[mapguide-commits] r6932 - in trunk/Tools/Maestro: Maestro.Editors Maestro.Editors/Fusion Maestro.Editors/Fusion/WidgetEditors OSGeo.MapGuide.MaestroAPI/ObjectModels OSGeo.MapGuide.MaestroAPI/Properties OSGeo.MapGuide.MaestroAPI/Resource/Validation
svn_mapguide at osgeo.org
Thu Aug 2 06:48:05 PDT 2012
Author: jng
Date: 2012-08-02 06:48:04 -0700 (Thu, 02 Aug 2012)
New Revision: 6932
Added:
trunk/Tools/Maestro/Maestro.Editors/Fusion/MenuCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Fusion/MenuCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/Fusion/MenuCtrl.resx
trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/WidgetInfoDialog.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/WidgetInfoDialog.cs
trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/WidgetInfoDialog.resx
trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/GenericWidgetCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/GenericWidgetCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/GenericWidgetCtrl.resx
trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetReferenceCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetReferenceCtrl.resx
trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetSettingsCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinitionInterfaces.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ApplicationDefinitionValidator.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ResourceValidatorSet.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ValidationStatusCode.cs
#2089, #1635: Fusion editor fixes and enhancements:
- Generic Widget XML editor fixes/enhancements:
- Fix Generic Widget XML editor incorrectly saving extension elements. It was previously doing it by element name which is wrong because a widget can have multiple extension elements of the same name.
- Add a Widget Info button that shows available extension properties for the current widget
- New validation rules:
- Check for widget references to non-existent widgets
- Check for non-UI widgets being attached to containers. You wouldn't want to attach a Map widget to a menu!
- Check for referenced widgets with no labels or icons. These probably won't be displayed in such cases.
- Widget section fixes:
- Add missing menu properties editor for Flyout menus
- Enable Move up/down when flyout menus are selected
- Enable assorted functionality that was previously disabled when a flyout menu is selected.
- Fix missing labels for widgets under the "View" menu of a new Fusion template. Thank the new validation rules in place that caught this out.
- If a NullReferenceException is thrown during a validation run, log the full gory details instead of going through the NestedExceptionMessageProcessor
Added: trunk/Tools/Maestro/Maestro.Editors/Fusion/MenuCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/MenuCtrl.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/MenuCtrl.Designer.cs 2012-08-02 13:48:04 UTC (rev 6932)
@@ -0,0 +1,115 @@
+namespace Maestro.Editors.Fusion
+ partial class MenuCtrl
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Component Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(MenuCtrl));
+ this.label1 = new System.Windows.Forms.Label();
+ this.txtMenuLabel = new System.Windows.Forms.TextBox();
+ this.txtTooltip = new System.Windows.Forms.TextBox();
+ this.label2 = new System.Windows.Forms.Label();
+ this.txtImageUrl = new System.Windows.Forms.TextBox();
+ this.label3 = new System.Windows.Forms.Label();
+ this.txtImageClass = new System.Windows.Forms.TextBox();
+ this.label4 = new System.Windows.Forms.Label();
+ this.SuspendLayout();
+ // label1
+ resources.ApplyResources(this.label1, "label1");
+ this.label1.Name = "label1";
+ // txtMenuLabel
+ resources.ApplyResources(this.txtMenuLabel, "txtMenuLabel");
+ this.txtMenuLabel.Name = "txtMenuLabel";
+ this.txtMenuLabel.TextChanged += new System.EventHandler(this.txtMenuLabel_TextChanged);
+ // txtTooltip
+ resources.ApplyResources(this.txtTooltip, "txtTooltip");
+ this.txtTooltip.Name = "txtTooltip";
+ this.txtTooltip.TextChanged += new System.EventHandler(this.txtTooltip_TextChanged);
+ // label2
+ resources.ApplyResources(this.label2, "label2");
+ this.label2.Name = "label2";
+ // txtImageUrl
+ resources.ApplyResources(this.txtImageUrl, "txtImageUrl");
+ this.txtImageUrl.Name = "txtImageUrl";
+ this.txtImageUrl.TextChanged += new System.EventHandler(this.txtImageUrl_TextChanged);
+ // label3
+ resources.ApplyResources(this.label3, "label3");
+ this.label3.Name = "label3";
+ // txtImageClass
+ resources.ApplyResources(this.txtImageClass, "txtImageClass");
+ this.txtImageClass.Name = "txtImageClass";
+ this.txtImageClass.TextChanged += new System.EventHandler(this.txtImageClass_TextChanged);
+ // label4
