[mapguide-commits] r6881 - in branches/2.4/MgDev/Desktop: MapViewer MapViewer/AppLayoutEngine MapViewerTest
svn_mapguide at osgeo.org
Mon Jul 9 04:07:56 PDT 2012
Author: jng
Date: 2012-07-09 04:07:55 -0700 (Mon, 09 Jul 2012)
New Revision: 6881
branches/2.4/MgDev/Desktop/MapViewer/AppLayoutEngine/Shell.cs
branches/2.4/MgDev/Desktop/MapViewer/MgComponent.cs
branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs
branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.cs
branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.resx
#2064: Document solution for non-modals to not be sent to the back of the draw order by the MgMapViewer control. Basically such forms you have to call Show() with the owner parameter. The owner may or may not be null, but using this particular overload ensures that it will not be sent to the back of the drawing order if the form is over an instance of the MgMapViewer control.
Modified: branches/2.4/MgDev/Desktop/MapViewer/AppLayoutEngine/Shell.cs
--- branches/2.4/MgDev/Desktop/MapViewer/AppLayoutEngine/Shell.cs 2012-07-09 09:06:02 UTC (rev 6880)
+++ branches/2.4/MgDev/Desktop/MapViewer/AppLayoutEngine/Shell.cs 2012-07-09 11:07:55 UTC (rev 6881)
@@ -364,6 +364,17 @@
_components[compDef.ComponentID].Viewer = mapViewer;
+ //4th pass, set the owner parent of any MgViewerComponent instances
+ //to this instance
+ foreach (var comp in _components.Values)
+ var vc = comp as MgViewerComponent;
+ if (vc != null)
+ vc.OwnerParent = this;
void IMapStatusBar.SetCursorPositionMessage(string message)
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgComponent.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgComponent.cs 2012-07-09 09:06:02 UTC (rev 6880)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgComponent.cs 2012-07-09 11:07:55 UTC (rev 6881)
@@ -308,6 +308,17 @@
/// <summary>
+ /// Gets or sets the owner form that any new windows displayed by this component will belong to.
+ /// </summary>
+ [Category("MapGuide Component Properties")]
+ [Description("The parent form which will be the owner for any new windows displayed by this component")]
+ public Form OwnerParent
+ get;
+ set;
+ /// <summary>
/// Creates the associated view. Must be overridden by subclasses
/// </summary>
/// <returns></returns>
@@ -323,7 +334,7 @@
else //New Window
- new NewWindowContentCloser(control);
+ new NewWindowContentCloser(control, this.OwnerParent);
@@ -352,7 +363,7 @@
private Form _frm;
private MgControlImpl _control;
- public NewWindowContentCloser(MgControlImpl control)
+ public NewWindowContentCloser(MgControlImpl control, Form owner)
_frm = new Form();
_control = control;
@@ -365,9 +376,9 @@
_control.Closer = this;
if (control.ModalWindow)
- _frm.ShowDialog();
+ _frm.ShowDialog(owner);
else
- _frm.Show();
+ _frm.Show(owner);
public void Close()
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs 2012-07-09 09:06:02 UTC (rev 6880)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs 2012-07-09 11:07:55 UTC (rev 6881)
@@ -16,8 +16,27 @@
namespace OSGeo.MapGuide.Viewer
/// <summary>
- /// A map viewer component
+ /// A map viewer component for displaying/rendering a <see cref="T:OSGeo.MapGuide.MgMapBase"/> instance
/// </summary>
+ /// <remarks>
+ /// <para>
+ /// For any non-modal <see cref="T:System.Windows.Forms.Form"/> instances displayed over this control, if you call <see cref="T:System.Windows.Forms.Form.Show()"/> on the
+ /// form without specifying the owner, this control will automatically be sent to the back of the draw order by this control. To avoid this behavior always call
+ /// <see cref="T:System.Windows.Forms.Form.Show(System.Windows.Forms.IWin32Window)"/>. You can choose to pass an actual owner or a null owner, but this particular overload
+ /// must be used.
