[mapguide-commits] r6947 - branches/2.4/MgDev/Desktop/MapViewer
svn_mapguide at osgeo.org
Tue Aug 21 10:33:07 PDT 2012
Author: jng
Date: 2012-08-21 10:33:07 -0700 (Tue, 21 Aug 2012)
New Revision: 6947
branches/2.4/MgDev/Desktop/MapViewer/MgLegend.cs
branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs
#2096: Improve MgLegend performance:
- Lazy load layer definition content on-demand instead of all on the spot. Should be readily apparent with really large maps for the first load.
- Cache the icons that are generated for subsequent rebuilds of the underlying TreeView
- For subsequent rebuilds of the underlying TreeView, create nodes off of existing cached metadata where possible instead of going for direct resource content seek and calls to GenerateLegendImage
- Instead of having various dictionaries storing various layer and group data, extend the Layer and Group node metadata classes to store this information where applicable. Add a new metadata class for theme information
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgLegend.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgLegend.cs 2012-08-21 14:54:08 UTC (rev 6946)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgLegend.cs 2012-08-21 17:33:07 UTC (rev 6947)
@@ -89,13 +89,14 @@
if (node.Nodes.Count > 0)
ClearNodes(node.Nodes);
var layerMeta = node.Tag as LayerNodeMetadata;
if (layerMeta != null && layerMeta.ThemeIcon != null)
layerMeta.Layer = null;
layerMeta.ThemeIcon.Dispose();
layerMeta.ThemeIcon = null;
nodes.Clear();
@@ -139,14 +140,14 @@
if (e.Node.Tag == null)
return;
- if (((LegendNodeMetadata)e.Node.Tag).IsGroup) //Group
+ var meta = ((LegendNodeMetadata)e.Node.Tag);
+ if (meta.IsGroup) //Group
- _presenter.SetGroupVisible(e.Node.Name, e.Node.Checked);
+ _presenter.SetGroupVisible(meta.ObjectId, e.Node.Checked);
else //Layer
- _presenter.SetLayerVisible(e.Node.Name, e.Node.Checked);
+ _presenter.SetLayerVisible(meta.ObjectId, e.Node.Checked);
@@ -155,13 +156,14 @@
return;
- _presenter.SetGroupExpandInLegend(e.Node.Name, true);
+ _presenter.SetGroupExpandInLegend(meta.ObjectId, true);
else //Layer
- _presenter.SetLayerExpandInLegend(e.Node.Name, true);
+ _presenter.SetLayerExpandInLegend(meta.ObjectId, true);
@@ -170,13 +172,14 @@
return;
- _presenter.SetGroupExpandInLegend(e.Node.Name, false);
+ _presenter.SetGroupExpandInLegend(meta.ObjectId, false);
else //Layer
- _presenter.SetLayerExpandInLegend(e.Node.Name, false);
+ _presenter.SetLayerExpandInLegend(meta.ObjectId, false);
@@ -269,7 +272,7 @@
get { return _themeCompressionLimit; }
set { _themeCompressionLimit = value; }
private void OnLayerContextMenuOpening(object sender, CancelEventArgs e)
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs 2012-08-21 14:54:08 UTC (rev 6946)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs 2012-08-21 17:33:07 UTC (rev 6947)
@@ -10,6 +10,7 @@
using Legend.Model;
using System.Xml;
using System.IO;
+using System.Diagnostics;
interface ILegendView
@@ -40,11 +41,8 @@
private ILegendView _legend;
- //TODO: Coalesce this all into a single object. ie. Merge into the respective metadata classes.
