[mapguide-commits] r6606 - in trunk/MgDev/Desktop: MapViewer
MapViewerTest MgDesktop UnitTest
svn_mapguide at osgeo.org
Mon Apr 30 12:16:35 EDT 2012
Author: jng
Date: 2012-04-30 09:16:35 -0700 (Mon, 30 Apr 2012)
New Revision: 6606
trunk/MgDev/Desktop/MapViewer/MapViewer.csproj
trunk/MgDev/Desktop/MapViewer/MgBufferControl.cs
trunk/MgDev/Desktop/MapViewer/MgLineMeasureControl.cs
trunk/MgDev/Desktop/MapViewer/MgQueryControl.cs
trunk/MgDev/Desktop/MapViewer/MgQueryResultsDialog.cs
trunk/MgDev/Desktop/MapViewerTest/Form1.Designer.cs
trunk/MgDev/Desktop/MapViewerTest/Form1.resx
trunk/MgDev/Desktop/MgDesktop/MgDesktop.vcproj
trunk/MgDev/Desktop/UnitTest/UnitTest.vcproj
Fix VS2008 projects due to recent mg-desktop changes
Modified: trunk/MgDev/Desktop/MapViewer/MapViewer.csproj
--- trunk/MgDev/Desktop/MapViewer/MapViewer.csproj 2012-04-30 15:40:30 UTC (rev 6605)
+++ trunk/MgDev/Desktop/MapViewer/MapViewer.csproj 2012-04-30 16:16:35 UTC (rev 6606)
@@ -101,6 +101,18 @@
<Compile Include="MgPropertyPane.Designer.cs">
<DependentUpon>MgPropertyPane.cs</DependentUpon>
</Compile>
+ <Compile Include="MgQueryControl.cs">
+ <SubType>UserControl</SubType>
+ </Compile>
+ <Compile Include="MgQueryControl.Designer.cs">
+ <DependentUpon>MgQueryControl.cs</DependentUpon>
+ </Compile>
+ <Compile Include="MgQueryResultsDialog.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="MgQueryResultsDialog.Designer.cs">
+ <DependentUpon>MgQueryResultsDialog.cs</DependentUpon>
+ </Compile>
<Compile Include="MgReadOnlyStream.cs" />
<Compile Include="Properties\AssemblyInfo.cs" />
<Compile Include="Properties\Resources.Designer.cs">
@@ -127,6 +139,12 @@
<EmbeddedResource Include="MgPropertyPane.resx">
</EmbeddedResource>
+ <EmbeddedResource Include="MgQueryControl.resx">
+ </EmbeddedResource>
+ <EmbeddedResource Include="MgQueryResultsDialog.resx">
<EmbeddedResource Include="Properties\Resources.resx">
<Generator>ResXFileCodeGenerator</Generator>
<LastGenOutput>Resources.Designer.cs</LastGenOutput>
Modified: trunk/MgDev/Desktop/MapViewer/MgBufferControl.cs
--- trunk/MgDev/Desktop/MapViewer/MgBufferControl.cs 2012-04-30 15:40:30 UTC (rev 6605)
+++ trunk/MgDev/Desktop/MapViewer/MgBufferControl.cs 2012-04-30 16:16:35 UTC (rev 6606)
@@ -3,7 +3,6 @@
using System.ComponentModel;
using System.Drawing;
using System.Data;
-using System.Linq;
using System.Text;
using System.Windows.Forms;
using System.Globalization;
@@ -111,7 +110,7 @@
MgResourceIdentifier ldfId = new MgResourceIdentifier("Session:" + _sessionId + "//" + txtBufferLayer.Text + "_Buffer.LayerDefinition");
MgLayerBase layer = FindLayer(layers, txtBufferLayer.Text);
- string[] layerNames = lstLayers.Items.OfType<string>().ToArray();
+ string[] layerNames = GetLayerNames();
double distance = Convert.ToDouble(numBufferDistance.Value);
MeasurementUnit bUnits = (MeasurementUnit)cmbUnits.SelectedItem;
@@ -381,6 +380,16 @@
MessageBox.Show("Buffer layer (" + txtBufferLayer.Text + ") " + (newBuffer ? "created" : "updated"));
+ private string[] GetLayerNames()
+ var items = new List<string>();
+ foreach (var it in lstLayers.Items)
+ items.Add(it.ToString());
+ return items.ToArray();
static string ToHtmlColor(Color color)
return String.Format("{0:X2}{1:X2}{2:X2}", color.R, color.G, color.B);
Modified: trunk/MgDev/Desktop/MapViewer/MgLineMeasureControl.cs
--- trunk/MgDev/Desktop/MapViewer/MgLineMeasureControl.cs 2012-04-30 15:40:30 UTC (rev 6605)
+++ trunk/MgDev/Desktop/MapViewer/MgLineMeasureControl.cs 2012-04-30 16:16:35 UTC (rev 6606)
@@ -3,7 +3,6 @@
using System.Data;
-using System.Linq;
using System.Text;
@@ -46,10 +45,20 @@
//Add to list of line segments
_segments.Add(new MeasuredLineSegment() { MapDistanceMeters = dist, Units = (MeasurementUnit)cmbUnits.SelectedItem });
- lblUnits.Text = _segments.Sum(x => x.DisplayUnits).ToString();
+ lblUnits.Text = TotalUnits(_segments).ToString();
+ private static double TotalUnits(IEnumerable<MeasuredLineSegment> segments)
+ double total = 0.0;
+ foreach (var seg in segments)
+ total += seg.DisplayUnits;
+ return total;
private void cmbUnits_SelectedIndexChanged(object sender, EventArgs e)
//Update segments units, then total
@@ -57,7 +66,7 @@
seg.Units = (MeasurementUnit)cmbUnits.SelectedItem;
Modified: trunk/MgDev/Desktop/MapViewer/MgQueryControl.cs
--- trunk/MgDev/Desktop/MapViewer/MgQueryControl.cs 2012-04-30 15:40:30 UTC (rev 6605)
