[mapguide-commits] r7274 - sandbox/jng/streaming/Web/src/CgiAgent
svn_mapguide at osgeo.org
Mon Dec 17 00:04:46 PST 2012
Author: jng
Date: 2012-12-17 00:04:46 -0800 (Mon, 17 Dec 2012)
New Revision: 7274
Added:
sandbox/jng/streaming/Web/src/CgiAgent/CgiReaderStreamer.cpp
sandbox/jng/streaming/Web/src/CgiAgent/CgiReaderStreamer.h
sandbox/jng/streaming/Web/src/CgiAgent/CgiAgent.vcxproj
sandbox/jng/streaming/Web/src/CgiAgent/CgiResponseHandler.cpp
#2194: Add CGI implementation of MgHttpReaderStreamer. As printf is the http output mechanism, we have to escape any '%' characters in the chunks we're writing out. All 3 implementations (Apache/ISAPI/CGI) have been verified to produce the same identical xml and json responses.
Modified: sandbox/jng/streaming/Web/src/CgiAgent/CgiAgent.vcxproj
--- sandbox/jng/streaming/Web/src/CgiAgent/CgiAgent.vcxproj 2012-12-17 05:40:35 UTC (rev 7273)
+++ sandbox/jng/streaming/Web/src/CgiAgent/CgiAgent.vcxproj 2012-12-17 08:04:46 UTC (rev 7274)
@@ -190,6 +190,7 @@
<ItemGroup>
<ClCompile Include="CgiAgent.cpp" />
<ClCompile Include="CgiPostParser.cpp" />
+ <ClCompile Include="CgiReaderStreamer.cpp" />
<ClCompile Include="CgiResponseHandler.cpp" />
<ClCompile Include="EchoTest.cpp" />
</ItemGroup>
@@ -198,6 +199,7 @@
</ItemGroup>
<ItemGroup>
<ClInclude Include="CgiPostParser.h" />
+ <ClInclude Include="CgiReaderStreamer.h" />
<ClInclude Include="CgiResponseHandler.h" />
</ItemGroup>
<ItemGroup>
Added: sandbox/jng/streaming/Web/src/CgiAgent/CgiReaderStreamer.cpp
--- sandbox/jng/streaming/Web/src/CgiAgent/CgiReaderStreamer.cpp (rev 0)
+++ sandbox/jng/streaming/Web/src/CgiAgent/CgiReaderStreamer.cpp 2012-12-17 08:04:46 UTC (rev 7274)
@@ -0,0 +1,66 @@
+#include "CgiReaderStreamer.h"
+#include "MapAgentStrings.h"
+extern void DumpMessage(const char* format, ...);
+extern void DumpMessage2(const char* msg);
+CgiReaderStreamer::CgiReaderStreamer(MgReader* reader, CREFSTRING format) :
+ MgHttpReaderStreamer(reader, format),
+ m_bEndOfStream(false)
+CgiReaderStreamer::~CgiReaderStreamer()
+ EndStream();
+void CgiReaderStreamer::EndStream()
+ if (!m_bEndOfStream)
+ //Write end of chunked response
+ printf("0\r\n\r\n");
+ m_bEndOfStream = true;
+void CgiReaderStreamer::SetChunkedEncoding()
+ printf("Connection: Keep-Alive");
+ printf(MapAgentStrings::CrLf);
+ printf("Transfer-Encoding: chunked");
+void CgiReaderStreamer::WriteChunk(const char* str, size_t length)
+ std::string logStr = "BEGIN - CgiReaderStreamer::WriteChunk";
+ logStr.append(" str='");
+ logStr.append(str);
+ logStr.append("', length=");
+ MgUtil::ReplaceString("%", "%%", logStr, -1);
+ std::string lengthStr;
+ MgUtil::Int32ToString(length, lengthStr);
+ logStr.append(lengthStr);
+ DumpMessage(logStr.c_str());
+ m_hexLen.clear();
+ MgUtil::Int32ToHexString(length, m_hexLen);
+ m_hexLen.append(MapAgentStrings::CrLf);
+ printf(m_hexLen.c_str());
+ //---- BEGIN chunk body ----//
+ //Need to escape any characters that may trip up printf
+ //Currently it is: '%'
+ m_sCurrentChunk.clear();
+ m_sCurrentChunk = str;
+ MgUtil::ReplaceString("%", "%%", m_sCurrentChunk, -1);
+ printf(m_sCurrentChunk.c_str());
