[mapguide-commits] r6419 - in trunk/Tools/Maestro: . Maestro
Maestro.Base Maestro.Base/Commands
Maestro.Base/Commands/Conditions Maestro.Base/Properties
Maestro.Base/UI/Preferences OSGeo.MapGuide.MaestroAPI
OSGeo.MapGuide.MaestroAPI/Mapping Properties RtMapInspector
RtMapInspector/Properties
svn_mapguide at osgeo.org
Wed Jan 11 08:27:11 EST 2012
Author: jng
Date: 2012-01-11 05:27:11 -0800 (Wed, 11 Jan 2012)
New Revision: 6419
Added:
trunk/Tools/Maestro/Maestro.Base/Commands/Conditions/SupportedCommandConditionEvaluator.cs
trunk/Tools/Maestro/Maestro.Base/Commands/RtMapInspectorCommand.cs
trunk/Tools/Maestro/RtMapInspector/
trunk/Tools/Maestro/RtMapInspector/MainForm.Designer.cs
trunk/Tools/Maestro/RtMapInspector/MainForm.cs
trunk/Tools/Maestro/RtMapInspector/MainForm.resx
trunk/Tools/Maestro/RtMapInspector/Program.cs
trunk/Tools/Maestro/RtMapInspector/Properties/
trunk/Tools/Maestro/RtMapInspector/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/RtMapInspector/Properties/Resources.Designer.cs
trunk/Tools/Maestro/RtMapInspector/Properties/Resources.resx
trunk/Tools/Maestro/RtMapInspector/Properties/Settings.Designer.cs
trunk/Tools/Maestro/RtMapInspector/Properties/Settings.settings
trunk/Tools/Maestro/RtMapInspector/RtMapInspector.csproj
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
trunk/Tools/Maestro/Maestro.Base/UI/Preferences/ConfigProperties.cs
trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.cs
trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.resx
trunk/Tools/Maestro/Maestro/Maestro_All.sln
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs
#1622: This submission implements a viewer/inspector for the Runtime Map state
Modified: trunk/Tools/Maestro/Maestro/Maestro_All.sln
--- trunk/Tools/Maestro/Maestro/Maestro_All.sln 2012-01-11 10:38:34 UTC (rev 6418)
+++ trunk/Tools/Maestro/Maestro/Maestro_All.sln 2012-01-11 13:27:11 UTC (rev 6419)
@@ -124,6 +124,8 @@
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "Maestro.AddIn.FdoToolbox", "..\Maestro.AddIn.FdoToolbox\Maestro.AddIn.FdoToolbox.csproj", "{8787FF3F-552F-46BE-B9D7-548B6162B079}"
EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "RtMapInspector", "..\RtMapInspector\RtMapInspector.csproj", "{E204559D-EE92-4792-96E2-06F45654FAFC}"
+EndProject
Global
GlobalSection(SolutionConfigurationPlatforms) = preSolution
Debug|Any CPU = Debug|Any CPU
@@ -286,6 +288,10 @@
{8787FF3F-552F-46BE-B9D7-548B6162B079}.Debug|Any CPU.Build.0 = Debug|Any CPU
{8787FF3F-552F-46BE-B9D7-548B6162B079}.Release|Any CPU.ActiveCfg = Release|Any CPU
{8787FF3F-552F-46BE-B9D7-548B6162B079}.Release|Any CPU.Build.0 = Release|Any CPU
+ {E204559D-EE92-4792-96E2-06F45654FAFC}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {E204559D-EE92-4792-96E2-06F45654FAFC}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {E204559D-EE92-4792-96E2-06F45654FAFC}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {E204559D-EE92-4792-96E2-06F45654FAFC}.Release|Any CPU.Build.0 = Release|Any CPU
EndGlobalSection
GlobalSection(SolutionProperties) = preSolution
HideSolutionNode = FALSE
Added: trunk/Tools/Maestro/Maestro.Base/Commands/Conditions/SupportedCommandConditionEvaluator.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/Conditions/SupportedCommandConditionEvaluator.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/Conditions/SupportedCommandConditionEvaluator.cs 2012-01-11 13:27:11 UTC (rev 6419)
@@ -0,0 +1,60 @@
+#region Disclaimer / License
+// Copyright (C) 2012, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using ICSharpCode.Core;
+using Maestro.Base.Services;
+using OSGeo.MapGuide.MaestroAPI.Commands;
+namespace Maestro.Base.Commands.Conditions
+ public class SupportedCommandConditionEvaluator : IConditionEvaluator
+ public bool IsValid(object caller, Condition condition)
+ var wb = Workbench.Instance;
+ if (wb != null)
+ var exp = wb.ActiveSiteExplorer;
+ if (exp != null)
+ var cmds = condition.Properties["commands"].Split(',');
+ var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+ var conn = connMgr.GetConnection(exp.ConnectionName);
+ int[] caps = conn.Capabilities.SupportedCommands;
+ foreach (var cmdName in cmds)
+ try
+ CommandType cmd = (CommandType)Enum.Parse(typeof(CommandType), cmdName);
+ if (Array.IndexOf(caps, (int)cmd) < 0)
+ return false;
+ catch { return false; }
+ return true;
+ return false;
Added: trunk/Tools/Maestro/Maestro.Base/Commands/RtMapInspectorCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/RtMapInspectorCommand.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/RtMapInspectorCommand.cs 2012-01-11 13:27:11 UTC (rev 6419)
@@ -0,0 +1,56 @@
+#endregion
+using System;
+using System.Text;
+using Maestro.Base.UI.Preferences;
+using Maestro.Shared.UI;
+using System.IO;
+using System.Diagnostics;
+ public class RtMapInspectorCommand : AbstractMenuCommand
+ public override void Run()
+ string exe = PropertyService.Get(ConfigProperties.RtMapInspectorPath, "");
+ if (!File.Exists(exe))
+ using (var dlg = DialogFactory.OpenFile())
+ dlg.Title = string.Format(Properties.Resources.LocateExecutable, "RtMapInspector.exe");
+ dlg.Filter = Properties.Resources.FilterExecutables;
+ if (dlg.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ exe = dlg.FileName;
+ PropertyService.Set(ConfigProperties.MgCookerPath, exe);
+ var procInfo = new ProcessStartInfo(exe);
+ procInfo.WorkingDirectory = Path.GetDirectoryName(exe);
+ var proc = Process.Start(procInfo);
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2012-01-11 10:38:34 UTC (rev 6418)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2012-01-11 13:27:11 UTC (rev 6419)
@@ -23,6 +23,7 @@
<ConditionEvaluator name="HasDocuments" class="Maestro.Base.Commands.Conditions.NonZeroDocumentConditionEvaluator" />
<ConditionEvaluator name="ResourceType" class="Maestro.Base.Commands.Conditions.ResourceTypeConditionEvaluator" />
<ConditionEvaluator name="NoConnectionOfType" class="Maestro.Base.Commands.Conditions.ConnectionProviderConditionEvaluator" />
+ <ConditionEvaluator name="SupportedCommand" class="Maestro.Base.Commands.Conditions.SupportedCommandConditionEvaluator" />
</Import>
</Runtime>
@@ -664,6 +665,9 @@
<MenuItem id="LocalFsPreview"
label="${res:LocalFsPreview}"
class="Maestro.Base.Commands.LocalFeatureSourcePreviewCommand"/>
+ <MenuItem id="RtMapInspector"
+ label="${res:RtMapInspector}"
+ class="Maestro.Base.Commands.RtMapInspectorCommand"/>
<MenuItem id="ServerMonitor"
label="${res:ServerMonitor}"
icon="system_monitor"
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2012-01-11 10:38:34 UTC (rev 6418)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2012-01-11 13:27:11 UTC (rev 6419)
@@ -67,11 +67,13 @@
<Compile Include="Commands\Conditions\SelectedItemConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\SelectedRootItemConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\NonZeroDocumentConditionEvaluator.cs" />
+ <Compile Include="Commands\Conditions\SupportedCommandConditionEvaluator.cs" />
<Compile Include="Commands\CopyCommand.cs" />
<Compile Include="Commands\CreatePackageCommand.cs" />
<Compile Include="Commands\CutCommand.cs" />
<Compile Include="Commands\EditAsXmlCommand.cs" />
<Compile Include="Commands\EditPackageCommand.cs" />
+ <Compile Include="Commands\RtMapInspectorCommand.cs" />
<Compile Include="Commands\SiteExplorer\EditResourceHeaderCommand.cs" />
<Compile Include="Commands\LoadPackageCommand.cs" />
<Compile Include="Commands\LocalFeatureSourcePreviewCommand.cs" />
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2012-01-11 10:38:34 UTC (rev 6418)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2012-01-11 13:27:11 UTC (rev 6419)
@@ -1863,6 +1863,15 @@
/// <summary>
+ /// Looks up a localized string similar to Runtime Map Inspector.
