[mapguide-commits] r6877 - in trunk/MgDev: . Server/src/Core
svn_mapguide at osgeo.org
Sat Jul 7 10:11:44 PDT 2012
Author: jng
Date: 2012-07-07 10:11:44 -0700 (Sat, 07 Jul 2012)
New Revision: 6877
trunk/MgDev/Server/src/Core/Makefile.am
trunk/MgDev/configure.in
#2063: Add NLSPATH to mgserver.sh and mgserverd.sh allow for any FDO exceptions thrown to have actual messages instead of symbolic ids
Modified: trunk/MgDev/Server/src/Core/Makefile.am
--- trunk/MgDev/Server/src/Core/Makefile.am 2012-07-07 16:11:14 UTC (rev 6876)
+++ trunk/MgDev/Server/src/Core/Makefile.am 2012-07-07 17:11:44 UTC (rev 6877)
@@ -387,8 +387,6 @@
@cp -fp ../../RepositoryAdmin/*.pdf $(repositoryadmindir)
@cp -fp ../../RepositoryAdmin/license.txt $(repositoryadmindir)
@cp -fp ../../RepositoryAdmin/php.ini $(repositoryadmindir)
- @pushd $(fdodir); ln -s libxalanMsg.so.17.0 libxalanMsg.so.17; ln -s libxalanMsg.so.17.0 libxalanMsg.so; popd;
- @pushd $(fdodir); ln -s libxerces-c.so.25.0 libxerces-c.so.25; ln -s libxerces-c.so.25.0 libxerces-c.so; popd;
install-data-hook:
@sed -e 's#^FdoPath.*=.*#FdoPath = $(map_fdo_lib)#' \
@@ -412,6 +410,7 @@
@echo '' >> ${prefix}/bin/mgserver.sh
@echo 'export MENTOR_DICTIONARY_PATH=$(mentor_dict_install_dir)' >> ${prefix}/bin/mgserver.sh
@echo 'export LD_LIBRARY_PATH=$(fdodir):"$$LD_LIBRARY_PATH"' >> ${prefix}/bin/mgserver.sh
+ @echo 'export NLSPATH=$(map_fdo_nls):"$$NLSPATH"' >> ${prefix}/bin/mgserver.sh
@echo 'pushd ${prefix}/bin' >> ${prefix}/bin/mgserver.sh
@cp -f ${prefix}/bin/mgserver.sh ${prefix}/bin/mgserverd.sh
@echo './mgserver run' >> ${prefix}/bin/mgserver.sh
Modified: trunk/MgDev/configure.in
--- trunk/MgDev/configure.in 2012-07-07 16:11:14 UTC (rev 6876)
+++ trunk/MgDev/configure.in 2012-07-07 17:11:44 UTC (rev 6877)
@@ -101,9 +101,10 @@
AC_MSG_ERROR([the specified FDO library path $custom_lib is not a valid directory])
fi
fi
+map_fdo_nls="/usr/local/fdo-3.8.0/nls/%N"
AC_SUBST(map_fdo_include)
AC_SUBST(map_fdo_lib)
+AC_SUBST(map_fdo_nls)
dnl *******************************************************
dnl GCC Compiler Configuration
More information about the mapguide-commits