+++ trunk/MgDev/Desktop/MapViewer/MgQueryControl.cs 2012-04-30 16:16:35 UTC (rev 6606)
@@ -3,7 +3,6 @@
using System.Data;
-using System.Linq;
using System.Text;
Modified: trunk/MgDev/Desktop/MapViewer/MgQueryResultsDialog.cs
--- trunk/MgDev/Desktop/MapViewer/MgQueryResultsDialog.cs 2012-04-30 15:40:30 UTC (rev 6605)
+++ trunk/MgDev/Desktop/MapViewer/MgQueryResultsDialog.cs 2012-04-30 16:16:35 UTC (rev 6606)
@@ -3,7 +3,6 @@
using System.Data;
-using System.Linq;
using System.Text;
@@ -56,7 +55,8 @@
var propNames = new List<string>();
int propCount = reader.GetPropertyCount();
- HashSet<int> skipProps = new HashSet<int>();
+ //.net 2.0 compatibility hack for set-like behaviour
+ var skipProps = new Dictionary<int, int>();
for (int i = 0; i < propCount; i++)
var pt = reader.GetPropertyType(i);
@@ -66,7 +66,7 @@
pt == MgPropertyType.Null ||
pt == MgPropertyType.Raster)
- skipProps.Add(i);
+ skipProps[i] = i;
else
@@ -84,7 +84,7 @@
object[] values = new object[propCount];
- if (skipProps.Contains(i))
+ if (skipProps.ContainsKey(i))
continue;
if (reader.IsNull(i))
Modified: trunk/MgDev/Desktop/MapViewerTest/Form1.Designer.cs
--- trunk/MgDev/Desktop/MapViewerTest/Form1.Designer.cs 2012-04-30 15:40:30 UTC (rev 6605)
+++ trunk/MgDev/Desktop/MapViewerTest/Form1.Designer.cs 2012-04-30 16:16:35 UTC (rev 6606)
@@ -55,33 +55,31 @@
this.btnDigitizePolygon = new System.Windows.Forms.ToolStripButton();
this.toolStripSeparator1 = new System.Windows.Forms.ToolStripSeparator();
this.btnPlotToDwf = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator2 = new System.Windows.Forms.ToolStripSeparator();
this.toolStripButton1 = new System.Windows.Forms.ToolStripButton();
this.toolStripButton2 = new System.Windows.Forms.ToolStripButton();
this.toolStripButton3 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripButton4 = new System.Windows.Forms.ToolStripButton();
this.splitContainer1 = new System.Windows.Forms.SplitContainer();
this.splitContainer2 = new System.Windows.Forms.SplitContainer();
+ this.legend = new OSGeo.MapGuide.Viewer.MgLegend();
this.ctxGroup = new System.Windows.Forms.ContextMenuStrip(this.components);
this.thisIsAGroupContextMenuToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
this.ctxLayer = new System.Windows.Forms.ContextMenuStrip(this.components);
this.thisIsALayerContextMenuToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.propertyPane = new OSGeo.MapGuide.Viewer.MgPropertyPane();
+ this.viewer = new OSGeo.MapGuide.Viewer.MgMapViewer();
this.ctxViewer = new System.Windows.Forms.ContextMenuStrip(this.components);
this.refreshMapToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
this.initialViewToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
this.toolStripContainer1 = new System.Windows.Forms.ToolStripContainer();
- this.toolStripButton4 = new System.Windows.Forms.ToolStripButton();
- this.legend = new OSGeo.MapGuide.Viewer.MgLegend();
- this.propertyPane = new OSGeo.MapGuide.Viewer.MgPropertyPane();
- this.viewer = new OSGeo.MapGuide.Viewer.MgMapViewer();
this.toolbar = new OSGeo.MapGuide.Viewer.MgDefaultToolbar();
- this.toolStripSeparator2 = new System.Windows.Forms.ToolStripSeparator();
this.statusStrip1.SuspendLayout();
this.menuStrip1.SuspendLayout();
this.toolStrip1.SuspendLayout();
- ((System.ComponentModel.ISupportInitialize)(this.splitContainer1)).BeginInit();
this.splitContainer1.Panel1.SuspendLayout();
this.splitContainer1.Panel2.SuspendLayout();
this.splitContainer1.SuspendLayout();
- ((System.ComponentModel.ISupportInitialize)(this.splitContainer2)).BeginInit();
this.splitContainer2.Panel1.SuspendLayout();
this.splitContainer2.Panel2.SuspendLayout();
this.splitContainer2.SuspendLayout();
@@ -317,6 +315,11 @@
this.btnPlotToDwf.Text = "Plot current view to DWF";
this.btnPlotToDwf.Click += new System.EventHandler(this.btnPlotToDwf_Click);
+ // toolStripSeparator2
+ this.toolStripSeparator2.Name = "toolStripSeparator2";
+ this.toolStripSeparator2.Size = new System.Drawing.Size(6, 25);
// toolStripButton1
this.toolStripButton1.Image = ((System.Drawing.Image)(resources.GetObject("toolStripButton1.Image")));
@@ -344,6 +347,16 @@
this.toolStripButton3.Text = "Query";
this.toolStripButton3.Click += new System.EventHandler(this.toolStripButton3_Click);
+ // toolStripButton4
