[mapguide-commits] r6874 - in trunk/MgDev/Desktop: MapViewer MgDesktop MgDesktop/Services MgDesktop/System UnitTest
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Jul 7 03:49:43 PDT 2012
Author: jng
Date: 2012-07-07 03:49:43 -0700 (Sat, 07 Jul 2012)
New Revision: 6874
   trunk/MgDev/Desktop/MapViewer/MgLegend.cs
   trunk/MgDev/Desktop/MgDesktop/MgDesktop.vcproj
   trunk/MgDev/Desktop/MgDesktop/MgDesktop.vcxproj
   trunk/MgDev/Desktop/MgDesktop/Platform.ini
   trunk/MgDev/Desktop/MgDesktop/Services/ResourceService.cpp
   trunk/MgDev/Desktop/MgDesktop/Services/ResourceService.h
   trunk/MgDev/Desktop/MgDesktop/Services/ServiceFactory.cpp
   trunk/MgDev/Desktop/MgDesktop/Services/ServiceFactory.h
   trunk/MgDev/Desktop/MgDesktop/System/PlatformInit.cpp
   trunk/MgDev/Desktop/UnitTest/TestResourceService.cpp
   trunk/MgDev/Desktop/UnitTest/TestResourceService.h
Merge r6857, r6860, r6861, r6873 to trunk
Modified: trunk/MgDev/Desktop/MapViewer/MgLegend.cs
--- trunk/MgDev/Desktop/MapViewer/MgLegend.cs	2012-07-07 05:30:18 UTC (rev 6873)
+++ trunk/MgDev/Desktop/MapViewer/MgLegend.cs	2012-07-07 10:49:43 UTC (rev 6874)
@@ -51,16 +51,33 @@
             InitializeComponent();
+        private Dictionary<string, bool> _initialLayerSelectabilityState = new Dictionary<string, bool>();
         internal void Init(MgMapViewerProvider provider)
             _provider = provider;
             _map = _provider.GetMap();
+            InitInitialSelectabilityStates();
             _resSvc = (MgResourceService)_provider.CreateService(MgServiceType.ResourceService);
             _selectableIcon = Properties.Resources.lc_select;
             _unselectableIcon = Properties.Resources.lc_unselect;
             RefreshLegend();
+        private void InitInitialSelectabilityStates()
+            if (_map != null)
+                _initialLayerSelectabilityState.Clear();
+                var layers = _map.GetLayers();
+                for (int i = 0; i < layers.GetCount(); i++)
+                    var layer = layers.GetItem(i);
+                    _initialLayerSelectabilityState[layer.GetObjectId()] = layer.Selectable;
         private Dictionary<string, MgLayerBase> _layers = new Dictionary<string, MgLayerBase>();
         private Dictionary<string, MgLayerGroup> _groups = new Dictionary<string, MgLayerGroup>();
         private Dictionary<string, string> _layerDefinitionContents = new Dictionary<string, string>();
@@ -287,7 +304,9 @@
             if (fsId.EndsWith("DrawingSource"))
                 node.SelectedImageKey = node.ImageKey = IMG_DWF;
-                node.Tag = new LayerNodeMetadata(layer);
+                //If not in the dictionary, assume it is a dynamically added layer
+                bool bInitiallySelectable = _initialLayerSelectabilityState.ContainsKey(layer.GetObjectId()) ? _initialLayerSelectabilityState[layer.GetObjectId()] : layer.Selectable;
+                node.Tag = new LayerNodeMetadata(layer, bInitiallySelectable);
                 node.ToolTipText = string.Format(Properties.Resources.DrawingLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId);
             else
@@ -343,7 +362,9 @@
                                 imgLegend.Images.Add(id, img);
                                 node.SelectedImageKey = node.ImageKey = id;
                                     ThemeIcon = img
@@ -447,7 +468,7 @@
             TreeNode node = new TreeNode();
             node.Text = (count + " other styles");
