[mapguide-commits] r6907 - in branches/2.4/MgDev/Desktop: MgAppLayout MgDesktop MgDesktop/Services MgDesktop/Services/Feature MgDesktop/System UnitTest
svn_mapguide at osgeo.org
Tue Jul 17 10:54:48 PDT 2012
Author: jng
Date: 2012-07-17 10:54:48 -0700 (Tue, 17 Jul 2012)
New Revision: 6907
branches/2.4/MgDev/Desktop/MgAppLayout/Program.cs
branches/2.4/MgDev/Desktop/MgDesktop/MgDesktop.vcproj
branches/2.4/MgDev/Desktop/MgDesktop/Services/Feature/FdoConnectionPool.cpp
branches/2.4/MgDev/Desktop/MgDesktop/Services/Feature/FdoConnectionPool.h
branches/2.4/MgDev/Desktop/MgDesktop/Services/Feature/FeatureConnection.cpp
branches/2.4/MgDev/Desktop/MgDesktop/Services/FeatureService.cpp
branches/2.4/MgDev/Desktop/MgDesktop/System/PlatformInit.cpp
branches/2.4/MgDev/Desktop/UnitTest/TestProfilingService.cpp
branches/2.4/MgDev/Desktop/UnitTest/main.cpp
mg-desktop: fixes for debug mode
Modified: branches/2.4/MgDev/Desktop/MgAppLayout/Program.cs
--- branches/2.4/MgDev/Desktop/MgAppLayout/Program.cs 2012-07-16 03:09:00 UTC (rev 6906)
+++ branches/2.4/MgDev/Desktop/MgAppLayout/Program.cs 2012-07-17 17:54:48 UTC (rev 6907)
@@ -65,11 +65,12 @@
((Shell)frm).Initialize(layout, provider);
Application.ApplicationExit += new EventHandler(OnAppExit);
Application.Run((Shell)frm);
+ MgPlatform.Terminate();
static void OnAppExit(object sender, EventArgs e)
- MgPlatform.Terminate();
static void Application_ThreadException(object sender, System.Threading.ThreadExceptionEventArgs e)
Modified: branches/2.4/MgDev/Desktop/MgDesktop/MgDesktop.vcproj
--- branches/2.4/MgDev/Desktop/MgDesktop/MgDesktop.vcproj 2012-07-16 03:09:00 UTC (rev 6906)
+++ branches/2.4/MgDev/Desktop/MgDesktop/MgDesktop.vcproj 2012-07-17 17:54:48 UTC (rev 6907)
@@ -66,7 +66,7 @@
<Tool
Name="VCLinkerTool"
- AdditionalDependencies="FDO.lib FDOCommon.lib FDOGeometry.lib ExpressionEngine.lib ACEd.lib MgFoundationd.lib MgGeometryd.lib MgMdfModeld.lib MgMdfParserd.lib MgPlatformBased.lib MgRenderersd.lib MgStylizationd.lib MgGwsCommond.lib MgGwsQueryEngined.lib xerces-c_3mgD.lib dwfcore_wt.1.1.1.lib dwftk_wt.7.1.1.lib whiptk_wt.7.7.601.lib MgSecurity.lib"
+ AdditionalDependencies="FDO.lib FDOCommon.lib FDOGeometry.lib ExpressionEngine.lib ACEd.lib MgFoundationd.lib MgGeometryd.lib MgMdfModeld.lib MgMdfParserd.lib MgPlatformBased.lib MgRenderersd.lib MgStylizationd.lib MgGwsCommond.lib MgGwsQueryEngined.lib xerces-c_3mgD.lib dwfcore_wt.1.1.1.lib dwftk_wt.7.1.1.lib whiptk_wt.7.7.601.lib MgSecurityd.lib"
ShowProgress="0"
OutputFile="$(OutDir)\MgDesktopd.dll"
LinkIncremental="1"
Modified: branches/2.4/MgDev/Desktop/MgDesktop/Services/Feature/FdoConnectionPool.cpp
--- branches/2.4/MgDev/Desktop/MgDesktop/Services/Feature/FdoConnectionPool.cpp 2012-07-16 03:09:00 UTC (rev 6906)
+++ branches/2.4/MgDev/Desktop/MgDesktop/Services/Feature/FdoConnectionPool.cpp 2012-07-17 17:54:48 UTC (rev 6907)
@@ -3,6 +3,9 @@
#include "FdoConnectionPool.h"
#include "FdoConnectionUtil.h"
+INT64 MgFdoConnectionPool::sm_nConnectionsRequested = 0L;
+INT64 MgFdoConnectionPool::sm_nConnectionsReturned = 0L;
//connection pool record -- contains database pointer
//plus extra timing information/status
struct PoolRec
@@ -100,6 +103,8 @@
MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgFdoConnectionPool::GetConnection")
+ sm_nConnectionsRequested++;
return conn.Detach();
@@ -110,8 +115,11 @@
ScopedLock scc(g_pool.mutex);
STRING providerName = conn->GetProviderName();
FdoPtr<FdoIConnection> fdoConn = conn->GetConnection();
+ STRING fsIdStr;