+ /// </para>
+ /// <para>
+ /// If you are using <see cref="T:OSGeo.MapGuide.Viewer.MgViewerComponent"/> instances with <see cref="T:OSGeo.MapGuide.Viewer.MgViewerTarget"/> set to NewWindow,
+ /// be sure to set the <see cref="P:OSGeo.MapGuide.Viewer.MgViewerComponent.OwnerParent"/> property to your top-level form. This form will be automatically set as
+ /// the owner form for any new window displayed by the respective component. This property is optional. All forms displayed by this component will not exhibit the
+ /// "sent to back of draw order" display problem.
+ /// </para>
+ /// <para>
+ /// For applications using the AppLayout engine, such components do not need to have the OwnerParent set. As long as the Target is set to NewWindow, the AppLayout
+ /// engine will automatically set the OwnerParent of all defined <see cref="T:OSGeo.MapGuide.Viewer.MgViewerComponent"/> instances to the main
+ /// AppLayout main window.
+ /// </para>
+ /// </remarks>
[ToolboxItem(true)]
public class MgMapViewer : Control, IMapViewer
Modified: branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.cs
--- branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.cs 2012-07-09 09:06:02 UTC (rev 6880)
+++ branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.cs 2012-07-09 11:07:55 UTC (rev 6881)
@@ -118,7 +118,7 @@
var map = mapViewer.GetMap();
var viewer = new CompactViewer();
viewer.LoadMap(map.MapDefinition);
- viewer.Show();
+ viewer.Show(this); //or viewer.Show(null) works too. You just have to call the overload of Show() that takes a owner parameter
private void profileComponent_Invoked(object sender, EventArgs e)
Modified: branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.resx
--- branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.resx 2012-07-09 09:06:02 UTC (rev 6880)
+++ branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.resx 2012-07-09 11:07:55 UTC (rev 6881)
@@ -126,148 +126,10 @@
<metadata name="mgLoadMapComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>1081, 173</value>
</metadata>
- <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
- <data name="toolStripMenuItem1.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIMAAAAAAP///ydYF5fYTmBfDJlmAGYzALWEU8yZZtSmeP/jyP///wAAAAAAAAAAAAAA
- ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAALACwAAAAAEAAQAAAIcwAXCBxIcIGAgwUTGhQQAKHAAhAj
- FiDAcMAAhBATINioAEFFixchKhhJUsFBARcPFtC4kWNLlAIMLFiZoGZNBTZhyixwoKdPBT51zvT5M+jF
- nSWTmjy4k2hPoE6bOoVKVCpRqj6tFo0604DXr2DBKhwrMCAAOw==
-</value>
- </data>
- <metadata name="mgLoadPackageComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>1019, 95</value>
