[mapguide-commits] r6568 - in trunk/MgDev: .
BuildTools/WebTools/IMake Common/Renderers Common/Security
Common/Stylization Oem
Oem/ACE/ACE_wrappers/include/makeinclude Oem/SWIGEx
Oem/dbxml/xqilla Oem/dbxml/xqilla/include/xqilla/framework
Oem/geos-2.2.0 Server/src/Gws/GwsQueryEngine Web/src/CgiAgent
svn_mapguide at osgeo.org
Wed Apr 11 11:07:14 EDT 2012
Author: jng
Date: 2012-04-11 08:07:14 -0700 (Wed, 11 Apr 2012)
New Revision: 6568
trunk/MgDev/BuildTools/WebTools/IMake/Makefile
trunk/MgDev/BuildTools/WebTools/IMake/stdafx.h
trunk/MgDev/Common/Renderers/Makefile.am
trunk/MgDev/Common/Renderers/ObservationMesh.cpp
trunk/MgDev/Common/Security/CryptographyUtil.cpp
trunk/MgDev/Common/Stylization/Makefile.am
trunk/MgDev/Common/Stylization/SE_BufferPool.cpp
trunk/MgDev/Common/Stylization/atom.h
trunk/MgDev/Common/Stylization/atom_element_structure.h
trunk/MgDev/Oem/ACE/ACE_wrappers/include/makeinclude/platform_linux.GNU
trunk/MgDev/Oem/ACE/ACE_wrappers/include/makeinclude/platform_linux_common.GNU
trunk/MgDev/Oem/Makefile.am
trunk/MgDev/Oem/SWIGEx/Makefile
trunk/MgDev/Oem/dbxml/xqilla/Makefile.in
trunk/MgDev/Oem/dbxml/xqilla/include/xqilla/framework/XPath2MemoryManager.hpp
trunk/MgDev/Oem/geos-2.2.0/configure.in
trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsBatchSortedBlockJoinQueryResults.cpp
trunk/MgDev/Web/src/CgiAgent/Makefile.am
trunk/MgDev/configure.in
#1977: Apply fixes to allow MapGuide to build on Ubuntu 11.10 (which uses GCC 4.6)
Modified: trunk/MgDev/BuildTools/WebTools/IMake/Makefile
--- trunk/MgDev/BuildTools/WebTools/IMake/Makefile 2012-04-11 12:34:12 UTC (rev 6567)
+++ trunk/MgDev/BuildTools/WebTools/IMake/Makefile 2012-04-11 15:07:14 UTC (rev 6568)
@@ -12,8 +12,8 @@
CXX = g++
LEX = flex
YACC = yacc
-CFLAGS = -pipe -UZTS -Wall -W -O2 -g -pipe -march=i386 -mcpu=i686 -fno-use-cxa-atexit -fexceptions -DNDEBUG
-CXXFLAGS = -pipe -UZTS -Wall -W -O2 -g -pipe -march=i386 -mcpu=i686 -fno-use-cxa-atexit -fexceptions -DNDEBUG
+CFLAGS = -pipe -UZTS -Wall -W -O2 -g -pipe -march=i686 -mtune=i686 -fno-use-cxa-atexit -fexceptions -DNDEBUG
+CXXFLAGS = -pipe -UZTS -Wall -W -O2 -g -pipe -march=i686 -mtune=i686 -fno-use-cxa-atexit -fexceptions -DNDEBUG
LEXFLAGS =
YACCFLAGS= -d
INCPATH = -I$(QTDIR)/mkspecs/default -I.