+ /// </summary>
+ internal static string RtMapInspector {
+ get {
+ return ResourceManager.GetString("RtMapInspector", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Saved resource content to {0}.
/// </summary>
internal static string SavedResource {
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2012-01-11 10:38:34 UTC (rev 6418)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2012-01-11 13:27:11 UTC (rev 6419)
@@ -1082,4 +1082,7 @@
<data name="Menu_Tools_Translate_Desc" xml:space="preserve">
<value>Translate this Layout</value>
</data>
+ <data name="RtMapInspector" xml:space="preserve">
+ <value>Runtime Map Inspector</value>
+ </data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Base/UI/Preferences/ConfigProperties.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/Preferences/ConfigProperties.cs 2012-01-11 10:38:34 UTC (rev 6418)
+++ trunk/Tools/Maestro/Maestro.Base/UI/Preferences/ConfigProperties.cs 2012-01-11 13:27:11 UTC (rev 6419)
@@ -36,6 +36,7 @@
public const string OpenColor = "General.OpenColor";
public const string DirtyColor = "General.DirtyColor";
public const string MgCookerPath = "General.MgCookerPath";
+ public const string RtMapInspectorPath = "General.RtMapInspectorPath";
public const string LocalFsPreviewPath = "General.LocalFsPreviewPath";
public const string ValidateOnSave = "General.ValidateResourceOnSave";
public const string XsdSchemaPath = "Editor.XsdSchemaPath";
@@ -62,6 +63,7 @@
Props.Set(ConfigProperties.OpenColor, DefaultOpenColor);
Props.Set(ConfigProperties.DirtyColor, DefaultDirtyColor);
Props.Set(ConfigProperties.MgCookerPath, DefaultMgCookerPath);
+ Props.Set(ConfigProperties.RtMapInspectorPath, DefaultRtMapInspectorPath);
Props.Set(ConfigProperties.LocalFsPreviewPath, DefaultLocalFsPreviewPath);
Props.Set(ConfigProperties.ShowTipOfTheDay, DefaultShowTipOfTheDay);
@@ -72,6 +74,8 @@
public static string DefaultLocalFsPreviewPath { get { return Path.Combine(FileUtility.ApplicationRootPath, "MaestroFsPreview.exe"); } }
+ public static string DefaultRtMapInspectorPath { get { return Path.Combine(FileUtility.ApplicationRootPath, "RtMapInspector.exe"); } }
public static Color DefaultOpenColor { get { return Color.LightGreen; } }
public static Color DefaultDirtyColor { get { return Color.Pink; } }
Modified: trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.Designer.cs 2012-01-11 10:38:34 UTC (rev 6418)
+++ trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.Designer.cs 2012-01-11 13:27:11 UTC (rev 6419)
@@ -36,6 +36,7 @@
this.txtTemplatePath = new System.Windows.Forms.TextBox();
this.btnBrowseTemplatePath = new System.Windows.Forms.Button();
this.groupBox1 = new System.Windows.Forms.GroupBox();
+ this.chkShowTipOfTheDay = new System.Windows.Forms.CheckBox();
this.chkOutbound = new System.Windows.Forms.CheckBox();
this.chkMessages = new System.Windows.Forms.CheckBox();
this.groupBox2 = new System.Windows.Forms.GroupBox();
@@ -50,7 +51,9 @@
this.cmbOpenedColor = new Maestro.Editors.Common.ColorComboBox();
this.label6 = new System.Windows.Forms.Label();
this.label5 = new System.Windows.Forms.Label();
- this.chkShowTipOfTheDay = new System.Windows.Forms.CheckBox();
+ this.btnBrowseRtMapInspector = new System.Windows.Forms.Button();
+ this.txtRtMapInspector = new System.Windows.Forms.TextBox();
+ this.label7 = new System.Windows.Forms.Label();
this.groupBox1.SuspendLayout();
this.groupBox2.SuspendLayout();
this.groupBox3.SuspendLayout();
@@ -102,6 +105,12 @@
this.groupBox1.Name = "groupBox1";
this.groupBox1.TabStop = false;
+ // chkShowTipOfTheDay
+ resources.ApplyResources(this.chkShowTipOfTheDay, "chkShowTipOfTheDay");
+ this.chkShowTipOfTheDay.Name = "chkShowTipOfTheDay";
+ this.chkShowTipOfTheDay.UseVisualStyleBackColor = true;
// chkOutbound
resources.ApplyResources(this.chkOutbound, "chkOutbound");
@@ -117,6 +126,9 @@
// groupBox2
resources.ApplyResources(this.groupBox2, "groupBox2");
+ this.groupBox2.Controls.Add(this.label7);
+ this.groupBox2.Controls.Add(this.btnBrowseRtMapInspector);
+ this.groupBox2.Controls.Add(this.txtRtMapInspector);
this.groupBox2.Controls.Add(this.btnBrowseFsPreview);
this.groupBox2.Controls.Add(this.txtFsPreview);
this.groupBox2.Controls.Add(this.btnBrowseMgCooker);
@@ -194,12 +206,24 @@
resources.ApplyResources(this.label5, "label5");
this.label5.Name = "label5";
- // chkShowTipOfTheDay
+ // btnBrowseRtMapInspector
- resources.ApplyResources(this.chkShowTipOfTheDay, "chkShowTipOfTheDay");
- this.chkShowTipOfTheDay.Name = "chkShowTipOfTheDay";
- this.chkShowTipOfTheDay.UseVisualStyleBackColor = true;
+ resources.ApplyResources(this.btnBrowseRtMapInspector, "btnBrowseRtMapInspector");
+ this.btnBrowseRtMapInspector.Name = "btnBrowseRtMapInspector";
+ this.btnBrowseRtMapInspector.UseVisualStyleBackColor = true;
+ this.btnBrowseRtMapInspector.Click += new System.EventHandler(this.btnBrowseRtMapInspector_Click);
+ // txtRtMapInspector
+ resources.ApplyResources(this.txtRtMapInspector, "txtRtMapInspector");
+ this.txtRtMapInspector.Name = "txtRtMapInspector";
+ this.txtRtMapInspector.ReadOnly = true;
+ // label7
+ resources.ApplyResources(this.label7, "label7");
+ this.label7.Name = "label7";
// GeneralPreferencesCtrl
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
@@ -249,5 +273,8 @@
private Maestro.Editors.Common.ColorComboBox cmbModifiedColor;
private Maestro.Editors.Common.ColorComboBox cmbOpenedColor;
private System.Windows.Forms.CheckBox chkShowTipOfTheDay;
+ private System.Windows.Forms.Label label7;
+ private System.Windows.Forms.Button btnBrowseRtMapInspector;
+ private System.Windows.Forms.TextBox txtRtMapInspector;
Modified: trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.cs 2012-01-11 10:38:34 UTC (rev 6418)
+++ trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.cs 2012-01-11 13:27:11 UTC (rev 6419)
@@ -62,6 +62,7 @@
txtFsPreview.Text = Props.Get(ConfigProperties.LocalFsPreviewPath, ConfigProperties.DefaultLocalFsPreviewPath);
txtMgCooker.Text = Props.Get(ConfigProperties.MgCookerPath, ConfigProperties.DefaultMgCookerPath);
+ txtRtMapInspector.Text = Props.Get(ConfigProperties.RtMapInspectorPath, ConfigProperties.DefaultRtMapInspectorPath);
cmbOpenedColor.CurrentColor = Props.Get(ConfigProperties.OpenColor, Color.LightGreen);
cmbModifiedColor.CurrentColor = Props.Get(ConfigProperties.DirtyColor, Color.Pink);
@@ -99,6 +100,7 @@
Apply(ConfigProperties.UserTemplatesDirectory, txtTemplatePath.Text);
Apply(ConfigProperties.MgCookerPath, txtMgCooker.Text);
Apply(ConfigProperties.LocalFsPreviewPath, txtFsPreview.Text);
+ Apply(ConfigProperties.RtMapInspectorPath, txtRtMapInspector.Text);
Apply(ConfigProperties.OpenColor, (Color)cmbOpenedColor.CurrentColor);
Apply(ConfigProperties.DirtyColor, (Color)cmbModifiedColor.CurrentColor);
Apply(ConfigProperties.ShowTipOfTheDay, chkShowTipOfTheDay.Checked);
@@ -155,5 +157,18 @@
+ private void btnBrowseRtMapInspector_Click(object sender, EventArgs e)
+ if (dlg.ShowDialog() == DialogResult.OK)
+ txtRtMapInspector.Text = dlg.FileName;
Modified: trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.resx
--- trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.resx 2012-01-11 10:38:34 UTC (rev 6418)
+++ trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.resx 2012-01-11 13:27:11 UTC (rev 6419)
@@ -285,6 +285,66 @@
<data name="groupBox1.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Left, Right</value>
</data>
+ <data name=">>chkShowTipOfTheDay.Name" xml:space="preserve">
+ <value>chkShowTipOfTheDay</value>
+ </data>
+ <data name=">>chkShowTipOfTheDay.Type" xml:space="preserve">
+ <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>chkShowTipOfTheDay.Parent" xml:space="preserve">
+ <value>groupBox1</value>
+ </data>
+ <data name=">>chkShowTipOfTheDay.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name=">>chkOutbound.Name" xml:space="preserve">
+ <value>chkOutbound</value>
+ </data>
+ <data name=">>chkOutbound.Type" xml:space="preserve">
+ </data>
+ <data name=">>chkOutbound.Parent" xml:space="preserve">
+ </data>
+ <data name=">>chkOutbound.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name=">>chkMessages.Name" xml:space="preserve">
+ <value>chkMessages</value>
+ </data>
+ <data name=">>chkMessages.Type" xml:space="preserve">
+ </data>
+ <data name=">>chkMessages.Parent" xml:space="preserve">
+ </data>
+ <data name=">>chkMessages.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="groupBox1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>16, 93</value>
+ </data>
+ <data name="groupBox1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>426, 50</value>
+ </data>
+ <data name="groupBox1.TabIndex" type="System.Int32, mscorlib">
+ <value>6</value>
+ </data>
+ <data name="groupBox1.Text" xml:space="preserve">
+ <value>Show on Startup</value>
+ </data>
+ <data name=">>groupBox1.Name" xml:space="preserve">
+ </data>
+ <data name=">>groupBox1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>groupBox1.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>groupBox1.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
