QH/BPQBBwHxAfQJAALbAQkD2wG0AfAB9CUAAfMG8gH0CgABCQbbAfQDAAH/AfQBvAoHAbwB9AH/
- BfQB8wHwARwDbgEcAfIi/wEAAv8BBwr/AQcC/wIRAe8BBwHwARwBcwF0A5oCdAGZAfMBAAH/AfMMvAHz
- Af8BvA0HAbwDAAG8Cv8BvAIAAmYB8gEHAXMBdAF5AnQCSwF0AZkCdAEbAQAB8QHwCvIB8AHxAQABBwH/
- C/QB/wEHAwABvAj/AfQB/wG8AgABZgEVAfEBkgGaBHQCmgFLAXQCmgGZAQAB8AzyAfABAAG8AfQGcwJ4
- ARwCmQH0AbwDAAG8B/8C9AH/AbwCAAESAWYB8wH3BZoBdAFLAXMBHAJ0ARoBAAHwDPIB8AEAAbwB9AFz
- ARwBeAFzAngBmQEcAZ8BwwEIAfQBvAMAAbwG/wP0Af8BvAIAAa4B6gH/Ae8DmgGZAXQBcwGSAe8BBwHw
- AbwCAAHxDPIB8QEAAbwB9AFzARwBeAFzAXgCmQGYAZ8BGwEHAfQBvAMAAbwF/wT0Af8BvAIAAuoC8QN0
- AZMBvAEHAe8BBwG8AfEB8AIAAfEB8wvyAfEBAAG8AfQDcwN4AZgCmQEIAbsB9AG8AwABvAT/BvQBvAYA
- AfQB7wKSBOwB7QHvAfQCAAHxAfML8gHxAQABvAH/AXMDeAKZAZ8BmQEbARkBuwH/AbwDAAHwA/8F9AHz
- AfQB8AYAAfEB8gG8AQcB7wL3Ae8BvAHxAfACAAHxA/MJ8gHxAQABvAH/AXMDeAKZAZ8BmQHxAdwBugH/
- AbwDAAHwAv8F9ALzAfQB8AYAAfEB8gG8AQcB7wL3Ae8BvAHyAfACAAHyBvMH8gEAAfAB/wFzAXgBmQF4
- AZkBnwHDAQgBCQHcAboB/wHwAwAB8AH/BfQC8wHxAfQB8AYAAfEB8wHxAfABvAIHAbwB8AHzAfACAAHy
- AfQK8wH0AfIBAAHwAf8DeAOZAQgCuwK6Af8B8AMAAfAB/wT0AvMC8QH0AfAGAAH0Ae8CkgTsAe0B7wH0
- AgAB8gH0CvMB9AHyAQAB8AH/AXgDmQHDARsB8QG7AtwBugH/AfADAAHwAf8D9ALzAfED9wG8BgAB8QHy
- AbwBBwHvAvcBBwG8AfIB8AIAAfIB9ArzAfQB8gEAAfAB/wF4A5kBwwHCAQkBugHcAdsBugH/AfADAAHw
- Af8C9ALzAvEB7wH/AfAB9AYAAfEB8gG8AQcB7wL3AQcBvAHzAfACAAHzAfIK9AHyAfMBAAHwAf8BeAGY
- ApkBCAK7A7oBtAH/AfADAAHxAv8F9AEHAfEB9AcAAfEB8wHxAfABvAIHAbwB8AHzAfACAAH/AfMK8gHz
- Af8BAAHxDf8B8QMAAfMI8gH0CAAB8gnxAfIRAAHzDfIB8wEAAUIBTQE+BwABPgMAASgDAAFAAwABMAMA
- AQEBAAEBBQABgAEBFgAD/wIAAR8B4AEPAcABAwMAAR8B4AEPAcABAwMAAT8B/AF/AfABDwMAAQcB/AF/
- AfABDwMAAQcB+AE/AfgBHwMAAQcB+AE/AfwBPwMAAQcB8AEfAfwBPwQAAfABHwH8AT8CAAHgAQAB4AEP
- AfwBPwIAAeABAAHgAQ8B/AE/AgAB4AEAAeABDwGMATECAAHgAQAB4AEPAYwBMQIAAfwBAAHgAQ8BgAEB
- AgAB/AEAAeABDwGAAQECAAH8AQAB4AEPAYABAQIAAfwBAAHwAR8C/wIAAv8BAAEPAeABBwEAAQ8DAAEP
- AwABDwMAAQMCAAGABAABAwIAAYAHAAGAAQEGAAGAAQEGAAGAAQEGAAGAAQEGAAGAAQEGAAGAAQEGAAGA
- AQECAAHAAQAB4AEHAYABAQIAAcABAAHgAQcBgAEBAgAB8AEAAeABBwH4AQECAAHwAQAB4AEPAfgBAwT/
- AeABHwH4AQcHAAEBAwABAQMAAQEBwAEDAgABgAEBAQABAQHAAQMCAAGAAQEBAAEBAcABAwIAAYABAQEA
- AQEBwAEDAQABAQGAAQEBAAEBAcABAwEAAQEBgAEBAQABAQHAAQMB8AEBAYABAQEAAQEBwAEDAfABAQGA
- AQEBAAEBAcABAwHwAQEBgAEBAQABAQHAAQMB8AEBAYABAQEAAQEBwAEDAfABAQGAAQEBAAEBAcABAwHw
- AQEBgAEBAQABAQHAAQMB8AEBAYABAQEAAQEBwAEHAfABAQGAAQEBAAEBAcABDwHwAQEC/wEAAQEL
-</value>
- </data>
<assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="resImageList.ImageSize" type="System.Drawing.Size, System.Drawing">
+ <value>16, 16</value>
+ </data>
<data name="lstResources.Location" type="System.Drawing.Point, System.Drawing">
<value>3, 31</value>
</data>
@@ -473,54 +384,8 @@
<metadata name="folderImageList.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>137, 17</value>
</metadata>
- <data name="folderImageList.ImageStream" mimetype="application/x-microsoft.net.object.binary.base64">
- <value>
- ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAACk
- CQAAAk1TRnQBSQFMAgEBAgEAATABAAEwAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
- AwABEAMAAQEBAAEgBgABEBYAAwcBCgMSARgDEwEaAxMBGgMTARoDEwEaAxMBGgMTARoDEwEaAxMBGgMT
- ARoDEwEaAxIBGAMIAQvIAAMOARMDPAFnA1ABpANQAaQDUAGkA1ABpANQAaQDUAGkA1ABpANQAaQDUAGk
- A1ABpAM8AWgDEAEVBAADBAEGAxABFgMTARoDEwEaAxMBGgMTARoDEwEaAxMBGgMTARoDEwEaAxMBGgMT
- ARoDEwEaAxMBGgMQARYDBAEGiAADGgElA0sBjgOGAf8DggH/A4IB/wOCAf8DggH/A4IB/wOCAf8DhgH/
- A0sBjgMaASUIAAJMAU0BkQFWAloBvQFWAloBvQFWAloBvQFWAloBvQFWAloBvQFWAloBvQFWAloBvQFW
- AloBvQFWAloBvQFWAloBvQFWAloBvQFWAloBvQFWAloBvQFWAloBvQJMAU0BkYwAA0wBkwNnAf8DYwH/
- A2MB/wNjAf8DYwH/A2MB/wEtAcwBLQH/A2cB/wNMAZMMAAFTAlUBsAGGAc8B8AH/AYIBywHtAf8BggHL
- Ae0B/wGCAcsB7QH/AYIBywHtAf8BggHLAe0B/wGCAcsB7QH/AYIBywHtAf8BggHLAe0B/wGCAcsB7QH/
- AYIBywHtAf8BggHLAe0B/wGCAcsB7QH/AYYBzwHwAf8BUwJVAbCMAANSAagDTwH/A08B/wNPAf8DTwH/
- A08B/wNPAf8DTwH/A08B/wNSAagMAANRAaIBhgHPAe4B/wF3AcgB6AH/AXcByAHoAf8BdwHIAegB/wF3
- AcgB6AH/AXcByAHoAf8BdwHIAegB/wF3AcgB6AH/AXcByAHoAf8BdwHIAegB/wF3AcgB6AH/AXcByAHo
- Af8BdwHIAegB/wGGAc8B7gH/A1EBoowAA0UBfgPHAf8DvQH/A70B/wO9Af8DvQH/A70B/wO9Af8DxwH/
- A0UBfgwAA1ABnQGKAdMB8AH/AYIBzAHrAf8BggHMAesB/wGCAcwB6wH/AYIBzAHrAf8BggHMAesB/wGC
- AcwB6wH/AYIBzAHrAf8BggHMAesB/wGCAcwB6wH/AYIBzAHrAf8BggHMAesB/wGCAcwB6wH/AYoB0wHw
- Af8DUAGdjAADQwF4A8oB/wPAAf8DwAH/A8AB/wPAAf8DwAH/A9IB/wPKAf8DQwF4DAADTgGZAY8B1wHy
- Af8BhwHQAe0B/wGHAdAB7QH/AYcB0AHtAf8BhwHQAe0B/wGHAdAB7QH/AYcB0AHtAf8BhwHQAe0B/wGH
- AdAB7QH/AYcB0AHtAf8BhwHQAe0B/wGHAdAB7QH/AYcB0AHtAf8BjwHXAfIB/wNOAZmMAANCAXUDzQH/
- A8MB/wPDAf8DwwH/A8MB/wPDAf8DmQH/A80B/wNCAXUMAAFNAk4BlQGUAdsB9AH/AY0B1QHwAf8BjQHV
- AfAB/wGNAdUB8AH/AY0B1QHwAf8BjQHVAfAB/wGNAdUB8AH/AY0B1QHwAf8BjQHVAfAB/wGNAdUB8AH/
- AY0B1QHwAf8BjQHVAfAB/wGNAdUB8AH/AZQB2wH0Af8BTQJOAZWMAANBAXMD1gH/A9EB/wPRAf8D0QH/
- A9EB/wPRAf8D0QH/A9YB/wNBAXMMAANMAZIBmQHgAfYB/wGSAdoB8wH/AZIB2gHzAf8BkgHaAfMB/wGS
- AdoB8wH/AZIB2gHzAf8BkgHaAfMB/wGSAdoB8wH/AZIB2gHzAf8BkgHaAfMB/wGSAdoB8wH/AZIB2gHz
- Af8BkgHaAfMB/wGZAeAB9gH/A0wBkowAA0ABcQO3Af8DuwH/A7sB/wO7Af8DuwH/A7sB/wO7Af8DtwH/
- A0ABcQwAA0sBjgGfAeUB+QH/AZgB3wH2Af8BmAHfAfYB/wGYAd8B9gH/AZgB3wH2Af8BmAHfAfYB/wGY
- Ad8B9gH/AZgB3wH2Af8BmAHfAfYB/wGYAd8B9gH/AZgB3wH2Af8BmAHfAfYB/wGYAd8B9gH/AZ8B5QH5
- Af8DSwGOjAADQAFvA9kB/wPPAf8DzwH/A88B/wPPAf8DzwH/A88B/wPZAf8DQAFvDAADSgGLAaMB6QH7
- Af8BnQHjAfkB/wGdAeMB+QH/AZ0B4wH5Af8BnQHjAfkB/wGdAeMB+QH/AZ0B4wH5Af8BowHpAfoB/wGj
- AekB+gH/AaMB6QH6Af8BowHpAfoB/wGjAekB+gH/AaMB6QH6Af8BpgHsAfsB/wNKAYuMAAM/AW0D4QH/
- A9wB/wPcAf8D3AH/A9wB/wPcAf8D3AH/A+EB/wM/AW0MAAFIAkkBiAGoAe0B/QH/AaIB5wH7Af8BogHn
- AfsB/wGiAecB+wH/AaIB5wH7Af8BogHnAfsB/wGrAfAB/QH/AYUBygHmAf8BcgG8Ad4B/wFyAbwB3gH/
- AXIBvAHeAf8BcgG8Ad4B/wFyAbwB3gH/AXIBvAHeAf8BSAJJAYiMAAM+AWsDwQH/A8YB/wPGAf8DxgH/
- A8YB/wPGAf8DxgH/A8EB/wM+AWsMAANIAYUBrgHzAv8BqwHwAf4B/wGrAfAB/gH/AasB8AH+Af8BqwHw
- Af4B/wGuAfMC/wGJAc0B6QH/AYkBzQHpAf8BqwHwAf4B/wGrAfAB/gH/AasB8AH+Af8BqwHwAf4B/wGr
- AfAB/gH/Aa4B8wL/A0gBhYwAAz0BaQPjAf8D2gH/A9oB/wPaAf8D2gH/A9oB/wPaAf8D4wH/Az0BaQwA
- AzsBYwFHAkgBgwFHAkgBgwFHAkgBgwFHAkgBgwFHAkgBgwFHAkgBgwFHAkgBgwL+Af0B/wL4AfMB/wLw
- AeYB/wLpAdsB/wH+AckBOwH/AfQBtgEoAf8BRwJIAYMDOwFjjAADPQFoA+oB/wPlAf8D5QH/A+UB/wPl
- Af8D5QH/A+UB/wPqAf8DPQFoKAADIAEuAUYCRwGBAUYCRwGBAUYCRwGBAUYCRwGBAUYCRwGBAUYCRwGB
- AyABLpAAAzEBTQM9AWcDPQFnAz0BZwM9AWcDPQFnAz0BZwM9AWcDPQFnAzEBTcwAAUIBTQE+BwABPgMA
- ASgDAAFAAwABEAMAAQEBAAEBBQABgBcAA/8BAAGAAQEC/wQAAYABAQYAAcABAwYAAeABBwYAAeABBwYA
- AeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwH+
- AQEEAAHgAQcC/wQACw==
-</value>
+ <data name="folderImageList.ImageSize" type="System.Drawing.Size, System.Drawing">
</data>
<data name="trvFolders.Location" type="System.Drawing.Point, System.Drawing">
<value>12, 31</value>
Modified: trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
--- trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2011-11-07 16:31:53 UTC (rev 6203)
+++ trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2011-11-08 13:43:56 UTC (rev 6204)
@@ -893,6 +893,24 @@
</Compile>
<Compile Include="Migration\NsDoc.cs" />
<Compile Include="NsDoc.cs" />
+ <Compile Include="Packaging\AddResourceEntryDialog.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="Packaging\AddResourceEntryDialog.designer.cs">
+ <DependentUpon>AddResourceEntryDialog.cs</DependentUpon>
+ </Compile>
+ <Compile Include="Packaging\EditResourceDataEntryDialog.cs">
+ </Compile>
+ <Compile Include="Packaging\EditResourceDataEntryDialog.designer.cs">
+ <DependentUpon>EditResourceDataEntryDialog.cs</DependentUpon>
+ </Compile>
+ <Compile Include="Packaging\PackageEditorDialog.cs">
+ </Compile>
+ <Compile Include="Packaging\PackageEditorDialog.designer.cs">
+ <DependentUpon>PackageEditorDialog.cs</DependentUpon>
+ </Compile>
<Compile Include="PrintLayout\LogoDialog.cs">
</Compile>
@@ -937,6 +955,7 @@
<DependentUpon>Resources.resx</DependentUpon>
</Compile>
<Compile Include="RepositoryHandle.cs" />
+ <Compile Include="RepositoryIcons.cs" />
<Compile Include="ResourceEditorServiceBase.cs" />
<Compile Include="SymbolDefinition\AdvancedSettingsCtrl.cs">
<SubType>UserControl</SubType>
@@ -2206,6 +2225,14 @@
<Content Include="OdbcDriverMap.xml">
<CopyToOutputDirectory>Always</CopyToOutputDirectory>
</Content>
+ <None Include="Resources\disk.png" />
+ <None Include="Resources\printer.png" />
+ <None Include="Resources\map.png" />
+ <None Include="Resources\images-stack.png" />
+ <None Include="Resources\database-share.png" />
+ <None Include="Resources\blueprints.png" />
+ <None Include="Resources\applications-stack.png" />
+ <None Include="Resources\application-browser.png" />
<None Include="Resources\color.png" />
<EmbeddedResource Include="Common\ColorPickerDialog.resx">
<DependentUpon>ColorPickerDialog.cs</DependentUpon>
@@ -2219,6 +2246,15 @@
<EmbeddedResource Include="MapDefinition\ExtentCalculationDialog.resx">
<DependentUpon>ExtentCalculationDialog.cs</DependentUpon>
</EmbeddedResource>
+ <EmbeddedResource Include="Packaging\AddResourceEntryDialog.resx">
+ </EmbeddedResource>
+ <EmbeddedResource Include="Packaging\EditResourceDataEntryDialog.resx">
+ <EmbeddedResource Include="Packaging\PackageEditorDialog.resx">
<EmbeddedResource Include="Resources\areas\Acad_iso02w100.png" />
<EmbeddedResource Include="Resources\areas\Acad_iso03w100.png" />
<EmbeddedResource Include="Resources\areas\Acad_iso04w100.png" />
Added: trunk/Tools/Maestro/Maestro.Editors/Packaging/AddResourceEntryDialog.cs
--- trunk/Tools/Maestro/Maestro.Editors/Packaging/AddResourceEntryDialog.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Packaging/AddResourceEntryDialog.cs 2011-11-08 13:43:56 UTC (rev 6204)
@@ -0,0 +1,113 @@
+// Copyright (C) 2009, Kenneth Skovhede
+// http://www.hexad.dk, opensource at hexad.dk
+#endregion
+using System;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Text;
+using System.Windows.Forms;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.MaestroAPI.Exceptions;
+namespace Maestro.Editors.Packaging
+ public partial class AddResourceEntryDialog : Form
+ public AddResourceEntryDialog()
+ InitializeComponent();
+ private void UseHeader_CheckedChanged(object sender, EventArgs e)
+ HeaderPath.Enabled = BrowseHeaderButton.Enabled = UseHeader.Checked;
+ private void BrowseHeaderButton_Click(object sender, EventArgs e)
+ if (BrowseFileDialog.ShowDialog(this) == DialogResult.OK)
+ HeaderPath.Text = BrowseFileDialog.FileName;
+ private void BrowseContentButton_Click(object sender, EventArgs e)
+ ContentPath.Text = BrowseFileDialog.FileName;
+ private void OKBtn_Click(object sender, EventArgs e)
+ try
+ if (UseAlternateName.Checked && AlternateName.Text.Trim().Length == 0)
+ MessageBox.Show(this, Properties.Resources.AlternateNameMissing, Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+ AlternateName.Focus();
+ return;
+ if (UseHeader.Checked && !System.IO.File.Exists(HeaderPath.Text))
+ MessageBox.Show(this, Properties.Resources.HeaderFileMissing, Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+ HeaderPath.Focus();
+ return;
+ if (!System.IO.File.Exists(ContentPath.Text))
+ MessageBox.Show(this, Properties.Resources.ContentFileMissing, Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+ ContentPath.Focus();
+ return;
+ catch (Exception ex)
+ string msg = NestedExceptionMessageProcessor.GetFullMessage(ex);
+ MessageBox.Show(this, string.Format(Properties.Resources.FilenameValidationError, msg), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+ return;
+ this.DialogResult = DialogResult.OK;
+ this.Close();
+ public string ContentFilepath { get { return ContentPath.Text; } }
+ public string HeaderFilepath { get { return UseHeader.Checked ? HeaderPath.Text : null; } }
+ public string ResourceName { get { return UseAlternateName.Checked ? AlternateName.Text : System.IO.Path.GetFileName(ContentPath.Text); } }
+ private void UseAlternateName_CheckedChanged(object sender, EventArgs e)
+ AlternateName.Enabled = UseAlternateName.Checked;
+ private void ContentPath_TextChanged(object sender, EventArgs e)
+ try { AlternateName.Text = System.IO.Path.GetFileName(ContentPath.Text); }
+ catch { }
+ private void AddResourceEntry_Load(object sender, EventArgs e)
+ this.Show();
Added: trunk/Tools/Maestro/Maestro.Editors/Packaging/AddResourceEntryDialog.designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Packaging/AddResourceEntryDialog.designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Packaging/AddResourceEntryDialog.designer.cs 2011-11-08 13:43:56 UTC (rev 6204)
@@ -0,0 +1,151 @@
+ partial class AddResourceEntryDialog
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(AddResourceEntryDialog));
+ this.UseHeader = new System.Windows.Forms.CheckBox();
+ this.BrowseHeaderButton = new System.Windows.Forms.Button();
+ this.HeaderPath = new System.Windows.Forms.TextBox();
+ this.label1 = new System.Windows.Forms.Label();
+ this.ContentPath = new System.Windows.Forms.TextBox();
+ this.BrowseContentButton = new System.Windows.Forms.Button();
+ this.OKBtn = new System.Windows.Forms.Button();
+ this.CancelBtn = new System.Windows.Forms.Button();
+ this.BrowseFileDialog = new System.Windows.Forms.OpenFileDialog();
+ this.AlternateName = new System.Windows.Forms.TextBox();
+ this.UseAlternateName = new System.Windows.Forms.CheckBox();
+ this.SuspendLayout();
+ // UseHeader
+ resources.ApplyResources(this.UseHeader, "UseHeader");
+ this.UseHeader.Name = "UseHeader";
+ this.UseHeader.UseVisualStyleBackColor = true;
+ this.UseHeader.CheckedChanged += new System.EventHandler(this.UseHeader_CheckedChanged);
+ // BrowseHeaderButton
+ resources.ApplyResources(this.BrowseHeaderButton, "BrowseHeaderButton");
+ this.BrowseHeaderButton.Name = "BrowseHeaderButton";
+ this.BrowseHeaderButton.UseVisualStyleBackColor = true;
+ this.BrowseHeaderButton.Click += new System.EventHandler(this.BrowseHeaderButton_Click);
+ // HeaderPath
+ resources.ApplyResources(this.HeaderPath, "HeaderPath");
+ this.HeaderPath.Name = "HeaderPath";
+ // label1
+ resources.ApplyResources(this.label1, "label1");
+ this.label1.Name = "label1";
+ // ContentPath
+ resources.ApplyResources(this.ContentPath, "ContentPath");
+ this.ContentPath.Name = "ContentPath";
+ this.ContentPath.TextChanged += new System.EventHandler(this.ContentPath_TextChanged);
+ // BrowseContentButton
+ resources.ApplyResources(this.BrowseContentButton, "BrowseContentButton");
+ this.BrowseContentButton.Name = "BrowseContentButton";
+ this.BrowseContentButton.UseVisualStyleBackColor = true;
+ this.BrowseContentButton.Click += new System.EventHandler(this.BrowseContentButton_Click);
+ // OKBtn
+ resources.ApplyResources(this.OKBtn, "OKBtn");
+ this.OKBtn.Name = "OKBtn";
+ this.OKBtn.UseVisualStyleBackColor = true;
+ this.OKBtn.Click += new System.EventHandler(this.OKBtn_Click);
+ // CancelBtn
+ resources.ApplyResources(this.CancelBtn, "CancelBtn");
+ this.CancelBtn.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+ this.CancelBtn.Name = "CancelBtn";
+ this.CancelBtn.UseVisualStyleBackColor = true;
+ // BrowseFileDialog
+ resources.ApplyResources(this.BrowseFileDialog, "BrowseFileDialog");
+ // AlternateName
+ resources.ApplyResources(this.AlternateName, "AlternateName");
+ this.AlternateName.Name = "AlternateName";
+ // UseAlternateName
+ resources.ApplyResources(this.UseAlternateName, "UseAlternateName");
+ this.UseAlternateName.Name = "UseAlternateName";
+ this.UseAlternateName.UseVisualStyleBackColor = true;
+ this.UseAlternateName.CheckedChanged += new System.EventHandler(this.UseAlternateName_CheckedChanged);
+ // AddResourceEntryDialog
+ resources.ApplyResources(this, "$this");
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.CancelButton = this.CancelBtn;
+ this.Controls.Add(this.AlternateName);
+ this.Controls.Add(this.UseAlternateName);
+ this.Controls.Add(this.CancelBtn);
+ this.Controls.Add(this.OKBtn);
+ this.Controls.Add(this.BrowseContentButton);
+ this.Controls.Add(this.ContentPath);
+ this.Controls.Add(this.label1);
+ this.Controls.Add(this.HeaderPath);
+ this.Controls.Add(this.BrowseHeaderButton);
+ this.Controls.Add(this.UseHeader);
+ this.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog;
+ this.MaximizeBox = false;
+ this.MinimizeBox = false;
+ this.Name = "AddResourceEntryDialog";
+ this.Load += new System.EventHandler(this.AddResourceEntry_Load);
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.CheckBox UseHeader;
+ private System.Windows.Forms.Button BrowseHeaderButton;
+ private System.Windows.Forms.TextBox HeaderPath;
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.TextBox ContentPath;
+ private System.Windows.Forms.Button BrowseContentButton;
+ private System.Windows.Forms.Button OKBtn;
+ private System.Windows.Forms.Button CancelBtn;
+ private System.Windows.Forms.OpenFileDialog BrowseFileDialog;
+ private System.Windows.Forms.TextBox AlternateName;
+ private System.Windows.Forms.CheckBox UseAlternateName;
Added: trunk/Tools/Maestro/Maestro.Editors/Packaging/AddResourceEntryDialog.resx
--- trunk/Tools/Maestro/Maestro.Editors/Packaging/AddResourceEntryDialog.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Packaging/AddResourceEntryDialog.resx 2011-11-08 13:43:56 UTC (rev 6204)
@@ -0,0 +1,426 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="UseHeader.AutoSize" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="UseHeader.Location" type="System.Drawing.Point, System.Drawing">
+ <value>15, 11</value>
+ </data>
+ <data name="UseHeader.Size" type="System.Drawing.Size, System.Drawing">
+ <value>77, 17</value>
+ </data>
+ <data name="UseHeader.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="UseHeader.Text" xml:space="preserve">
+ <value>Header file</value>
+ </data>
+ <data name=">>UseHeader.Name" xml:space="preserve">
+ <value>UseHeader</value>
+ </data>
+ <data name=">>UseHeader.Type" xml:space="preserve">
+ <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>UseHeader.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>UseHeader.ZOrder" xml:space="preserve">
+ <value>9</value>
+ </data>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="BrowseHeaderButton.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Right</value>
+ </data>
+ <data name="BrowseHeaderButton.Enabled" type="System.Boolean, mscorlib">
+ <value>False</value>
+ </data>
+ <data name="BrowseHeaderButton.Location" type="System.Drawing.Point, System.Drawing">
+ <value>337, 8</value>
+ </data>
+ <data name="BrowseHeaderButton.Size" type="System.Drawing.Size, System.Drawing">
+ <value>24, 20</value>
+ </data>
+ <data name="BrowseHeaderButton.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name="BrowseHeaderButton.Text" xml:space="preserve">
+ <value>...</value>
+ </data>
+ <data name=">>BrowseHeaderButton.Name" xml:space="preserve">
+ <value>BrowseHeaderButton</value>
+ </data>
+ <data name=">>BrowseHeaderButton.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>BrowseHeaderButton.Parent" xml:space="preserve">
+ </data>
+ <data name=">>BrowseHeaderButton.ZOrder" xml:space="preserve">
+ <value>8</value>
+ </data>
+ <data name="HeaderPath.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Left, Right</value>
+ </data>
+ <data name="HeaderPath.Enabled" type="System.Boolean, mscorlib">
+ </data>
+ <data name="HeaderPath.Location" type="System.Drawing.Point, System.Drawing">
+ <value>112, 8</value>
+ </data>
+ <data name="HeaderPath.Size" type="System.Drawing.Size, System.Drawing">
+ <value>225, 20</value>
+ </data>
+ <data name="HeaderPath.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name=">>HeaderPath.Name" xml:space="preserve">
+ <value>HeaderPath</value>
+ </data>
+ <data name=">>HeaderPath.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>HeaderPath.Parent" xml:space="preserve">
+ </data>
+ <data name=">>HeaderPath.ZOrder" xml:space="preserve">
+ <value>7</value>
+ </data>
+ <data name="label1.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>32, 44</value>
+ </data>
+ <data name="label1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>60, 13</value>
+ </data>
+ <data name="label1.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="label1.Text" xml:space="preserve">
+ <value>Content file</value>
+ </data>
+ <data name=">>label1.Name" xml:space="preserve">
+ <value>label1</value>
+ </data>
+ <data name=">>label1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>label1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label1.ZOrder" xml:space="preserve">
+ <value>6</value>
+ </data>
+ <data name="ContentPath.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="ContentPath.Location" type="System.Drawing.Point, System.Drawing">