@@ -100,8 +100,7 @@
yaccclean:
lexclean:
clean:
- -$(DEL_FILE) $(OBJECTS)
- -$(DEL_FILE) Makefile
+ -$(DEL_FILE) $(OBJECTS)
-$(DEL_FILE) *~ core *.core
Modified: trunk/MgDev/BuildTools/WebTools/IMake/stdafx.h
--- trunk/MgDev/BuildTools/WebTools/IMake/stdafx.h 2012-04-11 12:34:12 UTC (rev 6567)
+++ trunk/MgDev/BuildTools/WebTools/IMake/stdafx.h 2012-04-11 15:07:14 UTC (rev 6568)
@@ -17,5 +17,6 @@
#include <ctype.h>
#include <cstdlib>
#include <cstring>
+#include <cstdio>
#endif
Modified: trunk/MgDev/Common/Renderers/Makefile.am
--- trunk/MgDev/Common/Renderers/Makefile.am 2012-04-11 12:34:12 UTC (rev 6567)
+++ trunk/MgDev/Common/Renderers/Makefile.am 2012-04-11 15:07:14 UTC (rev 6568)
@@ -88,6 +88,12 @@
../../Oem/gd/freetype/objs/.libs/libfreetype.a \
../../Oem/gd/jpeg/.libs/libjpeg.a \
../../Oem/gd/lpng/libpng.a \
- ../../Oem/agg-2.4/src/libagg.a
+ ../../Oem/agg-2.4/src/libagg.a \
+ -ldwfcore \
+ -ldwftk \
+ -ldwfemap
-libMgRenderers_la_LDFLAGS = -release $(PACKAGE_VERSION)
+libMgRenderers_la_LDFLAGS = -release $(PACKAGE_VERSION) \
+ -L../../Oem/DWFTK7.1/develop/global/src/dwfcore/.libs \
+ -L../../Oem/DWFTK7.1/develop/global/src/dwf/.libs \
+ -L../../Oem/DWFTK7.1/develop/global/src/dwfemap/.libs
Modified: trunk/MgDev/Common/Renderers/ObservationMesh.cpp
--- trunk/MgDev/Common/Renderers/ObservationMesh.cpp 2012-04-11 12:34:12 UTC (rev 6567)
+++ trunk/MgDev/Common/Renderers/ObservationMesh.cpp 2012-04-11 15:07:14 UTC (rev 6568)
@@ -22,6 +22,7 @@
#include "RS_OutputStream.h"
#include <map>
#include <cstring>
+#include <cstdio>
//desired observation mesh accuracy (in degrees)
#define OM_TOLERANCE 1e-5
Modified: trunk/MgDev/Common/Security/CryptographyUtil.cpp
--- trunk/MgDev/Common/Security/CryptographyUtil.cpp 2012-04-11 12:34:12 UTC (rev 6567)
+++ trunk/MgDev/Common/Security/CryptographyUtil.cpp 2012-04-11 15:07:14 UTC (rev 6568)
@@ -17,6 +17,7 @@
#include "CryptographyUtil.h"
#include <cstring>
+#include <cstdio>
/// Constants.
Modified: trunk/MgDev/Common/Stylization/Makefile.am
--- trunk/MgDev/Common/Stylization/Makefile.am 2012-04-11 12:34:12 UTC (rev 6567)
+++ trunk/MgDev/Common/Stylization/Makefile.am 2012-04-11 15:07:14 UTC (rev 6568)
@@ -202,6 +202,7 @@
Vector3D.h \
TransformMesh.h
-libMgStylization_la_LIBADD =
+libMgStylization_la_LIBADD = -lExpressionEngine
-libMgStylization_la_LDFLAGS = -release $(PACKAGE_VERSION)
+libMgStylization_la_LDFLAGS = -release $(PACKAGE_VERSION) \
+ -L$(map_fdo_lib)
Modified: trunk/MgDev/Common/Stylization/SE_BufferPool.cpp
--- trunk/MgDev/Common/Stylization/SE_BufferPool.cpp 2012-04-11 12:34:12 UTC (rev 6567)
+++ trunk/MgDev/Common/Stylization/SE_BufferPool.cpp 2012-04-11 15:07:14 UTC (rev 6568)
@@ -17,8 +17,8 @@
#include "stdafx.h"
#include "SE_BufferPool.h"
+#include <cstdlib>
SE_BufferPool::SE_BufferPool()
Modified: trunk/MgDev/Common/Stylization/atom.h
--- trunk/MgDev/Common/Stylization/atom.h 2012-04-11 12:34:12 UTC (rev 6567)
+++ trunk/MgDev/Common/Stylization/atom.h 2012-04-11 15:07:14 UTC (rev 6568)
@@ -1962,7 +1962,7 @@
virtual IStructure* Outer() const = 0;
// What is the "shape" of the run? Does it flow and wrap, or... ?