+ resources.ApplyResources(this.label4, "label4");
+ this.label4.Name = "label4";
+ // MenuCtrl
+ resources.ApplyResources(this, "$this");
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.Controls.Add(this.txtImageClass);
+ this.Controls.Add(this.label4);
+ this.Controls.Add(this.txtImageUrl);
+ this.Controls.Add(this.label3);
+ this.Controls.Add(this.txtTooltip);
+ this.Controls.Add(this.label2);
+ this.Controls.Add(this.txtMenuLabel);
+ this.Controls.Add(this.label1);
+ this.Name = "MenuCtrl";
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.TextBox txtMenuLabel;
+ private System.Windows.Forms.TextBox txtTooltip;
+ private System.Windows.Forms.Label label2;
+ private System.Windows.Forms.TextBox txtImageUrl;
+ private System.Windows.Forms.Label label3;
+ private System.Windows.Forms.TextBox txtImageClass;
+ private System.Windows.Forms.Label label4;
Added: trunk/Tools/Maestro/Maestro.Editors/Fusion/MenuCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/MenuCtrl.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/MenuCtrl.cs 2012-08-02 13:48:04 UTC (rev 6932)
@@ -0,0 +1,91 @@
+#region Disclaimer / License
+// Copyright (C) 2012, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Drawing;
+using System.Data;
+using System.Linq;
+using System.Text;
+using System.Windows.Forms;
+using OSGeo.MapGuide.ObjectModels.ApplicationDefinition;
+ [ToolboxItem(false)]
+ public partial class MenuCtrl : UserControl
+ private MenuCtrl()
+ InitializeComponent();
+ private IFlyoutItem _menu;
+ private IEditorService _edSvc;
+ private bool _init = false;
+ public MenuCtrl(IFlyoutItem menu, IEditorService edSvc)
+ : this()
+ _menu = menu;
+ _edSvc = edSvc;
+ _init = true;
+ try
+ txtMenuLabel.Text = _menu.Label;
+ txtImageClass.Text = _menu.ImageClass;
+ txtImageUrl.Text = _menu.ImageUrl;
+ txtTooltip.Text = _menu.Tooltip;
+ finally
+ _init = false;
+ private void txtMenuLabel_TextChanged(object sender, EventArgs e)
+ if (_init)
+ return;
+ _menu.Label = txtMenuLabel.Text;
+ private void txtTooltip_TextChanged(object sender, EventArgs e)
+ if (_init)
+ return;
+ _menu.Tooltip = txtTooltip.Text;
+ private void txtImageUrl_TextChanged(object sender, EventArgs e)
+ if (_init)
+ return;
+ _menu.ImageUrl = txtImageUrl.Text;
+ private void txtImageClass_TextChanged(object sender, EventArgs e)
+ if (_init)
+ return;
+ _menu.ImageClass = txtImageClass.Text;
Added: trunk/Tools/Maestro/Maestro.Editors/Fusion/MenuCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/MenuCtrl.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/MenuCtrl.resx 2012-08-02 13:48:04 UTC (rev 6932)
@@ -0,0 +1,351 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="label1.AutoSize" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>18, 17</value>
+ </data>
+ <data name="label1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>33, 13</value>
+ </data>
+ <data name="label1.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="label1.Text" xml:space="preserve">
+ <value>Label</value>
+ </data>
+ <data name=">>label1.Name" xml:space="preserve">
+ <value>label1</value>
+ </data>
+ <data name=">>label1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>label1.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>label1.ZOrder" xml:space="preserve">
+ <value>7</value>
+ </data>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="txtMenuLabel.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Left, Right</value>
+ </data>
+ <data name="txtMenuLabel.Location" type="System.Drawing.Point, System.Drawing">
+ <value>112, 14</value>
+ </data>
+ <data name="txtMenuLabel.Size" type="System.Drawing.Size, System.Drawing">
+ <value>260, 20</value>
+ </data>
+ <data name="txtMenuLabel.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name=">>txtMenuLabel.Name" xml:space="preserve">
+ <value>txtMenuLabel</value>
+ </data>
+ <data name=">>txtMenuLabel.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>txtMenuLabel.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtMenuLabel.ZOrder" xml:space="preserve">
+ <value>6</value>
+ </data>
+ <data name="txtTooltip.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="txtTooltip.Location" type="System.Drawing.Point, System.Drawing">
+ <value>112, 40</value>
+ </data>
+ <data name="txtTooltip.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="txtTooltip.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name=">>txtTooltip.Name" xml:space="preserve">
+ <value>txtTooltip</value>
+ </data>
+ <data name=">>txtTooltip.Type" xml:space="preserve">
+ </data>
+ <data name=">>txtTooltip.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtTooltip.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="label2.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label2.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ <value>NoControl</value>
