[mapguide-commits] r6135 - in trunk/MgDev: Common/Schema
Web/src/WebApp Web/src/stdicons Web/src/viewerfiles
svn_mapguide at osgeo.org
Sun Sep 18 21:51:38 EDT 2011
Author: hubu
Date: 2011-09-18 18:51:37 -0700 (Sun, 18 Sep 2011)
New Revision: 6135
Added:
trunk/MgDev/Common/Schema/WebLayout-2.4.0.xsd
trunk/MgDev/Web/src/stdicons/icon_maptip.gif
trunk/MgDev/Web/src/stdicons/icon_maptip_disabled.gif
trunk/MgDev/Web/src/WebApp/WebActions.h
trunk/MgDev/Web/src/WebApp/WebGettingStarted.cpp
trunk/MgDev/Web/src/WebApp/WebLayout.cpp
trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ
trunk/MgDev/Web/src/viewerfiles/mainframe.templ
Fix Ticket: Fix the ticket #1765: Add a new command "MapTip" to enable/disable map tooltips
https://trac.osgeo.org/mapguide/ticket/1765
Added: trunk/MgDev/Common/Schema/WebLayout-2.4.0.xsd
--- trunk/MgDev/Common/Schema/WebLayout-2.4.0.xsd (rev 0)
+++ trunk/MgDev/Common/Schema/WebLayout-2.4.0.xsd 2011-09-19 01:51:37 UTC (rev 6135)
@@ -0,0 +1,344 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified">
+ <xs:element name="WebLayout" type="WebLayoutType"/>
+ <xs:complexType name="WebLayoutType">
+ <xs:sequence>
+ <xs:element name="Title" type="xs:string"/>
+ <xs:element name="Map" type="MapType"/>
+ <xs:element name="EnablePingServer" type="xs:boolean" minOccurs="0" />
+ <xs:element name="ToolBar" type="ToolBarType"/>
+ <xs:element name="InformationPane" type="InformationPaneType"/>
+ <xs:element name="ContextMenu" type="ContextMenuType"/>
+ <xs:element name="TaskPane" type="TaskPaneType"/>
+ <xs:element name="StatusBar" type="StatusBarType"/>
+ <xs:element name="ZoomControl" type="ZoomControlType"/>
+ <xs:element name="CommandSet" type="CommandSetType"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ResourceReferenceType">
+ <xs:sequence>
+ <xs:element name="ResourceId" type="xs:string"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="MapType">
+ <xs:complexContent>
+ <xs:extension base="ResourceReferenceType">
+ <xs:sequence>
+ <xs:element name="InitialView" type="MapViewType" minOccurs="0"/>
+ <xs:element name="HyperlinkTarget" type="TargetType"/>
+ <xs:element name="HyperlinkTargetFrame" type="xs:string" minOccurs="0"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexContent>
+ </xs:complexType>
+ <xs:complexType name="WebLayoutControlType">
+ <xs:sequence>
+ <xs:element name="Visible" type="xs:boolean"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="WebLayoutResizableControlType">
+ <xs:extension base="WebLayoutControlType">
+ <xs:sequence>
+ <xs:element name="Width" type="xs:int"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="ToolBarType">
+ <xs:sequence>
+ <xs:element name="Button" type="UIItemType" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="ContextMenuType">
+ <xs:sequence>
+ <xs:element name="MenuItem" type="UIItemType" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="StatusBarType">
+ <xs:extension base="WebLayoutControlType"/>
+ </xs:complexType>
+ <xs:complexType name="ZoomControlType">
+ </xs:complexType>
+ <xs:complexType name="InformationPaneType">
+ <xs:extension base="WebLayoutResizableControlType">
+ <xs:sequence>
+ <xs:element name="LegendVisible" type="xs:boolean"/>
+ <xs:element name="PropertiesVisible" type="xs:boolean"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="TaskPaneType">
+ <xs:sequence>
