[mapguide-commits] r6454 - trunk/Tools/Maestro/SignMapGuideApi
svn_mapguide at osgeo.org
Fri Jan 27 01:01:58 EST 2012
Author: jng
Date: 2012-01-26 22:01:58 -0800 (Thu, 26 Jan 2012)
New Revision: 6454
trunk/Tools/Maestro/SignMapGuideApi/Program.cs
Update SignMapGuideApi.exe to support signing MapGuide API assemblies that target .net Framework 4.0 (ie. Future releases). A new optional /framework parameter is used to specify the framework version of the assemblies to be signed. The following command will sign MapGuide API assemblies that target .net Framework 4.0
- SignMapGuideApi.exe /framework=4.0
If framework parameter is omitted, the default framework version used is 2.0
Modified: trunk/Tools/Maestro/SignMapGuideApi/Program.cs
--- trunk/Tools/Maestro/SignMapGuideApi/Program.cs 2012-01-24 16:38:24 UTC (rev 6453)
+++ trunk/Tools/Maestro/SignMapGuideApi/Program.cs 2012-01-27 06:01:58 UTC (rev 6454)
@@ -9,18 +9,49 @@
class Program
static string[] files = { "MapGuideDotNetApi", "OSGeo.MapGuide.Foundation", "OSGeo.MapGuide.Geometry", "OSGeo.MapGuide.MapGuideCommon", "OSGeo.MapGuide.PlatformBase", "OSGeo.MapGuide.Web" };
- static string[] ildasm32 = { "C:\\Program Files\\Microsoft SDKs\\Windows\\v6.0A\\Bin\\ildasm.exe",
+ static Dictionary<string, string[]> ilasm32Paths = new Dictionary<string, string[]>()
+ { "2.0", new string [] { "C:\\Windows\\Microsoft.NET\\Framework\\v2.0.50727\\ilasm.exe" } },
+ { "3.5", new string [] { "C:\\Windows\\Microsoft.NET\\Framework\\v2.0.50727\\ilasm.exe" } },
+ { "4.0", new string [] { "C:\\Windows\\Microsoft.NET\\Framework\\v4.0.30319\\ilasm.exe" } },
+ static Dictionary<string, string[]> ilasm64Paths = new Dictionary<string, string[]>()
+ { "2.0", new string [] { "C:\\Windows\\Microsoft.NET\\Framework64\\v2.0.50727\\ilasm.exe" } },
+ { "3.5", new string [] { "C:\\Windows\\Microsoft.NET\\Framework64\\v2.0.50727\\ilasm.exe" } },
+ { "4.0", new string [] { "C:\\Windows\\Microsoft.NET\\Framework64\\v4.0.30319\\ilasm.exe" } },
+ static Dictionary<string, string[]> ildasm32Paths = new Dictionary<string, string[]>()
+ { "2.0", new string [] { "C:\\Program Files\\Microsoft SDKs\\Windows\\v6.0A\\Bin\\ildasm.exe",
"C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v6.0A\\Bin\\ildasm.exe",
"C:\\Program Files\\Microsoft SDKs\\Windows\\v7.0A\\Bin\\ildasm.exe",
- "C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v7.0A\\Bin\\ildasm.exe" };
- static string[] ildasm64 = { "C:\\Program Files\\Microsoft SDKs\\Windows\\v6.0A\\Bin\\x64\\ildasm.exe",
+ "C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v7.0A\\Bin\\ildasm.exe" }},
+ { "3.5", new string [] { "C:\\Program Files\\Microsoft SDKs\\Windows\\v6.0A\\Bin\\ildasm.exe",
+ "C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v6.0A\\Bin\\ildasm.exe",
+ "C:\\Program Files\\Microsoft SDKs\\Windows\\v7.0A\\Bin\\ildasm.exe",
+ { "4.0", new string [] { "C:\\Program Files\\Microsoft SDKs\\Windows\\v7.0A\\bin\\NETFX 4.0 Tools\\ildasm.exe",
+ "C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v7.0A\\bin\\NETFX 4.0 Tools\\ildasm.exe" }}
+ static Dictionary<string, string[]> ildasm64Paths = new Dictionary<string, string[]>()
+ { "2.0", new string [] { "C:\\Program Files\\Microsoft SDKs\\Windows\\v6.0A\\Bin\\x64\\ildasm.exe",
