[mapguide-commits] r6509 - in trunk/Tools/Maestro/Maestro.Base: .
Commands/SiteExplorer Properties UI
svn_mapguide at osgeo.org
Mon Feb 13 10:16:58 EST 2012
Author: jng
Date: 2012-02-13 07:16:58 -0800 (Mon, 13 Feb 2012)
New Revision: 6509
Added:
trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/TestResourceCompatibilityCommand.cs
trunk/Tools/Maestro/Maestro.Base/UI/IncompatibleResourcesDialog.Designer.cs
trunk/Tools/Maestro/Maestro.Base/UI/IncompatibleResourcesDialog.cs
trunk/Tools/Maestro/Maestro.Base/UI/IncompatibleResourcesDialog.resx
trunk/Tools/Maestro/Maestro.Base/UI/TestResourceCompatibilityDialog.Designer.cs
trunk/Tools/Maestro/Maestro.Base/UI/TestResourceCompatibilityDialog.cs
trunk/Tools/Maestro/Maestro.Base/UI/TestResourceCompatibilityDialog.resx
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
#1675: Add a command for checking resource version compatibility against a given MapGuide site version. This is for checking if a package of said folder can be loaded into this particular MapGuide Server.
Added: trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/TestResourceCompatibilityCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/TestResourceCompatibilityCommand.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/TestResourceCompatibilityCommand.cs 2012-02-13 15:16:58 UTC (rev 6509)
@@ -0,0 +1,302 @@
+#region Disclaimer / License
+// Copyright (C) 2012, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Linq;
+using System.Text;
+using ICSharpCode.Core;
+using Maestro.Base.Services;
+using Maestro.Shared.UI;
+using Maestro.Base.UI;
+using System.ComponentModel;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.MaestroAPI.Capability;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using OSGeo.MapGuide.ObjectModels.Common;
+namespace Maestro.Base.Commands.SiteExplorer
+ internal class TestResourceCompatibilityCommand : AbstractMenuCommand
+ private Version _checkVersion;
+ private IServerConnection _conn;
+ private object BackgroundCheckResources(BackgroundWorker worker, DoWorkEventArgs e, params object[] args)
+ var documents = new List<string>();
+ foreach (object a in args)
+ string rid = a.ToString();
+ if (ResourceIdentifier.Validate(rid))
+ var resId = new ResourceIdentifier(rid);
+ if (resId.IsFolder)
+ foreach (IRepositoryItem o in _conn.ResourceService.GetRepositoryResources((string)args[0]).Children)
+ if (!o.IsFolder)
+ documents.Add(o.ResourceId);
+ else
+ documents.Add(rid);
+ var items = new List<string>();
+ var test = new MockServerConnection() { SiteVersion = _checkVersion };
+ var caps = new TestCapabilities(test);
+ if (documents.Count == 0)
+ return items.ToArray();
+ var unit = 100 / documents.Count;
+ var progress = 0.0;
+ worker.ReportProgress(0);
+ foreach (string resId in documents)
+ IResource res = _conn.ResourceService.GetResource(resId);
+ Version ver = null;
+ try
+ ver = caps.GetMaxSupportedResourceVersion(res.ResourceType);
+ catch
+ items.Add(resId);
+ continue;
+ //The resource's version is greater than the maximum version supported by
+ //the user's selected site version
+ if (res.ResourceVersion > ver)
+ items.Add(resId);
+ progress += unit;
+ worker.ReportProgress((int)progress);
+ worker.ReportProgress(100);
+ public override void Run()
+ var wb = Workbench.Instance;
+ var items = wb.ActiveSiteExplorer.SelectedItems;
+ var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+ _conn = connMgr.GetConnection(wb.ActiveSiteExplorer.ConnectionName);
+ if (items.Length > 0)
+ var diag = new TestResourceCompatibilityDialog();
+ if (diag.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ _checkVersion = diag.SelectedVersion;
+ var pdlg = new ProgressDialog();
+ pdlg.CancelAbortsThread = true;
+ var args = new HashSet<string>();
+ for (int i = 0; i < items.Length; i++)
+ args.Add(items[i].ResourceId);
+ var incompatibleItems = (string[])pdlg.RunOperationAsync(wb, new ProgressDialog.DoBackgroundWork(BackgroundCheckResources), args.ToArray());
+ if (incompatibleItems.Length > 0)
+ new IncompatibleResourcesDialog(_checkVersion, incompatibleItems).ShowDialog();
+ else