             node.ImageKey = node.SelectedImageKey = IMG_OTHER;
-            node.Tag = new LayerNodeMetadata(null) {
+            node.Tag = new LayerNodeMetadata(null, false) {
                 IsBaseLayer = false,
                 ThemeIcon = Properties.Resources.icon_etc,
                 IsThemeRule = true
@@ -458,12 +479,12 @@
         private TreeNode CreateThemeRuleNode(MgResourceIdentifier layerDefId, double viewScale, string labelText, int geomType, int categoryIndex)
             MgByteReader icon = _provider.GenerateLegendImage(layerDefId,
-                                                               viewScale,
-                                                               16,
-                                                               16,
-                                                               "PNG",
-                                                               geomType,
-                                                               categoryIndex);
+                                                              viewScale,
+                                                              16,
+                                                              16,
+                                                              "PNG",
+                                                              geomType,
+                                                              categoryIndex);
             node.Text = labelText;
             if (icon != null)
@@ -473,7 +494,7 @@
                     byte[] b = new byte[icon.GetLength()];
                     icon.Read(b, b.Length);
-                    var tag = new LayerNodeMetadata(null)
+                    var tag = new LayerNodeMetadata(null, false)
                         IsThemeRule = true
@@ -535,12 +556,12 @@
         class LayerNodeMetadata : LegendNodeMetadata
-            public LayerNodeMetadata(MgLayerBase layer)
+            public LayerNodeMetadata(MgLayerBase layer, bool bInitiallySelectable)
                 base.IsGroup = false;
                 this.Layer = layer;
                 this.IsSelectable = (layer != null) ? layer.Selectable : false;
-                this.DrawSelectabilityIcon = (layer != null);
+                this.DrawSelectabilityIcon = (layer != null && bInitiallySelectable);
                 this.IsThemeRule = false;
Modified: trunk/MgDev/Desktop/MgDesktop/MgDesktop.vcproj
--- trunk/MgDev/Desktop/MgDesktop/MgDesktop.vcproj	2012-07-07 05:30:18 UTC (rev 6873)
+++ trunk/MgDev/Desktop/MgDesktop/MgDesktop.vcproj	2012-07-07 10:49:43 UTC (rev 6874)
@@ -241,7 +241,7 @@
 				OutputFile="$(OutDir)\$(ProjectName).dll"
 				LinkIncremental="1"
 				AdditionalLibraryDirectories="..\..\Oem\ACE\ACE_wrappers\lib;..\..\Oem\FDO\Lib;..\..\Oem\DWFTK7.1\develop\global\lib\static\release\vc8.0;"..\..\Oem\dbxml\xerces-c-src\Build\Win32\VC9\Release";..\..\Common\lib\release;..\..\Server\lib\release"
-				DelayLoadDLLs="MgMdfParser.dll;MgGeometry.dll;MgGwsCommon.dll;MgGwsResource.dll;xerces-c_3_1mg.dll;FDO.dll;FDOCommon.dll;MgStylization.dll;FDOGeometry.dll;ExpressionEngine.dll"
+				DelayLoadDLLs="MgMdfParser.dll;MgGeometry.dll;MgGwsCommon.dll;MgGwsResource.dll;FDO.dll;FDOCommon.dll;MgStylization.dll;FDOGeometry.dll;ExpressionEngine.dll"
 				GenerateDebugInformation="true"
 				SubSystem="2"
 				OptimizeReferences="2"
@@ -323,7 +323,7 @@
 				LinkIncremental="1"