<data name="chkShowTipOfTheDay.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
@@ -366,33 +426,90 @@
<value>2</value>
</data>
- <data name="groupBox1.Location" type="System.Drawing.Point, System.Drawing">
- <value>16, 93</value>
+ <data name="groupBox2.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Left, Right</value>
</data>
- <data name="groupBox1.Size" type="System.Drawing.Size, System.Drawing">
- <value>426, 50</value>
+ <data name="label7.AutoSize" type="System.Boolean, mscorlib">
+ <value>True</value>
</data>
- <data name="groupBox1.TabIndex" type="System.Int32, mscorlib">
- <value>6</value>
+ <data name="label7.Location" type="System.Drawing.Point, System.Drawing">
+ <value>17, 74</value>
</data>
- <data name="groupBox1.Text" xml:space="preserve">
- <value>Show on Startup</value>
+ <data name="label7.Size" type="System.Drawing.Size, System.Drawing">
+ <value>103, 13</value>
</data>
- <data name=">>groupBox1.Name" xml:space="preserve">
- <value>groupBox1</value>
+ <data name="label7.TabIndex" type="System.Int32, mscorlib">
+ <value>14</value>
</data>
- <data name=">>groupBox1.Type" xml:space="preserve">
- <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <data name="label7.Text" xml:space="preserve">
+ <value>RtMapInspector.exe</value>
</data>
- <data name=">>groupBox1.Parent" xml:space="preserve">
- <value>$this</value>
+ <data name=">>label7.Name" xml:space="preserve">
+ <value>label7</value>
</data>
- <data name=">>groupBox1.ZOrder" xml:space="preserve">
- <value>2</value>
+ <data name=">>label7.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
- <data name="groupBox2.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <data name=">>label7.Parent" xml:space="preserve">
+ <value>groupBox2</value>
+ </data>
+ <data name=">>label7.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="btnBrowseRtMapInspector.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Right</value>
+ </data>
+ <data name="btnBrowseRtMapInspector.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ <value>NoControl</value>
+ </data>
+ <data name="btnBrowseRtMapInspector.Location" type="System.Drawing.Point, System.Drawing">
+ <value>386, 69</value>
+ </data>
+ <data name="btnBrowseRtMapInspector.Size" type="System.Drawing.Size, System.Drawing">
+ <value>25, 23</value>
+ </data>
+ <data name="btnBrowseRtMapInspector.TabIndex" type="System.Int32, mscorlib">
+ <value>13</value>
+ </data>
+ <data name="btnBrowseRtMapInspector.Text" xml:space="preserve">
+ <value>...</value>
+ </data>
+ <data name=">>btnBrowseRtMapInspector.Name" xml:space="preserve">
+ <value>btnBrowseRtMapInspector</value>
+ </data>
+ <data name=">>btnBrowseRtMapInspector.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnBrowseRtMapInspector.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnBrowseRtMapInspector.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="txtRtMapInspector.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
</data>
+ <data name="txtRtMapInspector.Location" type="System.Drawing.Point, System.Drawing">
+ <value>141, 71</value>
+ </data>
+ <data name="txtRtMapInspector.Size" type="System.Drawing.Size, System.Drawing">
+ <value>239, 20</value>
+ </data>
+ <data name="txtRtMapInspector.TabIndex" type="System.Int32, mscorlib">
+ <value>12</value>
+ </data>
+ <data name=">>txtRtMapInspector.Name" xml:space="preserve">
+ <value>txtRtMapInspector</value>
+ </data>
+ <data name=">>txtRtMapInspector.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>txtRtMapInspector.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtRtMapInspector.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
<data name="btnBrowseFsPreview.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
</data>
@@ -418,7 +535,7 @@
</data>
<data name=">>btnBrowseFsPreview.ZOrder" xml:space="preserve">
- <value>0</value>
+ <value>3</value>
</data>
<data name="txtFsPreview.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
@@ -442,7 +559,7 @@
</data>
<data name=">>txtFsPreview.ZOrder" xml:space="preserve">
- <value>1</value>
+ <value>4</value>
</data>
<data name="btnBrowseMgCooker.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
@@ -469,7 +586,7 @@
</data>
<data name=">>btnBrowseMgCooker.ZOrder" xml:space="preserve">
- <value>2</value>
+ <value>5</value>
</data>
<data name="label4.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
@@ -496,7 +613,7 @@
</data>
<data name=">>label4.ZOrder" xml:space="preserve">
- <value>3</value>
+ <value>6</value>
</data>
<data name="txtMgCooker.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
@@ -520,7 +637,7 @@
</data>
<data name=">>txtMgCooker.ZOrder" xml:space="preserve">
- <value>4</value>
+ <value>7</value>
</data>
<data name="label3.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
@@ -547,13 +664,13 @@
</data>
<data name=">>label3.ZOrder" xml:space="preserve">
- <value>5</value>
+ <value>8</value>
</data>
<data name="groupBox2.Location" type="System.Drawing.Point, System.Drawing">
<value>16, 245</value>
</data>
<data name="groupBox2.Size" type="System.Drawing.Size, System.Drawing">
- <value>426, 94</value>
+ <value>426, 115</value>
</data>
<data name="groupBox2.TabIndex" type="System.Int32, mscorlib">
<value>7</value>
@@ -576,6 +693,78 @@
<data name="groupBox3.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
</data>
+ <data name=">>cmbModifiedColor.Name" xml:space="preserve">
+ <value>cmbModifiedColor</value>
+ </data>
+ <data name=">>cmbModifiedColor.Type" xml:space="preserve">
+ <value>Maestro.Editors.Common.ColorComboBox, Maestro.Editors, Version=4.0.0.6359, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
+ </data>
+ <data name=">>cmbModifiedColor.Parent" xml:space="preserve">
+ <value>groupBox3</value>
+ </data>
+ <data name=">>cmbModifiedColor.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name=">>cmbOpenedColor.Name" xml:space="preserve">
+ <value>cmbOpenedColor</value>
+ </data>
+ <data name=">>cmbOpenedColor.Type" xml:space="preserve">
+ </data>
+ <data name=">>cmbOpenedColor.Parent" xml:space="preserve">
+ </data>
+ <data name=">>cmbOpenedColor.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name=">>label6.Name" xml:space="preserve">
+ <value>label6</value>
+ </data>
+ <data name=">>label6.Type" xml:space="preserve">
+ </data>
+ <data name=">>label6.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label6.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name=">>label5.Name" xml:space="preserve">
+ <value>label5</value>
+ </data>
+ <data name=">>label5.Type" xml:space="preserve">
+ </data>
+ <data name=">>label5.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label5.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="groupBox3.Location" type="System.Drawing.Point, System.Drawing">
+ <value>16, 149</value>
+ </data>
+ <data name="groupBox3.Size" type="System.Drawing.Size, System.Drawing">
+ <value>426, 90</value>
+ </data>
+ <data name="groupBox3.TabIndex" type="System.Int32, mscorlib">
+ <value>8</value>
+ </data>
+ <data name="groupBox3.Text" xml:space="preserve">
+ <value>Site Explorer</value>
+ </data>
+ <data name=">>groupBox3.Name" xml:space="preserve">
+ </data>
+ <data name=">>groupBox3.Type" xml:space="preserve">
+ </data>
+ <data name=">>groupBox3.Parent" xml:space="preserve">
+ </data>
+ <data name=">>groupBox3.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
<data name="cmbModifiedColor.Location" type="System.Drawing.Point, System.Drawing">
<value>187, 49</value>
</data>
@@ -589,7 +778,7 @@
</data>
- <value>Maestro.Editors.Common.ColorComboBox, Maestro.Editors, Version=3.0.0.5728, Culture=neutral, PublicKeyToken=null</value>
</data>
@@ -610,7 +799,7 @@
</data>
</data>
@@ -672,35 +861,11 @@
<value>3</value>
</data>
- <data name="groupBox3.Location" type="System.Drawing.Point, System.Drawing">
- <value>16, 149</value>
- </data>
- <data name="groupBox3.Size" type="System.Drawing.Size, System.Drawing">
- <value>426, 90</value>
- </data>
- <data name="groupBox3.TabIndex" type="System.Int32, mscorlib">
- <value>8</value>
- </data>
- <data name="groupBox3.Text" xml:space="preserve">
- <value>Site Explorer</value>
- </data>
- <data name=">>groupBox3.Name" xml:space="preserve">
- <value>groupBox3</value>
- </data>
- <data name=">>groupBox3.Type" xml:space="preserve">
- </data>
- <data name=">>groupBox3.Parent" xml:space="preserve">
- </data>
- <data name=">>groupBox3.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
<metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
<data name="$this.Size" type="System.Drawing.Size, System.Drawing">
- <value>459, 351</value>
+ <value>459, 376</value>
</data>
<data name=">>$this.Name" xml:space="preserve">
<value>GeneralPreferencesCtrl</value>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2012-01-11 10:38:34 UTC (rev 6418)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2012-01-11 13:27:11 UTC (rev 6419)
@@ -1149,6 +1149,23 @@
/// <summary>
+ /// Gets the groups of the specified group.