+ </data>
+ <data name="label2.Location" type="System.Drawing.Point, System.Drawing">
+ <value>18, 43</value>
+ </data>
+ <data name="label2.Size" type="System.Drawing.Size, System.Drawing">
+ <value>39, 13</value>
+ </data>
+ <data name="label2.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="label2.Text" xml:space="preserve">
+ <value>Tooltip</value>
+ </data>
+ <data name=">>label2.Name" xml:space="preserve">
+ <value>label2</value>
+ </data>
+ <data name=">>label2.Type" xml:space="preserve">
+ </data>
+ <data name=">>label2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label2.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
+ <data name="txtImageUrl.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="txtImageUrl.Location" type="System.Drawing.Point, System.Drawing">
+ <value>112, 66</value>
+ </data>
+ <data name="txtImageUrl.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="txtImageUrl.TabIndex" type="System.Int32, mscorlib">
+ <value>5</value>
+ </data>
+ <data name=">>txtImageUrl.Name" xml:space="preserve">
+ <value>txtImageUrl</value>
+ </data>
+ <data name=">>txtImageUrl.Type" xml:space="preserve">
+ </data>
+ <data name=">>txtImageUrl.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtImageUrl.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="label3.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label3.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <data name="label3.Location" type="System.Drawing.Point, System.Drawing">
+ <value>18, 69</value>
+ </data>
+ <data name="label3.Size" type="System.Drawing.Size, System.Drawing">
+ <value>61, 13</value>
+ </data>
+ <data name="label3.TabIndex" type="System.Int32, mscorlib">
+ <value>4</value>
+ </data>
+ <data name="label3.Text" xml:space="preserve">
+ <value>Image URL</value>
+ </data>
+ <data name=">>label3.Name" xml:space="preserve">
+ <value>label3</value>
+ </data>
+ <data name=">>label3.Type" xml:space="preserve">
+ </data>
+ <data name=">>label3.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label3.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="txtImageClass.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="txtImageClass.Location" type="System.Drawing.Point, System.Drawing">
+ <value>112, 92</value>
+ </data>
+ <data name="txtImageClass.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="txtImageClass.TabIndex" type="System.Int32, mscorlib">
+ <value>7</value>
+ </data>
+ <data name=">>txtImageClass.Name" xml:space="preserve">
+ <value>txtImageClass</value>
+ </data>
+ <data name=">>txtImageClass.Type" xml:space="preserve">
+ </data>
+ <data name=">>txtImageClass.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtImageClass.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="label4.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label4.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <data name="label4.Location" type="System.Drawing.Point, System.Drawing">
+ <value>18, 95</value>
+ </data>
+ <data name="label4.Size" type="System.Drawing.Size, System.Drawing">
+ <value>88, 13</value>
+ </data>
+ <data name="label4.TabIndex" type="System.Int32, mscorlib">
+ <value>6</value>
+ </data>
+ <data name="label4.Text" xml:space="preserve">
+ <value>Image CSS Class</value>
+ </data>
+ <data name=">>label4.Name" xml:space="preserve">
+ <value>label4</value>
+ </data>
+ <data name=">>label4.Type" xml:space="preserve">
+ </data>
+ <data name=">>label4.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label4.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ </metadata>
+ <data name="$this.AutoScaleDimensions" type="System.Drawing.SizeF, System.Drawing">
+ <value>6, 13</value>
+ </data>
+ <data name="$this.Size" type="System.Drawing.Size, System.Drawing">
+ <value>400, 330</value>
+ </data>
+ <data name=">>$this.Name" xml:space="preserve">
+ <value>MenuCtrl</value>
+ </data>
+ <data name=">>$this.Type" xml:space="preserve">
+ <value>System.Windows.Forms.UserControl, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/GenericWidgetCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/GenericWidgetCtrl.Designer.cs 2012-07-31 16:32:38 UTC (rev 6931)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/GenericWidgetCtrl.Designer.cs 2012-08-02 13:48:04 UTC (rev 6932)
@@ -32,6 +32,7 @@
this.txtXmlContent = new System.Windows.Forms.TextBox();
this.btnSave = new System.Windows.Forms.Button();
+ this.btnWidgetInfo = new System.Windows.Forms.Button();
// label1
@@ -52,9 +53,17 @@
this.btnSave.UseVisualStyleBackColor = true;
this.btnSave.Click += new System.EventHandler(this.btnSave_Click);
+ // btnWidgetInfo
+ resources.ApplyResources(this.btnWidgetInfo, "btnWidgetInfo");
+ this.btnWidgetInfo.Name = "btnWidgetInfo";