- virtual Shape::Type Shape() const = 0;
+ virtual Shape::Type GetShape() const = 0;
// Is selection considered continuous with previous run?
virtual bool Continuous() const = 0;
Modified: trunk/MgDev/Common/Stylization/atom_element_structure.h
--- trunk/MgDev/Common/Stylization/atom_element_structure.h 2012-04-11 12:34:12 UTC (rev 6567)
+++ trunk/MgDev/Common/Stylization/atom_element_structure.h 2012-04-11 15:07:14 UTC (rev 6568)
@@ -44,7 +44,7 @@
- ATOM::Shape::Type Shape() const
+ ATOM::Shape::Type GetShape() const
return m_eShape;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/include/makeinclude/platform_linux.GNU
--- trunk/MgDev/Oem/ACE/ACE_wrappers/include/makeinclude/platform_linux.GNU 2012-04-11 12:34:12 UTC (rev 6567)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/include/makeinclude/platform_linux.GNU 2012-04-11 15:07:14 UTC (rev 6568)
@@ -80,7 +80,7 @@
ifeq ($(threads),1)
LIBS += -lpthread
# look for the rt library in the usual places
- LIBS += $(shell test "`ls -L /usr/lib*/librt.so* /lib*/librt.so*`" && echo -lrt)
+ LIBS += $(shell getconf AIO_LISTIO_MAX >/dev/null 2>&1 && echo -lrt)
endif
ifeq ($(optimize),1)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/include/makeinclude/platform_linux_common.GNU
--- trunk/MgDev/Oem/ACE/ACE_wrappers/include/makeinclude/platform_linux_common.GNU 2012-04-11 12:34:12 UTC (rev 6567)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/include/makeinclude/platform_linux_common.GNU 2012-04-11 15:07:14 UTC (rev 6568)
@@ -85,7 +85,7 @@
endif
PLATFORM_AIO_SUPPORT := \
- $(shell test "`ls -L /usr/lib*/librt.so* /lib*/librt.so*`" && echo -DACE_HAS_AIO_CALLS)
+ $(shell getconf AIO_LISTIO_MAX >/dev/null 2>&1 && echo -DACE_HAS_AIO_CALLS)
GNU_LIBPTHREAD_VERSION := $(shell getconf GNU_LIBPTHREAD_VERSION 2> /dev/null || echo Unknown)
ifeq (NPTL, $(word 1,$(GNU_LIBPTHREAD_VERSION)))
Modified: trunk/MgDev/Oem/Makefile.am
--- trunk/MgDev/Oem/Makefile.am 2012-04-11 12:34:12 UTC (rev 6567)
+++ trunk/MgDev/Oem/Makefile.am 2012-04-11 15:07:14 UTC (rev 6568)
@@ -18,8 +18,5 @@
@cp -fpd dbxml/install/lib/libdb_cxx*.so* ${prefix}/lib
@cp -fpd dbxml/install/lib/libdbxml*.so* ${prefix}/lib
@cp -fp DWFTK7.1/develop/global/src/dwfcore/.libs/libdwfcore-* ${prefix}/lib
- @cp -fpd DWFTK7.1/develop/global/src/dwfcore/.libs/libdwfcore ${prefix}/lib
@cp -fp DWFTK7.1/develop/global/src/dwfemap/.libs/libdwfemap-* ${prefix}/lib
- @cp -fpd DWFTK7.1/develop/global/src/dwfemap/.libs/libdwfemap ${prefix}/lib
@cp -fp DWFTK7.1/develop/global/src/dwf/.libs/libdwftk-* ${prefix}/lib