 				AdditionalLibraryDirectories="..\..\Oem\ACE\ACE_wrappers\lib64;..\..\Oem\FDO\Lib64;..\..\Oem\DWFTK7.1\develop\global\lib\static\release64\vc8.0;"..\..\Oem\dbxml\xerces-c-src\Build\x64\VC9\Release";..\..\Common\lib\release64;..\..\Server\lib\release64"
 				SubSystem="2"
Modified: trunk/MgDev/Desktop/MgDesktop/MgDesktop.vcxproj
--- trunk/MgDev/Desktop/MgDesktop/MgDesktop.vcxproj	2012-07-07 05:30:18 UTC (rev 6873)
+++ trunk/MgDev/Desktop/MgDesktop/MgDesktop.vcxproj	2012-07-07 10:49:43 UTC (rev 6874)
@@ -129,7 +129,7 @@
       <AdditionalDependencies>FDO.lib;FDOCommon.lib;FDOGeometry.lib;ExpressionEngine.lib;ACE.lib;MgFoundation.lib;MgGeometry.lib;MgMdfModel.lib;MgMdfParser.lib;MgPlatformBase.lib;MgRenderers.lib;MgStylization.lib;MgGwsCommon.lib;MgGwsQueryEngine.lib;xerces-c_3mg.lib;dwfcore_wt.1.1.1.lib;dwftk_wt.7.1.1.lib;whiptk_wt.7.7.601.lib;%(AdditionalDependencies)</AdditionalDependencies>
       <OutputFile>$(OutDir)$(ProjectName).dll</OutputFile>
       <AdditionalLibraryDirectories>..\..\Oem\ACE\ACE_wrappers\lib;..\..\Oem\FDO\Lib;..\..\Oem\DWFTK7.1\develop\global\lib\static\release\vc8.0;..\..\Oem\dbxml\xerces-c-src\Build\Win32\VC10\Release;..\..\Common\lib\release;..\..\Server\lib\release;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
-      <DelayLoadDLLs>MgMdfParser.dll;MgGeometry.dll;MgGwsCommon.dll;MgGwsResource.dll;xerces-c_3_1mg.dll;FDO.dll;FDOCommon.dll;MgStylization.dll;FDOGeometry.dll;ExpressionEngine.dll;%(DelayLoadDLLs)</DelayLoadDLLs>
+      <DelayLoadDLLs>MgMdfParser.dll;MgGeometry.dll;MgGwsCommon.dll;MgGwsResource.dll;FDO.dll;FDOCommon.dll;MgStylization.dll;FDOGeometry.dll;ExpressionEngine.dll;%(DelayLoadDLLs)</DelayLoadDLLs>
       <GenerateDebugInformation>true</GenerateDebugInformation>
       <SubSystem>Windows</SubSystem>
       <OptimizeReferences>true</OptimizeReferences>
@@ -205,7 +205,7 @@
       <AdditionalLibraryDirectories>..\..\Oem\ACE\ACE_wrappers\lib64;..\..\Oem\FDO\Lib64;..\..\Oem\DWFTK7.1\develop\global\lib\static\release64\vc8.0;..\..\Oem\dbxml\xerces-c-src\Build\x64\VC10\Release;..\..\Common\lib\release64;..\..\Server\lib\release64;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
Modified: trunk/MgDev/Desktop/MgDesktop/Platform.ini
(Binary files differ)
Modified: trunk/MgDev/Desktop/MgDesktop/Services/ResourceService.cpp
--- trunk/MgDev/Desktop/MgDesktop/Services/ResourceService.cpp	2012-07-07 05:30:18 UTC (rev 6873)
+++ trunk/MgDev/Desktop/MgDesktop/Services/ResourceService.cpp	2012-07-07 10:49:43 UTC (rev 6874)
@@ -19,13 +19,14 @@
 //INTERNAL_API:
-MgdResourceService::MgdResourceService(CREFSTRING libraryContentRoot, CREFSTRING libraryDataRoot, CREFSTRING sessionContentRoot, CREFSTRING sessionDataRoot)
+MgdResourceService::MgdResourceService(CREFSTRING libraryContentRoot, CREFSTRING libraryDataRoot, CREFSTRING sessionContentRoot, CREFSTRING sessionDataRoot, CREFSTRING schemaPath)
 : MgResourceService()
 	m_libraryContentPath = libraryContentRoot;
 	m_libraryDataPath = libraryDataRoot;
 	m_sessionContentPath = sessionContentRoot;
 	m_sessionDataPath = sessionDataRoot;
+    m_schemaPath = schemaPath;
 MgdResourceService::~MgdResourceService() { }
@@ -298,7 +299,95 @@
     if (NULL != content)
 	    Ptr<MgByteSink> sink = new MgByteSink(content);
-        sink->ToFile(path);
+        std::string xml;
+        sink->ToStringUtf8(xml);
+        XercesDOMParser parser;
+        parser.setValidationScheme(XercesDOMParser::Val_Always);
+        parser.cacheGrammarFromParse(true);
+        DefaultHandler handler;