- private Dictionary<string, bool> _initialLayerSelectabilityState = new Dictionary<string, bool>();
- private Dictionary<string, MgLayerBase> _layers = new Dictionary<string, MgLayerBase>();
- private Dictionary<string, MgLayerGroup> _groups = new Dictionary<string, MgLayerGroup>();
- private Dictionary<string, string> _layerDefinitionContents = new Dictionary<string, string>();
+ private Dictionary<string, LayerNodeMetadata> _layers = new Dictionary<string, LayerNodeMetadata>();
+ private Dictionary<string, GroupNodeMetadata> _groups = new Dictionary<string, GroupNodeMetadata>();
public MgLegendControlPresenter(ILegendView legend, MgMapViewerProvider provider)
@@ -61,12 +59,12 @@
if (_map != null)
- _initialLayerSelectabilityState.Clear();
+ _layers.Clear();
var layers = _map.GetLayers();
for (int i = 0; i < layers.GetCount(); i++)
var layer = layers.GetItem(i);
- _initialLayerSelectabilityState[layer.GetObjectId()] = layer.Selectable;
+ _layers[layer.GetObjectId()] = new LayerNodeMetadata(layer, layer.Selectable);
@@ -98,26 +96,43 @@
var lt = layer.GetLayerType();
var fsId = layer.GetFeatureSourceId();
+ LayerNodeMetadata layerMeta = null;
if (fsId.EndsWith("DrawingSource"))
node.SelectedImageKey = node.ImageKey = IMG_DWF;
- //If not in the dictionary, assume it is a dynamically added layer
- bool bInitiallySelectable = _initialLayerSelectabilityState.ContainsKey(layer.GetObjectId()) ? _initialLayerSelectabilityState[layer.GetObjectId()] : layer.Selectable;
- node.Tag = new LayerNodeMetadata(layer, bInitiallySelectable);
+ bool bInitiallySelectable = layer.Selectable;
+ if (_layers.ContainsKey(layer.GetObjectId()))
+ layerMeta = _layers[layer.GetObjectId()];
+ bInitiallySelectable = layerMeta.WasInitiallySelectable;
+ else //If not in the dictionary, assume it is a dynamically added layer
+ layerMeta = new LayerNodeMetadata(layer, bInitiallySelectable);
+ _layers[layer.GetObjectId()] = layerMeta;
+ node.Tag = layerMeta;
node.ToolTipText = string.Format(Properties.Resources.DrawingLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId);
else
- string layerData = null;
var ldfId = layer.LayerDefinition;
- if (_layerDefinitionContents.ContainsKey(ldfId.ToString()))
- layerData = _layerDefinitionContents[ldfId.ToString()];
- if (layerData == null)
+ else
+ layerMeta = new LayerNodeMetadata(layer, layer.Selectable);
+ if (string.IsNullOrEmpty(layerMeta.LayerDefinitionContent))
return null;
XmlDocument doc = new XmlDocument();
- doc.LoadXml(layerData);
+ doc.LoadXml(layerMeta.LayerDefinitionContent);
int type = 0;
XmlNodeList scaleRanges = doc.GetElementsByTagName("VectorScaleRange");
if (scaleRanges.Count == 0)
@@ -139,111 +154,116 @@
try
- MgByteReader layerIcon = _provider.GenerateLegendImage(layer.LayerDefinition,
- _map.ViewScale,
- 16,
- 16,
- "PNG",
- -1,
- -1);
- if (layerIcon != null)
+ if (layerMeta.Icon == null)
- try
+ MgByteReader layerIcon = _provider.GenerateLegendImage(layer.LayerDefinition,
+ _map.ViewScale,
+ 16,
+ 16,
+ "PNG",
+ -1,
+ -1);
+ legendCallCount++;
+ if (layerIcon != null)
- byte[] b = new byte[layerIcon.GetLength()];
- layerIcon.Read(b, b.Length);
- using (var ms = new MemoryStream(b))
