[mapguide-commits] r6395 - trunk/MgDev
svn_mapguide at osgeo.org
Sun Jan 1 08:36:16 EST 2012
Author: jng
Date: 2012-01-01 05:36:16 -0800 (Sun, 01 Jan 2012)
New Revision: 6395
trunk/MgDev/build.bat
trunk/MgDev/build64.bat
Update build.bat to also copy out viewer and devguide samples
Modified: trunk/MgDev/build.bat
--- trunk/MgDev/build.bat 2011-12-31 15:48:43 UTC (rev 6394)
+++ trunk/MgDev/build.bat 2012-01-01 13:36:16 UTC (rev 6395)
@@ -67,7 +67,7 @@
SET MG_FUSION=%MG_OEM%\Fusion
SET MG_DOC=%MG_DEV%\Doc
SET MG_DOC_OUTPUT=%MG_DOC%\MgOpensource_WebAPIReference
-SET MG_DOC_DEVGUIDE_SAMPLES=%MG_DOC%\samples\phpsamples
+SET MG_DOC_DEVGUIDE_SAMPLES=%MG_DOC%\samples\
SET MG_BUILD_TEMP=%MG_DEV%\BuildTemp
SET MG_OUTPUT=%MG_DEV%\%TYPEBUILD%
@@ -416,10 +416,23 @@
:install_doc
echo [install]: Documentation
%XCOPY% "%MG_DOC_OUTPUT%" "%MG_OUTPUT_WEB%\www\help\webapi" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
-echo [install]: Developer's Guide Sample Code
-%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%" "%MG_OUTPUT_WEB%\www\phpsamples" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+echo [install]: Developer's Guide Sample Code (PHP)
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\phpsamples" "%MG_OUTPUT_WEB%\www\phpsamples" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+echo [install]: Developer's Guide Sample Code (Java)
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\javasamples" "%MG_OUTPUT_WEB%\www\javasamples" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+echo [install]: Developer's Guide Sample Code (DotNet)
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\dotnetsamples" "%MG_OUTPUT_WEB%\www\dotnetsamples" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\phpviewersample" "%MG_OUTPUT_WEB%\www\phpviewersample" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\javaviewersample" "%MG_OUTPUT_WEB%\www\javaviewersample" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\dotnetviewersample" "%MG_OUTPUT_WEB%\www\dotnetviewersample" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
echo [install]: Viewer API documentation
%XCOPY% "%MG_DOC%\viewerapi" "%MG_OUTPUT_WEB%\www\help\viewerapi" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+echo [install]: Copy dlls into .net samples
+%XCOPY% "%MG_OUTPUT_WEB%\www\mapviewernet\bin\*.dll" "%MG_OUTPUT_WEB%\www\dotnetsamples\bin" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_OUTPUT_WEB%\www\mapviewernet\bin\*.dll" "%MG_OUTPUT_WEB%\www\dotnetviewersample\bin" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
goto quit
Modified: trunk/MgDev/build64.bat
--- trunk/MgDev/build64.bat 2011-12-31 15:48:43 UTC (rev 6394)
+++ trunk/MgDev/build64.bat 2012-01-01 13:36:16 UTC (rev 6395)
@@ -69,7 +69,7 @@
@@ -444,10 +444,23 @@
:install_doc
%XCOPY% "%MG_DOC_OUTPUT%" "%MG_OUTPUT_WEB%\www\help\webapi" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
-%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%" "%MG_OUTPUT_WEB%\www\devguide" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
%XCOPY% "%MG_DOC%\viewerapi" "%MG_OUTPUT_WEB%\www\help\viewerapi" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
goto quit
More information about the mapguide-commits
