[mapguide-commits] r6938 - in branches/2.4/MgDev/Desktop: MapViewer MapViewer.Desktop
svn_mapguide at osgeo.org
Thu Aug 16 05:51:25 PDT 2012
Author: jng
Date: 2012-08-16 05:51:25 -0700 (Thu, 16 Aug 2012)
New Revision: 6938
branches/2.4/MgDev/Desktop/MapViewer.Desktop/MgDesktopMapViewerProvider.cs
branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs
branches/2.4/MgDev/Desktop/MapViewer/MgMapViewerProvider.cs
Clean out un-used code as a result of the previous submission. The following public methods have been removed
- MgMapViewerProvider
- GetGeometryProperty
- GetTooltipExpression
- HasTooltips
- CheckAndCacheGeometryProperty
- CacheGeometryProperties
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs 2012-08-16 09:07:48 UTC (rev 6937)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs 2012-08-16 12:51:25 UTC (rev 6938)
@@ -2142,6 +2142,10 @@
Clipboard.SetImage(this.GetCurrentImage());
+ /// <summary>
+ /// Selects features from all selectable layers that intersects the given geometry
+ /// </summary>
+ /// <param name="geom"></param>
public void SelectByGeometry(MgGeometry geom)
SelectByGeometry(geom, -1);
@@ -2170,6 +2174,7 @@
MgSelectionBase newSel = sel.Selection;
string newXml = newSel.ToXml();
_selection.FromXml(newXml);
+ newSel.Dispose();
else
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgMapViewerProvider.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgMapViewerProvider.cs 2012-08-16 09:07:48 UTC (rev 6937)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgMapViewerProvider.cs 2012-08-16 12:51:25 UTC (rev 6938)
@@ -77,7 +77,6 @@
DisposeExistingMap();
_map = map;
RebuildLayerInfoCache();
- CacheGeometryProperties(_map.GetLayers());
OnNewMapLoaded(map);
var h = this.MapLoaded;
if (h != null)
@@ -111,63 +110,16 @@
return CoordSysFactory.Create(_map.GetMapSRS());
- private Dictionary<string, string> _layerGeomProps = new Dictionary<string, string>();
- public void CacheGeometryProperties(MgLayerCollection layers)
- //Cache geometry properties
- for (int i = 0; i < layers.GetCount(); i++)
- var layer = layers.GetItem(i);
- //if (!layer.Selectable || !layer.IsVisible())
- // continue;
- var objId = layer.GetObjectId();
- if (_layerGeomProps.ContainsKey(objId))
- continue;
- string fsId = layer.FeatureSourceId;
- if (fsId.EndsWith(MgResourceType.DrawingSource))
- continue;
- CheckAndCacheGeometryProperty(layer);
- public void CheckAndCacheGeometryProperty(MgLayerBase layer)
- if (!_layerGeomProps.ContainsKey(objId))
- try
- var cls = layer.GetClassDefinition();
- var geomName = cls.DefaultGeometryPropertyName;
- if (!string.IsNullOrEmpty(geomName))
- _layerGeomProps[objId] = geomName;
- catch (MgException ex)
- Trace.TraceWarning("Failed to get geometry property for layer: " + layer.Name + Environment.NewLine + ex.ToString());
- ex.Dispose();
private Dictionary<string, MgCoordinateSystemTransform> _mapToLayerTransforms = new Dictionary<string, MgCoordinateSystemTransform>();
private Dictionary<string, NameValueCollection> _propertyMappings = new Dictionary<string, NameValueCollection>();
internal Dictionary<string, NameValueCollection> AllPropertyMappings { get { return _propertyMappings; } }
private Dictionary<string, XmlDocument> _cachedLayerDefinitions = new Dictionary<string, XmlDocument>();
- private Dictionary<string, string> _tooltipExpressions = new Dictionary<string, string>();
protected void RebuildLayerInfoCache()
_cachedLayerDefinitions.Clear();
- _tooltipExpressions.Clear();
_propertyMappings.Clear();
foreach (var trans in _mapToLayerTransforms.Values)
@@ -222,9 +174,6 @@
doc.LoadXml(contents.GetItem(i));
_cachedLayerDefinitions[resIds.GetItem(i)] = doc;
- XmlNodeList nodes = doc.GetElementsByTagName("ToolTip");
- if (nodes.Count == 1)
- _tooltipExpressions[resIds.GetItem(i)] = nodes[0].InnerText;
XmlNodeList propMaps = doc.GetElementsByTagName("PropertyMapping");
if (propMaps.Count > 0)
@@ -311,21 +260,6 @@
return CreateTransientState(_map);
- public string GetGeometryProperty(string objId)
- return _layerGeomProps[objId];
- public string GetTooltipExpression(MgResourceIdentifier ldfId)
- return _tooltipExpressions[ldfId.ToString()];
- public bool HasTooltips(MgResourceIdentifier ldfId)
- return _tooltipExpressions.ContainsKey(ldfId.ToString());
internal MgCoordinateSystemTransform GetLayerTransform(string objId, out bool bAlreadyChecked)
bAlreadyChecked = false;
Modified: branches/2.4/MgDev/Desktop/MapViewer.Desktop/MgDesktopMapViewerProvider.cs
--- branches/2.4/MgDev/Desktop/MapViewer.Desktop/MgDesktopMapViewerProvider.cs 2012-08-16 09:07:48 UTC (rev 6937)
+++ branches/2.4/MgDev/Desktop/MapViewer.Desktop/MgDesktopMapViewerProvider.cs 2012-08-16 12:51:25 UTC (rev 6938)
@@ -163,10 +163,17 @@
public override MgQueryMapFeaturesResult QueryMapFeatures(MgQueryRequestType queryType, MgStringCollection layerNames, MgGeometry filterGeom, int selectionVariant, string featureFilter, int maxFeatures, int layerAttributeFilter)
var fi = _renderSvc.QueryFeatures(_implMap, layerNames, filterGeom, selectionVariant, featureFilter, maxFeatures, layerAttributeFilter);
- if (queryType == MgQueryRequestType.Tooltip)
- return MakeTooltip(fi.GetTooltip());
- else
- return MakeSelectionResult(fi.GetSelection());
+ try
+ if (queryType == MgQueryRequestType.Tooltip)
+ return MakeTooltip(fi.GetTooltip());
+ else
+ return MakeSelectionResult(fi.GetSelection());
+ finally
+ fi.Dispose();
More information about the mapguide-commits