+ try
- string id = Guid.NewGuid().ToString();
- Image img = Image.FromStream(ms);
- _legend.AddLegendIcon(id, img);
- node.SelectedImageKey = node.ImageKey = id;
+ byte[] b = new byte[layerIcon.GetLength()];
+ layerIcon.Read(b, b.Length);
+ using (var ms = new MemoryStream(b))
- ThemeIcon = img
- node.ToolTipText = string.Format(Properties.Resources.DefaultLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId, layer.FeatureClassName);
+ layerMeta.Icon = Image.FromStream(ms);
+ node.ToolTipText = string.Format(Properties.Resources.DefaultLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId, layer.FeatureClassName);
+ finally
+ layerIcon.Dispose();
- finally
+ else
- layerIcon.Dispose();
+ layerMeta.Icon = Properties.Resources.lc_broken;
- else
- node.SelectedImageKey = node.ImageKey = IMG_BROKEN;
catch
- for (int sc = 0; sc < scaleRanges.Count; sc++)
+ if (!layerMeta.HasTheme())
- XmlElement scaleRange = (XmlElement)scaleRanges[sc];
- XmlNodeList minElt = scaleRange.GetElementsByTagName("MinScale");
- XmlNodeList maxElt = scaleRange.GetElementsByTagName("MaxScale");
- String minScale, maxScale;
- minScale = "0";
- maxScale = "1000000000000.0"; // as MDF's VectorScaleRange::MAX_MAP_SCALE
- if (minElt.Count > 0)
- minScale = minElt[0].ChildNodes[0].Value;
- if (maxElt.Count > 0)
- maxScale = maxElt[0].ChildNodes[0].Value;
+ for (int sc = 0; sc < scaleRanges.Count; sc++)
+ XmlElement scaleRange = (XmlElement)scaleRanges[sc];
+ XmlNodeList minElt = scaleRange.GetElementsByTagName("MinScale");
+ XmlNodeList maxElt = scaleRange.GetElementsByTagName("MaxScale");
+ String minScale, maxScale;
+ minScale = "0";
+ maxScale = "1000000000000.0"; // as MDF's VectorScaleRange::MAX_MAP_SCALE
+ if (minElt.Count > 0)
+ minScale = minElt[0].ChildNodes[0].Value;
+ if (maxElt.Count > 0)
+ maxScale = maxElt[0].ChildNodes[0].Value;
- if (type != 0)
- break;
+ if (type != 0)
+ break;
- for (int geomType = 0; geomType < typeStyles.Length; geomType++)
- int catIndex = 0;
- XmlNodeList typeStyle = scaleRange.GetElementsByTagName(typeStyles[geomType]);
- for (int st = 0; st < typeStyle.Count; st++)
+ for (int geomType = 0; geomType < typeStyles.Length; geomType++)
- // We will check if this typestyle is going to be shown in the legend
- XmlNodeList showInLegend = ((XmlElement)typeStyle[st]).GetElementsByTagName("ShowInLegend");
- if (showInLegend.Count > 0)
- if (!bool.Parse(showInLegend[0].ChildNodes[0].Value))
- continue; // This typestyle does not need to be shown in the legend
+ ThemeCategory themeCat = new ThemeCategory()
+ MinScale = minScale,
+ MaxScale = maxScale,
+ GeometryType = geomType
- XmlNodeList rules = ((XmlElement)typeStyle[st]).GetElementsByTagName(ruleNames[geomType]);
- if (rules.Count > 1)
+ int catIndex = 0;
+ XmlNodeList typeStyle = scaleRange.GetElementsByTagName(typeStyles[geomType]);
+ for (int st = 0; st < typeStyle.Count; st++)
- node.SelectedImageKey = node.ImageKey = IMG_THEME;
- var layerMeta = node.Tag as LayerNodeMetadata;
- if (layerMeta != null)
+ // We will check if this typestyle is going to be shown in the legend
+ XmlNodeList showInLegend = ((XmlElement)typeStyle[st]).GetElementsByTagName("ShowInLegend");