+ this.toolStripButton4.Image = ((System.Drawing.Image)(resources.GetObject("toolStripButton4.Image")));
+ this.toolStripButton4.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripButton4.Name = "toolStripButton4";
+ this.toolStripButton4.Size = new System.Drawing.Size(61, 22);
+ this.toolStripButton4.Text = "Profile";
+ this.toolStripButton4.ToolTipText = "Profile current map view";
+ this.toolStripButton4.Click += new System.EventHandler(this.toolStripButton4_Click);
// splitContainer1
this.splitContainer1.Dock = System.Windows.Forms.DockStyle.Fill;
@@ -381,6 +394,17 @@
this.splitContainer2.SplitterDistance = 236;
this.splitContainer2.TabIndex = 0;
+ // legend
+ this.legend.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.legend.GroupContextMenu = this.ctxGroup;
+ this.legend.LayerContextMenu = this.ctxLayer;
+ this.legend.Location = new System.Drawing.Point(0, 0);
+ this.legend.Name = "legend";
+ this.legend.Size = new System.Drawing.Size(208, 236);
+ this.legend.TabIndex = 0;
+ this.legend.ThemeCompressionLimit = 25;
// ctxGroup
this.ctxGroup.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
@@ -409,6 +433,28 @@
this.thisIsALayerContextMenuToolStripMenuItem.Text = "This is a layer context menu";
this.thisIsALayerContextMenuToolStripMenuItem.Click += new System.EventHandler(this.thisIsALayerContextMenuToolStripMenuItem_Click);
+ // propertyPane
+ this.propertyPane.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.propertyPane.Location = new System.Drawing.Point(0, 0);
+ this.propertyPane.Name = "propertyPane";
+ this.propertyPane.Size = new System.Drawing.Size(208, 225);
+ this.propertyPane.TabIndex = 0;
+ // viewer
+ this.viewer.ContextMenuStrip = this.ctxViewer;
+ this.viewer.ConvertTiledGroupsToNonTiled = true;
+ this.viewer.Cursor = System.Windows.Forms.Cursors.Default;
+ this.viewer.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.viewer.Location = new System.Drawing.Point(0, 0);
+ this.viewer.Name = "viewer";
+ this.viewer.SelectionColor = System.Drawing.Color.OrangeRed;
+ this.viewer.Size = new System.Drawing.Size(572, 465);
+ this.viewer.TabIndex = 1;
+ this.viewer.ZoomInFactor = 0.75;
+ this.viewer.ZoomOutFactor = 1.35;
// ctxViewer
this.ctxViewer.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
@@ -450,49 +496,6 @@
this.toolStripContainer1.TopToolStripPanel.Controls.Add(this.toolbar);
this.toolStripContainer1.TopToolStripPanel.Controls.Add(this.toolStrip1);
- // toolStripButton4
- this.toolStripButton4.Image = ((System.Drawing.Image)(resources.GetObject("toolStripButton4.Image")));
- this.toolStripButton4.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.toolStripButton4.Name = "toolStripButton4";
- this.toolStripButton4.Size = new System.Drawing.Size(61, 22);
- this.toolStripButton4.Text = "Profile";
- this.toolStripButton4.ToolTipText = "Profile current map view";
- this.toolStripButton4.Click += new System.EventHandler(this.toolStripButton4_Click);
- // legend
- this.legend.Dock = System.Windows.Forms.DockStyle.Fill;
- this.legend.GroupContextMenu = this.ctxGroup;
- this.legend.LayerContextMenu = this.ctxLayer;
- this.legend.Location = new System.Drawing.Point(0, 0);
- this.legend.Name = "legend";
- this.legend.Size = new System.Drawing.Size(208, 236);
- this.legend.TabIndex = 0;
- this.legend.ThemeCompressionLimit = 25;
- // propertyPane
- this.propertyPane.Dock = System.Windows.Forms.DockStyle.Fill;
- this.propertyPane.Location = new System.Drawing.Point(0, 0);
- this.propertyPane.Name = "propertyPane";
- this.propertyPane.Size = new System.Drawing.Size(208, 225);
- this.propertyPane.TabIndex = 0;
- // viewer
- this.viewer.ContextMenuStrip = this.ctxViewer;
- this.viewer.ConvertTiledGroupsToNonTiled = true;
- this.viewer.Cursor = System.Windows.Forms.Cursors.Default;
- this.viewer.Dock = System.Windows.Forms.DockStyle.Fill;
- this.viewer.Location = new System.Drawing.Point(0, 0);
- this.viewer.Name = "viewer";
- this.viewer.SelectionColor = System.Drawing.Color.OrangeRed;
- this.viewer.Size = new System.Drawing.Size(572, 465);
- this.viewer.TabIndex = 1;
- this.viewer.ZoomInFactor = 0.75D;
- this.viewer.ZoomOutFactor = 1.35D;
// toolbar
this.toolbar.Dock = System.Windows.Forms.DockStyle.None;
@@ -506,11 +509,6 @@
this.toolbar.Viewer = null;
this.toolbar.ZoomOutMode = OSGeo.MapGuide.Viewer.ZoomOutMode.AutoZoom;
- // toolStripSeparator2
