[mapguide-commits] r6249 - in trunk/Tools/Maestro:
OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/Services
OSGeo.MapGuide.MaestroAPI.Http OSGeo.MapGuide.MaestroAPI.Native
svn_mapguide at osgeo.org
Thu Nov 24 09:32:43 EST 2011
Author: jng
Date: 2011-11-24 06:32:43 -0800 (Thu, 24 Nov 2011)
New Revision: 6249
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/MgServerConnectionBase.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs
Re-introduce QueryMapFeatures to IMappingService. The implementation is a direct copy/paste from Maestro 2.1
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/MgServerConnectionBase.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/MgServerConnectionBase.cs 2011-11-23 14:56:48 UTC (rev 6248)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/MgServerConnectionBase.cs 2011-11-24 14:32:43 UTC (rev 6249)
@@ -146,6 +146,29 @@
#region Rendering
/// <summary>
+ /// Selects features from a runtime map, returning a selection Xml.
+ /// </summary>
+ /// <param name="runtimeMapName">The map to query. NOT a resourceID, only the map name!</param>
+ /// <param name="wkt">The WKT of the geometry to query with (always uses intersection)</param>
+ /// <param name="persist">True if the selection should be saved in the runtime map, false otherwise.</param>
+ /// <returns>The selection Xml, or an empty string if there were no data.</returns>
+ public string QueryMapFeatures(string runtimeMapName, string wkt, bool persist)
+ return QueryMapFeatures(runtimeMapName, wkt, persist, QueryMapFeaturesLayerAttributes.Default, false);
+ /// <summary>
+ /// </summary>
+ /// <param name="attributes">The type of layer to include in the query</param>
+ /// <param name="raw">True if the result should contain the tooltip and link info</param>
+ abstract public string QueryMapFeatures(string runtimeMapName, string wkt, bool persist, QueryMapFeaturesLayerAttributes attributes, bool raw);
+ /// <summary>
/// Renders a minature bitmap of the layers style
/// </summary>
/// <param name="scale">The scale for the bitmap to match</param>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs 2011-11-23 14:56:48 UTC (rev 6248)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs 2011-11-24 14:32:43 UTC (rev 6249)
@@ -238,5 +238,25 @@
/// <param name="type">The geometry type, 1 for point, 2 for line, 3 for area, 4 for composite</param>
/// <returns>The minature bitmap</returns>
System.Drawing.Image GetLegendImage(double scale, string layerdefinition, int themeIndex, int type);
+ /// <summary>
+ /// </summary>
+ string QueryMapFeatures(string runtimeMapName, string wkt, bool persist, QueryMapFeaturesLayerAttributes attributes, bool raw);
+ /// <summary>
+ /// </summary>
+ string QueryMapFeatures(string runtimeMapName, string wkt, bool persist);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2011-11-23 14:56:48 UTC (rev 6248)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2011-11-24 14:32:43 UTC (rev 6249)
@@ -1710,6 +1710,48 @@
+ public override string QueryMapFeatures(string runtimeMapName, string wkt, bool persist, QueryMapFeaturesLayerAttributes attributes, bool raw)
+ //The request may execeed the url limit of the server, when large geometries
+ System.IO.MemoryStream ms = new System.IO.MemoryStream();
+ System.Net.WebRequest req = m_reqBuilder.QueryMapFeatures(runtimeMapName, persist, wkt, ms, attributes);
+ req.Timeout = 200 * 1000;
+ ms.Position = 0;
+ using (System.IO.Stream rs = req.GetRequestStream())
+ Utility.CopyStream(ms, rs);
+ rs.Flush();
+ System.Xml.XmlDocument doc = new System.Xml.XmlDocument();
+#if DEBUG
+ System.IO.MemoryStream xms = new System.IO.MemoryStream();
+ Utility.CopyStream(req.GetResponse().GetResponseStream(), xms);
+ xms.Position = 0;
+ string f = System.Text.Encoding.UTF8.GetString(xms.ToArray());
+ if (raw)
+ return f;
+ xms.Position = 0;
+ doc.Load(xms);
+#else
+ if (raw)
+ return System.Text.Encoding.UTF8.GetString(xms.ToArray());
+ doc.Load(req.GetResponse().GetResponseStream());
+#endif
+ if (doc.SelectSingleNode("FeatureInformation/FeatureSet") != null && doc["FeatureInformation"]["FeatureSet"].ChildNodes.Count > 0)
+ return "<FeatureSet>" + doc["FeatureInformation"]["FeatureSet"].InnerXml + "</FeatureSet>";
+ else
+ return "";
public override string[] GetSchemas(string resourceId)
var req = m_reqBuilder.GetSchemas(resourceId);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs 2011-11-23 14:56:48 UTC (rev 6248)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs 2011-11-24 14:32:43 UTC (rev 6249)
@@ -1193,5 +1193,36 @@
LogMethodCall("MgDrawingService::GetSectionResource", true, resourceID, resourceName);
return res;
+ MgRenderingService rs = this.Connection.CreateService(MgServiceType.RenderingService) as MgRenderingService;
+ MgResourceService res = this.Connection.CreateService(MgServiceType.ResourceService) as MgResourceService;
+ MgMap map = new MgMap();
+ string mapname = runtimeMapName.IndexOf(":") > 0 ? new ResourceIdentifier(runtimeMapName).Path : runtimeMapName;
+ map.Open(res, mapname);
+ MgWktReaderWriter r = new MgWktReaderWriter();
+ MgFeatureInformation info = rs.QueryFeatures(map, null, r.Read(wkt), (int)MgFeatureSpatialOperations.Intersects, "", -1, (int)attributes);
+ using (var ms = new MemoryStream())
+ using (var stream = Utility.MgStreamToNetStream(info, info.GetType().GetMethod("ToXml"), null))
+ MaestroAPI.Utility.CopyStream(stream, ms);
+ ms.Position = 0L;
+ string xml = System.Text.Encoding.UTF8.GetString(ms.ToArray()).Trim();
+ if (persist)
+ MgSelection sel = new MgSelection(map, xml);
+ sel.Save(res, mapname);
+ return xml;
More information about the mapguide-commits