+ <xs:element name="TaskBar" type="TaskBarType"/>
+ <xs:element name="InitialTask" type="xs:string" minOccurs="0"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="TaskButtonType">
+ <xs:sequence>
+ <xs:element name="Name" type="xs:string"/>
+ <xs:element name="Tooltip" type="xs:string" minOccurs="0"/>
+ <xs:element name="Description" type="xs:string" minOccurs="0"/>
+ <xs:element name="ImageURL" type="xs:string" minOccurs="0"/>
+ <xs:element name="DisabledImageURL" type="xs:string" minOccurs="0"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="TaskBarType">
+ <xs:sequence>
+ <xs:element name="Home" type="TaskButtonType"/>
+ <xs:element name="Forward" type="TaskButtonType"/>
+ <xs:element name="Back" type="TaskButtonType"/>
+ <xs:element name="Tasks" type="TaskButtonType"/>
+ <xs:element name="MenuButton" type="UIItemType" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="CommandSetType">
+ <xs:sequence>
+ <xs:element name="Command" type="CommandType" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="MapViewType">
+ <xs:sequence>
+ <xs:element name="CenterX" type="xs:double"/>
+ <xs:element name="CenterY" type="xs:double"/>
+ <xs:element name="Scale" type="xs:double"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="UIItemType">
+ <xs:sequence>
+ <xs:element name="Function" type="UIItemFunctionType"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:simpleType name="UIItemFunctionType">
+ <xs:restriction base="xs:string">
+ <xs:enumeration value="Separator"/>
+ <xs:enumeration value="Command"/>
+ <xs:enumeration value="Flyout"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="FlyoutItemType">
+ <xs:extension base="UIItemType">
+ <xs:sequence>
+ <xs:element name="Label" type="xs:string"/>
+ <xs:element name="SubItem" type="UIItemType" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="SeparatorItemType">
+ <xs:extension base="UIItemType"/>
+ </xs:complexType>
+ <xs:complexType name="CommandItemType">
+ <xs:sequence>
+ <xs:element name="Command" type="xs:string"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="CommandType" abstract="true">
+ <xs:sequence>
+ <xs:element name="TargetViewer" type="TargetViewerType"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:simpleType name="BasicCommandActionType">
+ <xs:enumeration value="Pan"/>
+ <xs:enumeration value="PanUp"/>
+ <xs:enumeration value="PanDown"/>
+ <xs:enumeration value="PanRight"/>
+ <xs:enumeration value="PanLeft"/>
+ <xs:enumeration value="Zoom"/>
+ <xs:enumeration value="ZoomIn"/>
+ <xs:enumeration value="ZoomOut"/>
+ <xs:enumeration value="ZoomRectangle"/>
+ <xs:enumeration value="ZoomToSelection"/>
+ <xs:enumeration value="FitToWindow"/>
+ <xs:enumeration value="PreviousView"/>
+ <xs:enumeration value="NextView"/>
+ <xs:enumeration value="RestoreView"/>
+ <xs:enumeration value="Select"/>
+ <xs:enumeration value="SelectRadius"/>
+ <xs:enumeration value="SelectPolygon"/>
+ <xs:enumeration value="ClearSelection"/>
+ <xs:enumeration value="Refresh"/>
+ <xs:enumeration value="CopyMap"/>
+ <xs:enumeration value="About"/>
+ <xs:enumeration value="MapTip"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="BasicCommandType">
+ <xs:extension base="CommandType">
+ <xs:sequence>
+ <xs:element name="Action" type="BasicCommandActionType"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:simpleType name="TargetViewerType">
