[mapguide-commits] r6901 - in branches/2.4/MgDev/Desktop: MgDesktop/Services UnitTest
svn_mapguide at osgeo.org
Sun Jul 15 07:44:19 PDT 2012
Author: jng
Date: 2012-07-15 07:44:18 -0700 (Sun, 15 Jul 2012)
New Revision: 6901
branches/2.4/MgDev/Desktop/MgDesktop/Services/FeatureService.cpp
branches/2.4/MgDev/Desktop/MgDesktop/Services/FeatureService.h
branches/2.4/MgDev/Desktop/UnitTest/TestFeatureService.cpp
branches/2.4/MgDev/Desktop/UnitTest/TestFeatureService.h
branches/2.4/MgDev/Desktop/UnitTest/main.cpp
#2074: Partition off existing select aggregate functionality into a private SelectAggregateNormal method. Add a stub SelectAggregateJoined method which is called if the class is an extended one.
Modified: branches/2.4/MgDev/Desktop/MgDesktop/Services/FeatureService.cpp
--- branches/2.4/MgDev/Desktop/MgDesktop/Services/FeatureService.cpp 2012-07-15 11:25:45 UTC (rev 6900)
+++ branches/2.4/MgDev/Desktop/MgDesktop/Services/FeatureService.cpp 2012-07-15 14:44:18 UTC (rev 6901)
@@ -3757,151 +3757,180 @@
throw new MgInvalidArgumentException(L"MgdFeatureService::SelectAggregate", __LINE__, __WFILE__, NULL, L"", NULL);
Ptr<MgFeatureConnection> connWrap = new MgFeatureConnection(resource);
+ bool bFeatureJoin = FindFeatureJoinProperties(resource, className);
+ if (bFeatureJoin)
+ reader = SelectAggregateJoined(connWrap, className, options);
+ else
+ reader = SelectAggregateNormal(connWrap, className, options);
+ // Successful operation
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Success.c_str());
+ MG_FEATURE_SERVICE_CHECK_CONNECTION_CATCH(resource, L"MgdFeatureService::SelectAggregate")
+ if (mgException != NULL)
- FdoPtr<FdoIConnection> conn = connWrap->GetConnection();
+ // Failed operation
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Failure.c_str());
+ MG_DESKTOP_LOG_EXCEPTION();
- FdoPtr<FdoISelectAggregates> select = (FdoISelectAggregates*)conn->CreateCommand(FdoCommandType_SelectAggregates);
- select->SetFeatureClassName(className.c_str());
+ // Add access log entry for operation
+ MG_LOG_OPERATION_MESSAGE_ACCESS_ENTRY();
- STRING filter = options->GetFilter();
- if (!filter.empty())
- select->SetFilter(filter.c_str());
+ MG_FEATURE_SERVICE_THROW()
- Ptr<MgStringCollection> props = options->GetClassProperties();
- Ptr<MgStringPropertyCollection> computed = options->GetComputedProperties();
+ return reader.Detach();
- INT32 propCount = props->GetCount();
- INT32 compCount = computed->GetCount();
- bool bCustomPropertyFound = false;
- FdoFunction* customFunc = NULL;
- STRING customPropName;
+MgDataReader* MgdFeatureService::SelectAggregateNormal(MgFeatureConnection* connWrap, CREFSTRING className, MgFeatureAggregateOptions* options)
+ Ptr<MgDataReader> reader;
+ MG_FEATURE_SERVICE_TRY()
+ CHECKNULL(options, L"MgdFeatureService::SelectAggregateNormal");
+ CHECKNULL(connWrap, L"MgdFeatureService::SelectAggregateNormal");
+ FdoPtr<FdoIConnection> conn = connWrap->GetConnection();
- FdoPtr<FdoIdentifierCollection> fdoProps = select->GetPropertyNames();
- if (propCount > 0)
+ FdoPtr<FdoISelectAggregates> select = (FdoISelectAggregates*)conn->CreateCommand(FdoCommandType_SelectAggregates);
+ select->SetFeatureClassName(className.c_str());
+ STRING filter = options->GetFilter();
+ if (!filter.empty())
+ select->SetFilter(filter.c_str());
+ Ptr<MgStringCollection> props = options->GetClassProperties();
+ Ptr<MgStringPropertyCollection> computed = options->GetComputedProperties();
