[mapguide-commits] r6415 - trunk/MgDev
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Jan 11 00:12:23 EST 2012
Author: jng
Date: 2012-01-10 21:12:23 -0800 (Tue, 10 Jan 2012)
New Revision: 6415
   trunk/MgDev/build.bat
   trunk/MgDev/build64.bat
#1841: Update output dir preparations by selectively including .svn metadata from certain directories
Modified: trunk/MgDev/build.bat
--- trunk/MgDev/build.bat	2012-01-09 07:57:59 UTC (rev 6414)
+++ trunk/MgDev/build.bat	2012-01-11 05:12:23 UTC (rev 6415)
@@ -87,7 +87,7 @@
 rem running
 rem ==================================================
-IF "%JAVA_HOME%" == "" SET JAVA_HOME=C:\Program Files\Java\jdk1.5.0_18
+IF "%JAVA_HOME%" == "" SET JAVA_HOME=C:\Program Files\Java\jdk1.6.0_21
 IF "%DOXYGEN%" == "" SET DOXYGEN=%MG_DEV%\BuildTools\doxygen
 IF "%GNUWIN32%" == "" SET GNUWIN32=C:\Program Files\GnuWin32\bin
 IF "%SEVENZ%" == "" SET SEVENZ=%MG_DEV%\BuildTools\WebTools\7-Zip
@@ -110,7 +110,7 @@
 rem Command aliases
 rem SET XCOPY=xcopy /E /Y /I /F
-SET XCOPY=xcopy /E /Y /I /Q
+SET XCOPY=xcopy /E /Y /I /Q /H
 SET XCOPY_SINGLE=xcopy /Y /I /Q
 SET MSBUILD=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%TYPEBUILD% %MSBUILD_VERBOSITY% %MSBUILD_LOG%
 SET MSBUILD_CLEAN=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%TYPEBUILD% /t:Clean %MSBUILD_VERBOSITY%
@@ -370,25 +370,25 @@
 echo [install]: web Tier
 echo [install]: Web Tier - localized
-%XCOPY% "%MG_WEB_SRC%\localized" "%MG_OUTPUT_WEB%\www\localized" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\localized" "%MG_OUTPUT_WEB%\www\localized" /EXCLUDE:%TYPEBUILD%_excludes.txt
 echo [install]: Web Tier - mapadmin
-%XCOPY% "%MG_WEB_SRC%\mapadmin" "%MG_OUTPUT_WEB%\www\mapadmin" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\mapadmin" "%MG_OUTPUT_WEB%\www\mapadmin" /EXCLUDE:%TYPEBUILD%_excludes.txt
 echo [install]: Web Tier - mapagent
 %XCOPY% "%MG_WEB_SRC%\mapagent" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:svn_excludes.txt+mapagent_excludes.txt+%TYPEBUILD%_excludes.txt+%TYPEBUILD%_excludes.txt
 echo [install]: Web Tier - MapGuide API unmanaged binaries
 %XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+java_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
 echo [install]: Web Tier - mapagent test forms
-%XCOPY% "%MG_UNIT_TEST%\WebTier\MapAgent\MapAgentForms" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_UNIT_TEST%\WebTier\MapAgent\MapAgentForms" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:%TYPEBUILD%_excludes.txt
 echo [install]: Web Tier - stdicons
-%XCOPY% "%MG_WEB_SRC%\stdicons" "%MG_OUTPUT_WEB%\www\stdicons" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\stdicons" "%MG_OUTPUT_WEB%\www\stdicons" /EXCLUDE:%TYPEBUILD%_excludes.txt
 echo [install]: Web Tier - viewerfiles
-%XCOPY% "%MG_WEB_SRC%\viewerfiles" "%MG_OUTPUT_WEB%\www\viewerfiles" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\viewerfiles" "%MG_OUTPUT_WEB%\www\viewerfiles" /EXCLUDE:%TYPEBUILD%_excludes.txt
 echo [install]: Web Tier - schemareport
-%XCOPY% "%MG_WEB_SRC%\schemareport" "%MG_OUTPUT_WEB%\www\schemareport" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\schemareport" "%MG_OUTPUT_WEB%\www\schemareport" /EXCLUDE:%TYPEBUILD%_excludes.txt
 echo [install]: Web Tier - webconfig.ini
 copy /Y "%MG_WEB_SRC%\webconfig.ini" "%MG_OUTPUT_WEB%\www"
 echo [install]: Web Tier - mapviewerphp
-%XCOPY% "%MG_WEB_SRC%\mapviewerphp" "%MG_OUTPUT_WEB%\www\mapviewerphp" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\mapviewerphp" "%MG_OUTPUT_WEB%\www\mapviewerphp" /EXCLUDE:%TYPEBUILD%_excludes.txt
 echo [install]: Web Tier - Tomcat - MapGuide API unmanaged binaries
