[mapguide-commits] r6462 - in
trunk/Tools/Maestro/Maestro.AddIn.GeoRest: . Properties
Resources Services UI
svn_mapguide at osgeo.org
Sun Jan 29 09:11:33 EST 2012
Author: jng
Date: 2012-01-29 06:11:33 -0800 (Sun, 29 Jan 2012)
New Revision: 6462
Added:
trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Resources/application-list.png
trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Maestro.AddIn.GeoRest.csproj
trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Properties/Resources.resx
trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Services/GeoRestService.cs
trunk/Tools/Maestro/Maestro.AddIn.GeoRest/UI/FileSystemView.Designer.cs
trunk/Tools/Maestro/Maestro.AddIn.GeoRest/UI/FileSystemView.cs
trunk/Tools/Maestro/Maestro.AddIn.GeoRest/UI/FileSystemView.resx
#1913: Add support in the GeoREST addin for generating the required config XML for creating a GeoREST-enabled http server connection
Modified: trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Maestro.AddIn.GeoRest.csproj
--- trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Maestro.AddIn.GeoRest.csproj 2012-01-28 07:04:49 UTC (rev 6461)
+++ trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Maestro.AddIn.GeoRest.csproj 2012-01-29 14:11:33 UTC (rev 6462)
@@ -128,6 +128,7 @@
<Content Include="Manifest.addin">
<CopyToOutputDirectory>Always</CopyToOutputDirectory>
</Content>
+ <None Include="Resources\application-list.png" />
<None Include="Resources\arrow-circle-045-left.png" />
<None Include="Resources\document-task.png" />
<None Include="Resources\disk.png" />
Modified: trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Properties/Resources.Designer.cs 2012-01-28 07:04:49 UTC (rev 6461)
+++ trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Properties/Resources.Designer.cs 2012-01-29 14:11:33 UTC (rev 6462)
@@ -60,6 +60,13 @@
+ internal static System.Drawing.Bitmap application_list {
+ get {
+ object obj = ResourceManager.GetObject("application-list", resourceCulture);
+ return ((System.Drawing.Bitmap)(obj));
internal static System.Drawing.Bitmap arrow_circle_045_left {
get {
object obj = ResourceManager.GetObject("arrow-circle-045-left", resourceCulture);
@@ -162,6 +169,15 @@
+ /// <summary>
+ /// Looks up a localized string similar to Maestro Config Saved to {0}.
+ /// </summary>
+ internal static string MaestroConfigSaved {
+ get {
+ return ResourceManager.GetString("MaestroConfigSaved", resourceCulture);
internal static System.Drawing.Bitmap magnifier {
get {
object obj = ResourceManager.GetObject("magnifier", resourceCulture);
@@ -231,6 +247,15 @@
/// <summary>
+ /// Looks up a localized string similar to XML Files (*.xml)|*.xml.
+ /// </summary>
+ internal static string XmlFilter {
+ get {
+ return ResourceManager.GetString("XmlFilter", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to XML Document is well-formed.
/// </summary>
internal static string XmlWellFormed {
Modified: trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Properties/Resources.resx 2012-01-28 07:04:49 UTC (rev 6461)
+++ trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Properties/Resources.resx 2012-01-29 14:11:33 UTC (rev 6462)
@@ -117,68 +117,77 @@
<resheader name="writer">
<value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
+ <data name="TitleSelectPreview" xml:space="preserve">
+ <value>Select Representation Preview</value>
+ </data>
+ <data name="ErrConfigRootDoesNotExist" xml:space="preserve">
+ <value>The specified configuration root directory does not exist</value>
+ </data>
+ <data name="XmlWellFormed" xml:space="preserve">
+ <value>XML Document is well-formed</value>
+ </data>
+ <data name="PreviewTypeHtmlMany" xml:space="preserve">
+ <value>HTML (Many template) - {0}</value>
+ </data>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="magnifier" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\magnifier.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="PreviewTypeKmzMany" xml:space="preserve">
+ <value>KMZ (Many template) - {0}</value>
+ </data>
+ <data name="PreviewTypeODataRaw" xml:space="preserve">