+ if (showInLegend.Count > 0)
+ if (!bool.Parse(showInLegend[0].ChildNodes[0].Value))
+ continue; // This typestyle does not need to be shown in the legend
+ XmlNodeList rules = ((XmlElement)typeStyle[st]).GetElementsByTagName(ruleNames[geomType]);
+ if (rules.Count > 1)
- layerMeta.ThemeIcon = Properties.Resources.lc_theme;
+ layerMeta.Icon = Properties.Resources.lc_theme;
node.ToolTipText = string.Format(Properties.Resources.ThemedLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId, layer.FeatureClassName, rules.Count);
- if (_legend.ThemeCompressionLimit > 0 && rules.Count > _legend.ThemeCompressionLimit)
- AddThemeRuleNode(layer, node, geomType, 0, rules, 0);
- node.Nodes.Add(CreateCompressedThemeNode(rules.Count - 2));
- AddThemeRuleNode(layer, node, geomType, rules.Count - 1, rules, rules.Count - 1);
- else
- for (int r = 0; r < rules.Count; r++)
+ if (_legend.ThemeCompressionLimit > 0 && rules.Count > _legend.ThemeCompressionLimit)
- AddThemeRuleNode(layer, node, geomType, catIndex++, rules, r);
+ AddThemeRuleNode(layerMeta, themeCat, node, geomType, 0, rules, 0);
+ node.Nodes.Add(CreateCompressedThemeNode(layerMeta, themeCat, rules.Count - 2));
+ AddThemeRuleNode(layerMeta, themeCat, node, geomType, rules.Count - 1, rules, rules.Count - 1);
+ else
+ for (int r = 0; r < rules.Count; r++)
+ AddThemeRuleNode(layerMeta, themeCat, node, geomType, catIndex++, rules, r);
+ else //Already cached
+ Trace.TraceInformation("Icons already cached for: " + layer.Name);
+ node.Nodes.AddRange(layerMeta.CreateThemeNodesFromCachedMetadata(_map.ViewScale));
return node;
- private void AddThemeRuleNode(MgLayerBase layer, TreeNode node, int geomType, int catIndex, XmlNodeList rules, int r)
+ private void AddThemeRuleNode(LayerNodeMetadata layerMeta, ThemeCategory themeCat, TreeNode node, int geomType, int catIndex, XmlNodeList rules, int r)
XmlElement rule = (XmlElement)rules[r];
XmlNodeList label = rule.GetElementsByTagName("LegendLabel");
@@ -256,33 +276,32 @@
//if (filter != null && filter.Count > 0 && filter[0].ChildNodes.Count > 0)
// filterText = filter[0].ChildNodes[0].Value;
- var child = CreateThemeRuleNode(layer.LayerDefinition, _map.ViewScale, labelText, (geomType + 1), catIndex);
+ var child = CreateThemeRuleNode(layerMeta, themeCat, _map.ViewScale, labelText, (geomType + 1), catIndex);
node.Nodes.Add(child);
- private TreeNode CreateCompressedThemeNode(int count)
+ private TreeNode CreateCompressedThemeNode(LayerNodeMetadata layer, ThemeCategory cat, int count)
TreeNode node = new TreeNode();
node.Text = (count + " other styles");
node.ImageKey = node.SelectedImageKey = IMG_OTHER;
- node.Tag = new LayerNodeMetadata(null, false)
- IsBaseLayer = false,
- ThemeIcon = Properties.Resources.icon_etc,
- IsThemeRule = true
+ var meta = new LayerThemeNodeMetadata(true, Properties.Resources.icon_etc, node.Text);
+ node.Tag = meta;
+ layer.AddThemeNode(cat, meta);
return node;
- private TreeNode CreateThemeRuleNode(MgResourceIdentifier layerDefId, double viewScale, string labelText, int geomType, int categoryIndex)