- </metadata>
- <data name="mgLoadPackageComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
-</value>
- </data>
<metadata name="appContextMenu.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>338, 17</value>
</metadata>
- <data name="toolStripMenuItem2.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
- YQUAAAAJcEhZcwAADrwAAA68AZW8ckkAAAFoSURBVDhPpVNdKwRRGN47jZ/g57hQJGSzmxSTUv4DF26F
- tRa12JLaXVtKMimJ3ZKLsUyWbEImdsUwF37C4zwzTZ2z7a4pp956v57ned9zZiIRcbTJgy5NNzIduvGj
- jRtVbcKYY461UIeAWNpC2qxj/swG/U7dgAz2REhMgUYRJhaKNmZSOfR0R5GtfKA3YSokJIwLYvbR6HNq
- T4QEiyJJcGD520/0LfskNPrMsT6byiNTfgdX9gnEaKMbFgp3fkNgjGWTa4mSDQr7BGI/qvQnTezdqySM
- m+XGNsUKQli5ZJIMJC+xX3WUSWRl1tjD3qYvxcLhg+OZDKTP3OCKD275vCwePX55JhMwHkqFAA+vlnH8
- /K2AGTPfUjm4xKhoOn1RwYyZbzs2b3Nq+wYl21WUGY+s/QEOPqTsVU0Bn7+6iK2HAAcEuesalrYKHsnF
- m4t4WHDwJU7vVHDy5GDXqoN+250b3/A/v/MvkqOAAMpRUaEAAAAASUVORK5CYII=
-</value>
- </data>
- <metadata name="mgBufferComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>1019, 134</value>
- </metadata>
- <data name="mgBufferComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
-</value>
- </data>
- <data name="toolStripMenuItem3.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAJcEhZcwAADrwAAA68AZW8ckkAAABjSURBVDhPY2AY+sDGxuY/Ob6A64MxiDUIQz1IgFwMdjlV
- XEBRGJCjGUXPxCC2VfVBbP/QMVD8PzZxmBhIH9ggkMD/Fyn/F5ea/SeFBumDG/D9FNt/UjDIIrgBFHuB
- 4kAccAMAwje0sEjeZewAAAAASUVORK5CYII=
-</value>
- </data>
- <metadata name="mgMeasureComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>412, 173</value>
- </metadata>
- <data name="mgMeasureComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
-</value>
- </data>
- <data name="toolStripMenuItem4.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAJcEhZcwAADrwAAA68AZW8ckkAAAHySURBVDhPnZPLSxtRFMb9T6rUTW3Ulmw0GhqMNk0wSqCO
- YhnNIkZUjCKUgvj4C7rSlUtXQksKRUHQxk0XhYpF8IETkpiHjxiT0TgTI0nm6z0DloxJbOmFj3Mf5/7u
- me8wVVVFY2hyasLmcPjr6l8o1TW1eKZrVGhN+8V5ZeedbznB1PEGS5+82No/xHd/QI1Ln71oNppgc3D+
- ipCuHk74uLCIH4EQdiIx/GLaDkfx8zii6ujsHIPDI6C8EsjY+w8TbRYbdo7D2D89Qzx9A+nuTp3vxk7+
- aDsYQqupDZSvgXRz/cLK6hqOzuOIiSIKioLrTAZC/AKH7OViLXu/oJt7UIWu4aVyEI0hnEwhm8tBYYAT
- 8QrBxCUCD7QXieI5M1hTwZPqpwhfJnF6da1eTkqyCoimxBKFLhKg7mgAOkaMsIPEjaRepkg+lFOQ+UL5
- GgD3jhfWv/kgypm/yvt1FZSvAUxPz3qaDUbI2Sxk5n45kTepdBpNhlZQfkkr+/oG/J7JKci3t8gVCiWS
- WFdGx8bBDzhhbn+t9eCexvO88Ir12efbgsS8yOfzLErY2NiEocWI3t5+2O12uN3uypDZ+XkPgepZa6k7
- FGlN+/SyXq+H1WqFy+WqDHnsp7mHWCwWOJ2PfM6/QMxm8/9VQXCqhDQzM4ffTfzkLal2r4sAAAAASUVO
- RK5CYII=
-</value>
- </data>
- <metadata name="mgQueryComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>238, 173</value>
- </metadata>
