[mapguide-commits] r6243 - in trunk/Tools/Maestro: MaestroAPITests
OSGeo.MapGuide.MaestroAPI/Services OSGeo.MapGuide.MaestroAPI.Http
svn_mapguide at osgeo.org
Tue Nov 22 08:55:27 EST 2011
Author: jng
Date: 2011-11-22 05:55:27 -0800 (Tue, 22 Nov 2011)
New Revision: 6243
trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs
#1860: The GetLegendImage() API is already implemented. It just wasn't accessible through any public interface. This submission exposes this method through the IMappingService interface. A unit test has been added to exercise this API.
Modified: trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs 2011-11-22 07:50:47 UTC (rev 6242)
+++ trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs 2011-11-22 13:55:27 UTC (rev 6243)
@@ -460,6 +460,46 @@
#endregion
+ public virtual void TestLegendIconRendering()
+ var resSvc = _conn.ResourceService;
+ var mapSvc = _conn.GetService((int)ServiceType.Mapping) as IMappingService;
+ Assert.NotNull(mapSvc);
+ var mdf = resSvc.GetResource("Library://UnitTests/Maps/Sheboygan.MapDefinition") as IMapDefinition;
+ Assert.NotNull(mdf);
+ //FIXME: We have a problem. Can we calculate this value without MgCoordinateSystem and just using the WKT?
+ //The answer to this will answer whether we can actually support the Rendering Service API over http
+ //using pure client-side runtime maps
+ //The hard-coded value here was the output of MgCoordinateSystem.ConvertCoordinateSystemUnitsToMeters(1.0)
+ //for this particular map.
+ double metersPerUnit = 111319.490793274;
+ var cs = CoordinateSystemBase.Create(mdf.CoordinateSystem);
+ metersPerUnit = cs.MetersPerUnitX;
+ Trace.TraceInformation("Using MPU of: {0}", metersPerUnit);
+ var mid = "Session:" + _conn.SessionID + "//TestLegendIconRendering.Map";
+ var map = mapSvc.CreateMap(mid, mdf, metersPerUnit);
+ map.ViewScale = 12000;
+ map.DisplayWidth = 1024;
+ map.DisplayHeight = 1024;
+ map.DisplayDpi = 96;
+ //Doesn't exist yet because save isn't called
+ Assert.IsTrue(!resSvc.ResourceExists(mid));
+ map.Save();
+ int counter = 0;
+ foreach (var layer in map.Layers)
+ var icon = mapSvc.GetLegendImage(map.ViewScale, layer.LayerDefinitionID, -1, -1);
+ icon.Save("TestLegendIconRendering_" + counter + ".png");
+ counter++;
public virtual void TestRender12k()
//Render a map of sheboygan at 12k
@@ -989,6 +1029,12 @@
[Test]
+ public override void TestLegendIconRendering()
+ base.TestLegendIconRendering();
+ [Test]
public override void TestMapManipulation()
base.TestMapManipulation();
@@ -1055,6 +1101,12 @@
[Test]
+ [Test]
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs 2011-11-22 07:50:47 UTC (rev 6242)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs 2011-11-22 13:55:27 UTC (rev 6243)
@@ -228,5 +228,15 @@
/// <param name="format"></param>
/// <returns></returns>
System.IO.Stream RenderMapLegend(RuntimeMap map, int width, int height, Color backgroundColor, string format);
+ /// <summary>
+ /// Renders a minature bitmap of the layers style
+ /// </summary>
+ /// <param name="scale">The scale for the bitmap to match</param>
+ /// <param name="layerdefinition">The layer definition resource id</param>
+ /// <param name="themeIndex">If the layer is themed, this gives the theme index, otherwise set to 0</param>
+ /// <param name="type">The geometry type, 1 for point, 2 for line, 3 for area, 4 for composite</param>
+ /// <returns>The minature bitmap</returns>
+ System.Drawing.Image GetLegendImage(double scale, string layerdefinition, int themeIndex, int type);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2011-11-22 07:50:47 UTC (rev 6242)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2011-11-22 13:55:27 UTC (rev 6243)
@@ -1298,7 +1298,6 @@
return new System.Drawing.Bitmap(this.OpenRead(param));
/// <summary>
/// Upload a MapGuide Package file to the server
/// </summary>
More information about the mapguide-commits