+        parser.setErrorHandler(&handler);
+        try
+            MemBufInputSource source((const XMLByte*)xml.c_str(), xml.size(), "MgdResourceService.Class", false);
+            parser.parse(source);
+            DOMDocument* doc = parser.getDocument();
+            CHECKNULL(doc, L"MgdResourceService::SetResource");
+            STRING resType = resource->GetResourceType();
+            DOMElement* docEl = doc->getDocumentElement();
+            CHECKNULL(docEl, L"MgdResourceService::SetResource");
+            STRING docElName = docEl->getNodeName();
+            //Now make sure it's the right type of XML document
+            //Everything except SymbolDefinitions will have the same root element name as the resource type
+            if (resType != MgResourceType::SymbolDefinition)
+                if (resType != docElName)
+                    MgStringCollection args;
+                    args.Add(docElName);
+                    throw new MgInvalidResourceTypeException(L"MgdResourceService::SetResource", __LINE__, __WFILE__, &args, L"", NULL);
+            else
+                if (docElName != L"SimpleSymbolDefinition" && docElName != L"CompoundSymbolDefinition")
+        catch (const SAXParseException& e)
+            STRING msg = e.getMessage();
+            XMLFileLoc lineNum = e.getLineNumber();
+            XMLFileLoc colNum = e.getColumnNumber();
+            const XMLCh* pubId = e.getPublicId();
+            const XMLCh* sysId = e.getSystemId();
+            STRING pubIdStr;
+            if (NULL != pubId)
+                pubIdStr = pubId;
+            STRING sysIdStr;
+            if (NULL != sysId)
+                sysIdStr = sysId;
+            STRING lineNumStr;
+            STRING colNumStr;
+            MgUtil::Int64ToString(lineNum, lineNumStr);
+            MgUtil::Int64ToString(colNum, colNumStr);
+            args.Add(msg);
+            args.Add(lineNumStr);
+            args.Add(colNumStr);
+            args.Add(pubIdStr);
+            args.Add(sysIdStr);
+            throw new MgXmlParserException(L"MgdResourceService::SetResource", __LINE__, __WFILE__, &args, L"", NULL);
+        //Can't rewind a byte sink. So make another one
+        if (content->IsRewindable())
+            content->Rewind();
+            Ptr<MgByteSink> sink2 = new MgByteSink(content);
+            sink2->ToFile(path);
+        else
+            //Make a new byte source/reader/sink from the checked out xml string
+            Ptr<MgByteSource> bs = new MgByteSource((BYTE_ARRAY_IN)xml.c_str(), (INT32)xml.length());
+            Ptr<MgByteReader> rdr = bs->GetReader();
+            Ptr<MgByteSink> sink2 = new MgByteSink(rdr);
         ReleasePotentialLocks(resource);
Modified: trunk/MgDev/Desktop/MgDesktop/Services/ResourceService.h
--- trunk/MgDev/Desktop/MgDesktop/Services/ResourceService.h	2012-07-07 05:30:18 UTC (rev 6873)
+++ trunk/MgDev/Desktop/MgDesktop/Services/ResourceService.h	2012-07-07 10:49:43 UTC (rev 6874)
@@ -8,7 +8,7 @@
     DECLARE_CLASSNAME(MgdResourceService)
 INTERNAL_API:
-    MgdResourceService(CREFSTRING libraryContentRoot, CREFSTRING libraryDataRoot, CREFSTRING sessionContentRoot, CREFSTRING sessionDataRoot);
+    MgdResourceService(CREFSTRING libraryContentRoot, CREFSTRING libraryDataRoot, CREFSTRING sessionContentRoot, CREFSTRING sessionDataRoot, CREFSTRING schemaPath);
     virtual MgByteReader* EnumerateRepositories(CREFSTRING repositoryType);
Modified: trunk/MgDev/Desktop/MgDesktop/Services/ServiceFactory.cpp
