[mapguide-commits] r6737 - trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc
svn_mapguide at osgeo.org
Fri Jun 8 02:04:30 PDT 2012
Author: jng
Date: 2012-06-08 02:04:29 -0700 (Fri, 08 Jun 2012)
New Revision: 6737
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs
Add mental note for #2002
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs 2012-06-07 10:47:13 UTC (rev 6736)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs 2012-06-08 09:04:29 UTC (rev 6737)
@@ -308,7 +308,9 @@
try
- var desc = _fs.Describe();
+ //#2002 TODO: Here is where we would present a list of classes in order to be able to create a filtered down
+ //logical schema
+ var desc = _fs.Describe(); //TODO: Describe only the selected class names
if (desc.Schemas.Length == 0)
throw new ApplicationException("Could not retrieve any schemas from this connection. If it is a DSN, ensure it is a valid DSN");
_doc.AddSchema(desc.Schemas[0]); //Only one schema is supported by ODBC so this is ok
More information about the mapguide-commits