+ <value>112, 40</value>
+ </data>
+ <data name="ContentPath.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="ContentPath.TabIndex" type="System.Int32, mscorlib">
+ <value>4</value>
+ </data>
+ <data name=">>ContentPath.Name" xml:space="preserve">
+ <value>ContentPath</value>
+ </data>
+ <data name=">>ContentPath.Type" xml:space="preserve">
+ </data>
+ <data name=">>ContentPath.Parent" xml:space="preserve">
+ </data>
+ <data name=">>ContentPath.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
+ <data name="BrowseContentButton.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="BrowseContentButton.Location" type="System.Drawing.Point, System.Drawing">
+ <value>337, 40</value>
+ </data>
+ <data name="BrowseContentButton.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="BrowseContentButton.TabIndex" type="System.Int32, mscorlib">
+ <value>5</value>
+ </data>
+ <data name="BrowseContentButton.Text" xml:space="preserve">
+ </data>
+ <data name=">>BrowseContentButton.Name" xml:space="preserve">
+ <value>BrowseContentButton</value>
+ </data>
+ <data name=">>BrowseContentButton.Type" xml:space="preserve">
+ </data>
+ <data name=">>BrowseContentButton.Parent" xml:space="preserve">
+ </data>
+ <data name=">>BrowseContentButton.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="OKBtn.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Bottom</value>
+ </data>
+ <data name="OKBtn.Location" type="System.Drawing.Point, System.Drawing">
+ <value>108, 104</value>
+ </data>
+ <data name="OKBtn.Size" type="System.Drawing.Size, System.Drawing">
+ <value>75, 23</value>
+ </data>
+ <data name="OKBtn.TabIndex" type="System.Int32, mscorlib">
+ <value>6</value>
+ </data>
+ <data name="OKBtn.Text" xml:space="preserve">
+ <value>OK</value>
+ </data>
+ <data name=">>OKBtn.Name" xml:space="preserve">
+ <value>OKBtn</value>
+ </data>
+ <data name=">>OKBtn.Type" xml:space="preserve">
+ </data>
+ <data name=">>OKBtn.Parent" xml:space="preserve">
+ </data>
+ <data name=">>OKBtn.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="CancelBtn.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="CancelBtn.Location" type="System.Drawing.Point, System.Drawing">
+ <value>196, 104</value>
+ </data>
+ <data name="CancelBtn.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="CancelBtn.TabIndex" type="System.Int32, mscorlib">
+ <value>7</value>
+ </data>
+ <data name="CancelBtn.Text" xml:space="preserve">
+ <value>Cancel</value>
+ </data>
+ <data name=">>CancelBtn.Name" xml:space="preserve">
+ <value>CancelBtn</value>
+ </data>
+ <data name=">>CancelBtn.Type" xml:space="preserve">
+ </data>
+ <data name=">>CancelBtn.Parent" xml:space="preserve">
+ </data>
+ <data name=">>CancelBtn.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <metadata name="BrowseFileDialog.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
+ <data name="BrowseFileDialog.Filter" xml:space="preserve">
+ <value>All files (*.*)|*.*</value>
+ </data>
+ <data name="BrowseFileDialog.Title" xml:space="preserve">
+ <value>Select the file to use</value>
+ </data>
+ <data name="AlternateName.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="AlternateName.Enabled" type="System.Boolean, mscorlib">
+ </data>
+ <data name="AlternateName.Location" type="System.Drawing.Point, System.Drawing">
+ <value>112, 72</value>
+ </data>
+ <data name="AlternateName.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="AlternateName.TabIndex" type="System.Int32, mscorlib">
+ <value>9</value>
+ </data>
+ <data name=">>AlternateName.Name" xml:space="preserve">
+ <value>AlternateName</value>
+ </data>
+ <data name=">>AlternateName.Type" xml:space="preserve">
+ </data>
+ <data name=">>AlternateName.Parent" xml:space="preserve">
+ </data>
+ <data name=">>AlternateName.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="UseAlternateName.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="UseAlternateName.Location" type="System.Drawing.Point, System.Drawing">
+ <value>9, 74</value>
+ </data>
+ <data name="UseAlternateName.Size" type="System.Drawing.Size, System.Drawing">
+ <value>97, 17</value>
+ </data>
+ <data name="UseAlternateName.TabIndex" type="System.Int32, mscorlib">
+ <value>8</value>
+ </data>
+ <data name="UseAlternateName.Text" xml:space="preserve">
+ <value>Alternate name</value>
+ </data>
+ <data name=">>UseAlternateName.Name" xml:space="preserve">
+ <value>UseAlternateName</value>
+ </data>
+ <data name=">>UseAlternateName.Type" xml:space="preserve">
+ </data>
+ <data name=">>UseAlternateName.Parent" xml:space="preserve">
+ </data>
+ <data name=">>UseAlternateName.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ </metadata>
+ <data name="$this.AutoScaleDimensions" type="System.Drawing.SizeF, System.Drawing">
+ <value>6, 13</value>
+ </data>
+ <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
+ <value>371, 135</value>
+ </data>
+ <data name="$this.Text" xml:space="preserve">
+ <value>Add a resource</value>
+ </data>
+ <data name=">>BrowseFileDialog.Name" xml:space="preserve">
+ <value>BrowseFileDialog</value>
+ </data>
+ <data name=">>BrowseFileDialog.Type" xml:space="preserve">
+ <value>System.Windows.Forms.OpenFileDialog, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>$this.Name" xml:space="preserve">
+ <value>AddResourceEntryDialog</value>
+ </data>
+ <data name=">>$this.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Form, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+</root>
Added: trunk/Tools/Maestro/Maestro.Editors/Packaging/EditResourceDataEntryDialog.cs
--- trunk/Tools/Maestro/Maestro.Editors/Packaging/EditResourceDataEntryDialog.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Packaging/EditResourceDataEntryDialog.cs 2011-11-08 13:43:56 UTC (rev 6204)
@@ -0,0 +1,95 @@
+#endregion
+using System;
+using System.Data;
+using System.Text;
+ public partial class EditResourceDataEntryDialog : Form
+ private string m_resourceName;
+ private string m_contentType;
+ private string m_filename;
+ private string m_datatype;
+ get { return m_resourceName; }
+ set { m_resourceName = value; }
+ public string ContentType
+ get { return m_contentType; }
+ set { m_contentType = value; }
+ public string Filename
+ get { return m_filename; }
+ set { m_filename = value; }
+ public string DataType
+ get { return m_datatype; }
+ set { m_datatype = value; }
+ public EditResourceDataEntryDialog()
+ private void EditResourceDataEntry_Load(object sender, EventArgs e)
+ ResourceNameBox.Text = m_resourceName;
+ ContentTypeBox.Text = m_contentType;
+ DataTypeBox.SelectedIndex = DataTypeBox.FindString(m_datatype);
+ FilenameBox.Text = m_filename;
+ private void ValidateForm(object sender, EventArgs e)
+ OKBtn.Enabled =
+ !string.IsNullOrEmpty(ResourceNameBox.Text) &&
+ !string.IsNullOrEmpty(ContentTypeBox.Text) &&
+ !string.IsNullOrEmpty(DataTypeBox.Text);
+ m_resourceName = ResourceNameBox.Text;
+ m_contentType = ContentTypeBox.Text;
+ m_datatype = DataTypeBox.Text;
+ this.Close();
Added: trunk/Tools/Maestro/Maestro.Editors/Packaging/EditResourceDataEntryDialog.designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Packaging/EditResourceDataEntryDialog.designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Packaging/EditResourceDataEntryDialog.designer.cs 2011-11-08 13:43:56 UTC (rev 6204)
@@ -0,0 +1,151 @@
+ partial class EditResourceDataEntryDialog
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(EditResourceDataEntryDialog));
+ this.ResourceNameBox = new System.Windows.Forms.TextBox();
+ this.label2 = new System.Windows.Forms.Label();
+ this.ContentTypeBox = new System.Windows.Forms.ComboBox();
+ this.DataTypeBox = new System.Windows.Forms.ComboBox();
+ this.label3 = new System.Windows.Forms.Label();
+ this.label4 = new System.Windows.Forms.Label();
+ this.FilenameBox = new System.Windows.Forms.TextBox();
+ // label1
+ // ResourceNameBox
+ resources.ApplyResources(this.ResourceNameBox, "ResourceNameBox");
+ this.ResourceNameBox.Name = "ResourceNameBox";
+ this.ResourceNameBox.TextChanged += new System.EventHandler(this.ValidateForm);
+ // label2
+ resources.ApplyResources(this.label2, "label2");
+ this.label2.Name = "label2";
+ // ContentTypeBox
+ resources.ApplyResources(this.ContentTypeBox, "ContentTypeBox");
+ this.ContentTypeBox.FormattingEnabled = true;
+ this.ContentTypeBox.Items.AddRange(new object[] {
+ resources.GetString("ContentTypeBox.Items"),
+ resources.GetString("ContentTypeBox.Items1")});
+ this.ContentTypeBox.Name = "ContentTypeBox";
+ this.ContentTypeBox.TextChanged += new System.EventHandler(this.ValidateForm);
+ // DataTypeBox
+ resources.ApplyResources(this.DataTypeBox, "DataTypeBox");
+ this.DataTypeBox.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
+ this.DataTypeBox.FormattingEnabled = true;
+ this.DataTypeBox.Items.AddRange(new object[] {
+ resources.GetString("DataTypeBox.Items"),
+ resources.GetString("DataTypeBox.Items1")});
+ this.DataTypeBox.Name = "DataTypeBox";
+ this.DataTypeBox.SelectedIndexChanged += new System.EventHandler(this.ValidateForm);
+ this.DataTypeBox.TextChanged += new System.EventHandler(this.ValidateForm);
+ // label3
+ resources.ApplyResources(this.label3, "label3");
+ this.label3.Name = "label3";
+ // label4
+ resources.ApplyResources(this.label4, "label4");
+ this.label4.Name = "label4";
+ // FilenameBox
+ resources.ApplyResources(this.FilenameBox, "FilenameBox");
+ this.FilenameBox.Name = "FilenameBox";
+ this.FilenameBox.ReadOnly = true;
+ // OKBtn
+ // CancelBtn
+ // EditResourceDataEntryDialog
+ this.AcceptButton = this.OKBtn;
+ this.Controls.Add(this.FilenameBox);
+ this.Controls.Add(this.label4);
+ this.Controls.Add(this.DataTypeBox);
+ this.Controls.Add(this.label3);
+ this.Controls.Add(this.ContentTypeBox);
+ this.Controls.Add(this.label2);
+ this.Controls.Add(this.ResourceNameBox);
+ this.Name = "EditResourceDataEntryDialog";
+ this.Load += new System.EventHandler(this.EditResourceDataEntry_Load);
+ #endregion
+ private System.Windows.Forms.TextBox ResourceNameBox;
+ private System.Windows.Forms.Label label2;
+ private System.Windows.Forms.ComboBox ContentTypeBox;
+ private System.Windows.Forms.ComboBox DataTypeBox;
+ private System.Windows.Forms.Label label3;
+ private System.Windows.Forms.Label label4;
+ private System.Windows.Forms.TextBox FilenameBox;
Added: trunk/Tools/Maestro/Maestro.Editors/Packaging/EditResourceDataEntryDialog.resx
--- trunk/Tools/Maestro/Maestro.Editors/Packaging/EditResourceDataEntryDialog.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Packaging/EditResourceDataEntryDialog.resx 2011-11-08 13:43:56 UTC (rev 6204)
@@ -0,0 +1,411 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ </data>
+ <value>8, 11</value>
+ </data>
+ <value>35, 13</value>
+ </data>
+ <value>0</value>
+ </data>
+ <value>Name</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>9</value>
+ </data>
+ <data name="ResourceNameBox.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="ResourceNameBox.Location" type="System.Drawing.Point, System.Drawing">
+ <value>80, 8</value>
+ </data>
+ <data name="ResourceNameBox.Size" type="System.Drawing.Size, System.Drawing">
+ <value>200, 20</value>
+ </data>
+ <data name="ResourceNameBox.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name=">>ResourceNameBox.Name" xml:space="preserve">
+ <value>ResourceNameBox</value>
+ </data>
+ <data name=">>ResourceNameBox.Type" xml:space="preserve">
+ </data>
+ <data name=">>ResourceNameBox.Parent" xml:space="preserve">
+ </data>
+ <data name=">>ResourceNameBox.ZOrder" xml:space="preserve">
+ <value>8</value>
+ </data>
+ <data name="label2.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label2.Location" type="System.Drawing.Point, System.Drawing">
+ <value>8, 35</value>
+ </data>
+ <data name="label2.Size" type="System.Drawing.Size, System.Drawing">
+ <value>71, 13</value>
+ </data>
+ <data name="label2.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="label2.Text" xml:space="preserve">
+ <value>Content Type</value>
+ </data>
+ <data name=">>label2.Name" xml:space="preserve">
+ <value>label2</value>
+ </data>
+ <data name=">>label2.Type" xml:space="preserve">
+ </data>
+ <data name=">>label2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label2.ZOrder" xml:space="preserve">
+ <value>7</value>
+ </data>
+ <data name="ContentTypeBox.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="ContentTypeBox.Items" xml:space="preserve">
+ <value>text/xml</value>
+ </data>
+ <data name="ContentTypeBox.Items1" xml:space="preserve">
+ <value>application/octet-stream</value>
+ </data>
+ <data name="ContentTypeBox.Location" type="System.Drawing.Point, System.Drawing">
+ <value>80, 32</value>
+ </data>
+ <data name="ContentTypeBox.Size" type="System.Drawing.Size, System.Drawing">
+ <value>200, 21</value>
+ </data>
+ <data name="ContentTypeBox.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name=">>ContentTypeBox.Name" xml:space="preserve">
+ <value>ContentTypeBox</value>
+ </data>
+ <data name=">>ContentTypeBox.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ComboBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>ContentTypeBox.Parent" xml:space="preserve">
+ </data>
+ <data name=">>ContentTypeBox.ZOrder" xml:space="preserve">
+ <value>6</value>
+ </data>
+ <data name="DataTypeBox.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="DataTypeBox.Items" xml:space="preserve">
+ <value>File</value>
+ </data>
+ <data name="DataTypeBox.Items1" xml:space="preserve">
+ <value>Stream</value>
+ </data>
+ <data name="DataTypeBox.Location" type="System.Drawing.Point, System.Drawing">
+ <value>80, 56</value>
+ </data>
+ <data name="DataTypeBox.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="DataTypeBox.TabIndex" type="System.Int32, mscorlib">
+ <value>5</value>
+ </data>
+ <data name=">>DataTypeBox.Name" xml:space="preserve">
+ <value>DataTypeBox</value>
+ </data>
+ <data name=">>DataTypeBox.Type" xml:space="preserve">
+ </data>
+ <data name=">>DataTypeBox.Parent" xml:space="preserve">
+ </data>
+ <data name=">>DataTypeBox.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="label3.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label3.Location" type="System.Drawing.Point, System.Drawing">
+ <value>8, 59</value>
+ </data>
+ <data name="label3.Size" type="System.Drawing.Size, System.Drawing">
+ <value>57, 13</value>
+ </data>
+ <data name="label3.TabIndex" type="System.Int32, mscorlib">
+ <value>4</value>
+ </data>
+ <data name="label3.Text" xml:space="preserve">
+ <value>Data Type</value>
+ </data>
+ <data name=">>label3.Name" xml:space="preserve">
+ <value>label3</value>
+ </data>
+ <data name=">>label3.Type" xml:space="preserve">
+ </data>
+ <data name=">>label3.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label3.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
+ <data name="label4.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label4.Location" type="System.Drawing.Point, System.Drawing">
+ <value>8, 83</value>
+ </data>
+ <data name="label4.Size" type="System.Drawing.Size, System.Drawing">
+ <value>54, 13</value>
+ </data>
+ <data name="label4.TabIndex" type="System.Int32, mscorlib">
+ <value>6</value>
+ </data>
+ <data name="label4.Text" xml:space="preserve">
+ <value>File Name</value>
+ </data>
+ <data name=">>label4.Name" xml:space="preserve">
+ <value>label4</value>
+ </data>
+ <data name=">>label4.Type" xml:space="preserve">
+ </data>
+ <data name=">>label4.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label4.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="FilenameBox.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="FilenameBox.Location" type="System.Drawing.Point, System.Drawing">
+ <value>80, 80</value>
+ </data>
+ <data name="FilenameBox.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="FilenameBox.TabIndex" type="System.Int32, mscorlib">
+ <value>7</value>
+ </data>
+ <data name=">>FilenameBox.Name" xml:space="preserve">
+ <value>FilenameBox</value>
+ </data>
+ <data name=">>FilenameBox.Type" xml:space="preserve">
+ </data>
+ <data name=">>FilenameBox.Parent" xml:space="preserve">
+ </data>
+ <data name=">>FilenameBox.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="OKBtn.Enabled" type="System.Boolean, mscorlib">
+ </data>
+ <value>64, 112</value>
+ </data>
+ <value>72, 24</value>
+ </data>
+ <value>8</value>
+ </data>
+ <value>OK</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>1</value>
+ </data>
+ <value>152, 112</value>
+ </data>
+ </data>
+ <value>9</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>0</value>
+ </data>
+ </metadata>
+ </data>
+ <value>289, 144</value>
+ </data>
+ <data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
+ <value>CenterParent</value>
+ </data>
+ <value>Edit resourcedata details</value>
+ </data>
+ <value>EditResourceDataEntryDialog</value>
+ </data>
+ </data>
+</root>
Added: trunk/Tools/Maestro/Maestro.Editors/Packaging/PackageEditorDialog.cs
--- trunk/Tools/Maestro/Maestro.Editors/Packaging/PackageEditorDialog.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Packaging/PackageEditorDialog.cs 2011-11-08 13:43:56 UTC (rev 6204)
@@ -0,0 +1,474 @@
+#region Disclaimer / License
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Data;
+using System.Text;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using System.IO;
+using Maestro.Packaging;
+ public partial class PackageEditorDialog : Form
+ private Dictionary<string, ResourceItem> m_resources;
+ private IServerConnection _conn;
+ public PackageEditorDialog(string filename, IServerConnection conn)
+ : this()
+ _conn = conn;
+ m_filename = filename;
+ m_resources = new Dictionary<string, ResourceItem>();
+ ResourceTree.ImageList = RepositoryIcons.CreateImageList(); //owner.ResourceEditorMap.SmallImageList;
+ ResourceDataFileList.SmallImageList = RepositoryIcons.CreateImageList(); //ResourceEditors.ShellIcons.ImageList;
+ private PackageEditorDialog()
+ private void PackageEditor_Load(object sender, EventArgs e)
+ this.Show();
+ try
+ m_resources = PackageProgress.ListPackageContents(this, _conn, m_filename);
+ if (m_resources == null)
+ this.DialogResult = DialogResult.Cancel;
+ this.Close();
+ return;
+ RebuildTree();
+ if (ex is System.Reflection.TargetInvocationException && ex.InnerException != null)
+ ex = ex.InnerException;
+ MessageBox.Show(this, string.Format(Properties.Resources.PackageReadError, msg), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+ this.Close();
+ return;
+ OKBtn.Enabled = true;
+ private void RebuildTree()
+ ResourceTree.Nodes.Clear();
+ TreeNode root = ResourceTree.Nodes.Add("Library://");
+ root.ImageIndex = root.SelectedImageIndex = RepositoryIcons.RES_ROOT;
+ foreach (ResourceItem ri in m_resources.Values)
+ string partial = ri.ResourcePath.Substring(root.Text.Length);
+ string[] parts = partial.Split('/');
+ TreeNode cur = root;
+ root.Expand();
+ for (int i = 0; i < parts.Length - 1; i++)
+ TreeNode next = null;
+ foreach (TreeNode n in cur.Nodes)
+ if (n.Text == parts[i])
+ next = n;
+ break;
+ if (next == null)
+ cur = cur.Nodes.Add(parts[i]);
+ cur.ImageIndex = cur.SelectedImageIndex = RepositoryIcons.RES_FOLDER;
+ else
+ cur = next;
+ cur.Expand();
+ if (parts[parts.Length - 1].Trim().Length > 0)
+ TreeNode n = cur.Nodes.Add(parts[parts.Length - 1]);
+ n.Tag = ri;
+ n.ImageIndex = n.SelectedImageIndex = RepositoryIcons.GetImageIndexForResourceType(ResourceIdentifier.GetResourceType(ri.ResourcePath));
+ else
+ cur.Tag = ri;
+ private void MainGroup_Panel2_Paint(object sender, PaintEventArgs e)
+ private void ResourcDataFileList_SelectedIndexChanged(object sender, EventArgs e)
+ DeleteResourceButton.Enabled = EditResourceData.Enabled = SaveResourceData.Enabled = ResourceDataFileList.SelectedItems.Count == 1;
+ private void AddResourceData_Click(object sender, EventArgs e)
+ if (BrowseResourceDataFile.ShowDialog(this) == DialogResult.OK)
+ ResourceDataItem rdi = new ResourceDataItem(
+ System.IO.Path.GetFileName(BrowseResourceDataFile.FileName),
+ "application/octet-stream",
+ BrowseResourceDataFile.FileName,
+ "File");
+ rdi.EntryType = EntryTypeEnum.Added;
+ ((ResourceItem)ResourceTree.SelectedNode.Tag).Items.Add(rdi);
+ RefreshFileList();
+ private void RefreshFileList()
+ ResourceDataFileList.Items.Clear();
+ foreach (ResourceDataItem rdi in ((ResourceItem)ResourceTree.SelectedNode.Tag).Items)