+ /// </summary>
+ /// <param name="groupName">Name of the group.</param>
+ /// <returns></returns>
+ public RuntimeMapGroup[] GetGroupsOfGroup(string groupName)
+ Check.NotEmpty(groupName, "groupName");
+ List<RuntimeMapGroup> groups = new List<RuntimeMapGroup>();
+ foreach (var grp in this.Groups)
+ if (groupName.Equals(grp.Group))
+ groups.Add(grp);
+ return groups.ToArray();
+ /// <summary>
/// Saves this instance. The changes are propagated back to the MapGuide Server
/// </summary>
public virtual void Save()
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2012-01-11 10:38:34 UTC (rev 6418)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2012-01-11 13:27:11 UTC (rev 6419)
@@ -1931,7 +1931,7 @@
public virtual RuntimeMap OpenMap(string runtimeMapResourceId)
- if (!runtimeMapResourceId.StartsWith("Session:" + this.SessionID + "//") || !runtimeMapResourceId.EndsWith(".Map"))
+ if (!runtimeMapResourceId.StartsWith("Session:") || !runtimeMapResourceId.EndsWith(".Map"))
throw new ArgumentException("Runtime maps must be in the current session repository");
var map = new RuntimeMap(GetInterface());
Modified: trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs
--- trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs 2012-01-11 10:38:34 UTC (rev 6418)
+++ trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs 2012-01-11 13:27:11 UTC (rev 6419)
@@ -23,7 +23,7 @@
[assembly: AssemblyConfiguration("")]
[assembly: AssemblyCompany("Open Source Geospatial Foundation")]
-[assembly: AssemblyCopyright("Copyright (c) 2011, Jackie Ng")]
+[assembly: AssemblyCopyright("Copyright (c) 2012, Jackie Ng")]
// Version information for an assembly consists of the following four values:
Property changes on: trunk/Tools/Maestro/RtMapInspector
___________________________________________________________________
Added: svn:ignore
+ obj
bin
Added: trunk/Tools/Maestro/RtMapInspector/MainForm.Designer.cs
--- trunk/Tools/Maestro/RtMapInspector/MainForm.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/RtMapInspector/MainForm.Designer.cs 2012-01-11 13:27:11 UTC (rev 6419)
@@ -0,0 +1,230 @@
+namespace RtMapInspector
+ partial class MainForm
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ this.components = new System.ComponentModel.Container();
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(MainForm));
+ this.groupBox1 = new System.Windows.Forms.GroupBox();
+ this.btnLoad = new System.Windows.Forms.Button();
+ this.label1 = new System.Windows.Forms.Label();
+ this.txtMapName = new System.Windows.Forms.TextBox();
+ this.txtSessionId = new System.Windows.Forms.TextBox();
+ this.txtResourceId = new System.Windows.Forms.TextBox();
+ this.rdResourceId = new System.Windows.Forms.RadioButton();
+ this.rdMapName = new System.Windows.Forms.RadioButton();
+ this.groupBox2 = new System.Windows.Forms.GroupBox();
+ this.trvLayersAndGroups = new System.Windows.Forms.TreeView();
+ this.imgList = new System.Windows.Forms.ImageList(this.components);
+ this.groupBox3 = new System.Windows.Forms.GroupBox();
+ this.properties = new System.Windows.Forms.PropertyGrid();
+ this.groupBox1.SuspendLayout();
+ this.groupBox2.SuspendLayout();
+ this.groupBox3.SuspendLayout();
+ this.SuspendLayout();
+ // groupBox1
+ this.groupBox1.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ | System.Windows.Forms.AnchorStyles.Right)));
+ this.groupBox1.Controls.Add(this.btnLoad);
+ this.groupBox1.Controls.Add(this.label1);
+ this.groupBox1.Controls.Add(this.txtMapName);
+ this.groupBox1.Controls.Add(this.txtSessionId);
+ this.groupBox1.Controls.Add(this.txtResourceId);
+ this.groupBox1.Controls.Add(this.rdResourceId);
+ this.groupBox1.Controls.Add(this.rdMapName);
+ this.groupBox1.Location = new System.Drawing.Point(13, 13);
+ this.groupBox1.Name = "groupBox1";
+ this.groupBox1.Size = new System.Drawing.Size(597, 135);
+ this.groupBox1.TabIndex = 0;
+ this.groupBox1.TabStop = false;
+ this.groupBox1.Text = "Source";
+ // btnLoad
+ this.btnLoad.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnLoad.Location = new System.Drawing.Point(497, 97);
+ this.btnLoad.Name = "btnLoad";
+ this.btnLoad.Size = new System.Drawing.Size(75, 23);
+ this.btnLoad.TabIndex = 6;
+ this.btnLoad.Text = "Load Map";
+ this.btnLoad.UseVisualStyleBackColor = true;
+ this.btnLoad.Click += new System.EventHandler(this.btnLoad_Click);
+ // label1
+ this.label1.AutoSize = true;
+ this.label1.Location = new System.Drawing.Point(17, 22);
+ this.label1.Name = "label1";
+ this.label1.Size = new System.Drawing.Size(58, 13);
+ this.label1.TabIndex = 5;
+ this.label1.Text = "Session ID";
+ // txtMapName
+ this.txtMapName.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtMapName.Location = new System.Drawing.Point(133, 45);
+ this.txtMapName.Name = "txtMapName";
+ this.txtMapName.Size = new System.Drawing.Size(439, 20);
+ this.txtMapName.TabIndex = 4;
+ // txtSessionId
+ this.txtSessionId.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtSessionId.Location = new System.Drawing.Point(133, 19);
+ this.txtSessionId.Name = "txtSessionId";
+ this.txtSessionId.Size = new System.Drawing.Size(439, 20);
+ this.txtSessionId.TabIndex = 3;
+ // txtResourceId
+ this.txtResourceId.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtResourceId.Location = new System.Drawing.Point(133, 71);
+ this.txtResourceId.Name = "txtResourceId";
+ this.txtResourceId.Size = new System.Drawing.Size(439, 20);
+ this.txtResourceId.TabIndex = 2;
+ // rdResourceId
+ this.rdResourceId.AutoSize = true;
+ this.rdResourceId.Location = new System.Drawing.Point(20, 72);
+ this.rdResourceId.Name = "rdResourceId";
+ this.rdResourceId.Size = new System.Drawing.Size(85, 17);
+ this.rdResourceId.TabIndex = 1;
+ this.rdResourceId.TabStop = true;
+ this.rdResourceId.Text = "Resource ID";
+ this.rdResourceId.UseVisualStyleBackColor = true;
+ // rdMapName
+ this.rdMapName.AutoSize = true;
+ this.rdMapName.Checked = true;
+ this.rdMapName.Location = new System.Drawing.Point(20, 45);
+ this.rdMapName.Name = "rdMapName";
+ this.rdMapName.Size = new System.Drawing.Size(77, 17);
+ this.rdMapName.TabIndex = 0;