+ INT32 propCount = props->GetCount();
+ INT32 compCount = computed->GetCount();
+ bool bCustomPropertyFound = false;
+ FdoFunction* customFunc = NULL;
+ STRING customPropName;
+ FdoPtr<FdoIdentifierCollection> fdoProps = select->GetPropertyNames();
+ if (propCount > 0)
+ for (INT32 i = 0; i < propCount; i++)
- for (INT32 i = 0; i < propCount; i++)
- FdoPtr<FdoIdentifier> name = FdoIdentifier::Create(props->GetItem(i).c_str());
- fdoProps->Add(name);
+ FdoPtr<FdoIdentifier> name = FdoIdentifier::Create(props->GetItem(i).c_str());
+ fdoProps->Add(name);
- if (compCount > 0)
+ if (compCount > 0)
+ for (INT32 i = 0; i < compCount; i++)
- for (INT32 i = 0; i < compCount; i++)
- Ptr<MgStringProperty> comp = computed->GetItem(i);
- STRING aliasName = comp->GetName();
- FdoPtr<FdoExpression> expr = FdoExpression::Parse(comp->GetValue().c_str());
- if (ContainsUdf(connWrap, expr))
- // If property is already found, two custom properties are not supported and therefore throw exception
- if (bCustomPropertyFound)
- STRING message = MgFeatureUtil::GetMessage(L"MgOnlyOnePropertyAllowed");
+ Ptr<MgStringProperty> comp = computed->GetItem(i);
+ STRING aliasName = comp->GetName();
+ FdoPtr<FdoExpression> expr = FdoExpression::Parse(comp->GetValue().c_str());
+ if (ContainsUdf(connWrap, expr))
+ // If property is already found, two custom properties are not supported and therefore throw exception
+ if (bCustomPropertyFound)
+ STRING message = MgFeatureUtil::GetMessage(L"MgOnlyOnePropertyAllowed");
- MgStringCollection arguments;
- arguments.Add(message);
- throw new MgFeatureServiceException(L"MgdFeatureService::SelectAggregate", __LINE__, __WFILE__, &arguments, L"", NULL);
+ MgStringCollection arguments;
+ arguments.Add(message);
+ throw new MgFeatureServiceException(L"MgdFeatureService::SelectAggregate", __LINE__, __WFILE__, &arguments, L"", NULL);
- // Downcast to FdoFunction
- FdoFunction* function = dynamic_cast<FdoFunction*>(expr.p);
+ // Downcast to FdoFunction
+ FdoFunction* function = dynamic_cast<FdoFunction*>(expr.p);
- if (function != NULL)
- FdoString* expName = aliasName.c_str();
- if (expName != NULL)
- FdoPtr<FdoExpressionCollection> exprCol = function->GetArguments();
- FdoInt32 cnt = exprCol->GetCount();
- FdoPtr<FdoExpression> expr;
- if (cnt > 0)
- expr = exprCol->GetItem(0); // Property Name
+ if (function != NULL)
+ FdoString* expName = aliasName.c_str();
+ if (expName != NULL)
+ FdoPtr<FdoExpressionCollection> exprCol = function->GetArguments();
+ FdoInt32 cnt = exprCol->GetCount();
+ FdoPtr<FdoExpression> expr;
+ if (cnt > 0)
+ expr = exprCol->GetItem(0); // Property Name
- // Just pass in the property name
- // FdoPtr<FdoComputedIdentifier> fdoIden = FdoComputedIdentifier::Create(expName, expr);
+ // Just pass in the property name
+ // FdoPtr<FdoComputedIdentifier> fdoIden = FdoComputedIdentifier::Create(expName, expr);
- // NOTE: Each provider has its own rule for supporting computed properties, select and select aggregate
- // functionality. Therefore we just work with simple select command, fetch the property and do the needed
- // calculations. Therefore, we are not adding them as computed properties.
+ // NOTE: Each provider has its own rule for supporting computed properties, select and select aggregate
+ // functionality. Therefore we just work with simple select command, fetch the property and do the needed
+ // calculations. Therefore, we are not adding them as computed properties.
