[mapguide-commits] r6229 - in trunk/Tools/Maestro:
OSGeo.MapGuide.MaestroAPI/Mapping SDK/SamplesWeb/SamplesWeb/Tasks
svn_mapguide at osgeo.org
Wed Nov 16 09:34:36 EST 2011
Author: jng
Date: 2011-11-16 06:34:35 -0800 (Wed, 16 Nov 2011)
New Revision: 6229
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/Collections.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapGroup.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.cs
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/FeatureInfo.aspx.cs
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/SetSelectedFeatures.aspx.cs
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleGroupVisibility.aspx.cs
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleLayerVisibility.aspx.cs
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleParcelsLayer.aspx.cs
Some post-#1852 API changes:
- Make public ctor for RuntimeMapLayer and RuntimeMapGroup
- Add a IndexOf(TKey) method for KeyValueCollection<TKey, TValue>
- Make RuntimeMapLayerCollection.GetByObjectId() public
- Update the SDK web sample to reflect proper usage, and update/remove usage of any deprecated APIs
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/Collections.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/Collections.cs 2011-11-16 13:48:35 UTC (rev 6228)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/Collections.cs 2011-11-16 14:34:35 UTC (rev 6229)
@@ -62,6 +62,19 @@
/// <summary>
+ /// Determines the index of a specific key in the collection
+ /// </summary>
+ /// <param name="key">The key of the object to locate in the collection</param>
+ /// <returns>
+ /// The index of <paramref name="key"/> if found in the list; otherwise, -1.
+ /// </returns>
+ public int IndexOf(TKey key)
+ var item = this[key];
+ return IndexOf(item);
+ /// <summary>
/// Inserts an item to the <see cref="T:System.Collections.Generic.IList`1"/> at the specified index.
/// </summary>
/// <param name="index">The zero-based index at which <paramref name="item"/> should be inserted.</param>
@@ -434,7 +447,12 @@
return value.Name;
- internal RuntimeMapLayer GetByObjectId(string id)
+ /// <summary>
+ /// Gets a runtime map layer by its object id.
+ /// </summary>
+ /// <param name="id">The object id.</param>
+ /// <returns></returns>
+ public RuntimeMapLayer GetByObjectId(string id)
return _layerIdMap.ContainsKey(id) ? _layerIdMap[id] : null;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2011-11-16 13:48:35 UTC (rev 6228)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2011-11-16 14:34:35 UTC (rev 6229)
@@ -1033,6 +1033,7 @@
/// <param name="layerDefinitionId"></param>
/// <param name="group"></param>
+ [Obsolete("Use RuntimeMapLayer constructor")]
public RuntimeMapLayer CreateLayer(string layerDefinitionId, RuntimeMapGroup group)
ILayerDefinition ldf = GetLayerDefinition(layerDefinitionId);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapGroup.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapGroup.cs 2011-11-16 13:48:35 UTC (rev 6228)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapGroup.cs 2011-11-16 14:34:35 UTC (rev 6229)
@@ -42,7 +42,7 @@
this.ObjectId = Guid.NewGuid().ToString();
- internal RuntimeMapGroup(RuntimeMap map, string name)
+ public RuntimeMapGroup(RuntimeMap map, string name)
: this()
this.Parent = map;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs 2011-11-16 13:48:35 UTC (rev 6228)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs 2011-11-16 14:34:35 UTC (rev 6229)
@@ -80,7 +80,7 @@
this.Group = string.Empty;
- internal RuntimeMapLayer(RuntimeMap parent, ILayerDefinition ldf)
+ public RuntimeMapLayer(RuntimeMap parent, ILayerDefinition ldf)
: this(parent)
Check.NotNull(ldf, "ldf");
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.cs 2011-11-16 13:48:35 UTC (rev 6228)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.cs 2011-11-16 14:34:35 UTC (rev 6229)
@@ -53,17 +53,19 @@
RuntimeMap rtMap = mpSvc.OpenMap(rtMapId);
- RuntimeMapLayer tracks = rtMap.GetLayerByName("Tracks");
+ RuntimeMapLayer tracks = rtMap.Layers["Tracks"];
if (tracks != null)
lblMessage.Text = "Tracks layer already added";
else
- RuntimeMapGroup group = rtMap.GetGroupByName("Transportation");
+ string groupName = "Transportation";
+ RuntimeMapGroup group = rtMap.Groups[groupName];
if (group == null)
- group = rtMap.AddGroup("Transportation");
+ group = new RuntimeMapGroup(rtMap, groupName);
+ rtMap.Groups.Add(group);
throw new Exception("Layer group not found");
@@ -79,8 +81,10 @@
CreateTracksLayer(conn, fsId, layerId);
- RuntimeMapLayer layer = rtMap.CreateLayer(layerId, group);
+ ILayerDefinition layerDef = (ILayerDefinition)conn.ResourceService.GetResource(layerId);
+ RuntimeMapLayer layer = new RuntimeMapLayer(rtMap, layerDef);
+ layer.Group = groupName;
layer.LegendLabel = "Tracks";
layer.ShowInLegend = true;
layer.ExpandInLegend = true;
@@ -92,8 +96,8 @@
//So for a layer to be drawn above something else, its draw order must be
//less than that particular layer.
