[mapguide-commits] r6451 - in
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI: . Exceptions
Properties Resource/Validation Services
svn_mapguide at osgeo.org
Tue Jan 24 02:59:49 EST 2012
Author: jng
Date: 2012-01-23 23:59:49 -0800 (Mon, 23 Jan 2012)
New Revision: 6451
Added:
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Exceptions/NullExtentException.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/BaseMapDefinitionValidator.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ValidationStatusCode.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IFeatureService.cs
#1929: Fix incorrect validation flag when saving a Map Definition that references an empty Feature Source.
Added: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Exceptions/NullExtentException.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Exceptions/NullExtentException.cs (rev 0)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Exceptions/NullExtentException.cs 2012-01-24 07:59:49 UTC (rev 6451)
@@ -0,0 +1,44 @@
+#region Disclaimer / License
+// Copyright (C) 2012, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+namespace OSGeo.MapGuide.MaestroAPI.Exceptions
+ [global::System.Serializable]
+ public class NullExtentException : Exception
+ // For guidelines regarding the creation of new exception types, see
+ // http://msdn.microsoft.com/library/default.asp?url=/library/en-us/cpgenref/html/cpconerrorraisinghandlingguidelines.asp
+ // and
+ // http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dncscol/html/csharp07192001.asp
+ public NullExtentException() { }
+ public NullExtentException(string message) : base(message) { }
+ public NullExtentException(string message, Exception inner) : base(message, inner) { }
+ protected NullExtentException(
+ System.Runtime.Serialization.SerializationInfo info,
+ System.Runtime.Serialization.StreamingContext context)
+ : base(info, context) { }
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2012-01-21 15:42:44 UTC (rev 6450)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2012-01-24 07:59:49 UTC (rev 6451)
@@ -200,6 +200,7 @@
<Compile Include="Exceptions\MaestroException.cs" />
<Compile Include="Exceptions\NestedExceptionMessageProcessor.cs" />
<Compile Include="Exceptions\NsDoc.cs" />
+ <Compile Include="Exceptions\NullExtentException.cs" />
<Compile Include="Exceptions\ResourceConversionException.cs" />
<Compile Include="Exceptions\SerializationException.cs" />
<Compile Include="Exceptions\UnsupportedResourceTypeException.cs" />
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2012-01-21 15:42:44 UTC (rev 6450)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2012-01-24 07:59:49 UTC (rev 6451)
@@ -39,6 +39,7 @@
using GeoAPI.Geometries;
using OSGeo.MapGuide.ObjectModels.LoadProcedure;
using OSGeo.MapGuide.ObjectModels.LayerDefinition;
+using OSGeo.MapGuide.MaestroAPI.Exceptions;
@@ -1578,6 +1579,7 @@
/// <param name="geometry">The geometry.</param>
/// <param name="filter">The filter.</param>
/// <param name="allowFallbackToContextInformation">if set to <c>true</c> [allow fallback to context information].</param>
+ /// <exception cref="T:OSGeo.MapGuide.MaestroAPI.Exceptions.NullExtentException">Thrown if the geometric extent is null</exception>
/// <returns></returns>
protected virtual OSGeo.MapGuide.ObjectModels.Common.IEnvelope GetSpatialExtent(string resourceID, string schema, string geometry, string filter, bool allowFallbackToContextInformation)
@@ -1593,10 +1595,13 @@
if (fsr.ReadNext())
+ if (fsr.IsNull("EXTENT"))
+ throw new NullExtentException();
IGeometry geom = fsr["EXTENT"] as IGeometry;
if (geom == null)
- throw new Exception("No data found in resource: " + resourceID);
else
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs 2012-01-21 15:42:44 UTC (rev 6450)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs 2012-01-24 07:59:49 UTC (rev 6451)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:2.0.50727.5448
+// Runtime Version:2.0.50727.4963
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
@@ -918,6 +918,15 @@
/// <summary>
+ /// Looks up a localized string similar to Map Definition references feature source {0} which has a null extent. Most likely caused by feature source having no actual data inside it.
+ /// </summary>
+ internal static string MDF_LayerWithNullExtent {
+ get {
+ return ResourceManager.GetString("MDF_LayerWithNullExtent", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Layer {0} has no geometry column.
/// </summary>
internal static string MDF_MissingLayerGeometryColumnError {
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx 2012-01-21 15:42:44 UTC (rev 6450)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx 2012-01-24 07:59:49 UTC (rev 6451)
@@ -560,4 +560,7 @@
<data name="ERR_PROPERTY_VALUE_NOT_OF_TYPE" xml:space="preserve">
<value>The specified property {0} is not of type: {1}</value>
</data>
+ <data name="MDF_LayerWithNullExtent" xml:space="preserve">
+ <value>Map Definition references feature source {0} which has a null extent. Most likely caused by feature source having no actual data inside it</value>
+ </data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/BaseMapDefinitionValidator.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/BaseMapDefinitionValidator.cs 2012-01-21 15:42:44 UTC (rev 6450)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/BaseMapDefinitionValidator.cs 2012-01-24 07:59:49 UTC (rev 6451)
@@ -198,8 +198,16 @@
catch (Exception ex)
- string msg = NestedExceptionMessageProcessor.GetFullMessage(ex);
- issues.Add(new ValidationIssue(resource, ValidationStatus.Error, ValidationStatusCode.Error_MapDefinition_ResourceRead, string.Format(Properties.Resources.MDF_ResourceReadError, fs.ResourceID, msg)));
+ var nex = ex as NullExtentException;
+ if (nex != null)
+ issues.Add(new ValidationIssue(resource, ValidationStatus.Warning, ValidationStatusCode.Warning_MapDefinition_FeatureSourceWithNullExtent, string.Format(Properties.Resources.MDF_LayerWithNullExtent, fs.ResourceID)));
+ else
+ string msg = NestedExceptionMessageProcessor.GetFullMessage(ex);
+ issues.Add(new ValidationIssue(resource, ValidationStatus.Error, ValidationStatusCode.Error_MapDefinition_ResourceRead, string.Format(Properties.Resources.MDF_ResourceReadError, fs.ResourceID, msg)));
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ValidationStatusCode.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ValidationStatusCode.cs 2012-01-21 15:42:44 UTC (rev 6450)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ValidationStatusCode.cs 2012-01-24 07:59:49 UTC (rev 6451)
@@ -161,6 +161,11 @@
Warning_MapDefinition_MissingCoordinateSystem,
/// <summary>
+ /// The Map Definition contains a referenced feature source that has a null extent (usually caused by having no data in the feature source)
+ /// </summary>
+ Warning_MapDefinition_FeatureSourceWithNullExtent,
+ /// <summary>
/// The specified initial view parameters lie outside the referenced Map Definition's extents. Usually means you will see nothing when the Fusion viewer loads.
/// </summary>
Warning_Fusion_InitialViewOutsideMapExtents = 3401,
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IFeatureService.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IFeatureService.cs 2012-01-21 15:42:44 UTC (rev 6450)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IFeatureService.cs 2012-01-24 07:59:49 UTC (rev 6451)
@@ -188,6 +188,7 @@
/// <param name="schema"></param>
/// <param name="geometry"></param>
/// <param name="allowFallbackToContextInformation"></param>
ObjCommon.IEnvelope GetSpatialExtent(string resourceID, string schema, string geometry, bool allowFallbackToContextInformation);
More information about the mapguide-commits