"C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v6.0A\\Bin\\x64\\ildasm.exe",
"C:\\Program Files\\Microsoft SDKs\\Windows\\v7.0A\\Bin\\x64\\ildasm.exe",
- "C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v7.0A\\Bin\\x64\\ildasm.exe" };
+ "C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v7.0A\\Bin\\x64\\ildasm.exe" }},
+ { "3.5", new string [] { "C:\\Program Files\\Microsoft SDKs\\Windows\\v6.0A\\Bin\\x64\\ildasm.exe",
+ "C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v6.0A\\Bin\\x64\\ildasm.exe",
+ "C:\\Program Files\\Microsoft SDKs\\Windows\\v7.0A\\Bin\\x64\\ildasm.exe",
+ { "4.0", new string [] { "C:\\Program Files\\Microsoft SDKs\\Windows\\v7.0A\\bin\\NETFX 4.0 Tools\\x64\\ildasm.exe",
+ "C:\\Program Files (x86)\\Microsoft SDKs\\Windows\\v7.0A\\bin\\NETFX 4.0 Tools\\x64\\ildasm.exe" }}
- static string[] ilasm32 = { "C:\\Windows\\Microsoft.NET\\Framework\\v2.0.50727\\ilasm.exe", "C:\\Windows\\Microsoft.NET\\Framework\\v4.0.30319\\ilasm.exe" };
- static string[] ilasm64 = { "C:\\Windows\\Microsoft.NET\\Framework64\\v2.0.50727\\ilasm.exe", "C:\\Windows\\Microsoft.NET\\Framework64\\v4.0.30319\\ilasm.exe" };
//TODO: Allow for custom key and infer public key token from it
static string _keyFile = "maestroapi.key";
static string _publicKeyToken = "F5 26 C4 89 29 FD A8 56";
@@ -30,34 +61,46 @@
return IntPtr.Size == 8;
- static string getILDASMEXE()
+ static string getILDASMEXE(string frameworkVersion)
if (Is64BitProcess())
- foreach (string f in ildasm64)
+ if (!ildasm64Paths.ContainsKey(frameworkVersion))
+ throw new Exception("No registered ildasm.exe search paths for framework version: " + frameworkVersion);
+ foreach (string f in ildasm64Paths[frameworkVersion])
if (File.Exists(f))
return f;
else
- foreach (string f in ildasm32)
+ if (!ildasm32Paths.ContainsKey(frameworkVersion))
+ foreach (string f in ildasm32Paths[frameworkVersion])
if (File.Exists(f))
return f;
return null;
- static string getILASMEXE()
+ static string getILASMEXE(string frameworkVersion)
- foreach (string f in ilasm64)
+ if (!ilasm64Paths.ContainsKey(frameworkVersion))
+ throw new Exception("No registered ilasm.exe search paths for framework version: " + frameworkVersion);
+ foreach (string f in ilasm64Paths[frameworkVersion])
if (File.Exists(f))
return f;
else
- foreach (string f in ilasm32)
+ if (!ilasm32Paths.ContainsKey(frameworkVersion))
+ foreach (string f in ilasm32Paths[frameworkVersion])
if (File.Exists(f))
return f;
@@ -198,13 +241,23 @@
static void Main(string[] args)
+ string fxVersion = "2.0"; //default version
+ foreach (var arg in args)
+ if (arg.StartsWith("/framework="))
+ fxVersion = arg.Substring("/framework=".Length);
+ break;
+ Console.WriteLine("Target Framework: " + fxVersion);
try
if (File.Exists(_keyFile))
Console.Write("Detecting tools...");
- string ildasmexe = getILDASMEXE(); // Detect 32 or 64 bit versions of decompiler and compiler
- string ilasmexe = getILASMEXE();
+ string ildasmexe = getILDASMEXE(fxVersion); // Detect 32 or 64 bit versions of decompiler and compiler
+ string ilasmexe = getILASMEXE(fxVersion);
Console.WriteLine("Done");
Console.WriteLine("Compiler: " + ilasmexe);
Console.WriteLine("Decompiler: " + ildasmexe);
More information about the mapguide-commits