+ if (rdi.EntryType != EntryTypeEnum.Deleted)
+ var lvi = new ListViewItem(new string[] {
+ rdi.ResourceName, rdi.ContentType, rdi.DataType.ToString(), rdi.Filename
+ ResourceDataFileList.Items.Add(lvi).Tag = rdi;
+ private void ResourceTree_AfterSelect(object sender, TreeViewEventArgs e)
+ DeleteResourceButton.Enabled = MainGroup.Panel2.Enabled = (ResourceTree.SelectedNode != null && ResourceTree.SelectedNode.Tag as ResourceItem != null);
+ if (MainGroup.Panel2.Enabled)
+ HeaderFilepath.Text = ((ResourceItem)ResourceTree.SelectedNode.Tag).Headerpath;
+ ContentFilePath.Text = ((ResourceItem)ResourceTree.SelectedNode.Tag).Contentpath;
+ private void DeleteResourceData_Click(object sender, EventArgs e)
+ if (ResourceDataFileList.SelectedItems.Count != 1 || ResourceDataFileList.SelectedItems[0].Tag as ResourceDataItem == null)
+ return;
+ (ResourceDataFileList.SelectedItems[0].Tag as ResourceDataItem).EntryType = EntryTypeEnum.Deleted;
+ private void SaveResourceData_Click(object sender, EventArgs e)
+ try
+ return;
+ SaveResourceDataFile.FileName = System.IO.Path.GetFileName((ResourceDataFileList.SelectedItems[0].Tag as ResourceDataItem).Filename);
+ if (SaveResourceDataFile.ShowDialog(this) != DialogResult.OK)
+ return;
+ if ((ResourceDataFileList.SelectedItems[0].Tag as ResourceDataItem).Filename == SaveResourceDataFile.FileName)
+ return;
+ if ((ResourceDataFileList.SelectedItems[0].Tag as ResourceDataItem).EntryType == EntryTypeEnum.Regular)
+ using(ICSharpCode.SharpZipLib.Zip.ZipFile zipfile = new ICSharpCode.SharpZipLib.Zip.ZipFile(m_filename))
+ int index = FindZipEntry(zipfile, (ResourceDataFileList.SelectedItems[0].Tag as ResourceDataItem).Filename);
+ if (index >= 0)
+ using (System.IO.FileStream fs = new System.IO.FileStream(SaveResourceDataFile.FileName, System.IO.FileMode.Create, System.IO.FileAccess.Write, System.IO.FileShare.None))
+ Utility.CopyStream(zipfile.GetInputStream(index), fs);
+ else if ((ResourceDataFileList.SelectedItems[0].Tag as ResourceDataItem).EntryType == EntryTypeEnum.Added)
+ System.IO.File.Copy((ResourceDataFileList.SelectedItems[0].Tag as ResourceDataItem).Filename, SaveResourceDataFile.FileName, true);
+ MessageBox.Show(this, string.Format(Properties.Resources.FileCopyError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+ private void EditResourceData_Click(object sender, EventArgs e)
+ return;
+ var dlg = new EditResourceDataEntryDialog();
+ dlg.ResourceName = (ResourceDataFileList.SelectedItems[0].Tag as ResourceDataItem).ResourceName;
+ dlg.ContentType = (ResourceDataFileList.SelectedItems[0].Tag as ResourceDataItem).ContentType;
+ dlg.DataType = (ResourceDataFileList.SelectedItems[0].Tag as ResourceDataItem).DataType;
+ dlg.Filename = (ResourceDataFileList.SelectedItems[0].Tag as ResourceDataItem).Filename;
+ if (dlg.ShowDialog(this) == DialogResult.OK)
+ (ResourceDataFileList.SelectedItems[0].Tag as ResourceDataItem).ResourceName = dlg.ResourceName;
+ (ResourceDataFileList.SelectedItems[0].Tag as ResourceDataItem).ContentType = dlg.ContentType;
+ (ResourceDataFileList.SelectedItems[0].Tag as ResourceDataItem).DataType = dlg.DataType;
+ private void ResourceDataFileList_DoubleClick(object sender, EventArgs e)
+ EditResourceData_Click(sender, e);
+ private void ResourceTree_DragDrop(object sender, DragEventArgs e)
+ TreeNode x = e.Data.GetData(typeof(TreeNode)) as TreeNode;
+ if (x == null || x.Tag == null)
+ return;
+ TreeNode n = ResourceTree.GetNodeAt(ResourceTree.PointToClient(new Point(e.X, e.Y)));
+ if (n != null && n.Tag as ResourceItem != null && (n.Tag as ResourceItem).IsFolder)
+ //Can't drag onto its' own child
+ TreeNode t = n;
+ while (t.Parent != null)
+ if (t == x)
+ return;
+ else
+ t = t.Parent;
+ x.Remove();
+ n.Nodes.Add(x);
+ else
+ return;
+ private void ResourceTree_DragOver(object sender, DragEventArgs e)
+ e.Effect = DragDropEffects.None;
+ return;
+ TreeNode t = n;
+ if (t == x)
+ return;
+ else
+ t = t.Parent;
+ e.Effect = DragDropEffects.Move;
+ else
+ private void ResourceTree_ItemDrag(object sender, ItemDragEventArgs e)
+ ResourceTree.DoDragDrop(e.Item, DragDropEffects.Move);
+ private void AddFolderButton_Click(object sender, EventArgs e)
+ TreeNode n = new TreeNode(Properties.Resources.NewFolder, RepositoryIcons.RES_FOLDER, RepositoryIcons.RES_FOLDER);
+ n.Tag = new ResourceItem("", "", "");
+ (n.Tag as ResourceItem).EntryType = EntryTypeEnum.Added;
+ (n.Tag as ResourceItem).IsFolder = true;
+ if (ResourceTree.SelectedNode == null || ResourceTree.SelectedNode.Parent == null)
+ ResourceTree.Nodes[0].Nodes.Add(n);
+ else if (ResourceTree.SelectedNode.Tag as ResourceItem != null)
+ if ((ResourceTree.SelectedNode.Tag as ResourceItem).IsFolder)
+ ResourceTree.SelectedNode.Nodes.Add(n);
+ else if (ResourceTree.SelectedNode.Parent == null)
+ else
+ ResourceTree.SelectedNode.Parent.Nodes.Add(n);
+ n.EnsureVisible();
+ ResourceTree.SelectedNode = n;
+ ResourceTree.Focus();
+ private void DeleteResourceButton_Click(object sender, EventArgs e)
+ if (ResourceTree.SelectedNode == null || ResourceTree.SelectedNode.Tag as ResourceItem == null)
+ return;
+ if (MessageBox.Show(this, Properties.Resources.DeleteConfirmation, Application.ProductName, MessageBoxButtons.YesNoCancel, MessageBoxIcon.Question) != DialogResult.Yes)
+ return;
+ TreeNode root = ResourceTree.SelectedNode;
+ Queue<TreeNode> lst = new Queue<TreeNode>();
+ lst.Enqueue(root);
+ while (lst.Count > 0)
+ TreeNode n = lst.Dequeue();
+ foreach (TreeNode tn in n.Nodes)
+ lst.Enqueue(tn);
+ if (n.Tag as ResourceItem != null)
+ if ((n.Tag as ResourceItem).EntryType == EntryTypeEnum.Regular)
+ for (int i = 0; i < (n.Tag as ResourceItem).Items.Count; i++)
+ if ((n.Tag as ResourceItem).Items[i].EntryType == EntryTypeEnum.Added)
+ (n.Tag as ResourceItem).Items.RemoveAt(i);
+ i--;
+ (n.Tag as ResourceItem).EntryType = EntryTypeEnum.Deleted;
+ root.Remove();
+ private void AddResourceButton_Click(object sender, EventArgs e)
+ var dlg = new AddResourceEntryDialog();
+ int imageindex = RepositoryIcons.GetImageIndexForResourceType((ResourceTypes)Enum.Parse(typeof(ResourceTypes), Path.GetExtension(dlg.ResourceName).Replace(".", "")));
+ TreeNode n = new TreeNode(dlg.ResourceName, imageindex, imageindex);
+ ResourceItem i = new ResourceItem("", dlg.HeaderFilepath, dlg.ContentFilepath);
+ i.EntryType = EntryTypeEnum.Added;
+ n.Tag = i;
+ else
+ SavePackageDialog.FileName = m_filename;
+ if (SavePackageDialog.ShowDialog(this) != DialogResult.OK)
+ return;
+ //Preparation: Update all resources with the correct path, and build a list with them
+ List<ResourceItem> items = new List<ResourceItem>();
+ try
+ ResourceTree.PathSeparator = "/";
+ ResourceTree.Nodes[0].Text = "Library:/";
+ Queue<TreeNode> nl = new Queue<TreeNode>();
+ foreach (TreeNode n in ResourceTree.Nodes[0].Nodes)
+ nl.Enqueue(n);
+ while (nl.Count > 0)
+ TreeNode n = nl.Dequeue();
+ nl.Enqueue(tn);
+ if (n.Tag as ResourceItem != null && (n.Tag as ResourceItem).EntryType != EntryTypeEnum.Deleted)
+ ResourceItem ri = new ResourceItem(n.Tag as ResourceItem);
+ ri.ResourcePath = n.FullPath + (ri.IsFolder ? "/" : "");
+ if (string.IsNullOrEmpty(ri.OriginalResourcePath))
+ ri.OriginalResourcePath = ri.ResourcePath;
+ items.Add(ri);
+ finally
+ ResourceTree.Nodes[0].Text = "Library://";
+ try
+ if (PackageProgress.RebuildPackage(this, _conn, m_filename, items, SavePackageDialog.FileName, InsertDeleteCommands.Checked) != DialogResult.OK)
+ return;
+ MessageBox.Show(this, string.Format(Properties.Resources.PackageBuildError, msg), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+ return;
+ finally
+ this.Close();
+ private int FindZipEntry(ICSharpCode.SharpZipLib.Zip.ZipFile file, string path)
+ string p = path.Replace('\\', '/');
+ foreach (ICSharpCode.SharpZipLib.Zip.ZipEntry ze in file)
+ if (ze.Name.Replace('\\', '/').Equals(p))
+ return (int)ze.ZipFileIndex;
+ return -1;
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Editors/Packaging/PackageEditorDialog.designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Packaging/PackageEditorDialog.designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Packaging/PackageEditorDialog.designer.cs 2011-11-08 13:43:56 UTC (rev 6204)
@@ -0,0 +1,380 @@
+ partial class PackageEditorDialog
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(PackageEditorDialog));
+ this.MainGroup = new System.Windows.Forms.SplitContainer();
+ this.ResourceTree = new System.Windows.Forms.TreeView();
+ this.panel1 = new System.Windows.Forms.Panel();
+ this.InsertDeleteCommands = new System.Windows.Forms.CheckBox();
+ this.toolStrip1 = new System.Windows.Forms.ToolStrip();
+ this.DeleteResourceButton = new System.Windows.Forms.ToolStripButton();
+ this.panel3 = new System.Windows.Forms.Panel();
+ this.ResourceDataFileList = new System.Windows.Forms.ListView();
+ this.columnHeader1 = new System.Windows.Forms.ColumnHeader();
+ this.columnHeader2 = new System.Windows.Forms.ColumnHeader();
+ this.columnHeader3 = new System.Windows.Forms.ColumnHeader();
+ this.columnHeader5 = new System.Windows.Forms.ColumnHeader();
+ this.toolStrip2 = new System.Windows.Forms.ToolStrip();
+ this.AddResourceData = new System.Windows.Forms.ToolStripButton();
+ this.DeleteResourceData = new System.Windows.Forms.ToolStripButton();
+ this.EditResourceData = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator1 = new System.Windows.Forms.ToolStripSeparator();
+ this.SaveResourceData = new System.Windows.Forms.ToolStripButton();
+ this.ContentFilePath = new System.Windows.Forms.TextBox();
+ this.HeaderFilepath = new System.Windows.Forms.TextBox();
+ this.ButtonPanel = new System.Windows.Forms.Panel();
+ this.panel2 = new System.Windows.Forms.Panel();
+ this.BrowseResourceDataFile = new System.Windows.Forms.OpenFileDialog();
+ this.SaveResourceDataFile = new System.Windows.Forms.SaveFileDialog();
+ this.SavePackageDialog = new System.Windows.Forms.SaveFileDialog();
+ this.AddResourceButton = new System.Windows.Forms.ToolStripButton();
+ this.AddFolderButton = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator2 = new System.Windows.Forms.ToolStripSeparator();
+ this.MainGroup.Panel1.SuspendLayout();
+ this.MainGroup.Panel2.SuspendLayout();
+ this.MainGroup.SuspendLayout();
+ this.panel1.SuspendLayout();
+ this.toolStrip1.SuspendLayout();
+ this.panel3.SuspendLayout();
+ this.toolStrip2.SuspendLayout();
+ this.ButtonPanel.SuspendLayout();
+ this.panel2.SuspendLayout();
+ // MainGroup
+ resources.ApplyResources(this.MainGroup, "MainGroup");
+ this.MainGroup.FixedPanel = System.Windows.Forms.FixedPanel.Panel1;
+ this.MainGroup.Name = "MainGroup";
+ // MainGroup.Panel1
+ this.MainGroup.Panel1.Controls.Add(this.ResourceTree);
+ this.MainGroup.Panel1.Controls.Add(this.panel1);
+ this.MainGroup.Panel1.Controls.Add(this.toolStrip1);
+ // MainGroup.Panel2
+ this.MainGroup.Panel2.Controls.Add(this.panel3);
+ this.MainGroup.Panel2.Controls.Add(this.label3);
+ this.MainGroup.Panel2.Controls.Add(this.ContentFilePath);
+ this.MainGroup.Panel2.Controls.Add(this.HeaderFilepath);
+ this.MainGroup.Panel2.Controls.Add(this.label2);
+ this.MainGroup.Panel2.Controls.Add(this.label1);
+ resources.ApplyResources(this.MainGroup.Panel2, "MainGroup.Panel2");
+ this.MainGroup.Panel2.Paint += new System.Windows.Forms.PaintEventHandler(this.MainGroup_Panel2_Paint);
+ // ResourceTree
+ this.ResourceTree.AllowDrop = true;
+ resources.ApplyResources(this.ResourceTree, "ResourceTree");
+ this.ResourceTree.LabelEdit = true;
+ this.ResourceTree.Name = "ResourceTree";
+ this.ResourceTree.DragDrop += new System.Windows.Forms.DragEventHandler(this.ResourceTree_DragDrop);
+ this.ResourceTree.AfterSelect += new System.Windows.Forms.TreeViewEventHandler(this.ResourceTree_AfterSelect);
+ this.ResourceTree.ItemDrag += new System.Windows.Forms.ItemDragEventHandler(this.ResourceTree_ItemDrag);
+ this.ResourceTree.DragOver += new System.Windows.Forms.DragEventHandler(this.ResourceTree_DragOver);
+ // panel1
+ this.panel1.Controls.Add(this.InsertDeleteCommands);
+ resources.ApplyResources(this.panel1, "panel1");
+ this.panel1.Name = "panel1";
+ // InsertDeleteCommands
+ resources.ApplyResources(this.InsertDeleteCommands, "InsertDeleteCommands");
+ this.InsertDeleteCommands.Name = "InsertDeleteCommands";
+ this.InsertDeleteCommands.UseVisualStyleBackColor = true;
+ // toolStrip1
+ this.toolStrip1.GripStyle = System.Windows.Forms.ToolStripGripStyle.Hidden;
+ this.toolStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.AddFolderButton,
+ this.AddResourceButton,
+ this.toolStripSeparator2,
+ this.DeleteResourceButton});
+ resources.ApplyResources(this.toolStrip1, "toolStrip1");
+ this.toolStrip1.Name = "toolStrip1";
+ this.toolStrip1.RenderMode = System.Windows.Forms.ToolStripRenderMode.Professional;
+ // DeleteResourceButton
+ resources.ApplyResources(this.DeleteResourceButton, "DeleteResourceButton");
+ this.DeleteResourceButton.Image = global::Maestro.Editors.Properties.Resources.cross_script;
+ this.DeleteResourceButton.Name = "DeleteResourceButton";
+ this.DeleteResourceButton.Click += new System.EventHandler(this.DeleteResourceButton_Click);
+ // panel3
+ resources.ApplyResources(this.panel3, "panel3");
+ this.panel3.Controls.Add(this.ResourceDataFileList);
+ this.panel3.Controls.Add(this.toolStrip2);
+ this.panel3.Name = "panel3";
+ // ResourceDataFileList
+ this.ResourceDataFileList.Columns.AddRange(new System.Windows.Forms.ColumnHeader[] {
+ this.columnHeader1,
+ this.columnHeader2,
+ this.columnHeader3,
+ this.columnHeader5});
+ resources.ApplyResources(this.ResourceDataFileList, "ResourceDataFileList");
+ this.ResourceDataFileList.FullRowSelect = true;
+ this.ResourceDataFileList.MultiSelect = false;
+ this.ResourceDataFileList.Name = "ResourceDataFileList";
+ this.ResourceDataFileList.UseCompatibleStateImageBehavior = false;
+ this.ResourceDataFileList.View = System.Windows.Forms.View.Details;
+ this.ResourceDataFileList.SelectedIndexChanged += new System.EventHandler(this.ResourcDataFileList_SelectedIndexChanged);
+ this.ResourceDataFileList.DoubleClick += new System.EventHandler(this.ResourceDataFileList_DoubleClick);
+ // columnHeader1
+ resources.ApplyResources(this.columnHeader1, "columnHeader1");
+ // columnHeader2
+ resources.ApplyResources(this.columnHeader2, "columnHeader2");
+ // columnHeader3
+ resources.ApplyResources(this.columnHeader3, "columnHeader3");
+ // columnHeader5
+ resources.ApplyResources(this.columnHeader5, "columnHeader5");
+ // toolStrip2
+ this.toolStrip2.GripStyle = System.Windows.Forms.ToolStripGripStyle.Hidden;
+ this.toolStrip2.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.AddResourceData,
+ this.DeleteResourceData,
+ this.EditResourceData,
+ this.toolStripSeparator1,
+ this.SaveResourceData});
+ resources.ApplyResources(this.toolStrip2, "toolStrip2");
+ this.toolStrip2.Name = "toolStrip2";
+ this.toolStrip2.RenderMode = System.Windows.Forms.ToolStripRenderMode.Professional;
+ // AddResourceData
+ this.AddResourceData.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.AddResourceData.Image = global::Maestro.Editors.Properties.Resources.document__plus;
+ resources.ApplyResources(this.AddResourceData, "AddResourceData");
+ this.AddResourceData.Name = "AddResourceData";
+ this.AddResourceData.Click += new System.EventHandler(this.AddResourceData_Click);
+ // DeleteResourceData
+ this.DeleteResourceData.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ resources.ApplyResources(this.DeleteResourceData, "DeleteResourceData");
+ this.DeleteResourceData.Image = global::Maestro.Editors.Properties.Resources.document__minus;
+ this.DeleteResourceData.Name = "DeleteResourceData";
+ this.DeleteResourceData.Click += new System.EventHandler(this.DeleteResourceData_Click);
+ this.EditResourceData.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ resources.ApplyResources(this.EditResourceData, "EditResourceData");
+ this.EditResourceData.Image = global::Maestro.Editors.Properties.Resources.document__pencil;
+ this.EditResourceData.Name = "EditResourceData";
+ this.EditResourceData.Click += new System.EventHandler(this.EditResourceData_Click);
+ // toolStripSeparator1
+ this.toolStripSeparator1.Name = "toolStripSeparator1";
+ resources.ApplyResources(this.toolStripSeparator1, "toolStripSeparator1");
+ // SaveResourceData
+ this.SaveResourceData.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ resources.ApplyResources(this.SaveResourceData, "SaveResourceData");
+ this.SaveResourceData.Image = global::Maestro.Editors.Properties.Resources.disk;
+ this.SaveResourceData.Name = "SaveResourceData";
+ this.SaveResourceData.Click += new System.EventHandler(this.SaveResourceData_Click);
+ // label3
+ // ContentFilePath
+ resources.ApplyResources(this.ContentFilePath, "ContentFilePath");
+ this.ContentFilePath.Name = "ContentFilePath";
+ this.ContentFilePath.ReadOnly = true;
+ // HeaderFilepath
+ resources.ApplyResources(this.HeaderFilepath, "HeaderFilepath");
+ this.HeaderFilepath.Name = "HeaderFilepath";
+ this.HeaderFilepath.ReadOnly = true;
+ // label2
+ // label1
+ // ButtonPanel
+ this.ButtonPanel.Controls.Add(this.CancelBtn);
+ this.ButtonPanel.Controls.Add(this.OKBtn);
+ resources.ApplyResources(this.ButtonPanel, "ButtonPanel");
+ this.ButtonPanel.Name = "ButtonPanel";
+ // CancelBtn
+ // OKBtn
+ // panel2
+ this.panel2.Controls.Add(this.MainGroup);
+ resources.ApplyResources(this.panel2, "panel2");
+ this.panel2.Name = "panel2";
+ // BrowseResourceDataFile
+ resources.ApplyResources(this.BrowseResourceDataFile, "BrowseResourceDataFile");
+ // SaveResourceDataFile
+ resources.ApplyResources(this.SaveResourceDataFile, "SaveResourceDataFile");
+ // SavePackageDialog
+ this.SavePackageDialog.DefaultExt = "mgp";
+ resources.ApplyResources(this.SavePackageDialog, "SavePackageDialog");
+ // AddResourceButton
+ this.AddResourceButton.Image = global::Maestro.Editors.Properties.Resources.document__plus;
+ resources.ApplyResources(this.AddResourceButton, "AddResourceButton");
+ this.AddResourceButton.Name = "AddResourceButton";
+ this.AddResourceButton.Click += new System.EventHandler(this.AddResourceButton_Click);
+ // AddFolderButton
+ this.AddFolderButton.Image = global::Maestro.Editors.Properties.Resources.folder__plus;
+ resources.ApplyResources(this.AddFolderButton, "AddFolderButton");
+ this.AddFolderButton.Name = "AddFolderButton";
+ this.AddFolderButton.Click += new System.EventHandler(this.AddFolderButton_Click);
+ // toolStripSeparator2
+ this.toolStripSeparator2.Name = "toolStripSeparator2";
+ resources.ApplyResources(this.toolStripSeparator2, "toolStripSeparator2");
+ // PackageEditorDialog
+ this.Controls.Add(this.panel2);
+ this.Controls.Add(this.ButtonPanel);
+ this.Name = "PackageEditorDialog";
+ this.Load += new System.EventHandler(this.PackageEditor_Load);
+ this.MainGroup.Panel1.ResumeLayout(false);
+ this.MainGroup.Panel1.PerformLayout();
+ this.MainGroup.Panel2.ResumeLayout(false);
+ this.MainGroup.Panel2.PerformLayout();
+ this.MainGroup.ResumeLayout(false);
+ this.panel1.ResumeLayout(false);
+ this.panel1.PerformLayout();
+ this.toolStrip1.ResumeLayout(false);
+ this.toolStrip1.PerformLayout();
+ this.panel3.ResumeLayout(false);
+ this.panel3.PerformLayout();
+ this.toolStrip2.ResumeLayout(false);
+ this.toolStrip2.PerformLayout();
+ this.ButtonPanel.ResumeLayout(false);
+ this.panel2.ResumeLayout(false);
+ #endregion
+ private System.Windows.Forms.Panel ButtonPanel;
+ private System.Windows.Forms.Panel panel2;
+ private System.Windows.Forms.SplitContainer MainGroup;
+ private System.Windows.Forms.TreeView ResourceTree;
+ private System.Windows.Forms.ToolStrip toolStrip1;
+ private System.Windows.Forms.ToolStripButton DeleteResourceButton;
+ private System.Windows.Forms.TextBox ContentFilePath;
+ private System.Windows.Forms.TextBox HeaderFilepath;
+ private System.Windows.Forms.Panel panel3;
+ private System.Windows.Forms.ToolStrip toolStrip2;
+ private System.Windows.Forms.ToolStripButton AddResourceData;
+ private System.Windows.Forms.ToolStripButton EditResourceData;
+ private System.Windows.Forms.ToolStripButton DeleteResourceData;
+ private System.Windows.Forms.ToolStripSeparator toolStripSeparator1;
+ private System.Windows.Forms.ToolStripButton SaveResourceData;
+ private System.Windows.Forms.ListView ResourceDataFileList;
