[mapguide-commits] r6259 - trunk/MgDev/Server/src/Core
svn_mapguide at osgeo.org
Tue Nov 29 04:16:41 EST 2011
Author: hubu
Date: 2011-11-29 01:16:41 -0800 (Tue, 29 Nov 2011)
New Revision: 6259
trunk/MgDev/Server/src/Core/Makefile.am
Revert the last submission, because this submission is incorrect. It modified too many lines.
Modified: trunk/MgDev/Server/src/Core/Makefile.am
--- trunk/MgDev/Server/src/Core/Makefile.am 2011-11-29 08:55:22 UTC (rev 6258)
+++ trunk/MgDev/Server/src/Core/Makefile.am 2011-11-29 09:16:41 UTC (rev 6259)
@@ -127,13 +127,14 @@
-lMgRenderers \
../../../Common/Security/libMgSecurity.a
-mgserver_LDFLAGS = -version-info 7:0:0 \
+mgserver_LDFLAGS = \
-R$(map_fdo_lib) \
-R$(map_srcdir)/Oem/ACE/ACE_wrappers/ace \
-R$(map_srcdir)/Oem/DWFTK7.1/develop/global/src/dwfcore \
-R$(map_srcdir)/Oem/DWFTK7.1/develop/global/src/dwf \
-R$(map_srcdir)/Oem/DWFTK7.1/develop/global/src/dwfemap \
-R$(map_srcdir)/Oem/dbxml/install/lib \
+ -R$(map_srcdir)/Common/CoordinateSystem/.libs \
-R$(map_srcdir)/Common/MdfModel/.libs \
-R$(map_srcdir)/Common/MdfParser/.libs \
-R$(map_srcdir)/Common/Stylization/.libs \
@@ -163,6 +164,7 @@
-L../../../Oem/DWFTK7.1/develop/global/src/dwf \
-L../../../Oem/DWFTK7.1/develop/global/src/dwfemap \
-L../../../Oem/dbxml/install/lib \
+ -L$(top_builddir)/Common/CoordinateSystem \
-L../../../Common/MdfModel \
-L../../../Common/MdfParser \
-L../../../Common/Stylization \
@@ -275,7 +277,7 @@
cp -f -r $(mentor_dict_source_dir)/* $(mentor_dict_install_dir);)
@echo "#!/bin/sh" > unittest.sh
@echo "export MENTOR_DICTIONARY_PATH=$(mentor_dict_install_dir)" >> unittest.sh
- @echo "echo MENTOR_DICTIONARY_PATH=\$$MENTOR_DICTIONARY_PATH" >> unittest.sh
+ @echo "echo MENTOR_DICTIONARY_PATH=\$$MENTOR_DICTIONARY_PATH" >> unittest.sh
@echo "./mgserver test" >> unittest.sh
@chmod a+x unittest.sh
@@ -328,12 +330,8 @@
@mkdir Schema
@cp -f ../../../Common/Schema/*.xsd Schema/
-mglf:
- @sudo cp -f ../../../Common/Security/lfsvaaka /etc/lfsvaaka
- @sudo chmod +w /etc/lfsvaaka
+all : Schema Resources Logs Temp Trash Packages Repositories serverconfig_linux.ini
-all : Schema Resources Logs Temp Trash Packages Repositories serverconfig_linux.ini mglf
logfiledir = ${prefix}/Logs
tempdir = ${prefix}/Temp
trashdir = ${prefix}/Trash
@@ -383,34 +381,18 @@
@cp -fp ../../../Oem/dbxml/install/bin/dbxml ${prefix}/bin/
@cp -fp ../../../Oem/dbxml/install/bin/dbxml_dump ${prefix}/bin/
@cp -fp ../../../Oem/dbxml/install/bin/dbxml_load ${prefix}/bin/
- @sed -e '1aexport PATH=${root_prefix}/webserverextensions/php/bin:$$PATH LD_LIBRARY_PATH=${root_prefix}/lib:${prefix}/lib:$$LD_LIBRARY_PATH' \
- ../../RepositoryAdmin/BackUpOfflineRepositories.sh > $(repositoryadmindir)/BackUpOfflineRepositories.sh
- ../../RepositoryAdmin/BackUpOnlineRepositories.sh > $(repositoryadmindir)/BackUpOnlineRepositories.sh
- ../../RepositoryAdmin/RecoverRepositories.sh > $(repositoryadmindir)/RecoverRepositories.sh
