[mapguide-commits] r6139 - in trunk/Tools/Maestro:
Maestro.Base/Services OSGeo.MapGuide.MaestroAPI/Schema
svn_mapguide at osgeo.org
Wed Sep 21 01:43:58 EDT 2011
Author: jng
Date: 2011-09-20 22:43:58 -0700 (Tue, 20 Sep 2011)
New Revision: 6139
trunk/Tools/Maestro/Maestro.Base/Services/OpenResourceManager.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/DataPropertyDefinition.cs
Add missing xsd schema data type introduced in latest MG trunk and fix a small defect where an editor which has been saved under a different resource name is still marked as "open" when closed
Modified: trunk/Tools/Maestro/Maestro.Base/Services/OpenResourceManager.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/OpenResourceManager.cs 2011-09-20 16:52:32 UTC (rev 6138)
+++ trunk/Tools/Maestro/Maestro.Base/Services/OpenResourceManager.cs 2011-09-21 05:43:58 UTC (rev 6139)
@@ -176,7 +176,8 @@
ed.ViewContentClosed += (sender, e) =>
- _openItems.Remove(key);
+ //Recompute the resource key as that may have changed by a save as operation
+ _openItems.Remove(ComputeResourceKey(((EditorContentBase)sender).EditorService.ResourceID, conn));
siteExp.FlagNode(conn.DisplayName, ed.EditorService.ResourceID, NodeFlagAction.None);
ed.EditorService.Saved += (sender, e) =>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/DataPropertyDefinition.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/DataPropertyDefinition.cs 2011-09-20 16:52:32 UTC (rev 6138)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/DataPropertyDefinition.cs 2011-09-21 05:43:58 UTC (rev 6139)
@@ -148,6 +148,7 @@
return DataPropertyType.Int32;
case "fdo:int64":
case "xs:int64":
+ case "xs:long":
return DataPropertyType.Int64;
case "xs:float":
case "xs:single":
More information about the mapguide-commits