- this.toolStripSeparator2.Name = "toolStripSeparator2";
- this.toolStripSeparator2.Size = new System.Drawing.Size(6, 25);
// Form1
this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
@@ -530,11 +528,9 @@
this.toolStrip1.PerformLayout();
this.splitContainer1.Panel1.ResumeLayout(false);
this.splitContainer1.Panel2.ResumeLayout(false);
- ((System.ComponentModel.ISupportInitialize)(this.splitContainer1)).EndInit();
this.splitContainer1.ResumeLayout(false);
this.splitContainer2.Panel1.ResumeLayout(false);
this.splitContainer2.Panel2.ResumeLayout(false);
- ((System.ComponentModel.ISupportInitialize)(this.splitContainer2)).EndInit();
this.splitContainer2.ResumeLayout(false);
this.ctxGroup.ResumeLayout(false);
this.ctxLayer.ResumeLayout(false);
Modified: trunk/MgDev/Desktop/MapViewerTest/Form1.resx
--- trunk/MgDev/Desktop/MapViewerTest/Form1.resx 2012-04-30 15:40:30 UTC (rev 6605)
+++ trunk/MgDev/Desktop/MapViewerTest/Form1.resx 2012-04-30 16:16:35 UTC (rev 6606)
@@ -112,21 +112,21 @@
<value>2.0</value>
</resheader>
<resheader name="reader">
- <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
<resheader name="writer">
- <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
- <metadata name="statusStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <metadata name="statusStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>17, 17</value>
</metadata>
- <metadata name="menuStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <metadata name="menuStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>133, 17</value>
</metadata>
- <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>248, 17</value>
</metadata>
- <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="toolStripButton1.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
@@ -187,16 +187,16 @@
KlSA8/zRh9ABIDUG+1JpAAAAAElFTkSuQmCC
</value>
</data>
- <metadata name="ctxGroup.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <metadata name="ctxGroup.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>444, 17</value>
</metadata>
- <metadata name="ctxLayer.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <metadata name="ctxLayer.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>545, 17</value>
</metadata>
- <metadata name="ctxViewer.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <metadata name="ctxViewer.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>641, 17</value>
</metadata>
- <metadata name="toolbar.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <metadata name="toolbar.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>353, 17</value>
</metadata>
</root>
\ No newline at end of file
Modified: trunk/MgDev/Desktop/MgDesktop/MgDesktop.vcproj
--- trunk/MgDev/Desktop/MgDesktop/MgDesktop.vcproj 2012-04-30 15:40:30 UTC (rev 6605)
+++ trunk/MgDev/Desktop/MgDesktop/MgDesktop.vcproj 2012-04-30 16:16:35 UTC (rev 6606)
@@ -105,9 +105,9 @@
</Configuration>
<Configuration
- Name="Release|Win32"
- OutputDirectory="..\bin\release"
- IntermediateDirectory="..\obj\release"
+ Name="Debug|x64"
+ OutputDirectory="$(PlatformName)\$(ConfigurationName)"
+ IntermediateDirectory="$(PlatformName)\$(ConfigurationName)"
ConfigurationType="2"
CharacterSet="1"
WholeProgramOptimization="1"
@@ -126,15 +126,18 @@
<Tool
Name="VCMIDLTool"
+ TargetEnvironment="3"
<Tool
Name="VCCLCompilerTool"
- Optimization="2"
- EnableIntrinsicFunctions="true"
+ Optimization="0"
+ EnableIntrinsicFunctions="false"
AdditionalIncludeDirectories="..\..\Common\Foundation;..\..\Common\PlatformBase;..\..\Common\Geometry;..\..\Common\MdfModel;..\..\Common\MdfParser;..\..\Oem\ACE\ACE_wrappers;"..\..\Oem\dbxml\xerces-c-src\src";..\..\Oem\FDO\Inc;..\..\Oem\FDO\Inc\ExpressionEngine;..\..\Common\Renderers;..\..\Common\Stylization;..\..\Oem\DWFTK7.1\develop\global\src;..\..\Oem\DWFTK7.1\develop\global\src\dwf;..\..\Server\src\Gws\Include;..\..\Server\src\Gws\GwsCommon\inc;..\..\Server\src\Gws\GwsQueryEngine\inc"
- PreprocessorDefinitions="WIN32;NDEBUG;_WINDOWS;_USRDLL;DESKTOP_EXPORTS;DWFCORE_STATIC;DWFTK_STATIC;DWFTK_USE_DWFCORE_ZLIB;DWFTK_BUILD_EXPAT;WHIP_STATIC_LIB"
+ PreprocessorDefinitions="WIN32;DEBUG;_WINDOWS;_USRDLL;DESKTOP_EXPORTS;DWFCORE_STATIC;DWFTK_STATIC;DWFTK_USE_DWFCORE_ZLIB;DWFTK_BUILD_EXPAT;WHIP_STATIC_LIB"
+ MinimalRebuild="true"
ExceptionHandling="1"
- RuntimeLibrary="2"
+ BasicRuntimeChecks="3"
+ RuntimeLibrary="3"