 %XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Tomcat\bin"/EXCLUDE:java_excludes.txt+dotnetapi_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
 echo [install]: Web Tier - php - MapGuide API unmanaged binaries
@@ -396,11 +396,11 @@
 echo [install]: Web Tier - php ext - MapGuide API unmanaged binaries
 %XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php\ext" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
 echo [install]: Web Tier - mapviewernet
-%XCOPY% "%MG_WEB_SRC%\mapviewernet" "%MG_OUTPUT_WEB%\www\mapviewernet" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\mapviewernet" "%MG_OUTPUT_WEB%\www\mapviewernet" /EXCLUDE:%TYPEBUILD%_excludes.txt
 echo [install]: Web Tier - mapviewernet - MapGuide API unmanaged binaries
 %XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\www\mapviewernet\bin" /EXCLUDE:dotnet_excludes.txt+%TYPEBUILD%_excludes.txt+%TYPEBUILD%_excludes.txt
 echo [install]: Web Tier - mapviewerjava
-%XCOPY% "%MG_WEB_SRC%\mapviewerjava" "%MG_OUTPUT_WEB%\www\mapviewerjava" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\mapviewerjava" "%MG_OUTPUT_WEB%\www\mapviewerjava" /EXCLUDE:%TYPEBUILD%_excludes.txt
 echo [install]: Web Tier - mapviewerjava - WEB-INF
 %XCOPY% "%MG_WEB_SRC%\WEB-INF" "%MG_OUTPUT_WEB%\www\WEB-INF" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
 echo [install]: Web Tier - fusion templates
@@ -417,19 +417,19 @@
 echo [install]: Documentation
 %XCOPY% "%MG_DOC_OUTPUT%" "%MG_OUTPUT_WEB%\www\help\webapi" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
 echo [install]: Developer's Guide Sample Code (PHP)
-%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\phpsamples" "%MG_OUTPUT_WEB%\www\phpsamples" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\phpsamples" "%MG_OUTPUT_WEB%\www\phpsamples" /EXCLUDE:%TYPEBUILD%_excludes.txt
 echo [install]: Developer's Guide Sample Code (Java)
-%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\javasamples" "%MG_OUTPUT_WEB%\www\javasamples" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\javasamples" "%MG_OUTPUT_WEB%\www\javasamples" /EXCLUDE:%TYPEBUILD%_excludes.txt
 echo [install]: Developer's Guide Sample Code (DotNet)
-%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\dotnetsamples" "%MG_OUTPUT_WEB%\www\dotnetsamples" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\dotnetsamples" "%MG_OUTPUT_WEB%\www\dotnetsamples" /EXCLUDE:%TYPEBUILD%_excludes.txt
-%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\phpviewersample" "%MG_OUTPUT_WEB%\www\phpviewersample" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\phpviewersample" "%MG_OUTPUT_WEB%\www\phpviewersample" /EXCLUDE:%TYPEBUILD%_excludes.txt
-%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\javaviewersample" "%MG_OUTPUT_WEB%\www\javaviewersample" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\javaviewersample" "%MG_OUTPUT_WEB%\www\javaviewersample" /EXCLUDE:%TYPEBUILD%_excludes.txt
-%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\dotnetviewersample" "%MG_OUTPUT_WEB%\www\dotnetviewersample" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%\dotnetviewersample" "%MG_OUTPUT_WEB%\www\dotnetviewersample" /EXCLUDE:%TYPEBUILD%_excludes.txt
 echo [install]: Viewer API documentation
-%XCOPY% "%MG_DOC%\viewerapi" "%MG_OUTPUT_WEB%\www\help\viewerapi" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC%\viewerapi" "%MG_OUTPUT_WEB%\www\help\viewerapi" /EXCLUDE:%TYPEBUILD%_excludes.txt
 echo [install]: Copy dlls into .net samples
 %XCOPY% "%MG_OUTPUT_WEB%\www\mapviewernet\bin\*.dll" "%MG_OUTPUT_WEB%\www\dotnetsamples\bin" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
 %XCOPY% "%MG_OUTPUT_WEB%\www\mapviewernet\bin\*.dll" "%MG_OUTPUT_WEB%\www\dotnetviewersample\bin" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
