[mapguide-commits] r6153 - in trunk/MgDev/Common: Renderers
Stylization
svn_mapguide at osgeo.org
Thu Sep 29 15:32:21 EDT 2011
Author: waltweltonlair
Date: 2011-09-29 12:32:21 -0700 (Thu, 29 Sep 2011)
New Revision: 6153
trunk/MgDev/Common/Renderers/EPlotRenderer.cpp
trunk/MgDev/Common/Renderers/EPlotRenderer.h
trunk/MgDev/Common/Stylization/SE_Renderer.cpp
trunk/MgDev/Common/Stylization/SE_Renderer.h
Additional fix for ticket #1818 (Implement RFC 121 - Upgrade PHP, Apache and Tomcat to latest version)
Update the Visual Studio 2008 project file to account for new version of Apache.
Modified: trunk/MgDev/Common/Renderers/EPlotRenderer.cpp
--- trunk/MgDev/Common/Renderers/EPlotRenderer.cpp 2011-09-29 18:15:09 UTC (rev 6152)
+++ trunk/MgDev/Common/Renderers/EPlotRenderer.cpp 2011-09-29 19:32:21 UTC (rev 6153)
@@ -483,6 +483,14 @@
+// Disable this optimization for EPlots. When the plotted DWF is
+// zoomed in using the DWF viewer, we want to see text and not lines.
+bool EPlotRenderer::OptimizeGeometry()
+ return false;
//TODO: fold this function and its twin residing in EMapUpdateRenderer
//into DWFRenderer.
void EPlotRenderer::AddW2DResource(DWFCore::DWFBufferOutputStream* w2dStream,
Modified: trunk/MgDev/Common/Renderers/EPlotRenderer.h
--- trunk/MgDev/Common/Renderers/EPlotRenderer.h 2011-09-29 18:15:09 UTC (rev 6152)
+++ trunk/MgDev/Common/Renderers/EPlotRenderer.h 2011-09-29 19:32:21 UTC (rev 6153)
@@ -67,6 +67,11 @@
RENDERERS_API virtual void Done();
+ // SE_Renderer overloads
+ virtual bool OptimizeGeometry();
// EPlot specific stuff
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.cpp
--- trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2011-09-29 18:15:09 UTC (rev 6152)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2011-09-29 19:32:21 UTC (rev 6153)
@@ -687,9 +687,11 @@
-// Indicates whether rendering optimization is used by this renderer. For example, if we are rendering text and
-// optimization is turned on, then text is rendered as a simple line when it is very small.
-// By default, optimization is turned on. For other behavior, this method must be overridden.
+// Indicates whether rendering optimization is used by this renderer. For
+// example, if we are rendering text and optimization is turned on, then
+// text is rendered as a simple line when it is very small. By default,
+// optimization is turned on. For other behavior, this method must be
+// overridden.
bool SE_Renderer::OptimizeGeometry()
return true;
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.h
--- trunk/MgDev/Common/Stylization/SE_Renderer.h 2011-09-29 18:15:09 UTC (rev 6152)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.h 2011-09-29 19:32:21 UTC (rev 6153)
@@ -129,9 +129,11 @@
// helper method
void ProcessLineLabels(LineBuffer* geometry, SE_RenderLineStyle* style);
- // Indicates whether rendering optimization is used by this renderer. For example, we are rendering text and
- // optimization is turned on, then text is rendered as a simple line when it is very small.
- // By default, optimization is turned on. For other behavior, this method must be overridden.
+ // Indicates whether rendering optimization is used by this renderer. For
+ // example, if we are rendering text and optimization is turned on, then
+ // text is rendered as a simple line when it is very small. By default,
+ // optimization is turned on. For other behavior, this method must be
+ // overridden.
STYLIZATION_API virtual bool OptimizeGeometry();
private:
More information about the mapguide-commits