--- trunk/MgDev/Desktop/MgDesktop/Services/ServiceFactory.cpp	2012-07-07 05:30:18 UTC (rev 6873)
+++ trunk/MgDev/Desktop/MgDesktop/Services/ServiceFactory.cpp	2012-07-07 10:49:43 UTC (rev 6874)
@@ -11,6 +11,7 @@
 STRING MgServiceFactory::sm_libDataPath = L"";
 STRING MgServiceFactory::sm_sesContentPath = L"";
 STRING MgServiceFactory::sm_sesDataPath = L"";
+STRING MgServiceFactory::sm_schemaPath = L"";
 MG_IMPL_DYNCREATE(MgServiceFactory);
@@ -42,6 +43,11 @@
                          sm_sesDataPath,
                          MgConfigProperties::DefaultResourceServicePropertySessionResourceDataFilePath);
+    conf->GetStringValue(MgConfigProperties::ResourceServicePropertiesSection,
+                         MgConfigProperties::ResourceServicePropertyResourceSchemaFilePath,
+                         sm_schemaPath,
+                         MgConfigProperties::DefaultResourceServicePropertyResourceSchemaFilePath);
     //Create these paths if they don't exist
     if (!MgFileUtil::IsDirectory(sm_libContentPath))
         MgFileUtil::CreateDirectory(sm_libContentPath, false, true);
@@ -51,6 +57,12 @@
         MgFileUtil::CreateDirectory(sm_sesContentPath, false, true);
     if (!MgFileUtil::IsDirectory(sm_sesDataPath))
         MgFileUtil::CreateDirectory(sm_sesDataPath, false, true);
+    if (!MgFileUtil::IsDirectory(sm_schemaPath))
+        args.Add(sm_schemaPath);
+        throw new MgDirectoryNotFoundException(L"MgServiceFactory::Initialize", __LINE__, __WFILE__, &args, L"", NULL);
 MgService* MgServiceFactory::CreateService(INT32 serviceType)
@@ -71,7 +83,8 @@
         return new MgdResourceService(sm_libContentPath,
                                       sm_libDataPath,
                                       sm_sesContentPath,
-                                      sm_sesDataPath);
+                                      sm_sesDataPath,
+                                      sm_schemaPath);
     case MgServiceType::TileService:
         return new MgdTileService();
Modified: trunk/MgDev/Desktop/MgDesktop/Services/ServiceFactory.h
--- trunk/MgDev/Desktop/MgDesktop/Services/ServiceFactory.h	2012-07-07 05:30:18 UTC (rev 6873)
+++ trunk/MgDev/Desktop/MgDesktop/Services/ServiceFactory.h	2012-07-07 10:49:43 UTC (rev 6874)
@@ -34,6 +34,7 @@
     static STRING sm_libDataPath;
 	static STRING sm_sesContentPath;
 	static STRING sm_sesDataPath;
+    static STRING sm_schemaPath;
 #endif
\ No newline at end of file
Modified: trunk/MgDev/Desktop/MgDesktop/System/PlatformInit.cpp
--- trunk/MgDev/Desktop/MgDesktop/System/PlatformInit.cpp	2012-07-07 05:30:18 UTC (rev 6873)
+++ trunk/MgDev/Desktop/MgDesktop/System/PlatformInit.cpp	2012-07-07 10:49:43 UTC (rev 6874)
@@ -14,6 +14,7 @@
         return;
     ACE::init();
+    XMLPlatformUtils::Initialize();
     MgConfiguration* pConfiguration = MgConfiguration::GetInstance();
     pConfiguration->LoadConfiguration(configFile);
@@ -179,6 +180,7 @@
     Ptr<MgdResourceService> resSvc = dynamic_cast<MgdResourceService*>(fact->CreateService(MgServiceType::ResourceService));
     resSvc->DeleteSessionFiles();
+    XMLPlatformUtils::Terminate();
     ACE::fini();
     MG_CATCH_AND_RELEASE()
Modified: trunk/MgDev/Desktop/UnitTest/TestResourceService.cpp
--- trunk/MgDev/Desktop/UnitTest/TestResourceService.cpp	2012-07-07 05:30:18 UTC (rev 6873)
+++ trunk/MgDev/Desktop/UnitTest/TestResourceService.cpp	2012-07-07 10:49:43 UTC (rev 6874)
@@ -429,6 +429,77 @@