- <data name="mgQueryComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- RK5CYII=
-</value>
- </data>
- <data name="toolStripMenuItem28.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIMAAAAAAP///6e6zXG39mCc0bzd+87trIC4QpfYTv/eStm9P//vqmdnZywsLP///wAA
- ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAOACwAAAAAEAAQAAAIeQAdCBxIsKADBggTIjQokIGBhxAb
- MDxoAIFFBAckMnRoUaFCghwRMFhAsqTGhhVFLkjAMoGCkxQPHBjJ0qPCBjhpJmBQoKfPBgKCCtDJc4DR
- AQRgjlSgoOjRpCBxNnBqFOpAoUMLHEUKE2QBAmDBdh3IQKrZiVixBgQAOw==
-</value>
- </data>
- <metadata name="mgThemeComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>903, 173</value>
- </metadata>
- <data name="mgThemeComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
-</value>
- </data>
- <data name="toolStripMenuItem12.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAJcEhZcwAADr0AAA69AUf7kK0AAAC0SURBVDhPrZPLCsIwEEXzXeKyS/0bQUFxISiKK8EH/TXF
- QtRiKBaLSqyrkQnkgovCkBg4zFyYOYRAlIo9raSTtpMuhcC7ihfPuQGD2Yak8K4TxOAEoQc3OGQnkrI/
- avJAkOmcepMV4CwBAn0x1J+u6fmyrvrMfRM8A0F+LX5enrMECExRUggQ3MqKhvMt4CwBgnv1oNFiR3X9
- cdVn7pvgGQj48cbLFHCWAIG1bwrhP4LY3/gFpD/IGPp59QYAAAAASUVORK5CYII=
-</value>
- </data>
- <metadata name="mgViewerOptionsComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>17, 173</value>
- </metadata>
- <data name="mgViewerOptionsComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
-</value>
- </data>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="toolStripMenuItem13.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -510,6 +372,21 @@
</value>
</data>
+ <metadata name="mgBufferComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>1019, 134</value>
+ </metadata>
+ <data name="mgBufferComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+ YQUAAAAJcEhZcwAADrwAAA68AZW8ckkAAAFoSURBVDhPpVNdKwRRGN47jZ/g57hQJGSzmxSTUv4DF26F
+ tRa12JLaXVtKMimJ3ZKLsUyWbEImdsUwF37C4zwzTZ2z7a4pp956v57ned9zZiIRcbTJgy5NNzIduvGj
+ jRtVbcKYY461UIeAWNpC2qxj/swG/U7dgAz2REhMgUYRJhaKNmZSOfR0R5GtfKA3YSokJIwLYvbR6HNq
+ T4QEiyJJcGD520/0LfskNPrMsT6byiNTfgdX9gnEaKMbFgp3fkNgjGWTa4mSDQr7BGI/qvQnTezdqySM
+ m+XGNsUKQli5ZJIMJC+xX3WUSWRl1tjD3qYvxcLhg+OZDKTP3OCKD275vCwePX55JhMwHkqFAA+vlnH8
+ /K2AGTPfUjm4xKhoOn1RwYyZbzs2b3Nq+wYl21WUGY+s/QEOPqTsVU0Bn7+6iK2HAAcEuesalrYKHsnF
+ m4t4WHDwJU7vVHDy5GDXqoN+250b3/A/v/MvkqOAAMpRUaEAAAAASUVORK5CYII=
+</value>
+ </data>
<data name="toolStripMenuItem22.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -518,6 +395,17 @@
</value>
</data>
+ <metadata name="mgMeasureComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>412, 173</value>
+ </metadata>
+ <data name="mgMeasureComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAJcEhZcwAADrwAAA68AZW8ckkAAABjSURBVDhPY2AY+sDGxuY/Ob6A64MxiDUIQz1IgFwMdjlV