+ <value>OData (Raw) - {0}</value>
+ </data>
<data name="ErrCanOnlyEditRestCfg" xml:space="preserve">
<value>Only files named restcfg.xml can be edited</value>
</data>
- <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
- <data name="document-task" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\document-task.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="PromptSelectPreview" xml:space="preserve">
+ <value>Choose a Representation to Preview</value>
</data>
+ <data name="ErrNoPreviewableRepresentations" xml:space="preserve">
+ <value>Could not find any previewable representations in this file</value>
+ </data>
<data name="disk" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\disk.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="magnifier" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\magnifier.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="ErrRestCfgMissingResourceNode" xml:space="preserve">
+ <value>The specified restcfg.xml is missing the top-level <Resource> node. This is probably an invalid document</value>
</data>
<data name="ErrGeoRestUrlNotSpecified" xml:space="preserve">
<value>GeoRest URL not specified</value>
</data>
- <data name="FileSaved" xml:space="preserve">
- <value>File saved to: {0}</value>
+ <data name="PreviewTypeKmlMany" xml:space="preserve">
+ <value>KML (Many template) - {0}</value>
</data>
- <data name="ErrConfigRootDoesNotExist" xml:space="preserve">
- <value>The specified configuration root directory does not exist</value>
- </data>
- <data name="GeoRestExplorer" xml:space="preserve">
- <value>GeoREST Explorer</value>
- </data>
<data name="plug" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\plug.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="XmlWellFormed" xml:space="preserve">
- <value>XML Document is well-formed</value>
+ <data name="document-task" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\document-task.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="arrow-circle-045-left" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\arrow-circle-045-left.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="GeoRestExplorer" xml:space="preserve">
+ <value>GeoREST Explorer</value>
</data>
- <data name="ErrNoPreviewableRepresentations" xml:space="preserve">
- <value>Could not find any previewable representations in this file</value>
- </data>
<data name="ErrPreviewNotRestCfg" xml:space="preserve">
<value>File is not restcfg.xml. Cannot extract previewable representations</value>
</data>
- <data name="ErrRestCfgMissingResourceNode" xml:space="preserve">
- <value>The specified restcfg.xml is missing the top-level <Resource> node. This is probably an invalid document</value>
- </data>
<data name="ErrRestCfgMissingUriPart" xml:space="preserve">
<value>The specified restcfg.xml is missing a uripart attribute in its <Resource> element. Previewable representations cannot be determined without this attribute</value>
</data>
- <data name="PreviewTypeHtmlMany" xml:space="preserve">
- <value>HTML (Many template) - {0}</value>
+ <data name="FileSaved" xml:space="preserve">
+ <value>File saved to: {0}</value>
</data>
- <data name="PreviewTypeKmlMany" xml:space="preserve">
- <value>KML (Many template) - {0}</value>
+ <data name="arrow-circle-045-left" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\arrow-circle-045-left.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="PreviewTypeKmzMany" xml:space="preserve">
- <value>KMZ (Many template) - {0}</value>
+ <data name="application-list" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\application-list.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="PreviewTypeODataRaw" xml:space="preserve">
- <value>OData (Raw) - {0}</value>
+ <data name="MaestroConfigSaved" xml:space="preserve">
+ <value>Maestro Config Saved to {0}</value>
</data>
- <data name="PromptSelectPreview" xml:space="preserve">
- <value>Choose a Representation to Preview</value>
+ <data name="XmlFilter" xml:space="preserve">
+ <value>XML Files (*.xml)|*.xml</value>
</data>
- <data name="TitleSelectPreview" xml:space="preserve">