EnableFunctionLevelLinking="true"
WarningLevel="3"
DebugInformationFormat="3"
@@ -150,17 +153,20 @@
<Tool
Name="VCLinkerTool"
- AdditionalDependencies="FDO.lib FDOCommon.lib FDOGeometry.lib ExpressionEngine.lib ACE.lib MgFoundation.lib MgGeometry.lib MgMdfModel.lib MgMdfParser.lib MgPlatformBase.lib MgRenderers.lib MgStylization.lib MgGwsCommon.lib MgGwsQueryEngine.lib xerces-c_3mg.lib dwfcore_wt.1.1.1.lib dwftk_wt.7.1.1.lib whiptk_wt.7.7.601.lib"
- OutputFile="$(OutDir)\$(ProjectName).dll"
+ AdditionalDependencies="FDO.lib FDOCommon.lib FDOGeometry.lib ExpressionEngine.lib ACEd.lib MgFoundationd.lib MgGeometryd.lib MgMdfModeld.lib MgMdfParserd.lib MgPlatformBased.lib MgRenderersd.lib MgStylizationd.lib MgGwsCommond.lib MgGwsQueryEngined.lib xerces-c_3mgD.lib dwfcore_wt.1.1.1.lib dwftk_wt.7.1.1.lib whiptk_wt.7.7.601.lib"
+ ShowProgress="0"
+ OutputFile="$(OutDir)\MgDesktopd.dll"
LinkIncremental="1"
- AdditionalLibraryDirectories="..\..\Oem\ACE\ACE_wrappers\lib;..\..\Oem\FDO\Lib;..\..\Oem\DWFTK7.1\develop\global\lib\static\release\vc8.0;"..\..\Oem\dbxml\xerces-c-src\Build\Win32\VC9\Release";..\..\Common\lib\release;..\..\Server\lib\release"
- DelayLoadDLLs="MgMdfParser.dll;MgGeometry.dll;MgGwsCommon.dll;MgGwsResource.dll;xerces-c_3_1mg.dll;FDO.dll;FDOCommon.dll;MgStylization.dll;FDOGeometry.dll;ExpressionEngine.dll"
+ AdditionalLibraryDirectories="..\..\Oem\ACE\ACE_wrappers\lib64;..\..\Oem\FDO\Lib64;..\..\Oem\DWFTK7.1\develop\global\lib\static\debug64\vc8.0;"..\..\Oem\dbxml\xerces-c-src\Build\x64\VC9\Debug";..\..\Common\lib\debug64;..\..\Server\lib\debug64"
+ DelayLoadDLLs="FDO.dll;FDOCommon.dll;FDOGeometry.dll;ExpressionEngine.dll"
GenerateDebugInformation="true"
SubSystem="2"
- OptimizeReferences="2"
- EnableCOMDATFolding="2"
- ImportLibrary="..\lib\release\MgDesktop.lib"
- TargetMachine="1"
+ OptimizeReferences="0"
+ EnableCOMDATFolding="0"
+ RandomizedBaseAddress="1"
+ DataExecutionPrevention="0"
+ ImportLibrary="..\lib\debug\MgDesktopd.lib"
+ TargetMachine="17"
<Tool
Name="VCALinkTool"
@@ -186,9 +192,9 @@
</Configuration>
<Configuration
- Name="Debug|x64"
- OutputDirectory="$(PlatformName)\$(ConfigurationName)"
- IntermediateDirectory="$(PlatformName)\$(ConfigurationName)"
+ Name="Release|Win32"
+ OutputDirectory="..\bin\release"
+ IntermediateDirectory="..\obj\release"
CharacterSet="1"
@@ -207,18 +213,15 @@
<Tool
Name="VCMIDLTool"
- TargetEnvironment="3"
<Tool
- Optimization="0"
- EnableIntrinsicFunctions="false"
+ Optimization="2"
+ EnableIntrinsicFunctions="true"
- PreprocessorDefinitions="WIN32;DEBUG;_WINDOWS;_USRDLL;DESKTOP_EXPORTS;DWFCORE_STATIC;DWFTK_STATIC;DWFTK_USE_DWFCORE_ZLIB;DWFTK_BUILD_EXPAT;WHIP_STATIC_LIB"
- MinimalRebuild="true"
+ PreprocessorDefinitions="WIN32;NDEBUG;_WINDOWS;_USRDLL;DESKTOP_EXPORTS;DWFCORE_STATIC;DWFTK_STATIC;DWFTK_USE_DWFCORE_ZLIB;DWFTK_BUILD_EXPAT;WHIP_STATIC_LIB"
- BasicRuntimeChecks="3"
- RuntimeLibrary="3"
+ RuntimeLibrary="2"
WarningLevel="3"
@@ -234,20 +237,17 @@
<Tool
Name="VCLinkerTool"
- AdditionalDependencies="FDO.lib FDOCommon.lib FDOGeometry.lib ExpressionEngine.lib ACEd.lib MgFoundationd.lib MgGeometryd.lib MgMdfModeld.lib MgMdfParserd.lib MgPlatformBased.lib MgRenderersd.lib MgStylizationd.lib MgGwsCommond.lib MgGwsQueryEngined.lib xerces-c_3mgD.lib dwfcore_wt.1.1.1.lib dwftk_wt.7.1.1.lib whiptk_wt.7.7.601.lib"
- ShowProgress="0"
- OutputFile="$(OutDir)\MgDesktopd.dll"
+ AdditionalDependencies="FDO.lib FDOCommon.lib FDOGeometry.lib ExpressionEngine.lib ACE.lib MgFoundation.lib MgGeometry.lib MgMdfModel.lib MgMdfParser.lib MgPlatformBase.lib MgRenderers.lib MgStylization.lib MgGwsCommon.lib MgGwsQueryEngine.lib xerces-c_3mg.lib dwfcore_wt.1.1.1.lib dwftk_wt.7.1.1.lib whiptk_wt.7.7.601.lib"
+ OutputFile="$(OutDir)\$(ProjectName).dll"
LinkIncremental="1"
- AdditionalLibraryDirectories="..\..\Oem\ACE\ACE_wrappers\lib64;..\..\Oem\FDO\Lib64;..\..\Oem\DWFTK7.1\develop\global\lib\static\debug64\vc8.0;"..\..\Oem\dbxml\xerces-c-src\Build\x64\VC9\Debug";..\..\Common\lib\debug64;..\..\Server\lib\debug64"
- DelayLoadDLLs="FDO.dll;FDOCommon.dll;FDOGeometry.dll;ExpressionEngine.dll"
+ AdditionalLibraryDirectories="..\..\Oem\ACE\ACE_wrappers\lib;..\..\Oem\FDO\Lib;..\..\Oem\DWFTK7.1\develop\global\lib\static\release\vc8.0;"..\..\Oem\dbxml\xerces-c-src\Build\Win32\VC9\Release";..\..\Common\lib\release;..\..\Server\lib\release"
