[mapguide-commits] r6436 - trunk/MgDev/Web/src/mapadmin/HelpDocs
svn_mapguide at osgeo.org
Tue Jan 17 20:12:25 EST 2012
Author: liuar
Date: 2012-01-17 17:12:24 -0800 (Tue, 17 Jan 2012)
New Revision: 6436
trunk/MgDev/Web/src/mapadmin/HelpDocs/configuring_servers.htm
Submit on behalf of Mars Wu
Fix Ticket: http://trac.osgeo.org/mapguide/ticket/1919 - The Site Admin Help for "Configuring Servers" are not correct
Modified: trunk/MgDev/Web/src/mapadmin/HelpDocs/configuring_servers.htm
--- trunk/MgDev/Web/src/mapadmin/HelpDocs/configuring_servers.htm 2012-01-18 01:07:02 UTC (rev 6435)
+++ trunk/MgDev/Web/src/mapadmin/HelpDocs/configuring_servers.htm 2012-01-18 01:12:24 UTC (rev 6436)
@@ -208,8 +208,7 @@
<div class="rule2">
<table width="100%" border="0">
<tr>
- <td width="17%"><b>General Properties</b></td>
- <td width="83%"> </td>
+ <td width="17%" colspan="2"><b>General Properties</b></td>
</tr>
<tr>
<td width="17%">Display name</td>
@@ -258,13 +257,15 @@
</table>
<tr>
- <td width="17%"><b> Administrative Connection Properties</b></td>
+ <td width="17%" colspan="2"><b> Administrative Connection Properties</b></td>
</tr>
<tr>
<td width="17%">Maximum connections</td>
<td width="83%">Max number of open administration connections (value
- <= 1024)</td>
+ <= 1024)<br />
+ The operations through this connection include Log related operations (get log, delete log, clear log etc.), package related operations (make package, load package, enumerate packages etc.) and Site related operations (get site version, get site status) etc. <br />
+ MgServerAdmin is the central class to performance administration operations <br /><br />
+ </td>
</tr>
<tr>
<td width="17%">Port</td>
@@ -287,58 +288,60 @@
<tr>
- <td width="17%"><b> Client Connection Properties</b></td>
+ <td width="17%" colspan="2"><b> Client Connection Properties</b></td>
</tr>
<tr>
- <td width="83%">Max number of open administration connections (value
- <= 1024)</td>
+ <td width="83%">Max number of open client connections (value
+ <= 1024)<br />
+ The operations that are performed via the service APIs (including FeatureService, Resource Server, Rendering Service etc.)are through this connection <br /><br />
+ </td>
</tr>
<tr>
- <td width="83%">Port to use for administration operations. If this
+ <td width="83%">Port to use for client operations. If this
port number is changed, the corresponding port number in the <i>webconfig.ini</i>
file should also be changed (the <i>ini</i> file is installed with
the Web Extensions).</td>
</tr>
<tr>
<td width="17%">Maximum queued operations</td>
- <td width="83%">Max number of administration operations to queue (value
+ <td width="83%">Max number of client operations to queue (value
<= 1024)</td>
</tr>
<tr>
<td width="17%">Maximum threads in pool</td>
- <td width="83%">Number of threads available for processing administration
+ <td width="83%">Number of threads available for processing client
operations (value <= 1024)</td>
</tr>
</table>
<tr>
- <td width="17%"><b> Site Connection Properties</b></td>
+ <td width="17%" colspan="2"><b> Site Connection Properties</b></td>
</tr>
<tr>
- <= 1024)</td>
+ <td width="83%">Max number of open site connections (value
+ <= 1024)<br />
+ The operations through this connect include create session, destroy session, enumerate users, authenticate etc. MgSite is the central class to performance these operations <br /><br />
+ </td>
</tr>
<tr>
+ <td width="83%">Port to use for site operations. If this
</tr>
<tr>
+ <td width="83%">Max number of site operations to queue (value
<= 1024)</td>
</tr>
<tr>
+ <td width="83%">Number of threads available for processing site
</tr>
</table>
Property changes on: trunk/MgDev/Web/src/mapadmin/HelpDocs/configuring_servers.htm
___________________________________________________________________
Added: svn:mergeinfo
+ /sandbox/adsk/2.4j/Web/src/mapadmin/HelpDocs/configuring_servers.htm:6327-6435
/sandbox/rfc94/Web/src/mapadmin/HelpDocs/configuring_servers.htm:5099-5163
/trunk/MgDev/Web/src/mapadmin/HelpDocs/configuring_servers.htm:6250-6326
More information about the mapguide-commits