+ System.Windows.Forms.MessageBox.Show(string.Format(Properties.Resources.ResourcesCompatibleWithSelectedVersion, _checkVersion));
+ class TestCapabilities : ConnectionCapabilities
+ public TestCapabilities(MockServerConnection conn)
+ : base(conn)
+ public override int[] SupportedCommands
+ get { throw new NotImplementedException(); }
+ public override bool SupportsResourcePreviews
+ public override bool IsMultithreaded
+ class MockServerConnection : IServerConnection
+ public string ProviderName
+ public System.Collections.Specialized.NameValueCollection CloneParameters
+ public IServerConnection Clone()
+ throw new NotImplementedException();
+ public string[] ExecuteLoadProcedure(OSGeo.MapGuide.ObjectModels.LoadProcedure.ILoadProcedure loadProc, LengthyOperationProgressCallBack callback, bool ignoreUnsupportedFeatures)
+ public string[] ExecuteLoadProcedure(string resourceID, LengthyOperationProgressCallBack callback, bool ignoreUnsupportedFeatures)
+ public OSGeo.MapGuide.MaestroAPI.Services.IFeatureService FeatureService
+ public OSGeo.MapGuide.MaestroAPI.Services.IResourceService ResourceService
+ public OSGeo.MapGuide.MaestroAPI.Commands.ICommand CreateCommand(int commandType)
+ public IConnectionCapabilities Capabilities
+ public string SessionID
+ public bool AutoRestartSession
+ get
+ set
+ public OSGeo.MapGuide.MaestroAPI.Services.IService GetService(int serviceType)
+ public Version MaxTestedVersion
+ public Version SiteVersion
+ get;
+ set;
+ public bool DisableValidation
+ get
+ set
+ public OSGeo.MapGuide.MaestroAPI.CoordinateSystem.ICoordinateSystemCatalog CoordinateSystemCatalog
+ public string DisplayName
+ public void RestartSession()
+ public bool RestartSession(bool throwException)
+ public string[] GetCustomPropertyNames()
+ public Type GetCustomPropertyType(string name)
+ public void SetCustomProperty(string name, object value)
+ public object GetCustomProperty(string name)
+ public event RequestEventHandler RequestDispatched;
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2012-02-13 14:21:31 UTC (rev 6508)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2012-02-13 15:16:58 UTC (rev 6509)
@@ -454,6 +454,9 @@
label="${res:SiteExplorer_SelectedItem_Delete}"
class="Maestro.Base.Commands.SiteExplorer.DeleteSelectedItemsCommand" />
</Condition>
+ <MenuItem id="TestCompatibility"
+ label="${res:SiteExplorer_TestResourceCompatibility}"
+ class="Maestro.Base.Commands.SiteExplorer.TestResourceCompatibilityCommand" />
<MenuItem id="Validate"
icon="tick"
label="${res:SiteExplorer_ValidateResources}"
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2012-02-13 14:21:31 UTC (rev 6508)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2012-02-13 15:16:58 UTC (rev 6509)
@@ -129,6 +129,7 @@
<Compile Include="Commands\SiteExplorer\ShowSpatialContextsCommand.cs" />
<Compile Include="Commands\SiteExplorer\ValidateCommand.cs" />
<Compile Include="Commands\StartupCommand.cs" />
+ <Compile Include="Commands\SiteExplorer\TestResourceCompatibilityCommand.cs" />
<Compile Include="Commands\Test\OpenCoordinateSystemPickerCommand.cs" />
<Compile Include="Commands\Test\OpenResourceCommand.cs" />
<Compile Include="Commands\Test\OpenSymbolBrowserCommand.cs" />
@@ -289,6 +290,12 @@
<Compile Include="UI\DirtyStateConfirmationDialog.Designer.cs">
<DependentUpon>DirtyStateConfirmationDialog.cs</DependentUpon>
</Compile>
+ <Compile Include="UI\IncompatibleResourcesDialog.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="UI\IncompatibleResourcesDialog.Designer.cs">
+ <DependentUpon>IncompatibleResourcesDialog.cs</DependentUpon>
+ </Compile>
<Compile Include="UI\ISiteExplorer.cs" />
<Compile Include="UI\LabelLocalizationDialog.cs">
@@ -385,6 +392,12 @@
<DependentUpon>SiteExplorer.cs</DependentUpon>
</Compile>
<Compile Include="UI\SiteExplorerDragDropHandler.cs" />
+ <Compile Include="UI\TestResourceCompatibilityDialog.cs">
+ </Compile>
+ <Compile Include="UI\TestResourceCompatibilityDialog.Designer.cs">
+ <DependentUpon>TestResourceCompatibilityDialog.cs</DependentUpon>
+ </Compile>
<Compile Include="UI\TipOfTheDayDialog.cs">
