[mapguide-commits] r7265 - in sandbox/adsk/2.5k: . Common/CoordinateSystem
svn_mapguide at osgeo.org
Thu Dec 13 03:57:05 PST 2012
Author: baertelchen
Date: 2012-12-13 03:57:05 -0800 (Thu, 13 Dec 2012)
New Revision: 7265
sandbox/adsk/2.5k/
sandbox/adsk/2.5k/Common/CoordinateSystem/
sandbox/adsk/2.5k/Common/CoordinateSystem/CoordSysCategoryDictionary.cpp
Fix "Remove redundant call to CS-Map's CSupdCategories() function in MgCoordinateSystemCategoryDictionary::Remove" (as part of RFC 127)
This is a merge of changeset 7264.
I've changed CS-Map's [CS_ctdel()] function to write all content into the CSD file. That is, calling CSupdCategories(NULL) isn't required anymore.
I've also fixed another problem in [MgCoordinateSystemCategoryDictionary::Modify] which got modified due to RFC127. An category which got updated a 2nd time got actually never written to disk. Instead, the code basically picked the category definition from CSMAP and then did write that one again - instead of taking the category instance that was passed to [MgCoordinateSystemCategoryDictionary::Modify].
Changes reviewed by Hugues.
Property changes on: sandbox/adsk/2.5k
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/sandbox/rfc94:5099-5163
/trunk/MgDev:7190-7200,7207,7235
+ /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/trunk/MgDev:7190-7200,7207,7235,7264
Property changes on: sandbox/adsk/2.5k/Common/CoordinateSystem
Deleted: svn:mergeinfo
- /branches/2.4/MgDev/Common/CoordinateSystem:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/sandbox/rfc94/Common/CoordinateSystem:5099-5163
/trunk/MgDev/Common/CoordinateSystem:7190-7200,7207,7235
Modified: sandbox/adsk/2.5k/Common/CoordinateSystem/CoordSysCategoryDictionary.cpp
--- sandbox/adsk/2.5k/Common/CoordinateSystem/CoordSysCategoryDictionary.cpp 2012-12-13 11:43:53 UTC (rev 7264)
+++ sandbox/adsk/2.5k/Common/CoordinateSystem/CoordSysCategoryDictionary.cpp 2012-12-13 11:57:05 UTC (rev 7265)
@@ -375,14 +375,6 @@
throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemCategoryDictionary.Remove", __LINE__, __WFILE__, &arguments, L"MgCoordinateSystemInternalException", NULL);
- int updateCategoriesResult = CSupdCategories(NULL);
- if (updateCategoriesResult)
- MgStringCollection arguments;
- arguments.Add(sName);
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemCategoryDictionary.Remove", __LINE__, __WFILE__, &arguments, L"MgCoordinateSystemInternalException", NULL);
long position = iter->second;
CCategoryName const& categoryName = List().at(position);
if (0 != CS_stricmp(categoryName.Name(), pName)) //is the category name at the index what we think it is?
@@ -454,15 +446,8 @@
invalidIndexOnFailure = true;
- pCategory = CS_ctdef(pName);
- if (NULL == pCategory)
- arguments.Add(str);
- throw new MgCoordinateSystemLoadFailedException(L"MgCoordinateSystemCategoryDictionary.Modify", __LINE__, __WFILE__, &arguments, L"MgCoordinateSystemNotFoundException", NULL);
- int updateResult = CS_ctupd(pCategory);
+ cs_Ctdef_ const* pDef = pCategoryDef->GetCategoryDef();
+ int updateResult = CS_ctupd(pDef);
if (updateResult < 0)
More information about the mapguide-commits