+ XEBRGJCjGUXPxCC2VfVBbP/QMVD8PzZxmBhIH9ggkMD/Fyn/F5ea/SeFBumDG/D9FNt/UjDIIrgBFHuB
+ 4kAccAMAwje0sEjeZewAAAAASUVORK5CYII=
+</value>
+ </data>
<data name="toolStripMenuItem23.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -533,15 +421,127 @@
RK5CYII=
</value>
</data>
+ <metadata name="mgQueryComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>238, 173</value>
+ </metadata>
+ <data name="mgQueryComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAJcEhZcwAADrwAAA68AZW8ckkAAAHySURBVDhPnZPLSxtRFMb9T6rUTW3Ulmw0GhqMNk0wSqCO
+ YhnNIkZUjCKUgvj4C7rSlUtXQksKRUHQxk0XhYpF8IETkpiHjxiT0TgTI0nm6z0DloxJbOmFj3Mf5/7u
+ me8wVVVFY2hyasLmcPjr6l8o1TW1eKZrVGhN+8V5ZeedbznB1PEGS5+82No/xHd/QI1Ln71oNppgc3D+
+ ipCuHk74uLCIH4EQdiIx/GLaDkfx8zii6ujsHIPDI6C8EsjY+w8TbRYbdo7D2D89Qzx9A+nuTp3vxk7+
+ aDsYQqupDZSvgXRz/cLK6hqOzuOIiSIKioLrTAZC/AKH7OViLXu/oJt7UIWu4aVyEI0hnEwhm8tBYYAT
+ 8QrBxCUCD7QXieI5M1hTwZPqpwhfJnF6da1eTkqyCoimxBKFLhKg7mgAOkaMsIPEjaRepkg+lFOQ+UL5
+ GgD3jhfWv/kgypm/yvt1FZSvAUxPz3qaDUbI2Sxk5n45kTepdBpNhlZQfkkr+/oG/J7JKci3t8gVCiWS
+ WFdGx8bBDzhhbn+t9eCexvO88Ir12efbgsS8yOfzLErY2NiEocWI3t5+2O12uN3uypDZ+XkPgepZa6k7
+ FGlN+/SyXq+H1WqFy+WqDHnsp7mHWCwWOJ2PfM6/QMxm8/9VQXCqhDQzM4ffTfzkLal2r4sAAAAASUVO
+ RK5CYII=
+</value>
+ </data>
<data name="toolStripMenuItem24.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
+ YQUAAAAJcEhZcwAADrwAAA68AZW8ckkAAAC0SURBVDhPrZPLCsIwEEXzXeKyS/0bQUFxISiKK8EH/TXF
</value>
</data>
+ <metadata name="mgViewerOptionsComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 173</value>
+ </metadata>
+ <data name="mgViewerOptionsComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ QtRiKBaLSqyrkQnkgovCkBg4zFyYOYRAlIo9raSTtpMuhcC7ihfPuQGD2Yak8K4TxOAEoQc3OGQnkrI/
+ avJAkOmcepMV4CwBAn0x1J+u6fmyrvrMfRM8A0F+LX5enrMECExRUggQ3MqKhvMt4CwBgnv1oNFiR3X9
+ cdVn7pvgGQj48cbLFHCWAIG1bwrhP4LY3/gFpD/IGPp59QYAAAAASUVORK5CYII=
+</value>
+ </data>
+ <data name="toolStripMenuItem1.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIMAAAAAAP///ydYF5fYTmBfDJlmAGYzALWEU8yZZtSmeP/jyP///wAAAAAAAAAAAAAA
+ ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAALACwAAAAAEAAQAAAIcwAXCBxIcIGAgwUTGhQQAKHAAhAj
+ FiDAcMAAhBATINioAEFFixchKhhJUsFBARcPFtC4kWNLlAIMLFiZoGZNBTZhyixwoKdPBT51zvT5M+jF
+ nSWTmjy4k2hPoE6bOoVKVCpRqj6tFo0604DXr2DBKhwrMCAAOw==
+</value>
+ </data>
+ <metadata name="mgLoadPackageComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>1019, 95</value>
+ </metadata>
+ <data name="mgLoadPackageComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+</value>
+ </data>
+ <data name="toolStripMenuItem2.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+</value>