- @cp -fpd DWFTK7.1/develop/global/src/dwf/.libs/libdwftk ${prefix}/lib
Modified: trunk/MgDev/Oem/SWIGEx/Makefile
--- trunk/MgDev/Oem/SWIGEx/Makefile 2012-04-11 12:34:12 UTC (rev 6567)
+++ trunk/MgDev/Oem/SWIGEx/Makefile 2012-04-11 15:07:14 UTC (rev 6568)
@@ -12,8 +12,8 @@
CXX = g++
LEX = flex
YACC = yacc
LEXFLAGS =
YACCFLAGS= -d
INCPATH = -I$(QTDIR)/mkspecs/default -I. -ISource/CParse -ISource/DOH -ISource/Include -ISource/Swig -ISource/Modules -ISource/Preprocessor
@@ -221,7 +221,6 @@
lexclean:
clean:
Modified: trunk/MgDev/Oem/dbxml/xqilla/Makefile.in
--- trunk/MgDev/Oem/dbxml/xqilla/Makefile.in 2012-04-11 12:34:12 UTC (rev 6567)
+++ trunk/MgDev/Oem/dbxml/xqilla/Makefile.in 2012-04-11 15:07:14 UTC (rev 6568)
@@ -5373,7 +5373,6 @@
$(LEXERFILE): $(LEXTEMPLATE) $(LEXSKEL)
- $(LEX) -BUs -Pxq -S$(LEXSKEL) -o$(LEXERFILE) $(LEXTEMPLATE) # This can take a long time
$(PARSERCPP) $(PARSERHPP): $(PARSERFILE)
$(YACC) -d -v -o $(PARSERCPP) $(PARSERFILE)
Modified: trunk/MgDev/Oem/dbxml/xqilla/include/xqilla/framework/XPath2MemoryManager.hpp
--- trunk/MgDev/Oem/dbxml/xqilla/include/xqilla/framework/XPath2MemoryManager.hpp 2012-04-11 12:34:12 UTC (rev 6567)
+++ trunk/MgDev/Oem/dbxml/xqilla/include/xqilla/framework/XPath2MemoryManager.hpp 2012-04-11 15:07:14 UTC (rev 6568)
@@ -24,6 +24,7 @@
#include <algorithm>
#include <assert.h>
+#include <cstddef>
#include <xqilla/framework/XQillaExport.hpp>
Modified: trunk/MgDev/Oem/geos-2.2.0/configure.in
--- trunk/MgDev/Oem/geos-2.2.0/configure.in 2012-04-11 12:34:12 UTC (rev 6567)
+++ trunk/MgDev/Oem/geos-2.2.0/configure.in 2012-04-11 15:07:14 UTC (rev 6568)
@@ -47,10 +47,6 @@
dnl types checks ------------------------------------------------------
dnl Find a working 64bit integer
-PGAC_TYPE_64BIT_INT([long int])
-if test x"$HAVE_LONG_INT_64" = x"no" ; then
- PGAC_TYPE_64BIT_INT([long long int])
-fi
dnl function checks ------------------------------------------------------
AC_FUNC_CLOSEDIR_VOID
@@ -77,7 +73,21 @@
dnl check for libraries ---------------------------------------------------
dnl things to substitute in output ----------------------------------------
-AC_SUBST(VERSION VERSION_MAJOR VERSION_MINOR VERSION_PATCH INTERFACE_CURRENT INTERFACE_REVISION INTERFACE_AGE JTS_PORT CAPI_VERSION CAPI_VERSION_MAJOR CAPI_VERSION_MINOR CAPI_VERSION_PATCH CAPI_INTERFACE_CURRENT CAPI_INTERFACE_REVISION CAPI_INTERFACE_AGE)
+AC_SUBST(VERSION)
+AC_SUBST(VERSION_MAJOR)
+AC_SUBST(VERSION_MINOR)
+AC_SUBST(VERSION_PATCH)
+AC_SUBST(INTERFACE_CURRENT)
+AC_SUBST(INTERFACE_REVISION)
+AC_SUBST(INTERFACE_AGE)
+AC_SUBST(JTS_PORT)