+ this.rdMapName.TabStop = true;
+ this.rdMapName.Text = "Map Name";
+ this.rdMapName.UseVisualStyleBackColor = true;
+ // groupBox2
+ this.groupBox2.Anchor = ((System.Windows.Forms.AnchorStyles)((((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom)
+ | System.Windows.Forms.AnchorStyles.Left)
+ this.groupBox2.Controls.Add(this.trvLayersAndGroups);
+ this.groupBox2.Location = new System.Drawing.Point(13, 155);
+ this.groupBox2.Name = "groupBox2";
+ this.groupBox2.Size = new System.Drawing.Size(321, 328);
+ this.groupBox2.TabIndex = 1;
+ this.groupBox2.TabStop = false;
+ this.groupBox2.Text = "Layers and Groups";
+ // trvLayersAndGroups
+ this.trvLayersAndGroups.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.trvLayersAndGroups.ImageIndex = 0;
+ this.trvLayersAndGroups.ImageList = this.imgList;
+ this.trvLayersAndGroups.Location = new System.Drawing.Point(3, 16);
+ this.trvLayersAndGroups.Name = "trvLayersAndGroups";
+ this.trvLayersAndGroups.SelectedImageIndex = 0;
+ this.trvLayersAndGroups.Size = new System.Drawing.Size(315, 309);
+ this.trvLayersAndGroups.TabIndex = 0;
+ this.trvLayersAndGroups.AfterSelect += new System.Windows.Forms.TreeViewEventHandler(this.trvLayersAndGroups_AfterSelect);
+ // imgList
+ this.imgList.ImageStream = ((System.Windows.Forms.ImageListStreamer)(resources.GetObject("imgList.ImageStream")));
+ this.imgList.TransparentColor = System.Drawing.Color.Transparent;
+ this.imgList.Images.SetKeyName(0, "folder.png");
+ this.imgList.Images.SetKeyName(1, "folder--minus.png");
+ this.imgList.Images.SetKeyName(2, "layer.png");
+ this.imgList.Images.SetKeyName(3, "layer--minus.png");
+ this.imgList.Images.SetKeyName(4, "map.png");
+ // groupBox3
+ this.groupBox3.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom)
+ this.groupBox3.Controls.Add(this.properties);
+ this.groupBox3.Location = new System.Drawing.Point(340, 155);
+ this.groupBox3.Name = "groupBox3";
+ this.groupBox3.Size = new System.Drawing.Size(270, 328);
+ this.groupBox3.TabIndex = 2;
+ this.groupBox3.TabStop = false;
+ this.groupBox3.Text = "Properties";
+ // properties
+ this.properties.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.properties.Location = new System.Drawing.Point(3, 16);
+ this.properties.Name = "properties";
+ this.properties.Size = new System.Drawing.Size(264, 309);
+ this.properties.TabIndex = 0;
+ // MainForm
+ this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.ClientSize = new System.Drawing.Size(622, 495);
+ this.Controls.Add(this.groupBox3);
+ this.Controls.Add(this.groupBox2);
+ this.Controls.Add(this.groupBox1);
+ this.Name = "MainForm";
+ this.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent;
+ this.Text = "Runtime Map Inspector";
+ this.groupBox1.ResumeLayout(false);
+ this.groupBox1.PerformLayout();
+ this.groupBox2.ResumeLayout(false);
+ this.groupBox3.ResumeLayout(false);
+ this.ResumeLayout(false);
+ #endregion
+ private System.Windows.Forms.GroupBox groupBox1;
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.TextBox txtMapName;
+ private System.Windows.Forms.TextBox txtSessionId;
+ private System.Windows.Forms.TextBox txtResourceId;
+ private System.Windows.Forms.RadioButton rdResourceId;
+ private System.Windows.Forms.RadioButton rdMapName;
+ private System.Windows.Forms.Button btnLoad;
+ private System.Windows.Forms.GroupBox groupBox2;
+ private System.Windows.Forms.TreeView trvLayersAndGroups;
+ private System.Windows.Forms.GroupBox groupBox3;
+ private System.Windows.Forms.PropertyGrid properties;
+ private System.Windows.Forms.ImageList imgList;
Added: trunk/Tools/Maestro/RtMapInspector/MainForm.cs
--- trunk/Tools/Maestro/RtMapInspector/MainForm.cs (rev 0)
+++ trunk/Tools/Maestro/RtMapInspector/MainForm.cs 2012-01-11 13:27:11 UTC (rev 6419)
@@ -0,0 +1,525 @@
+#endregion
+using System;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Text;
+using System.Windows.Forms;
+using OSGeo.MapGuide.MaestroAPI.Mapping;
+using OSGeo.MapGuide.MaestroAPI;
+using Maestro.Login;
+using OSGeo.MapGuide.MaestroAPI.Services;
+using OSGeo.MapGuide.ObjectModels.Common;
+ public partial class MainForm : Form
+ public MainForm()
+ InitializeComponent();
+ private IServerConnection _conn;
+ private IMappingService _mappingSvc;
+ private RuntimeMap _rtMap;
+ #region Design-time property wrappers
+ class PointDecorator
+ private string _str;
+ public PointDecorator(IPoint2D pt)
+ _str = "(" + pt.X + ", " + pt.Y + ")";
+ public override string ToString()
+ return _str;
+ class BoxDecorator
+ public BoxDecorator(IEnvelope env)
+ _str = string.Format("( ({0}, {1}), ({2}, {3}) )", env.MinX, env.MinY, env.MaxX, env.MaxY);
+ return _str;
+ class MapDecorator
+ private RuntimeMap _map;
+ [Category("Map Properties")]
+ [ReadOnly(true)]
+ public string Name
+ get { return _map.Name; }
+ set { _map.Name = value; }
+ [ReadOnly(true)]
+ public Color BackgroundColor
+ get { return _map.BackgroundColor; }
+ set { _map.BackgroundColor = value; }
+ [ReadOnly(true)]
+ public int DisplayDpi
+ get { return _map.DisplayDpi; }
+ set { _map.DisplayDpi = value; }
+ [ReadOnly(true)]
+ public int DisplayHeight
+ get { return _map.DisplayHeight; }
+ set { _map.DisplayWidth = value; }
+ [ReadOnly(true)]
+ public int DisplayWidth
+ get { return _map.DisplayWidth; }
+ [ReadOnly(true)]
+ public string ResourceId
+ get { return _map.ResourceID; }
+ set { _map.ResourceID = value; }
+ [ReadOnly(true)]
+ public string ObjectId
+ get { return _map.ObjectId; }
+ [ReadOnly(true)]
+ public string CoordinateSystem
+ get { return _map.CoordinateSystem; }
+ [ReadOnly(true)]
+ public double MetersPerUnit
+ get { return _map.MetersPerUnit; }
+ [ReadOnly(true)]
+ public PointDecorator ViewCenter
+ get { return new PointDecorator(_map.ViewCenter); }
+ [ReadOnly(true)]
+ public BoxDecorator DataExtent
+ get { return new BoxDecorator(_map.DataExtent); }
+ public MapDecorator(RuntimeMap map)
+ _map = map;
+ class GroupDecorator
+ private RuntimeMapGroup _group;
+ public GroupDecorator(RuntimeMapGroup group)
+ _group = group;
+ [Category("Group properties")]
+ [ReadOnly(true)]
+ public bool ExpandInLegend