+void TestResourceService::TestCase_SetResourceInvalid()
+    try
+        Ptr<MgServiceFactory> fact = new MgServiceFactory();
+        Ptr<MgResourceService> pService = dynamic_cast<MgResourceService*>(fact->CreateService(MgServiceType::ResourceService));
+        if (pService == 0)
+            throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_MoveResource", __LINE__, __WFILE__, NULL, L"", NULL);
+        std::string notXml = "Not XML content";
+        std::string malformedXml = "<Foo></Bar>";
+        std::string fsXml = "<FeatureSource></FeatureSource>";
+        std::string unkXml = "<Unknown></Unknown>";
+        std::string fsIncompleteXml = "<FeatureSource xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" xsi:noNamespaceSchemaLocation=\"FeatureSource-1.0.0.xsd\"></FeatureSource>";
+        std::string simpleSymXml = "<SimpleSymbolDefinition></SimpleSymbolDefinition>";
+        std::string compoundSymXml = "<CompoundSymbolDefinition></CompoundSymbolDefinition>";
+        Ptr<MgByteSource> bs1 = new MgByteSource((BYTE_ARRAY_IN)notXml.c_str(), (INT32)notXml.length());
+        Ptr<MgByteSource> bs2 = new MgByteSource((BYTE_ARRAY_IN)malformedXml.c_str(), (INT32)malformedXml.length());
+        Ptr<MgByteSource> bs3 = new MgByteSource((BYTE_ARRAY_IN)fsXml.c_str(), (INT32)fsXml.length());
+        Ptr<MgByteSource> bs4 = new MgByteSource((BYTE_ARRAY_IN)unkXml.c_str(), (INT32)unkXml.length());
+        Ptr<MgByteSource> bs5 = new MgByteSource((BYTE_ARRAY_IN)fsIncompleteXml.c_str(), (INT32)fsIncompleteXml.length());
+        Ptr<MgByteSource> bs6 = new MgByteSource((BYTE_ARRAY_IN)simpleSymXml.c_str(), (INT32)simpleSymXml.length());
+        Ptr<MgByteSource> bs7 = new MgByteSource((BYTE_ARRAY_IN)compoundSymXml.c_str(), (INT32)compoundSymXml.length());
+        Ptr<MgByteReader> r1 = bs1->GetReader();
+        Ptr<MgByteReader> r2 = bs2->GetReader();
+        Ptr<MgByteReader> r3 = bs3->GetReader();
+        Ptr<MgByteReader> r4 = bs4->GetReader();
+        Ptr<MgByteReader> r5 = bs5->GetReader();
+        Ptr<MgByteReader> r6 = bs6->GetReader();
+        Ptr<MgByteReader> r7 = bs7->GetReader();
+        Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(L"Library://UnitTests/NotGettingSaved.FeatureSource");
+        Ptr<MgResourceIdentifier> ldfId = new MgResourceIdentifier(L"Library://UnitTests/NotGettingSaved.LayerDefinition");
+        Ptr<MgResourceIdentifier> mdfId = new MgResourceIdentifier(L"Library://UnitTests/NotGettingSaved.MapDefinition");
+        Ptr<MgResourceIdentifier> pltId = new MgResourceIdentifier(L"Library://UnitTests/NotGettingSaved.PrintLayout");
+        Ptr<MgResourceIdentifier> symId = new MgResourceIdentifier(L"Library://UnitTests/NotGettingSaved.SymbolDefinition");
+        Ptr<MgResourceIdentifier> slbId = new MgResourceIdentifier(L"Library://UnitTests/NotGettingSaved.SymbolLibrary");
+        Ptr<MgResourceIdentifier> ssId = new MgResourceIdentifier(L"Library://UnitTests/GettingSavedSimple.SymbolDefinition");
+        Ptr<MgResourceIdentifier> csId = new MgResourceIdentifier(L"Library://UnitTests/GettingSavedCompound.SymbolDefinition");
+        //TODO: We can get xerces to vet the content as being XML, but can't figure out how to get xerces
+        //to validate the content model. Until we figure that out, the relevant assertions are commented
+        //out. Still at this stage it's better than letting any arbitrary content get through these calls.