+ <xs:enumeration value="Dwf"/>
+ <xs:enumeration value="Ajax"/>
+ <xs:enumeration value="All"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="CustomCommandType" abstract="true">
+ <xs:extension base="CommandType"/>
+ </xs:complexType>
+ <xs:complexType name="TargetedCommandType" abstract="true">
+ <xs:extension base="CustomCommandType">
+ <xs:sequence>
+ <xs:element name="Target" type="TargetType"/>
+ <xs:element name="TargetFrame" type="xs:string" minOccurs="0"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:simpleType name="TargetType">
+ <xs:enumeration value="TaskPane"/>
+ <xs:enumeration value="NewWindow"/>
+ <xs:enumeration value="SpecifiedFrame"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="SearchCommandType">
+ <xs:extension base="TargetedCommandType">
+ <xs:sequence>
+ <xs:element name="Layer" type="xs:string"/>
+ <xs:element name="Prompt" type="xs:string"/>
+ <xs:element name="ResultColumns" type="ResultColumnSetType"/>
+ <xs:element name="Filter" type="xs:string" minOccurs="0"/>
+ <xs:element name="MatchLimit" type="xs:integer"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="InvokeURLCommandType">
+ <xs:sequence>
+ <xs:element name="URL" type="xs:string"/>
+ <xs:element name="LayerSet" type="LayerSetType" minOccurs="0"/>
+ <xs:element name="AdditionalParameter" type="ParameterPairType" minOccurs="0" maxOccurs="unbounded"/>
+ <xs:element name="DisableIfSelectionEmpty" type="xs:boolean"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="BufferCommandType">
+ <xs:extension base="TargetedCommandType"/>
+ </xs:complexType>
+ <xs:complexType name="SelectWithinCommandType">
+ </xs:complexType>
+ <xs:complexType name="PrintCommandType">
+ <xs:sequence>
+ <xs:element name="PrintLayout" type="ResourceReferenceType" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="GetPrintablePageCommandType">
+ </xs:complexType>
+ <xs:complexType name="MeasureCommandType">
+ </xs:complexType>
+ <xs:complexType name="ViewOptionsCommandType">
+ </xs:complexType>
+ <xs:complexType name="HelpCommandType">
+ <xs:sequence>
+ <xs:element name="URL" type="xs:string" minOccurs="0"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="InvokeScriptCommandType">
+ <xs:sequence>
+ <xs:element name="Script" type="xs:string"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="ParameterPairType">
+ <xs:sequence>
+ <xs:element name="Key" type="xs:string"/>
+ <xs:element name="Value" type="xs:string"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="LayerSetType">
+ <xs:sequence>
+ <xs:element name="Layer" type="xs:string" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ResultColumnType">
+ <xs:sequence>
+ <xs:element name="Property" type="xs:string"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ResultColumnSetType">
+ <xs:sequence>
+ <xs:element name="Column" type="ResultColumnType" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:complexType>
+</xs:schema>
Modified: trunk/MgDev/Web/src/WebApp/WebActions.h
--- trunk/MgDev/Web/src/WebApp/WebActions.h 2011-09-15 18:02:38 UTC (rev 6134)
+++ trunk/MgDev/Web/src/WebApp/WebActions.h 2011-09-19 01:51:37 UTC (rev 6135)
@@ -57,6 +57,7 @@
static const INT32 InvokeScript = 31;
static const INT32 SelectWithin = 32;
static const INT32 Help = 33;
+ static const INT32 MapTip = 34;
#endif // _MGWEBACTIONS_H_
Modified: trunk/MgDev/Web/src/WebApp/WebGettingStarted.cpp
