[mapguide-commits] r6256 - in trunk/Tools/Maestro/Maestro.Editors: LayerDefinition/Vector Properties
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Nov 28 23:38:32 EST 2011
Author: jng
Date: 2011-11-28 20:38:32 -0800 (Mon, 28 Nov 2011)
New Revision: 6256
   trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.cs
   trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
#1848: Alert to user if they picked an empty feature source when creating a new vector layer definition
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.cs	2011-11-29 03:58:05 UTC (rev 6255)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.cs	2011-11-29 04:38:32 UTC (rev 6256)
@@ -109,11 +109,42 @@
         private void txtFeatureSource_TextChanged(object sender, EventArgs e)
+            if (string.IsNullOrEmpty(txtFeatureSource.Text))
+                return;
             _cachedDesc = _edsvc.FeatureService.DescribeFeatureSource(txtFeatureSource.Text);
             if (string.IsNullOrEmpty(txtFeatureClass.Text))
-                SetFeatureClass(_cachedDesc.Schemas[0].Classes[0]);
+                //This feature source must have at least one class definition with a geometry property
+                ClassDefinition clsDef = null;
+                foreach (FeatureSchema fs in _cachedDesc.Schemas)
+                    if (clsDef != null)
+                        break;
+                    foreach (ClassDefinition cls in fs.Classes)
+                            break;
+                        foreach (PropertyDefinition prop in cls.Properties)
+                            if (prop.Type == PropertyDefinitionType.Geometry)
+                                clsDef = cls;
+                                break;
+                if (clsDef == null)
+                    MessageBox.Show(string.Format(Properties.Resources.InvalidFeatureSourceNoClasses, txtFeatureSource.Text));
+                    txtFeatureSource.Text = string.Empty;
+                    return;
+                SetFeatureClass(clsDef);
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs	2011-11-29 03:58:05 UTC (rev 6255)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs	2011-11-29 04:38:32 UTC (rev 6256)
@@ -1,7 +1,7 @@
 // <auto-generated>
 //     This code was generated by a tool.
-//     Runtime Version:2.0.50727.5448
+//     Runtime Version:2.0.50727.4963
 //     Changes to this file may cause incorrect behavior and will be lost if
 //     the code is regenerated.
@@ -1753,6 +1753,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Feature Source ({0}) has no usable feature classes. Choose a different feature source.
+        /// </summary>
+        internal static string InvalidFeatureSourceNoClasses {
+            get {
+                return ResourceManager.GetString("InvalidFeatureSourceNoClasses", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Invalid field count in line {0}.
         /// </summary>
         internal static string InvalidFieldCountError {
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx	2011-11-29 03:58:05 UTC (rev 6255)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx	2011-11-29 04:38:32 UTC (rev 6256)
@@ -1298,4 +1298,7 @@
   <data name="disk" type="System.Resources.ResXFileRef, System.Windows.Forms">
     <value>..\Resources\disk.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
   </data>
+  <data name="InvalidFeatureSourceNoClasses" xml:space="preserve">
+    <value>Feature Source ({0}) has no usable feature classes. Choose a different feature source</value>
+  </data>
 </root>
\ No newline at end of file
More information about the mapguide-commits mailing list