- ../../RepositoryAdmin/RestoreColdBackupRepositories.sh > $(repositoryadmindir)/RestoreColdBackupRepositories.sh
- ../../RepositoryAdmin/RestoreHotBackupRepositories.sh > $(repositoryadmindir)/RestoreHotBackupRepositories.sh
- ../../RepositoryAdmin/SetupRepositoryIndices.sh > $(repositoryadmindir)/SetupRepositoryIndices.sh
- ../../RepositoryAdmin/UpgradeRepositories.sh > $(repositoryadmindir)/UpgradeRepositories.sh
+ @cp -fp ../../RepositoryAdmin/*.sh $(repositoryadmindir)
@cp -fp ../../RepositoryAdmin/*.php $(repositoryadmindir)
@cp -fp ../../RepositoryAdmin/*.inc $(repositoryadmindir)
- @cp -fp ../../RepositoryAdmin/MgEnterpriseRepositoryAdmin.pdf $(repositoryadmindir)/RepositoryAdmin.pdf
+ @cp -fp ../../RepositoryAdmin/*.pdf $(repositoryadmindir)
+ @cp -fp ../../RepositoryAdmin/license.txt $(repositoryadmindir)
@cp -fp ../../RepositoryAdmin/php.ini $(repositoryadmindir)
- @chmod a+x $(repositoryadmindir)/*.sh
- test -h $(fdodir)/libxalanMsg.so.17 || (pushd $(fdodir); ln -s libxalanMsg.so.17.0 libxalanMsg.so.17; popd;)
- test -h $(fdodir)/libxalanMsg.so || (pushd $(fdodir); ln -s libxalanMsg.so.17.0 libxalanMsg.so; popd;)
- test -h $(fdodir)/libxerces-c.so.25 || (pushd $(fdodir); ln -s libxerces-c.so.25.0 libxerces-c.so.25; popd;)
- test -h $(fdodir)/libxerces-c.so || (pushd $(fdodir); ln -s libxerces-c.so.25.0 libxerces-c.so; popd;)
+ @pushd $(fdodir); ln -s libxalanMsg.so.17.0 libxalanMsg.so.17; ln -s libxalanMsg.so.17.0 libxalanMsg.so; popd;
+ @pushd $(fdodir); ln -s libxerces-c.so.25.0 libxerces-c.so.25; ln -s libxerces-c.so.25.0 libxerces-c.so; popd;
install-data-hook:
@sed -e 's#^FdoPath.*=.*#FdoPath = $(map_fdo_lib)#' \
-e 's#^LogsPath.*=.*#LogsPath = ${prefix}/Logs/#' \
- -e 's#^MentorDictionaryPath.*=.*#MentorDictionaryPath = ${mentor_dict_install_dir}#' \
-e 's#^ResourcesPath.*=.*#ResourcesPath = ${prefix}/Resources/#' \
-e 's#^TempPath.*=.*#TempPath = ${prefix}/Temp/#' \
-e 's#^WmsDocumentPath.*=.*#WmsDocumentPath = ${prefix}/Wms/#' \
@@ -425,10 +407,10 @@
-e 's#^ResourceSchemaFilePath.*=.*#ResourceSchemaFilePath = ${prefix}/Schema/#' \
-e 's#^ResourceDataFileTrashFolderName.*=.*#ResourceDataFileTrashFolderName = Trash#' \
serverconfig.ini > ${prefix}/bin/serverconfig.ini
- @echo '#!/bin/sh' > ${prefix}/bin/mgserver.sh
+ @echo '#!/bin/bash' > ${prefix}/bin/mgserver.sh
@echo '' >> ${prefix}/bin/mgserver.sh
@echo 'export MENTOR_DICTIONARY_PATH=$(mentor_dict_install_dir)' >> ${prefix}/bin/mgserver.sh
- @echo 'export LD_LIBRARY_PATH=$(fdodir):"$$LD_LIBRARY_PATH"' >> ${prefix}/bin/mgserver.sh
+ @echo 'export LD_LIBRARY_PATH=$(fdodir):"$$LD_LIBRARY_PATH"' >> ${prefix}/bin/mgserver.sh
@echo 'pushd ${prefix}/bin' >> ${prefix}/bin/mgserver.sh
@cp -f ${prefix}/bin/mgserver.sh ${prefix}/bin/mgserverd.sh
@echo './mgserver run' >> ${prefix}/bin/mgserver.sh
More information about the mapguide-commits