+ private System.Windows.Forms.ColumnHeader columnHeader1;
+ private System.Windows.Forms.ColumnHeader columnHeader2;
+ private System.Windows.Forms.ColumnHeader columnHeader3;
+ private System.Windows.Forms.ColumnHeader columnHeader5;
+ private System.Windows.Forms.OpenFileDialog BrowseResourceDataFile;
+ private System.Windows.Forms.SaveFileDialog SaveResourceDataFile;
+ private System.Windows.Forms.SaveFileDialog SavePackageDialog;
+ private System.Windows.Forms.Panel panel1;
+ private System.Windows.Forms.CheckBox InsertDeleteCommands;
+ private System.Windows.Forms.ToolStripButton AddFolderButton;
+ private System.Windows.Forms.ToolStripButton AddResourceButton;
+ private System.Windows.Forms.ToolStripSeparator toolStripSeparator2;
Added: trunk/Tools/Maestro/Maestro.Editors/Packaging/PackageEditorDialog.resx
--- trunk/Tools/Maestro/Maestro.Editors/Packaging/PackageEditorDialog.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Packaging/PackageEditorDialog.resx 2011-11-08 13:43:56 UTC (rev 6204)
@@ -0,0 +1,1340 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ <data name="MainGroup.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ <value>Fill</value>
+ </data>
+ <data name="MainGroup.Location" type="System.Drawing.Point, System.Drawing">
+ <value>0, 0</value>
+ </data>
+ <data name="ResourceTree.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ </data>
+ <data name="ResourceTree.Location" type="System.Drawing.Point, System.Drawing">
+ <value>0, 25</value>
+ </data>
+ <data name="ResourceTree.Size" type="System.Drawing.Size, System.Drawing">
+ <value>276, 330</value>
+ </data>
+ <data name="ResourceTree.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name=">>ResourceTree.Name" xml:space="preserve">
+ <value>ResourceTree</value>
+ </data>
+ <data name=">>ResourceTree.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TreeView, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>ResourceTree.Parent" xml:space="preserve">
+ <value>MainGroup.Panel1</value>
+ </data>
+ <data name=">>ResourceTree.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="InsertDeleteCommands.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="InsertDeleteCommands.Location" type="System.Drawing.Point, System.Drawing">
+ <value>8, 8</value>
+ </data>
+ <data name="InsertDeleteCommands.Size" type="System.Drawing.Size, System.Drawing">
+ <value>160, 17</value>
+ </data>
+ <data name="InsertDeleteCommands.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="InsertDeleteCommands.Text" xml:space="preserve">
+ <value>Delete targets before restore</value>
+ </data>
+ <data name=">>InsertDeleteCommands.Name" xml:space="preserve">
+ <value>InsertDeleteCommands</value>
+ </data>
+ <data name=">>InsertDeleteCommands.Type" xml:space="preserve">
+ </data>
+ <data name=">>InsertDeleteCommands.Parent" xml:space="preserve">
+ <value>panel1</value>
+ </data>
+ <data name=">>InsertDeleteCommands.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="panel1.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ </data>
+ <data name="panel1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>0, 355</value>
+ </data>
+ <data name="panel1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>276, 32</value>
+ </data>
+ <data name="panel1.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name=">>panel1.Name" xml:space="preserve">
+ </data>
+ <data name=">>panel1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>panel1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>panel1.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ </metadata>
+ <data name="AddFolderButton.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ <value>Magenta</value>
+ </data>
+ <data name="AddFolderButton.Size" type="System.Drawing.Size, System.Drawing">
+ <value>87, 22</value>
+ </data>
+ <data name="AddFolderButton.Text" xml:space="preserve">
+ <value>New Folder</value>
+ </data>
+ <data name="AddFolderButton.ToolTipText" xml:space="preserve">
+ <value>Add a new folder</value>
+ </data>
+ <data name="AddResourceButton.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ </data>
+ <data name="AddResourceButton.Size" type="System.Drawing.Size, System.Drawing">
+ <value>102, 22</value>
+ </data>
+ <data name="AddResourceButton.Text" xml:space="preserve">
+ <value>New Resource</value>
+ </data>
+ <data name="AddResourceButton.ToolTipText" xml:space="preserve">
+ <value>Add a new resource to the package</value>
+ </data>
+ <data name="toolStripSeparator2.Size" type="System.Drawing.Size, System.Drawing">
+ <value>6, 25</value>
+ </data>
+ <data name="DeleteResourceButton.Enabled" type="System.Boolean, mscorlib">
+ </data>
+ <data name="DeleteResourceButton.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ </data>
+ <data name="DeleteResourceButton.Size" type="System.Drawing.Size, System.Drawing">
+ <value>60, 22</value>
+ </data>
+ <data name="DeleteResourceButton.Text" xml:space="preserve">
+ <value>Delete</value>
+ </data>
+ <data name="DeleteResourceButton.ToolTipText" xml:space="preserve">
+ <value>Delete the selected item</value>
+ </data>
+ <data name="toolStrip1.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="toolStrip1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>276, 25</value>
+ </data>
+ <data name="toolStrip1.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name=">>toolStrip1.Name" xml:space="preserve">
+ <value>toolStrip1</value>
+ </data>
+ <data name=">>toolStrip1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStrip, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>toolStrip1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>toolStrip1.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name=">>MainGroup.Panel1.Name" xml:space="preserve">
+ </data>
+ <data name=">>MainGroup.Panel1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.SplitterPanel, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>MainGroup.Panel1.Parent" xml:space="preserve">
+ <value>MainGroup</value>
+ </data>
+ <data name=">>MainGroup.Panel1.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="panel3.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Bottom, Left, Right</value>
+ </data>
+ <data name="columnHeader1.Text" xml:space="preserve">
+ <value>Filename</value>
+ </data>
+ <data name="columnHeader1.Width" type="System.Int32, mscorlib">
+ <value>100</value>
+ </data>
+ <data name="columnHeader2.Text" xml:space="preserve">
+ <value>Content type</value>
+ </data>
+ <data name="columnHeader2.Width" type="System.Int32, mscorlib">
+ <value>80</value>
+ </data>
+ <data name="columnHeader3.Text" xml:space="preserve">
+ <value>Data type</value>
+ </data>
+ <data name="columnHeader5.Text" xml:space="preserve">
+ </data>
+ <data name="ResourceDataFileList.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ </data>
+ <data name="ResourceDataFileList.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="ResourceDataFileList.Size" type="System.Drawing.Size, System.Drawing">
+ <value>314, 266</value>
+ </data>
+ <data name="ResourceDataFileList.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name=">>ResourceDataFileList.Name" xml:space="preserve">
+ <value>ResourceDataFileList</value>
+ </data>
+ <data name=">>ResourceDataFileList.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ListView, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>ResourceDataFileList.Parent" xml:space="preserve">
+ <value>panel3</value>
+ </data>
+ <data name=">>ResourceDataFileList.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <metadata name="toolStrip2.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ </metadata>
+ <data name="AddResourceData.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ </data>
+ <data name="AddResourceData.Size" type="System.Drawing.Size, System.Drawing">
+ <value>23, 22</value>
+ </data>
+ <data name="AddResourceData.ToolTipText" xml:space="preserve">
+ <value>Add a file</value>
+ </data>
+ <data name="DeleteResourceData.Enabled" type="System.Boolean, mscorlib">
+ </data>
+ <data name="DeleteResourceData.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ </data>
+ <data name="DeleteResourceData.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="DeleteResourceData.ToolTipText" xml:space="preserve">
+ <value>Delete the selected file</value>
+ </data>
+ <data name="EditResourceData.Enabled" type="System.Boolean, mscorlib">
+ </data>
+ <data name="EditResourceData.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ </data>
+ <data name="EditResourceData.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="EditResourceData.ToolTipText" xml:space="preserve">
+ <value>Edit the selected files metadata</value>
+ </data>
+ <data name="toolStripSeparator1.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="SaveResourceData.Enabled" type="System.Boolean, mscorlib">
+ </data>
+ <data name="SaveResourceData.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ </data>
+ <data name="SaveResourceData.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="SaveResourceData.ToolTipText" xml:space="preserve">
+ <value>Save the selected file</value>
+ </data>
+ <data name="toolStrip2.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="toolStrip2.Size" type="System.Drawing.Size, System.Drawing">
+ <value>314, 25</value>
+ </data>
+ <data name="toolStrip2.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="toolStrip2.Text" xml:space="preserve">
+ <value>toolStrip2</value>
+ </data>
+ <data name=">>toolStrip2.Name" xml:space="preserve">
+ </data>
+ <data name=">>toolStrip2.Type" xml:space="preserve">
+ </data>
+ <data name=">>toolStrip2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>toolStrip2.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="panel3.Location" type="System.Drawing.Point, System.Drawing">
+ <value>16, 88</value>
+ </data>
+ <data name="panel3.Size" type="System.Drawing.Size, System.Drawing">
+ <value>314, 291</value>
+ </data>
+ <data name="panel3.TabIndex" type="System.Int32, mscorlib">
+ <value>5</value>
+ </data>
+ <data name=">>panel3.Name" xml:space="preserve">
+ </data>
+ <data name=">>panel3.Type" xml:space="preserve">
+ </data>
+ <data name=">>panel3.Parent" xml:space="preserve">
+ <value>MainGroup.Panel2</value>
+ </data>
+ <data name=">>panel3.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <value>True</value>
+ </data>
+ <value>16, 64</value>
+ </data>
+ <value>51, 13</value>
+ </data>
+ <value>4</value>
+ </data>
+ <value>Data files</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>1</value>
+ </data>
+ <data name="ContentFilePath.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="ContentFilePath.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="ContentFilePath.Size" type="System.Drawing.Size, System.Drawing">
+ <value>250, 20</value>
+ </data>
+ <data name="ContentFilePath.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name=">>ContentFilePath.Name" xml:space="preserve">
+ <value>ContentFilePath</value>
+ </data>
+ <data name=">>ContentFilePath.Type" xml:space="preserve">
+ </data>
+ <data name=">>ContentFilePath.Parent" xml:space="preserve">
+ </data>
+ <data name=">>ContentFilePath.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="HeaderFilepath.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="HeaderFilepath.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="HeaderFilepath.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="HeaderFilepath.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name=">>HeaderFilepath.Name" xml:space="preserve">
+ <value>HeaderFilepath</value>
+ </data>
+ <data name=">>HeaderFilepath.Type" xml:space="preserve">
+ </data>
+ <data name=">>HeaderFilepath.Parent" xml:space="preserve">
+ </data>
+ <data name=">>HeaderFilepath.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ </data>
+ <value>16, 32</value>
+ </data>
+ </data>
+ <value>1</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>4</value>
+ </data>
+ </data>
+ <value>16, 8</value>
+ </data>
+ <value>58, 13</value>
+ </data>
+ <value>0</value>
+ </data>
+ <value>Header file</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>5</value>
+ </data>
+ <data name="MainGroup.Panel2.Enabled" type="System.Boolean, mscorlib">
+ <value>False</value>
+ </data>
+ <data name=">>MainGroup.Panel2.Name" xml:space="preserve">
+ </data>
+ <data name=">>MainGroup.Panel2.Type" xml:space="preserve">
+ </data>
+ <data name=">>MainGroup.Panel2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>MainGroup.Panel2.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="MainGroup.Size" type="System.Drawing.Size, System.Drawing">
+ <value>624, 387</value>
+ </data>
+ <data name="MainGroup.SplitterDistance" type="System.Int32, mscorlib">
+ <value>276</value>
+ </data>
+ <data name="MainGroup.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name=">>MainGroup.Name" xml:space="preserve">
+ </data>
+ <data name=">>MainGroup.Type" xml:space="preserve">
+ <value>System.Windows.Forms.SplitContainer, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>MainGroup.Parent" xml:space="preserve">
+ <value>panel2</value>
+ </data>
+ <data name=">>MainGroup.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ </data>
+ <value>319, 16</value>
+ </data>
+ </data>
+ <value>1</value>
+ </data>
+ </data>
+ </data>
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <value>ButtonPanel</value>
+ </data>
+ <value>0</value>
+ </data>
+ </data>
+ </data>
+ <value>231, 16</value>
+ </data>
+ </data>
+ <value>0</value>
+ </data>
+ <value>OK</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>1</value>
+ </data>
+ <data name="ButtonPanel.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ </data>
+ <data name="ButtonPanel.Location" type="System.Drawing.Point, System.Drawing">
+ <value>0, 387</value>
+ </data>
+ <data name="ButtonPanel.Size" type="System.Drawing.Size, System.Drawing">
+ <value>624, 55</value>
+ </data>
+ <data name="ButtonPanel.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name=">>ButtonPanel.Name" xml:space="preserve">
+ </data>
+ <data name=">>ButtonPanel.Type" xml:space="preserve">
+ </data>
+ <data name=">>ButtonPanel.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>ButtonPanel.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="panel2.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ </data>
+ <data name="panel2.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="panel2.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="panel2.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name=">>panel2.Name" xml:space="preserve">
+ </data>
+ <data name=">>panel2.Type" xml:space="preserve">
+ </data>
+ <data name=">>panel2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>panel2.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <metadata name="BrowseResourceDataFile.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>227, 17</value>
+ </metadata>
+ <data name="BrowseResourceDataFile.Filter" xml:space="preserve">
+ </data>
+ <data name="BrowseResourceDataFile.Title" xml:space="preserve">
+ <value>Select a file to add</value>
+ </data>
+ <metadata name="SaveResourceDataFile.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>411, 17</value>
+ </metadata>
+ <data name="SaveResourceDataFile.Filter" xml:space="preserve">
+ </data>
+ <data name="SaveResourceDataFile.Title" xml:space="preserve">
+ <value>Select where to save the file</value>
+ </data>
+ <metadata name="SavePackageDialog.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>581, 17</value>
+ </metadata>
+ <data name="SavePackageDialog.Filter" xml:space="preserve">
+ <value>MapGuide Packages (*.mgp)|*.mgp|Zip files (*.zip)|*.zip|All files (*.*)|*.*</value>
+ </data>
+ <data name="SavePackageDialog.Title" xml:space="preserve">
+ <value>Select where to store the file</value>
+ </data>
+ </metadata>
+ </data>
+ <value>624, 442</value>
+ </data>
+ <data name="$this.Icon" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ AAABAAwAMDAQAAEABABoBgAAxgAAACAgEAABAAQA6AIAAC4HAAAYGBAAAQAEAOgBAAAWCgAAEBAQAAEA
+ BAAoAQAA/gsAADAwAAABAAgAqA4AACYNAAAgIAAAAQAIAKgIAADOGwAAGBgAAAEACADIBgAAdiQAABAQ
+ AAABAAgAaAUAAD4rAAAwMAAAAQAgAKglAACmMAAAICAAAAEAIACoEAAATlYAABgYAAABACAAiAkAAPZm
+ AAAQEAAAAQAgAGgEAAB+cAAAKAAAADAAAABgAAAAAQAEAAAAAACABAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAIAAAIAAAACAgACAAAAAgACAAICAAACAgIAAwMDAAAAA/wAA/wAAAP//AP8AAAD/AP8A//8AAP//
+ /wAAAAAAAAAAAAAAAIeHAAAAAAAAAAAAAAAAAAAAAAAAAAd8RsTEfEdwAAAAAAAAAAAAAAAAAAAAhGxH
+ d4iIx2xMdwAAAAAAAAAAAAAAAACEx3iPiIjo+PiHxHcAAAAAAAAAAAAAAAbHd2iOjufn7oiIh8xwAAAA
+ AAAAAAAACEV4ZiZo7Oznzm7uiIfEgAAAAAAAAAAAfGiOI2Nmjo6O6Ox+zoiERwAAAAAAAAAHx4iHYnpy
+ 6Ofs7O7n5+6PxlAAAAAAAAB8aI7oanpyZ+jo6OjO7sjoh8cAAAAAAAfHiI6Ocno3pn6Ofn7ozu7IZ3yA
+ AAAAAAbPjo6I4nOnJyaO5+fu6M7uZnZAAAAAAHyIjo5+hienp6Zo5+fsjujoYmhlAAAAB0BgYERAUCBj
+ pzNo6MZCQEBAACBEcAAABAAAAAAAAAACenpmjgAAAAAAAAAAYAAAgAEBAQEhAhAANjYyhgAQEAECEBAQ
+ WAAAYzMzMzMzMzMzY6em6HMzMzMzMzMzdAAAwzMzMzMzMzMzNqZ4jhMzMzMzMzMzPAAHczkzOTOTOTOT
+ Yojo6HMzkzkzkzM5d3AMb4gzMzMzNzNqIAAABo6HJzMzM5M2dsAHz445M5M2JqemAAAABI6GejMzkzN6
+ d0AGf4gzMzMyYmJgMzMzM0jmNjMTMzM2KEAMiOgzMzk3iI8DEzkzMxaGpyMzMzN6Z8CGiI45MzM4iIYT
+ MzMzkzCGJyOTOTM3KGh8iIgzOTM4iOEzOTMzMzNIYjMzMzNqZ8eMiOczMzMX6BMzMzOTM5M2hiMzkzOG
+ aHeGj3YzM5M2djMzM5czMzMxaCEzMzfo+McMjiIzkzMyITM5MziHOTMzNmMzOTN2aEAGgmIzMzM1MzMz
+ M4iIMzMzMSOTMzMmKEAMdiczM5MwMzkzmI6Ogzk5MxMzMzNyZ8AHx6czkzMzOTMzjoiI5zMzMzM5M5N6
+ dnAIZ2MzMzOTMzMzj46OiHMzOTMzMzM2jHAAyCYzM5MzMzk2Zojo6OOTMzOTMzNidgAAdnIzkzMzkzNj
+ Jo6I6IdzMzMzkzMnxwAAhzOTMzMzMzN6Z+jo6O5zOTOTMzkzdwAAAxMzMzkzOXpyaIiOjo6HMzMzMzMz
+ EAAAAzMzOTM5MmImjo546M7sczkzOTOTcAAAAHdzMzd3hiYo6IZijo6Od3d3d4d3AAAAAAR3ZqaOiCam
+ jnpyZ+jn7u7u6IZAAAAAAAjHYnJo56Y2b2Knpifo7OzoiMdwAAAAAAB2hiemaCYmfnZ6c2Yn6OjohscA
+ AAAAAAAHyGJiKGJo6Go2Onpmjs6Ix3AAAAAAAAAAfIiGaGfo6Cenpzc26I+MfAAAAAAAAAAACGyGqI6I
+ 52pzanqmeI5HcAAAAAAAAAAAAAZ3iI/iYnOnp6ciflxwAAAAAAAAAAAAAAB8bIh2JqYmImZ4fHcAAAAA
+ AAAAAAAAAAAAhsZ4d3eHh4fGyAAAAAAAAAAAAAAAAAAAAAjGxsZsbGyAAAAAAAAAAAAAAAAAAAAAAAAA
+ CIiIgAAAAAAAAAAAAAD///w///8AAP//gAH//wAA//wAAD//AAD/8AAAD/8AAP/gAAAH/wAA/4AAAAH/
+ AAD/AAAAAP8AAP4AAAAAfwAA/AAAAAA/AAD4AAAAAB8AAPgAAAAAHwAA8AAAAAAPAADgAAAAAAcAAOAA
+ AAAABwAAwAAAAAADAADAAAAAAAMAAMAAAAAAAwAAgAAAAAABAACAAAAAAAEAAIAAAAAAAQAAgAAAAAAB
+ AACAAAAAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAAAABAACAAAAAAAEAAIAA
+ AAAAAQAAgAAAAAABAACAAAAAAAEAAMAAAAAAAwAAwAAAAAADAADAAAAAAAMAAOAAAAAABwAA4AAAAAAH
+ AADwAAAAAA8AAPgAAAAAHwAA+AAAAAAfAAD8AAAAAD8AAP4AAAAAfwAA/wAAAAD/AAD/gAAAAf8AAP/g
+ AAAH/wAA//AAAA//AAD//AAAP/8AAP//gAH//wAA///4H///AAAoAAAAIAAAAEAAAAABAAQAAAAAAAAC
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAgAAAAICAAIAAAACAAIAAgIAAAICAgADAwMAAAAD/AAD/
+ AAAA//8A/wAAAP8A/wD//wAA////AAAAAAAAAAB3dwAAAAAAAAAAAAAAAHRlyMfHRwAAAAAAAAAAAHx4
+ j46IiIx8AAAAAAAAAIR3Zo7n7u6Ih0gAAAAAAAfIhicn7n7O7OiMcAAAAAB8iOenpo5+js7uiMcAAAAI
+ yI6OJzYo5+fo7OZ2gAAABojo6Gp6dn6Ofs6GZ8AAAFBAQAQAJ6No5EAkACAHAAAAIAIQAQJ6Z2AAEAAQ
+ BAAHMzMzMzMzY2dzMzMzMzNwDDM5MzMzNyjo4zMzMzM3UAeIMzkzc3IAAHiHM5M5N2CM+DMzNiYgMzNO
+ diMzM3J4d44zMziIIzMTNeNjMzN6yH6IOTN4hjOTMzN2MzkzJnd4hzMzN3MzMzMxN2MzM4eMfIYzOTYz
+ Ezh5MzNjMzNud4hiMzMwMzN4hzMzEzEzcngGYzMzMzk3iOhzMzMzM3bAB2czkzkzN4iOgzkzE5MncAdy
+ MzMzM3JuiOczMzMzZ3AAMzM5MzNqiOjoczkzMzcAADOTMzNyd+jo7oYzM5MzAAAHcnOHYmiGZ47IaHeH
+ UAAACMcmeGam46Zn7u7ujIAAAAB+cmaKZ4ZzpyjsiMcAAAAAB3fihn6Cp6cuiIyAAAAAAACMdo6OY2N6
+ dofIAAAAAAAAAHaIYiamJnfHAAAAAAAAAAAAfIeHeHdnAAAAAAAAAAAAAAAIyMjgAAAAAAAA//w////A
+ A///AAD//AAAP/gAAB/wAAAP4AAAB+AAAAfAAAADwAAAA4AAAAGAAAABgAAAAQAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAIAAAAGAAAABgAAAAcAAAAPAAAAD4AAAB+AAAAfwAAAP+AAAH/wAAD//AAD//8AD///4
+ H/8oAAAAGAAAADAAAAABAAQAAAAAACABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAgAAAAICAAIAA
+ AACAAIAAgIAAAICAgADAwMAAAAD/AAD/AAAA//8A/wAAAP8A/wD//wAA////AAAAAAAAd8cAAAAAAAAA
+ AAd3iIiMcAAAAAAAB2Zo7O5ohnAAAAAAaIZ2fo7uyIwAAAAHh+MnbufO7oZwAAB36OdqN36OjOZ3AABA
+ QAADan5AAAAEAAcTExMwemgDMzExYAczMzMzJ44zEzMzcIeDMzY2AAGOMzM3aHjjEzdyMzNnYzEzZ8iD
+ M3hzMzMXYzM2d3jjM3czM5MzYzM4jHdjkzIzGIMzcxM2Z4ZzMxMziOczMTM3eAdjMzOTeI5zMzMycAcz
+ M5M2boiHM5M3cAgzEzNqiO7nMzMxAAB3N4dmhneOd+h3AAAGYmemhqZn7njAAAAAd24243o26IwAAAAA
+ B3iOenNqjHAAAAAAAAaGdmdncAAAAAAAAAAId36AAAAAAP/D/wD+AH8A+AAfAPAADwDgAAcAwAADAMAA
+ AwCAAAEAgAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIAAAQCAAAEAgAADAMAAAwDgAAcA8AAPAPgA
+ HwD+AH8A/4H/ACgAAAAQAAAAIAAAAAEABAAAAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAAACA
+ AAAAgIAAgAAAAIAAgACAgAAAgICAAMDAwAAAAP8AAP8AAAD//wD/AAAA/wD/AP//AAD///8AAAAAd3cA
+ AAAAAHaOjowAAAB4Z25+yIcAAI6GNujuZgAAQAAndgBAUAMzMzZ3MzMweDM3IydzM3d4M3gzM2MzJ34z
+ czNTdjOHhpMxOIMzk2cGMzN+hzMzYAMzM2joczMwAHOGdn7n5wAAhmZ2o2h4AAAAeONnZwAAAAAAd3gA
+ AAD8PwAA8A8AAMADAADAAwAAgAEAAIABAAAAAAAAAAAAAAAAAAAAAAAAgAEAAIABAADAAwAAwAMAAPAP
+ AAD8PwAAKAAAADAAAABgAAAAAQAIAAAAAAAACQAAAAAAAAAAAAAAAQAAAAEAAAAAAAATDwgACxsFABgS
+ BwAADhMAARYdACUOCgA2FQ4AKhUUADwQEAAMIwsAGD8GABkkEQARMhUANigIAD8wDgAnIxQANioXAAAd
+ JwAMJy0AAiw6ADYvIQAuOCwANTMvACAwMQBFHhUAQT42ABpQGgAkWQIAI0sQACx0DAA1dwYAK3kYAD5+
+ HwATUC4AJF8kADhcLAAebDsAJX44AGxTGwBCfA4AUkQjAFpXOQABOUgAAkFPAAFDVgASSlYAGndJABdy
+ WQA2Zl4AKn1VAAFVcAA9WGwAEm5hABBzZQAEYXkAGmF5AAlzfQA/YHcAUk1OAHxRUwBRcEMAemZWAExV
+ YwBlYmEAnCwqAJ8wKwCMLzEAnjAwAKQ3KwCjOjYArEEsALJKLAC3US8ArEY3ALJMNQC4VTcAiG83AKtK
+ RQCrUUkAtVdHAK9UUwCyW1kAkXxAAK1kTQC7ZVQAn312ALhmYwC/cGUAu3l3AMVyVwDEeGkAwnx5ADeI
+ BgA3jRMAOJIXADWNKQA4myYAKogzADWYPgA5ozcAQ4sLAEmOEgBViRgATZIYAFaUGQBnmR8AW5ooAFeL
+ OQBmmyUAcZ8qAGiaNwB0oS0AZ6A1AHmmOgAbg18AIYZMADWeQQAkjVQAKptbADmsRwAuoFgAG4ZmAC6D
+ awAklWUAd5NTAHalSgBWgn8AfZ9hAHaZdwCIqTkA/LkeAMyfOADcoygA26k6AOerJgDssS0A/rwnAOKs
+ MwDvuj0A/78wAP7BNwCZnksAmZpWAK+OQgCzkkkAvJ9eAImsRACXsEgAiKhcALi3RQCtrV8AoLlcALK7
+ WQCtmnsAt5pzAIKlZgCapW0AmbhhAJuwfACjoWoAqLFpAKugdwDJoEEA3KxEAN+xTADEt1kA2rFWAOm5
+ TgDnulcAyoVrAMqIdQDQjnoAw5J2ANCQfQDBtmgA1L1tAOi/ZAC6wmgAvMVzAMvDXgD+xkYA/MpXAP/Q
+ XgDHxGcA2sVpANnNdgDpxWkA+8xjAP3QaQDnyXsA8ct3AOzRcwD91HYAAmiIAAd2iAAAbpMAB3GRABp5
+ kwAle4gARWyCAGR6iAAvgpMAR4aBAG6VigB5o5YAup2FAI6nhACYqYUAjKyaALihhwCttYUAurCFAKq4
+ lwC/v58AyImGAMqUiQDUmYgAzZSSANOckwDLo4YAz6yfANillwDfsqMA47+zAKnGgQC9xJ8AxMeMAN3H
+ jADFyZUA2suTAM3UlgDc15MA59OFAPzYhgDv3JsA+9uTAP3hnADLwqQA1sOkANnYpQDWzrQA7d6sAOfG
+ uADs1roA+N+yANfgtQD946cA/ui5ANrSyQDu08MA89zGAPvpxQD56dMA/vHVAP///wAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAA2tfX2gAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFxOQkJC
+ QkJERERBRE5ZAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANdOQkJCSlJc19ra11tSREFEQUbX
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADXR0ZQW976/vz39+3t7ff8/vTXT0RERNcAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAE5HT62VaOfsu6mlpIaGpKSoscHt/PNXREFGAAAAAAAAAAAAAAAAAAAAAAAAAADX
+ R0JY02VeXiiOp6SKiIiIiIeFhYWkqer481FBRNcAAAAAAAAAAAAAAAAAAAAAAFhHRdv+nl1jY2Afgry1
+ jY2MjIyJiYiHhYWp6vzXREFXAAAAAAAAAAAAAAAAAAAAVUVL8/jqlx5jeHhkXZS3tY2NjY2MjImDiYeH
+ irz34EZEUQAAAAAAAAAAAAAAAABYR07797+nsF1keHh4ZGWZt7W1jY2NjIyJiYODh4eo9/FXRFcAAAAA
+ AAAAAAAAANdHS/v3u6m2wW5eeHh4eGRdlMG1tY2NjY2MiYmDg4OHu2aVUkFcAAAAAAAAAAAAAEdK8/i7
+ sba2vbpdeHh4eHhkXW7AtrW1jY2MjImJg4ODqGddnU9EAAAAAAAAAAAAUEfe+L+xtry8vexlZHh4eHh4
+ eF5wwbW1jY2NjYyJiYODtmVeXZpGRgAAAAAAAABWBwYXFRERERERERUCCg0jeHh4eHhduLe1oycPDg4O
+ Dg4OEQICAgwICVkAAAAAAAAZAAAAAAAAAAAAAAAAAAAADXh4eHhhasGjAwAAAAAAAAAAAAAAAAAAAEMA
+ AAAAANgZEhISEhISEhISEhISEgUACnV4eHh4XbqQAAQFEhISEhISEhISEhISBUPXAAAAAEvExMTExMTE
+ xMTExMTExMTCMHh4eGRfXbKxMcTExMTExMTExMTExMTExDRGAAAAAEjExMTExMTExMTExMTExMTExXhk
+ ZWWUsuqwxcTFxMTExMTExMTExMTExDpEAAAAq0jExMTExMTExMTExMTExMTFfGQfoeS+u7G7gcXExMTE
+ xMTExMTExMTExMhEWQAAUEj54p/FxMTExMTCMnR3d3l4dQsAAQAAAQGRvLGvnyZ2NsXExMTExMN8YpxO
+ RgAASEz+7b7FxMTExMQ4IWF4eGRkHAAEBAQEBAQQp7e9gl94JcLExMTExMN4ZHFXRAAASFv+7L7FxMTE
+ xMQ3Hl1dXV0fAS3ExMTExMQrKbbqXmR4JcLExMTExMN4ZF3XRAAASK786r7FxMTExMQ3bOPw8PQaK8TE
+ xMTExMTEFE3pXWR4JcTFxMTExMN4eF2tRADZSN746unFxMTExMQ31vj49T4UxMTExMTExMTEwhOSgl94
+ JcLExMTExMN4eF3SRNeuSN/46unFxMTExMTC7vj4mhPCxMTExMTExMTExDcWr2VfJcLExMTExMNfX13S
+ RlyuSN/495XFxMTExMTCleXuGDfExMTExMTExMTExMQzKrlqI8LExMTExMeWgnDdQlzZSN78k17ExMTE
+ xMU3Hm87M8TExMTExMrKxMTExMTEM1OyG8LExMTExMe2wfjeQtcASN7hXV3ExMTExMQ3IB0zxMTExMTE
+ yubjxsXExMTExC6OIzfExMTExMpqamveQgAASdldXV3ExMTExMQ3JSvExMTExMTG5ezq08bExMTExMQi
+ G8LExMTExDldX12tRAAASatlYXXExMTExMQ3K8TExMTExMXV7Orq6s/ExMTExMTCK8LExMTExDlkYWtY
+ RAAATFpvYXjExMTExMTExMTExMTExNHs7Orqwb/MxMTExMTEwsTExMTExMN4X5VPSgAAqlCPXXnFxMTE
+ xMTExMTExMTEe/L37OrqwcG8y8TExMTExMTExMTExMN4XaJKWAAAAEytXWTExMTExMTExMTExMQ2XWVy
+ 6+rBwcG9ucfExMTExMTExMTExDlfaK1CAAAAAExUJCLFxMTExMTExMTExDl1ZGFds+rBwby8t6bCxcTE
+ xMTExMTExDkbPU9GAAAAAK04xMTExMTExMTExMTExXl4ZF2T7MHBvby3traPwsTExMTExMTExMTExD9Z
+ AAAAAADExMTExMTExMTExMTEdnh4X3LswcHBwby2trW1fcTExMTExMTExMTExDQAAAAAAADGxMTExMTE
+ xMTExMQlZF1dXenBwemTmcG3tbW1izHExMTExMTExMTExMwAAAAAAAAAPkB/L3p6ejLNgdBoXWVllOrB
+ 6WhfXbC3t7W1jYZ9fYB9gICBzck7PAAAAAAAAAAAAElbcl54ZGbqweqZZmVdaerqlF54YWWUu7e1jIyM
+ iYmDibXq+kpHAAAAAAAAAAAAAKtJqm9deF1xuOxyXWFfXXHqaV94eGRfZYK5toyDiYOMter7T0dcAAAA
+ AAAAAAAAAABaTKtvXWRdXWqyXWRhZYLqgl14eHh4ZF9dpo2JjIy16vtVR1UAAAAAAAAAAAAAAAAAWkyq
+ cl1dXV3pal1dmb3Ba2F4eHh4eHhfcLWMjbf3+lBFUAAAAAAAAAAAAAAAAAAAAFpMW9T2aF3pcG24vbe5
+ XXh4eHh4eHhkZbS3wfjfS0dVAAAAAAAAAAAAAAAAAAAAAACqSUzZcl3o7cHBwcFuX3h4eHh4eHh4X4L4
+ +6pHR1sAAAAAAAAAAAAAAAAAAAAAAAAAAExMWtz9+PiYZWhdeHh4eHh4ZGFlZZXeS0dKAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAACsSUlMqvOTXV1dXV9dX2VdZnKdrVVLR1sAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAKpMSUxarZuboaCgoZubq1pMS0urAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFtMSUlM
+ TExMTExJSEtYAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADerKurrNkAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAD///w///8AAP//gAH//wAA//wAAD//AAD/8AAAD/8AAP/gAAAH/wAA/4AAAAH/
+ AAAH/wAA//AAAA//AAD//AAAP/8AAP//gAH//wAA///4H///AAAoAAAAIAAAAEAAAAABAAgAAAAAAAAE
+ AAAAAAAAAAAAAAABAAAAAQAAAAAAAAoIBAAcCwkACRcGABIXBQAAExkAJBsJACQcEwAkIR0AAiYtABkv
+ LgAeMjYAXyIkABxJCwApYw0ANW0SABpPIQANTj4AIGQkACp9NABYRBcARUgxAGpGPwB6YiwAB05VAB9X
+ XgAee0cADWNZAANXawAAV3QALF52ABZmYAADYXgAHm97AAhxegAmbnEASU5FAHlFRQBWe18Af3RLAJws
+ LACfMzIAojUtAKc7LgCpPi8Aozk3AKxCLQCySS4ArEQzAKZBPgCqRDkAr0s7ALJMNAC6VzcAh0hIAINb
+ TgCnRkUAqUZDAKtJQwC4XUkAr1ZWALJbWQCUdE0AvWRNALdhVwC2Yl8AuGVeAKFwXACwdV8AhH9uALZk
+ YgC6amUAumxrAL9wZQC/f2MAtXdrAL5xawCyf2wAvXJwAMFpTADBbFUAw3NYAMBxZADGemQAxHpsAMl+
+ aADCenYAwXt5ADeGAAA3iQYAPIgFADSECAA7gw8AN4oMADuLCwA2jhIAPI4SADiTGAA4miYAKIY0AC+R
+ NQA2mDAANZY/ADabOAA5oC8AOqc+AEWMDABEjBMASIkWAEaRFQBUkxoAV44iAFiXIgBCjDYAYJAiAGad
+ KAB/misAZZ02AHGWOQB5pDUAJIRAADKFQQAql1UAMJ9RADqrRwAuoFkAMaRUACaWYABimkQAfpNAAHSd
+ QQB6mEcAZ4VqAIalNQD7uB4A3KUuAN+sOwDtriMA4KcqAOOqLADxsSEA/rskAP6+LADjqzEA7LQyAP/A
+ MwD/wToAiJlHAImWVwCZnFwApp9HALGQRwCrjF4ArZtWAIyvVQCKtFwAnLZUAKaiTwCmtEkAsrdKAKW3
+ VAC4u1IAs7xZALq6XACaj2EAt4diAJa2ZwCup2YAuK5jAKayYAC/tm4A3K1CAMi7RgDes1UA6rpMAOm9
+ WQDKgGgAy4d0AMOxYADlvGYAxsFZAP7EQgD/x0gA/chLAOzIVwD8ylcAycNhANzGaADJyHMA1sd1AO3A
+ YAD+zmIA/dFrAO3MegD2z3YA6NF4APzUeQACZ4cABXOJABZ2jQAAbpMABHCSAC1rhgA8eYUAPHeQADKB
+ igBSj4wARY2WAGWalQB3oJAAioiKAImpkwClsoQAtreDAMuOigDOkIQA0paFANSZhQDUnI4Ay5GSANKc
+ kwDIqY8A1qGRANmmlgDfsJkA2rymAMnPkQDlyoIA8c+CAOvSgwDz1IIA/taDAPXVigD+2owA69mWAPTX
+ kwD62pIA+dyZANvLpQDnwawA6MSpAOzJqwDk3KkA6siwAPLXtwD23bMA9t67AO/hpwD74qYA/eSsAP7m
+ sgD75roA/ei4AOHbxAD+68EA////AAAAAAAAAAAAAAAAAAAAV0hIVwAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAEwqKjpCTExBOSgoSAAAAAAAAAAAAAAAAAAAAAAAAEAyRN32+evk5Oj49d89KDwAAAAAAAAAAAAA
+ AAAAANwrTINgb7Krj4+Li4eIr+zwPSjbAAAAAAAAAAAAAABULN77XGZna6G1kpGRjo2Jiq7t2ihIAAAA
+ AAAAAAAAVDDv7LNyfHx8bru1kpKRjo6NjI/C4ThIAAAAAAAAANww7+ivuaJhfHxpbbS5kpKRjo2NhpCF
+ lDHbAAAAAAAALt/svr+/5mF8fHx8YaG5tZKRjo2NjXRdpCkAAAAAABYCCAcGBwYHAwMQfHx8bcCrFAYG
+ BgYGBAMDAjYAAAAABwUFBQUFBQUFBQFjfHxonxcBBQUFBQUFBQUFDAAAAFPIyMjIyMjIyMjIxXtpYmGf
+ p8XIyMjIyMjIyMgeRgAAL8jIyMjIyMjIyMjGe2yp48Oqx8jIyMjIyMjIyMopAAAv/dXJyMjIIWN9fnwN
+ AAEAAZe+vXF6IMjIyMl+gDgA2j/+5MnIyMgbYWFhDgkcHB0cCq26YXwcyMjIxnxtRtaxsPrkycjIyB/i
+ 8u4LxcjIyMjFFaNiaSDIyMjJfGFLTlOx+eTJyMjIy/v1JCDIyMjIyMggJ3BlHMjIycZiYU1GU7H7m8jI
+ yMgjpkUdyMjIyMjIyMgcmXIcyMjJx6ycV0exsaZeycjIyBsPHMjIyMjT0cjIyMgZkxzIyMnHhZxXTN6w
+ XmHJyMjIHBjIyMjI0OzozsjIyMgRHMjIycZhbUTbAE9ufMjIyMjFycjIyM/r7ObBzcjIyMXFyMjJxnx1
+ MwAANYFnyMjIyMjIyMgipurpxMS7x8jIyMjIyMnGYpQsAABTPhLIyMjIyMjIyWRhcOnEwL+oyMjIyMjI
+ yckOQ0IAAADFyMjIyMnJych6fGG8xMS/ubmUyMjIyMjJyMgeAAAAAMnIyMjIycnIGmhhnMTkosK5t7Um
+ yMjIyMnJyMwAAAAAADeEeH951NVwXlrD53NhhcC3kpCdnZad1NIlAAAAAAAA2U92aGGg6HdhYYW9YXxi
+ bZ64kY2NjsDxNNcAAAAAAAAAsFF2YV1tnGFhnsNefHx8aG23jpHA8TNEAAAAAAAAAAAAsE+Vm168bp+/
+ n2J8fHx8Yp+57OA0UwAAAAAAAAAAAAAA2TWld/fpu7RufHx8fHxoc/VULtcAAAAAAAAAAAAAAAAAAE81
+ sfF1WV1iYmFhcJOYND8AAAAAAAAAAAAAAAAAAAAAAABTNU+lpZmYpaVPNVIAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAANmwUVGw2gAAAAAAAAAAAAAAAAD//D///8AD//8AAP/8AAA/+AAAH/AAAA/gAAAH4AAAB8AA
+ AAPAAAADgAAAAYAAAAGAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAAYAAAAGAAAABwAAAA8AA
+ AAPgAAAH4AAAB/AAAA/4AAAf/AAAP/8AAP//wAP///gf/ygAAAAYAAAAMAAAAAEACAAAAAAAQAIAAAAA
+ AAAAAAAAAAEAAAABAAAAAAAABg8DAAQMDAAXCAYAGQkJAAkQBAAHFggAGxQEABASCAAaFQoAGxgUADs1
+ HgANNT0ACD07ABpNIAAiQCUAVEEWAHRpPAAARV0ACVJWABBeUgATZ08AD2BSABJhXwAaZF8AHnFdAB16
+ WwAicEwALmVdAC92WgAIVW0AF1poAANYcgAAXXoAD2liAAxqbAAHbXkAD3x8AHBMVgB3WlcAWVpgAKM9
+ PQCvSjwAsE08AI5OUgCZV1MAp0VFAKlIRwCsTksAs1hPALleSwCvVFMAr1ZWALJaVwCyW1kAs11ZALVf
+ XACYYV4AlWpbAJF7UAC9YEIAs3hPAK5mVQC3YFUAu2VTALBrVwC2YFgAtWBdALR1VQC6bGkAoHNkALxx
+ bwC+c3AAwGlKAMJuVADDcFcAwnBYAMZ6ZgDJfGQAyH9rADSGCAA5kRUAOZQaADWMJQAzjysAN5cnADqX
+ IAA4mSMANpgsADmfLgAxjD4ALpI7ADSaNgA3nj0AOaEyADegOAA5pTsAOqg/AECLCgBBhxAATpMWAEaX
+ HwBLlh4ATJUfAFSWHQBEmCIASpkiAFGbJABcmiMAZ54pAGWbNQBumD0AdZI5AHKRPQB4kT0AZqAsAH2k
+ LwBmoDUAKpFGAC+YRQAxmkEAOqtEADOjTgA5rEgAfotFAHiTRABshFsAU4t/AICpPAC8pz8A1a45AO+x
+ JADxsiIA/rshAPu6KAD+vigA/78tAOauMgDirDQA4a04APi+OAD+wDEA/sE1AP/COgD+wjwAjodCAI+I
+ RgCMhk8Ajo5MAJKATgCUjUsAjJNKAIyTUgCwgVUAgKNCAIGtTgCSrkQAmK9DAI+wVQCNsFgAoqZKALyn
+ QACrtkoAtbZCAKK2UgC3vFUAiYJsAJeZYACSnm4Ao6NnAKSzYgCnu2UAuLlkALy0aAC3t3oAtbl8ANWx
+ SADhsEQA5rZMAMqAagDKiXwAzIx+AMu3YADEvWgA1rxpALvAYADNwFAA18RZAP7FRADyx04A/slOAOLF
+ VADkx1kA78RbAPfKVwD/zFIA9MVbAM7FZQDXy3UA7sNgAOvDZADpx28A/s5jAPXPaAD6z20A8813APDK
+ eADyzn4A/tRyAPrUewAAY4MAD22FAAFtjwALe4UAA3KMAA10jQASdY4AAG6TAARwkwAMdJMALHmAACJ7
+ jAB9n4MAaJKQAJ6OhwCPrJcApLOMALm6gwCyu5MAiK67AMuQjgDRmoUA1JqJANafkQDYoI0A26aPANyp
+ jwDfrI0Aw7aJAN2rkADkuJQA5ryWAOO3nADlu58A6L6YAM7KhwDPxo0A7NOBAPLThAD91oEA89SIAPvZ
+ jgDsyqwA/uOhAP3kuAD///8AAAAAAAAAAAAAAEhDOEcAAAAAAAAAAAAAAAAAAAAAADFDte/w8O+1MC8A
+ AAAAAAAAAAAAAAA/QXFuuLGLiouyz/A4MwAAAAAAAAAAACvq9VNdZ7+PjoiIg4rN5ykAAAAAAAAAK/LP
+ yGV7YWzAvI+IiIWEx6cuAAAAAABA6s/Hypxhe3tpu7yPjYiFjWOTMwAAAAADCgkHCQgGDnthc8cQBwcH
+ BwEFBAAAACcSEhISEhISDXt7UrYMEhISEhISEiwAACjZ2dnZ2dnZ1Viat8nd2dnZ2dnZ2SYA6ef22dnZ
+ GXd6VAYCAgvBrFsj2dnZd5XmT/P42dnZG5ufD9LZ2SERnWEi2dnWYXxFTPz429nZ3/6mIdnZ2dkglFYi
+ 2dnWXn04S/ye2dnZHage2dnb29nZH6AW2dnYuu41s6lQ2dnZFRPZ2dvk4tnZ2RwU2dnXZJhF6pFf2dnZ
+ IdnZ2eH7+d7Z2dkh2dnWXpXmAD1V2dnZ2dnZGqv70cx/2dnZ2dnWUj8AADoX2dnZ2dklYGf30MrH3NnZ
+ 2dnZGC0AAOXZ2dnZ2SRfUcbRxcq+sNPZ2dnZ2QAAAABGfnZa46piaPmAVqLCj4Khoa3gOQAAAAAASXFX
+ baRSUbloYV5ro4iIw/QrAAAAAAAAAEmXdZxsostpe3t7ar3Q7ysAAAAAAAAAAABLma79pXRhe3thUq5N
+ MgAAAAAAAAAAAAAAADxOlnFvb3KSRDIAAAAAAAAAAAAAAAAAAAAA6E5LS03oAAAAAAAAAAAA/8P/AP4A
+ fwD4AB8A8AAPAOAABwDAAAMAwAADAIAAAQCAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAABAIAA
+ AQCAAAMAwAADAOAABwDwAA8A+AAfAP4AfwD/gf8AKAAAABAAAAAgAAAAAQAIAAAAAAAAAQAAAAAAAAAA
+ AAAAAQAAAAEAAAAAAAAEFQ8ABRQQAA0WEAASFxAAERgVABEZGAAuHx4AAis4AAQsOABEIiQAH10nACFe
+ IQBsViIAHX1UACN5RQA8eE0AP31QAARdbwAEX3MAB1p0ABFdcAAZfWAANWxsACNldwB+e0AAp2pPAKx6
+ SwC4ZV4Au35dALVuZgC6amcAu29qAL1wbwC/dHAAvnV0AMh8ZgDIfmkAwHh0AD2VIgA4miUAP5okADSa
+ NgAykzkAOqAxADmjNABRlR0ARZkoAFqCOgBDnT0AYoA6AHSXOgBAoDIAS6EwAFShMABfpDIAWKA3AGKh
+ LwB2pDQAfqo+ACCHVgA4okEAOqlBADqsRgA6rUgAGoZrAECTTQBvgkwAdJZBAHeQZABgjnoAgYw/AIyq
+ MgCDrD4Akaw/ALurLgDTrjcA8rQmAP67IgD+vi0A/8E2APbAPgD/wjsAg45JAKePSgCKrkAAhalKAJ60
+ SwCerlQAobJDAKS0SQC5t0QArrZXALGRewCWtmEAqqxwALy9eADStEkA7r1OAOu+WgDrv14AyoFqAMqC
+ bgDKh3QAzIt0AMmHfADPjHgAz5V2ANeefwDcp3cA3qV5AO3FTwD2xUkA/spSAM/IcwDpymUA6ctoAPLH
+ aQDrxHEA7dJ7AP7TdAACb44AFWqKABtsigADcY4AAG6SAARukAAAb5QAAnGRAAxzkAARdpQAHnuSACN+
+ kwCGpYwAxYOEAMyMggDTloIA2qKCAMC1kQDNwoQA1MmSAOTHggDqw5UA9tuZAOLUogAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAP///wAAAAAAAAAiHx8hAAAAAAAAAAAAABpTjWRkdm0cAAAAAAAAh2xYPTlwUE9NYmuG
+ AAAAAIl1cyw/N29ST05LGQAAAAcGBQUBC0BVDQQEAwIKAAB9fX19fUE3XEZ9fX19egBmkH19DyoMCAhU
+ VhZ9gDEiJY+Af4WKFH19FTMOfYAoHmZefX0RGH2Eg30XEX2BWiBqJ319FICCjIuBfRR9gC8mADB9gH+A
+ QnJ4X319fX0yAAB9fX9/PDZ3dHFFfX19ewAAAEMrYC46VzVbUUxhXQAAAACIRy47WUlAP0hxbmkAAAAA
+ AAAbjkooLDREJQAAAAAAAAAAAABqHR1nAAAAAAAA/D8AAPAPAADAAwAAwAMAAIABAACAAQAAAAAAAAAA
+ AAAAAAAAAAAAAIABAACAAQAAwAMAAMADAADwDwAA/D8AACgAAAAwAAAAYAAAAAEAIAAAAAAAgCUAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAChMSsCoDErHKAwK0ifLytqny8rgZ4uK4yeLiuMnS0qgZ0t
+ KmqdLCpInCwqHJwrKgIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACiNCsIojMqT6EyKp+hMiveoDEq/aAxKv6gMCv/ny8q/p4v
+ Kv6eLiv/ni4q/p0tKv6dLCr/nCwp/ZwrKd6cKyqfmyopT5sqKggAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApDYrHaM2K42jNCvoozQr/qIzKv6hMiv/pjw1/rVf
+ Wf7Cenb/youG/s6Tjv7Nk47/yYqG/sB4dv6zW1n/ojc1/pwsKf6cKyr/nCsp/pwqKuibKimNmykpHQAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKU4KxGlNyuQpDYr96Y7MP+wUkn/wHZv/9Sh
+ mv/t0cP//vHV///twv//6LD//eOk//3gnf/84Jz//eKh//7nrf//7L///vDS/+zQwf/OlJD/q0xK/5ws
+ Kv+cKir/myoq95sqKpCbKioRAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApjkrUKY4K+WmOi7+slRK/sGM
+ fP6LoVz/TpMc/s3Ulv742pT/7sdu/uW6Wf7fsUz/2qtE/tioP/7Ypz7/2qk//t6uRf7ktk//7MJg/vbR
+ ef7+4pz//ezF/ubGuf+5aGf+nCwr/psqKv+aKSnlmikpUAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKc6KwSnOiyRpjkr/aY5
+ LP+8amD+rLSD/kSNEP43iwv/NYkW/kJ8Dv6Znkv/2rBX/t6qOv7krDH/6a8v/uyxLv7tsSz/6q4p/uWq
+ J/7fpSb/2qIo/tqkLv7frD3/7L9X/vvXgf/+6rj+58i7/q9UU/+bKin+mikp/ZspKpGaKCkEAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAqDwsEag7
+ LLmoOyz/qT4v/9ObkP/979T/mbhh/zWFD/81lT7/NZQ9/zWNKf82gAT/iqc5/+3Oaf//xUL//8E4///B
+ Nv//wDP//78w//+/Lf//vir//Lsn//KzJP/nqiL/3aMm/92nMv/rvFD/+9iD//3rxP/Nk4//nS8u/5sq
+ Kv+bKSq5mykqEQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AACpPSwRqT0ryKg8K/6vSjv/5sS3/v/quf/21Ib+ra1f/jJ3Bv43n0L/OqpH/jqtSP45ozX/N4sJ/p6y
+ R/7/zl3//sRB/v7CPP7/wjn//sE2/v7AM/7/vy///r4s/v69KP7/vSX/+7ki/u6vIf/hpiX+4aw2/vLH
+ YP/+5aj+47+z/qU+Pv+bKyv+mykqyJsqKxEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAKo+KwSqPiy8qT0r/rBOPv7v1sb//uWr/vDJc//itVb+175u/jmEAv46qT//Oq1I/jqt
+ SP47rkn/OZwp/kGKCP60u1b//tFm/v7GRv7/wz///sI8/v7BOP7/wTX//sAx/v6/Lf7/vin//r0l/v+8
+ Iv/8uSD+7a4g/uKpK//su07+/eOi/tbOtP+0YmH+nS4u/psqKrybKioEAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAKs/LJarPyz/sU08/+/Xx//+46f/7cVu/+S2Vf/0wlT//tV4/26f
+ K/83jg//O61I/zuuSf87rkn/Oq1I/zmgMP84iAT/mLBG//zUcv//ylD//8VC///DPv//wjr//8E2///A
+ Mv//vy7//74p//+9Jf//vCH//7sf//e2H//mqyf/6cJr/0uOEf+HpFv/slxb/5wsLP+bKiqWAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAq0ArVatAK/2tRDH/6Me5/v7mrv7ux3L/6Lta/vnI
+ Wv/+zFv+/tBm/t7Pev43hwL/OqtE/jqtSP47rkn/Oq1I/jqtSP46pTr/N4oI/mydKP7s0XP//spR/v7G
+ RP7/xED//sI7/v7BN/7/wDL//r8u/v++Kf/+vCX+/rsh/v+7Hf/8uR7+67tN/lWJGP83hgH+mqVt/qtN
+ TP+bKir9mysrVQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACINCIVrEEs56xBLP/Xo5b//+u9//PO
+ fP/rvl///Mtf///OYf//zmP//9Bn//zbjv8+iQb/OqY6/zuuSf87rkn/O65J/zuuSf87rkn/OqpD/zeP
+ Ef9zoS3//tR0///IS///x0X//8RB///CPP//wTf//8Ay//+/Lf//vSj//7wk//+7IP//ux7/+8xW/0GB
+ CP82jR3/PYoI/6+be/+jPDz/mikp54YkJBUAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABeJBiXNhUO/iUO
+ Cv41My//Ni8h/jIpFv40KhT/NiwV/jYsFf82LBb+Ni0Z/jMuH/4MHQD/DCML/hEyFf4gXyj/NqFD/jqt
+ SP47rkn/Oq1I/jqpQf43iQX/xcNl/v7OXv7+x0v/zJ84/mxTG/4/MA7/NikL/jYoCv82KAn+NigI/jYo
+ B/82KAb+NisS/g4dAf8LHwr+Cx0C/hkkEf8qFRT+PBAQ/ockJJcAAAAAAAAAAAAAAAAAAAAAAAAAAIEz
+ IyJBGRD5AAAA/gAAAP4AAAD/AAAA/gAAAP4AAAD/AAAA/gAAAP8AAAD+AAAA/gAAAP4AAAD/AAAA/gAA
+ AP4AAAD/ETMV/jinRv47rkn/Oq1I/jqtSP45miX/Ypoi/v3We/7JoEH/GBIH/gAAAP4AAAD/AAAA/gAA
+ AP8AAAD+AAAA/gAAAP8AAAD+AAAA/gAAAP8AAAD+AAAA/gAAAP8AAAD+AAAA/pEnJ/mQKCgiAAAAAAAA
+ AAAAAAAAAAAAAKFDLpU/IRv/ABoi/gAeKP4AHij/AB4o/gAeKP4AHij/AB4o/gAeKP8AHij+AB4o/gAe
+ KP4AHij/AB0n/gAWHf4ABQb/CBkK/jejRP47rkn/Oq1I/jqtSP46qkH/N4cC/tXLcv6vjkL/BgUC/gAH
+ Cv4AGCD/AB0n/gAeKP8AHij+AB4o/gAeKP8AHij+AB4o/gAeKP8AHij+AB4o/gAeKP8AHSf+ABYd/owv
+ Mf+YLCyVAAAAAAAAAAAAAAAArEYuD69GLfAFa47/AG6T/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG+U/wBvlP8Ab5T/AG6T/wBtkv8AZIT/F3JZ/zmrSf87rkn/OqxG/zmiNP84lBn/N4cC/77C
+ Zv/pw2P/MGFe/wBniv8AbpL/AG6T/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8AbpP/AG2S/z1WbP+bKyrwmysqEAAAAAAAAAAAsEYsXLBGLP4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBu
+ k/4Ab5T/AG6T/gBvlP8AbpP+AG6T/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/B3eJ/jepTf44mSL/N4kF/kWN
+ Df6Mrkn/vcNs/vvYhv7RvWz/DnSQ/gBuk/4Ab5T/AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AG6T/gBv
+ lP8AbpP+AG6T/gBvlP8AbpP+AG6T/j9gd/+cLCv+nCsqXAAAAAAAAAAAsEcsqrBHLP4Eb5L/AG+U/gBu
+ k/4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBvlP8AbpP+AG6T/gBuk/4Ab5T/AG6T/gBvk/4Ec47/IZNp/jij
+ P/4yeQD/qLFp/t3HjP7kxH7/5MBv/ui/ZP7wyGb/c5l8/glykf4Ab5P/AG6T/gBvlP8AbpP+AG6T/gBv
+ lP8AbpP+AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AG6T/kVsgv+hNjT+nCwqqgAAAACxSC0FsUgt6bFH
+ Lf/a0sn/vcSf/5+ug/8GcZL/AG+U/wBvlP8Ab5T/AG+U/wBvlP8HaYj/K3tT/yGGTP8nmGL/KZtf/y6g
+ WP82qU7/OKE2/xg/Bv8DBgD/CQgG/wkIBf8JCAT/CQgE/xMPCP+zkkn//c1i/+fDYP/Btmn/m7B8/yV+
+ OP8ijFj/Em5h/wBpi/8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wZ2i/8omF//Kogz/4KlZv+oRUL/nCwq6Zws
+ KgWxSC0osUgs/rlZQP7+9N///N2X/ubKfP4JcpH/AG6T/gBuk/4Ab5T/AG6T/gBvlP8JY33+Pn4f/jiX
+ H/46rUf/OqtD/jqnPv44mSX/JFkC/gIJBf4ADxP/AA8U/gAPFP4ADxT/AA8U/gAOE/4nIxT/27JW/v7N
+ Xf7/03H/h6o8/jiQE/86rUj+H24//gBlhv8AbpP+AG6T/gBvlP8AbpP+AG6T/gl5h/86rEn+OJsp/mOg
+ N/+2Y2D+nSwq/pwsKiiySS1Wskks/sd6Zv7+8ND/+9qP/ufLfP4JcpH/AG6T/gBuk/4Ab5T/AG6T/gBv
+ lP8DYHb+LHQM/jeJBv43iAP/N4cB/jaGAP47dg7/ChQJ/gBEWv4AbJD/AGyQ/gBskP4AbJD/AGyQ/gBr
+ jv4AOUz/UkQj/vLEXf721oH/QosI/jmjNf86rUj+H24//gBlhv8AbpP+AG6T/gBvlP8AbpP+AG6T/gl5
+ h/86rUn+OaM3/j6KCP/Fh4P+ni8s/p0tKlazSi15s0ot/9KUgv/+7MT//NmK/+jMff8JcpL/AG+U/wBv
+ lP8Ab5T/AG+U/wBvlP8DYHb/V4s5/8DMjP/W16L/3dqo/+vatv9BPjb/ADdJ/wBskP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG+U/wBvlP8Aao3/Ay47/4hvN//u04D/OYcC/zqkOP86rUj/H24//wBlhv8Ab5T/AG+U/wBv
+ lP8Ab5T/AG+U/wl5iP86rUn/OqpD/zeGAf/Alof/oDEv/50tKnmzSi2Qs0os/tmkk/7+6r3//dmJ/ujM
+ fv4JcpL/AG6T/gBuk/4Ab5T/AG6T/gBvlP8IYnz+v7+f/v3kt/7+5Lb/+N+y/ndrVf4CKzn/AGqO/gBu
+ k/4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBuk/4Ab5P/AGWH/g8qLv68n17/i6tA/jiQE/86rUj+H24//gBl
+ hv8AbpP+AG6T/gBvlP8AbpP+AG6T/gl5h/86rUn+Oq1H/jeIA/+6nYX+oDQx/p4tKpCzSy2cs0ss/t2t
+ nf7+6bn//dqL/ujRjv4JcpP/AG6T/gBuk/4Ab5T/AG6T/gBvlP8NZYD+y8Kk/v3mvP7947f/q5l7/gol
+ Lf4AZYf/AG6T/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBggP4uOCz/wrZn/kOM
+ Cv84lRv+H208/gBlhv8AbpP+AG6T/gBvlP8AbpP+AG6T/ghzff83jA3+OJUd/jeHAv+4oYf+oTUx/p4u
+ K5u0TC2dtEst/92unf/+6rz/+uGh/4yvXP8EcI//AG+U/wBvlP8Ab5T/AG+U/wBvlP8NZYH/fZ9h/8TP
+ lP/Ww6T/IDAx/wBffv8AbpP/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8AVXH/Wlc5/9rHb/9ZlRr/HV4i/wBlhv8Ab5T/AG+U/wBvlP8Ab5T/AG+U/yB7if+4t0X/iak2/2uh
+ M//PrJ//oDMu/54uK520TC2StEwt/tqmlf787sv/ha1K/jKEDP4Cb43/AG6T/gBuk/4Ab5T/AG6T/gBv
+ lP8FYXn+LXUN/meaN/5HTkn/AFZz/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/AG+T/jiHk/4rgJL/AG6T/gBu
+ k/4Ab5T/AG6T/gBuk/4AbpP/A01k/pF8QP/CwV/+H1oa/gBlhv8AbpP+AG6T/gBvlP8AbpP+AG6T/ih9
+ h//3y1X++9Vy/v7ptv/UoJv+nzAr/p4vKpK1TS18tU0u/tiikv6pxoH/N4YA/jKEDP4Cb43/AG6T/gBu
+ k/4Ab5T/AG6T/gBvlP8DYHf+K3kY/iNLEP4CTGT/AG6T/gBuk/4Ab5T/AG6T/gBuk/4Ab5P/LIGU/trL
+ k/7Jw43/HHqS/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/AG2R/hJKVv+cmlD+KV8h/gBlhv8AbpP+AG6T/gBv
+ lP8AbpP+AG6T/id+jf9nmR/+Ypoh/luZI//Snpr+oDIs/p8vKn21TS1btk8w/9Scif84hgH/N4gE/zKF
+ D/8Cb47/AG+U/wBvlP8Ab5T/AG+U/wBvlP8DYnr/HWIz/wFDU/8AbpL/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8YeZT/xsSW//7akf/92Ir/r7aI/w50kv8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBrj/8LRz7/GE4c/wBl
+ hv8Ab5T/AG+U/wBvlP8Ab5T/AG+U/w10f/82hwT/OJAS/zmHA//JjYj/oTIs/6AwK1u1Ti4utk8v/s+J
+ dP48iQb/OZwp/jWjRv4CcJD/AG6T/gBuk/4Ab5T/AG6T/gBvlP8AXHn+AkFP/gBskP4Ab5T/AG6T/gBu
+ k/4Ab5T/AG6T/gtzk/6quJf//NqU/v3Zjv7+14f//NWA/o6nhP4EcJL/AG6T/gBuk/4Ab5T/AG6T/gBv
+ lP8AZ4r+AztD/gBlh/8AbpP+AG6T/gBvlP8AbpP+AG6T/ghzfv85ozf+OZ4s/lycLv+7bGf+oTIr/qAx
+ Ky62Ti4Itk8u7cNuU/5snDv/OJkj/jWoT/4CcJD/AG6T/gBuk/4Ab5T/AG6T/gBvlP8Aa4/+AGyQ/gBu
+ k/4Ab5T/AG6T/gBuk/4Ab5T/BXGU/oysmv772pb//dqQ/v3Yiv7+14T//dV9/vfQdv5rloH/AW6T/gBu
+ k/4Ab5T/AG6T/gBvlP8AbpP+AGqN/gBtkf8AbpP+AG6T/gBvlP8AbpP+AG6T/gl5h/86rUn+OJMX/oSp
+ W/+uTkf+oTIr7aEyKwgAAAAAtk8us71fQf+Wm1n/N4wM/zWoTv8CcJD/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8AbpL/LoNr/+3erP/94af//tuR//7Xhv/+1oD//tR5//7S
+ cv/vy23/R4aB/wBuk/8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wl5
+ h/86q0X/N4cD/6ugd/+nPjb/ojMrswAAAAAAAAAAtk8uZrhTM/7BkXD/OogE/jWfP/4CcJD/AG6T/gBu