+ get { return _group.ExpandInLegend; }
+ set { _group.ExpandInLegend = value; }
+ [ReadOnly(true)]
+ public string Group
+ get { return _group.Group; }
+ set { _group.Group = value; }
+ [ReadOnly(true)]
+ public string LegendLabel
+ get { return _group.LegendLabel; }
+ set { _group.LegendLabel = value; }
+ [ReadOnly(true)]
+ get { return _group.Name; }
+ set { _group.Name = value; }
+ [ReadOnly(true)]
+ get { return _group.ObjectId; }
+ [ReadOnly(true)]
+ public bool ShowInLegend
+ get { return _group.ShowInLegend; }
+ set { _group.ShowInLegend = value; }
+ [ReadOnly(true)]
+ public int Type
+ get { return _group.Type; }
+ [ReadOnly(true)]
+ public bool Visible
+ get { return _group.Visible; }
+ set { _group.Visible = value; }
+ class LayerDecorator
+ private RuntimeMapLayer _layer;
+ public LayerDecorator(RuntimeMapLayer layer)
+ _layer = layer;
+ [Category("Layer Properties")]
+ [ReadOnly(true)]
+ public double DisplayOrder
+ get { return _layer.DisplayOrder; }
+ [ReadOnly(true)]
+ get { return _layer.ExpandInLegend; }
+ set { _layer.ExpandInLegend = value; }
+ [ReadOnly(true)]
+ public string FeatureSourceID
+ get { return _layer.FeatureSourceID; }
+ [ReadOnly(true)]
+ public string Filter
+ get { return _layer.Filter; }
+ [ReadOnly(true)]
+ public string GeometryPropertyName
+ get { return _layer.GeometryPropertyName; }
+ [ReadOnly(true)]
+ get { return _layer.Group; }
+ set { _layer.Group = value; }
+ [ReadOnly(true)]
+ public bool HasTooltips
+ get { return _layer.HasTooltips; }
+ [ReadOnly(true)]
+ public string[] IdentityProperties
+ get { return new IdentityPropertyCollection(_layer.IdentityProperties).ToArray(); }
+ [ReadOnly(true)]
+ public string LayerDefinition
+ get { return _layer.LayerDefinitionID; }
+ [ReadOnly(true)]
+ get { return _layer.LegendLabel; }
+ set { _layer.LegendLabel = value; }
+ [ReadOnly(true)]
+ get { return _layer.Name; }
+ set { _layer.Name = value; }
+ [ReadOnly(true)]
+ public bool NeedsRefresh
+ get { return _layer.NeedsRefresh; }
+ [ReadOnly(true)]
+ get { return _layer.ObjectId; }
+ [ReadOnly(true)]
+ public string FeatureClass
+ get { return _layer.QualifiedClassName; }
+ [ReadOnly(true)]
+ public string[] ScaleRanges
+ get { return new ScaleRangeCollection(_layer.ScaleRanges).ToArray(); }
+ [ReadOnly(true)]
+ public string SchemaName
+ get { return _layer.SchemaName; }
+ [ReadOnly(true)]
+ public bool Selectable
+ get { return _layer.Selectable; }
+ set { _layer.Selectable = value; }
+ [ReadOnly(true)]
+ get { return _layer.ShowInLegend; }
+ set { _layer.ShowInLegend = value; }
+ [ReadOnly(true)]
+ public int Type
+ get { return _layer.Type; }
+ [ReadOnly(true)]
+ get { return _layer.Visible; }
+ set { _layer.Visible = value; }
+ class ScaleRangeCollection : List<string>
+ public ScaleRangeCollection(RuntimeMapLayer.ScaleRange[] ranges)
+ foreach(var s in ranges )
+ Add(s.MinScale + " : " + s.MaxScale);
+ class IdentityPropertyCollection : List<string>
+ public IdentityPropertyCollection(PropertyInfo[] props)
+ foreach (var p in props)
+ Add(p.Name + " (" + p.Type.FullName + ")");
+ #endregion
+ protected override void OnLoad(EventArgs e)
+ base.OnLoad(e);
+ var login = new LoginDialog();
+ if (login.ShowDialog() == DialogResult.OK)
+ _conn = login.Connection;
+ if (Array.IndexOf(_conn.Capabilities.SupportedServices, (int)ServiceType.Mapping) < 0)
+ MessageBox.Show(Properties.Resources.ErrIncompatibleConnection);
+ Application.Exit();
+ _mappingSvc = (IMappingService)_conn.GetService((int)ServiceType.Mapping);
+ else
+ private void btnLoad_Click(object sender, EventArgs e)
+ _rtMap = null;
+ properties.SelectedObject = null;
+ trvLayersAndGroups.Nodes.Clear();
+ if (rdMapName.Checked)
+ _rtMap = _mappingSvc.OpenMap(string.Format("Session:{0}//{1}.Map", txtSessionId.Text, txtMapName.Text));
+ else if (rdResourceId.Checked)
+ _rtMap = _mappingSvc.OpenMap(txtResourceId.Text);
+ if (_rtMap == null)
+ MessageBox.Show(Properties.Resources.ErrFailedRuntimeMapOpen);
+ return;
+ InitTreeView();
+ const int IDX_GROUP = 0;
+ const int IDX_GROUP_HIDDEN = 1;
+ const int IDX_LAYER = 2;
+ const int IDX_LAYER_HIDDEN = 3;
+ const int IDX_MAP = 4;
+ private TreeNode CreateGroupNode(RuntimeMapGroup group)
+ var node = new TreeNode(group.LegendLabel);
+ node.Tag = new GroupDecorator(group);
+ node.ImageIndex = node.SelectedImageIndex = group.Visible ? IDX_GROUP : IDX_GROUP_HIDDEN;
+ foreach (var grp in _rtMap.GetGroupsOfGroup(group.Name))
+ node.Nodes.Add(CreateGroupNode(grp));
+ foreach (var layer in _rtMap.GetLayersOfGroup(group.Name))
+ node.Nodes.Add(CreateLayerNode(layer));
+ return node;
+ private TreeNode CreateLayerNode(RuntimeMapLayer layer)
+ var node = new TreeNode(layer.LegendLabel);
+ node.Tag = new LayerDecorator(layer);
+ node.ImageIndex = node.SelectedImageIndex = layer.Visible ? IDX_LAYER : IDX_LAYER_HIDDEN;
+ return node;
+ private void InitTreeView()
+ try
+ trvLayersAndGroups.BeginUpdate();
+ var node = new TreeNode(_rtMap.Name);
+ node.ImageIndex = node.SelectedImageIndex = IDX_MAP;
+ node.Tag = new MapDecorator(_rtMap);
+ trvLayersAndGroups.Nodes.Add(node);
+ foreach (var group in _rtMap.Groups)
+ node.Nodes.Add(CreateGroupNode(group));
+ finally
+ trvLayersAndGroups.EndUpdate();
+ private void trvLayersAndGroups_AfterSelect(object sender, TreeViewEventArgs e)
+ properties.SelectedObject = e.Node.Tag;
Added: trunk/Tools/Maestro/RtMapInspector/MainForm.resx
--- trunk/Tools/Maestro/RtMapInspector/MainForm.resx (rev 0)
+++ trunk/Tools/Maestro/RtMapInspector/MainForm.resx 2012-01-11 13:27:11 UTC (rev 6419)
@@ -0,0 +1,182 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <metadata name="imgList.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
+ <data name="imgList.ImageStream" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>
+ AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
+ LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
+ ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAAE
+ DAAAAk1TRnQBSQFMAgEBBQEAAQgBAAEIAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
+ AwABQAMAASADAAEBAQABCAYAAQgYAAGAAgABgAMAAoABAAGAAwABgAEAAYABAAKAAgADwAEAAcAB3AHA