+ this.btnWidgetInfo.UseVisualStyleBackColor = true;
+ this.btnWidgetInfo.Click += new System.EventHandler(this.btnWidgetInfo_Click);
// GenericWidgetCtrl
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
+ this.Controls.Add(this.btnWidgetInfo);
this.Controls.Add(this.btnSave);
this.Controls.Add(this.txtXmlContent);
@@ -70,5 +79,6 @@
private System.Windows.Forms.TextBox txtXmlContent;
private System.Windows.Forms.Button btnSave;
+ private System.Windows.Forms.Button btnWidgetInfo;
Modified: trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/GenericWidgetCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/GenericWidgetCtrl.cs 2012-07-31 16:32:38 UTC (rev 6931)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/GenericWidgetCtrl.cs 2012-08-02 13:48:04 UTC (rev 6932)
@@ -42,11 +42,14 @@
private string _xml;
private IWidget _widget;
+ private IWidgetInfo _widgetInfo;
public void Setup(IWidget widget, FlexibleLayoutEditorContext context, IEditorService edsvc)
_widget = widget;
_xml = _widget.ToXml();
+ _widgetInfo = context.GetWidgetInfo(widget.Type);
+ btnWidgetInfo.Enabled = (_widgetInfo != null);
txtXmlContent.Text = _xml;
@@ -85,9 +88,12 @@
if (node != null)
List<XmlElement> elements = new List<XmlElement>();
- foreach (XmlNode child in node.ChildNodes)
+ //foreach (XmlNode child in node.ChildNodes)
+ for (int i = 0; i < node.ChildNodes.Count; i++)
- elements.Add(node[child.Name]);
+ var el = doc.CreateElement(node.ChildNodes[i].Name);
+ el.InnerXml = node.ChildNodes[i].InnerXml;
+ elements.Add(el);
_widget.Extension.Content = elements.ToArray();
@@ -131,5 +137,11 @@
MessageBox.Show(ex.Message);
+ private void btnWidgetInfo_Click(object sender, EventArgs e)
+ if (_widgetInfo != null)
+ new WidgetInfoDialog(_widgetInfo).ShowDialog();
Modified: trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/GenericWidgetCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/GenericWidgetCtrl.resx 2012-07-31 16:32:38 UTC (rev 6931)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/GenericWidgetCtrl.resx 2012-08-02 13:48:04 UTC (rev 6932)
@@ -112,16 +112,16 @@
<value>2.0</value>
</resheader>
- <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
- <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
- <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<value>True</value>
</data>
- <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<value>15, 11</value>
</data>
@@ -138,15 +138,15 @@
</data>
- <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
</data>
- <value>2</value>
+ <value>3</value>
</data>
- <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="txtXmlContent.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Bottom, Left, Right</value>
</data>
@@ -168,17 +168,20 @@
<data name="txtXmlContent.TabIndex" type="System.Int32, mscorlib">
<value>1</value>
</data>
+ <data name="txtXmlContent.WordWrap" type="System.Boolean, mscorlib">
+ <value>False</value>
+ </data>
<data name=">>txtXmlContent.Name" xml:space="preserve">
<value>txtXmlContent</value>
</data>
<data name=">>txtXmlContent.Type" xml:space="preserve">
- <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>txtXmlContent.Parent" xml:space="preserve">
</data>
<data name=">>txtXmlContent.ZOrder" xml:space="preserve">
- <value>1</value>
+ <value>2</value>
</data>
<data name="btnSave.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Bottom, Left</value>
@@ -202,15 +205,45 @@
<value>btnSave</value>
</data>
<data name=">>btnSave.Type" xml:space="preserve">
- <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>btnSave.Parent" xml:space="preserve">
</data>
<data name=">>btnSave.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="btnWidgetInfo.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Bottom, Left</value>
+ </data>
+ <data name="btnWidgetInfo.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <data name="btnWidgetInfo.Location" type="System.Drawing.Point, System.Drawing">
+ <value>99, 380</value>
+ </data>
+ <data name="btnWidgetInfo.Size" type="System.Drawing.Size, System.Drawing">
+ <value>75, 23</value>
+ </data>
+ <data name="btnWidgetInfo.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="btnWidgetInfo.Text" xml:space="preserve">
+ <value>Widget Info</value>
+ </data>
+ <data name=">>btnWidgetInfo.Name" xml:space="preserve">
+ <value>btnWidgetInfo</value>
+ </data>
+ <data name=">>btnWidgetInfo.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnWidgetInfo.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnWidgetInfo.ZOrder" xml:space="preserve">
<value>0</value>
</data>
- <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
@@ -220,6 +253,6 @@
<value>GenericWidgetCtrl</value>
</data>
- <value>System.Windows.Forms.UserControl, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
</root>