+ private TreeNode CreateThemeRuleNode(LayerNodeMetadata layer, ThemeCategory themeCat, double viewScale, string labelText, int geomType, int categoryIndex)
- MgByteReader icon = _provider.GenerateLegendImage(layerDefId,
+ MgLayerBase lyr = layer.Layer;
+ MgByteReader icon = _provider.GenerateLegendImage(lyr.LayerDefinition,
viewScale,
16,
16,
"PNG",
geomType,
categoryIndex);
node.Text = labelText;
if (icon != null)
@@ -292,17 +311,12 @@
byte[] b = new byte[icon.GetLength()];
icon.Read(b, b.Length);
- var tag = new LayerNodeMetadata(null, false)
- tag.ThemeIcon = Image.FromStream(ms);
+ var tag = new LayerThemeNodeMetadata(false, Image.FromStream(ms), labelText);
+ layer.AddThemeNode(themeCat, tag);
+ node.Tag = tag;
- node.Tag = tag;
finally
@@ -319,30 +333,34 @@
node.Text = group.GetLegendLabel();
node.Checked = group.IsVisible();
node.SelectedImageKey = node.ImageKey = IMG_GROUP;
- node.Tag = new GroupNodeMetadata(group);
+ var meta = new GroupNodeMetadata(group);
+ node.Tag = meta;
+ _groups[group.GetObjectId()] = meta;
node.ContextMenuStrip = _legend.GroupContextMenu;
return node;
+ private int legendCallCount = 0;
public TreeNode[] CreateNodes()
List<TreeNode> output = new List<TreeNode>();
var nodesById = new Dictionary<string, TreeNode>();
var scale = _map.ViewScale;
+ if (scale < 10.0)
+ return output.ToArray();
var groups = _map.GetLayerGroups();
- _layerDefinitionContents.Clear();
- _layers.Clear();
- _groups.Clear();
+ legendCallCount = 0;
//Process groups first
List<MgLayerGroup> remainingNodes = new List<MgLayerGroup>();
for (int i = 0; i < groups.GetCount(); i++)
var group = groups.GetItem(i);
- _groups.Add(group.GetObjectId(), group);
if (!group.GetDisplayInLegend())
continue;
@@ -382,38 +400,73 @@
- //Now process layers
+ //Collect all resource contents in a batch
+ MgStringCollection layerIds = new MgStringCollection();
+ //Also collect the layer metadata nodes to create or update
+ var layerMetaNodesToUpdate = new Dictionary<string, MgLayerBase>();
+ //Now process layers. Layers without metadata nodes or without layer definition content
+ //are added to the list
var lyr = layers.GetItem(i);
- var ldfId = lyr.LayerDefinition;
+ bool display = lyr.DisplayInLegend;
+ bool visible = _provider.IsLayerPotentiallyVisibleAtScale(lyr, false);
+ if (!display)
+ continue;
- if (!_layerDefinitionContents.ContainsKey(ldfId.ToString()))
+ if (!visible)
+ continue;
+ if (_layers.ContainsKey(lyr.GetObjectId()))
- _layerDefinitionContents[ldfId.ToString()] = string.Empty;
+ if (string.IsNullOrEmpty(_layers[lyr.GetObjectId()].LayerDefinitionContent))
+ var ldfId = lyr.LayerDefinition;
+ layerIds.Add(ldfId.ToString());
+ layerMetaNodesToUpdate[ldfId.ToString()] = lyr;
+ else
- //Collect all resource contents in a batch
- MgStringCollection layerIds = new MgStringCollection();
- foreach (var lid in _layerDefinitionContents.Keys)
+ if (layerIds.GetCount() > 0)
- layerIds.Add(lid);
+ int added = 0;
+ int updated = 0;
+ //Fetch the contents and create/update the required layer metadata nodes
+ MgStringCollection layerContents = _resSvc.GetResourceContents(layerIds, null);
+ for (int i = 0; i < layerIds.GetCount(); i++)
+ string lid = layerIds.GetItem(i);
