[mapguide-commits] r6515 - in trunk/Tools/Maestro: Maestro.AddIn.ExtendedObjectModels Maestro.AddIn.FdoToolbox Maestro.AddIn.GeoRest Maestro.AddIn.Local Maestro.AddIn.Scripting
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Feb 15 10:24:46 EST 2012
Author: jng
Date: 2012-02-15 07:24:46 -0800 (Wed, 15 Feb 2012)
New Revision: 6515
   trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Manifest.addin
   trunk/Tools/Maestro/Maestro.AddIn.FdoToolbox/Manifest.addin
   trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Manifest.addin
   trunk/Tools/Maestro/Maestro.AddIn.Local/Manifest.addin
   trunk/Tools/Maestro/Maestro.AddIn.Scripting/Manifest.addin
Update Maestro.Base import statements in addin manifests. According to the SharpDevelop documentation, using the form (:Maestro.Base) instead of a relative path will use Assembly.Load instead of Assembly.LoadFrom, which is important for any user addins (as the relative paths won't check out)
Modified: trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Manifest.addin
--- trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Manifest.addin	2012-02-15 15:06:46 UTC (rev 6514)
+++ trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Manifest.addin	2012-02-15 15:24:46 UTC (rev 6515)
@@ -9,7 +9,7 @@
     </Manifest>
     <Runtime>
-        <Import assembly="../../Maestro.Base.dll" />
+        <Import assembly=":Maestro.Base" />
         <Import assembly="Maestro.AddIn.ExtendedObjectModels.dll" />
     </Runtime>
Modified: trunk/Tools/Maestro/Maestro.AddIn.FdoToolbox/Manifest.addin
--- trunk/Tools/Maestro/Maestro.AddIn.FdoToolbox/Manifest.addin	2012-02-15 15:06:46 UTC (rev 6514)
+++ trunk/Tools/Maestro/Maestro.AddIn.FdoToolbox/Manifest.addin	2012-02-15 15:24:46 UTC (rev 6515)
@@ -9,7 +9,7 @@
     </Manifest>
     <Runtime>
         <Import assembly="Maestro.AddIn.FdoToolbox.dll" />
     </Runtime>
Modified: trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Manifest.addin
--- trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Manifest.addin	2012-02-15 15:06:46 UTC (rev 6514)
+++ trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Manifest.addin	2012-02-15 15:24:46 UTC (rev 6515)
@@ -9,7 +9,7 @@
     </Manifest>
     <Runtime>
         <Import assembly="Maestro.AddIn.GeoRest.dll" />
     </Runtime>
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/Manifest.addin
--- trunk/Tools/Maestro/Maestro.AddIn.Local/Manifest.addin	2012-02-15 15:06:46 UTC (rev 6514)
+++ trunk/Tools/Maestro/Maestro.AddIn.Local/Manifest.addin	2012-02-15 15:24:46 UTC (rev 6515)
@@ -9,7 +9,7 @@
     </Manifest>
     <Runtime>
         <Import assembly="Maestro.AddIn.Local.dll" />
     </Runtime>
Modified: trunk/Tools/Maestro/Maestro.AddIn.Scripting/Manifest.addin
--- trunk/Tools/Maestro/Maestro.AddIn.Scripting/Manifest.addin	2012-02-15 15:06:46 UTC (rev 6514)
+++ trunk/Tools/Maestro/Maestro.AddIn.Scripting/Manifest.addin	2012-02-15 15:24:46 UTC (rev 6515)
@@ -9,7 +9,7 @@
     </Manifest>
     <Runtime>
         <Import assembly="Maestro.AddIn.Scripting.dll" />
     </Runtime>
More information about the mapguide-commits mailing list