- FdoIdentifier* propName = dynamic_cast<FdoIdentifier*>(expr.p);
+ FdoIdentifier* propName = dynamic_cast<FdoIdentifier*>(expr.p);
- if (propName != NULL)
- fdoProps->Add(propName);
+ if (propName != NULL)
+ fdoProps->Add(propName);
- customPropName = aliasName;
- bCustomPropertyFound = true;
- customFunc = FDO_SAFE_ADDREF(function);
- else
- FdoPtr<FdoComputedIdentifier> name = FdoComputedIdentifier::Create(comp->GetName().c_str(), expr);
+ customPropName = aliasName;
+ bCustomPropertyFound = true;
+ customFunc = FDO_SAFE_ADDREF(function);
+ else
+ FdoPtr<FdoComputedIdentifier> name = FdoComputedIdentifier::Create(comp->GetName().c_str(), expr);
- if (options->GetDistinct())
- select->SetDistinct(true);
+ if (options->GetDistinct())
+ select->SetDistinct(true);
- STRING groupFilter = options->GetGroupFilter();
- if (!groupFilter.empty())
+ STRING groupFilter = options->GetGroupFilter();
+ if (!groupFilter.empty())
+ FdoPtr<FdoFilter> grpFilter = FdoFilter::Parse(groupFilter.c_str());
+ select->SetGroupingFilter(grpFilter);
+ FdoPtr<FdoIdentifierCollection> fdoGroupBy = select->GetGrouping();
+ Ptr<MgStringCollection> mgGroupBy = options->GetGroupingProperties();
+ if (NULL != mgGroupBy && mgGroupBy->GetCount() > 0)
+ for (INT32 i = 0; i < mgGroupBy->GetCount(); i++)
- FdoPtr<FdoFilter> grpFilter = FdoFilter::Parse(groupFilter.c_str());
- select->SetGroupingFilter(grpFilter);
- FdoPtr<FdoIdentifierCollection> fdoGroupBy = select->GetGrouping();
- Ptr<MgStringCollection> mgGroupBy = options->GetGroupingProperties();
- if (NULL != mgGroupBy && mgGroupBy->GetCount() > 0)
- for (INT32 i = 0; i < mgGroupBy->GetCount(); i++)
- STRING name = mgGroupBy->GetItem(i);
- FdoPtr<FdoIdentifier> fdoId = FdoIdentifier::Create(name.c_str());
+ STRING name = mgGroupBy->GetItem(i);
+ FdoPtr<FdoIdentifier> fdoId = FdoIdentifier::Create(name.c_str());
- fdoGroupBy->Add(fdoId);
+ fdoGroupBy->Add(fdoId);
- FdoPtr<FdoIDataReader> fdoReader = select->Execute();
- Ptr<MgReader> origReader = new MgdDataReader(connWrap, fdoReader);
- Ptr<MgDataReader> customReader = dynamic_cast<MgDataReader*>(this->GetCustomReader(origReader, customFunc, customPropName));
- origReader->Close();
- reader = customReader;
- else
- reader = new MgdDataReader(connWrap, fdoReader);
+ FdoPtr<FdoIDataReader> fdoReader = select->Execute();
+ Ptr<MgReader> origReader = new MgdDataReader(connWrap, fdoReader);
+ Ptr<MgDataReader> customReader = dynamic_cast<MgDataReader*>(this->GetCustomReader(origReader, customFunc, customPropName));
+ origReader->Close();
+ reader = customReader;
+ else
+ reader = new MgdDataReader(connWrap, fdoReader);
- // Successful operation
- MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Success.c_str());
+ MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgdFeatureService::SelectAggregateNormal")
- MG_FEATURE_SERVICE_CHECK_CONNECTION_CATCH(resource, L"MgdFeatureService::SelectAggregate")
- if (mgException != NULL)
- // Failed operation
- MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Failure.c_str());
- MG_DESKTOP_LOG_EXCEPTION();
+MgDataReader* MgdFeatureService::SelectAggregateJoined(MgFeatureConnection* connWrap, CREFSTRING className, MgFeatureAggregateOptions* options)
- // Add access log entry for operation
- MG_LOG_OPERATION_MESSAGE_ACCESS_ENTRY();
- MG_FEATURE_SERVICE_THROW()
+ NOT_IMPLEMENTED(L"MgdFeatureService::SelectAggregateJoined");
- return reader.Detach();
+ MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgdFeatureService::SelectAggregateJoined")
// Convert reader into a custom MgDataReader
Modified: branches/2.4/MgDev/Desktop/MgDesktop/Services/FeatureService.h
