[mapguide-commits] r6407 - in sandbox/adsk/2.3r/Server/src:
Common/Manager Core
svn_mapguide at osgeo.org
Thu Jan 5 03:00:17 EST 2012
Author: christinebao
Date: 2012-01-05 00:00:17 -0800 (Thu, 05 Jan 2012)
New Revision: 6407
sandbox/adsk/2.3r/Server/src/Common/Manager/FdoConnectionManager.cpp
sandbox/adsk/2.3r/Server/src/Core/serverconfig.ini
http://trac.osgeo.org/mapguide/ticket/1793
AIMS hang when foreign WMS is not available anymore
Integrate r6095, r6110, r6140 to Reeses SP2.
Modified: sandbox/adsk/2.3r/Server/src/Common/Manager/FdoConnectionManager.cpp
--- sandbox/adsk/2.3r/Server/src/Common/Manager/FdoConnectionManager.cpp 2012-01-05 05:22:18 UTC (rev 6406)
+++ sandbox/adsk/2.3r/Server/src/Common/Manager/FdoConnectionManager.cpp 2012-01-05 08:00:17 UTC (rev 6407)
@@ -262,6 +262,9 @@
// Create a new connection
pFdoConnection = m_connManager->CreateConnection(provider.c_str());
+ // Check if the connection support timeout setting
+ SetConnectionTimeout(pFdoConnection, provider);
// Check if we have thread model
if((FdoThreadCapability)-1 == providerInfo->GetThreadModel())
@@ -381,6 +384,9 @@
// Create a new connection and add it to the cache
pFdoConnection = m_connManager->CreateConnection(providerNoVersion.c_str());
+ SetConnectionTimeout(pFdoConnection, providerNoVersion);
@@ -778,6 +784,54 @@
+void MgFdoConnectionManager::SetConnectionTimeout(FdoIConnection* pFdoConnection, STRING providerName)
+ FdoPtr<FdoIConnectionCapabilities> connectionCapabilities = pFdoConnection->GetConnectionCapabilities();
+ if(connectionCapabilities->SupportsTimeout())
+ MgConfiguration* configuration = MgConfiguration::GetInstance();
+ ACE_ASSERT(NULL != configuration);
+ STRING timeoutCustom = MgConfigProperties::DefaultFeatureServicePropertyFDOConnectionTimeoutCustom;
+ if (NULL != configuration)
+ configuration->GetStringValue(
+ MgConfigProperties::FeatureServicePropertiesSection,
+ MgConfigProperties::FeatureServicePropertyFDOConnectionTimeoutCustom,
+ timeoutCustom,
+ MgConfigProperties::DefaultFeatureServicePropertyFDOConnectionTimeoutCustom);
+ if(timeoutCustom.length() > 0)
+ Ptr<MgStringCollection> fdoTimeoutCol = MgStringCollection::ParseCollection(timeoutCustom, L","); // NOXLATE
+ // Update the fdo connection timeout value
+ if (fdoTimeoutCol.p)
+ for(INT32 i=0;i<fdoTimeoutCol->GetCount();i++)
+ STRING fdoTimeoutCustom = fdoTimeoutCol->GetItem(i);
+ STRING provider = L""; // NOXLATE
+ INT32 timeoutVal = 120;
+ // Parse the format: provider:timeoutVal
+ // Example: OSGeo.WMS:120
+ Ptr<MgStringCollection> customCol = MgStringCollection::ParseCollection(fdoTimeoutCustom, L":"); // NOXLATE
+ if(customCol->GetCount() == 2)
+ provider = customCol->GetItem(0);
+ STRING value = customCol->GetItem(1);
+ timeoutVal = MgUtil::StringToInt32(value);
+ if(provider.find(providerName) != STRING::npos && timeoutVal > 0)
+ //FDOConnectionTimeoutCustom is second, and FdoConnectionTimeout is millisecond.
+ pFdoConnection->SetConnectionTimeout(timeoutVal * 1000);
+ break;
void MgFdoConnectionManager::ActivateSpatialContext(FdoIConnection* pFdoConnection, STRING& spatialContextName)
CHECKNULL((FdoIConnection*)pFdoConnection, L"MgFdoConnectionManager.ActivateSpatialContext()");
Modified: sandbox/adsk/2.3r/Server/src/Core/serverconfig.ini
--- sandbox/adsk/2.3r/Server/src/Core/serverconfig.ini 2012-01-05 05:22:18 UTC (rev 6406)
+++ sandbox/adsk/2.3r/Server/src/Core/serverconfig.ini 2012-01-05 08:00:17 UTC (rev 6407)
@@ -264,6 +264,8 @@
# DataTransactionTimerInterval Time interval in seconds for when the server
# checks for idle FDO transactions
# 0 < Value <= 1800
+# FDOConnectionTimeoutCustom Time duration in seconds for an FDO connection
+# 0 < Value <= 600
CacheSize = 100
CacheTimeLimit = 86400
@@ -278,6 +280,7 @@
JoinQueryBatchSize = 1000
DataTransactionTimeout = 360
DataTransactionTimerInterval = 60
+FDOConnectionTimeoutCustom = OSGeo.WMS:120
[MappingServiceProperties]
More information about the mapguide-commits