+ k/4Ab5T/AG6T/gBvlP8AbpP+AG6T/gBuk/4Ab5T/AG6T/gBuk/4Qc2X/NYUK/j6JB/5zpDj/79yb/v3X
+ hf7+1Hv//dN1/v3Rbv7+z2f/3cBl/iZ3g/4AbpP/AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AG6T/gBv
+ lP8AbpP+AG6T/ghzff83jA7+S5IZ/sOEe/+jNi3+ojQrZgAAAAAAAAAAtlAvFrZQLvWtZE3/OFws/xNN
+ LP8AbY//AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wp1gP8znUD/OZwp/zmf
+ Lf83hgH/vMVz//7XhP/+03b//tJw//7Qav//zmP//81c/8KwXv8Pbof/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wZpgv8YSRr/UXBD/6tRSf+iNCv1ojUrFgAAAAAAAAAAAAAAAKtS
+ NKUaYXn/AGyQ/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBvlP8AbpP+AG6T/gBuk/4Ab5T/BG+H/i+e
+ Vf46rUn/Oqg//jeIBf6HrUf/99yW/v3UeP7+0nD//tBr/v7PZf7/zV7//stY/v7KUv6bm1r/BWyM/gBv
+ lP8AbpP+AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AGqN/kxVY/+dOC+lAAAAAAAA
+ AAAAAAAAAAAAAGZcWTAAb5T/AG6T/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBvlP8AbpP+AG6T/gBu
+ k/4Baof/J45R/jqsRv46rEX/N48R/n+oP/793ZT//dR5/v3UeP7+1n7//tR1/v7OYv7/zFn//spT/v7J
+ Tf76xUf/a4FZ/gFsj/8AbpP+AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AG6T/j1Z
+ bP1yR0owAAAAAAAAAAAAAAAAAAAAAAAAAAABbpLxAG6T/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG+U/wFskP8cbjj/OaM3/zeKCP83iAT/O4gE/+PUiv/+1Hf//tV6/+fUhv+KrEP/sLxe//7V
+ eP//y1X//8lO///ISf//xUP/77o9/z1rX/8AbZL/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG6T/yhgebUAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3ZHMsdllO8GViYf5Wgn//GndJ/huD
+ YP4cimz/G4Nf/ip/WP95oI7+eZuA/pKlh/5Njxf/N4oI/keODv45hwL/kLBM/v3aiP7+0nD/6NSE/k6R
+ FP44kRT/OIcD/s/IbP7/0Gb//spS/v7GRP7/wz7//sI5/tqqNP9+j1f+eZFc/nmRWv95kFj+eZBZ/nmS
+ X/95mXP+eaae/mR6iP9dTFT+dEdJ8EhWZSkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApVM3abhT
+ MP7Hel//eZ1F/jeMC/46qkL/OaI0/keNDf/12Yz+/tN0/v7Xgf6zwGj/R40O/j2JBf43jg//VpQa/v3b
+ jv7/1n3/k7BJ/jiPEv46rUj/OJgh/kaNDP6cskj/4sxs/v7NWv7/xkT//sE2/v+/MP/+viv+/r0m/v+8
+ Iv/+vCH+/r4p/v/IRf/+3In+7tK//qtENv+mOSv+mT0zaQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAt1EvArhRLq26VjT/x4Vp/2aZNP83jQ3/OqlA/zeOD/9pnSn/x8Zt//vckP9woC//N4gF/zme
+ LP84lRz/O4gD/2ecJ//83ZH/WJUb/ziUGv86rEb/Oq1I/zmfLf84kBP/Q4sJ/4+rPP/Vxl7//8tS//+/
+ Lf//vSf//7wj//+8I///vyv//8hG///agv/14Mj/slNF/6g7LP+nOiytpjksAgAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAALhSLw+4US7Nu1k4/smLb/5omjb/N4wL/jmgMP83jQz+N4cC/mCZ
+ If68w2n/OIcD/jmiNP45mST/QosJ/oysQP7+2of/g6g6/jeHAv46qUH/Oq1I/jqtSP46rUj/OaI0/jiS
+ Fv45iAP/x79U/v/DOP/+vSX+/r0n/v/BMf/+y07+/tyJ/vbhyP+3XE7+qDwr/qg7LM2nOisPAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC4UjAYuFEu1rtZN/7KhWv/eZ5G/jeG
+ AP87iAX+N4YA/j+KB/7o1IP/YJkh/jeNDf43iAT/srxZ/v7Sa/7+1Xb/X5gf/jmcKf47rkn/Oq1I/jqt
+ SP47rkn/Oq1I/jqtSP44mCH/eqIr/v/LT//+vy7+/sU8/v/QXv/+4pz+79TA/rVWRv+pPSv+qT0r1qg8
+ LBgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAuFIwGLhR
+ Ls66VjT/x3le/7qwhf/X4LX/UZMZ/zeGAP/j1IT/daMy/2mdJ//EwmH//NNv///LVf/XyWn/OIcC/zqp
+ Qf87rkn/O65J/zuuSf87rkn/O65J/zuuSf86pDb/OogE/8vEXf//z13//9h6///rvP/fsqP/r0k2/6s/
+ LP+qPizOqT0sGAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAALhSLw+4US6tuFIv/rtZOf/NmoD+dJ9D/jqIBP7c15P//t6S/v7Zgf7+1nn/+dR2/v3V
+ dv5xnyr/OJQb/jqtSP47rkn/Oq1I/jqtSP47rkn/Oq1I/jqtSP46rUf/OJMY/n6pP//+6rn+89zG/sZ8
+ bP+sQSv+q0Ar/qs/LK2qPisPAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC4US4Ct1EubbdQLvO6WDf+xnRa/sujhv7149L//u3E/v7m
+ rP6guVz/RYwM/lGRFP43igj/OqpC/jqtSP47rkn/Oq1I/jqtSP46qkL/OaM1/jiZIv43jAv/P4oK/oqr
+ Xv/VnZD+sUo1/q1CLP+sQSzzrEArbatALAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALhRLyS4US6vt1Au/bhT
+ Mv+5VDP/y4Fp/+jFtv9/q1X/PIkG/zeGAP83iQX/N40O/ziPEf84jxH/N40N/zeKB/83hgH/QowO/26g
+ QP+ho2r/xpN8/71mUv+xSzT/rkMt/a1DLK+sQiwkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAt1AuMbZPLau3Ty74tk8t/rlXOP7FcVf/0I96/rqWcP6zn3P/qKFs/qGhaP6hoWj/qKFt/rSf
+ dP6+l3b/zYp4/r9pU/63Vj7/sUox/rBFLfivRS2rrkUuMQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC2Ty4dtk8ucrZPLr+2Ti70tlAw/rdTNP64VDb/uVc5/rlY
+ O/64Vzv/t1U5/rZRNf60TjP/skou/rFILfSxSC2/sEcucrBHLh0AAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC2Ty8Ntk8vO7VO
+ Lmi1TS6LtU0uobRMLay0TC2ss0stobNLLYuzSi1oskouO7FJLg0AAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD//8AD//8AAP/+
+ AAB//wAA//gAAB//AAD/4AAAB/8AAP/AAAAD/wAA/wAAAAD/AAD+AAAAAH8AAPwAAAAAPwAA+AAAAAAf
+ AAD4AAAAAB8AAPAAAAAADwAA4AAAAAAHAADgAAAAAAcAAMAAAAAAAwAAwAAAAAADAACAAAAAAAEAAIAA
+ AAAAAQAAgAAAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAAAAAAAEAAIAA
+ AAAAAQAAgAAAAAABAADAAAAAAAMAAMAAAAAAAwAA4AAAAAAHAADgAAAAAAcAAPAAAAAADwAA8AAAAAAP
+ AAD4AAAAAB8AAPwAAAAAPwAA/gAAAAB/AAD/AAAAAP8AAP+AAAAB/wAA/+AAAAf/AAD/+AAAH/8AAP/+
+ AAB//wAA///AA///AAAoAAAAIAAAAEAAAAABACAAAAAAAIAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAChMisOoDErSqAwK36fLyugni8rsZ4u
+ KrGdLSqgnSwqfpwrKkqcKyoOAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKQ2KwGjNStLojQrsKIzK/mhMyv/rEpE/7hk
+ X/++cWz/vXBs/7ZiX/+pRkP/nSwq/5wrKvmbKiqwmyoqS5sqKgEAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAClOCs3pTgsyqpEOf+wdV//yKmP//be
+ u//85Kz/9deR//HQg//xz4L/9NWN//vipv/23LX/2KaX/7NdWv+bKir/myoqypsqKjcAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACnOiwCpzosgKY5LPy/c2n/ephH/zyO
+ E/9XjiL/w7Fg/9urQv/hqzT/5aww/+WsLf/iqSz/3KUu/9+sO//rv1r/+duT/+jEqf+yWlj/myoq/Jsp
+ KoCbKSoCAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAqTwsB6g8LK2pPi//1qGR//rn
+ u/87gw//NZY//zeZOP9EjBP/ubtQ///FQ///wTj//8A0//+/L//+viv/+Lgm/+2uI//gpyr/6rpM//re
+ mv/Smo7/nC0t/5spKq2bKSoHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKo+LAKqPiyvrEQ0/+fB
+ rP/42JH/5bxm/2CQIv86qkT/O65J/zqrQ/9Qkxb/3cdg///HSP//wz3//8E4///AMv//vy3//70n//67
+ Iv/xsSH/5Kww//bPdv/avKb/p0ZF/5sqKq+bKSoCAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAq0AshKxC
+ L//nwq3/9tWL/+i7Wf/6yVv/tbxY/ziXH/87rkn/O65J/zqnPf9FkhX/xMBZ///LVf//xEH//8I7///A
+ NP//vy7//70n//+8If/7uB7/6rEw/4ShN/+Fl1L/pT8//5sqKoQAAAAAAAAAAAAAAAAAAAAAAAAAAJs7
+ JzqsQSz82qeV//nbmP/twGD//cxf///OYf/41n//O5AT/zuuSf87rkn/O65J/zqrRP84khb/uLxV///K
+ UP//xUP//8I8///ANP//vy3//70m//+7IP/+vij/f5or/zeJDf+aj2H/nzIy/JEnJzsAAAAAAAAAAAAA
+ AACDMyEBRxsSzhoKB/8kIR3/IhwQ/yMcDf8kHQ7/JB0P/yIfE/8IFAH/Ch8N/xpPIf84pkX/O65J/zqs
+ Rf9Kkxf/99Ft/96vQv9YRBf/KB4J/yQbB/8kGwX/JBoF/yQbBf8SFwX/BxQF/w4WB/8eDAz/ax0dzpAn
+ JwEAAAAAAAAAAJ9CLVAqGRb/ABQa/wAUGv8AFBr/ABQa/wAUGv8AFBr/ABQa/wAUGv8AEBX/AAMD/yp9
+ NP87rkn/O65J/zmbKP+tuVP/emIs/wADBP8AERf/ABQa/wAUGv8AFBr/ABQa/wAUGv8AFBr/ABQa/wAS
+ Gf9fIiT/mCsrUAAAAAAAAAAArkYuugJtkf8AbpP/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBu
+ k/8BZYH/MJ9S/zqoP/85myf/PY8S/6i4Vv+up2b/AWWG/wBuk/8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG6T/ylfev+bKyq6AAAAALBHLROwRy37Am+T/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG+T/wd2iv8wn1D/SIkW/6ayYP/lyoL/7shx/7+2bv8Udo//AG+T/wBvlP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG+U/wBvlP8Ab5P/LWuG/54wL/ucKyoTsUgtU7JJLv/h28T/vbyG/wVwkv8Ab5T/AG+U/wBv
+ lP8eb3v/KIY0/y6gWf8xpFT/OKVA/xxJC/8DBAH/BgUD/wYFA/8KCAT/sZBH//PJX//RwXP/Qow2/yiS
+ VP8DYXj/AG+U/wBvlP8Ab5T/BHSN/y6dUv9imkT/pkE+/5wsKlOySS2HvmVN//7rwf/tz3//BnGS/wBv
+ lP8Ab5T/AG+U/w5iWP83jAz/OJMZ/zeQEv8vZgv/AiYt/wBSbf8AU27/AFNu/wBRbP8ZLy7/3rNV/8nD
+ Yf84lh7/N6NF/wRdbv8Ab5T/AG+U/wBvlP8GdYz/OqxJ/0GRGP+2ZGH/nSwqh7NKLanJfmj//uay/+/P
+ fv8GcZL/AG+U/wBvlP8Ab5T/FmZg/8nPkf/k3Kn/28ul/x4yNv8AZon/AG+U/wBvlP8Ab5T/AG+U/wBj
+ hP9FSDH/urpc/ziXH/83o0X/BF1u/wBvlP8Ab5T/AG+U/wZ1jP86rUn/OJIW/7V3a/+dLSqqs0stu86L
+ dv/+5az/79KH/wZxk/8Ab5T/AG+U/wBvlP88eYX//eW6//fesv9JTkX/AGCA/wBvlP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG+U/wBZd/9/dEv/Xpkh/zaYMP8EXW7/AG+U/wBvlP8Ab5T/BnOH/ziZJP83jxH/sn9s/54u
+ K7u0TC28z4x3//3ouP+Mr1X/Am+Q/wBvlP8Ab5T/AG+U/yZucf+TtWL/hH9u/wBWcv8AbpP/AG+U/wBv
+ lP8CcJP/AW+T/wBvlP8Ab5T/AG+U/wdSaf+tm1b/XJEf/wRba/8Ab5T/AG+U/wBvlP8Xd4z/yLtG/6C4
+ Vv/Bgnr/ni8rvLRNLavNhnD/nb1v/zSECP8Bb4//AG+U/wBvlP8Ab5T/DWRb/zVtEv8IUGf/AG6T/wBv
+ lP8Ab5T/AW+U/4mpk/93oJD/AG+T/wBvlP8Ab5T/AG6T/x9XXv+MmkL/BFlo/wBvlP8Ab5T/AG+U/xp5
+ jv+NqDL/mrZU/8J6dv+fLyustU0uisqAaf83iQb/NI0X/wFvkP8Ab5T/AG+U/wBvlP8JXmP/B05V/wBu
+ k/8Ab5T/AG+U/wBvk/9lmpX/+tmS//fViP9Sj4z/AG+U/wBvlP8Ab5T/AG2R/w1OPv8DWGr/AG+U/wBv
+ lP8Ab5T/B3KF/ziTGf8+jA3/umpl/6AxK4q2Ti5YwWhN/1GTIf83qUv/AXCR/wBvlP8Ab5T/AG+U/wBi
+ g/8AbZH/AG+U/wBvlP8AbpP/RY2W//TXlv/+2Y3//taD/+3Nev8ygYr/AG6T/wBvlP8Ab5T/AGuO/wBk
+ hf8Ab5T/AG+U/wBvlP8GdIr/OqpD/2OcNv+rSUL/oTIrWLZPLhi6Vzj9fpNA/zaeOP8BcJH/AG+U/wBv
+ lP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/whxev+Ssmb/69mW//7Yif/+1X3//tJz/9rBbf8WdYz/AG+U/wBv
+ lP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wZ0if84mib/i5VV/6Q5Mf2hMysYAAAAALZQL8GUdE3/IGQk/wBu
+ kf8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8EcYv/L5E1/ziWHv9Xlh7//tuP//7Tdv/+0Wz//s5i/7iu
+ Y/8Hbo7/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/BG2H/yRgD/+hcFz/ozUrwQAAAAAAAAAAn1M6Wwto
+ hv8AbpP/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AW2O/ymXW/86rEb/PpEU/8bHdP/+1Xz//tFv//7P
+ Zf//zFz//spS/4uWXv8AbZH/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG6T/y9dc/+YOTJbAAAAAAAA
+ AABGYmsDAG6T+QBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBukv8ee0f/OZsn/ziQE/+etlX//tV6//TV
+ gf+yvFv/9NFz///LVP//yEv/+8NC/1Z7X/8AbpP/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/H2N/3WZL
+ UgMAAAAAAAAAAAAAAABYXmBMg1tO/meFav8khED/JpZg/zKFQf+lsof/sLOB/1eWIP9Ciwr/PYkG/+fS
+ gP/+1n3/Zp0o/ziWHv+Cpzb//dJt///ITP//wjz/7rc0/6ifSf+mn0j/pp9G/6aiT/+msoL/ioiK/3lF
+ Rf5gTlZKAAAAAAAAAAAAAAAAAAAAAAAAAAC3US+UwmtN/3CVOP85nCj/OJQb/6i4Vf/114T/daM0/zqT
+ GP84kBP/fqY3/9vNd/83jxH/Oq1H/zmbJ/9DkBL/pbNE/+zIV///wTP//70n//+8I///vy3//9Fj/+zJ
+ q/+rQjP/pjoslAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALhRLge4Ui+6wnFS/3OXO/84lBr/N4kG/0mO
+ D/+gtVH/OJYe/zqQE/+jtEz/6NF4/zmLCv86rEX/O65J/zqsRv85nSv/TJIV//rIS///vSf//8I2///U
+ bv/syqv/r0s7/6g8LLqnOiwHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALhRLgu4Ui+7wWpM/5mc
+ XP+KtFz/PIgE/8zJcv9Ukxf/qrZN///PYP+xuE7/OZwo/zuuSf87rkn/O65J/zuuSf84mCL/s7dG///M
+ VP//35P/37CZ/65GNP+qPiy7qTwsCwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALhR
+ Lge4US6UuVUz/rqLZf90nUH/7+Gn///cjP/dy23/ycJa/1GUGP86q0T/O65J/zuuSf87rkn/Oq1H/zmg
+ L/9fmib/8te3/8Z6aP+sQSz+q0AslKo+LAcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAC3US5KuFEv271dPv/OiHD/6siw/2ifN/83hgD/N48Q/ziZI/84mSP/OJYe/ziQ
+ E/9Ulyb/hZhM/7OGY/+zTjj/rUMs26xBLEoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC3UC4Et08uXrZPLsi4UjL+wmtQ/7+BYf+0iWH/q41e/6yM
+ Xv+0iGL/v39j/71kTf+0Tzb+sEYtyK9FLV6uQy0EAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALZPLh62Ty5gtU4uk7VN
+ LrW0TC3GtEstxrNKLbWySi2TsUktYLFILR4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAP/gB///AAD//gAAf/gAAB/wAAAP4AAAB+AAAAfAAAADgAAAAYAAAAGAAAABAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIAAAAGAAAABgAAAAcAAAAPgAAAH4AAAB/AA
+ AA/4AAAf/gAAf/8AAP//4Af/KAAAABgAAAAwAAAAAQAgAAAAAABgCQAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACHKyMCoTIqO6AxK36fMCusny8rwp4uKsKdLSqsnCwpfpwr
+ KjuFJCQCAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkzEmBKQ2
+ K2mnPjTctmBY/syMfv/dq5D/5LiV/+S4lP7cqY//yol8/qxOS/+cKyrcmyopaY4mJgQAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAClOSslpjkrzLBrV/5ykT3+ZZs1/ta8af7hsET+4q04/uKs
+ NP7hrTj+5rZM/vHOff7mvJb+s11Z/psqKcyaKSklAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKk8
+ LDqqPy/t2KGM/s7Kh/81jCX/N549/kyVH//ixVT//8I7//7BNf7/vy7/+7oo/u+xJP/mrjL/8813/tOa
+ hv+dLy/tmykqOgAAAAAAAAAAAAAAAAAAAAAAAAAAqj8rJ6xCMO7jt5z/8Mp4/uvDZP9Glx//Oq1I/jqp
+ Qf9anCX/5MdZ//7FQ/7/wjn//sAx/v++Kf/+uyL/8bIi/u7DYP+XmWD/oTg47psqKicAAAAAAAAAAAAA
+ AACGMyIFrEErztumj/7zzn/+98dd/v7OY/6Ur0T+OqtE/jqtSP46q0X+RZgh/tfEWf7+xkX+/sI8/v7A
+ Mv7+vin+/rsg/vi+OP5BhxD+jIZP/p0vL86LJSUFAAAAAAAAAABjJhltFwgG/hsYFP8ZFAr/GxYK/hsW
+ C/8QEgj/BxUI/hpNIP86rEj/OqxH/2agLP7xw1n/VEEW/h0WBv8bFAT/GxQD/hsVBv8GDwP/CRAE/hkJ
+ Cf+NJiZsAAAAAJQ8JwNlRUHhAEVc/gBGXv8ARl7/AEZe/gBGXv8ARl7/AERa/gg9O/85qkj/OqpD/ziT
+ F/7Lt2D/DTU9/gBEW/8ARl7/AEZe/gBGXv8ARl7/AEZe/gBEWv9/NzzhkCcnBLBHLEFZWmD+AG+T/gBu
+ k/4AbpP+AG6T/gBuk/4AbpP+AG6T/gt7hf42mCz+gKNC/sS9aP7px2/+InuM/gBvk/4AbpP+AG6T/gBu
+ k/4AbpP+AG6T/gBuk/5wTFb+nCsqQbFILYXQmoX/z8aN/gRwk/8Ab5T/AG6T/h5xXf8vmEX/M6NO/jOP
+ K/8HFwj/BAwN/wQMDP47NR7/78Rd/ri5ZP8ukjv/DGps/gBvlP8Ab5T/A3OO/jGaQf+Re1D/nCwqhbJJ
+ LbPlu5//8tOE/gRwk/8Ab5T/AG6T/iJwTP+BrU7/jbBY/iJAJf8AY4P/AG2S/wBtkv4AX3//dGk8/piv
+ Q/86qD//D2li/gBvlP8Ab5T/BHSN/jqqQ/9+i0X/ni4ss7NLLcrsyar/89SI/gRwk/8Ab5T/AG6T/miS
+ kP/95Lj/iYJs/gBaeP8Ab5T/AG+U/wBuk/4Ab5T/A1hy/o6OTP87lyD/D2li/gBvlP8Ab5T/BHKL/jmf
+ Lv94k0T/nzEuyrRMLcvsy67+j7BV/gFvkf4AbpP+AG6T/i92Wv6Snm7+CFVt/gBuk/4AbpP+DnWT/gpz
+ k/4AbpP+AG6T/hdaaP6ipkr+D2BS/gBuk/4AbpP+EnWO/s3AUP7Dton+nzAsy7VNLrWjo2f/NIYI/gFv
+ kP8Ab5T/AG6T/hNnT/8JUlb/AG6T/gBvlP8GcZT/sruT/6SzjP4DcJP/AG6T/gBuk/8uZV3/EF5S/gBv
+ lP8Ab5T/DXSN/k6TFv+Mk1L/oDErtbZOLoiOh0L+N6A4/gFvkv4AbpP+AG6T/gBdev4AbpP+AG6T/gFv
+ lP6PrJf+/dmP/v3Wgv59n4P+AG6T/gBuk/4AbZH+AF56/gBuk/4AbpP+BHKL/jmgMf6SgE7+oTIriLZP
+ LkazeE//N5cn/gFvkv8Ab5T/AG6T/gBvlP8Ab5T/AG6T/h16W/+nu2X/+tmO//3Uev76z23/U4t//gBu
+ k/8Ab5T/AG6T/gBvlP8Ab5T/BHKL/jyUHP+uZlX/oTMrRqRJKwWKWkrmEmFf/gBukv8Ab5T/AG6T/gBv
+ lP8Ab5T/D3x8/jikPP9Llh7/7NOB//7ScP7+z2T/78RZ/ix5gP8Ab5T/AG6T/gBvlP8Ab5T/AW2P/hpk
+ X/+ORUHmnTIqBQAAAAAhaICIAG6T/gBuk/4AbpP+AG6T/gBuk/4HbXn+NJo2/jmTGP7Xy3X++NR8/s7F
+ Zf7+zmL+/slO/tWxSP4PbYX+AG6T/gBuk/4AbpP+AG6T/gBuk/5HVmZ4AAAAAAAAAAA4YnALjlhG1WyE
+ W/8qkUb/MYw+/rm6g/+ks2L/QIsK/laWHv/+14H/gKk8/zmXIP6stkr/98pX/v/DPP/Vrjn/vKdA/ryn
+ P/+8tGj/no6H/oRCP9VPU2AKAAAAAAAAAAAAAAAAuFEuL71hQfJ0kzn/OJkj/meeKf+itlL/OJQa/juQ
+ E/+7wGD/UpYc/zqsRv45ojT/UZsk/rW2Qv//vyz//r4o/v/MUv/ovpj/q0Ey8qc6LC8AAAAAAAAAAAAA
+ AAAAAAAAAAAAALhRL0G+YUHyjJNK/magNf6QrkT+Xpki/qq2S/71z2j+Q5kj/jqtSP46rUj+Oq1I/kqZ
+ Iv7yx07+/tZ0/t+sjf6tRDLyqTwrQQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC4US4vuFMx17CB
+ Vf+1uXz//uOh/re8Vf99pC//OqY7/zqtSP46rUf/OqY6/jqWHf+3t3r/xnll/qxBLNerPywvAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAsk4sCbdQLne3UTDoyXth/pSNS/93kTr/bpg9/26Y
+ Pf54kT3/j4hG/rR1Vf+zTzjorkMtd6pBKwkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAACtSysHtk8uTLZPL4+2UTK8t1I00rZRM9K0TTG8skkuj7BHLUyqRCsHAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAP4AfwD4AB8A8AAPAOAABwDAAAMAgAABAIAAAQAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAABAIAAAQDAAAMA4AAHAPAADwD4AB8A/gB/ACgA
+ AAAQAAAAIAAAAAEAIAAAAAAAQAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAcSUeE58y
+ Km2jNzGxrU1I06xLSNOgMjCxmiopbm8eHhMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApDgrbaJi
+ RfGDjkn/5MeC/+u/Xv/rvlr/68Rx/9ynd/+0XVXxmikpbQAAAAAAAAAAAAAAAAAAAAAAAAAAqj8umNee
+ f/+erlT/OKJB/2KhL//2xUn//8E2//29LP/ytCb/7r1O/8+Vdv+eMDGYAAAAAAAAAAAAAAAApT4qb9qi
+ gv/yx2n/6cpl/zqgMf86rEb/X6Qy/+3FT///wjv//78u//67Iv+7qy7/fntA/5krK28AAAAAbSsdFCMU
+ EvIRGRj/ERgU/xEZFv8EFQ//H10n/zqtSP+KrkD/bFYi/xMXEP8SFxD/DRYQ/wUUEP86FxnydCAgFK1F
+ LHIBbpP/AG+U/wBvlP8Ab5T/AG6T/xqGa/9YoDf/rrZX/2COev8AbpP/AG+U/wBvlP8Ab5T/FWqK/5ws
+ K3K1UDW24tSi/wJvk/8Ab5T/I3lF/zSaNv8hXiH/Ais4/wQsOP+nj0r/halK/xl9YP8Ab5T/AnKQ/0Od
+ Pf+lPz22v2dO2Pbbmf8DcJP/AG+U/4aljP/AtZH/B1p0/wBvlP8Ab5T/EV1w/3SXOv8dfVT/AG+U/wNx
+ jv84miX/qFRL2MFrUNmWtmH/AW+R/wBvlP8/fVD/I2V3/wBuk/8jfpP/HnuS/wBvlP81bGz/PHhN/wBv
+ lP8Mc5D/pLRJ/7BWUdm9YUS4PZUi/wBvkv8Ab5T/BF9z/wBuk/8RdpT/1MmS/83ChP8Mc5H/AG6T/wRd
+ b/8Ab5T/A3GO/0WZKP+pRT+4tlEwdVqCOv8Ab5L/AG+U/wBvlP8Bb5H/QJNN/8/Ic//+03T/qqxw/wFu
+ kv8Ab5T/AG+U/wJvjv9igDr/ojUsdWhCNRcDbZD9AG+U/wBvlP8AbpP/IIdW/1ShMP/t0nv/6cto//7K
+ U/93kGT/AG6T/wBvlP8Ab5T/E2eG9nQyLhcAAAAAj1dEd2+CTP8ykzn/vL14/1KWHf92pDT/nrRL/0uh
+ MP+5t0T/9sA+/9OuN//StEn/sZF7/4dCPXcAAAAAAAAAAGYtGQG6WTiggYw//1GVHf9+qj7/obJD/4Os
+ Pv86rUj/OqlB/4yqMv//y1H/3qV5/6pAL6BnJBsBAAAAAAAAAAAAAAAAaC4aAbhSL3epdkX26sOV/5Gs
+ P/8/miT/OaM0/0CgMv90lkH/xnhh9qxALHdpJhsBAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkT8kGLdQ
+ L3m7YkO8smxG3rFrRt64XUO8sUkveZA4JRgAAAAAAAAAAAAAAAAAAAAA8A8AAOAHAADAAwAAgAEAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAEAAIABAADAAwAA8A8AAA==
+</value>
+ </data>
+ <data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
+ <value>CenterParent</value>
+ </data>
+ <data name="$this.Text" xml:space="preserve">
+ <value>Package Editor</value>
+ </data>
+ <data name=">>DeleteResourceButton.Name" xml:space="preserve">
+ <value>DeleteResourceButton</value>
+ </data>
+ <data name=">>DeleteResourceButton.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>columnHeader1.Name" xml:space="preserve">
+ <value>columnHeader1</value>
+ </data>
+ <data name=">>columnHeader1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ColumnHeader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>columnHeader2.Name" xml:space="preserve">
+ <value>columnHeader2</value>
+ </data>
+ <data name=">>columnHeader2.Type" xml:space="preserve">
+ </data>
+ <data name=">>columnHeader3.Name" xml:space="preserve">
+ <value>columnHeader3</value>
+ </data>
+ <data name=">>columnHeader3.Type" xml:space="preserve">
+ </data>
+ <data name=">>columnHeader5.Name" xml:space="preserve">
+ <value>columnHeader5</value>
+ </data>
+ <data name=">>columnHeader5.Type" xml:space="preserve">
+ </data>
+ <data name=">>AddResourceData.Name" xml:space="preserve">
+ <value>AddResourceData</value>
+ </data>
+ <data name=">>AddResourceData.Type" xml:space="preserve">
+ </data>
+ <data name=">>DeleteResourceData.Name" xml:space="preserve">
+ <value>DeleteResourceData</value>
+ </data>
+ <data name=">>DeleteResourceData.Type" xml:space="preserve">
+ </data>
+ <data name=">>EditResourceData.Name" xml:space="preserve">
+ <value>EditResourceData</value>
+ </data>
+ <data name=">>EditResourceData.Type" xml:space="preserve">
+ </data>
+ <data name=">>toolStripSeparator1.Name" xml:space="preserve">
+ <value>toolStripSeparator1</value>
+ </data>
+ <data name=">>toolStripSeparator1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStripSeparator, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>SaveResourceData.Name" xml:space="preserve">
+ <value>SaveResourceData</value>
+ </data>
+ <data name=">>SaveResourceData.Type" xml:space="preserve">
+ </data>
+ <data name=">>BrowseResourceDataFile.Name" xml:space="preserve">
+ <value>BrowseResourceDataFile</value>
+ </data>
+ <data name=">>BrowseResourceDataFile.Type" xml:space="preserve">
+ <value>System.Windows.Forms.OpenFileDialog, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>SaveResourceDataFile.Name" xml:space="preserve">
+ <value>SaveResourceDataFile</value>
+ </data>
+ <data name=">>SaveResourceDataFile.Type" xml:space="preserve">
+ <value>System.Windows.Forms.SaveFileDialog, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>SavePackageDialog.Name" xml:space="preserve">
+ <value>SavePackageDialog</value>
+ </data>
+ <data name=">>SavePackageDialog.Type" xml:space="preserve">
+ </data>
+ <data name=">>AddResourceButton.Name" xml:space="preserve">
+ <value>AddResourceButton</value>
+ </data>
+ <data name=">>AddResourceButton.Type" xml:space="preserve">
+ </data>
+ <data name=">>AddFolderButton.Name" xml:space="preserve">
+ <value>AddFolderButton</value>
+ </data>
+ <data name=">>AddFolderButton.Type" xml:space="preserve">
+ </data>
+ <data name=">>toolStripSeparator2.Name" xml:space="preserve">
+ <value>toolStripSeparator2</value>
+ </data>
+ <data name=">>toolStripSeparator2.Type" xml:space="preserve">
+ </data>
+ <data name=">>$this.Name" xml:space="preserve">
+ <value>PackageEditorDialog</value>
+ </data>
+ <data name=">>$this.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Form, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2011-11-07 16:31:53 UTC (rev 6203)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2011-11-08 13:43:56 UTC (rev 6204)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:2.0.50727.4961
+// Runtime Version:2.0.50727.5448
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
@@ -117,6 +117,13 @@
+ internal static System.Drawing.Bitmap application_browser {
+ get {
+ object obj = ResourceManager.GetObject("application_browser", resourceCulture);
+ return ((System.Drawing.Bitmap)(obj));
internal static System.Drawing.Bitmap application_export {
get {
object obj = ResourceManager.GetObject("application-export", resourceCulture);
@@ -138,6 +145,13 @@
+ internal static System.Drawing.Bitmap applications_stack {
+ get {
+ object obj = ResourceManager.GetObject("applications_stack", resourceCulture);
internal static System.Drawing.Bitmap arrow {
get {
object obj = ResourceManager.GetObject("arrow", resourceCulture);
@@ -212,6 +226,13 @@
+ internal static System.Drawing.Bitmap blueprints {
+ get {
+ object obj = ResourceManager.GetObject("blueprints", resourceCulture);
/// <summary>
/// Looks up a localized string similar to Ensure the Geometry box is checked.
