[mapguide-commits] r6928 - trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics
svn_mapguide at osgeo.org
Tue Jul 31 07:10:42 PDT 2012
Author: jng
Date: 2012-07-31 07:10:41 -0700 (Tue, 31 Jul 2012)
New Revision: 6928
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.designer.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.resx
#2085: Remove the "Change Base Style" button from the Theme Creation dialog. The style that is created by this button is not even used or referenced in the theme generation code, so the button ultimately does nothing. The "template from first rule" approach is a much simpler way to setup the base style anyways, so we'll use that approach for setting base styles instead.
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs 2012-07-31 13:39:35 UTC (rev 6927)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs 2012-07-31 14:10:41 UTC (rev 6928)
@@ -52,7 +52,6 @@
private DataPropertyType m_dataType;
private object m_ruleCollection;
- private object m_defaultItem;
private static readonly Type[] NUMERIC_TYPES = null;
@@ -908,50 +907,6 @@
RefreshPreview();
- private void ChangeBaseStyleBtn_Click(object sender, EventArgs e)
- IVectorLayerDefinition vl = (IVectorLayerDefinition)m_layer.SubLayer;
- UserControl uc = null;
- if (m_ruleCollection is IPointVectorStyle)
- uc = new PointFeatureStyleEditor(m_editor, m_schema, vl.ResourceId);
- ((PointFeatureStyleEditor)uc).Item = (IPointSymbolization2D)Utility.XmlDeepCopy(m_defaultItem);
- ((PointFeatureStyleEditor)uc).SetupForTheming();
- else if (m_ruleCollection is ILineVectorStyle)
- uc = new LineFeatureStyleEditor(m_editor, m_schema, vl.ResourceId, _factory);
- var rule = _factory.CreateDefaultLineRule();
- ((LineFeatureStyleEditor)uc).Item = new List<IStroke>(rule.Strokes);
- ((LineFeatureStyleEditor)uc).SetupForTheming();
- else if (m_ruleCollection is IAreaVectorStyle)
- uc = new AreaFeatureStyleEditor(m_editor, m_schema, vl.ResourceId);
- ((AreaFeatureStyleEditor)uc).Item = (IAreaSymbolizationFill)Utility.XmlDeepCopy(m_defaultItem);
- ((AreaFeatureStyleEditor)uc).SetupForTheming();
- if (uc != null)
- EditorTemplateForm dlg = new EditorTemplateForm();
- dlg.ItemPanel.Controls.Add(uc);
- uc.Dock = DockStyle.Fill;
- dlg.RefreshSize();
- if (dlg.ShowDialog(this) == DialogResult.OK)
- m_defaultItem = ((PointFeatureStyleEditor)uc).Item;
- m_defaultItem = ((LineFeatureStyleEditor)uc).Item;
- m_defaultItem = ((AreaFeatureStyleEditor)uc).Item;
private void ColorBrewerDataType_SelectedIndexChanged(object sender, EventArgs e)
string prevSet = ColorBrewerColorSet.Text;
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.designer.cs 2012-07-31 13:39:35 UTC (rev 6927)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.designer.cs 2012-07-31 14:10:41 UTC (rev 6928)
@@ -52,7 +52,6 @@
this.GradientToColor = new Maestro.Editors.Common.ColorComboBox();
this.GradientFromColor = new Maestro.Editors.Common.ColorComboBox();
this.label4 = new System.Windows.Forms.Label();
- this.ChangeBaseStyleBtn = new System.Windows.Forms.Button();
this.ColorBrewerColors = new System.Windows.Forms.RadioButton();
this.GradientColors = new System.Windows.Forms.RadioButton();
this.PreviewGroup = new System.Windows.Forms.GroupBox();
@@ -180,7 +179,6 @@
this.DisplayGroup.Controls.Add(this.ColorBrewerPanel);
this.DisplayGroup.Controls.Add(this.ColorBrewerLabel);
this.DisplayGroup.Controls.Add(this.panel2);
- this.DisplayGroup.Controls.Add(this.ChangeBaseStyleBtn);
this.DisplayGroup.Controls.Add(this.ColorBrewerColors);
this.DisplayGroup.Controls.Add(this.GradientColors);
this.DisplayGroup.Name = "DisplayGroup";
@@ -249,13 +247,6 @@
resources.ApplyResources(this.label4, "label4");
this.label4.Name = "label4";
- // ChangeBaseStyleBtn
- resources.ApplyResources(this.ChangeBaseStyleBtn, "ChangeBaseStyleBtn");
- this.ChangeBaseStyleBtn.Name = "ChangeBaseStyleBtn";
- this.ChangeBaseStyleBtn.UseVisualStyleBackColor = true;
- this.ChangeBaseStyleBtn.Click += new System.EventHandler(this.ChangeBaseStyleBtn_Click);
// ColorBrewerColors
resources.ApplyResources(this.ColorBrewerColors, "ColorBrewerColors");
@@ -358,7 +349,6 @@
private System.Windows.Forms.Button CancelBtn;
private System.Windows.Forms.Button OKBtn;
private System.Windows.Forms.Panel panel2;
- private System.Windows.Forms.Button ChangeBaseStyleBtn;
private System.Windows.Forms.RadioButton ColorBrewerColors;
private System.Windows.Forms.RadioButton GradientColors;
private CustomCombo ColorBrewerColorSet;
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.resx
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.resx 2012-07-31 13:39:35 UTC (rev 6927)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.resx 2012-07-31 14:10:41 UTC (rev 6928)
@@ -648,30 +648,6 @@
<data name=">>panel2.ZOrder" xml:space="preserve">
<value>2</value>
</data>
- <data name="ChangeBaseStyleBtn.Location" type="System.Drawing.Point, System.Drawing">
- <value>16, 80</value>
- </data>
- <data name="ChangeBaseStyleBtn.Size" type="System.Drawing.Size, System.Drawing">
- <value>112, 23</value>
- </data>
- <data name="ChangeBaseStyleBtn.TabIndex" type="System.Int32, mscorlib">
- <value>2</value>
- </data>
- <data name="ChangeBaseStyleBtn.Text" xml:space="preserve">
- <value>Change base style</value>
- </data>
- <data name=">>ChangeBaseStyleBtn.Name" xml:space="preserve">
- <value>ChangeBaseStyleBtn</value>
- </data>
- <data name=">>ChangeBaseStyleBtn.Type" xml:space="preserve">
- <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>ChangeBaseStyleBtn.Parent" xml:space="preserve">
- <value>DisplayGroup</value>
- </data>
- <data name=">>ChangeBaseStyleBtn.ZOrder" xml:space="preserve">
- <value>3</value>
- </data>
<data name="ColorBrewerColors.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
@@ -694,7 +670,7 @@
</data>
<data name=">>ColorBrewerColors.ZOrder" xml:space="preserve">
- <value>4</value>
+ <value>3</value>
</data>
<data name="GradientColors.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
@@ -721,7 +697,7 @@
</data>
<data name=">>GradientColors.ZOrder" xml:space="preserve">
- <value>5</value>
+ <value>4</value>
</data>
<data name="DisplayGroup.Location" type="System.Drawing.Point, System.Drawing">
<value>8, 152</value>
More information about the mapguide-commits