+ </data>
+ <data name="toolStripMenuItem3.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+</value>
+ </data>
+ <data name="toolStripMenuItem4.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ RK5CYII=
+</value>
+ </data>
+ <data name="toolStripMenuItem28.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIMAAAAAAP///6e6zXG39mCc0bzd+87trIC4QpfYTv/eStm9P//vqmdnZywsLP///wAA
+ ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAOACwAAAAAEAAQAAAIeQAdCBxIsKADBggTIjQokIGBhxAb
+ MDxoAIFFBAckMnRoUaFCghwRMFhAsqTGhhVFLkjAMoGCkxQPHBjJ0qPCBjhpJmBQoKfPBgKCCtDJc4DR
+ AQRgjlSgoOjRpCBxNnBqFOpAoUMLHEUKE2QBAmDBdh3IQKrZiVixBgQAOw==
+</value>
+ </data>
+ <metadata name="mgThemeComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>903, 173</value>
+ </metadata>
+ <data name="mgThemeComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+</value>
+ </data>
+ <data name="toolStripMenuItem12.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+</value>
+ </data>
<metadata name="appToolbar.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>121, 17</value>
</metadata>
@@ -639,16 +639,16 @@
<data name="toolStripButton13.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAIXSURBVDhPnZNbaxNREMf3i9TUW0WbeosPQi/RJBoSGiWg
- 21LZmocYRCGp2iqUXqBFfPFN8EWEfgNBKT6IIEisUFFffOimaJrEaLXdTZNNNsle/p45EOglKdKBYc45
- O/M7c/7DCsImuzFyNxEMh1PHuk7a7fsP4ajzhE17Ot+c13Tdf0WUPf4g5l7O4/1SCsnl7zzOvZpHt9uD
- YFhMtYRcuirK12/ewuKPND5ncvjC/NNKFovpDJb/rKGo63j67Dkobwfk9tiDhC/Qj6+ZLL7lf2G1WIJW
- q/F1el1B3TRx+sxZHvs8PlD+FshlcUh+8eYtln6vIqeqsGwbG5UK8oUNGJbFi8nJTAZRFMXaAnAeP2XL
- rHiF3VY1DNgM8FMtQK/XeeE+x4Gm3tHR+ZiDHO0HkVVUfiMVr2tlDljTNJjbOqDvOtOD6gjMIE8EJxtZ
- nhX8LWm8mCLpQF6o6PxJ1AnFHOtyZvah3XgCQQTxmiS/S36AWq40da1ag2FaoPiaaUX5DUBbm6MojI9P
- xnt6z6HEWisz9Vt5kQnb3eMG5TcAh490PuLrwcHh1L3R+6gy4Uj57U7n8cQdSMMReH0XuQY7TJIk+bzn
- AhYWPsJg0yCjmGTP6+1zY2BgCKFQCLFYrDVkcno6TqAuNlqaDkXa0znd7HK5EAgEEI1GW0N2+2kaEL/f
- j0hkl+f8D8Tr9e6tC4JTJ+QTE1P4B0Dj4GE2TdATAAAAAElFTkSuQmCC
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAIXSURBVDhPnZNbaxNREMf3i/Si1oo29RYfhF6iSTQkNErA
+ bktlax5iEIXE1huU1qIUfPFN8EWEfgNBKT6IIJRYoaX64kM3RdMkRqvdbppsskn28vfMgUAvSREHhjnn
+ 7MzvzPkPKwjb7Prt8XggFEoe6z5ptx/owFHHCZv2dL49r+F64Ioou30BzL6ew/xKEonVbzzOvplDj8uN
+ QEhMNoVcGhTlazduYvF7CsvpLD4zX1rLYDGVxurvDRR0Hc9fvATl7YHcuvcg7vUP4Es6g6+5n1gvFKFV
+ q3ydUjZRM02cPnOWx363F5S/A3JZHJFfvXuPlV/ryKoqLNvGVrmMXH4LhmXxYnIyk0EURbF2ABzHT9ky
+ K15jt1UMAzYD/FDz0Gs1XtjadrChd3Z2PeWgtvZDyGyq/EYqVrQSB2xoGsxdHdB3nelBdQRmkGeCg40s
+ xwr+FDVeTJF0IM+Xdf4k6oRilnX56PGMXX8CQQTxqiR/SHyEWio3dK1ShWFaoPiWaUX5dUBLS2tBmJiY