Ptr<MgResourceIdentifier> fsId = conn->GetFeatureSource();
- STRING fsIdStr = fsId->ToString();
+ if (NULL != fsId.p)
+ fsIdStr = fsId->ToString();
bool bReturned = false;
bool bProviderExcluded = false;
@@ -153,10 +161,15 @@
logDetail.Create();
MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgFdoConnectionPool::ReturnConnection")
+ sm_nConnectionsReturned++;
void MgFdoConnectionPool::Initialize(MgConfiguration* pConfiguration)
+ sm_nConnectionsRequested = 0L;
+ sm_nConnectionsReturned = 0L;
MG_FEATURE_SERVICE_TRY()
bool bDataConnectionPoolEnabled = MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolEnabled;
@@ -210,9 +223,17 @@
- MG_LOG_TRACE_ENTRY(L"MgFdoConnectionPool::Cleanup()");
+ ScopedLock scc(g_pool.mutex);
- ScopedLock scc(g_pool.mutex);
+ MgLogDetail logDetail(MgServiceType::FeatureService, MgLogDetail::InternalTrace, L"MgFdoConnectionPool::Cleanup", mgStackParams);
+ logDetail.AddInt64(L"ConnectionsRequested", sm_nConnectionsRequested);
+ logDetail.AddInt64(L"ConnectionsReturned", sm_nConnectionsReturned);
+ logDetail.Create();
+ if (sm_nConnectionsRequested != sm_nConnectionsReturned)
+ ACE_DEBUG((LM_INFO, ACE_TEXT("[WARNING] %d connections have leaked for this session (ie. not returned)\n"), (sm_nConnectionsRequested - sm_nConnectionsReturned)));
for (ConnPool::iterator it = g_pool.freePool.begin(); it != g_pool.freePool.end(); ++it)
Modified: branches/2.4/MgDev/Desktop/MgDesktop/Services/Feature/FdoConnectionPool.h
--- branches/2.4/MgDev/Desktop/MgDesktop/Services/Feature/FdoConnectionPool.h 2012-07-16 03:09:00 UTC (rev 6906)
+++ branches/2.4/MgDev/Desktop/MgDesktop/Services/Feature/FdoConnectionPool.h 2012-07-17 17:54:48 UTC (rev 6907)
@@ -36,6 +36,8 @@
static void GetCacheInfo(std::vector<PoolCacheEntry*>& entries); //Caller responsible for cleanup of contents
private:
+ static INT64 sm_nConnectionsRequested;
+ static INT64 sm_nConnectionsReturned;
static bool StringStartsWith(CREFSTRING haystack, CREFSTRING needle);
Modified: branches/2.4/MgDev/Desktop/MgDesktop/Services/Feature/FeatureConnection.cpp
--- branches/2.4/MgDev/Desktop/MgDesktop/Services/Feature/FeatureConnection.cpp 2012-07-16 03:09:00 UTC (rev 6906)
+++ branches/2.4/MgDev/Desktop/MgDesktop/Services/Feature/FeatureConnection.cpp 2012-07-17 17:54:48 UTC (rev 6907)
@@ -68,13 +68,7 @@
#ifdef DEBUG_FDO_CONNECTION_POOL
ACE_DEBUG((LM_INFO, ACE_TEXT("MgFeatureConnection::Close()\n")));
#endif
- //Ones initialized with a resource id are poolable and thus must be
- //returned
- if (m_bIsCreatedFromFeatureSource)
- MgFdoConnectionPool::ReturnConnection(this);
- else
- m_fdoConn->Close();
+ MgFdoConnectionPool::ReturnConnection(this);
m_fdoConn = NULL;
Modified: branches/2.4/MgDev/Desktop/MgDesktop/Services/FeatureService.cpp
--- branches/2.4/MgDev/Desktop/MgDesktop/Services/FeatureService.cpp 2012-07-16 03:09:00 UTC (rev 6906)
+++ branches/2.4/MgDev/Desktop/MgDesktop/Services/FeatureService.cpp 2012-07-17 17:54:48 UTC (rev 6907)
@@ -159,6 +159,8 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::TestConnection");
MG_LOG_OPERATION_MESSAGE_INIT(MG_API_VERSION(1, 0, 0), 1);
MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
MG_LOG_OPERATION_MESSAGE_ADD_STRING((NULL == resource) ? L"MgResourceIdentifier" : resource->ToString().c_str());
@@ -166,8 +168,6 @@
MG_LOG_TRACE_ENTRY(L"MgdFeatureService::TestConnection()");
- CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::TestConnection");
Ptr<MgFeatureConnection> conn = new MgFeatureConnection(resource);