</Compile>
@@ -523,6 +536,9 @@
<EmbeddedResource Include="UI\DirtyStateConfirmationDialog.resx">
</EmbeddedResource>
+ <EmbeddedResource Include="UI\IncompatibleResourcesDialog.resx">
+ </EmbeddedResource>
<EmbeddedResource Include="UI\LabelLocalizationDialog.resx">
<DependentUpon>LabelLocalizationDialog.cs</DependentUpon>
</EmbeddedResource>
@@ -572,6 +588,9 @@
<SubType>Designer</SubType>
</EmbeddedResource>
+ <EmbeddedResource Include="UI\TestResourceCompatibilityDialog.resx">
<EmbeddedResource Include="UI\TipOfTheDayDialog.resx">
<DependentUpon>TipOfTheDayDialog.cs</DependentUpon>
</EmbeddedResource>
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2012-02-13 14:21:31 UTC (rev 6508)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2012-02-13 15:16:58 UTC (rev 6509)
@@ -1731,6 +1731,15 @@
/// <summary>
+ /// Looks up a localized string similar to All resources selected are compatible with the selected site version {0}..
+ /// </summary>
+ internal static string ResourcesCompatibleWithSelectedVersion {
+ get {
+ return ResourceManager.GetString("ResourcesCompatibleWithSelectedVersion", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to {0} resources processed.
/// </summary>
internal static string ResourcesProcessed {
@@ -2242,6 +2251,15 @@
/// <summary>
+ /// Looks up a localized string similar to Test Resource Compatibility.
+ /// </summary>
+ internal static string SiteExplorer_TestResourceCompatibility {
+ get {
+ return ResourceManager.GetString("SiteExplorer_TestResourceCompatibility", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Validate.
/// </summary>
internal static string SiteExplorer_ValidateResources {
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2012-02-13 14:21:31 UTC (rev 6508)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2012-02-13 15:16:58 UTC (rev 6509)
@@ -1094,4 +1094,10 @@
<data name="Menu_Tools_XmlChanges_Desc" xml:space="preserve">
<value>View XML content changes of current resource</value>
</data>
+ <data name="SiteExplorer_TestResourceCompatibility" xml:space="preserve">
+ <value>Test Resource Compatibility</value>
+ </data>
+ <data name="ResourcesCompatibleWithSelectedVersion" xml:space="preserve">
+ <value>All resources selected are compatible with the selected site version {0}.</value>
+ </data>
</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Base/UI/IncompatibleResourcesDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/IncompatibleResourcesDialog.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/UI/IncompatibleResourcesDialog.Designer.cs 2012-02-13 15:16:58 UTC (rev 6509)
@@ -0,0 +1,74 @@
+namespace Maestro.Base.UI
+ partial class IncompatibleResourcesDialog
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(IncompatibleResourcesDialog));
+ this.lblMessage = new System.Windows.Forms.Label();
+ this.lstIncompatible = new System.Windows.Forms.ListBox();
+ this.btnClose = new System.Windows.Forms.Button();
+ this.SuspendLayout();
+ // lblMessage
+ resources.ApplyResources(this.lblMessage, "lblMessage");
+ this.lblMessage.Name = "lblMessage";
+ // lstIncompatible
+ resources.ApplyResources(this.lstIncompatible, "lstIncompatible");
+ this.lstIncompatible.FormattingEnabled = true;
+ this.lstIncompatible.Name = "lstIncompatible";
+ // btnClose
+ resources.ApplyResources(this.btnClose, "btnClose");
+ this.btnClose.Name = "btnClose";
+ this.btnClose.UseVisualStyleBackColor = true;
+ this.btnClose.Click += new System.EventHandler(this.btnClose_Click);
+ // IncompatibleResourcesDialog
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
+ resources.ApplyResources(this, "$this");
+ this.ControlBox = false;
+ this.Controls.Add(this.btnClose);
+ this.Controls.Add(this.lstIncompatible);
+ this.Controls.Add(this.lblMessage);
+ this.Name = "IncompatibleResourcesDialog";
+ this.ResumeLayout(false);
+ #endregion
+ private System.Windows.Forms.Label lblMessage;
+ private System.Windows.Forms.ListBox lstIncompatible;
+ private System.Windows.Forms.Button btnClose;