+ ivX2nUORtVZi6jfzAhO2p9cFyq8DDh/pesLXw8OjyTt376PChCPldzudx+JjkEbD8Hgvcg32mCRJ8nn3
+ BSwsfILBpkFGMcGe19fvwtDQCILBIKLRaHPI1PR0jEDdbLQ0HYq0p3O62el0wu/3IxKJNIfs99PUIT6f
+ D+HwPs/5F4jH4/m/LghOnZBPTj7EXzBH4FruleOnAAAAAElFTkSuQmCC
</value>
</data>
<metadata name="mgZoomPreviousComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
@@ -657,29 +657,29 @@
<data name="mgZoomPreviousComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
</value>
</data>
<data name="toolStripButton14.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAGQSURBVDhPrVPLTsJQEOUvjN/BAhIeG8WvkMQEUSI/ADsN
- eyVGKHwDW125YGEiJBiiqxI1UXxWHgXT522L48yVJjVQcOEkJ522c86cmd4GAp6IRqMFxCviawrKC96a
- uXksFlsNh8Nv25mMet5smjfdJ7h+eISzep1tbu1q9I5qfIWoa1Go6LcfPSB0hzLc9/o877xLcHhUNKjG
- FYjH44DY4fdkMZVK6XeShMQhGJYFFH1FAWbbHCY+EzudSa1WOyXOVOBHhOzVGw32LI/AxGIKy3GAIYrl
- MhUtBDmAF1mGgapyso3EHnY/FoSlZBLnAtJoDENVA5Uxfh0oKieXKlWwJxMOy3ZAFEWYGYGWc9lqsU9d
- By9IwEGi++wCx3QX+WuJkUjkYC+b1RTDAA0dzMMYx9tMJi3fM0GLFKpVQ0EXtDwvVBQ+KZX4SOuJDT7C
- TIRCoRWyl06n9at2mxmmCQTKk9jZ/RK5XM5fhFRpnHlHmToHg0HuYqmI33H9d5F8Pr94nL848V3qst+X
- iIS1RGL/G4UHqnEre6t4AAAAAElFTkSuQmCC
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAGSSURBVDhPrVPLTsJQEOUvjN/BAhIeG8WfgMQFjRL5Adhp
+ 2AsxAvUb2OrKBYmJhGBIdGONmig+K4+CaWl72+I4c6VJDRRcOMlJp+2cM2emt4GAJ6LRaAHxiviagvKC
+ t2ZuHovFVsPh8JuQyWinzaZ51XmCy4dHOKnXWXJze0zvqMZXiLqWqqJ++9EFQmegwH23x/Obdxn2i0WD
+ alyBeDwOiC1+TxbT6bR+J8tIHIBhWUDRU1Vgts1h4rNrSZrUarVj4kwFfkTIXr3RYM/KEEwsprAcBxii
+ VKlQ0UKQA3hRFOhrGifbSOxi94NqdSmZxLmAPBzBQBuDxhi/9lWNk8viEdiTCYdlOyBJEsyMQMs5b7XY
+ p66DFyTgINF9doZjuov8tcRIJLK3k82OVcOAMTqYhxGOl0ylLN8zQYusiKKhogtanhcaCh+Wy3yk9cQG
+ H2EmQqHQCtkTBEG/aLeZYZpAoDyFnd0vkcvl/EVIlcaZd5SpczAY5C6Wivgd138Xyefzi8f5ixPfpS77
+ fYlIWEskdr8BQbKqUTrNYS4AAAAASUVORK5CYII=
</value>
</data>
<metadata name="mgZoomNextComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
@@ -688,14 +688,14 @@
<data name="mgZoomNextComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
</value>
</data>
<data name="toolStripButton6.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -815,9 +815,6 @@
AABJRU5ErkJggg==
</value>
</data>
- <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>600, 173</value>
- </metadata>
<data name="toolStripMenuItem9.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -864,7 +861,7 @@
<data name="toolStripMenuItem31.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -963,6 +960,9 @@
RU5ErkJggg==
</value>
</data>
+ <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>600, 173</value>
+ </metadata>
<data name="toolStripMenuItem5.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
More information about the mapguide-commits