+        CPPUNIT_ASSERT_THROW_MG(pService->SetResource(resId, r1, NULL), MgXmlParserException*);
+        CPPUNIT_ASSERT_THROW_MG(pService->SetResource(resId, r2, NULL), MgXmlParserException*);
+        //CPPUNIT_ASSERT_THROW_MG(pService->SetResource(resId, r3, NULL), MgXmlParserException*);
+        CPPUNIT_ASSERT_THROW_MG(pService->SetResource(ldfId, r3, NULL), MgInvalidResourceTypeException*);
+        r3->Rewind();
+        CPPUNIT_ASSERT_THROW_MG(pService->SetResource(mdfId, r3, NULL), MgInvalidResourceTypeException*);
+        r3->Rewind();
+        CPPUNIT_ASSERT_THROW_MG(pService->SetResource(pltId, r3, NULL), MgInvalidResourceTypeException*);
+        r3->Rewind();
+        CPPUNIT_ASSERT_THROW_MG(pService->SetResource(symId, r3, NULL), MgInvalidResourceTypeException*);
+        r3->Rewind();
+        CPPUNIT_ASSERT_THROW_MG(pService->SetResource(slbId, r3, NULL), MgInvalidResourceTypeException*);
+        CPPUNIT_ASSERT_THROW_MG(pService->SetResource(resId, r4, NULL), MgInvalidResourceTypeException*);
+        //CPPUNIT_ASSERT_THROW_MG(pService->SetResource(resId, r5, NULL), MgXmlParserException*);
+        pService->SetResource(ssId, r6, NULL);
+        pService->SetResource(csId, r7, NULL);
+    catch(MgException* e)
+        STRING message = e->GetDetails(TEST_LOCALE);
+        SAFE_RELEASE(e);
+        CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
 /// Test Case Description:
Modified: trunk/MgDev/Desktop/UnitTest/TestResourceService.h
--- trunk/MgDev/Desktop/UnitTest/TestResourceService.h	2012-07-07 05:30:18 UTC (rev 6873)
+++ trunk/MgDev/Desktop/UnitTest/TestResourceService.h	2012-07-07 10:49:43 UTC (rev 6874)
@@ -36,6 +36,7 @@
     CPPUNIT_TEST(TestCase_ResourceExists);
     CPPUNIT_TEST(TestCase_EnumerateResources);
     CPPUNIT_TEST(TestCase_SetResource);
+    CPPUNIT_TEST(TestCase_SetResourceInvalid);
     CPPUNIT_TEST(TestCase_MoveResource);
     CPPUNIT_TEST(TestCase_CopyResource);
     CPPUNIT_TEST(TestCase_GetResourceContent);
@@ -78,6 +79,7 @@
     void TestCase_ResourceExists();
     void TestCase_EnumerateResources();
     void TestCase_SetResource();
+    void TestCase_SetResourceInvalid();
     void TestCase_MoveResource();
     void TestCase_CopyResource();
     void TestCase_GetResourceContent();
More information about the mapguide-commits mailing list