- <value>Select Representation Preview</value>
- </data>
</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Resources/application-list.png
(Binary files differ)
Property changes on: trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Resources/application-list.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Services/GeoRestService.cs
--- trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Services/GeoRestService.cs 2012-01-28 07:04:49 UTC (rev 6461)
+++ trunk/Tools/Maestro/Maestro.AddIn.GeoRest/Services/GeoRestService.cs 2012-01-29 14:11:33 UTC (rev 6462)
@@ -50,6 +50,89 @@
+ public XmlDocument GetMaestroConfig()
+ var doc = new XmlDocument();
+ var config = doc.CreateElement("GeoRestConfiguration");
+ doc.AppendChild(config);
+ var files = Directory.GetFiles(_configRootPath, "restcfg.xml", SearchOption.AllDirectories);
+ foreach (var f in files)
+ AddConfigs(f, doc, config);
+ return doc;
+ private static void AddConfigs(string file, XmlDocument config, XmlNode root)
+ doc.Load(file);
+ XmlNodeList sources = doc.GetElementsByTagName("Source");
+ foreach (XmlNode sourceNode in sources)
+ var attr = sourceNode.Attributes["type"];
+ if (attr != null && attr.Value == "MapGuide")
+ var configNode = config.CreateElement("GeoRestFeatureSource");
+ var fsNode = config.CreateElement("FeatureSource");
+ var fsClassNode = config.CreateElement("FeatureClass");
+ fsNode.InnerText = sourceNode["FeatureSource"].InnerText;
+ fsClassNode.InnerText = sourceNode["FeatureClass"].InnerText;
+ configNode.AppendChild(fsNode);
+ configNode.AppendChild(fsClassNode);
+ var uriPartNode = config.CreateElement("UriPart");
+ uriPartNode.InnerText = sourceNode.ParentNode.Attributes["uripart"].Value;
+ configNode.AppendChild(uriPartNode);
+ var allowInsertNode = config.CreateElement("AllowInsert");
+ var allowUpdateNode = config.CreateElement("AllowUpdate");
+ var allowDeleteNode = config.CreateElement("AllowDelete");
+ allowInsertNode.InnerText = "false";
+ allowUpdateNode.InnerText = "false";
+ allowDeleteNode.InnerText = "false";
+ configNode.AppendChild(allowInsertNode);
+ configNode.AppendChild(allowUpdateNode);
+ configNode.AppendChild(allowDeleteNode);
+ var parent = sourceNode.ParentNode;
+ var match = parent.SelectSingleNode("Representation[@renderer='XML']");
+ if (match != null)
+ foreach (XmlNode repNode in match.ChildNodes)
+ var method = repNode.Attributes["name"];
+ if (method != null)
+ switch (method.Value)
+ case "POST":
+ allowInsertNode.InnerText = "true";
+ break;
+ case "PUT":
+ allowUpdateNode.InnerText = "true";
+ break;
+ case "DELETE":
+ allowDeleteNode.InnerText = "true";
+ break;
+ root.AppendChild(configNode);
public FileSystemEntry[] GetEntries(string path)
var entries = new List<FileSystemEntry>();
Modified: trunk/Tools/Maestro/Maestro.AddIn.GeoRest/UI/FileSystemView.Designer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.GeoRest/UI/FileSystemView.Designer.cs 2012-01-28 07:04:49 UTC (rev 6461)
+++ trunk/Tools/Maestro/Maestro.AddIn.GeoRest/UI/FileSystemView.Designer.cs 2012-01-29 14:11:33 UTC (rev 6462)
@@ -32,9 +32,9 @@
System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(FileSystemView));
this.toolStrip1 = new System.Windows.Forms.ToolStrip();
this.btnConnect = new System.Windows.Forms.ToolStripButton();
- this.btnRefresh = new System.Windows.Forms.ToolStripButton();
this.toolStripSeparator1 = new System.Windows.Forms.ToolStripSeparator();
this.btnPreview = new System.Windows.Forms.ToolStripButton();
+ this.btnRefresh = new System.Windows.Forms.ToolStripButton();
this.fileTree = new System.Windows.Forms.TreeView();
this.imgList = new System.Windows.Forms.ImageList(this.components);
this.ctxFolder = new System.Windows.Forms.ContextMenuStrip(this.components);
@@ -42,6 +42,8 @@
this.ctxConfig = new System.Windows.Forms.ContextMenuStrip(this.components);
this.addRepresentationToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
this.editXMLToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.btnOptions = new System.Windows.Forms.ToolStripDropDownButton();
