[mapguide-commits] r6868 - in trunk/MgDev/Web/src: localized mapviewerjava mapviewernet mapviewerphp viewerfiles
svn_mapguide at osgeo.org
Fri Jul 6 08:25:21 PDT 2012
Author: jng
Date: 2012-07-06 08:25:20 -0700 (Fri, 06 Jul 2012)
New Revision: 6868
trunk/MgDev/Web/src/localized/en
trunk/MgDev/Web/src/mapviewerjava/measure.jsp
trunk/MgDev/Web/src/mapviewerjava/measureui.jsp
trunk/MgDev/Web/src/mapviewernet/measure.aspx
trunk/MgDev/Web/src/mapviewernet/measureui.aspx
trunk/MgDev/Web/src/mapviewerphp/measure.php
trunk/MgDev/Web/src/mapviewerphp/measureui.php
trunk/MgDev/Web/src/viewerfiles/measureui.templ
#1834: Merge in 2.4 branch submissions
Modified: trunk/MgDev/Web/src/localized/en
--- trunk/MgDev/Web/src/localized/en 2012-07-06 15:12:29 UTC (rev 6867)
+++ trunk/MgDev/Web/src/localized/en 2012-07-06 15:25:20 UTC (rev 6868)
@@ -18,6 +18,7 @@
DISTANCEMILES = Miles
DISTANCEKILOMETERS = Kilometers
DISTANCEFEET = Feet
+DISTANCEUSFEET = US Survey Feet
DISTANCEMETERS = Meters
# Fill Patterns/Values
@@ -113,6 +114,7 @@
COLORPICKERHEXFORMAT = Hex format
# MeasureUI
+MEASUREUNITS = Measure units:
MEASURETITLE = Measure Distance
MEASUREINFO = Click a start and end point.
RESUME = Resume
Modified: trunk/MgDev/Web/src/mapviewerjava/measure.jsp
--- trunk/MgDev/Web/src/mapviewerjava/measure.jsp 2012-07-06 15:12:29 UTC (rev 6867)
+++ trunk/MgDev/Web/src/mapviewerjava/measure.jsp 2012-07-06 15:25:20 UTC (rev 6868)
@@ -37,7 +37,7 @@
double y2;
double total;
String srs;
-int us;
+String units;
int segId;
String error;
double distance;
@@ -59,7 +59,7 @@
y2 = 0;
total = 0;
srs = "";
- us = 0;
+ units = "";
segId = 1;
error = "";
distance = 0;
@@ -124,10 +124,10 @@
distance = srsMap.ConvertCoordinateSystemUnitsToMeters(distance);
- if(0 == us)
- distance *= 0.001; //get kilometers
- else
- distance *= 0.000621371192; //get miles
+ if (units.equals("mi")) distance *= 0.000621371192; //get miles
+ if (units.equals("km")) distance *= 0.001; //get kilometers
+ if (units.equals("ft")) distance *= 3.2808399; //get feet
+ if (units.equals("usft")) distance *= 3.2808333; //get US survey feet
total += distance;
@@ -186,7 +186,14 @@
featureSrvc.CreateFeatureSource(dataSourceId, parameters);
//build map tip
- String unitText = (us==1)? "Miles": "Kilometers";
+ String unitText = "";
+ if (units.equals("mi")) unitText = "DISTANCEMILES";
+ if (units.equals("km")) unitText = "DISTANCEKILOMETERS";
+ if (units.equals("ft")) unitText = "DISTANCEFEET";
+ if (units.equals("usft")) unitText = "DISTANCEUSFEET";
+ if (units.equals("m")) unitText = "DISTANCEMETERS";
+ unitText = MgLocalizer.GetString(unitText, locale);
String tip = "Concat(Concat(Concat('" + MgLocalizer.GetString("MEASUREPARTIAL", locale) + ": ', PARTIAL), Concat(', " + MgLocalizer.GetString("MEASURETOTAL", locale) + ": ', TOTAL)), ' (" + unitText + ")')";
//Create the layer definition
@@ -262,6 +269,7 @@
String.valueOf(total),
String.valueOf(distance),
"1",
+ units,
vpath + "measure.jsp",
@@ -276,6 +284,7 @@
mapName = ValidateMapName(GetParameter(request, "MAPNAME"));
target = GetIntParameter(request, "TGT");
popup = GetIntParameter(request, "POPUP");
+ units = GetParameter(request, "UNITS");
if(IsParameter(request, "CLEAR"))
clear = true;
@@ -288,7 +297,6 @@