Modified: trunk/MgDev/build64.bat
--- trunk/MgDev/build64.bat	2012-01-09 07:57:59 UTC (rev 6414)
+++ trunk/MgDev/build64.bat	2012-01-11 05:12:23 UTC (rev 6415)
@@ -114,7 +114,7 @@
 rem Command aliases
 SET MSBUILD=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%CONFIGURATION% /p:Platform=%PLATFORM% %MSBUILD_VERBOSITY% %MSBUILD_LOG%
 SET MSBUILD_CLEAN=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%CONFIGURATION% /p:Platform=%PLATFORM% /t:Clean %MSBUILD_VERBOSITY%
@@ -398,25 +398,25 @@
-%XCOPY% "%MG_WEB_SRC%\localized" "%MG_OUTPUT_WEB%\www\localized" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\localized" "%MG_OUTPUT_WEB%\www\localized" /EXCLUDE:%CONFIGURATION%_excludes.txt
-%XCOPY% "%MG_WEB_SRC%\mapadmin" "%MG_OUTPUT_WEB%\www\mapadmin" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\mapadmin" "%MG_OUTPUT_WEB%\www\mapadmin" /EXCLUDE:%CONFIGURATION%_excludes.txt
 %XCOPY% "%MG_WEB_SRC%\mapagent64" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:svn_excludes.txt+mapagent_excludes.txt+%CONFIGURATION%_excludes.txt+%CONFIGURATION%_excludes.txt
 %XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+java_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
-%XCOPY% "%MG_UNIT_TEST%\WebTier\MapAgent\MapAgentForms" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_UNIT_TEST%\WebTier\MapAgent\MapAgentForms" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:%CONFIGURATION%_excludes.txt
-%XCOPY% "%MG_WEB_SRC%\stdicons" "%MG_OUTPUT_WEB%\www\stdicons" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\stdicons" "%MG_OUTPUT_WEB%\www\stdicons" /EXCLUDE:%CONFIGURATION%_excludes.txt
-%XCOPY% "%MG_WEB_SRC%\viewerfiles" "%MG_OUTPUT_WEB%\www\viewerfiles" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\viewerfiles" "%MG_OUTPUT_WEB%\www\viewerfiles" /EXCLUDE:%CONFIGURATION%_excludes.txt
-%XCOPY% "%MG_WEB_SRC%\schemareport" "%MG_OUTPUT_WEB%\www\schemareport" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\schemareport" "%MG_OUTPUT_WEB%\www\schemareport" /EXCLUDE:%CONFIGURATION%_excludes.txt
-%XCOPY% "%MG_WEB_SRC%\mapviewerphp" "%MG_OUTPUT_WEB%\www\mapviewerphp" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\mapviewerphp" "%MG_OUTPUT_WEB%\www\mapviewerphp" /EXCLUDE:%CONFIGURATION%_excludes.txt
 %XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Tomcat\bin"/EXCLUDE:java_excludes.txt+dotnetapi_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
@@ -424,11 +424,11 @@
 %XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php\ext" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
-%XCOPY% "%MG_WEB_SRC%\mapviewernet" "%MG_OUTPUT_WEB%\www\mapviewernet" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\mapviewernet" "%MG_OUTPUT_WEB%\www\mapviewernet" /EXCLUDE:%CONFIGURATION%_excludes.txt
 %XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\www\mapviewernet\bin" /EXCLUDE:dotnet_excludes.txt+%CONFIGURATION%_excludes.txt+%CONFIGURATION%_excludes.txt
-%XCOPY% "%MG_WEB_SRC%\mapviewerjava" "%MG_OUTPUT_WEB%\www\mapviewerjava" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_WEB_SRC%\mapviewerjava" "%MG_OUTPUT_WEB%\www\mapviewerjava" /EXCLUDE:%CONFIGURATION%_excludes.txt
 %XCOPY% "%MG_WEB_SRC%\WEB-INF" "%MG_OUTPUT_WEB%\www\WEB-INF" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
@@ -445,19 +445,19 @@
 %XCOPY% "%MG_DOC_OUTPUT%" "%MG_OUTPUT_WEB%\www\help\webapi" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
-%XCOPY% "%MG_DOC%\viewerapi" "%MG_OUTPUT_WEB%\www\help\viewerapi" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_DOC%\viewerapi" "%MG_OUTPUT_WEB%\www\help\viewerapi" /EXCLUDE:%CONFIGURATION%_excludes.txt
More information about the mapguide-commits mailing list
