[mapguide-commits] r6849 - branches/2.4/MgDev/Common/Foundation/System
svn_mapguide at osgeo.org
Wed Jul 4 09:14:23 PDT 2012
Author: jng
Date: 2012-07-04 09:14:23 -0700 (Wed, 04 Jul 2012)
New Revision: 6849
branches/2.4/MgDev/Common/Foundation/System/Util.cpp
#1454: Update MgUtil::GetLinuxMemoryStatus() to properly parse /proc/meminfo which contains the current Linux memory information.
Modified: branches/2.4/MgDev/Common/Foundation/System/Util.cpp
--- branches/2.4/MgDev/Common/Foundation/System/Util.cpp 2012-07-04 13:01:46 UTC (rev 6848)
+++ branches/2.4/MgDev/Common/Foundation/System/Util.cpp 2012-07-04 16:14:23 UTC (rev 6849)
@@ -858,43 +858,125 @@
throw new MgFileNotFoundException(L"MgUtil.GetLinuxMemoryStatus", __LINE__, __WFILE__, &arguments, L"", NULL);
- // Move file pointer to next line
- fgets(line, 80, meminfo);
- // Read physical memory info
+ /proc/meminfo looks like this:
+ MemTotal: <size> kB <-- Read this
+ MemFree: <size> kB <-- Read this
+ Buffers: <size> kB <-- Read this
+ Cached: <size> kB <-- Read this
+ SwapCached: <size> kB
+ Active: <size> kB
+ Inactive: <size> kB
+ Active(anon): <size> kB
+ Inactive(anon): <size> kB
+ Active(file): <size> kB
+ Inactive(file): <size> kB
+ Unevictable: <size> kB
+ Mlocked: <size> kB
+ HighTotal: <size> kB
+ HighFree: <size> kB
+ LowTotal: <size> kB
+ LowFree: <size> kB
+ SwapTotal: <size> kB <-- Read this
+ SwapFree: <size> kB <-- Read this
+ Infer the used amount by (total - free)
double total;
double used;
double free;
double shared;
double buffers;
double cached;
- sscanf(line, "%*4s %lf %lf %lf %lf %lf %lf",
- &total, &used, &free, &shared, &buffers, &cached);
- pMemoryStatus->m_memTotal = (INT64)total;
- pMemoryStatus->m_memUsed = (INT64)used;
- pMemoryStatus->m_memFree = (INT64)free;
- pMemoryStatus->m_memShared = (INT64)shared;
- pMemoryStatus->m_memBuffers = (INT64)buffers;
- pMemoryStatus->m_memCached = (INT64)cached;
- // Read swap memory info
double swapTotal;
double swapUsed;
double swapFree;
- sscanf(line, "%*5s %lf %lf %lf",
- &swapTotal, &swapUsed, &swapFree);
+ int lineNum = 0;
+ bool bComplete = false;
+ //printf("Parse /proc/meminfo\n");
+ //Read until all lines are accounted for or EOF
+ //All values read are in KB so they have to be multiplied
+ //by 1024 for the number to be in bytes (same as Windows)
+ while (fgets(line, 80, meminfo) != NULL)
+ lineNum++;
+ if (lineNum == 1) //MemTotal line
+ //printf("%s\n", line);
+ sscanf(line, "%*9s %lf", &total);
+ total *= 1024;
+ //printf("Parsed: %lf\n", total);
+ else if (lineNum == 2) //MemFree line
+ sscanf(line, "%*8s %lf", &free);
+ free *= 1024;
+ //printf("Parsed: %lf\n", free);
+ else if (lineNum == 3) //Buffers line
+ sscanf(line, "%*8s %lf", &buffers);
+ buffers *= 1024;
+ //printf("Parsed: %lf\n", buffers);
+ else if (lineNum == 4) //Cached line
+ sscanf(line, "%*7s %lf", &cached);
+ cached *= 1024;
+ //printf("Parsed: %lf\n", cached);
+ else if (lineNum == 18) //SwapTotal line
+ sscanf(line, "%*10s %lf", &swapTotal);
+ swapTotal *= 1024;
+ else if (lineNum == 19) //SwapFree line
+ sscanf(line, "%*9s %lf", &swapFree);
+ swapFree *= 1024;
- pMemoryStatus->m_swapTotal = (INT64)swapTotal;
- pMemoryStatus->m_swapUsed = (INT64)swapUsed;
- pMemoryStatus->m_swapFree = (INT64)swapFree;
+ if (lineNum > 19) //Past SwapFree line
+ bComplete = true; //All lines accounted for
+ break;
+ if (bComplete)
+ pMemoryStatus->m_memTotal = (INT64)total;
+ pMemoryStatus->m_memFree = (INT64)free;
+ pMemoryStatus->m_memUsed = (INT64)(pMemoryStatus->m_memTotal - pMemoryStatus->m_memFree);
+ //TODO: What value in /proc/meminfo represents this? This value isn't used at the moment so we can sort of get away with it for now
+ pMemoryStatus->m_memShared = 0L;
+ pMemoryStatus->m_memBuffers = (INT64)buffers;
+ pMemoryStatus->m_memCached = (INT64)cached;
+ pMemoryStatus->m_swapTotal = (INT64)swapTotal;
+ pMemoryStatus->m_swapFree = (INT64)swapFree;
+ pMemoryStatus->m_swapUsed = (INT64)(pMemoryStatus->m_swapTotal - pMemoryStatus->m_swapFree);
+ //printf("Parse complete\n");
+ bSuccess = true;
+ else
+ //printf("Parse failed\n");
+ bSuccess = false;
fclose(meminfo);
- bSuccess = true;
#endif // _WIN32
return bSuccess;
More information about the mapguide-commits