+ //---- END chunk body ----//
+ //DumpMessage("END - CgiReaderStreamer::WriteChunk");
\ No newline at end of file
Added: sandbox/jng/streaming/Web/src/CgiAgent/CgiReaderStreamer.h
--- sandbox/jng/streaming/Web/src/CgiAgent/CgiReaderStreamer.h (rev 0)
+++ sandbox/jng/streaming/Web/src/CgiAgent/CgiReaderStreamer.h 2012-12-17 08:04:46 UTC (rev 7274)
@@ -0,0 +1,41 @@
+// Copyright (C) 2004-2011 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#ifndef CGI_READER_STREAMER_H
+#define CGI_READER_STREAMER_H
+#include "MapGuideCommon.h"
+#include "HttpHandler.h"
+class CgiReaderStreamer : public MgHttpReaderStreamer
+public:
+ CgiReaderStreamer(MgReader* reader, CREFSTRING format);
+ virtual ~CgiReaderStreamer();
+protected:
+ virtual void SetChunkedEncoding();
+ virtual void WriteChunk(const char* str, size_t length);
+ virtual void EndStream();
+private:
+ bool m_bEndOfStream;
+ std::string m_hexLen;
+ std::string m_sCurrentChunk;
+#endif
Modified: sandbox/jng/streaming/Web/src/CgiAgent/CgiResponseHandler.cpp
--- sandbox/jng/streaming/Web/src/CgiAgent/CgiResponseHandler.cpp 2012-12-17 05:40:35 UTC (rev 7273)
+++ sandbox/jng/streaming/Web/src/CgiAgent/CgiResponseHandler.cpp 2012-12-17 08:04:46 UTC (rev 7274)
@@ -19,6 +19,7 @@
#include "HttpPrimitiveValue.h"
#include "CgiResponseHandler.h"
#include <stdlib.h>
@@ -101,6 +102,7 @@
printf(MapAgentStrings::ContentTypeHeader, MapAgentStrings::TextPlain, MapAgentStrings::Utf8Text);
+ Ptr<MgReader> outputDataReader;
Ptr<MgByteReader> outputReader;
Ptr<MgDisposable> resultObj = result->GetResultObject();
MgDisposable* pResultObj = (MgDisposable*)resultObj;
@@ -111,7 +113,7 @@
else if (NULL != dynamic_cast<MgFeatureReader*>(pResultObj))
- outputReader = ((MgFeatureReader*)pResultObj)->ToXml();
+ outputDataReader = SAFE_ADDREF((MgFeatureReader*)pResultObj); //Need to AddRef because there's now 2 references on this pointer
else if (NULL != dynamic_cast<MgStringCollection*>(pResultObj))
@@ -119,11 +121,11 @@
else if (NULL != dynamic_cast<MgSqlDataReader*>(pResultObj))
- outputReader = ((MgSqlDataReader*)pResultObj)->ToXml();
+ outputDataReader = SAFE_ADDREF((MgSqlDataReader*)pResultObj); //Need to AddRef because there's now 2 references on this pointer
else if (NULL != dynamic_cast<MgDataReader*>(pResultObj))
- outputReader = ((MgDataReader*)pResultObj)->ToXml();
+ outputDataReader = SAFE_ADDREF((MgDataReader*)pResultObj); //Need to AddRef because there's now 2 references on this pointer
else if (NULL != dynamic_cast<MgSpatialContextReader*>(pResultObj))
@@ -144,6 +146,11 @@
printf(MapAgentStrings::ContentLengthHeader, utf8.length());
printf("\r\n%s",utf8.c_str());
+ else if (outputDataReader != NULL)
+ CgiReaderStreamer crs(outputDataReader, result->GetResultContentType());
+ crs.StreamResult();
else if (outputReader != NULL)
INT64 outLen = outputReader->GetLength();
@@ -172,6 +179,8 @@
MG_TRY()
STRING shortError = e->GetExceptionMessage();
STRING longError = e->GetDetails();
+ longError += L"\n";
+ longError += e->GetStackTrace();
STRING statusMessage = e->GetClassName();
//TODO: Use a string resource for html error text format
More information about the mapguide-commits
