[mapguide-commits] r6532 - trunk/MgDev/Common/CoordinateSystem
svn_mapguide at osgeo.org
Tue Feb 28 05:20:11 EST 2012
Author: baertelchen
Date: 2012-02-28 02:20:10 -0800 (Tue, 28 Feb 2012)
New Revision: 6532
trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.h
Fix ticket 1945 "CCoordinateSystemTransform::Transform methods might return incorrect transformation results for geographic coordinate systems"
This is a merge of changeset 6476 (http://trac.osgeo.org/mapguide/changeset/6476, sandbox/adsk/2.4j/Common/CoordinateSystem) into the trunk.
The various CCoordinateSystemTransform::Transform methods changed the input coordinates if the source coordinate system had been geographic and if the IgnoreOutsideDomainWarning flag was set to true.
This resulted in Mg returning incorrect transformation results compared to CSMAP (e.g. have the MG API process CSMAP's TEST.DAT file...)
Also, it makes no sense to have the MG API trimming the LL coordinates but not XY. And, the transformation engine behaves totally different when just a single flag is switched.
The IgnoreOutsideDomainWarning flag is checked again anyway after CSMAP has been called.
In this submission, I'm removing the private method [GeographicAdjust] and all calls to it in [CCoordinateSystemTransform].
All values are now passed on to CSMAP without touching them (no checking against Min / Max LL nor any checking of any central meridian value).
Also, the dev comment for [GeographicAdjust] was a bit vague.
Processed CSMAP's TEST.DAT file through the Mg API with the IgnoreOutsideDomainWarning / IgnoreDatumShiftWarning enabled and disabled.
Checked, that no errors were reported.
Changes reviewed by Hugues.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp 2012-02-28 07:48:08 UTC (rev 6531)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp 2012-02-28 10:20:10 UTC (rev 6532)
@@ -166,10 +166,6 @@
else
- if (m_bIgnoreOutsideDomainWarning && m_bSrcIsGeographic)
- GeographicAdjust (dCoords);
if (m_bIsReentrant)
status = TransformPoint2D (dCoords);
@@ -235,10 +231,6 @@
else
if (m_bIsReentrant)
@@ -302,10 +294,6 @@
else
if (m_bIsReentrant)
status = TransformPoint3D (dCoords);
@@ -370,10 +358,6 @@
else
if (m_bIsReentrant)
@@ -1065,10 +1049,6 @@
//Convert the point
INT32 status;
double dCoords [3] = {*x, *y, 0.0};
if (m_bIsReentrant)
@@ -1142,10 +1122,6 @@
dCoords [0] = x [idx];
dCoords [1] = y [idx];
x [idx] = dCoords [0];
y [idx] = dCoords [1];
@@ -1195,10 +1171,6 @@
//Convert the point
INT32 status;
if (m_bIsReentrant)
@@ -1273,10 +1245,6 @@
@@ -1329,10 +1297,6 @@
//Convert the point
double dCoords [3] = {*x, *y, *z};
if (m_bIsReentrant)
@@ -1408,10 +1372,6 @@
dCoords [2] = z [idx];
@@ -1464,10 +1424,6 @@
//Convert the point
if (m_bIsReentrant)
@@ -1543,11 +1499,6 @@
@@ -1616,10 +1567,6 @@
pDblXY = xy [0];
for (idx = 0;idx < pointCount;idx++)
- GeographicAdjust (pDblXY);
status = TransformPoint2D (pDblXY);
// Warning status values will have already been counted. We only need
@@ -1684,10 +1631,6 @@
pDblXYZ = xyz [0];
- GeographicAdjust (pDblXYZ);
status = TransformPoint3D (pDblXYZ);
@@ -2261,30 +2204,7 @@
return status;
-/* Not sure that I understand why this is here. It was in previous code,
- so we keep it to eliminate possible regressions. */
-void CCoordinateSystemTransform::GeographicAdjust (double dCoords[3])
- if(dCoords[0] < m_src.cent_mer + m_src.min_ll[0])
- dCoords[0] = m_src.cent_mer + m_src.min_ll[0];
- if(dCoords[0] > m_src.cent_mer + m_src.max_ll[0])
- dCoords[0] = m_src.cent_mer + m_src.max_ll[0];
- if(dCoords[1] > m_src.max_ll[1])
- dCoords[1] = m_src.max_ll[1];
- if(dCoords[1] < m_src.min_ll[1])
// For performance reasons, this function is, usually, called only in the event
// of a non-zero status value. Note that exceptions are usually thrown should
// status be non-zero.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.h 2012-02-28 07:48:08 UTC (rev 6531)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.h 2012-02-28 10:20:10 UTC (rev 6532)
@@ -361,7 +361,6 @@
int TransformInverse (double& xx,double& yy);
INT32 TransformPoint2D (double dCoords [3]); /* 2D conversion without Critical Section */
INT32 TransformPoint3D (double dCoords [3]); /* 3D conversion without Critical Section */
- void GeographicAdjust (double dCoords [3]);
void InterpretStatus (INT32 status);
More information about the mapguide-commits