Added: trunk/Tools/Maestro/Maestro.Base/UI/IncompatibleResourcesDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/IncompatibleResourcesDialog.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/UI/IncompatibleResourcesDialog.cs 2012-02-13 15:16:58 UTC (rev 6509)
@@ -0,0 +1,50 @@
+#endregion
+using System;
+using System.Data;
+using System.Drawing;
+using System.Linq;
+using System.Text;
+using System.Windows.Forms;
+ public partial class IncompatibleResourcesDialog : Form
+ private IncompatibleResourcesDialog()
+ InitializeComponent();
+ public IncompatibleResourcesDialog(Version version, string[] incompatible)
+ : this()
+ lblMessage.Text = string.Format(lblMessage.Text, version);
+ lstIncompatible.DataSource = incompatible;
+ private void btnClose_Click(object sender, EventArgs e)
+ this.Close();
Added: trunk/Tools/Maestro/Maestro.Base/UI/IncompatibleResourcesDialog.resx
--- trunk/Tools/Maestro/Maestro.Base/UI/IncompatibleResourcesDialog.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/UI/IncompatibleResourcesDialog.resx 2012-02-13 15:16:58 UTC (rev 6509)
@@ -0,0 +1,219 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="lblMessage.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Left, Right</value>
+ </data>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="lblMessage.Location" type="System.Drawing.Point, System.Drawing">
+ <value>13, 13</value>
+ </data>
+ <data name="lblMessage.Size" type="System.Drawing.Size, System.Drawing">
+ <value>327, 50</value>
+ </data>
+ <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="lblMessage.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="lblMessage.Text" xml:space="preserve">
+ <value>The following resources are not incompatible with the selected site version: {0}</value>
+ </data>
+ <data name=">>lblMessage.Name" xml:space="preserve">
+ <value>lblMessage</value>
+ </data>
+ <data name=">>lblMessage.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>lblMessage.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>lblMessage.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="lstIncompatible.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Bottom, Left, Right</value>
+ </data>
+ <data name="lstIncompatible.Location" type="System.Drawing.Point, System.Drawing">
+ <value>16, 67</value>
+ </data>
+ <data name="lstIncompatible.Size" type="System.Drawing.Size, System.Drawing">
+ <value>324, 251</value>
+ </data>
+ <data name="lstIncompatible.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name=">>lstIncompatible.Name" xml:space="preserve">
+ <value>lstIncompatible</value>
+ </data>
+ <data name=">>lstIncompatible.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ListBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>lstIncompatible.Parent" xml:space="preserve">
+ </data>
+ <data name=">>lstIncompatible.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="btnClose.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Bottom, Right</value>
+ </data>
+ <data name="btnClose.Location" type="System.Drawing.Point, System.Drawing">
+ <value>265, 330</value>
+ </data>
+ <data name="btnClose.Size" type="System.Drawing.Size, System.Drawing">
+ <value>75, 23</value>
+ </data>
+ <data name="btnClose.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="btnClose.Text" xml:space="preserve">
+ <value>Close</value>
+ </data>
+ <data name=">>btnClose.Name" xml:space="preserve">
+ <value>btnClose</value>
+ </data>
+ <data name=">>btnClose.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnClose.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnClose.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ <value>True</value>
+ </metadata>
+ <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
+ <value>352, 365</value>
+ </data>
+ <data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
+ <value>CenterParent</value>
+ </data>
+ <data name="$this.Text" xml:space="preserve">
+ <value>Incompatible Resources</value>
+ </data>
+ <data name=">>$this.Name" xml:space="preserve">
+ <value>IncompatibleResourcesDialog</value>
+ </data>
+ <data name=">>$this.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Form, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+</root>