+ this.saveMaestroConfigToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
this.toolStrip1.SuspendLayout();
this.ctxFolder.SuspendLayout();
this.ctxConfig.SuspendLayout();
@@ -52,6 +54,7 @@
this.toolStrip1.GripStyle = System.Windows.Forms.ToolStripGripStyle.Hidden;
this.toolStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
this.btnConnect,
+ this.btnOptions,
this.toolStripSeparator1,
this.btnPreview,
this.btnRefresh});
@@ -61,19 +64,12 @@
// btnConnect
+ this.btnConnect.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
this.btnConnect.Image = global::Maestro.AddIn.GeoRest.Properties.Resources.plug;
resources.ApplyResources(this.btnConnect, "btnConnect");
this.btnConnect.Name = "btnConnect";
this.btnConnect.Click += new System.EventHandler(this.btnConnect_Click);
- // btnRefresh
- this.btnRefresh.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
- resources.ApplyResources(this.btnRefresh, "btnRefresh");
- this.btnRefresh.Image = global::Maestro.AddIn.GeoRest.Properties.Resources.arrow_circle_045_left;
- this.btnRefresh.Name = "btnRefresh";
- this.btnRefresh.Click += new System.EventHandler(this.btnRefresh_Click);
// toolStripSeparator1
this.toolStripSeparator1.Name = "toolStripSeparator1";
@@ -87,6 +83,14 @@
this.btnPreview.Name = "btnPreview";
this.btnPreview.Click += new System.EventHandler(this.btnPreview_Click);
+ // btnRefresh
+ this.btnRefresh.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ resources.ApplyResources(this.btnRefresh, "btnRefresh");
+ this.btnRefresh.Image = global::Maestro.AddIn.GeoRest.Properties.Resources.arrow_circle_045_left;
+ this.btnRefresh.Name = "btnRefresh";
+ this.btnRefresh.Click += new System.EventHandler(this.btnRefresh_Click);
// fileTree
resources.ApplyResources(this.fileTree, "fileTree");
@@ -140,6 +144,22 @@
this.editXMLToolStripMenuItem.Name = "editXMLToolStripMenuItem";
resources.ApplyResources(this.editXMLToolStripMenuItem, "editXMLToolStripMenuItem");
+ // btnOptions
+ this.btnOptions.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnOptions.DropDownItems.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.saveMaestroConfigToolStripMenuItem});
+ resources.ApplyResources(this.btnOptions, "btnOptions");
+ this.btnOptions.Image = global::Maestro.AddIn.GeoRest.Properties.Resources.application_list;
+ this.btnOptions.Name = "btnOptions";
+ // saveMaestroConfigToolStripMenuItem
+ this.saveMaestroConfigToolStripMenuItem.Image = global::Maestro.AddIn.GeoRest.Properties.Resources.disk;
+ this.saveMaestroConfigToolStripMenuItem.Name = "saveMaestroConfigToolStripMenuItem";
+ resources.ApplyResources(this.saveMaestroConfigToolStripMenuItem, "saveMaestroConfigToolStripMenuItem");
+ this.saveMaestroConfigToolStripMenuItem.Click += new System.EventHandler(this.saveMaestroConfigToolStripMenuItem_Click);
// FileSystemView
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
@@ -170,5 +190,7 @@
private System.Windows.Forms.ToolStripMenuItem editXMLToolStripMenuItem;
private System.Windows.Forms.ToolStripButton btnRefresh;
private System.Windows.Forms.ToolStripButton btnPreview;
+ private System.Windows.Forms.ToolStripDropDownButton btnOptions;
+ private System.Windows.Forms.ToolStripMenuItem saveMaestroConfigToolStripMenuItem;
Modified: trunk/Tools/Maestro/Maestro.AddIn.GeoRest/UI/FileSystemView.cs
--- trunk/Tools/Maestro/Maestro.AddIn.GeoRest/UI/FileSystemView.cs 2012-01-28 07:04:49 UTC (rev 6461)
+++ trunk/Tools/Maestro/Maestro.AddIn.GeoRest/UI/FileSystemView.cs 2012-01-29 14:11:33 UTC (rev 6462)
@@ -90,6 +90,7 @@
fileTree.Nodes.Clear();
_service.Connect(diag.ConfigurationRoot, diag.GeoRestUrl);
+ btnOptions.Enabled = true;
var node = new TreeNode();
node.Text = "Root";
node.Tag = new FileSystemEntry() { Name = _service.ConfigurationRoot, IsFolder = true };
@@ -212,6 +213,20 @@
var entries = _service.GetEntries(GetFilePath(node));
PopulateEntries(node.Nodes, entries);
+ private void saveMaestroConfigToolStripMenuItem_Click(object sender, EventArgs e)
+ using (var save = DialogFactory.SaveFile())
+ save.Filter = Properties.Resources.XmlFilter;
+ if (save.ShowDialog() == DialogResult.OK)