+ AQAB8AHKAaYBAAEzBQABMwEAATMBAAEzAQACMwIAAxYBAAMcAQADIgEAAykBAANVAQADTQEAA0IBAAM5
+ AQABgAF8Af8BAAJQAf8BAAGTAQAB1gEAAf8B7AHMAQABxgHWAe8BAAHWAucBAAGQAakBrQIAAf8BMwMA
+ AWYDAAGZAwABzAIAATMDAAIzAgABMwFmAgABMwGZAgABMwHMAgABMwH/AgABZgMAAWYBMwIAAmYCAAFm
+ AZkCAAFmAcwCAAFmAf8CAAGZAwABmQEzAgABmQFmAgACmQIAAZkBzAIAAZkB/wIAAcwDAAHMATMCAAHM
+ AWYCAAHMAZkCAALMAgABzAH/AgAB/wFmAgAB/wGZAgAB/wHMAQABMwH/AgAB/wEAATMBAAEzAQABZgEA
+ ATMBAAGZAQABMwEAAcwBAAEzAQAB/wEAAf8BMwIAAzMBAAIzAWYBAAIzAZkBAAIzAcwBAAIzAf8BAAEz
+ AWYCAAEzAWYBMwEAATMCZgEAATMBZgGZAQABMwFmAcwBAAEzAWYB/wEAATMBmQIAATMBmQEzAQABMwGZ
+ AWYBAAEzApkBAAEzAZkBzAEAATMBmQH/AQABMwHMAgABMwHMATMBAAEzAcwBZgEAATMBzAGZAQABMwLM
+ AQABMwHMAf8BAAEzAf8BMwEAATMB/wFmAQABMwH/AZkBAAEzAf8BzAEAATMC/wEAAWYDAAFmAQABMwEA
+ AWYBAAFmAQABZgEAAZkBAAFmAQABzAEAAWYBAAH/AQABZgEzAgABZgIzAQABZgEzAWYBAAFmATMBmQEA
+ AWYBMwHMAQABZgEzAf8BAAJmAgACZgEzAQADZgEAAmYBmQEAAmYBzAEAAWYBmQIAAWYBmQEzAQABZgGZ
+ AWYBAAFmApkBAAFmAZkBzAEAAWYBmQH/AQABZgHMAgABZgHMATMBAAFmAcwBmQEAAWYCzAEAAWYBzAH/
+ AQABZgH/AgABZgH/ATMBAAFmAf8BmQEAAWYB/wHMAQABzAEAAf8BAAH/AQABzAEAApkCAAGZATMBmQEA
+ AZkBAAGZAQABmQEAAcwBAAGZAwABmQIzAQABmQEAAWYBAAGZATMBzAEAAZkBAAH/AQABmQFmAgABmQFm
+ ATMBAAGZATMBZgEAAZkBZgGZAQABmQFmAcwBAAGZATMB/wEAApkBMwEAApkBZgEAA5kBAAKZAcwBAAKZ
+ Af8BAAGZAcwCAAGZAcwBMwEAAWYBzAFmAQABmQHMAZkBAAGZAswBAAGZAcwB/wEAAZkB/wIAAZkB/wEz
+ AQABmQHMAWYBAAGZAf8BmQEAAZkB/wHMAQABmQL/AQABzAMAAZkBAAEzAQABzAEAAWYBAAHMAQABmQEA
+ AcwBAAHMAQABmQEzAgABzAIzAQABzAEzAWYBAAHMATMBmQEAAcwBMwHMAQABzAEzAf8BAAHMAWYCAAHM
+ AWYBMwEAAZkCZgEAAcwBZgGZAQABzAFmAcwBAAGZAWYB/wEAAcwBmQIAAcwBmQEzAQABzAGZAWYBAAHM
+ ApkBAAHMAZkBzAEAAcwBmQH/AQACzAIAAswBMwEAAswBZgEAAswBmQEAA8wBAALMAf8BAAHMAf8CAAHM
+ Af8BMwEAAZkB/wFmAQABzAH/AZkBAAHMAf8BzAEAAcwC/wEAAcwBAAEzAQAB/wEAAWYBAAH/AQABmQEA
+ AcwBMwIAAf8CMwEAAf8BMwFmAQAB/wEzAZkBAAH/ATMBzAEAAf8BMwH/AQAB/wFmAgAB/wFmATMBAAHM
+ AmYBAAH/AWYBmQEAAf8BZgHMAQABzAFmAf8BAAH/AZkCAAH/AZkBMwEAAf8BmQFmAQAB/wKZAQAB/wGZ
+ AcwBAAH/AZkB/wEAAf8BzAIAAf8BzAEzAQAB/wHMAWYBAAH/AcwBmQEAAf8CzAEAAf8BzAH/AQAC/wEz
+ AQABzAH/AWYBAAL/AZkBAAL/AcwBAAJmAf8BAAFmAf8BZgEAAWYC/wEAAf8CZgEAAf8BZgH/AQAC/wFm
+ AQABIQEAAaUBAANfAQADdwEAA4YBAAOWAQADywEAA7IBAAPXAQAD3QEAA+MBAAPqAQAD8QEAA/gBAAHw
+ AfsB/wEAAaQCoAEAA4ADAAH/AgAB/wMAAv8BAAH/AwAB/wEAAf8BAAL/AgAD/wEAD/8xAAG8DQcBvDEA
+ AQcB9Qv0AfUBBzEAAe4B9AZzAngBHAKZAfQB7jEAAe4B9AFzARwBeAFzAngBmQEcAZ8BwwEIAfQB7jEA
+ AbwB9AFzARwBeAFzAXgCmQGYAZ8BGwEHAfQBvDEAAbwB9ANzA3gBmAKZAQgBuwH0AbwxAAG8AfUBcwN4
+ ApkBnwGZARsBGQG7AfUBvDEAAbwB9QFzA3gCmQGfAZkB8QHcAboB9QG8MQAB8AH1AXMBeAGZAXgBmQGf
+ AcMBCAEJAdwBugH1AfAxAAHwAfUDeAOZAQgCuwK6AfUB8DEAAfAB/wF4A5kBwwEbAfEBuwLcAboB/wHw
+ MQAB8AH/AXgDmQHDAcIBCQG6AdwB2wG6Af8B8DEAAfAB/wF4AZgCmQEIArsDugG0Af8B8DEAAfEN/wHx
+ MQAB8w3yAfMxAAH/AfQBHAp0ARwB9AL/AfQBHAp0ARwB9CP/AXQImgFSAZoBdAHyA/8BdAiaAVIBmgF0
+ AfIC/wHzDLwB8wL/AfMMvAHzAf8CAAGZAZoGegGaAXQBmgHaAZkBAAGTAW4ERQFLA3oBmgF0AZoB2gGZ
+ AgAB8QHwCvIB8AHxAgAB8QHwBvIBbgVFAZMCAAGZAZoGegGaAXQBmgHaAZkBAAFvBeMBRQN6AZoBdAGa
+ AdoBmQIAAfAM8gHwAgAB8AfyAUUF4wFvAgABmQiaAXQBmgHzAZkBAAGTAW8ERgFMBJoBdAGaAfMBmQIA
+ AfAM8gHwAgAB8AfyAW8ERgFFAZMCAAGZCJoBdAGaAfQBmQMAAZkImgF0AZoB9AGZAgAB8QzyAfECAAHx
+ DPIB8QMAAZkImgF0AZoB9QGZAwABmQiaAXQBmgH1AZkCAAHxAfML8gHxAgAB8QHzC/IB8QMAAZkImgJ5
+ Af8BmQMAAZkImgJ5Af8BmQIAAfEB8wvyAfECAAHxAfML8gHxAwABmQmaAXkBmQH0AwABmQmaAXkBmQH0
+ AgAB8QPzCfIB8QIAAfED8wnyAfEDAAGZCZoBoAGZBAABmQmaAaABmQMAAfIG8wfyAgAB8gbzB/IDAAEa
+ AaAImgGgARoEAAEaAaAImgGgARoDAAHyAfQK8wH0AfICAAHyAfQK8wH0AfIDAAEaAaAImgGgARoEAAEa
+ AaAImgGgARoDAAHyAfQK8wH0AfICAAHyAfQK8wH0AfIDAAEaCqABGgQAARoKoAEaAwAB8gH0CvMB9AHy
+ AgAB8gH0CvMB9AHyAwABGgqgARoEAAEaCqABGgMAAfMB8gr0AfIB8wIAAfMB8gr0AfIB8wMAARoBwwig
+ AcMBGgQAARoBwwigAcMBGgMAAf8B8wryAfMB/wIAAf8B8wryAfMB/wMAARsKGgEbBAABGwoaARsiAAFC
+ AU0BPgcAAT4DAAEoAwABQAMAASADAAEBAQABAQYAAQEWAAP/AgABAQcAAQEHAAEBBwABAQcAAQEHAAEB
+ BwABAQcAAQEHAAEBBwABAQcAAQEHAAEBBwABAQcAAQEHAAEBBwABARYAAcABAQEAAQEBgAEBAYABAAHA
+ AQEBAAEBAYABAQGAAQABwAEBAQABAQGAAQEBgAEAAcABAQHAAQEBgAEBAYABAQHAAQEBwAEBAYABAQGA
+ AQEBwAEBAcABAQGAAQEBgAEBAcABAQHAAQEBgAEBAYABAQHAAQMBwAEDAYABAQGAAQEBwAEDAcABAwGA
+ AQEBgAEBAcABAwHAAQMBgAEBAYABAQHAAQMBwAEDAYABAQGAAQEBwAEDAcABAwGAAQEBgAEBAcABAwHA
+ AQMBgAEBAYABAQHAAQMBwAEDBP8L
+</value>
+ </data>
+</root>
Added: trunk/Tools/Maestro/RtMapInspector/Program.cs
--- trunk/Tools/Maestro/RtMapInspector/Program.cs (rev 0)
+++ trunk/Tools/Maestro/RtMapInspector/Program.cs 2012-01-11 13:27:11 UTC (rev 6419)
@@ -0,0 +1,39 @@
+#endregion
+using System;
+ static class Program
+ /// <summary>
+ /// The main entry point for the application.
+ /// </summary>
+ [STAThread]
+ static void Main()
+ Application.EnableVisualStyles();
+ Application.SetCompatibleTextRenderingDefault(false);
+ Application.Run(new MainForm());
Added: trunk/Tools/Maestro/RtMapInspector/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/RtMapInspector/Properties/AssemblyInfo.cs (rev 0)
+++ trunk/Tools/Maestro/RtMapInspector/Properties/AssemblyInfo.cs 2012-01-11 13:27:11 UTC (rev 6419)
@@ -0,0 +1,20 @@
+using System.Reflection;
+using System.Runtime.CompilerServices;
+using System.Runtime.InteropServices;
+// General Information about an assembly is controlled through the following
+// set of attributes. Change these attribute values to modify the information
+// associated with an assembly.
+[assembly: AssemblyTitle("RtMapInspector")]
+[assembly: AssemblyDescription("")]
+[assembly: AssemblyProduct("RtMapInspector")]
+[assembly: AssemblyTrademark("")]
+[assembly: AssemblyCulture("")]
+// Setting ComVisible to false makes the types in this assembly not visible
+// to COM components. If you need to access a type in this assembly from
+// COM, set the ComVisible attribute to true on that type.
+[assembly: ComVisible(false)]
+// The following GUID is for the ID of the typelib if this project is exposed to COM
+[assembly: Guid("cd28ed02-61bf-46cc-a986-4ff3b50b0aae")]
Added: trunk/Tools/Maestro/RtMapInspector/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/RtMapInspector/Properties/Resources.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/RtMapInspector/Properties/Resources.Designer.cs 2012-01-11 13:27:11 UTC (rev 6419)
@@ -0,0 +1,81 @@
+// <auto-generated>
+// This code was generated by a tool.