ok = conn->IsConnectionOpen();
@@ -274,6 +274,9 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::ApplySchema");
+ CHECKARGUMENTNULL(schema, L"MgdFeatureService::ApplySchema");
MG_LOG_OPERATION_MESSAGE_INIT(MG_API_VERSION(1, 0, 0), 2);
@@ -283,9 +286,6 @@
MG_LOG_TRACE_ENTRY(L"MgdFeatureService::ApplySchema()");
- CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::ApplySchema");
- CHECKARGUMENTNULL(schema, L"MgdFeatureService::ApplySchema");
MgApplySchema apply;
apply.ApplySchema(resource, schema);
@@ -316,7 +316,9 @@
MG_LOG_OPERATION_MESSAGE(L"DescribeSchema");
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::DescribeSchema");
MG_LOG_OPERATION_MESSAGE_INIT(MG_API_VERSION(1, 0, 0), 3);
@@ -423,6 +425,8 @@
@@ -464,6 +468,8 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::DescribeSchemaAsXml");
@@ -475,8 +481,6 @@
MG_LOG_TRACE_ENTRY(L"MgdFeatureService::DescribeSchemaAsXml()");
- CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::DescribeSchemaAsXml");
MgDescribeSchema describe;
describe.DescribeSchemaAsXml(resource, schemaName, classNames);
@@ -508,6 +512,8 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService:DescribeSchemaAsXml");
@@ -626,6 +632,8 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::SelectFeatures");
@@ -675,6 +683,8 @@
MG_LOG_OPERATION_MESSAGE_INIT(MG_API_VERSION(1, 0, 0), 4);
@@ -771,6 +781,8 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::SelectFeatureExtended");
@@ -821,6 +833,9 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::SelectAggregate");
+ CHECKARGUMENTNULL(options, L"MgdFeatureService::SelectAggregate");
@@ -836,9 +851,6 @@
logDetail.AddObject(L"Options", options);
logDetail.Create();
- CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::SelectAggregate");
- CHECKARGUMENTNULL(options, L"MgdFeatureService::SelectAggregate");
MgSelectFeatures select;
reader = dynamic_cast<MgDataReader*>(select.SelectFeatures(resource, className, options, true));
CHECKNULL(reader.p, L"MgdFeatureService::SelectAggregate");
@@ -872,6 +884,9 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::UpdateFeatures");
+ CHECKARGUMENTNULL(commands, L"MgdFeatureService::UpdateFeatures");
@@ -883,9 +898,6 @@
MG_LOG_TRACE_ENTRY(L"MgdFeatureService::UpdateFeatures()");
- CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::UpdateFeatures");
- CHECKARGUMENTNULL(commands, L"MgdFeatureService::UpdateFeatures");
MgUpdateFeaturesCommand cmd;
result = cmd.Execute(resource, commands, useTransaction);
@@ -918,6 +930,8 @@
@@ -962,6 +976,8 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::InsertFeatures");
@@ -1003,6 +1019,8 @@
@@ -1046,6 +1064,8 @@
@@ -1086,6 +1106,8 @@
@@ -1128,6 +1150,8 @@
@@ -1169,6 +1193,8 @@
MG_LOG_OPERATION_MESSAGE_INIT(MG_API_VERSION(1, 0, 0), 5);
@@ -1214,6 +1240,8 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::DeleteFeatures");
@@ -1254,6 +1282,8 @@
@@ -1296,6 +1326,8 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::PurgeCache");
@@ -1334,6 +1366,8 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::GetLockedFeatures");
@@ -1376,6 +1410,8 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::BeginTransaction");
@@ -1383,8 +1419,6 @@
MG_LOG_TRACE_ENTRY(L"MgdFeatureService::BeginTransaction()");
- CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::BeginTransaction");
trans = new MgdTransaction(conn, resource);
@@ -1415,6 +1449,10 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::ExecuteSqlQuery");
+ if (sqlStatement.empty())