Added: trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/WidgetInfoDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/WidgetInfoDialog.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/WidgetInfoDialog.Designer.cs 2012-08-02 13:48:04 UTC (rev 6932)
@@ -0,0 +1,78 @@
+namespace Maestro.Editors.Fusion.WidgetEditors
+ partial class WidgetInfoDialog
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// </summary>
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(WidgetInfoDialog));
+ this.grdExtensionProperties = new System.Windows.Forms.DataGridView();
+ ((System.ComponentModel.ISupportInitialize)(this.grdExtensionProperties)).BeginInit();
+ // label1
+ // label2
+ // grdExtensionProperties
+ this.grdExtensionProperties.AllowUserToAddRows = false;
+ this.grdExtensionProperties.AllowUserToDeleteRows = false;
+ resources.ApplyResources(this.grdExtensionProperties, "grdExtensionProperties");
+ this.grdExtensionProperties.ColumnHeadersHeightSizeMode = System.Windows.Forms.DataGridViewColumnHeadersHeightSizeMode.AutoSize;
+ this.grdExtensionProperties.Name = "grdExtensionProperties";
+ this.grdExtensionProperties.ReadOnly = true;
+ // WidgetInfoDialog
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
+ this.Controls.Add(this.grdExtensionProperties);
+ this.Name = "WidgetInfoDialog";
+ this.ShowIcon = false;
+ ((System.ComponentModel.ISupportInitialize)(this.grdExtensionProperties)).EndInit();
+ #endregion
+ private System.Windows.Forms.DataGridView grdExtensionProperties;
Added: trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/WidgetInfoDialog.cs
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/WidgetInfoDialog.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/WidgetInfoDialog.cs 2012-08-02 13:48:04 UTC (rev 6932)
@@ -0,0 +1,41 @@
+#endregion
+using System;
+using System.Data;
+using System.Linq;
+using System.Text;
+ public partial class WidgetInfoDialog : Form
+ public WidgetInfoDialog(IWidgetInfo info)
+ this.Text += " - " + info.Type;
+ grdExtensionProperties.DataSource = info.Parameters;
Added: trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/WidgetInfoDialog.resx
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/WidgetInfoDialog.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetEditors/WidgetInfoDialog.resx 2012-08-02 13:48:04 UTC (rev 6932)
@@ -0,0 +1,216 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ <data name="label1.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <value>13, 13</value>
+ </data>
+ <value>637, 45</value>
+ </data>
+ <value>0</value>
+ </data>
+ <value>This widget defines the following extension properties. When editing a widget in XML form, such properties are specified in the <Extension> element of the given widget</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>2</value>
+ </data>
+ </data>
+ <value>13, 70</value>
+ </data>
+ <value>103, 13</value>
+ </data>
+ <value>1</value>
+ </data>
+ <value>Extension Properties</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>1</value>
+ </data>
+ <data name="grdExtensionProperties.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Bottom, Left, Right</value>
+ </data>
+ <data name="grdExtensionProperties.Location" type="System.Drawing.Point, System.Drawing">
+ <value>16, 86</value>
+ </data>
+ <data name="grdExtensionProperties.Size" type="System.Drawing.Size, System.Drawing">
+ <value>623, 328</value>
+ </data>
+ <data name="grdExtensionProperties.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name=">>grdExtensionProperties.Name" xml:space="preserve">
+ <value>grdExtensionProperties</value>
+ </data>
+ <data name=">>grdExtensionProperties.Type" xml:space="preserve">
+ <value>System.Windows.Forms.DataGridView, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>grdExtensionProperties.Parent" xml:space="preserve">
+ </data>
+ <data name=">>grdExtensionProperties.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ </metadata>
+ <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
+ <value>662, 438</value>
+ </data>
+ <data name="$this.Text" xml:space="preserve">
+ </data>
+ <value>WidgetInfoDialog</value>
+ </data>
+ <value>System.Windows.Forms.Form, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+</root>
Modified: trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetReferenceCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetReferenceCtrl.Designer.cs 2012-07-31 16:32:38 UTC (rev 6931)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetReferenceCtrl.Designer.cs 2012-08-02 13:48:04 UTC (rev 6932)
@@ -31,6 +31,7 @@
System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(WidgetReferenceCtrl));
this.cmbWidgetRefs = new System.Windows.Forms.ComboBox();
// label1
@@ -46,13 +47,19 @@
this.cmbWidgetRefs.Name = "cmbWidgetRefs";