/// </summary>
@@ -446,6 +467,13 @@
+ internal static System.Drawing.Bitmap database_share {
+ get {
+ object obj = ResourceManager.GetObject("database_share", resourceCulture);
internal static System.Drawing.Bitmap databases_relation {
get {
object obj = ResourceManager.GetObject("databases-relation", resourceCulture);
@@ -480,6 +508,13 @@
+ internal static System.Drawing.Bitmap disk {
+ get {
+ object obj = ResourceManager.GetObject("disk", resourceCulture);
/// <summary>
/// Looks up a localized string similar to Diverging.
/// </summary>
@@ -1638,6 +1673,13 @@
+ internal static System.Drawing.Bitmap images_stack {
+ get {
+ object obj = ResourceManager.GetObject("images_stack", resourceCulture);
/// <summary>
/// Looks up a localized string similar to This connection is not compatible.
/// </summary>
@@ -1885,6 +1927,13 @@
+ internal static System.Drawing.Bitmap map {
+ get {
+ object obj = ResourceManager.GetObject("map", resourceCulture);
internal static System.Drawing.Bitmap map__arrow {
get {
object obj = ResourceManager.GetObject("map--arrow", resourceCulture);
@@ -2296,6 +2345,13 @@
+ internal static System.Drawing.Bitmap printer {
+ get {
+ object obj = ResourceManager.GetObject("printer", resourceCulture);
/// <summary>
/// Looks up a localized string similar to Processed: {0}.
/// </summary>
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2011-11-07 16:31:53 UTC (rev 6203)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2011-11-08 13:43:56 UTC (rev 6204)
@@ -125,9 +125,15 @@
<value>Failed to read {0} color(s) in line {1}</value>
<comment>An error message that is displayed if the expected color count does not match the actual count</comment>
</data>
+ <data name="Confirm" xml:space="preserve">
+ <value>Confirm</value>
+ </data>
<data name="InvokeUrlNoMapDefined" xml:space="preserve">
<value>Cannot get layers. No map definition specified</value>
</data>
+ <data name="arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="minus-circle" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\minus-circle.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
@@ -137,14 +143,18 @@
<data name="layer--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\layer--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="HeaderFileMissing" xml:space="preserve">
+ <value>The header file does not exist</value>
+ <comment>A message displayed when the user selects a non-existing file</comment>
+ </data>
<data name="application--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\application--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_viewoptions" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_viewoptions.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="image" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\image.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="PropEnumNoValues" xml:space="preserve">
- <value>Could not find possible values for enumerable property</value>
+ <data name="property" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\property.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="DataReadError" xml:space="preserve">
<value>Unable to read data from the selected column: {0}</value>
@@ -163,12 +173,15 @@
<data name="tick-circle-frame" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\tick-circle-frame.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="ColorPicker" xml:space="preserve">
- <value>Color Picker ...</value>
+ <data name="application_browser" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\application-browser.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="icon_printablepage_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_printablepage_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="icon_measure" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_measure.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="application--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\application--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
@@ -178,17 +191,17 @@
<data name="icon_refreshmap_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_refreshmap_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="folder_horizontal" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\folder-horizontal.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="images_stack" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\images-stack.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="block" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\block.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="InvalidResourceIdFolder" xml:space="preserve">
- <value>Must be valid resource id. Cannot be a folder</value>
+ <data name="icon_print" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_print.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_tasks" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_tasks.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="ruler1" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\ruler1.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="ColHeaderName" xml:space="preserve">
<value>Name</value>
@@ -196,33 +209,40 @@
<data name="SelectSpatialContext" xml:space="preserve">
<value>Select Spatial Context</value>
</data>
- <data name="ui_splitter_horizontal" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\ui-splitter-horizontal.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="database_share" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\database-share.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="InlineSymbolDefinition" xml:space="preserve">
- <value>Inline Symbol Definition</value>
+ <data name="NotSessionBasedId" xml:space="preserve">
+ <value>Resource ID must not be session based</value>
</data>
- <data name="SaveResourceFirst" xml:space="preserve">
- <value>Please save this resource first</value>
+ <data name="icon_restorecenter" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_restorecenter.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="printer" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\printer.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="layer" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\layer.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="gear--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\gear--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
<data name="NoWidgetEditorIface" xml:space="preserve">
<value>The specified editor does not implement the required IWidgetEditor interface</value>
</data>
<data name="control" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\control.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_restorecenter_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_restorecenter_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="sql" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\sql.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="icon_zoomout_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_zoomout_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="PackageReadError" xml:space="preserve">
+ <value>Failed to read package. Error message was: {0}</value>
+ <comment>A message displayed when the package could not be read</comment>
+ </data>
+ <data name="icon_zoomselect_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoomselect_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="sql-join-left" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\sql-join-left.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
@@ -237,8 +257,8 @@
<value>New folder</value>
<comment>The default name of a new folder</comment>
</data>
- <data name="FsPreview_GeometryPropertyNodeTooltip" xml:space="preserve">
- <value>Name: {0}{7}Description: {1}{7}Geometry Types: {2}{7}Read Only: {3}{7}Has Elevation: {4}{7}Has Measure: {5}{7}Spatial Context: {6}</value>
+ <data name="icon_invokescript_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_invokescript_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="grid" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\grid.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
@@ -252,9 +272,12 @@
<data name="table--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\table--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="map--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\map--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="blueprints" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\blueprints.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="PreviewRecordCount" xml:space="preserve">
+ <value>{0} results found</value>
+ </data>
<data name="server" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\server.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
@@ -286,14 +309,17 @@
<data name="PromptDeleteWidgetAndReferences" xml:space="preserve">
<value>Delete this widget and all references to it?</value>
</data>
+ <data name="icon_selectwithin_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_selectwithin_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="gear" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\gear.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="AggregateQuery" xml:space="preserve">
<value>Aggregate Query</value>
</data>
- <data name="InvalidResourceIdNotSpecifiedType" xml:space="preserve">
- <value>Invalid Resource Identifier. Not the specified type</value>
+ <data name="map--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\map--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="icon_zoomin" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_zoomin.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
@@ -316,14 +342,11 @@
<data name="SpecifySecondaryFeatureSource" xml:space="preserve">
<value>Please specify the secondary feature source</value>
</data>
- <data name="globe--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\globe--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
<data name="drive-download" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\drive-download.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_null" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_null.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_search" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_search.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="QualitativeName" xml:space="preserve">
<value>Qualitative</value>
@@ -335,15 +358,24 @@
<data name="sort-number" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\sort-number.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="DeleteCommand" xml:space="preserve">
- <value>Delete Command</value>
+ <data name="IncompatibleConnection" xml:space="preserve">
+ <value>This connection is not compatible</value>
</data>
- <data name="sql-join-right" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\sql-join-right.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_selectwithin" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_selectwithin.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="map--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\map--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="PromptRepairBrokenFeatureSource" xml:space="preserve">
+ <value>The resource id {0} could not be found. You will now be prompted to select the correct feature source</value>
+ </data>
<data name="icon_popupscrollup_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_popupscrollup_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="color" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\color.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="icon_plotdwf" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_plotdwf.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
@@ -358,6 +390,9 @@
<data name="ruler" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\ruler.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="application-import" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\application-import.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="document-copy" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\document-copy.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
@@ -385,19 +420,9 @@
<data name="ErrorLoadingWmsConfig" xml:space="preserve">
<value>Error loading WMS configuration document: {0}. A default document will be created</value>
</data>
- <data name="SymbolGraphicsImagePlaceholder" xml:space="preserve">
- <value><image></value>
- </data>
<data name="ui-separator" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\ui-separator.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="XmlEditorCursorTemplate" xml:space="preserve">
- <value>Line {0}, Column {1}</value>
- </data>
- <data name="InvalidValueError" xml:space="preserve">
- <value>Invalid value</value>
- <comment>An error message that is displayed when the entered value is invalid</comment>
- </data>
<data name="UnitsKb" xml:space="preserve">
<value>KB</value>
</data>
@@ -407,9 +432,6 @@
<data name="icon_panright_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_panright_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="NoSchemasInFeatureSource" xml:space="preserve">
- <value>Feature Source has no schemas</value>
- </data>
<data name="RdbmsFeatureSource" xml:space="preserve">
<value>RDBMS Feature Source</value>
</data>
@@ -420,15 +442,12 @@
<data name="TestConnectionNoErrors" xml:space="preserve">
<value>Provider reported no errors</value>
</data>
- <data name="globe--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\globe--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="InvokeScriptCmdDescription" xml:space="preserve">
+ <value>Invoke Script Command</value>
</data>
<data name="CustomCommandsExported" xml:space="preserve">
<value>Custom commands exported to {0}</value>
</data>
- <data name="StandardQuery" xml:space="preserve">
- <value>Standard Query</value>
- </data>
<data name="ExtentsCalculationCompleted" xml:space="preserve">
<value>Map extents calculation completed. Click Accept to use the calculated extents.</value>
</data>
@@ -438,6 +457,11 @@
<data name="layer-shape-curve" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\layer-shape-curve.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="TooMuchDataWarning" xml:space="preserve">
+ <value>The selected column contains more than {0} different values.
+The calculated averages only accounts for the first {0} distinct values.</value>
+ <comment>A warning message that is displayed if the dataset is too large</comment>
+ </data>
<data name="NoTypesSelected" xml:space="preserve">
<value>You must select at least one type</value>
<comment>A message that is displayed when the user has not selected any resource types</comment>
@@ -455,8 +479,8 @@
<data name="ParameterOverrideExists" xml:space="preserve">
<value>Parameter Override already specified</value>
</data>
- <data name="sql-join" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\sql-join.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="SymbolGraphicsTextPlaceholder" xml:space="preserve">
+ <value><text></value>
</data>
<data name="layer--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\layer--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
@@ -471,6 +495,9 @@
<value>Unknown types</value>
<comment>The list entry that represents unknown resource types</comment>
</data>
+ <data name="gear--pencil" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\gear--pencil.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="icon_panright" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_panright.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
@@ -481,12 +508,9 @@
<data name="icon_home" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_home.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="QuestionResetFsOverrideList" xml:space="preserve">
- <value>Reset Feature Source override list?</value>
+ <data name="icon_restorecenter_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_restorecenter_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="FieldRequired" xml:space="preserve">
- <value>This field is required: {0}</value>
- </data>
<data name="ResourceDoesntExist" xml:space="preserve">
<value>Resource doesn't exist</value>
</data>
@@ -515,12 +539,9 @@
<data name="icon_pan" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_pan.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_search_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_search_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_viewoptions" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_viewoptions.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
<data name="icon_zoomselect" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_zoomselect.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
@@ -530,6 +551,9 @@
<data name="drive-upload" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\drive-upload.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="document--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\document--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="SpatialContextsFound" xml:space="preserve">
<value>{0} spatial contexts found</value>
</data>
@@ -542,19 +566,17 @@
<data name="globe--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\globe--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="TooManyIndiviualValuesError" xml:space="preserve">
+ <value>The selected column contains more than {0} different values, and thus cannot be used for theming with individual values</value>
+ <comment>An error message that is displayed if the selected column has too many distinct values</comment>
+ </data>
<data name="FdoConnectionStringComponentNotFound" xml:space="preserve">
<value>The component "{0}" could not be found in the specified FDO connection string</value>
</data>
- <data name="FindNothing" xml:space="preserve">
- <value>Could not find specified string or end of document reached</value>
- </data>
<data name="OutputFileMissing" xml:space="preserve">
<value>You must enter a full path to the output file</value>
<comment>A message that is displayed when the user has not entered an output file</comment>
</data>
- <data name="ErrorMapExtentCalculationFailed" xml:space="preserve">
- <value>Could not transform extents of any layer in this Map Definition. You will have to specify the extents manually.</value>
- </data>
<data name="OdbcCannotInferDriver" xml:space="preserve">
<value>Could not infer ODBC driver from file name: {0}</value>
</data>
@@ -564,9 +586,6 @@
<data name="UnitsMs" xml:space="preserve">
<value>ms</value>
</data>
- <data name="icon_print" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_print.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
<data name="databases-relation" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\databases-relation.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
@@ -580,6 +599,9 @@
<data name="arrow-return-180" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\arrow-return-180.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="tick" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\tick.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="arrow-curve-180-left" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\arrow-curve-180-left.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
@@ -597,6 +619,16 @@
<value>You have entered a non-numeric value in the Reference Y field. Due to a bug in MapGuide, this will likely give an error when saving.</value>
<comment>An error message that is displayed if the user attempts to use an expression as the InsertionPointY value (caused by an xsd bug in MapGuide)</comment>
</data>
+ <data name="OdbcDriverAccess64" xml:space="preserve">
+ <value>{Microsoft Access Driver (*.mdb, *.accdb)}</value>
+ </data>
+ <data name="SymbolTypeNotSupported" xml:space="preserve">
+ <value>Only symbols of type "Mark" and "Font" are currently supported</value>
+ <comment>A message that is displayed when the user attempts to modify an item with an unsupported type</comment>
+ </data>
+ <data name="FieldRequired" xml:space="preserve">
+ <value>This field is required: {0}</value>
+ </data>
<data name="icon_copy_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_copy_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
@@ -610,8 +642,8 @@
<data name="CoordinateTransformationFailed" xml:space="preserve">
<value>Failed to transform coordinates: {0}</value>
</data>
- <data name="cross" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\cross.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="SQLQuery" xml:space="preserve">
+ <value>SQL Query</value>
</data>
<data name="PropertyTooltip" xml:space="preserve">
<value>Property: {0}
@@ -653,18 +685,18 @@
<data name="icon_panup_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_panup_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="icon_selectpolygon" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_selectpolygon.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="InvalidConnection" xml:space="preserve">
<value>This is not a valid connection: {0}</value>
</data>
<data name="folder--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\folder--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_plotdwf_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_plotdwf_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_zoom_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoom_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="FsPreview_ClassNodeTooltip" xml:space="preserve">
- <value>Name: {0}{3}Description: {1}{3}Geometry Property: {2}</value>
- </data>
<data name="folder--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\folder--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
@@ -681,12 +713,18 @@
<value>An error occured while reading column values: {0}</value>
<comment>An error message that is displayed when the column values could not be read</comment>
</data>
+ <data name="WmsLayersUpdated" xml:space="preserve">
+ <value>WMS layers updated</value>
+ </data>
<data name="icon_viewoptions_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_viewoptions_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="icon_invokescript" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_invokescript.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="applications_stack" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\applications-stack.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="PromptUseOffice2010Drivers" xml:space="preserve">
<value>Use Office 2010 Drivers? (these are 64-bit compatible)</value>
</data>
@@ -696,9 +734,6 @@
<data name="icon_pandown_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_pandown_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="image" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\image.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
<data name="TransparentName" xml:space="preserve">
<value>Transparent</value>
</data>
@@ -722,16 +757,12 @@
<data name="ExportNoCommandsSelected" xml:space="preserve">
<value>No commands selected. Nothing to export</value>
</data>
- <data name="LoadProcedureVersionExecutionNotSupported" xml:space="preserve">
- <value>This connection does not support executing this type of Load Procedure</value>
+ <data name="UnknownQueryMode" xml:space="preserve">
+ <value>Unknown query mode</value>
</data>
- <data name="SymbolTypeNotSupported" xml:space="preserve">
- <value>Only symbols of type "Mark" and "Font" are currently supported</value>
- <comment>A message that is displayed when the user attempts to modify an item with an unsupported type</comment>
+ <data name="FsPreview_GeometryPropertyNodeTooltip" xml:space="preserve">
+ <value>Name: {0}{7}Description: {1}{7}Geometry Types: {2}{7}Read Only: {3}{7}Has Elevation: {4}{7}Has Measure: {5}{7}Spatial Context: {6}</value>
</data>
- <data name="arrow-curve" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\arrow-curve.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
<data name="FdoConnectionStatus" xml:space="preserve">
<value>FDO Connection Status: {0}</value>
</data>
@@ -742,6 +773,9 @@
<value>Missing column "{0}"</value>
<comment>An error message that is displayed if the file is missing a required column</comment>
</data>
+ <data name="icon_zoomrect" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoomrect.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="InvalidColorComponent" xml:space="preserve">
<value>Invalid {0} color component {1} in line {2}</value>
<comment>An error message that is displayed if a color component is outside the [0-255] range.
@@ -768,11 +802,11 @@
<data name="icon_pan_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_pan_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="application-search-result" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\application-search-result.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="sql-join" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\sql-join.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="UnknownQueryMode" xml:space="preserve">
- <value>Unknown query mode</value>
+ <data name="NoSchemasInFeatureSource" xml:space="preserve">
+ <value>Feature Source has no schemas</value>
</data>
<data name="SymbolGraphicsPathPlaceholder" xml:space="preserve">
<value><path></value>
@@ -781,15 +815,15 @@
<value>All files ({0})</value>
<comment>The text displayed when browsing for all file types</comment>
</data>
- <data name="NotSessionBasedId" xml:space="preserve">
- <value>Resource ID must not be session based</value>
- </data>
<data name="NoActiveDataFile" xml:space="preserve">
<value>No active resource data file selected</value>
</data>
- <data name="edit" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\edit.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="PreviewQueryElapsed" xml:space="preserve">
+ <value>Preview Completed in {0}ms</value>
</data>
+ <data name="XmlDocIsValid" xml:space="preserve">
+ <value>Document is valid</value>
+ </data>
<data name="SelectFeatureClass" xml:space="preserve">
<value>Select Feature Class</value>
</data>
@@ -805,30 +839,30 @@
<data name="arrow-270" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\arrow-270.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="UnmanagedBrowserMultiSelectionNotAllowed" xml:space="preserve">
+ <value>Multiple selection is not allowed when SelectFoldersOnly is set to true</value>
+ </data>
<data name="AlternateNameMissing" xml:space="preserve">
<value>You must enter a alternate name, or remove the checkmark</value>
<comment>A message displayed when the user has not entered an alternate name for a resource</comment>
</data>
- <data name="arrow-090" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\arrow-090.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="globe--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\globe--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="globe--pencil" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\globe--pencil.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="DeleteCommand" xml:space="preserve">
+ <value>Delete Command</value>
</data>
- <data name="icon_selectwithin_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_selectwithin_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
<data name="icon_selectradius" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_selectradius.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="application-export" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\application-export.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_select_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_select_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="GeometryStyleComboDataset" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\GeometryStyleComboDataset.xml;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
</data>
- <data name="question" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\question.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_selectradius_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_selectradius_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="TitleError" xml:space="preserve">
<value>Error</value>
@@ -836,21 +870,21 @@
<data name="FindReplaceNothing" xml:space="preserve">
<value>Nothing to replace</value>
</data>
- <data name="icon_zoomin_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoomin_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_plotdwf_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_plotdwf_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="FilterAll" xml:space="preserve">
- <value>All File Types (*.*)|*.*</value>
+ <data name="ui_splitter_horizontal" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\ui-splitter-horizontal.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="Confirm" xml:space="preserve">
- <value>Confirm</value>
+ <data name="folder_horizontal" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\folder-horizontal.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="gear--pencil" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\gear--pencil.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
<data name="icon_ctxarrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_ctxarrow.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="EditWatermarkInstance" xml:space="preserve">
+ <value>Edit Watermark Instance</value>
+ </data>
<data name="ColorBrewer" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\ColorBrewer.csv;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
</data>
@@ -861,18 +895,12 @@
<data name="table" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\table.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="database--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\database--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="question" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\question.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_selectpolygon" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_selectpolygon.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="FindNothing" xml:space="preserve">
+ <value>Could not find specified string or end of document reached</value>
</data>
- <data name="icon_pandown" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_pandown.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
- <data name="icon_selectwithin" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_selectwithin.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
<data name="icon_panup" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_panup.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
@@ -885,18 +913,17 @@
<data name="FilterXml" xml:space="preserve">
<value>XML Files (.xml)|*.xml</value>
</data>
- <data name="HeaderFileMissing" xml:space="preserve">
- <value>The header file does not exist</value>
- <comment>A message displayed when the user selects a non-existing file</comment>
+ <data name="edit" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\edit.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_search" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_search.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_select_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_select_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="ConfirmDeleteResourceData" xml:space="preserve">
<value>Are you sure you want to delete this resource data?</value>
</data>
- <data name="TitleQuestion" xml:space="preserve">
- <value>Question</value>
+ <data name="globe--pencil" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\globe--pencil.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="MgCooker" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -913,15 +940,15 @@
WFv7wcxM6j8JZ9++bzL/aISV/Ja7mnNYqmY07YouQubg/l1NwG/XLb2y/7oFegAAAABJRU5ErkJggg==
</value>
</data>
- <data name="icon_restorecenter" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_restorecenter.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="QuestionResetFsOverrideList" xml:space="preserve">
+ <value>Reset Feature Source override list?</value>
</data>
<data name="SelectPackageFile" xml:space="preserve">
<value>Select the package file to edit</value>
<comment>The title of the dialog that the is used to pick the package file to edit</comment>
</data>
- <data name="icon_zoomprev" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoomprev.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="map" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\map.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="WarningMapExtentCalculation" xml:space="preserve">
<value>Could not transform extents of one or more layers in this Map Definition. These extents have not been factored into the computed result.</value>
@@ -933,8 +960,8 @@
<value>Invalid column name</value>
<comment>An error message that is displayed when the column selected does not exist</comment>
</data>
- <data name="SearchCmdDescription" xml:space="preserve">
- <value>Search Command</value>
+ <data name="SaveResourceFirst" xml:space="preserve">
+ <value>Please save this resource first</value>
</data>
<data name="FilterShp" xml:space="preserve">
<value>ESRI Shape File (*.shp)|*.shp</value>
@@ -943,21 +970,28 @@
<value>Add this item to the flyout? Clicking "No" will add it before the flyout</value>
<comment>A question to confirm whether dropping a menu item on a flyout will add it to the flyout or before the flyout</comment>
</data>
- <data name="LayerGroupConvertedToBaseLayerGroup" xml:space="preserve">
- <value>Layer Group ({0}) successfully converted to Base Layer Group ({1})</value>
+ <data name="XmlEditorCursorTemplate" xml:space="preserve">
+ <value>Line {0}, Column {1}</value>
</data>
<data name="FilterSdf" xml:space="preserve">
<value>Autodesk SDF (*.sdf)|*.sdf</value>
</data>
+ <data name="icon_zoom" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoom.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="SelectFolder" xml:space="preserve">
<value>Select Folder</value>
</data>
<data name="application--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\application--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="FsPostgreSql" xml:space="preserve">
- <value>PostgreSQL/PostGIS Feature Source</value>
+ <data name="InlineSymbolDefinition" xml:space="preserve">
+ <value>Inline Symbol Definition</value>
</data>
+ <data name="BetweenLabel" xml:space="preserve">
+ <value>Between {0} and {1}</value>
+ <comment>The label used for all "between" values in the graduated theme set</comment>
+ </data>
<data name="OdbcDriverExcel" xml:space="preserve">
<value>{Microsoft Excel Driver (*.xls)}</value>
</data>
@@ -970,9 +1004,6 @@
<data name="arrow-circle-135" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\arrow-circle-135.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="document_task" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\document-task.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
<data name="WidgetNameExists" xml:space="preserve">
<value>A widget named {0} already exists</value>
</data>
@@ -985,15 +1016,18 @@
<data name="icon_invokeurl" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_invokeurl.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="FunctionTooltip" xml:space="preserve">
- <value>Function: {1}({2})
-Description: {3}
-Returns: {0}</value>
- <comment>The tooltip displayed in the text editor when the cursor is over a function name</comment>
+ <data name="sql-join-right" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\sql-join-right.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="SQLQuery" xml:space="preserve">
- <value>SQL Query</value>
+ <data name="SelectSymbolLibraryFirst" xml:space="preserve">
+ <value>Please specify the symbol library first</value>
</data>
+ <data name="LayerGroupConvertedToBaseLayerGroup" xml:space="preserve">
+ <value>Layer Group ({0}) successfully converted to Base Layer Group ({1})</value>
+ </data>
+ <data name="icon_zoomnext_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoomnext_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="InvalidFieldCountError" xml:space="preserve">
<value>Invalid field count in line {0}</value>
<comment>An error message that is displayed if the file has an invalid field count</comment>
@@ -1015,14 +1049,14 @@
<value>All types</value>
<comment>The list entry that represents all resource types</comment>
</data>
- <data name="SelectSymbolLibraryFirst" xml:space="preserve">
- <value>Please specify the symbol library first</value>
+ <data name="TitleQuestion" xml:space="preserve">
+ <value>Question</value>
</data>
<data name="NoSiteService" xml:space="preserve">
<value>No site service available</value>
</data>
- <data name="OdbcDriverAccess64" xml:space="preserve">
- <value>{Microsoft Access Driver (*.mdb, *.accdb)}</value>
+ <data name="FsPreview_ClassNodeTooltip" xml:space="preserve">
+ <value>Name: {0}{3}Description: {1}{3}Geometry Property: {2}</value>
</data>
<data name="icon_forward" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_forward.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
@@ -1030,11 +1064,11 @@
<data name="InvokeUrlCmdDescription" xml:space="preserve">
<value>Invoke URL command</value>
</data>
- <data name="EditWatermarkInstance" xml:space="preserve">
- <value>Edit Watermark Instance</value>
+ <data name="icon_pandown" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_pandown.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_zoom_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoom_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="PropEnumNoValues" xml:space="preserve">
+ <value>Could not find possible values for enumerable property</value>
</data>
<data name="CheckGeometryFirst" xml:space="preserve">
<value>Ensure the Geometry box is checked</value>
@@ -1048,8 +1082,8 @@
<data name="icon_copy" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_copy.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="ruler1" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\ruler1.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="gear--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\gear--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="SelectWidget" xml:space="preserve">
<value>Select widget</value>
@@ -1061,9 +1095,8 @@
<data name="MoreColorsName" xml:space="preserve">
<value>More colors...</value>
</data>
- <data name="FiletypeMGP" xml:space="preserve">
- <value>MapGuide Packages ({0})</value>
- <comment>The text displayed when browsing for MGP files</comment>
+ <data name="icon_null" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_null.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="icon_panleft_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_panleft_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
@@ -1077,8 +1110,8 @@
<data name="OdbcNoMarkedFile" xml:space="preserve">
<value>Could not infer ODBC driver. No file specified</value>
</data>
- <data name="icon_zoom" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoom.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_zoomprev" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoomprev.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="exclamation" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\exclamation.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
@@ -1090,30 +1123,29 @@
<value>This resource already exists, continue with save?</value>
<comment>Question similar to the standard response of saving to an exisiting file using the regular save file dialog</comment>
</data>
- <data name="FontPreviewError" xml:space="preserve">
- <value>Cannot Preview Font "{0}"</value>
- <comment>An error message that is displayed when the rendering fails, using the specified font</comment>
+ <data name="FunctionTooltip" xml:space="preserve">
+ <value>Function: {1}({2})
+Description: {3}
+Returns: {0}</value>
+ <comment>The tooltip displayed in the text editor when the cursor is over a function name</comment>
</data>
<data name="icon_clearselect_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_clearselect_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_measure" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_measure.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="LoadProcedureVersionExecutionNotSupported" xml:space="preserve">
+ <value>This connection does not support executing this type of Load Procedure</value>
</data>
<data name="NoTransformationRequired" xml:space="preserve">
<value>No transformation required</value>
</data>
- <data name="IncompatibleConnection" xml:space="preserve">
- <value>This connection is not compatible</value>
+ <data name="StandardQuery" xml:space="preserve">
+ <value>Standard Query</value>
</data>
- <data name="TooMuchDataWarning" xml:space="preserve">
- <value>The selected column contains more than {0} different values.
