[mapguide-commits] r6527 -
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Drawing
svn_mapguide at osgeo.org
Sun Feb 19 01:08:04 EST 2012
Author: jng
Date: 2012-02-18 22:08:04 -0800 (Sat, 18 Feb 2012)
New Revision: 6527
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Drawing/DrawingLayerSettingsCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Drawing/DrawingLayerSettingsCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Drawing/DrawingLayerSettingsCtrl.resx
#1798: Make the browse button in the Drawing Source editor do its intended function instead of doing nothing.
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Drawing/DrawingLayerSettingsCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Drawing/DrawingLayerSettingsCtrl.Designer.cs 2012-02-19 04:44:13 UTC (rev 6526)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Drawing/DrawingLayerSettingsCtrl.Designer.cs 2012-02-19 06:08:04 UTC (rev 6527)
@@ -71,6 +71,7 @@
resources.ApplyResources(this.btnBrowse, "btnBrowse");
this.btnBrowse.Name = "btnBrowse";
this.btnBrowse.UseVisualStyleBackColor = true;
+ this.btnBrowse.Click += new System.EventHandler(this.btnBrowse_Click);
// groupBox1
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Drawing/DrawingLayerSettingsCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Drawing/DrawingLayerSettingsCtrl.cs 2012-02-19 04:44:13 UTC (rev 6526)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Drawing/DrawingLayerSettingsCtrl.cs 2012-02-19 06:08:04 UTC (rev 6527)
@@ -27,6 +27,7 @@
using Maestro.Shared.UI;
using System.Diagnostics;
using OSGeo.MapGuide.ObjectModels.LayerDefinition;
+using Maestro.Editors.Generic;
namespace Maestro.Editors.LayerDefinition.Drawing
@@ -36,10 +37,12 @@
public DrawingLayerSettingsCtrl()
InitializeComponent();
+ _sheets = new BindingList<OSGeo.MapGuide.ObjectModels.Common.DrawingSectionListSection>();
private IEditorService _service;
private IDrawingLayerDefinition _dlayer;
+ private BindingList<OSGeo.MapGuide.ObjectModels.Common.DrawingSectionListSection> _sheets;
public void Bind(IEditorService service)
@@ -53,12 +56,13 @@
Debug.Assert(_dlayer != null);
TextBoxBinder.BindText(txtDrawingSource, _dlayer, "ResourceId");
- var sheets = _service.DrawingService.EnumerateDrawingSections(_dlayer.ResourceId);
cmbSheet.DisplayMember = "Title";
cmbSheet.ValueMember = "Name";
+ cmbSheet.DataSource = _sheets;
+ PopulateSheets();
+ cmbSheet_SelectedIndexChanged(this, EventArgs.Empty);
ComboBoxBinder.BindSelectedIndexChanged(cmbSheet, "SelectedValue", _dlayer, "Sheet");
- cmbSheet.DataSource = sheets.Section;
var minBinding = new Binding("Text", _dlayer, "MinScale");
var maxBinding = new Binding("Text", _dlayer, "MaxScale");
@@ -101,6 +105,16 @@
_dlayer.PropertyChanged += (sender, e) => { OnResourceChanged(); };
+ private void PopulateSheets()
+ _sheets.Clear();
+ var sheets = _service.DrawingService.EnumerateDrawingSections(_dlayer.ResourceId);
+ foreach (var sht in sheets.Section)
+ _sheets.Add(sht);
private void OnResourceChanged()
var handler = this.ResourceChanged;
@@ -180,5 +194,25 @@
_service.OpenResource(txtDrawingSource.Text);
+ private void btnBrowse_Click(object sender, EventArgs e)
+ using (var picker = new ResourcePicker(_service.ResourceService,
+ OSGeo.MapGuide.MaestroAPI.ResourceTypes.DrawingSource,
+ ResourcePickerMode.OpenResource))
+ if (picker.ShowDialog() == DialogResult.OK)
+ if (!txtDrawingSource.Text.Equals(picker.ResourceID))
+ txtDrawingSource.Text = picker.ResourceID;
+ _dlayer.LayerFilter = string.Empty;
+ PopulateSheets();
+ _dlayer.Sheet = _sheets[0].Name;
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Drawing/DrawingLayerSettingsCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Drawing/DrawingLayerSettingsCtrl.resx 2012-02-19 04:44:13 UTC (rev 6526)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Drawing/DrawingLayerSettingsCtrl.resx 2012-02-19 06:08:04 UTC (rev 6527)
@@ -502,6 +502,6 @@
<value>DrawingLayerSettingsCtrl</value>
</data>
<data name=">>$this.Type" xml:space="preserve">
- <value>Maestro.Shared.UI.CollapsiblePanel, Maestro.Shared.UI, Version=4.0.0.6359, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
+ <value>Maestro.Shared.UI.CollapsiblePanel, Maestro.Shared.UI, Version=5.0.0.6514, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
</data>
</root>
\ No newline at end of file
More information about the mapguide-commits