x2 = GetDoubleParameter(request, "X2");
y2 = GetDoubleParameter(request, "Y2");
total = GetDoubleParameter(request, "TOTAL");
- us = GetIntParameter(request, "US");
segId = GetIntParameter(request, "SEGID");
Modified: trunk/MgDev/Web/src/mapviewerjava/measureui.jsp
--- trunk/MgDev/Web/src/mapviewerjava/measureui.jsp 2012-07-06 15:12:29 UTC (rev 6867)
+++ trunk/MgDev/Web/src/mapviewerjava/measureui.jsp 2012-07-06 15:25:20 UTC (rev 6868)
@@ -31,6 +31,7 @@
int cmdIndex = -1;
String mapName = "";
String sessionId = "";
+String units = "";
double total = 0;
@@ -54,6 +55,7 @@
"0",
"0",
+ units,
@@ -70,5 +72,6 @@
cmdIndex = GetIntParameter(request, "CMDINDEX");
Modified: trunk/MgDev/Web/src/mapviewernet/measure.aspx
--- trunk/MgDev/Web/src/mapviewernet/measure.aspx 2012-07-06 15:12:29 UTC (rev 6867)
+++ trunk/MgDev/Web/src/mapviewernet/measure.aspx 2012-07-06 15:25:20 UTC (rev 6868)
@@ -35,7 +35,7 @@
double y2 = 0;
double total = 0;
String srs = "";
-int us = 0;
+String units = "";
int segId = 1;
String error = "";
double distance = 0;
@@ -102,10 +102,10 @@
- if (0 == us)
- else
+ if (units == "mi") distance *= 0.000621371192; //get miles
+ if (units == "km") distance *= 0.001; //get kilometers
+ if (units == "ft") distance *= 3.2808399; //get feet
+ if (units == "usft") distance *= 3.2808333; //get US survey feet
total += distance;
@@ -164,7 +164,14 @@
//build map tip
- String unitText = (us == 1) ? "Miles" : "Kilometers";
+ if (units == "mi") unitText = "DISTANCEMILES";
+ if (units == "km") unitText = "DISTANCEKILOMETERS";
+ if (units == "ft") unitText = "DISTANCEFEET";
+ if (units == "usft") unitText = "DISTANCEUSFEET";
+ if (units == "m") unitText = "DISTANCEMETERS";
String tip = String.Format("Concat(Concat(Concat('" + MgLocalizer.GetString("MEASUREPARTIAL", locale) + ": ', PARTIAL), Concat(', " + MgLocalizer.GetString("MEASURETOTAL", locale) + ": ', TOTAL)), ' ({0})')", unitText);
@@ -239,6 +246,7 @@
total.ToString(NumberFormatInfo.InvariantInfo),
distance.ToString(NumberFormatInfo.InvariantInfo),
"1",
+ units,
vpath + "measure.aspx",
@@ -266,6 +274,7 @@
mapName = ValidateMapName(GetParameter(parameters, "MAPNAME"));
target = GetIntParameter(parameters, "TGT");
popup = GetIntParameter(parameters, "POPUP");
+ units = GetParameter(parameters, "UNITS");
if(IsParameter(parameters, "CLEAR"))
clear = true;
else
@@ -275,7 +284,6 @@
x2 = GetDoubleParameter(parameters, "X2");
y2 = GetDoubleParameter(parameters, "Y2");
total = GetDoubleParameter(parameters, "TOTAL");
- us = GetIntParameter(parameters, "US");
segId = GetIntParameter(parameters, "SEGID");
Modified: trunk/MgDev/Web/src/mapviewernet/measureui.aspx
--- trunk/MgDev/Web/src/mapviewernet/measureui.aspx 2012-07-06 15:12:29 UTC (rev 6867)
+++ trunk/MgDev/Web/src/mapviewernet/measureui.aspx 2012-07-06 15:25:20 UTC (rev 6868)
@@ -30,6 +30,7 @@
int cmdIndex = -1;
+String units = "";
double total = 0;
</script>
@@ -53,6 +54,7 @@
"0",
"0",
+ units,
@@ -77,6 +79,7 @@
cmdIndex = GetIntParameter(parameters, "CMDINDEX");
</script>
Modified: trunk/MgDev/Web/src/mapviewerphp/measure.php
--- trunk/MgDev/Web/src/mapviewerphp/measure.php 2012-07-06 15:12:29 UTC (rev 6867)
+++ trunk/MgDev/Web/src/mapviewerphp/measure.php 2012-07-06 15:25:20 UTC (rev 6868)
@@ -32,7 +32,7 @@
