[mapguide-commits] FW: r6498 - in trunk/MgDev: . Oem/fusion_build Oem/fusion_build/lib Oem/fusion_build/templates/mapguide/aqua Oem/fusion_build/templates/mapguide/limegold Oem/fusion_build/templates/mapguide/maroon Oem/fusion_build/templates/mapguide/slate Oem/fusion_build
Tom Fukushima tom.fukushima at autodesk.com
Mon Feb 13 15:58:42 EST 2012
-----Original Message-----
From: svn_mapguide at osgeo.org [mailto:svn_mapguide at osgeo.org]
Sent: Saturday, February 11, 2012 9:16 PM
To: mapguide-commits at lists.osgeo.org
Subject: r6498 - in trunk/MgDev: . Oem/fusion_build Oem/fusion_build/lib Oem/fusion_build/templates/mapguide/aqua Oem/fusion_build/templates/mapguide/limegold Oem/fusion_build/templates/mapguide/maroon Oem/fusion_build/templates/mapguide/slate Oem/fusion_build/...
Author: jng
Date: 2012-02-11 20:16:13 -0800 (Sat, 11 Feb 2012)
New Revision: 6498
Added:
   trunk/MgDev/debug64_excludes.txt
   trunk/MgDev/release64_excludes.txt
   trunk/MgDev/Oem/fusion_build/config.json
   trunk/MgDev/Oem/fusion_build/lib/fusionSF-compressed.js
   trunk/MgDev/Oem/fusion_build/lib/fusionSF.js
   trunk/MgDev/Oem/fusion_build/templates/mapguide/aqua/index.html
   trunk/MgDev/Oem/fusion_build/templates/mapguide/limegold/index.html
   trunk/MgDev/Oem/fusion_build/templates/mapguide/maroon/index.html
   trunk/MgDev/Oem/fusion_build/templates/mapguide/slate/index.html
   trunk/MgDev/Oem/fusion_build/templates/mapguide/turquoiseyellow/index.html
   trunk/MgDev/build.bat
   trunk/MgDev/build64.bat
   trunk/MgDev/setenvironment64.bat
Update build scripts to not clear env vars set by setenvironment[64].bat. Also update build64.bat to support x64 cross compilation. The x64 cross compiler is used if the x64 cross tools command prompt is used and the setenvironment64.bat is called like so:
 setenvironment64.bat vc10cross
This submission also updates the deploy revision of fusion that we are keeping under Oem (r2529)
More information about the mapguide-commits mailing list