+ var lyr = layerMetaNodesToUpdate[lid];
+ var objId = lyr.GetObjectId();
+ LayerNodeMetadata meta = null;
+ if (_layers.ContainsKey(objId))
+ meta = _layers[objId];
+ updated++;
+ else
+ meta = new LayerNodeMetadata(lyr, lyr.Selectable);
+ _layers[objId] = meta;
+ added++;
+ meta.LayerDefinitionContent = layerContents.GetItem(i);
+ Trace.TraceInformation("CreateNodes: {0} layer contents added, {1} layer contents updated", added, updated);
- MgStringCollection layerContents = _resSvc.GetResourceContents(layerIds, null);
- for (int i = 0; i < layerIds.GetCount(); i++)
- string lid = layerIds.GetItem(i);
- _layerDefinitionContents[lid] = layerContents.GetItem(i);
List<MgLayerBase> remainingLayers = new List<MgLayerBase>();
- _layers.Add(layer.GetObjectId(), layer);
bool display = layer.DisplayInLegend;
bool visible = _provider.IsLayerPotentiallyVisibleAtScale(layer, false);
if (!display)
@@ -481,15 +534,15 @@
+ Trace.TraceInformation("{0} calls made to GenerateLegendImage", legendCallCount);
private static bool IsThemeLayerNode(TreeNode node)
- var meta = node.Tag as LayerNodeMetadata;
+ var meta = node.Tag as LayerThemeNodeMetadata;
if (meta != null)
- return meta.ThemeIcon != null || meta.IsBaseLayer;
+ return true;
return false;
@@ -502,7 +555,7 @@
internal void DrawNode(DrawTreeNodeEventArgs e, bool showPlusMinus, Font font)
- if (IsLayerNode(e.Node) && !e.Bounds.IsEmpty)
+ if (!e.Bounds.IsEmpty && (IsLayerNode(e.Node) || IsThemeLayerNode(e.Node)))
Color backColor, foreColor;
@@ -555,11 +608,12 @@
foreColor = e.Node.ForeColor;
- var tag = e.Node.Tag as LayerNodeMetadata;
+ var layerMeta = e.Node.Tag as LayerNodeMetadata;
+ var themeMeta = e.Node.Tag as LayerThemeNodeMetadata;
var checkBoxOffset = xoffset;
var selectabilityOffset = xoffset + 16;
var iconOffsetNoSelect = xoffset + 16;
- if (tag != null && tag.IsThemeRule) //No checkbox for theme rule nodes
+ if (themeMeta != null) //No checkbox for theme rule nodes
selectabilityOffset = xoffset;
iconOffsetNoSelect = xoffset;
@@ -571,7 +625,7 @@
//Uncomment if you need to "see" the bounds of the node
//e.Graphics.DrawRectangle(Pens.Black, e.Node.Bounds);
- if (tag != null && !tag.IsThemeRule) //No checkbox for theme rule nodes
+ if (layerMeta != null) //No checkbox for theme rule nodes
if (Application.RenderWithVisualStyles)
@@ -590,33 +644,45 @@
e.Graphics.DrawRectangle(new Pen(Brushes.Black, 2.0f), rect);
- if (tag != null)
- if (tag.DrawSelectabilityIcon)
+ if (layerMeta.DrawSelectabilityIcon)
- var icon = tag.IsSelectable ? _selectableIcon : _unselectableIcon;
+ var icon = layerMeta.IsSelectable ? _selectableIcon : _unselectableIcon;
e.Graphics.DrawImage(icon, e.Node.Bounds.X + selectabilityOffset, e.Node.Bounds.Y);
//Trace.TraceInformation("Painted icon at ({0},{1})", e.Node.Bounds.X, e.Node.Bounds.Y);
- if (tag.ThemeIcon != null)
+ if (layerMeta.Icon != null)
- e.Graphics.DrawImage(tag.ThemeIcon, e.Node.Bounds.X + iconOffset, e.Node.Bounds.Y);
+ e.Graphics.DrawImage(layerMeta.Icon, e.Node.Bounds.X + iconOffset, e.Node.Bounds.Y);
else
- e.Graphics.DrawImage(tag.ThemeIcon, e.Node.Bounds.X + iconOffsetNoSelect, e.Node.Bounds.Y);
