[mapguide-commits] r6212 - in trunk/Tools/Maestro: . Maestro
Maestro.AddIn.Local/UI Maestro.Login Properties
svn_mapguide at osgeo.org
Tue Nov 8 11:09:42 EST 2011
Author: jng
Date: 2011-11-08 08:09:42 -0800 (Tue, 08 Nov 2011)
New Revision: 6212
trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.cs
trunk/Tools/Maestro/Maestro.Login/LocalLoginCtrl.cs
trunk/Tools/Maestro/Maestro.Login/LocalNativeLoginCtrl.cs
trunk/Tools/Maestro/Maestro/changelog.txt
trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs
trunk/Tools/Maestro/build.bat
Prep 4.0 RC1 release
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt 2011-11-08 15:41:32 UTC (rev 6211)
+++ trunk/Tools/Maestro/Maestro/changelog.txt 2011-11-08 16:09:42 UTC (rev 6212)
@@ -1,4 +1,27 @@
-4.0 beta 2
+4.0 RC1
+ - A warning will now be displayed when attempting to preview a map definition with tiled layers in Local Connection Mode (because the mg-desktop viewer has not implemented support for this yet)
+ - Failed non-transactional package loading operations now include a corresponding exception as part of the results display.
+ - Support for deleting multiple resource data items
+ - New context menu command for editing raw document/header XML
+ - Document tabs now have a context menu for mass tab closure.
+ - Updated mg-desktop binaries for Local Connection mode.
+ - Re-instated the Package editor, which has been missing since Maestro 2.1
+ - Feature Source Preview now shows elapsed query time for executed queries.
+ - MgCooker windows application no longer closes after a successful tiling run.
+ - Improved Color editor field support. Can now use either FDO expressions or pick a color.
+ - Theme Generation will now use the UNIQUE() aggregate function first instead of raw spinning a feature reader for distinct values.
+ - Fix: Non-Transactional package loading will now skip any SETRESOURCE operations with no content
+ - Fix: Layer Property display cannot be re-ordered in Layer Definition editor
+ - Fix: Fields for built-in WebLayout commands are now editable
+ - Fix: Search layer display in WebLayout editor
+ - Fix: SHP Feature Source editor does not properly handle multiple embedded SHP files.
+ - Fix: Duplicate repository items being displayed in Site Explorer
+ - Fix: Min/Max Scale display in Layer Definition editor
+ - Fix: Error re-ordering style rules in Layer Definition editor
+4.0 beta 2
- Support for non-transactional package loading w/ ability to retry failed operations
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.cs 2011-11-08 15:41:32 UTC (rev 6211)
+++ trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.cs 2011-11-08 16:09:42 UTC (rev 6212)
@@ -53,6 +53,19 @@
public void Init(MgResourceIdentifier mapResId)
_map = new MgdMap(mapResId);
+ var groups = _map.GetLayerGroups();
+ if (groups != null && groups.GetCount() > 0)
+ for (int i = 0; i < groups.GetCount(); i++)
+ var grp = groups.GetItem(i);
+ if (grp.LayerGroupType == MgLayerGroupType.BaseMap)
+ MessageBox.Show("WARNING: The Map Preview does not yet support previews of maps with tiled layers. You will only see un-tiled ones");
+ break;
viewer.Init(_map);
viewer.RefreshMap();
Modified: trunk/Tools/Maestro/Maestro.Login/LocalLoginCtrl.cs
--- trunk/Tools/Maestro/Maestro.Login/LocalLoginCtrl.cs 2011-11-08 15:41:32 UTC (rev 6211)
+++ trunk/Tools/Maestro/Maestro.Login/LocalLoginCtrl.cs 2011-11-08 16:09:42 UTC (rev 6212)
@@ -40,7 +40,8 @@
using (var open = DialogFactory.OpenFile())
- open.RestoreDirectory = true;
+ open.InitialDirectory = Application.StartupPath;
+ open.RestoreDirectory = true;
open.Filter = "*.ini|*.ini";
if (open.ShowDialog() == DialogResult.OK)
Modified: trunk/Tools/Maestro/Maestro.Login/LocalNativeLoginCtrl.cs
--- trunk/Tools/Maestro/Maestro.Login/LocalNativeLoginCtrl.cs 2011-11-08 15:41:32 UTC (rev 6211)
+++ trunk/Tools/Maestro/Maestro.Login/LocalNativeLoginCtrl.cs 2011-11-08 16:09:42 UTC (rev 6212)
@@ -84,6 +84,7 @@
using (var dlg = DialogFactory.OpenFile())
+ dlg.InitialDirectory = Application.StartupPath;
//WTF does this default to false??? Does MS not realize that changing directories
//via this dialog absolutely screws up file/assembly loading from relative paths?
dlg.RestoreDirectory = true;
Modified: trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs
--- trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs 2011-11-08 15:41:32 UTC (rev 6211)
+++ trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs 2011-11-08 16:09:42 UTC (rev 6212)
@@ -35,5 +35,5 @@
// You can specify all the values or you can default the Build and Revision Numbers
// by using the '*' as shown below:
// [assembly: AssemblyVersion("1.0.*")]
-[assembly: AssemblyVersion("4.0.0.6143")]
-[assembly: AssemblyFileVersion("4.0.0.6143")]
+[assembly: AssemblyVersion("4.0.0.6212")]
+[assembly: AssemblyFileVersion("4.0.0.6212")]
Modified: trunk/Tools/Maestro/build.bat
--- trunk/Tools/Maestro/build.bat 2011-11-08 15:41:32 UTC (rev 6211)
+++ trunk/Tools/Maestro/build.bat 2011-11-08 16:09:42 UTC (rev 6212)
@@ -2,7 +2,7 @@
SET TYPEACTION=build
SET TYPEBUILD=Release
SET PLATFORM=Any CPU
-SET RELEASE_VERSION=4.0b2
+SET RELEASE_VERSION=4.0rc1
SET OLDPATH=%PATH%
SET PATH=%PATH%;%CD%\Thirdparty\NSIS;C:\Windows\Microsoft.NET\Framework\v3.5
SET SLNDIR=%CD%
More information about the mapguide-commits