- int index = rtMap.IndexOfLayer("Districts");
- rtMap.InsertLayer(index, layer);
+ int index = rtMap.Layers.IndexOf("Districts");
+ rtMap.Layers.Insert(index, layer);
rtMap.Save();
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/FeatureInfo.aspx.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/FeatureInfo.aspx.cs 2011-11-16 13:48:35 UTC (rev 6228)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/FeatureInfo.aspx.cs 2011-11-16 14:34:35 UTC (rev 6229)
@@ -54,7 +54,7 @@
string rtMapId = "Session:" + conn.SessionID + "//" + mapName + ".Map";
- RuntimeMapLayer layer = rtMap.GetLayerByObjectId(layerId);
+ RuntimeMapLayer layer = rtMap.Layers.GetByObjectId(layerId);
//The values returned are in the same order as the array from the IdentityProperties
object[] values = layer.ParseSelectionValues(id);
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/SetSelectedFeatures.aspx.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/SetSelectedFeatures.aspx.cs 2011-11-16 13:48:35 UTC (rev 6228)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/SetSelectedFeatures.aspx.cs 2011-11-16 14:34:35 UTC (rev 6229)
@@ -77,7 +77,7 @@
//Get the selected layer
- RuntimeMapLayer rtLayer = rtMap.GetLayerByObjectId(ddlLayers.SelectedValue);
+ RuntimeMapLayer rtLayer = rtMap.Layers.GetByObjectId(ddlLayers.SelectedValue);
//Query using the user filter
IFeatureReader reader = conn.FeatureService.QueryFeatureSource(
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleGroupVisibility.aspx.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleGroupVisibility.aspx.cs 2011-11-16 13:48:35 UTC (rev 6228)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleGroupVisibility.aspx.cs 2011-11-16 14:34:35 UTC (rev 6229)
@@ -49,7 +49,7 @@
- RuntimeMapGroup group = rtMap.GetGroupByName(Request.Params["GROUPNAME"]);
+ RuntimeMapGroup group = rtMap.Groups[Request.Params["GROUPNAME"]];
if (group != null)
group.Visible = !group.Visible;
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleLayerVisibility.aspx.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleLayerVisibility.aspx.cs 2011-11-16 13:48:35 UTC (rev 6228)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleLayerVisibility.aspx.cs 2011-11-16 14:34:35 UTC (rev 6229)
@@ -49,7 +49,7 @@
- RuntimeMapLayer layer = rtMap.GetLayerByName(Request.Params["LAYERNAME"]);
+ RuntimeMapLayer layer = rtMap.Layers[Request.Params["LAYERNAME"]];
if (layer != null)
layer.Visible = !layer.Visible;
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleParcelsLayer.aspx.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleParcelsLayer.aspx.cs 2011-11-16 13:48:35 UTC (rev 6228)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleParcelsLayer.aspx.cs 2011-11-16 14:34:35 UTC (rev 6229)
@@ -31,6 +31,7 @@
using OSGeo.MapGuide.MaestroAPI.Services;
using OSGeo.MapGuide.MaestroAPI.Mapping;
using System.Text;
+using OSGeo.MapGuide.ObjectModels.LayerDefinition;
namespace SamplesWeb.Tasks
@@ -50,10 +51,10 @@
- RuntimeMapLayer parcels = rtMap.GetLayerByName("Parcels");
+ RuntimeMapLayer parcels = rtMap.Layers["Parcels"];
if (parcels != null)
- rtMap.RemoveLayer(parcels);
+ rtMap.Layers.Remove(parcels);
rtMap.Save();
@@ -66,15 +67,19 @@
else
- RuntimeMapGroup group = rtMap.GetGroupByName("Municipal");
+ string groupName = "Municipal";
if (group == null)
- group = rtMap.AddGroup("Municipal");
- RuntimeMapLayer layer = rtMap.CreateLayer("Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition", group);
+ ILayerDefinition layerDef = (ILayerDefinition)conn.ResourceService.GetResource("Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition");
+ layer.Group = group.Name;
layer.LegendLabel = "Parcels";
@@ -86,8 +91,8 @@
- int index = rtMap.IndexOfLayer("Islands");
+ int index = rtMap.Layers.IndexOf("Islands");
rtMap.Save();
More information about the mapguide-commits