+ e.Graphics.DrawImage(layerMeta.Icon, e.Node.Bounds.X + iconOffsetNoSelect, e.Node.Bounds.Y);
using (SolidBrush brush = new SolidBrush(Color.Black))
- e.Graphics.DrawString(e.Node.Text, font, brush, e.Node.Bounds.X + (tag.DrawSelectabilityIcon ? textOffset : textOffsetNoSelect), e.Node.Bounds.Y);
+ e.Graphics.DrawString(e.Node.Text, font, brush, e.Node.Bounds.X + (layerMeta.DrawSelectabilityIcon ? textOffset : textOffsetNoSelect), e.Node.Bounds.Y);
+ else if (themeMeta != null)
+ if (themeMeta.ThemeIcon != null)
+ e.Graphics.DrawImage(themeMeta.ThemeIcon, e.Node.Bounds.X + iconOffsetNoSelect, e.Node.Bounds.Y);
+ using (SolidBrush brush = new SolidBrush(Color.Black))
+ e.Graphics.DrawString(e.Node.Text, font, brush, e.Node.Bounds.X + textOffsetNoSelect, e.Node.Bounds.Y);
else
@@ -633,23 +699,29 @@
- internal void SetGroupExpandInLegend(string groupName, bool expand)
+ internal void SetGroupExpandInLegend(string objectId, bool expand)
- if (_groups.ContainsKey(groupName))
- _provider.SetGroupExpandInLegend(_groups[groupName], expand);
+ if (_groups.ContainsKey(objectId))
+ var grp = _groups[objectId].Group;
+ _provider.SetGroupExpandInLegend(grp, expand);
- internal void SetLayerExpandInLegend(string layerName, bool expand)
+ internal void SetLayerExpandInLegend(string objectId, bool expand)
- if (_layers.ContainsKey(layerName))
- _provider.SetLayerExpandInLegend(_layers[layerName], expand);
+ if (_layers.ContainsKey(objectId))
+ var lyr = _layers[objectId].Layer;
+ _provider.SetLayerExpandInLegend(lyr, expand);
- internal void SetGroupVisible(string name, bool bChecked)
+ internal void SetGroupVisible(string objectId, bool bChecked)
- if (_groups.ContainsKey(name))
- var grp = _groups[name];
grp.SetVisible(bChecked);
var bVis = HasVisibleParent(grp);
if (bVis)
@@ -657,11 +729,11 @@
- internal void SetLayerVisible(string name, bool bChecked)
+ internal void SetLayerVisible(string objectId, bool bChecked)
- if (_layers.ContainsKey(name))
- var layer = _layers[name];
+ var layer = _layers[objectId].Layer;
layer.SetVisible(bChecked);
var bVis = HasVisibleParent(layer);
if (bVis)
@@ -675,22 +747,77 @@
namespace Legend.Model
- class LegendNodeMetadata
+ abstract class LegendNodeMetadata
public bool IsGroup { get; protected set; }
+ public abstract string ObjectId { get; }
+ [DebuggerDisplay("Name = {Layer.Name}, Label = {Layer.LegendLabel}")]
class GroupNodeMetadata : LegendNodeMetadata
- internal MgLayerGroup Group { get; set; }
+ internal MgLayerGroup Group { get; private set; }
public GroupNodeMetadata(MgLayerGroup group)
base.IsGroup = true;
this.Group = group;
+ public override string ObjectId
+ get { return this.Group.GetObjectId(); }
+ [DebuggerDisplay("Layer Theme Node")]
+ class LayerThemeNodeMetadata : LegendNodeMetadata
+ public LayerThemeNodeMetadata(bool bPlaceholder, Image themeIcon, string labelText)
+ this.IsPlaceholder = bPlaceholder;
+ this.ThemeIcon = themeIcon;
+ this.Label = labelText;
+ public bool IsPlaceholder { get; private set; }
+ public Image ThemeIcon { get; set; }
+ public string Label { get; private set; }
+ get { return ""; }
+ class ThemeCategory
+ public string MinScale { get; set; }
+ public string MaxScale { get; set; }