+ var doc = _service.GetMaestroConfig();
+ doc.Save(save.FileName);
+ MessageBox.Show(string.Format(Properties.Resources.MaestroConfigSaved, save.FileName));
public delegate void ObjectSelectionEventHandler<T>(object sender, T obj);
Modified: trunk/Tools/Maestro/Maestro.AddIn.GeoRest/UI/FileSystemView.resx
--- trunk/Tools/Maestro/Maestro.AddIn.GeoRest/UI/FileSystemView.resx 2012-01-28 07:04:49 UTC (rev 6461)
+++ trunk/Tools/Maestro/Maestro.AddIn.GeoRest/UI/FileSystemView.resx 2012-01-29 14:11:33 UTC (rev 6462)
@@ -118,22 +118,40 @@
</resheader>
<metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>17, 17</value>
+ <value>0, 0</value>
</metadata>
<assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="btnConnect.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
<value>Magenta</value>
</data>
<data name="btnConnect.Size" type="System.Drawing.Size, System.Drawing">
- <value>72, 22</value>
+ <value>23, 22</value>
</data>
<data name="btnConnect.Text" xml:space="preserve">
<value>Connect</value>
</data>
+ <data name="saveMaestroConfigToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
+ <value>183, 22</value>
+ </data>
+ <data name="saveMaestroConfigToolStripMenuItem.Text" xml:space="preserve">
+ <value>Save Maestro Config</value>
+ </data>
+ <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="btnOptions.Enabled" type="System.Boolean, mscorlib">
+ <value>False</value>
+ </data>
+ <data name="btnOptions.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ <value>Magenta</value>
+ </data>
+ <data name="btnOptions.Size" type="System.Drawing.Size, System.Drawing">
+ <value>29, 22</value>
+ </data>
+ <data name="btnOptions.Text" xml:space="preserve">
+ <value>toolStripButton1</value>
+ </data>
<data name="toolStripSeparator1.Size" type="System.Drawing.Size, System.Drawing">
<value>6, 25</value>
</data>
- <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="btnPreview.Enabled" type="System.Boolean, mscorlib">
</data>
@@ -197,7 +215,7 @@
AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAA6
- EQAAAk1TRnQBSQFMAgEBCQEAAVABAAFQAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
+ EQAAAk1TRnQBSQFMAgEBCQEAAWABAAFgAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
AwABQAMAATADAAEBAQABCAYAAQwYAAGAAgABgAMAAoABAAGAAwABgAEAAYABAAKAAgADwAEAAcAB3AHA
AQAB8AHKAaYBAAEzBQABMwEAATMBAAEzAQACMwIAAxYBAAMcAQADIgEAAykBAANVAQADTQEAA0IBAAM5
AQABgAF8Af8BAAJQAf8BAAGTAQAB1gEAAf8B7AHMAQABxgHWAe8BAAHWAucBAAGQAakBrQIAAf8BMwMA
@@ -351,12 +369,6 @@
<data name=">>btnConnect.Type" xml:space="preserve">
<value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
- <data name=">>btnRefresh.Name" xml:space="preserve">
- <value>btnRefresh</value>
- </data>
- <data name=">>btnRefresh.Type" xml:space="preserve">
- <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
<data name=">>toolStripSeparator1.Name" xml:space="preserve">
<value>toolStripSeparator1</value>
</data>
@@ -369,6 +381,12 @@
<data name=">>btnPreview.Type" xml:space="preserve">
</data>
+ <data name=">>btnRefresh.Name" xml:space="preserve">
+ <value>btnRefresh</value>
+ </data>
+ <data name=">>btnRefresh.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
<data name=">>imgList.Name" xml:space="preserve">
<value>imgList</value>
</data>
@@ -393,6 +411,18 @@
<data name=">>editXMLToolStripMenuItem.Type" xml:space="preserve">
<value>System.Windows.Forms.ToolStripMenuItem, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
+ <data name=">>btnOptions.Name" xml:space="preserve">
+ <value>btnOptions</value>
+ </data>
+ <data name=">>btnOptions.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStripDropDownButton, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>saveMaestroConfigToolStripMenuItem.Name" xml:space="preserve">
+ <value>saveMaestroConfigToolStripMenuItem</value>
+ </data>
+ <data name=">>saveMaestroConfigToolStripMenuItem.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStripMenuItem, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
<data name=">>$this.Name" xml:space="preserve">
<value>FileSystemView</value>
</data>
More information about the mapguide-commits