--- branches/2.4/MgDev/Desktop/MgDesktop/Services/FeatureService.h 2012-07-15 11:25:45 UTC (rev 6900)
+++ branches/2.4/MgDev/Desktop/MgDesktop/Services/FeatureService.h 2012-07-15 14:44:18 UTC (rev 6901)
@@ -273,6 +273,14 @@
bool withLock,
bool asScrollable);
+ MgDataReader* SelectAggregateNormal(MgFeatureConnection* conn,
+ CREFSTRING className,
+ MgFeatureAggregateOptions* options);
+ MgDataReader* SelectAggregateJoined(MgFeatureConnection* conn,
bool ContainsUdf(MgFeatureConnection* conn, FdoExpression* expression);
bool IsCustomFunction(FdoFunction* fdoFunc);
MgReader* GetCustomReader(MgReader* reader, FdoFunction* customFunc, CREFSTRING propertyName);
Modified: branches/2.4/MgDev/Desktop/UnitTest/TestFeatureService.cpp
--- branches/2.4/MgDev/Desktop/UnitTest/TestFeatureService.cpp 2012-07-15 11:25:45 UTC (rev 6900)
+++ branches/2.4/MgDev/Desktop/UnitTest/TestFeatureService.cpp 2012-07-15 14:44:18 UTC (rev 6901)
@@ -1453,21 +1453,22 @@
throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_SelectAggregate", __LINE__, __WFILE__, NULL, L"", NULL);
Ptr<MgResourceIdentifier> resource = new MgResourceIdentifier();
STRING className = L"";
Ptr<MgFeatureAggregateOptions> options = new MgFeatureAggregateOptions();
- CPPUNIT_ASSERT_THROW_MG(pService->SelectAggregate(resource, className, options), MgInvalidRepositoryTypeException*);
+ CPPUNIT_ASSERT_THROW_MG(reader = pService->SelectAggregate(resource, className, options), MgInvalidRepositoryTypeException*);
resource = new MgResourceIdentifier(L"Library://UnitTests/Data/Sheboygan_Parcels.MapDefinition");
- CPPUNIT_ASSERT_THROW_MG(pService->SelectAggregate(resource, className, options), MgInvalidResourceTypeException*);
+ CPPUNIT_ASSERT_THROW_MG(reader = pService->SelectAggregate(resource, className, options), MgInvalidResourceTypeException*);
resource = new MgResourceIdentifier(L"Library://UnitTests/Data/Sheboygan_Parcels.FeatureSource");
- CPPUNIT_ASSERT_THROW_MG(pService->SelectAggregate(resource, className, options), MgInvalidArgumentException*);
+ CPPUNIT_ASSERT_THROW_MG(reader = pService->SelectAggregate(resource, className, options), MgInvalidArgumentException*);
className = L"Parcels";
options->SetFilter(L"Autogenerated_SDF_ID = 1");
- Ptr<MgDataReader> reader = pService->SelectAggregate(resource, className, options);
+ reader = pService->SelectAggregate(resource, className, options);
bool bResult = reader->ReadNext();
reader->Close();
CPPUNIT_ASSERT(bResult);
@@ -2739,6 +2740,14 @@
Ptr<MgClassDefinition> clsDef = pService->GetClassDefinition(lFeatureSource, L"SHP_Schema", L"Ext1");
CPPUNIT_ASSERT(NULL != clsDef.p);
+ //Custom aggregates should also work
+ Ptr<MgFeatureAggregateOptions> agg = new MgFeatureAggregateOptions();
+ agg->AddComputedProperty(L"EXTENT", L"EXTENTS(SHPGEOM)");
+ Ptr<MgDataReader> dr = pService->SelectAggregate(lFeatureSource, L"Ext1", agg);
+ bool bRead = dr->ReadNext();
+ dr->Close();
+ CPPUNIT_ASSERT(bRead);
catch(MgException* e)
@@ -3611,6 +3620,114 @@
+void TestFeatureService::TestCase_BenchmarkSqliteAggregateJoin()
+ try
+ Ptr<MgServiceFactory> fact = new MgServiceFactory();
+ Ptr<MgResourceService> pService = dynamic_cast<MgResourceService*>(fact->CreateService(MgServiceType::ResourceService));
+ if (pService == 0)
+ throw new MgServiceNotAvailableException(L"TestFeatureService::TestCase_BenchmarkSqliteAggregateJoin",
+ __LINE__, __WFILE__, NULL, L"", NULL);
+ Ptr<MgFeatureService> featSvc = dynamic_cast<MgFeatureService*>(fact->CreateService(MgServiceType::FeatureService));
+ if (featSvc == 0)