+AC_SUBST(CAPI_VERSION)
+AC_SUBST(CAPI_VERSION_MAJOR)
+AC_SUBST(CAPI_VERSION_MINOR)
+AC_SUBST(CAPI_VERSION_PATCH)
+AC_SUBST(CAPI_INTERFACE_CURRENT)
+AC_SUBST(CAPI_INTERFACE_REVISION)
+AC_SUBST(CAPI_INTERFACE_AGE)
dnl output stuff ----------------------------------------------------------
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsBatchSortedBlockJoinQueryResults.cpp
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsBatchSortedBlockJoinQueryResults.cpp 2012-04-11 12:34:12 UTC (rev 6567)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsBatchSortedBlockJoinQueryResults.cpp 2012-04-11 15:07:14 UTC (rev 6568)
@@ -24,8 +24,8 @@
#include "stdafx.h"
#include "GwsQueryEngineImp.h"
#include "GwsBinaryFeatureWriter.h"
+#include <cstdio>
// This setting limits the batch size used by the join algorithm
int CGwsBatchSortedBlockJoinQueryResults::sm_nBatchSize = 100; //Default
Modified: trunk/MgDev/Web/src/CgiAgent/Makefile.am
--- trunk/MgDev/Web/src/CgiAgent/Makefile.am 2012-04-11 12:34:12 UTC (rev 6567)
+++ trunk/MgDev/Web/src/CgiAgent/Makefile.am 2012-04-11 15:07:14 UTC (rev 6568)
@@ -37,14 +37,17 @@
-lMgFoundation \
-lMgGeometry \
-lMgPlatformBase \
+ -lMgMapGuideCommon \
-lMgMdfModel \
-lMgMdfParser \
-lMgHttpHandler \
- -lMgWebSupport
+ -lMgWebSupport \
+ -llib_json
mapagent_LDFLAGS = \
-L../../../Oem/ACE/ACE_wrappers/ace \
-L../../../Oem/dbxml/install/lib \
+ -L../../../Oem/jsoncpp/lib \
-L../../../Common/CoordinateSystem \
-L../../../Common/MdfModel \
-L../../../Common/MdfParser \
Modified: trunk/MgDev/configure.in
--- trunk/MgDev/configure.in 2012-04-11 12:34:12 UTC (rev 6567)
+++ trunk/MgDev/configure.in 2012-04-11 15:07:14 UTC (rev 6568)
@@ -4,7 +4,7 @@
# Variables
# Following are the makefile directories
-AC_INIT(mapguide,2.2.0,http://mapguide.osgeo.org)
+AC_INIT(mapguide,2.4.0,http://mapguide.osgeo.org)
AC_CONFIG_SRCDIR(configure.in)
AM_INIT_AUTOMAKE
AM_INIT_AUTOMAKE([1.9 tar-pax])
@@ -135,12 +135,12 @@
AC_MSG_NOTICE([Using optimized configuration])
if test -s "gcc32.txt"; then
AC_MSG_NOTICE([gcc 3.2.x . Please pay attention to warnings!])
- CXXFLAGS="-O2 -g -pipe -march=i386 -mcpu=i686 -fno-use-cxa-atexit -fexceptions"
- AC_SUBST(CXXFLAGS, ["-O2 -g -pipe -march=i386 -mcpu=i686 -fno-use-cxa-atexit -fexceptions"])
+ CXXFLAGS="-O2 -g -pipe -march=i686 -mtune=i686 -fno-use-cxa-atexit -fexceptions"
+ AC_SUBST(CXXFLAGS, ["-O2 -g -pipe -march=i686 -mtune=i686 -fno-use-cxa-atexit -fexceptions"])
else
AC_MSG_NOTICE([this gcc version is not actively supported.])
fi
fi
More information about the mapguide-commits
