[mapguide-commits] r7276 - trunk/Tools/Maestro/Maestro.Base/UI
svn_mapguide at osgeo.org
Mon Dec 17 06:18:22 PST 2012
Author: jng
Date: 2012-12-17 06:18:21 -0800 (Mon, 17 Dec 2012)
New Revision: 7276
trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.cs
#2201: Prepend "EPSG:" to SRS fields in the WFS metadata tab. This is needed to properly register as a valid SRS, otherwise the OGC template engine will use the system default.
Modified: trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.cs 2012-12-17 08:06:34 UTC (rev 7275)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.cs 2012-12-17 14:18:21 UTC (rev 7276)
@@ -996,7 +996,7 @@
var cs = picker.SelectedCoordSys;
if (!string.IsNullOrEmpty(cs.EPSG))
- txtPrimarySRS.Text = cs.EPSG;
+ txtPrimarySRS.Text = "EPSG:" + cs.EPSG; //NOXLATE
@@ -1011,7 +1011,7 @@
- txtOtherSRS.Text = cs.EPSG;
+ txtOtherSRS.Text = "EPSG:" + cs.EPSG; //NOXLATE
More information about the mapguide-commits