+ public int GeometryType { get; set; }
+ public override int GetHashCode()
+ unchecked // Overflow is fine, just wrap
+ int hash = 17;
+ // Suitable nullity checks etc, of course :)
+ if (MinScale != null)
+ hash = hash * 23 + MinScale.GetHashCode();
+ if (MaxScale != null)
+ hash = hash * 23 + MaxScale.GetHashCode();
+ hash = hash * 23 + GeometryType.GetHashCode();
+ return hash;
class LayerNodeMetadata : LegendNodeMetadata
public LayerNodeMetadata(MgLayerBase layer, bool bInitiallySelectable)
@@ -699,20 +826,122 @@
this.Layer = layer;
this.IsSelectable = (layer != null) ? layer.Selectable : false;
this.DrawSelectabilityIcon = (layer != null && bInitiallySelectable);
- this.IsThemeRule = false;
+ this.WasInitiallySelectable = bInitiallySelectable;
+ this.LayerDefinitionContent = null;
+ _themeNodes = new Dictionary<ThemeCategory, List<LayerThemeNodeMetadata>>();
- internal MgLayerBase Layer { get; set; }
+ get { return this.Layer.GetObjectId(); }
+ public Image Icon { get; set; }
+ public string IconId { get; set; }
+ internal MgLayerBase Layer { get; private set; }
public bool DrawSelectabilityIcon { get; set; }
public bool IsSelectable { get; set; }
- public bool IsThemeRule { get; set; }
+ public bool WasInitiallySelectable { get; private set; }
public bool IsBaseLayer { get; set; }
- public Image ThemeIcon { get; set; }
+ public string LayerDefinitionContent { get; set; }
+ private Dictionary<ThemeCategory, List<LayerThemeNodeMetadata>> _themeNodes;
+ public List<LayerThemeNodeMetadata> GetThemeNodes(ThemeCategory category)
+ if (_themeNodes.ContainsKey(category))
+ return _themeNodes[category];
+ return null;
+ public void AddThemeNode(ThemeCategory category, LayerThemeNodeMetadata themeMeta)
+ if (!_themeNodes.ContainsKey(category))
+ _themeNodes[category] = new List<LayerThemeNodeMetadata>();
+ _themeNodes[category].Add(themeMeta);
+ internal bool HasTheme()
+ if (_themeNodes.Count == 0)
+ return false;
+ foreach (var coll in _themeNodes.Values)
+ if (coll.Count > 0)
+ return true;
+ return false;
+ internal TreeNode[] CreateThemeNodesFromCachedMetadata(double scale)
+ var nodes = new List<TreeNode>();
+ //Find the applicable scale range(s)
+ foreach (var cat in _themeNodes.Keys)
+ bool bApplicable = false;
+ bool bHasMin = !string.IsNullOrEmpty(cat.MinScale);
+ bool bHasMax = !string.IsNullOrEmpty(cat.MaxScale);
+ if (bHasMin)
+ double minVal = double.Parse(cat.MinScale);
+ if (bHasMax) //bHasMin = true, bHasMax = true
+ double maxVal = double.Parse(cat.MaxScale);
+ if (scale >= minVal && scale < maxVal)
+ bApplicable = true;
+ else //bHasMin = true, bHasMax = false
+ if (scale >= minVal)
+ else
+ if (bHasMax) //bHasMin = false, bHasMax = true
+ if (scale < maxVal)
+ else //bHasMin = false, bHasMax = false
+ if (bApplicable)
+ var metadata = _themeNodes[cat];
+ nodes.AddRange(CreateThemeNodes(metadata));
+ return nodes.ToArray();
+ private IEnumerable<TreeNode> CreateThemeNodes(List<LayerThemeNodeMetadata> metadata)
+ foreach (var meta in metadata)
+ var node = new TreeNode();
+ node.Text = meta.Label;
+ node.Tag = meta;
+ yield return node;
More information about the mapguide-commits
