[mapguide-commits] r6960 - branches/2.4/MgDev/Common/PlatformBase/Services
svn_mapguide at osgeo.org
Wed Aug 29 09:24:49 PDT 2012
Author: jng
Date: 2012-08-29 09:24:48 -0700 (Wed, 29 Aug 2012)
New Revision: 6960
branches/2.4/MgDev/Common/PlatformBase/Services/CreateSdfParams.h
branches/2.4/MgDev/Common/PlatformBase/Services/FileFeatureSourceParams.h
branches/2.4/MgDev/Common/PlatformBase/Services/SpatialContextReader.h
#2097: Remark more about MgFileFeatureSourceParams and flag more deprecations
Modified: branches/2.4/MgDev/Common/PlatformBase/Services/CreateSdfParams.h
--- branches/2.4/MgDev/Common/PlatformBase/Services/CreateSdfParams.h 2012-08-29 16:02:52 UTC (rev 6959)
+++ branches/2.4/MgDev/Common/PlatformBase/Services/CreateSdfParams.h 2012-08-29 16:24:48 UTC (rev 6960)
@@ -25,6 +25,8 @@
/// \brief
/// Contains the parameters used to create an SDF feature source.
+/// \deprecated
/// This is a deprecated class. Please use MgFileFeatureSourceParams
/// to create the parameters used to an SDF feature source.
Modified: branches/2.4/MgDev/Common/PlatformBase/Services/FileFeatureSourceParams.h
--- branches/2.4/MgDev/Common/PlatformBase/Services/FileFeatureSourceParams.h 2012-08-29 16:02:52 UTC (rev 6959)
+++ branches/2.4/MgDev/Common/PlatformBase/Services/FileFeatureSourceParams.h 2012-08-29 16:24:48 UTC (rev 6960)
@@ -30,8 +30,16 @@
/// \remarks
/// Use MgFeatureService::DescribeSchema and
/// MgFeatureService::GetSpatialContexts to get the values needed
-/// to construct and configure the MgFileFeatureSourceParams object.
+/// to construct and configure the MgFileFeatureSourceParams object.\n\n
+/// Only file-based FDO providers that support the FdoICreateDataStore command
+/// can be used with this class to create Feature Sources. As of this writing, the
+/// known supported file-based FDO providers are:
+/// \li OSGeo.SDF
+/// \li OSGeo.SHP
+/// \li OSGeo.SQLite
+/// You cannot create non-file Feature Sources using this class
/// <!-- Example (PHP) -->
/// \htmlinclude PHPExampleTop.html
/// \code
Modified: branches/2.4/MgDev/Common/PlatformBase/Services/SpatialContextReader.h
--- branches/2.4/MgDev/Common/PlatformBase/Services/SpatialContextReader.h 2012-08-29 16:02:52 UTC (rev 6959)
+++ branches/2.4/MgDev/Common/PlatformBase/Services/SpatialContextReader.h 2012-08-29 16:24:48 UTC (rev 6960)
@@ -396,7 +396,7 @@
/// Determines whether the spatial context currently being read
/// is the active spatial context.
- /// \remarks
+ /// \deprecated
/// This method is obsolete and will be deprecated.
/// <!-- Syntax in .Net, Java, and PHP -->
More information about the mapguide-commits