Added: trunk/Tools/Maestro/Maestro.Base/UI/TestResourceCompatibilityDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/TestResourceCompatibilityDialog.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/UI/TestResourceCompatibilityDialog.Designer.cs 2012-02-13 15:16:58 UTC (rev 6509)
@@ -0,0 +1,105 @@
+ partial class TestResourceCompatibilityDialog
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(TestResourceCompatibilityDialog));
+ this.label1 = new System.Windows.Forms.Label();
+ this.cmbSiteVersion = new System.Windows.Forms.ComboBox();
+ this.label2 = new System.Windows.Forms.Label();
+ this.btnCheck = new System.Windows.Forms.Button();
+ this.btnCancel = new System.Windows.Forms.Button();
+ this.lblVersion = new System.Windows.Forms.Label();
+ // label1
+ resources.ApplyResources(this.label1, "label1");
+ this.label1.Name = "label1";
+ // cmbSiteVersion
+ this.cmbSiteVersion.FormattingEnabled = true;
+ resources.ApplyResources(this.cmbSiteVersion, "cmbSiteVersion");
+ this.cmbSiteVersion.Name = "cmbSiteVersion";
+ this.cmbSiteVersion.SelectedIndexChanged += new System.EventHandler(this.cmbSiteVersion_SelectedIndexChanged);
+ // label2
+ resources.ApplyResources(this.label2, "label2");
+ this.label2.Name = "label2";
+ // btnCheck
+ resources.ApplyResources(this.btnCheck, "btnCheck");
+ this.btnCheck.Name = "btnCheck";
+ this.btnCheck.UseVisualStyleBackColor = true;
+ this.btnCheck.Click += new System.EventHandler(this.btnCheck_Click);
+ // btnCancel
+ this.btnCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+ resources.ApplyResources(this.btnCancel, "btnCancel");
+ this.btnCancel.Name = "btnCancel";
+ this.btnCancel.UseVisualStyleBackColor = true;
+ this.btnCancel.Click += new System.EventHandler(this.btnCancel_Click);
+ // lblVersion
+ resources.ApplyResources(this.lblVersion, "lblVersion");
+ this.lblVersion.Name = "lblVersion";
+ // TestResourceCompatibilityDialog
+ this.AcceptButton = this.btnCheck;
+ this.CancelButton = this.btnCancel;
+ this.Controls.Add(this.lblVersion);
+ this.Controls.Add(this.btnCancel);
+ this.Controls.Add(this.btnCheck);
+ this.Controls.Add(this.label2);
+ this.Controls.Add(this.cmbSiteVersion);
+ this.Controls.Add(this.label1);
+ this.Name = "TestResourceCompatibilityDialog";
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.ComboBox cmbSiteVersion;
+ private System.Windows.Forms.Label label2;
+ private System.Windows.Forms.Button btnCheck;
+ private System.Windows.Forms.Button btnCancel;
+ private System.Windows.Forms.Label lblVersion;
Added: trunk/Tools/Maestro/Maestro.Base/UI/TestResourceCompatibilityDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/TestResourceCompatibilityDialog.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/UI/TestResourceCompatibilityDialog.cs 2012-02-13 15:16:58 UTC (rev 6509)
@@ -0,0 +1,61 @@
+#endregion
+using System;
+using System.Data;
+using System.Linq;
+using System.Text;
+ public partial class TestResourceCompatibilityDialog : Form
+ public TestResourceCompatibilityDialog()
+ cmbSiteVersion.DataSource = Enum.GetValues(typeof(KnownSiteVersions));
+ cmbSiteVersion.SelectedIndex = 0;
+ public Version SelectedVersion
+ get { return SiteVersions.GetVersion((KnownSiteVersions)cmbSiteVersion.SelectedItem); }
+ private void btnCancel_Click(object sender, EventArgs e)
+ this.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+ private void btnCheck_Click(object sender, EventArgs e)
+ this.DialogResult = System.Windows.Forms.DialogResult.OK;
+ private void cmbSiteVersion_SelectedIndexChanged(object sender, EventArgs e)
+ lblVersion.Text = this.SelectedVersion.ToString();
Added: trunk/Tools/Maestro/Maestro.Base/UI/TestResourceCompatibilityDialog.resx
--- trunk/Tools/Maestro/Maestro.Base/UI/TestResourceCompatibilityDialog.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/UI/TestResourceCompatibilityDialog.resx 2012-02-13 15:16:58 UTC (rev 6509)
@@ -0,0 +1,288 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ <data name="label1.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>11, 60</value>
+ </data>