-The calculated averages only accounts for the first {0} distinct values.</value>
- <comment>A warning message that is displayed if the dataset is too large</comment>
+ <data name="InvalidResourceIdFolder" xml:space="preserve">
+ <value>Must be valid resource id. Cannot be a folder</value>
</data>
- <data name="TooManyIndiviualValuesError" xml:space="preserve">
- <value>The selected column contains more than {0} different values, and thus cannot be used for theming with individual values</value>
- <comment>An error message that is displayed if the selected column has too many distinct values</comment>
+ <data name="globe--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\globe--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="OdbcDriverAccess" xml:space="preserve">
<value>{Microsoft Access Driver (*.mdb)}</value>
@@ -1124,33 +1156,33 @@
<data name="NoRasterClasses" xml:space="preserve">
<value>This feature source has no class definitions with raster properties</value>
</data>
- <data name="tick" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\tick.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_zoomin_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_zoomin_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="FilterDwf" xml:space="preserve">
- <value>Autodesk DWF (*.dwf)|*.dwf</value>
+ <data name="ErrorMapExtentCalculationFailed" xml:space="preserve">
+ <value>Could not transform extents of any layer in this Map Definition. You will have to specify the extents manually.</value>
</data>
<data name="document" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\document.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="map--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\map--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="SearchCmdDescription" xml:space="preserve">
+ <value>Search Command</value>
</data>
<data name="SpecifyMapForWebLayout" xml:space="preserve">
<value>Specify a map for this web layout</value>
</data>
- <data name="icon_invokescript_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_invokescript_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="application-search-result" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\application-search-result.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="sql-join-inner" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\sql-join-inner.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="PackageReadError" xml:space="preserve">
- <value>Failed to read package. Error message was: {0}</value>
- <comment>A message displayed when the package could not be read</comment>
+ <data name="InvalidValueError" xml:space="preserve">
+ <value>Invalid value</value>
+ <comment>An error message that is displayed when the entered value is invalid</comment>
</data>
- <data name="sql" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\sql.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="ColorPicker" xml:space="preserve">
+ <value>Color Picker ...</value>
</data>
<data name="LessThanLabel" xml:space="preserve">
<value>Less than {0}</value>
@@ -1162,8 +1194,8 @@
<data name="FsSqlServerSpatial" xml:space="preserve">
<value>SQL Server Spatial Feature Source</value>
</data>
- <data name="UnmanagedBrowserMultiSelectionNotAllowed" xml:space="preserve">
- <value>Multiple selection is not allowed when SelectFoldersOnly is set to true</value>
+ <data name="FilterDwf" xml:space="preserve">
+ <value>Autodesk DWF (*.dwf)|*.dwf</value>
</data>
<data name="NewFlyout" xml:space="preserve">
<value>New Flyout</value>
@@ -1171,11 +1203,13 @@
<data name="layers-stack-arrange-back" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\layers-stack-arrange-back.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="document--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\document--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="FontPreviewError" xml:space="preserve">
+ <value>Cannot Preview Font "{0}"</value>
+ <comment>An error message that is displayed when the rendering fails, using the specified font</comment>
</data>
- <data name="WmsLayersUpdated" xml:space="preserve">
- <value>WMS layers updated</value>
+ <data name="FiletypeMGP" xml:space="preserve">
+ <value>MapGuide Packages ({0})</value>
+ <comment>The text displayed when browsing for MGP files</comment>
</data>
<data name="plus-circle" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\plus-circle.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
@@ -1190,17 +1224,17 @@
<value>The folder must start with \"Library://\", do you want the starting folder to become:\n {0} ?</value>
<comment>A message that is displayed when the user has not entered a folder starting with Library://</comment>
</data>
- <data name="property" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\property.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="FilterAll" xml:space="preserve">
+ <value>All File Types (*.*)|*.*</value>
</data>
- <data name="SymbolGraphicsTextPlaceholder" xml:space="preserve">
- <value><text></value>
+ <data name="document_task" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\document-task.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="SelectLayerFirst" xml:space="preserve">
<value>Please select the layer first</value>
</data>
- <data name="application-import" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\application-import.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="icon_search_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_search_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="sum" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\sum.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
@@ -1209,11 +1243,11 @@
<value><Select column></value>
<comment>A placeholder message displayed when the user has not yet selected a column</comment>
</data>
- <data name="XmlDocIsValid" xml:space="preserve">
- <value>Document is valid</value>
+ <data name="icon_tasks" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_tasks.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_zoomnext_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoomnext_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="InvalidResourceIdNotSpecifiedType" xml:space="preserve">
+ <value>Invalid Resource Identifier. Not the specified type</value>
</data>
<data name="icon_select" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_select.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
@@ -1221,21 +1255,20 @@
<data name="icon_back" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_back.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="BetweenLabel" xml:space="preserve">
- <value>Between {0} and {1}</value>
- <comment>The label used for all "between" values in the graduated theme set</comment>
+ <data name="database--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\database--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="InvokeScriptCmdDescription" xml:space="preserve">
- <value>Invoke Script Command</value>
+ <data name="arrow-090" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\arrow-090.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="GeometryStyleComboDataset" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\GeometryStyleComboDataset.xml;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+ <data name="cross" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\cross.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="CommandTypesDataset" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\CommandTypesDataset.xml;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;utf-8</value>
</data>
- <data name="icon_selectradius_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_selectradius_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="arrow-curve" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\arrow-curve.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="edit-indent" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\edit-indent.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
@@ -1253,25 +1286,16 @@
<data name="icon_forward_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\icon_forward_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="icon_zoomselect_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoomselect_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="FsPostgreSql" xml:space="preserve">
+ <value>PostgreSQL/PostGIS Feature Source</value>
</data>
- <data name="icon_zoomrect" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\icon_zoomrect.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="SymbolGraphicsImagePlaceholder" xml:space="preserve">
+ <value><image></value>
</data>
<data name="FindEmptyString" xml:space="preserve">
<value>Cannot Find an Empty String</value>
</data>
- <data name="color" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\color.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="disk" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\disk.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="PromptRepairBrokenFeatureSource" xml:space="preserve">
- <value>The resource id {0} could not be found. You will now be prompted to select the correct feature source</value>
- </data>
- <data name="PreviewQueryElapsed" xml:space="preserve">
- <value>Preview Completed in {0}ms</value>
- </data>
- <data name="PreviewRecordCount" xml:space="preserve">
- <value>{0} results found</value>
- </data>
</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Editors/RepositoryIcons.cs
--- trunk/Tools/Maestro/Maestro.Editors/RepositoryIcons.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/RepositoryIcons.cs 2011-11-08 13:43:56 UTC (rev 6204)
@@ -0,0 +1,109 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using OSGeo.MapGuide.MaestroAPI;
+using System.Windows.Forms;
+namespace Maestro.Editors
+ /// <summary>
+ /// Image list helper class for components that display or interact with Repository resources
+ /// </summary>
+ public class RepositoryIcons
+ public const int RES_UNKNOWN = 0;
+ public const int RES_FEATURESOURCE = 1;
+ public const int RES_LAYERDEFINITION = 2;
+ public const int RES_MAPDEFINITION = 3;
+ public const int RES_WEBLAYOUT = 4;
+ public const int RES_SYMBOLLIBRARY = 5;
+ public const int RES_PRINTLAYOUT = 6;
+ public const int RES_DRAWINGSOURCE = 7;
+ public const int RES_APPLICATIONDEFINITION = 8;
+ public const int RES_SYMBOLDEFINITION = 9;
+ public const int RES_WATERMARK = 10;
+ public const int RES_LOADPROCEDURE = 11;
+ public const int RES_ROOT = 12;
+ public const int RES_FOLDER = 13;
+ public static int GetImageIndexForResourceType(ResourceTypes resType)
+ switch (resType)
+ case ResourceTypes.ApplicationDefinition:
+ return RES_APPLICATIONDEFINITION;
+ case ResourceTypes.DrawingSource:
+ return RES_DRAWINGSOURCE;
+ case ResourceTypes.FeatureSource:
+ return RES_FEATURESOURCE;
+ case ResourceTypes.Folder:
+ return RES_FOLDER;
+ case ResourceTypes.LayerDefinition:
+ return RES_LAYERDEFINITION;
+ case ResourceTypes.LoadProcedure:
+ return RES_LOADPROCEDURE;
+ case ResourceTypes.MapDefinition:
+ return RES_MAPDEFINITION;
+ case ResourceTypes.PrintLayout:
+ return RES_PRINTLAYOUT;
+ case ResourceTypes.SymbolDefinition:
+ return RES_SYMBOLDEFINITION;
+ case ResourceTypes.SymbolLibrary:
+ return RES_SYMBOLLIBRARY;
+ case ResourceTypes.WatermarkDefinition:
+ return RES_WATERMARK;
+ case ResourceTypes.WebLayout:
+ return RES_WEBLAYOUT;
+ default:
+ throw new ArgumentException();
+ public static ImageList CreateImageList()
+ var imgList = new ImageList();
+ PopulateImageList(imgList);
+ return imgList;
+ public static void PopulateImageList(ImageList imgList)
+ imgList.Images.Add(Properties.Resources.document);
+ imgList.Images.Add(Properties.Resources.database_share);
+ imgList.Images.Add(Properties.Resources.layer);
+ imgList.Images.Add(Properties.Resources.map);
+ imgList.Images.Add(Properties.Resources.application_browser);
+ imgList.Images.Add(Properties.Resources.images_stack);
+ imgList.Images.Add(Properties.Resources.printer);
+ imgList.Images.Add(Properties.Resources.blueprints);
+ imgList.Images.Add(Properties.Resources.applications_stack);
+ imgList.Images.Add(Properties.Resources.marker);
+ imgList.Images.Add(Properties.Resources.edit);
+ imgList.Images.Add(Properties.Resources.script__arrow);
+ imgList.Images.Add(Properties.Resources.server);
+ imgList.Images.Add(Properties.Resources.folder_horizontal);
Added: trunk/Tools/Maestro/Maestro.Editors/Resources/application-browser.png
(Binary files differ)
Property changes on: trunk/Tools/Maestro/Maestro.Editors/Resources/application-browser.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/Tools/Maestro/Maestro.Editors/Resources/applications-stack.png
Property changes on: trunk/Tools/Maestro/Maestro.Editors/Resources/applications-stack.png
Added: trunk/Tools/Maestro/Maestro.Editors/Resources/blueprints.png
Property changes on: trunk/Tools/Maestro/Maestro.Editors/Resources/blueprints.png
Added: trunk/Tools/Maestro/Maestro.Editors/Resources/database-share.png
Property changes on: trunk/Tools/Maestro/Maestro.Editors/Resources/database-share.png
Added: trunk/Tools/Maestro/Maestro.Editors/Resources/disk.png
Property changes on: trunk/Tools/Maestro/Maestro.Editors/Resources/disk.png
Added: trunk/Tools/Maestro/Maestro.Editors/Resources/images-stack.png
Property changes on: trunk/Tools/Maestro/Maestro.Editors/Resources/images-stack.png
Added: trunk/Tools/Maestro/Maestro.Editors/Resources/map.png
Property changes on: trunk/Tools/Maestro/Maestro.Editors/Resources/map.png
Added: trunk/Tools/Maestro/Maestro.Editors/Resources/printer.png
Property changes on: trunk/Tools/Maestro/Maestro.Editors/Resources/printer.png
Modified: trunk/Tools/Maestro/Maestro.Packaging/PackageBuilder.cs
--- trunk/Tools/Maestro/Maestro.Packaging/PackageBuilder.cs 2011-11-07 16:31:53 UTC (rev 6203)
+++ trunk/Tools/Maestro/Maestro.Packaging/PackageBuilder.cs 2011-11-08 13:43:56 UTC (rev 6204)
@@ -862,7 +862,7 @@
if (string.IsNullOrEmpty(ri.Headerpath))
- filemap.Add(new KeyValuePair<string, string>(headerpath, System.IO.Path.Combine(tempfolder, Guid.NewGuid().ToString())));
+ filemap.Add(new KeyValuePair<string, string>(headerpath, System.IO.Path.Combine(tempfolder, ri.GenerateUniqueName())));
using (System.IO.FileStream fs = new System.IO.FileStream(filemap[filemap.Count - 1].Value, System.IO.FileMode.CreateNew, System.IO.FileAccess.Write, System.IO.FileShare.None))
byte[] data = System.Text.Encoding.UTF8.GetBytes(DEFAULT_HEADER);
@@ -882,7 +882,7 @@
@@ -895,7 +895,7 @@
if (index < 0)
throw new Exception(string.Format(Properties.Resources.FileMissingError, ri.Headerpath));
Utility.CopyStream(zipfile.GetInputStream(index), fs);
@@ -906,7 +906,7 @@
if (index < 0)
throw new Exception(string.Format(Properties.Resources.FileMissingError, ri.Contentpath));
- filemap.Add(new KeyValuePair<string, string>(contentpath, System.IO.Path.Combine(tempfolder, Guid.NewGuid().ToString())));
+ filemap.Add(new KeyValuePair<string, string>(contentpath, System.IO.Path.Combine(tempfolder, ri.GenerateUniqueName())));
@@ -921,7 +921,10 @@
string targetpath = filebase + "_DATA_" + EncodeFilename(rdi.ResourceName);
if (rdi.EntryType == EntryTypeEnum.Added)
- filemap.Add(new KeyValuePair<string, string>(targetpath, System.IO.Path.Combine(tempfolder, Guid.NewGuid().ToString())));
+ var tempFilePath = System.IO.Path.Combine(tempfolder, ri.GenerateUniqueName());
+ filemap.Add(new KeyValuePair<string, string>(targetpath, tempFilePath));
+ if (File.Exists(rdi.Filename))
+ File.Copy(rdi.Filename, tempFilePath);
else
@@ -929,7 +932,7 @@
if (index < 0)
throw new Exception(string.Format(Properties.Resources.FileMissingError, rdi.Filename));
+ filemap.Add(new KeyValuePair<string, string>(targetpath, System.IO.Path.Combine(tempfolder, ri.GenerateUniqueName())));
@@ -991,6 +994,7 @@
manifest.Operations.Operation = new System.ComponentModel.BindingList<ResourcePackageManifestOperationsOperation>();
foreach (ResourceItem ri in items)
if (ri.IsFolder)
AddFolderResource(
@@ -1009,6 +1013,7 @@
insertEraseCommands);
foreach (ResourceDataItem rdi in ri.Items)
AddResourceData(
manifest,
ri.ResourcePath,
@@ -1017,7 +1022,9 @@
rdi.ResourceName,
RelativeName(rdi.Filename, tempfolder).Replace('\\', '/'),
new System.IO.FileInfo(filemap_lookup[rdi.Filename]).Length);
filemap.Add(new KeyValuePair<string, string>(System.IO.Path.Combine(tempfolder, "MgResourcePackageManifest.xml"), System.IO.Path.Combine(tempfolder, Guid.NewGuid().ToString())));
Modified: trunk/Tools/Maestro/Maestro.Packaging/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Packaging/Properties/Resources.Designer.cs 2011-11-07 16:31:53 UTC (rev 6203)
+++ trunk/Tools/Maestro/Maestro.Packaging/Properties/Resources.Designer.cs 2011-11-08 13:43:56 UTC (rev 6204)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:2.0.50727.4959
+// Runtime Version:2.0.50727.5448
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
@@ -61,6 +61,15 @@
/// <summary>
+ /// Looks up a localized string similar to You must enter a alternate name, or remove the checkmark.
+ /// </summary>
+ internal static string AlternateNameMissing {
+ get {
+ return ResourceManager.GetString("AlternateNameMissing", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Do you want to cancel?.
/// </summary>
internal static string CancelConfirmation {
@@ -70,6 +79,33 @@
/// <summary>
+ /// Looks up a localized string similar to The content file does not exist.
+ /// </summary>
+ internal static string ContentFileMissing {
+ get {
+ return ResourceManager.GetString("ContentFileMissing", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Do you want to remove the selected item?.
+ /// </summary>
+ internal static string DeleteConfirmation {
+ get {
+ return ResourceManager.GetString("DeleteConfirmation", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to An error occured while copying file: {0}.
+ /// </summary>
+ internal static string FileCopyError {
+ get {
+ return ResourceManager.GetString("FileCopyError", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Failed to find file {0} in archive.
/// </summary>
internal static string FileMissingError {
@@ -88,6 +124,51 @@
/// <summary>
+ /// Looks up a localized string similar to Failed to validate the filenames: {0}.
+ /// </summary>
+ internal static string FilenameValidationError {
+ get {
+ return ResourceManager.GetString("FilenameValidationError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to All files ({0}).
+ /// </summary>
+ internal static string FiletypeAll {
+ get {
+ return ResourceManager.GetString("FiletypeAll", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to MapGuide Packages ({0}).
+ /// </summary>
+ internal static string FiletypeMGP {
+ get {
+ return ResourceManager.GetString("FiletypeMGP", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Zip files ({0}).
+ /// </summary>
+ internal static string FiletypeZip {
+ get {
+ return ResourceManager.GetString("FiletypeZip", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to The header file does not exist.
+ /// </summary>
+ internal static string HeaderFileMissing {
+ get {
+ return ResourceManager.GetString("HeaderFileMissing", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Failed to locate file MgResourcePackageManifest.xml in zip file. Most likely the file is not a MapGuide package..
/// </summary>
internal static string InvalidPackageFileError {
@@ -97,6 +178,24 @@
/// <summary>
+ /// Looks up a localized string similar to New folder.
+ /// </summary>
+ internal static string NewFolder {
+ get {
+ return ResourceManager.GetString("NewFolder", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to An error occured while building package: {0}.
+ /// </summary>
+ internal static string PackageBuildError {
+ get {
+ return ResourceManager.GetString("PackageBuildError", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to {0} Package Operations Failed.
/// </summary>
internal static string PackageOperationsFailed {
@@ -250,6 +349,15 @@
/// <summary>
+ /// Looks up a localized string similar to Select the package file to edit.
+ /// </summary>
+ internal static string SelectPackageFile {
+ get {
+ return ResourceManager.GetString("SelectPackageFile", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Uploading Package.
/// </summary>
internal static string TitleUploading {
Modified: trunk/Tools/Maestro/Maestro.Packaging/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Packaging/Properties/Resources.resx 2011-11-07 16:31:53 UTC (rev 6203)
+++ trunk/Tools/Maestro/Maestro.Packaging/Properties/Resources.resx 2011-11-08 13:43:56 UTC (rev 6204)
@@ -117,10 +117,26 @@
<resheader name="writer">
<value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
+ <data name="AlternateNameMissing" xml:space="preserve">
+ <value>You must enter a alternate name, or remove the checkmark</value>
+ <comment>A message displayed when the user has not entered an alternate name for a resource</comment>
+ </data>
<data name="CancelConfirmation" xml:space="preserve">
<value>Do you want to cancel?</value>
<comment>A confirmation message displayed when the user presses the cancel button</comment>
</data>
+ <data name="ContentFileMissing" xml:space="preserve">
+ <value>The content file does not exist</value>
+ <comment>A message displayed when the user selects a non-existing file</comment>
+ </data>
+ <data name="DeleteConfirmation" xml:space="preserve">
+ <value>Do you want to remove the selected item?</value>
+ <comment>A confirmation message displayed when deleting a resource</comment>
+ </data>
+ <data name="FileCopyError" xml:space="preserve">
+ <value>An error occured while copying file: {0}</value>
+ <comment>A message displayed when a file copy fails</comment>
+ </data>
<data name="FileMissingError" xml:space="preserve">
<value>Failed to find file {0} in archive</value>
<comment>An error message that is displayed if a file is missing in a package</comment>
@@ -129,10 +145,38 @@
<value>Filename "{0}" is not relative to "{1}"</value>
<comment>An internal error that is displayed when a filename inconsistency is encountered</comment>
</data>
+ <data name="FilenameValidationError" xml:space="preserve">
+ <value>Failed to validate the filenames: {0}</value>
+ <comment>A message displayed when the user enters an invalid filename</comment>
+ </data>
+ <data name="FiletypeAll" xml:space="preserve">
+ <value>All files ({0})</value>
+ <comment>The text displayed when browsing for all file types</comment>
+ </data>
+ </data>
+ <data name="FiletypeZip" xml:space="preserve">
+ <value>Zip files ({0})</value>
+ <comment>The text displayed when browsing for zip files</comment>
+ </data>
+ <data name="HeaderFileMissing" xml:space="preserve">
+ <value>The header file does not exist</value>
+ </data>
<data name="InvalidPackageFileError" xml:space="preserve">
<value>Failed to locate file MgResourcePackageManifest.xml in zip file. Most likely the file is not a MapGuide package.</value>
<comment>An error message that is displayed if the package file is invalid</comment>
</data>
+ <data name="NewFolder" xml:space="preserve">
+ <value>New folder</value>
+ <comment>The default name of a new folder</comment>
+ </data>
+ <data name="PackageBuildError" xml:space="preserve">
+ <value>An error occured while building package: {0}</value>
+ <comment>A message displayed when the package creation fails</comment>
+ </data>
<data name="PackageOperationsFailed" xml:space="preserve">
<value>{0} Package Operations Failed</value>
</data>
@@ -196,6 +240,10 @@
<value>Awating server processing ...</value>
<comment>A message that is displayed after the file is uploaded, and the server restores the file</comment>
</data>
+ <data name="SelectPackageFile" xml:space="preserve">
+ <value>Select the package file to edit</value>
+ <comment>The title of the dialog that the is used to pick the package file to edit</comment>
+ </data>
<data name="TitleUploading" xml:space="preserve">
<value>Uploading Package</value>
</data>
Modified: trunk/Tools/Maestro/Maestro.Packaging/ResourceItem.cs
--- trunk/Tools/Maestro/Maestro.Packaging/ResourceItem.cs 2011-11-07 16:31:53 UTC (rev 6203)
+++ trunk/Tools/Maestro/Maestro.Packaging/ResourceItem.cs 2011-11-08 13:43:56 UTC (rev 6204)
@@ -140,5 +140,10 @@
get { return m_headerpath; }
set { m_headerpath = value; }
+ internal string GenerateUniqueName()
+ return this.ResourcePath.Replace("://", "_").Replace("/", "_").Replace(".", "_") + Guid.NewGuid().ToString();
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/CollapsiblePanel.cs
--- trunk/Tools/Maestro/Maestro.Shared.UI/CollapsiblePanel.cs 2011-11-07 16:31:53 UTC (rev 6203)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/CollapsiblePanel.cs 2011-11-08 13:43:56 UTC (rev 6204)
@@ -117,8 +117,8 @@
[Category("Collapsible Panel")]
public bool CanCollapse
- get { return btnCollapse.Visible; }
- set { btnCollapse.Visible = value; }
+ get { return btnCollapse.Visible && btnExpand.Visible; }
+ set { btnCollapse.Visible = btnExpand.Visible = value; }
private bool _collapsed;
More information about the mapguide-commits