+ throw new MgInvalidArgumentException(L"MgdFeatureService::ExecuteSqlQuery", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -1424,10 +1462,6 @@
MG_LOG_TRACE_ENTRY(L"MgdFeatureService::ExecuteSqlQuery()");
- CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::ExecuteSqlQuery");
- if (sqlStatement.empty())
- throw new MgInvalidArgumentException(L"MgdFeatureService::ExecuteSqlQuery", __LINE__, __WFILE__, NULL, L"", NULL);
MgSqlCommand cmd;
reader = cmd.ExecuteQuery(resource, sqlStatement, NULL, NULL);
@@ -1461,6 +1495,8 @@
@@ -1529,6 +1565,10 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::ExecuteSqlNonQuery");
+ if (sqlNonSelectStatement.empty())
+ throw new MgInvalidArgumentException(L"MgdFeatureService::ExecuteSqlNonQuery", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -1542,10 +1582,6 @@
MG_LOG_TRACE_ENTRY(L"MgdFeatureService::ExecuteSqlNonQuery()");
- CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::ExecuteSqlNonQuery");
- if (sqlNonSelectStatement.empty())
- throw new MgInvalidArgumentException(L"MgdFeatureService::ExecuteSqlNonQuery", __LINE__, __WFILE__, NULL, L"", NULL);
CHECKARGUMENTNULL(params, L"MgdFeatureService::ExecuteSqlQuery");
CHECKARGUMENTNULL(trans, L"MgdFeatureService::ExecuteSqlQuery");
@@ -1579,6 +1615,10 @@
@@ -1588,10 +1628,6 @@
MgSqlCommand cmd;
ret = cmd.ExecuteNonQuery(resource, sqlNonSelectStatement, NULL, NULL);
@@ -1622,6 +1658,8 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resId, L"MgdResourceService::GetSpatialContext");
MG_LOG_OPERATION_MESSAGE_ADD_STRING((NULL == resId) ? L"MgResourceIdentifier" : resId->ToString().c_str());
@@ -1666,6 +1704,8 @@
MG_LOG_OPERATION_MESSAGE(L"GetLongTransactions");
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::GetLongTransactions");
@@ -1674,8 +1714,6 @@
MG_LOG_OPERATION_MESSAGE_ADD_BOOL(bActiveOnly);
MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
- CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::GetLongTransactions");
MgGetLongTransactions getTrans;
reader = getTrans.GetLongTransactions(resource, bActiveOnly);
@@ -1706,6 +1744,10 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::SetLongTransaction");
+ if (longTransactionName.empty())
+ throw new MgNullArgumentException(L"MgdFeatureService::SetLongTransaction", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -1713,10 +1755,6 @@
MG_LOG_OPERATION_MESSAGE_ADD_STRING(longTransactionName.c_str());
- CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::SetLongTransaction");
- if (longTransactionName.empty())
- throw new MgNullArgumentException(L"MgdFeatureService::SetLongTransaction", __LINE__, __WFILE__, NULL, L"", NULL);
Ptr<MgFeatureConnection> connWrap = new MgFeatureConnection(resource);
FdoPtr<FdoIConnection> conn = connWrap->GetConnection();
FdoPtr<FdoIActivateLongTransaction> activate = (FdoIActivateLongTransaction*)conn->CreateCommand(FdoCommandType_ActivateLongTransaction);
@@ -1751,13 +1789,13 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::GetSchemas");
- CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::GetSchemas");
schemaNames = describe.GetSchemas(resource);
@@ -1787,6 +1825,8 @@
MG_LOG_OPERATION_MESSAGE(L"GetClasses");
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::GetClasses");
@@ -1795,8 +1835,6 @@
MG_LOG_OPERATION_MESSAGE_ADD_STRING(schemaName.c_str());
- CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::GetClasses");
classNames = describe.GetClasses(resource, schemaName);