this.cmbWidgetRefs.SelectedIndexChanged += new System.EventHandler(this.cmbWidgetRefs_SelectedIndexChanged);
+ // label2
// WidgetReferenceCtrl
- resources.ApplyResources(this, "$this");
this.Controls.Add(this.cmbWidgetRefs);
this.Name = "WidgetReferenceCtrl";
@@ -62,5 +69,6 @@
private System.Windows.Forms.ComboBox cmbWidgetRefs;
Modified: trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetReferenceCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetReferenceCtrl.resx 2012-07-31 16:32:38 UTC (rev 6931)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetReferenceCtrl.resx 2012-08-02 13:48:04 UTC (rev 6932)
<value>2.0</value>
</resheader>
</resheader>
</resheader>
<value>True</value>
</data>
<value>19, 18</value>
</data>
</data>
</data>
</data>
- <value>1</value>
+ <value>2</value>
</data>
<data name="cmbWidgetRefs.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
</data>
@@ -163,27 +163,51 @@
<value>cmbWidgetRefs</value>
</data>
<data name=">>cmbWidgetRefs.Type" xml:space="preserve">
- <value>System.Windows.Forms.ComboBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.ComboBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>cmbWidgetRefs.Parent" xml:space="preserve">
</data>
<data name=">>cmbWidgetRefs.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ </data>
+ <value>19, 52</value>
+ </data>
+ <value>516, 13</value>
+ </data>
+ <value>2</value>
+ </data>
+ <value>NOTE: To customize properties of this widget. Edit the matching widget from the Widget Management dialog</value>
+ </data>
+ </data>
+ </data>
+ </data>
<value>0</value>
</data>
<value>True</value>
</metadata>
- <data name="$this.AutoScaleDimensions" type="System.Drawing.SizeF, System.Drawing">
- <value>6, 13</value>
- </data>
- <value>575, 53</value>
+ <value>575, 90</value>
</data>
<value>WidgetReferenceCtrl</value>
</data>
</data>
</root>
Modified: trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetSettingsCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetSettingsCtrl.cs 2012-07-31 16:32:38 UTC (rev 6931)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetSettingsCtrl.cs 2012-08-02 13:48:04 UTC (rev 6932)
@@ -130,8 +130,8 @@
string[] widgets = _flexLayout.GetAllReferenceableWidgetNames();
string widget = GenericItemSelectionDialog.SelectItem(
- Properties.Resources.AddWidgetReference,
- Properties.Resources.SelectWidget,
+ Properties.Resources.AddWidgetReference,
+ Properties.Resources.SelectWidget,
widgets);
if (widget != null)
@@ -141,6 +141,25 @@
this.SelectedNode.Nodes.Add(CreateNode(item));
+ else
+ var menu = this.SelectedNode.Tag as IMenu;
+ if (menu != null)
+ string[] widgets = _flexLayout.GetAllReferenceableWidgetNames();
+ string widget = GenericItemSelectionDialog.SelectItem(
+ widgets);
+ if (widget != null)
+ //at end
+ var item = _flexLayout.CreateWidgetReference(widget);
+ menu.Insert(item, menu.ItemCount);
+ this.SelectedNode.Nodes.Add(CreateNode(item));
private void separatorToolStripMenuItem_Click(object sender, EventArgs e)
@@ -150,9 +169,20 @@
//at end
var item = _flexLayout.CreateSeparator();
- cnt.Insert(item, cnt.ItemCount - 1);
+ cnt.Insert(item, cnt.ItemCount);
+ else
+ if (menu != null)
+ //at end
+ var item = _flexLayout.CreateSeparator();
private void flyoutMenuToolStripMenuItem_Click(object sender, EventArgs e)
@@ -162,9 +192,20 @@
//at end
var item = _flexLayout.CreateFlyout(Properties.Resources.NewFlyout);
+ else
+ if (menu != null)
+ //at end
+ var item = _flexLayout.CreateFlyout(Properties.Resources.NewFlyout);
private TreeNode CreateNode(IUIItem item)
@@ -251,6 +292,16 @@
parent.Nodes.Remove(node);
OnResourceChanged();
+ else
+ var menu = parent.Tag as IMenu;
+ if (menu != null && item != null)
+ menu.RemoveItem(item);
+ parent.Nodes.Remove(node);
+ OnResourceChanged();
@@ -275,6 +326,23 @@
+ else
+ int index = node.Index;
+ if (index >= 0)
+ index--;
+ menu.MoveUp(item);
+ parent.Nodes.Insert(index, node);
+ trvWidgets.SelectedNode = node;
@@ -299,6 +367,23 @@
+ else
+ if (index < parent.Nodes.Count - 1)
+ index++;
+ menu.MoveDown(item);
@@ -321,6 +406,15 @@
if (menu != null)
btnAddWidget.Enabled = true;
+ var fly = menu as IFlyoutItem;
+ if (fly != null) //Can only edit menus that are flyouts
+ btnRemoveWidget.Enabled = true;
+ btnMoveDown.Enabled = btnMoveUp.Enabled = true;
+ var ctrl = new MenuCtrl(fly, _edsvc);
+ ctrl.Dock = DockStyle.Fill;
+ propertiesPanel.Controls.Add(ctrl);
else
Modified: trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
--- trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2012-07-31 16:32:38 UTC (rev 6931)
+++ trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2012-08-02 13:48:04 UTC (rev 6932)
@@ -450,6 +450,12 @@
<Compile Include="Fusion\MapSettingsCtrl.Designer.cs">
<DependentUpon>MapSettingsCtrl.cs</DependentUpon>
</Compile>
