[mapguide-commits] r6209 -
trunk/Tools/Maestro/Maestro.Editors/Common
svn_mapguide at osgeo.org
Tue Nov 8 10:08:40 EST 2011
Author: jng
Date: 2011-11-08 07:08:40 -0800 (Tue, 08 Nov 2011)
New Revision: 6209
trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.resx
#1829: Support deleting of multiple resource data items
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.Designer.cs 2011-11-08 14:57:45 UTC (rev 6208)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.Designer.cs 2011-11-08 15:08:40 UTC (rev 6209)
@@ -82,7 +82,6 @@
this.lstDataFiles.AllowDrop = true;
resources.ApplyResources(this.lstDataFiles, "lstDataFiles");
- this.lstDataFiles.MultiSelect = false;
this.lstDataFiles.Name = "lstDataFiles";
this.lstDataFiles.ShowItemToolTips = true;
this.lstDataFiles.SmallImageList = this.imgIcons;
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.cs 2011-11-08 14:57:45 UTC (rev 6208)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.cs 2011-11-08 15:08:40 UTC (rev 6209)
@@ -55,10 +55,11 @@
private void EvaluateCommands()
+ var items = this.SelectedItems;
btnAdd.Enabled = (_edSvc != null);
- btnDelete.Enabled = (_edSvc != null && this.SelectedItem != null);
- btnDownload.Enabled = (_edSvc != null && this.SelectedItem != null);
- btnMark.Enabled = (this.SelectedItem != null);
+ btnDelete.Enabled = (_edSvc != null && items.Length > 0);
+ btnDownload.Enabled = (_edSvc != null && items.Length == 1);
+ btnMark.Enabled = (items.Length == 1);
private IEditorService _edSvc;
@@ -77,6 +78,19 @@
+ private ResourceDataListResourceData[] SelectedItems
+ get
+ var items = new List<ResourceDataListResourceData>();
+ foreach(ListViewItem selItem in lstDataFiles.SelectedItems)
+ items.Add(selItem.Tag as ResourceDataListResourceData);
+ return items.ToArray();
/// <summary>
/// Raises the <see cref="E:System.Windows.Forms.UserControl.Load"/> event.
/// </summary>
@@ -202,8 +216,8 @@
private void btnDelete_Click(object sender, EventArgs e)
- var item = this.SelectedItem;
- if (item != null)
+ if (items.Length > 0)
if (MessageBox.Show(Properties.Resources.ConfirmDeleteResourceData, Properties.Resources.Confirm, MessageBoxButtons.YesNo) == DialogResult.No)
return;
@@ -212,10 +226,13 @@
using (new WaitCursor(this))
- //_edSvc.RemoveResourceData(item.Name);
- IResource res = _edSvc.GetEditedResource();
- res.DeleteResourceData(item.Name);
- _data.Remove(item);
+ foreach (var item in items)
+ //_edSvc.RemoveResourceData(item.Name);
+ IResource res = _edSvc.GetEditedResource();
+ res.DeleteResourceData(item.Name);
+ _data.Remove(item);
BindResourceList();
OnDataListChanged();
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.resx 2011-11-08 14:57:45 UTC (rev 6208)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.resx 2011-11-08 15:08:40 UTC (rev 6209)
@@ -118,7 +118,7 @@
<value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
<metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>17, 17</value>
+ <value>0, 0</value>
</metadata>
<assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="btnAdd.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -203,7 +203,7 @@
AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAAK
- CAAAAk1TRnQBSQFMAwEBAAEwAQABMAEAARABAAEQAQAE/wEJAQAI/wFCAU0BNgEEBgABNgEEAgABKAMA
+ CAAAAk1TRnQBSQFMAwEBAAE4AQABOAEAARABAAEQAQAE/wEJAQAI/wFCAU0BNgEEBgABNgEEAgABKAMA
AUADAAEQAwABAQEAAQgGAAEEGAABgAIAAYADAAKAAQABgAMAAYABAAGAAQACgAIAA8ABAAHAAdwBwAEA
AfABygGmAQABMwUAATMBAAEzAQABMwEAAjMCAAMWAQADHAEAAyIBAAMpAQADVQEAA00BAANCAQADOQEA
AYABfAH/AQACUAH/AQABkwEAAdYBAAH/AewBzAEAAcYB1gHvAQAB1gLnAQABkAGpAa0CAAH/ATMDAAFm
More information about the mapguide-commits
