[mapguide-commits] r6923 - trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics
svn_mapguide at osgeo.org
Tue Jul 31 04:39:51 PDT 2012
Author: jng
Date: 2012-07-31 04:39:50 -0700 (Tue, 31 Jul 2012)
New Revision: 6923
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs
#2085: Retain the alpha component of the applicable color in the template rule when generating the matching theme.
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs 2012-07-24 16:12:22 UTC (rev 6922)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs 2012-07-31 11:39:50 UTC (rev 6923)
@@ -767,10 +767,24 @@
IPointVectorStyle col = m_ruleCollection as IPointVectorStyle;
+ string fillAlpha = "";
IPointRule template = null;
if (chkUseFirstRuleAsTemplate.Checked && col.RuleCount > 0)
template = col.GetRuleAt(0);
+ var sym = template.PointSymbolization2D.Symbol;
+ if (sym.Type == PointSymbolType.Mark)
+ string htmlColor = ((IMarkSymbol)sym).Fill.ForegroundColor;
+ if (htmlColor.Length == 8)
+ fillAlpha = htmlColor.Substring(0, 2);
+ else if (sym.Type == PointSymbolType.Font)
+ string htmlColor = ((IFontSymbol)sym).ForegroundColor;
if (OverwriteRules.Checked)
@@ -784,11 +798,11 @@
var sym = r.PointSymbolization2D.Symbol;
- ((IMarkSymbol)sym).Fill.ForegroundColor = Utility.SerializeHTMLColor(entry.Color, true);
+ ((IMarkSymbol)sym).Fill.ForegroundColor = fillAlpha + Utility.SerializeHTMLColor(entry.Color, string.IsNullOrEmpty(fillAlpha));
- ((IFontSymbol)sym).ForegroundColor = Utility.SerializeHTMLColor(entry.Color, true);
+ ((IFontSymbol)sym).ForegroundColor = fillAlpha + Utility.SerializeHTMLColor(entry.Color, string.IsNullOrEmpty(fillAlpha));
col.AddRule(r);
@@ -797,10 +811,21 @@
ILineVectorStyle col = m_ruleCollection as ILineVectorStyle;
+ string bordAlpha = "";
ILineRule template = null;
+ //TODO: Composite lines? Which "alpha" value wins there?
+ foreach (var st in template.Strokes)
+ if (st.Color.Length == 8)
+ bordAlpha = st.Color.Substring(0, 2);
+ break;
@@ -813,7 +838,7 @@
l.LegendLabel = entry.Label;
foreach (var st in l.Strokes)
- st.Color = Utility.SerializeHTMLColor(entry.Color, true);
+ st.Color = bordAlpha + Utility.SerializeHTMLColor(entry.Color, string.IsNullOrEmpty(bordAlpha));
col.AddRule(l);
@@ -822,10 +847,20 @@
IAreaVectorStyle col = m_ruleCollection as IAreaVectorStyle;
IAreaRule template = null;
+ if (template.AreaSymbolization2D != null)
+ if (template.AreaSymbolization2D.Fill != null)
+ if (template.AreaSymbolization2D.Fill.ForegroundColor.Length == 8)
+ fillAlpha = template.AreaSymbolization2D.Fill.ForegroundColor.Substring(0, 2);
@@ -836,7 +871,7 @@
var r = (template != null) ? CreateAreaRule(template, _factory) : _factory.CreateDefaultAreaRule();
r.Filter = entry.Filter;
r.LegendLabel = entry.Label;
- r.AreaSymbolization2D.Fill.ForegroundColor = Utility.SerializeHTMLColor(entry.Color, true);
+ r.AreaSymbolization2D.Fill.ForegroundColor = fillAlpha + Utility.SerializeHTMLColor(entry.Color, string.IsNullOrEmpty(fillAlpha));
col.AddRule(r);
More information about the mapguide-commits