+ <Compile Include="Fusion\MenuCtrl.cs">
+ <SubType>UserControl</SubType>
+ </Compile>
+ <Compile Include="Fusion\MenuCtrl.Designer.cs">
+ <DependentUpon>MenuCtrl.cs</DependentUpon>
+ </Compile>
<Compile Include="Fusion\NewWidgetDialog.cs">
<SubType>Form</SubType>
</Compile>
@@ -458,6 +464,12 @@
</Compile>
<Compile Include="Fusion\NsDoc.cs" />
<Compile Include="Fusion\WidgetEditors\NsDoc.cs" />
+ <Compile Include="Fusion\WidgetEditors\WidgetInfoDialog.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="Fusion\WidgetEditors\WidgetInfoDialog.Designer.cs">
+ <DependentUpon>WidgetInfoDialog.cs</DependentUpon>
+ </Compile>
<Compile Include="Fusion\WidgetManagementDialog.cs">
</Compile>
@@ -1447,9 +1459,15 @@
<SubType>Designer</SubType>
</EmbeddedResource>
+ <EmbeddedResource Include="Fusion\MenuCtrl.resx">
+ </EmbeddedResource>
<EmbeddedResource Include="Fusion\NewWidgetDialog.resx">
<DependentUpon>NewWidgetDialog.cs</DependentUpon>
</EmbeddedResource>
+ <EmbeddedResource Include="Fusion\WidgetEditors\WidgetInfoDialog.resx">
<EmbeddedResource Include="Fusion\WidgetManagementDialog.resx">
<DependentUpon>WidgetManagementDialog.cs</DependentUpon>
</EmbeddedResource>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinitionInterfaces.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinitionInterfaces.cs 2012-07-31 16:32:38 UTC (rev 6931)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinitionInterfaces.cs 2012-08-02 13:48:04 UTC (rev 6932)
@@ -600,15 +600,29 @@
Check.NotNull(appDef, "appDef");
Check.NotEmpty(name, "name");
+ return appDef.FindWidget(name) != null;
+ /// <summary>
+ /// Gets the widget of the specified name
+ /// </summary>
+ /// <param name="appDef"></param>
+ /// <param name="name"></param>
+ /// <returns></returns>
+ public static IWidget FindWidget(this IApplicationDefinition appDef, string name)
+ Check.NotNull(appDef, "appDef");
+ Check.NotEmpty(name, "name");
foreach (var set in appDef.WidgetSets)
foreach (var wgt in set.Widgets)
if (wgt.Name == name)
- return true;
+ return wgt;
- return false;
+ return null;
/// <summary>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs 2012-07-31 16:32:38 UTC (rev 6931)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs 2012-08-02 13:48:04 UTC (rev 6932)
@@ -716,18 +716,22 @@
//Show Overview
var showOverview = (IUIWidget)appDef.CreateWidget("showOverview", widgets.FindWidget(KnownWidgetNames.InvokeScript));
+ showOverview.Label = "Show Overview";
showOverview.SetValue("Script", "showOverviewMap()");
//Show Task Pane
var showTaskPane = (IUIWidget)appDef.CreateWidget("showTaskPane", widgets.FindWidget(KnownWidgetNames.InvokeScript));
+ showTaskPane.Label = "Show Task Pane";
showTaskPane.SetValue("Script", "showTaskPane()");
//Show Legend
var showLegend = (IUIWidget)appDef.CreateWidget("showLegend", widgets.FindWidget(KnownWidgetNames.InvokeScript));
+ showLegend.Label = "Show Legend";
showLegend.SetValue("Script", "showLegend()");
//Show Selection Panel
var showSelectionPanel = (IUIWidget)appDef.CreateWidget("showSelectionPanel", widgets.FindWidget(KnownWidgetNames.InvokeScript));
+ showSelectionPanel.Label = "Show Selection Panel";
showSelectionPanel.SetValue("Script", "showSelectionPanel()");
//Coordinate Tracker
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs 2012-07-31 16:32:38 UTC (rev 6931)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs 2012-08-02 13:48:04 UTC (rev 6932)
@@ -88,6 +88,15 @@
/// <summary>
+ /// Looks up a localized string similar to A non-existent widget by the id of {0} is being referenced from a menu/container : {1}.
+ /// </summary>
+ internal static string ADF_InvalidWidgetReferenceInContainer {
+ get {
+ return ResourceManager.GetString("ADF_InvalidWidgetReferenceInContainer", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Map with ID {0} does not point to a valid map.
/// </summary>
internal static string ADF_MapInvalidError {
@@ -124,6 +133,24 @@
/// <summary>
+ /// Looks up a localized string similar to A non-UI widget by the id of {0} is residing in the menu/container ({1}). Being a non-UI widget, this may cause rendering problems for that particular container.
+ /// </summary>
+ internal static string ADF_NonUiWidgetAttachedToContainer {
+ get {
+ return ResourceManager.GetString("ADF_NonUiWidgetAttachedToContainer", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to A widget by the id of {0} has no label. This may cause display problems in the menu/container ({1}) if there is no icon specified.
+ /// </summary>
+ internal static string ADF_ReferencedWidgetInMenuHasNoLabel {
+ get {
+ return ResourceManager.GetString("ADF_ReferencedWidgetInMenuHasNoLabel", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Fusion application specifies a start view that is outside the map's initial extents.