+// Runtime Version:2.0.50727.5448
+// Changes to this file may cause incorrect behavior and will be lost if
+// the code is regenerated.
+// </auto-generated>
+namespace RtMapInspector.Properties {
+ using System;
+ /// <summary>
+ /// A strongly-typed resource class, for looking up localized strings, etc.
+ /// </summary>
+ // This class was auto-generated by the StronglyTypedResourceBuilder
+ // class via a tool like ResGen or Visual Studio.
+ // To add or remove a member, edit your .ResX file then rerun ResGen
+ // with the /str option, or rebuild your VS project.
+ [global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "2.0.0.0")]
+ [global::System.Diagnostics.DebuggerNonUserCodeAttribute()]
+ [global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()]
+ internal class Resources {
+ private static global::System.Resources.ResourceManager resourceMan;
+ private static global::System.Globalization.CultureInfo resourceCulture;
+ [global::System.Diagnostics.CodeAnalysis.SuppressMessageAttribute("Microsoft.Performance", "CA1811:AvoidUncalledPrivateCode")]
+ internal Resources() {
+ /// <summary>
+ /// Returns the cached ResourceManager instance used by this class.
+ /// </summary>
+ [global::System.ComponentModel.EditorBrowsableAttribute(global::System.ComponentModel.EditorBrowsableState.Advanced)]
+ internal static global::System.Resources.ResourceManager ResourceManager {
+ get {
+ if (object.ReferenceEquals(resourceMan, null)) {
+ global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("RtMapInspector.Properties.Resources", typeof(Resources).Assembly);
+ resourceMan = temp;
+ return resourceMan;
+ /// <summary>
+ /// Overrides the current thread's CurrentUICulture property for all
+ /// resource lookups using this strongly typed resource class.
+ /// </summary>
+ internal static global::System.Globalization.CultureInfo Culture {
+ get {
+ return resourceCulture;
+ set {
+ resourceCulture = value;
+ /// <summary>
+ /// Looks up a localized string similar to Failed to open the Runtime Map.
+ /// </summary>
+ internal static string ErrFailedRuntimeMapOpen {
+ get {
+ return ResourceManager.GetString("ErrFailedRuntimeMapOpen", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to The selected connection is not compatible.
+ /// </summary>
+ internal static string ErrIncompatibleConnection {
+ get {
+ return ResourceManager.GetString("ErrIncompatibleConnection", resourceCulture);
Added: trunk/Tools/Maestro/RtMapInspector/Properties/Resources.resx
--- trunk/Tools/Maestro/RtMapInspector/Properties/Resources.resx (rev 0)
+++ trunk/Tools/Maestro/RtMapInspector/Properties/Resources.resx 2012-01-11 13:27:11 UTC (rev 6419)
@@ -0,0 +1,126 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ <data name="ErrFailedRuntimeMapOpen" xml:space="preserve">
+ <value>Failed to open the Runtime Map</value>
+ </data>
+ <data name="ErrIncompatibleConnection" xml:space="preserve">
+ <value>The selected connection is not compatible</value>
+ </data>
+</root>
Added: trunk/Tools/Maestro/RtMapInspector/Properties/Settings.Designer.cs
--- trunk/Tools/Maestro/RtMapInspector/Properties/Settings.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/RtMapInspector/Properties/Settings.Designer.cs 2012-01-11 13:27:11 UTC (rev 6419)
@@ -0,0 +1,30 @@
+ [global::System.CodeDom.Compiler.GeneratedCodeAttribute("Microsoft.VisualStudio.Editors.SettingsDesigner.SettingsSingleFileGenerator", "9.0.0.0")]
+ internal sealed partial class Settings : global::System.Configuration.ApplicationSettingsBase
+ private static Settings defaultInstance = ((Settings)(global::System.Configuration.ApplicationSettingsBase.Synchronized(new Settings())));
+ public static Settings Default
+ get
+ return defaultInstance;
Added: trunk/Tools/Maestro/RtMapInspector/Properties/Settings.settings
--- trunk/Tools/Maestro/RtMapInspector/Properties/Settings.settings (rev 0)
+++ trunk/Tools/Maestro/RtMapInspector/Properties/Settings.settings 2012-01-11 13:27:11 UTC (rev 6419)
@@ -0,0 +1,7 @@
+<?xml version='1.0' encoding='utf-8'?>
+<SettingsFile xmlns="http://schemas.microsoft.com/VisualStudio/2004/01/settings" CurrentProfile="(Default)">
+ <Profiles>
+ <Profile Name="(Default)" />
+ </Profiles>
+ <Settings />
+</SettingsFile>
Added: trunk/Tools/Maestro/RtMapInspector/RtMapInspector.csproj
--- trunk/Tools/Maestro/RtMapInspector/RtMapInspector.csproj (rev 0)
+++ trunk/Tools/Maestro/RtMapInspector/RtMapInspector.csproj 2012-01-11 13:27:11 UTC (rev 6419)
@@ -0,0 +1,94 @@
+<Project ToolsVersion="3.5" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <PropertyGroup>
+ <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
+ <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
+ <ProductVersion>9.0.30729</ProductVersion>
+ <SchemaVersion>2.0</SchemaVersion>
+ <ProjectGuid>{E204559D-EE92-4792-96E2-06F45654FAFC}</ProjectGuid>
+ <OutputType>WinExe</OutputType>
+ <AppDesignerFolder>Properties</AppDesignerFolder>
+ <RootNamespace>RtMapInspector</RootNamespace>
+ <AssemblyName>RtMapInspector</AssemblyName>
+ <TargetFrameworkVersion>v2.0</TargetFrameworkVersion>
+ <FileAlignment>512</FileAlignment>
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
+ <DebugSymbols>true</DebugSymbols>
+ <DebugType>full</DebugType>
+ <Optimize>false</Optimize>
+ <OutputPath>..\out\Debug\</OutputPath>
+ <DefineConstants>DEBUG;TRACE</DefineConstants>
+ <ErrorReport>prompt</ErrorReport>
+ <WarningLevel>4</WarningLevel>
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' ">
+ <DebugType>pdbonly</DebugType>
+ <Optimize>true</Optimize>
+ <OutputPath>..\out\Release\</OutputPath>
+ <DefineConstants>TRACE</DefineConstants>
+ </PropertyGroup>
+ <ItemGroup>
+ <Reference Include="System" />
+ <Reference Include="System.Data" />
+ <Reference Include="System.Deployment" />
+ <Reference Include="System.Drawing" />
+ <Reference Include="System.Windows.Forms" />
+ <Reference Include="System.Xml" />
+ </ItemGroup>
+ <ItemGroup>
+ <Compile Include="..\Properties\GlobalAssemblyInfo.cs">
+ <Link>GlobalAssemblyInfo.cs</Link>
+ </Compile>
+ <Compile Include="MainForm.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="MainForm.Designer.cs">
+ <DependentUpon>MainForm.cs</DependentUpon>
+ </Compile>
+ <Compile Include="Program.cs" />
+ <Compile Include="Properties\AssemblyInfo.cs" />
+ <EmbeddedResource Include="MainForm.resx">
+ </EmbeddedResource>
+ <EmbeddedResource Include="Properties\Resources.resx">
+ <Generator>ResXFileCodeGenerator</Generator>
+ <LastGenOutput>Resources.Designer.cs</LastGenOutput>
+ <SubType>Designer</SubType>
+ <Compile Include="Properties\Resources.Designer.cs">
+ <AutoGen>True</AutoGen>
+ <DependentUpon>Resources.resx</DependentUpon>
+ <DesignTime>True</DesignTime>
+ </Compile>
+ <None Include="Properties\Settings.settings">
+ <Generator>SettingsSingleFileGenerator</Generator>
+ <LastGenOutput>Settings.Designer.cs</LastGenOutput>
+ </None>
+ <Compile Include="Properties\Settings.Designer.cs">
+ <DependentUpon>Settings.settings</DependentUpon>
+ <DesignTimeSharedInput>True</DesignTimeSharedInput>
+ </Compile>
+ </ItemGroup>
+ <ItemGroup>
+ <ProjectReference Include="..\Maestro.Login\Maestro.Login.csproj">
+ <Project>{07588440-5F9F-4C30-AA06-9CF30BA6DDE6}</Project>
+ <Name>Maestro.Login</Name>
+ </ProjectReference>
+ <ProjectReference Include="..\OSGeo.MapGuide.MaestroAPI\OSGeo.MapGuide.MaestroAPI.csproj">
+ <Project>{80FA3158-8B5F-48D1-A393-0378AFE48A7E}</Project>
+ <Name>OSGeo.MapGuide.MaestroAPI</Name>
+ </ItemGroup>
+ <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
+ <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
+ Other similar extension points exist, see Microsoft.Common.targets.
+ <Target Name="BeforeBuild">
+ </Target>
+ <Target Name="AfterBuild">
+ </Target>
+</Project>
More information about the mapguide-commits