+ <data name="label1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>63, 13</value>
+ </data>
+ <data name="label1.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="label1.Text" xml:space="preserve">
+ <value>Site Version</value>
+ </data>
+ <data name=">>label1.Name" xml:space="preserve">
+ <value>label1</value>
+ </data>
+ <data name=">>label1.Type" xml:space="preserve">
+ </data>
+ <data name=">>label1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label1.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
+ <data name="cmbSiteVersion.Location" type="System.Drawing.Point, System.Drawing">
+ <value>92, 57</value>
+ </data>
+ <data name="cmbSiteVersion.Size" type="System.Drawing.Size, System.Drawing">
+ <value>199, 21</value>
+ </data>
+ <data name="cmbSiteVersion.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name=">>cmbSiteVersion.Name" xml:space="preserve">
+ <value>cmbSiteVersion</value>
+ </data>
+ <data name=">>cmbSiteVersion.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ComboBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>cmbSiteVersion.Parent" xml:space="preserve">
+ </data>
+ <data name=">>cmbSiteVersion.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="label2.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="label2.Location" type="System.Drawing.Point, System.Drawing">
+ <value>11, 9</value>
+ </data>
+ <data name="label2.Size" type="System.Drawing.Size, System.Drawing">
+ <value>289, 33</value>
+ </data>
+ <data name="label2.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="label2.Text" xml:space="preserve">
+ <value>This tool checks the schema versions of all affected resources to ensure compatibility with the selected site version</value>
+ </data>
+ <data name=">>label2.Name" xml:space="preserve">
+ <value>label2</value>
+ </data>
+ <data name=">>label2.Type" xml:space="preserve">
+ </data>
+ <data name=">>label2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label2.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="btnCheck.Location" type="System.Drawing.Point, System.Drawing">
+ <value>135, 98</value>
+ </data>
+ <data name="btnCheck.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnCheck.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="btnCheck.Text" xml:space="preserve">
+ <value>Check</value>
+ </data>
+ <data name=">>btnCheck.Name" xml:space="preserve">
+ <value>btnCheck</value>
+ </data>
+ <data name=">>btnCheck.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnCheck.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnCheck.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="btnCancel.Location" type="System.Drawing.Point, System.Drawing">
+ <value>216, 98</value>
+ </data>
+ <data name="btnCancel.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnCancel.TabIndex" type="System.Int32, mscorlib">
+ <value>4</value>
+ </data>
+ <data name="btnCancel.Text" xml:space="preserve">
+ <value>Cancel</value>
+ </data>
+ <data name=">>btnCancel.Name" xml:space="preserve">
+ <value>btnCancel</value>
+ </data>
+ <data name=">>btnCancel.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnCancel.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnCancel.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="lblVersion.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="lblVersion.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 103</value>
+ </data>
+ <data name="lblVersion.Size" type="System.Drawing.Size, System.Drawing">
+ <value>0, 13</value>
+ </data>
+ <data name="lblVersion.TabIndex" type="System.Int32, mscorlib">
+ <value>5</value>
+ </data>
+ <data name=">>lblVersion.Name" xml:space="preserve">
+ <value>lblVersion</value>
+ </data>
+ <data name=">>lblVersion.Type" xml:space="preserve">
+ </data>
+ <data name=">>lblVersion.Parent" xml:space="preserve">
+ </data>
+ <data name=">>lblVersion.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ </metadata>
+ <value>312, 133</value>
+ </data>
+ </data>
+ </data>
+ <value>TestResourceCompatibilityDialog</value>
+ </data>
+ </data>
+</root>
More information about the mapguide-commits