/// </summary>
internal static string ADF_ViewOutsideMapExtents {
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx 2012-07-31 16:32:38 UTC (rev 6931)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx 2012-08-02 13:48:04 UTC (rev 6932)
@@ -2775,4 +2775,13 @@
<data name="FS_SecuredCredentialTokensWithoutSecuredCredentialData" xml:space="preserve">
<value>Feature source content has the %MG_USERNAME% and %MG_PASSWORD% tokens, but does not have the MG_USER_CREDENTIALS resource data item</value>
</data>
+ <data name="ADF_InvalidWidgetReferenceInContainer" xml:space="preserve">
+ <value>A non-existent widget by the id of {0} is being referenced from a menu/container : {1}</value>
+ </data>
+ <data name="ADF_NonUiWidgetAttachedToContainer" xml:space="preserve">
+ <value>A non-UI widget by the id of {0} is residing in the menu/container ({1}). Being a non-UI widget, this may cause rendering problems for that particular container</value>
+ </data>
+ <data name="ADF_ReferencedWidgetInMenuHasNoLabel" xml:space="preserve">
+ <value>A widget by the id of {0} has no label. This may cause display problems in the menu/container ({1}) if there is no icon specified</value>
+ </data>
</root>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ApplicationDefinitionValidator.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ApplicationDefinitionValidator.cs 2012-07-31 16:32:38 UTC (rev 6931)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ApplicationDefinitionValidator.cs 2012-08-02 13:48:04 UTC (rev 6932)
@@ -124,11 +124,68 @@
+ //Check labels of referenced widgets
+ foreach (var wset in fusionApp.WidgetSets)
+ foreach (var cnt in wset.Containers)
+ var menu = cnt as IMenu;
+ if (menu != null)
+ ValidateWidgetReferencesForMenu(fusionApp, menu, issues, context, resource);
context.MarkValidated(resource.ResourceID);
return issues.ToArray();
+ private void ValidateWidgetReferencesForMenu(IApplicationDefinition fusionApp, IMenu menu, List<ValidationIssue> issues, ResourceValidationContext context, IResource resource)
+ foreach (var item in menu.Items)
+ var subMenu = item as IMenu;
+ var widgetRef = item as IWidgetItem;
+ if (subMenu != null)
+ ValidateWidgetReferencesForMenu(fusionApp, subMenu, issues, context, resource);
+ else if (widgetRef != null)
+ var id = widgetRef.Widget;
+ var wgt = fusionApp.FindWidget(id);
+ var uiWgt = wgt as IUIWidget;
+ string parentName = "<unknown>";
+ var cnt = menu as IWidgetContainer;
+ if (cnt != null)
+ parentName = cnt.Name;
+ else if (fly != null)
+ parentName = fly.Label;
+ if (wgt == null)
+ issues.Add(new ValidationIssue(resource, ValidationStatus.Error, ValidationStatusCode.Error_Fusion_InvalidWidgetReference, string.Format(Properties.Resources.ADF_InvalidWidgetReferenceInContainer, id, parentName)));
+ else
+ if (uiWgt == null)
+ issues.Add(new ValidationIssue(resource, ValidationStatus.Warning, ValidationStatusCode.Warning_Fusion_NonStandardUiWidgetAttachedToContainer, string.Format(Properties.Resources.ADF_NonUiWidgetAttachedToContainer, id, parentName)));
+ else
+ if (string.IsNullOrEmpty(uiWgt.Label) && string.IsNullOrEmpty(uiWgt.ImageUrl))
+ issues.Add(new ValidationIssue(resource, ValidationStatus.Warning, ValidationStatusCode.Warning_Fusion_NoLabelOnWidget, string.Format(Properties.Resources.ADF_ReferencedWidgetInMenuHasNoLabel, id, parentName)));
private static bool IsCommercialOverlay(IMap map)
string type = map.Type.ToLower();
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ResourceValidatorSet.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ResourceValidatorSet.cs 2012-07-31 16:32:38 UTC (rev 6931)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ResourceValidatorSet.cs 2012-08-02 13:48:04 UTC (rev 6932)
@@ -93,6 +93,8 @@
catch (Exception ex)
string msg = NestedExceptionMessageProcessor.GetFullMessage(ex);
+ if (ex is NullReferenceException)
+ msg = ex.ToString();
issueSet.AddIssue(new ValidationIssue(item, ValidationStatus.Error, ValidationStatusCode.Error_General_ValidationError, "Failed in validator: " + msg));
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ValidationStatusCode.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ValidationStatusCode.cs 2012-07-31 16:32:38 UTC (rev 6931)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ValidationStatusCode.cs 2012-08-02 13:48:04 UTC (rev 6932)
@@ -197,6 +197,16 @@
Warning_Fusion_MapCoordSysIncompatibleWithCommericalLayers,
/// <summary>
+ /// The referenced widget has no label, which may cause display problems if there is no icon specified
+ /// </summary>
+ Warning_Fusion_NoLabelOnWidget,
+ /// <summary>
+ /// A toolbar or container contains a reference to a non-UI widget
+ /// </summary>
+ Warning_Fusion_NonStandardUiWidgetAttachedToContainer,
+ /// <summary>
/// Unrecognised layer type
/// </summary>
Warning_LayerDefinition_UnsupportedLayerType = 3501,
@@ -313,6 +323,11 @@
Error_Fusion_MapValidationError,
/// <summary>
+ /// A toolbar or container contains a reference to a non-existent widget
+ /// </summary>
+ Error_Fusion_InvalidWidgetReference,
+ /// <summary>
/// Unclassifed validation error
/// </summary>
Error_LayerDefinition_Generic = 5401,
More information about the mapguide-commits