--- trunk/MgDev/Web/src/WebApp/WebGettingStarted.cpp 2011-09-15 18:02:38 UTC (rev 6134)
+++ trunk/MgDev/Web/src/WebApp/WebGettingStarted.cpp 2011-09-19 01:51:37 UTC (rev 6135)
@@ -171,6 +171,7 @@
cmdCodes["2e0f"] = MgWebActions::Buffer;
cmdCodes["2e0e"] = MgWebActions::Measure;
cmdCodes["2e0d"] = MgWebActions::Search;
+ cmdCodes["2e0c"] = MgWebActions::MapTip;
return true;
Modified: trunk/MgDev/Web/src/WebApp/WebLayout.cpp
--- trunk/MgDev/Web/src/WebApp/WebLayout.cpp 2011-09-15 18:02:38 UTC (rev 6134)
+++ trunk/MgDev/Web/src/WebApp/WebLayout.cpp 2011-09-19 01:51:37 UTC (rev 6135)
@@ -1089,6 +1089,8 @@
return MgWebActions::Buffer;
else if (action == L"Measure") // NOXLATE
return MgWebActions::Measure;
+ else if (action == L"MapTip") // NOXLATE
+ return MgWebActions::MapTip;
else if (action == L"ViewOptions") // NOXLATE
return MgWebActions::ViewOptions;
else if (action == L"InvokeScript") // NOXLATE
Added: trunk/MgDev/Web/src/stdicons/icon_maptip.gif
(Binary files differ)
Property changes on: trunk/MgDev/Web/src/stdicons/icon_maptip.gif
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/MgDev/Web/src/stdicons/icon_maptip_disabled.gif
Property changes on: trunk/MgDev/Web/src/stdicons/icon_maptip_disabled.gif
Modified: trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ
--- trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ 2011-09-15 18:02:38 UTC (rev 6134)
+++ trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ 2011-09-19 01:51:37 UTC (rev 6135)
@@ -323,6 +323,7 @@
var setSelScript = '%s';
var hlData;
var moveTimer = 0, mapInit = false;
+var haveTooltip = false;
var ovoffsx = 0, ovoffsy = 0;
var finscale = true;
var slidercourse = 78;
@@ -832,6 +833,9 @@
case 22:
About();
break;
+ case 34:
+ MapTip();
+ break;
@@ -1275,7 +1279,7 @@
if(!parent.InMeasure())
- if(x >= 0)
+ if(x >= 0 && haveTooltip)
hlData.curx = x;
hlData.cury = y;
@@ -2210,6 +2214,33 @@
GotoView(extX1 + (extX2 - extX1) / 2, extY2 + (extY1 - extY2) / 2, scale, true, true);
+function MapTip()
+ var maptipBtn = parent.tbFrame.document.getElementById(14)
+ if(!haveTooltip)
+ haveTooltip = true;
+ //The tooltip is enabled.
+ //highlight the maptip button via change the background and the border color
+ if(maptipBtn)
+ maptipBtn.style.border = "solid #a0a0a0 1px";
+ maptipBtn.style.background = "#dcdcdc";
+ else
+ haveTooltip = false;
+ //disable the tooltip
+ //change back the background and border color
+ if(maptipBtn)
+ maptipBtn.style.border = "solid #f0f0f0 1px";
+ maptipBtn.style.background = "#f0f0f0";
function StartToolFeedback(x, y, type)
moveType = DRAGGING;
Modified: trunk/MgDev/Web/src/viewerfiles/mainframe.templ
--- trunk/MgDev/Web/src/viewerfiles/mainframe.templ 2011-09-15 18:02:38 UTC (rev 6134)
+++ trunk/MgDev/Web/src/viewerfiles/mainframe.templ 2011-09-19 01:51:37 UTC (rev 6135)
@@ -42,7 +42,6 @@
var toolbarItems = new Array();
var taskItems = new Array();
var ctxMenuItems = new Array();
var intervalID;
var pingServerFailTime;
@@ -294,7 +293,7 @@
OpenTaskBar();
- if(action >= 1 && action <= 22)
+ if((action >= 1 && action <= 22)||(action == 34))
ExecuteMapAction(action);
else if(cmd.action == 23)
ExecutePrintCommand(index);
@@ -432,6 +431,7 @@
function OnMapLoaded()
ExecuteMapAction(15);
+ ExecuteMapAction(34);
RestoreView();
OnSelectionChanged();
DisplayMapSize();
More information about the mapguide-commits