$y2 = 0;
$total = 0;
$srs = "";
- $us = 1;
+ $units = "";
$segId = 1;
$error = "";
$distance = 0;
@@ -92,11 +92,12 @@
$distance = $srsMap->MeasureEuclideanDistance($x1, $y1, $x2, $y2);
$distance = $srsMap->ConvertCoordinateSystemUnitsToMeters($distance);
- if(!$us)
- $distance *= 0.001; //get kilometers
- else
- $distance *= 0.000621371192; //get miles
+ if ($units == "mi") $distance *= 0.000621371192; //get miles
+ if ($units == "km") $distance *= 0.001; //get kilometers
+ if ($units == "ft") $distance *= 3.2808399; //get feet
+ if ($units == "usft") $distance *= 3.2808333; //get US survey feet
$total += $distance;
//create the line string geometry representing this segment
@@ -154,7 +155,14 @@
$featureSrvc->CreateFeatureSource($dataSourceId, $params);
//build map tip
- $unitText = $us? GetLocalizedString("DISTANCEMILES", $locale): GetLocalizedString("DISTANCEKILOMETERS", $locale);
+ $unitText = "";
+ if ($units == "mi") $unitText = "DISTANCEMILES";
+ if ($units == "km") $unitText = "DISTANCEKILOMETERS";
+ if ($units == "ft") $unitText = "DISTANCEFEET";
+ if ($units == "usft") $unitText = "DISTANCEUSFEET";
+ if ($units == "m") $unitText = "DISTANCEMETERS";
+ $unitText = GetLocalizedString($unitText, $locale);
$tip = sprintf("Concat(Concat(Concat('" . GetLocalizedString("MEASUREPARTIAL", $locale) . ": ', PARTIAL), Concat(', " . GetLocalizedString("MEASURETOTAL", $locale) . ": ', TOTAL)), ' (%s)')", $unitText);
@@ -227,6 +235,7 @@
$total,
$distance,
1,
+ $units,
$vpath . "measure.php",
$vpath . "measure.php");
@@ -282,7 +291,7 @@
function GetParameters($params)
- global $mapName, $sessionId, $x1, $y1, $x2, $y2, $popup;
+ global $mapName, $sessionId, $x1, $y1, $x2, $y2, $popup, $units;
global $total, $clear, $us, $segId, $target, $locale;
$sessionId = ValidateSessionId(GetParameter($params, 'SESSION'));
@@ -291,11 +300,11 @@
$target = GetIntParameter($params, 'TGT');
$popup = GetIntParameter($params, 'POPUP');
+ $units = GetParameter($params, 'UNITS');
if(isset($params['CLEAR']))
$clear = true;
else
- $us = GetIntParameter($params, 'US');
$segId = GetIntParameter($params, 'SEGID');
$x1 = GetDoubleParameter($params, 'X1');
$y1 = GetDoubleParameter($params, 'Y1');
Modified: trunk/MgDev/Web/src/mapviewerphp/measureui.php
--- trunk/MgDev/Web/src/mapviewerphp/measureui.php 2012-07-06 15:12:29 UTC (rev 6867)
+++ trunk/MgDev/Web/src/mapviewerphp/measureui.php 2012-07-06 15:25:20 UTC (rev 6868)
@@ -26,6 +26,7 @@
$clientWidth = 0;
$mapName = "";
$sessionId = "";
+ $units = "";
$total = 0;
GetRequestParameters();
@@ -36,7 +37,7 @@
$templ = Localize($templ, $locale, GetClientOS());
$vpath = GetSurroundVirtualPath();
- print sprintf($templ, $locale, $target, $popup, $mapName, $sessionId, $total, 0, 0, $vpath . "measure.php", $vpath . "measure.php");
+ print sprintf($templ, $locale, $target, $popup, $mapName, $sessionId, $total, 0, 0, $units, $vpath . "measure.php", $vpath . "measure.php");
@@ -50,6 +51,7 @@
$cmdIndex = GetIntParameter($params, 'CMDINDEX');
$clientWidth = GetIntParameter($params, 'WIDTH');
$total = GetDoubleParameter($params, 'TOTAL');
function GetRequestParameters()
Modified: trunk/MgDev/Web/src/viewerfiles/measureui.templ
--- trunk/MgDev/Web/src/viewerfiles/measureui.templ 2012-07-06 15:12:29 UTC (rev 6867)
