[mapguide-commits] r6478 -
sandbox/adsk/2.4j/Common/MapGuideCommon/MapLayer
svn_mapguide at osgeo.org
Thu Feb 2 20:56:19 EST 2012
Author: christinebao
Date: 2012-02-02 17:56:19 -0800 (Thu, 02 Feb 2012)
New Revision: 6478
sandbox/adsk/2.4j/Common/MapGuideCommon/MapLayer/Map.cpp
Fix ticket http://trac.osgeo.org/mapguide/ticket/1944
when the map's layers are from different schemas, the features can't be selected
Modified: sandbox/adsk/2.4j/Common/MapGuideCommon/MapLayer/Map.cpp
--- sandbox/adsk/2.4j/Common/MapGuideCommon/MapLayer/Map.cpp 2012-02-03 01:44:27 UTC (rev 6477)
+++ sandbox/adsk/2.4j/Common/MapGuideCommon/MapLayer/Map.cpp 2012-02-03 01:56:19 UTC (rev 6478)
@@ -1063,10 +1063,10 @@
/// Typedefs for populating identity properties into the map
typedef std::list<MgLayer*> LayerList;
typedef std::map<STRING,LayerList> LayerClassMap;
- typedef std::map<STRING,LayerClassMap> LayerFeatureSourceMap;
+ typedef std::map<STRING,LayerClassMap> LayerSchemaMap;
+ typedef std::map<STRING,LayerSchemaMap> LayerFeatureSourceMap;
LayerFeatureSourceMap fsMap;
- std::map<STRING,STRING> fsSchema;
// Group layers by their feature source / class name
for(int i = 0; i < m_layers->GetCount(); i++)
@@ -1080,8 +1080,7 @@
layer->ParseFeatureName(featureService, className, schemaName);
if (!schemaName.empty())
- fsMap[featureSource][className].push_back(layer.p);
- fsSchema[featureSource] = schemaName;
+ fsMap[featureSource][schemaName][className].push_back(layer.p);
@@ -1090,35 +1089,39 @@
// Assumption: feature source is only referencing one schema
STRING featureSource = fsIter->first;
- STRING schemaName = fsSchema[featureSource];
Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(featureSource);
- LayerClassMap& classList = fsIter->second;
- Ptr<MgStringCollection> classNames = new MgStringCollection();
- for (LayerClassMap::iterator cIter = classList.begin(); cIter != classList.end(); ++cIter)
+ LayerSchemaMap& schemaList = fsIter->second;
+ for (LayerSchemaMap::iterator schemaIter = schemaList.begin(); schemaIter != schemaList.end(); ++schemaIter)
- classNames->Add(cIter->first);
+ STRING schemaName = schemaIter->first;
+ LayerClassMap& classList = schemaIter->second;
+ Ptr<MgStringCollection> classNames = new MgStringCollection();
+ for (LayerClassMap::iterator cIter = classList.begin(); cIter != classList.end(); ++cIter)
+ classNames->Add(cIter->first);
- try
- // Ignore failures when pulling identity properties
- Ptr<MgClassDefinitionCollection> partialDefs = featureService->GetIdentityProperties(resId, schemaName, classNames);
- for (int i = 0; i < partialDefs->GetCount(); i++)
+ try
- Ptr<MgClassDefinition> def = partialDefs->GetItem(i);
- STRING className = def->GetName();
+ // Ignore failures when pulling identity properties
+ Ptr<MgClassDefinitionCollection> partialDefs = featureService->GetIdentityProperties(resId, schemaName, classNames);
+ for (int i = 0; i < partialDefs->GetCount(); i++)
+ Ptr<MgClassDefinition> def = partialDefs->GetItem(i);
+ STRING className = def->GetName();
- LayerList& layers = fsMap[featureSource][className];
- for (LayerList::iterator lIter = layers.begin(); lIter != layers.end(); ++lIter)
- (*lIter)->PopulateIdentityProperties(def);
+ LayerList& layers = fsMap[featureSource][schemaName][className];
+ for (LayerList::iterator lIter = layers.begin(); lIter != layers.end(); ++lIter)
+ (*lIter)->PopulateIdentityProperties(def);
+ catch (MgException* e)
+ e->Release();
- catch (MgException* e)
- e->Release();
More information about the mapguide-commits