+ Ptr<MgResourceIdentifier> fsId = new MgResourceIdentifier(L"Library://UnitTests/Data/ParcelsJoinTestSQLite.FeatureSource");
+ CPPUNIT_ASSERT(featSvc->TestConnection(fsId));
+ // ----- Start the tests ------- //
+ Ptr<MgFeatureAggregateOptions> aggOpts = new MgFeatureAggregateOptions();
+ aggOpts->AddComputedProperty(L"Extents", L"SpatialExtents(Geometry)");
+ aggOpts->AddComputedProperty(L"TotalCount", L"Count(SdfId)");
+ ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteAggregateJoin() - Inner Join \n")));
+ long lStart = GetTickCount();
+ long total = 0L;
+ int iterations = 0;
+ reader = featSvc->SelectAggregate(fsId, L"ParcelsInner", aggOpts);
+ while(reader->ReadNext())
+ Ptr<MgByteReader> br = reader->GetGeometry(L"Extents");
+ total = reader->GetInt64(L"TotalCount");
+ iterations++;
+ reader->Close();
+ CPPUNIT_ASSERT(iterations == 1);
+ ACE_DEBUG((LM_INFO, ACE_TEXT(" Execution Time (%d results): = %6.4f (s)\n"), total, ((GetTickCount()-lStart)/1000.0) ));
+ ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteAggregateJoin() - Left Outer Join \n")));
+ lStart = GetTickCount();
+ iterations = 0L;
+ reader = featSvc->SelectAggregate(fsId, L"ParcelsLeftOuter", aggOpts);
+ iterations++;
+ reader->Close();
+ CPPUNIT_ASSERT(iterations == 1L);
+ ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteAggregateJoin() - Inner Join (Forced 1:1) \n")));
+ iterations = 0L;
+ reader = featSvc->SelectAggregate(fsId, L"ParcelsInnerOneToOne", aggOpts);
+ iterations++;
+ reader->Close();
+ ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteAggregateJoin() - Left Outer Join (Forced 1:1) \n")));
+ iterations = 0L;
+ reader = featSvc->SelectAggregate(fsId, L"ParcelsLeftOuterOneToOne", aggOpts);
+ iterations++;
+ reader->Close();
+ catch(MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch(FdoException* e)
+ STRING message = L"FdoException occurred: ";
+ message += e->GetExceptionMessage();
+ FDO_SAFE_RELEASE(e);
+ catch(...)
+ throw;
void TestFeatureService::TestCase_BenchmarkMergeSortJoin()
try
Modified: branches/2.4/MgDev/Desktop/UnitTest/TestFeatureService.h
--- branches/2.4/MgDev/Desktop/UnitTest/TestFeatureService.h 2012-07-15 11:25:45 UTC (rev 6900)
+++ branches/2.4/MgDev/Desktop/UnitTest/TestFeatureService.h 2012-07-15 14:44:18 UTC (rev 6901)
@@ -68,6 +68,7 @@
CPPUNIT_TEST(TestCase_LayerSelectScrollable);
CPPUNIT_TEST(TestCase_BenchmarkSqliteJoin);
+ CPPUNIT_TEST(TestCase_BenchmarkSqliteAggregateJoin);
CPPUNIT_TEST(TestCase_BenchmarkSdfJoin);
CPPUNIT_TEST(TestCase_BenchmarkMergeSortJoin);
CPPUNIT_TEST(TestCase_BenchmarkBatchSortedBlockJoin);
@@ -120,6 +121,7 @@
void TestCase_BenchmarkSdfJoin();
void TestCase_BenchmarkSqliteJoin();
+ void TestCase_BenchmarkSqliteAggregateJoin();
void TestCase_BenchmarkMergeSortJoin();
void TestCase_BenchmarkBatchSortedBlockJoin();
void TestCase_BenchmarkNestedLoopsSortedBlockJoin();
Modified: branches/2.4/MgDev/Desktop/UnitTest/main.cpp
--- branches/2.4/MgDev/Desktop/UnitTest/main.cpp 2012-07-15 11:25:45 UTC (rev 6900)
+++ branches/2.4/MgDev/Desktop/UnitTest/main.cpp 2012-07-15 14:44:18 UTC (rev 6901)
@@ -25,13 +25,13 @@
#define TEST_COORDINATE_SYSTEM 0
-#define TEST_LOG_MANAGER 1
-#define TEST_RESOURCE_SERVICE 1
+#define TEST_LOG_MANAGER 0
+#define TEST_RESOURCE_SERVICE 0
#define TEST_FEATURE_SERVICE 1
-#define TEST_MAPPING_SERVICE 1
-#define TEST_PROFILING_SERVICE 1
-#define TEST_RENDERING_SERVICE 1
-#define TEST_TILE_SERVICE 1
+#define TEST_MAPPING_SERVICE 0
+#define TEST_PROFILING_SERVICE 0
+#define TEST_RENDERING_SERVICE 0
+#define TEST_TILE_SERVICE 0
int main(int argc, char** argv)
More information about the mapguide-commits