+++ trunk/MgDev/Web/src/viewerfiles/measureui.templ 2012-07-06 15:25:20 UTC (rev 6868)
@@ -48,13 +48,14 @@
var total = %s;
var partial = %s;
var refresh = %s;
+var units = "%s";
function InitDocument()
if(!popup)
document.onmousedown = OnMouseDown;
+ SetUnits();
SetMeasureResults(partial, total);
- ShowUnits();
if(refresh)
GetParent().Refresh();
@@ -66,14 +67,14 @@
function AddMeasure(segId, begin, end)
- var url = "%s?SEGID=" + segId + "&LOCALE=" + locale + "&MAPNAME=" + encodeURIComponent(mapName) + "&SESSION=" + sessionId + "&X1=" + begin.X + "&Y1=" + begin.Y + "&X2=" + end.X + "&Y2=" + end.Y + "&TOTAL=" + total + "&US=" + (GetParent().GetMapFrame().IsEnglishUnits()? 1: 0) + "&TGT=" + target + "&POPUP=" + popup;
+ var url = "%s?SEGID=" + segId + "&LOCALE=" + locale + "&MAPNAME=" + encodeURIComponent(mapName) + "&SESSION=" + sessionId + "&X1=" + begin.X + "&Y1=" + begin.Y + "&X2=" + end.X + "&Y2=" + end.Y + "&TOTAL=" + total + "&UNITS=" + units + "&TGT=" + target + "&POPUP=" + popup;
document.location.href = url;
function ClearMeasure()
GetParent().ClearMeasure();
- var url = "%s?MAPNAME=" + encodeURIComponent(mapName) + "&LOCALE=" + locale + "&SESSION=" + sessionId + "&CLEAR=&TGT=" + target + "&POPUP=" + popup;
+ var url = "%s?MAPNAME=" + encodeURIComponent(mapName) + "&LOCALE=" + locale + "&SESSION=" + sessionId + "&CLEAR=&TGT=" + target + "&POPUP=" + popup + "&UNITS=" + units;
GetParent().ResumeMeasure();
@@ -111,13 +112,46 @@
document.getElementById("total").innerHTML = FormatLocalizedDecimal(total, 2);
-function ShowUnits()
+function OnChangeUnits()
- var units = GetParent().GetMapFrame().IsEnglishUnits()? "__#MILES#__": "__#KILOMETERS#__";
- document.getElementById("units1").innerHTML = units;
- document.getElementById("units2").innerHTML = units;
+ var unitelem = document.getElementById("unitselect");
+ for (var i=0; i < unitelem.length; i++)
+ var opt = unitelem.options[i];
+ if (opt.selected)
+ units = opt.value;
+ document.getElementById("units1").innerHTML = opt.text;
+ document.getElementById("units2").innerHTML = opt.text;
+ break;
+function SetUnits()
+ if (!units || units == "")
+ units = GetParent().GetMapFrame().IsEnglishUnits()? "mi": "km";
+ var unitText = "";
+ opt.selected = false;
+ if (opt.value == units)
+ opt.selected = true;
+ unitText = opt.text;
+ document.getElementById("units1").innerHTML = unitText;
+ document.getElementById("units2").innerHTML = unitText;
function FormatLocalizedDecimal(numberValue, decimalPlaces)
var unlocalized = numberValue.toFixed(decimalPlaces);
@@ -138,6 +172,16 @@
<tr><td class="Title">__#MEASURETITLE#__<hr></td></tr>
<tr><td class="InfoText">__#MEASUREINFO#__</td></tr>
<tr><td height="6"></td></tr>
+ <tr><td class="InfoText">__#MEASUREUNITS#__</td></tr>
+ <tr><td>
+ <select id="unitselect" name="UNITS" class="Ctrl" onchange="OnChangeUnits()">
+ <option value="mi">__#DISTANCEMILES#__</option>
+ <option value="km">__#DISTANCEKILOMETERS#__</option>
+ <option value="usft">__#DISTANCEUSFEET#__</option>
+ <option value="ft">__#DISTANCEFEET#__</option>
+ <option value="m">__#DISTANCEMETERS#__</option>
+ </select>
+ </td></tr>
</table>
<table border="0" cellpadding="5">
<tr class="RegText">
More information about the mapguide-commits