@@ -1829,6 +1867,8 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::GetClassDefinition");
@@ -1898,6 +1938,9 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::CreateFeatureSource");
+ CHECKARGUMENTNULL(sourceParams, L"MgdFeatureService::CreateFeatureSource");
@@ -1905,9 +1948,6 @@
MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"MgFeatureSourceParams");
- CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::CreateFeatureSource");
- CHECKARGUMENTNULL(sourceParams, L"MgdFeatureService::CreateFeatureSource");
Ptr<MgCreateFeatureSource> creator = new MgCreateFeatureSource();
creator->CreateFeatureSource(resource, sourceParams);
@@ -2138,6 +2178,8 @@
+ CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::GetIdentityProperties");
@@ -2147,8 +2189,6 @@
MG_LOG_OPERATION_MESSAGE_ADD_STRING(className.c_str());
- CHECK_FEATURE_SOURCE_ARGUMENT(resource, L"MgdFeatureService::GetIdentityProperties");
Ptr<MgStringCollection> classNames = new MgStringCollection();
classNames->Add(className);
@@ -2191,6 +2231,8 @@
@@ -2200,8 +2242,6 @@
MG_LOG_OPERATION_MESSAGE_ADD_STRING((NULL == classNames) ? L"MgStringCollection" : classNames->GetLogString().c_str());
classDefs = describe.GetIdentityProperties(resource, schemaName, classNames);
Modified: branches/2.4/MgDev/Desktop/MgDesktop/System/PlatformInit.cpp
--- branches/2.4/MgDev/Desktop/MgDesktop/System/PlatformInit.cpp 2012-07-16 03:09:00 UTC (rev 6906)
+++ branches/2.4/MgDev/Desktop/MgDesktop/System/PlatformInit.cpp 2012-07-17 17:54:48 UTC (rev 6907)
@@ -174,16 +174,16 @@
MG_LOG_TRACE_ENTRY(L"MgPlatform::Terminate()");
MG_TRY()
- MgFdoConnectionPool::Cleanup();
+ //MgFdoConnectionPool::Cleanup();
+ //This is important. Otherwise the process using this library will be left lingering
+ MgLogManager* pLogManager = MgLogManager::GetInstance();
+ pLogManager->StopLogThread();
Ptr<MgServiceFactory> fact = new MgServiceFactory();;
Ptr<MgdResourceService> resSvc = dynamic_cast<MgdResourceService*>(fact->CreateService(MgServiceType::ResourceService));
resSvc->DeleteSessionFiles();
- //This is important. Otherwise the process using this library will be left lingering
- MgLogManager* pLogManager = MgLogManager::GetInstance();
- pLogManager->StopLogThread();
XMLPlatformUtils::Terminate();
ACE::fini();
Modified: branches/2.4/MgDev/Desktop/UnitTest/TestProfilingService.cpp
--- branches/2.4/MgDev/Desktop/UnitTest/TestProfilingService.cpp 2012-07-16 03:09:00 UTC (rev 6906)
+++ branches/2.4/MgDev/Desktop/UnitTest/TestProfilingService.cpp 2012-07-17 17:54:48 UTC (rev 6907)
@@ -391,14 +391,6 @@
m_svcResource->DeleteResource(mapres12);
Ptr<MgResourceIdentifier> wdfres1 = new MgResourceIdentifier(L"Library://UnitTests/Watermarks/PoweredByMapGuide.WatermarkDefinition");
m_svcResource->DeleteResource(wdfres1);
- #ifdef _DEBUG
- MgFdoConnectionManager* pFdoConnectionManager = MgFdoConnectionManager::GetInstance();
- if(pFdoConnectionManager)
- pFdoConnectionManager->ShowCache();
- #endif
catch(MgFileIoException* e)
Modified: branches/2.4/MgDev/Desktop/UnitTest/main.cpp
--- branches/2.4/MgDev/Desktop/UnitTest/main.cpp 2012-07-16 03:09:00 UTC (rev 6906)
+++ branches/2.4/MgDev/Desktop/UnitTest/main.cpp 2012-07-17 17:54:48 UTC (rev 6907)
@@ -27,7 +27,7 @@
#define TEST_COORDINATE_SYSTEM 0
#define TEST_LOG_MANAGER 1
#define TEST_RESOURCE_SERVICE 1
-#define TEST_FEATURE_SERVICE 1
+#define TEST_FEATURE_SERVICE 0
#define TEST_MAPPING_SERVICE 1
#define TEST_PROFILING_SERVICE 1
#define TEST_RENDERING_SERVICE 1
More information about the mapguide-commits