+ DelayLoadDLLs="MgMdfParser.dll;MgGeometry.dll;MgGwsCommon.dll;MgGwsResource.dll;xerces-c_3_1mg.dll;FDO.dll;FDOCommon.dll;MgStylization.dll;FDOGeometry.dll;ExpressionEngine.dll"
SubSystem="2"
- OptimizeReferences="0"
- EnableCOMDATFolding="0"
- RandomizedBaseAddress="1"
- DataExecutionPrevention="0"
- ImportLibrary="..\lib\debug\MgDesktopd.lib"
- TargetMachine="17"
+ OptimizeReferences="2"
+ EnableCOMDATFolding="2"
+ ImportLibrary="..\lib\release\MgDesktop.lib"
+ TargetMachine="1"
<Tool
Name="VCALinkTool"
@@ -375,7 +375,7 @@
</FileConfiguration>
<FileConfiguration
+ Name="Debug|x64"
ExcludedFromBuild="true"
<Tool
@@ -383,7 +383,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -411,7 +411,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -419,7 +419,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -447,7 +447,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -455,7 +455,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -483,7 +483,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -491,7 +491,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -519,7 +519,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -527,7 +527,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -555,7 +555,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -563,7 +563,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -591,7 +591,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -599,7 +599,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -627,7 +627,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -635,7 +635,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -663,7 +663,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -671,7 +671,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -699,7 +699,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -707,7 +707,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -735,7 +735,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -743,7 +743,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -771,7 +771,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -779,7 +779,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -807,7 +807,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -815,7 +815,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -843,7 +843,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -851,7 +851,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -879,7 +879,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -887,7 +887,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -915,7 +915,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -923,7 +923,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -951,7 +951,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -959,7 +959,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -987,7 +987,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -995,7 +995,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1023,7 +1023,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1031,7 +1031,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1059,7 +1059,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1067,7 +1067,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1095,7 +1095,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1103,7 +1103,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1131,7 +1131,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1139,7 +1139,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1167,7 +1167,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1175,7 +1175,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1203,7 +1203,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1211,7 +1211,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1239,7 +1239,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1247,7 +1247,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1275,7 +1275,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1283,7 +1283,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1311,7 +1311,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1319,7 +1319,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1347,7 +1347,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1355,7 +1355,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1383,7 +1383,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1391,7 +1391,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1419,7 +1419,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1427,7 +1427,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1455,7 +1455,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1463,7 +1463,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1491,7 +1491,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1499,7 +1499,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1527,7 +1527,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1535,7 +1535,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1563,7 +1563,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1571,7 +1571,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1599,7 +1599,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1607,7 +1607,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1635,7 +1635,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1643,7 +1643,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1671,7 +1671,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1679,7 +1679,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1707,7 +1707,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1715,7 +1715,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1743,7 +1743,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1751,7 +1751,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1779,7 +1779,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1787,7 +1787,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1815,7 +1815,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1823,7 +1823,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1851,7 +1851,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1859,7 +1859,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1887,7 +1887,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1895,7 +1895,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1923,7 +1923,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1931,7 +1931,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1959,7 +1959,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -1967,7 +1967,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -1995,7 +1995,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2003,7 +2003,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2031,7 +2031,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2039,7 +2039,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2067,7 +2067,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2075,7 +2075,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2107,7 +2107,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2115,7 +2115,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2143,7 +2143,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2151,7 +2151,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2179,7 +2179,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2187,7 +2187,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2215,7 +2215,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2223,7 +2223,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2251,7 +2251,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2259,7 +2259,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2287,6 +2287,14 @@
<FileConfiguration
+ Name="Debug|x64"
+ ExcludedFromBuild="true"
+ <Tool
+ Name="VCCLCompilerTool"
+ </FileConfiguration>
+ <FileConfiguration
@@ -2295,6 +2303,26 @@
<FileConfiguration
+ Name="Release|x64"
+ <Tool
+ </File>
+ <File
+ RelativePath=".\Services\ProfilingService.cpp"
+ Name="Debug|Win32"
+ <Tool
Name="Debug|x64"
@@ -2303,6 +2331,14 @@
<FileConfiguration
+ <Tool
Name="Release|x64"
@@ -2323,7 +2359,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2331,7 +2367,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2359,7 +2395,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2367,7 +2403,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2395,7 +2431,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2403,7 +2439,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2431,7 +2467,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2439,7 +2475,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2467,7 +2503,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2475,7 +2511,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2503,7 +2539,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2511,7 +2547,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2539,7 +2575,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2547,7 +2583,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2575,7 +2611,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2583,7 +2619,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2611,7 +2647,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2619,7 +2655,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2647,7 +2683,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2655,7 +2691,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2683,7 +2719,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2691,7 +2727,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2719,7 +2755,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2727,7 +2763,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2755,7 +2791,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2763,7 +2799,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2791,7 +2827,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2799,7 +2835,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2827,7 +2863,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2835,7 +2871,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2863,7 +2899,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2871,7 +2907,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2899,7 +2935,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2907,7 +2943,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2935,7 +2971,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2943,7 +2979,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -2971,7 +3007,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -2979,7 +3015,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -3007,7 +3043,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -3015,7 +3051,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -3043,7 +3079,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -3051,7 +3087,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -3079,7 +3115,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -3087,7 +3123,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -3115,7 +3151,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -3123,7 +3159,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -3151,6 +3187,14 @@
<FileConfiguration
+ Name="Debug|x64"
+ <Tool
@@ -3159,6 +3203,26 @@
<FileConfiguration
+ <Tool
+ </File>
+ <File
+ RelativePath=".\System\TimerUtil.cpp"
+ <Tool
Name="Debug|x64"
@@ -3167,6 +3231,14 @@
<FileConfiguration
+ <Tool
Name="Release|x64"
@@ -3187,7 +3259,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -3195,7 +3267,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -3223,7 +3295,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -3231,7 +3303,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -3259,7 +3331,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -3267,7 +3339,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -3295,7 +3367,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -3303,7 +3375,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -3331,7 +3403,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -3339,7 +3411,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -3367,7 +3439,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -3375,7 +3447,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -3403,7 +3475,7 @@
<FileConfiguration
+ Name="Debug|x64"
<Tool
@@ -3411,7 +3483,7 @@
<FileConfiguration
- Name="Debug|x64"
<Tool
@@ -3682,6 +3754,10 @@
</File>
<File
+ RelativePath=".\Services\ProfilingService.h"
+ </File>
+ <File
RelativePath=".\Services\Feature\ProjectedFeatureReader.h"
</File>
@@ -3782,6 +3858,10 @@
</File>
<File
+ RelativePath=".\System\TimerUtil.h"
+ </File>
+ <File
RelativePath=".\Services\Transaction.h"
</File>
Modified: trunk/MgDev/Desktop/UnitTest/UnitTest.vcproj
--- trunk/MgDev/Desktop/UnitTest/UnitTest.vcproj 2012-04-30 15:40:30 UTC (rev 6605)
+++ trunk/MgDev/Desktop/UnitTest/UnitTest.vcproj 2012-04-30 16:16:35 UTC (rev 6606)
@@ -442,6 +442,10 @@
</File>
<File
+ RelativePath=".\TestProfilingService.cpp"
+ </File>
+ <File
RelativePath=".\TestRenderingService.cpp"
</File>
@@ -480,6 +484,10 @@
</File>
<File
+ RelativePath=".\TestProfilingService.h"
+ </File>
+ <File
RelativePath=".\TestRenderingService.h"
</File>
More information about the mapguide-commits
